进入MASKROM模式,EraseFlash,再刷贵公司的ROC-RK3308B-CC-PLUS_ROOTFS-EXT2-Qt-rgb_7.0inch-20201022.img固件,重启信息如下:(后面多了几行内容,中间多一些内容,供判断参考,谢谢!)
DDR Version V1.29 20190730
REG2C: 0x00000033, 0x00000034
589MHz
DDR3
Col=10 Bank=3 Row=14 Size=256MB
msch:1
Boot1 Release Time: Oct 28 2019 20:02:13, version: 1.19
chip_id:330800,0
ChipType = 0x13, 35790989
DPLL = 1300 MHz
sfc nor id: ff ff ff
DPLL = 1300 MHz
sfc_nand id: ff ff ff
DPLL = 1300 MHz
…nandc_flash_init enter…
NeedKHz=200KHz,clock=12000KHz
DPLL = 1300 MHz
NeedKHz=18000KHz,clock=650000KHz
DPLL = 1300 MHz
NeedKHz=48000KHz,clock=650000KHz
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=3728MB
FwPartOffset=2000 , 2000
SdmmcInit=0 NOT PRESENT
StorageInit ok = 35778354
SecureMode = 0
Secure read PBA: 0x4
Secure read PBA: 0x404
Secure read PBA: 0x804
Secure read PBA: 0xc04
Secure read PBA: 0x1004
atags_set_bootdev: ret:(0)
GPT part: 0, name: uboot, start:0x2000, size:0x1000
GPT part: 1, name: trust, start:0x3000, size:0x1000
GPT part: 2, name: misc, start:0x4000, size:0x800
GPT part: 3, name: recovery, start:0x4800, size:0x10000
GPT part: 4, name: boot, start:0x14800, size:0x4800
GPT part: 5, name: rootfs, start:0x20000, size:0x80000
GPT part: 6, name: oem, start:0xa0000, size:0x20000
GPT part: 7, name: userdata, start:0xc0000, size:0x687fdf
find part:uboot OK. first_lba:0x2000.
find part:trust OK. first_lba:0x3000.
LoadTrust Addr:0x3000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x600000, size=0xb7704
RunBL31 0x40000 @ 35737107 us
INFO: Preloader serial: 4
NOTICE: BL31: v1.3(release):30f1405
NOTICE: BL31: Built : 17:08:28, Sep 23 2019
INFO: Lastlog: last=0x100000, realtime=0x102000, size=0x2000
INFO: ARM GICv2 driver initialized
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe b
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: Entry point address = 0x600000
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Oct 21 2020 - 17:08:50 +0800)
Model: Rockchip RK3308 EVB
PreSerial: 4
DRAM: 254 MiB
Sysmem: init
Relocation Offset is: 0d80b000
dwmmc@ff480000: 1, dwmmc@ff490000: 0
Bootdev(atags): mmc 0
MMC0: High Speed, 52Mhz
PartType: EFI
boot mode: None
Found DTB in boot part
DTB: rk-kernel.dtb
Error binding driver ‘fixed regulator’: -22
Some drivers failed to bind
vdd_core init 1015000 uV
DVFS: cpu: low=0.0’c, high=55.0’c, Vmax=1340000uV, tz_temp=55.0’c, h_repeat=0, l_repeat=0
DVFS: 42.272’c
Model: Firefly ROC-RK3308B-CC-PLUS analog mic rgb_7.0inch board
Using display timing dts
Detailed mode clock 51200 kHz, flags[a]
H: 1024 1067 1069 1114
V: 0600 0603 0605 0610
bus_format: 100a
“Synchronous Abort” handler, esr 0x96000010
- Reason: Exception from a Data abort, from current exception level
- PC = 0000000000625adc
- LR = 0000000000625b58
- SP = 000000000d3ffc10
- ESR_EL2 = 0000000096000010
- Reloc Off = 000000000d80b000
x0 : ffffffffffffffea x1 : 000000000de99ddb
x2 : 0000000000000000 x3 : 0000000000000002
x4 : 0000000000000000 x5 : 0000000001f1186c
x6 : 0000000000000008 x7 : 0000000000000010
x8 : 0000000000000000 x9 : 0000000000000008
x10: 0000000000000258 x11: 000000000000045a
x12: 000000000000042b x13: 0000000000000200
x14: 0000000000000030 x15: 00000000ffffffff
x16: 0000000000000001 x17: 0000000001f16804
x18: 000000000d402d10 x19: 0000000000000004
x20: 0000000001f0575c x21: 0000000000000002
x22: 000000000d3ffed0 x23: 0000000001f05748
x24: 0000000000000001 x25: 000000000de99ddb
x26: ffffffffffffffea x27: 0000000000000262
x28: 000000000d456770 x29: 000000000d3ffdf0
Call trace:
PC: [< 00625adc >]
LR: [< 00625b58 >]
Stack:
[< 00625adc >]
[< 00625b58 >]
[< 0062609c >]
[< 00626180 >]
[< 006278d4 >]
[< 00627004 >]
[< 006216dc >]
[< 00641cb4 >]
[< 006406b0 >]
[< 006406d8 >]
[< 00640dec >]
[< 006028e8 >]
[< 00663778 >]
[< 006126cc >]
[< 00601b2c >]
Copy info from “Call trace…” to a file(eg. dump.txt), and run
command in your U-Boot project: ./scripts/stacktrace.sh dump.txt
Resetting CPU …
INFO: PSCI Power Domain Map:
INFO: Domain Node : Level 2, parent_node -1, State ON (0x0)
INFO: Domain Node : Level 1, parent_node 0, State ON (0x0)
INFO: Domain Node : Level 0, parent_node 0, State ON (0x0)
INFO: CPU Node : MPID 0x0, parent_node 1, State ON (0x0)
INFO: CPU Node : MPID 0xffffffffffffffff, parent_node 1, State OFF (0x2)
589MHz
DDR3
msch:1
chip_id:330800,0
ChipType = 0x13, 35790988
DPLL = 1300 MHz
DPLL = 1300 MHz
DPLL = 1300 MHz
DPLL = 1300 MHz
DPLL = 1300 MHz
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=3728MB
StorageInit ok = 35778346
SecureMode = 0
No find bl30.bin
No find bl32.bin
RunBL31 0x40000 @ 35737102 us
INFO: SPSR = 0x3c9
PreSerial: 4
DRAM: 254 MiB
Sysmem: init
PartType: EFI
boot mode: None
DTB: rk-kernel.dtb
DVFS: 42.727’c
bus_format: 100a
“Synchronous Abort” handler, esr 0x96000004
- PC = 000000000062605c
- LR = 000000000062606c
- SP = 000000000d3ffc20
- ESR_EL2 = 0000000096000004
x0 : 006c7274636e6970 x1 : 000000000d422b90
x2 : 000000000d422bc8 x3 : 0000000000000085
x4 : 0000000000000001 x5 : 0000000000000048
x6 : 000000000dea9c78 x7 : 0000000000000000
x8 : 000000000dea9bb0 x9 : 0000000000000008
x10: 0000000000000016 x11: 0000000000000001
x12: 000000000dea99d0 x13: 000000000dea9958
x14: 0000000000000000 x15: 00000000ffffffff
x16: 000000000de8a830 x17: 0000000000000000
x18: 000000000d402d10 x19: 0000000000000016
x20: 000000000d3ffec0 x21: 0000000000000078
x22: 0000000000000010 x23: 0000000000000000
x24: 0000000000f00000 x25: 0000000000000020
x26: 000000000dea9bb0 x27: 0000000000000085
x28: 000000000d445220 x29: 000000000d3ffe00
Call trace:
PC: [< 0062605c >]
LR: [< 0062606c >]
Stack:
[< 0062605c >]
[< 00627664 >]
[< 00629e08 >]
[< 00628d24 >]
[< 006477cc >]
[< 00640818 >]
[< 00640dec >]
[< 006028e8 >]
[< 00663778 >]
[< 006126cc >]
[< 00601b2c >]
Resetting CPU …
589MHz
DDR3
msch:1
chip_id:330800,0
DPLL = 1300 MHz
DPLL = 1300 MHz
DPLL = 1300 MHz
DPLL = 1300 MHz
DPLL = 1300 MHz
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=3728MB
StorageInit ok = 35778356
SecureMode = 0
No find bl30.bin
No find bl32.bin
RunBL31 0x40000 @ 35737114 us
INFO: SPSR = 0x3c9
PreSerial: 4
DRAM: 254 MiB
Sysmem: init
PartType: EFI
boot mode: None
DTB: rk-kernel.dtb
DVFS: 44.545’c
bus_format: 100a
CLK: (uboot. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
apll 816000 KHz
dpll 1300000 KHz
vpll0 1177823 KHz
vpll1 901583 KHz
aclk_bus 185714 KHz
hclk_bus 100000 KHz
pclk_bus 100000 KHz
aclk_peri 185714 KHz
hclk_peri 100000 KHz
pclk_peri 100000 KHz
hclk_audio 98151 KHz
pclk_audio 98151 KHz
Net: eth0: ethernet@ff4e0000
DVFS: cpu 44.90’c, 816000000 Hz, 1015000 uV
Fdt Ramdisk skip relocation
Booting LZ4 kernel at 0x02480000(Uncompress to 0x00280000) with fdt at 0x1f00000…
## Booting Android Image at 0x0247f800 …
Kernel load addr 0x00280000 size 5241 KiB
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Uncompressing Kernel Image … OK
Using Device Tree in place at 0000000001f00000, end 0000000001f16746
Can’t find file:
Adding bank: 0x00200000 - 0x10000000 (size: 0x0fe00000)
Total: 449.993 ms
[ 0.000000] Linux version 4.4.143 (zhengyk@mid-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #214 SMP PREEMPT Tue Oct 20 09:48:07 CST 2020
[ 0.000000] Boot CPU: AArch64 Processor [410fd042]
[ 0.000000] earlycon: Early serial console at MMIO32 0xff0e0000 (options ‘’)
[ 0.000000] PERCPU: Embedded 19 pages/cpu @ffffffc00ff43000 s40088 r8192 d29544 u77824
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64008
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=c3d9b8674f4b94f6 rootwait earlycon=uart8250,mmio32,0xff0e0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext2 snd_aloop.index=7 snd_aloop.use_raw_jiffies=1
[ 0.000000] PID hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.000000] software IO TLB [mem 0x0fea3000-0x0fee3000] (0MB) mapped at [ffffffc00fea3000-ffffffc00fee2fff]
[ 0.000000] Memory: 243296K/260096K available (6462K kernel code, 690K rwdata, 2436K rodata, 384K init, 511K bss, 16800K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8008940000 - 0xffffff80089a0000 ( 384 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff80086d0000 ( 6464 KB)
[ 0.000000] .rodata : 0xffffff80086d0000 - 0xffffff8008940000 ( 2496 KB)
[ 0.000000] .data : 0xffffff80089a0000 - 0xffffff8008a4c808 ( 691 KB)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc010000000 ( 254 MB)
[ 0.001971] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.002921] pid_max: default: 32768 minimum: 301
[ 0.003484] Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.004087] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.005550] sched-energy: CPU device node has no sched-energy-costs
[ 0.006173] Invalid sched_group_energy for CPU0
[ 0.006591] CPU0: update cpu_capacity 1024
[ 0.007015] ASID allocator initialised with 65536 entries
[ 0.016752] Detected VIPT I-cache on CPU1
[ 0.016807] Invalid sched_group_energy for CPU1
[ 0.016813] CPU1: update cpu_capacity 1024
[ 0.016817] CPU1: Booted secondary processor [410fd042]
[ 0.019775] Detected VIPT I-cache on CPU2
[ 0.019810] Invalid sched_group_energy for CPU2
[ 0.019814] CPU2: update cpu_capacity 1024
[ 0.019818] CPU2: Booted secondary processor [410fd042]
[ 0.022818] Detected VIPT I-cache on CPU3
[ 0.022853] Invalid sched_group_energy for CPU3
[ 0.022858] CPU3: update cpu_capacity 1024
[ 0.022862] CPU3: Booted secondary processor [410fd042]
[ 0.022934] Brought up 4 CPUs
[ 0.028140] SMP: Total of 4 processors activated.
[ 0.028579] CPU: All CPU(s) started at EL2
[ 0.029087] Invalid sched_group_energy for CPU3
[ 0.029507] Invalid sched_group_energy for Cluster3
[ 0.029955] Invalid sched_group_energy for CPU2
[ 0.030384] Invalid sched_group_energy for Cluster2
[ 0.030834] Invalid sched_group_energy for CPU1
[ 0.031250] Invalid sched_group_energy for Cluster1
[ 0.031707] Invalid sched_group_energy for CPU0
[ 0.032123] Invalid sched_group_energy for Cluster0
[ 0.033133] devtmpfs: initialized
[ 0.054784] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.055729] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.056691] pinctrl core: initialized pinctrl subsystem
[ 0.058317] NET: Registered protocol family 16
[ 0.063286] cpuidle: using governor menu
[ 0.063681] Registered FIQ tty driver
[ 0.064466] vdso: 2 pages (1 code @ ffffff80086d6000, 1 data @ ffffff80089a4000)
[ 0.065171] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.066012] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.069005] console [pstore-1] enabled
[ 0.069356] pstore: Registered ramoops as persistent store backend
[ 0.069939] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.091176] fiq debugger fiq mode enabled
[[ 0.091956] console [ttyFIQ0] enabled
[ 0.092652] bootconsole [uart0] disabled
[ 0.093282] Registered fiq debugger ttyFIQ0
WARNING: suspend_mode_handler: Not support call: 0x4
[ 0.129456] vcc_1v8: regulator get failed, ret=-517
[ 0.130420] vcc_1v8_codec: regulator get failed, ret=-517
[ 0.131347] vcc_1v8: supplied by vcc_io
[ 0.131460] vcc_1v8_codec: supplied by vcc_io
[ 0.133683] usb_hub_rst: Failed to create debugfs directory
[ 0.134896] SCSI subsystem initialized
[ 0.135199] usbcore: registered new interface driver usbfs
[ 0.135274] usbcore: registered new interface driver hub
[ 0.135429] usbcore: registered new device driver usb
[ 0.135625] pps_core: LinuxPPS API ver. 1 registered
[ 0.135638] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.135672] PTP clock support registered
[ 0.136987] Advanced Linux Sound Architecture Driver Initialized.
[ 0.137731] Bluetooth: Core ver 2.21
[ 0.137802] NET: Registered protocol family 31
[ 0.137814] Bluetooth: HCI device and connection manager initialized
[ 0.137834] Bluetooth: HCI socket layer initialized
[ 0.137849] Bluetooth: L2CAP socket layer initialized
[ 0.137883] Bluetooth: SCO socket layer initialized
[ 0.139005] rockchip-cpuinfo cpuinfo: Serial : c65b8d386fb58f94
[ 0.139829] clocksource: Switched to clocksource arch_sys_counter
[ 0.142350] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.142703] NET: Registered protocol family 2
[ 0.143440] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.143502] TCP bind hash table entries: 2048 (order: 3, 32768 bytes)
[ 0.143562] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.143650] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.143681] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.143929] NET: Registered protocol family 1
[ 0.145030] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.156559] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.156897] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.160343] io scheduler noop registered (default)
[ 0.161586] phy phy-ff008000.syscon:usb2-phy@100.0: Failed to get VBUS supply regulator
[ 0.165471] backlight supply power not found, using dummy regulator
[ 0.167380] dma-pl330 ff2c0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.167420] dma-pl330 ff2c0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.169925] dma-pl330 ff2d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.169966] dma-pl330 ff2d0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.170320] rockchip-pvtm ff000000.grf:pmu-pvtm: failed to get rst 0 pmu
[ 0.170478] rockchip-pvtm ff00c000.syscon:pvtm: failed to get rst 0 core
[ 0.172051] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.175228] [drm] Initialized drm 1.1.0 20060810
[ 0.175349] random: nonblocking pool is initialized
[ 0.177502] [drm] Rockchip DRM driver version: v1.0.1
[ 0.177769] rockchip-drm display-subsystem: devfreq is not set
[ 0.178046] rockchip-vop ff2e0000.vop: missing rockchip,grf property
[ 0.178296] rockchip-drm display-subsystem: bound ff2e0000.vop (ops 0xffffff800873ebe8)
[ 0.178482] rockchip-rgb rgb: [drm:rockchip_rgb_bind] ERROR failed to find panel or bridge: -517
[ 0.178510] rockchip-drm display-subsystem: failed to bind rgb (ops 0xffffff8008736bb8): -517
[ 0.178714] rockchip-drm display-subsystem: master bind failed: -517
[ 0.180772] panel supply power not found, using dummy regulator
[ 0.181514] Unable to detect cache hierarchy for CPU 0
[ 0.188854] loop: module loaded
[ 0.189220] SCSI Media Changer driver v0.25
[ 0.191411] rk_gmac-dwmac ff4e0000.ethernet: clock input or output? (input).
[ 0.191461] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: tx_delay.
[ 0.191478] rk_gmac-dwmac ff4e0000.ethernet: set tx_delay to 0x30
[ 0.191495] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: rx_delay.
[ 0.191510] rk_gmac-dwmac ff4e0000.ethernet: set rx_delay to 0x10
[ 0.191534] rk_gmac-dwmac ff4e0000.ethernet: integrated PHY? (no).
[ 0.191795] rk_gmac-dwmac ff4e0000.ethernet: clock input from PHY
[ 0.196860] rk_gmac-dwmac ff4e0000.ethernet: init for RMII
[ 0.197009] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.197026] Ring mode enabled
[ 0.197037] DMA HW capability register supported
[ 0.197046] Normal descriptors
[ 0.197058] RX Checksum Offload Engine supported (type 2)
[ 0.197068] TX Checksum insertion supported
[ 0.197077] Wake-Up On Lan supported
[ 0.197139] Enable RX Mitigation via HW Watchdog Timer
[ 0.200733] libphy: stmmac: probed
[ 0.200765] eth%d: PHY ID 001cc816 at 0 IRQ POLL (stmmac-0:00) active
[ 0.200784] eth%d: PHY ID 001cc816 at 1 IRQ POLL (stmmac-0:01)
[ 0.202074] Rockchip WiFi SYS interface (V1.00) …
[ 0.202220] usbcore: registered new interface driver r8152
[ 0.202302] usbcore: registered new interface driver asix
[ 0.202377] usbcore: registered new interface driver ax88179_178a
[ 0.202451] usbcore: registered new interface driver cdc_ether
[ 0.202513] usbcore: registered new interface driver net1080
[ 0.202574] usbcore: registered new interface driver cdc_subset
[ 0.202643] usbcore: registered new interface driver zaurus
[ 0.202762] usbcore: registered new interface driver cdc_ncm
[ 0.202853] usbcore: registered new interface driver qmi_wwan
[ 0.203317] ff400000.usb supply vusb_d not found, using dummy regulator
[ 0.203408] ff400000.usb supply vusb_a not found, using dummy regulator
[ 0.317904] dwc2 ff400000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 0.318432] dwc2 ff400000.usb: DWC OTG Controller
[ 0.318482] dwc2 ff400000.usb: new USB bus registered, assigned bus number 1
[ 0.318530] dwc2 ff400000.usb: irq 22, io mem 0xff400000
[ 0.319499] hub 1-0:1.0: USB hub found
[ 0.319556] hub 1-0:1.0: 1 port detected
[ 0.543317] phy phy-ff008000.syscon:usb2-phy@100.0: charger = USB_SDP_CHARGER
[ 0.543582] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.543607] ehci-platform: EHCI generic platform driver
[ 0.547491] ehci-platform ff440000.usb: EHCI Host Controller
[ 0.547546] ehci-platform ff440000.usb: new USB bus registered, assigned bus number 2
[ 0.547704] ehci-platform ff440000.usb: irq 23, io mem 0xff440000
[ 0.552864] ehci-platform ff440000.usb: USB 2.0 started, EHCI 1.00
[ 0.553812] hub 2-0:1.0: USB hub found
[ 0.553895] hub 2-0:1.0: 1 port detected
[ 0.554551] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.554611] ohci-platform: OHCI generic platform driver
[ 0.555085] ohci-platform ff450000.usb: Generic Platform OHCI controller
[ 0.555137] ohci-platform ff450000.usb: new USB bus registered, assigned bus number 3
[ 0.555276] ohci-platform ff450000.usb: irq 24, io mem 0xff450000
[ 0.610736] hub 3-0:1.0: USB hub found
[ 0.610795] hub 3-0:1.0: 1 port detected
[ 0.611459] usbcore: registered new interface driver cdc_wdm
[ 0.611547] usbcore: registered new interface driver uas
[ 0.611685] usbcore: registered new interface driver usb-storage
[ 0.611752] usbcore: registered new interface driver ums-alauda
[ 0.611812] usbcore: registered new interface driver ums-cypress
[ 0.611904] usbcore: registered new interface driver ums-datafab
[ 0.611970] usbcore: registered new interface driver ums_eneub6250
[ 0.612030] usbcore: registered new interface driver ums-freecom
[ 0.612096] usbcore: registered new interface driver ums-isd200
[ 0.612162] usbcore: registered new interface driver ums-jumpshot
[ 0.612220] usbcore: registered new interface driver ums-karma
[ 0.612282] usbcore: registered new interface driver ums-onetouch
[ 0.612344] usbcore: registered new interface driver ums-sddr09
[ 0.612409] usbcore: registered new interface driver ums-sddr55
[ 0.612470] usbcore: registered new interface driver ums-usbat
[ 0.612610] usbcore: registered new interface driver usbserial
[ 0.612679] usbcore: registered new interface driver option
[ 0.612728] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.614031] i2c /dev entries driver
[ 0.855862] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 0.917898] rk3x-i2c ff040000.i2c: Initialized RK3xxx I2C bus at ffffff8008b36000
[ 0.918980] rtc-pcf8563 1-0051: chip found, driver version 0.4.4
[ 0.930464] rtc-pcf8563 1-0051: pcf8563_write_block_data: err=-6 addr=0e, data=03
[ 0.930491] rtc-pcf8563 1-0051: pcf8563_probe: write error
[ 0.930541] rtc-pcf8563: probe of 1-0051 failed with error -5
[ 0.930581] rk3x-i2c ff050000.i2c: Initialized RK3xxx I2C bus at ffffff8008b38000
[ 0.931956] IR NEC protocol handler initialized
[ 0.931981] IR RC5(x/sz) protocol handler initialized
[ 0.931998] IR RC6 protocol handler initialized
[ 0.932014] IR JVC protocol handler initialized
[ 0.932032] IR Sony protocol handler initialized
[ 0.932050] IR SANYO protocol handler initialized
[ 0.932068] IR Sharp protocol handler initialized
[ 0.932085] IR MCE Keyboard/mouse protocol handler initialized
[ 0.932102] IR XMP protocol handler initialized
[ 0.932795] Registered IR keymap rc-empty
[ 0.932976] rc rc0: gpio_ir_recv as /devices/platform/ir_rx/rc/rc0
[ 0.933694] input: gpio_ir_recv as /devices/platform/ir_rx/rc/rc0/input0
[ 0.934191] rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
[ 0.934954] rc rc1: PWM IR Transmitter as /devices/platform/ir_tx/rc/rc1
[ 0.935171] rc rc1: lirc_dev: driver pwm-ir-tx registered at minor = 1, no receiver, raw IR transmitter
[ 0.938137] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 0.938390] rockchip-thermal ff1f0000.tsadc: tsadc is probed successfully!
[ 0.939045] Bluetooth: HCI UART driver ver 2.3
[ 0.939074] Bluetooth: HCI UART protocol H4 registered
[ 0.939086] Bluetooth: HCI UART protocol LL registered
[ 0.939356] cpu cpu0: leakage=18
[ 0.939623] cpu cpu0: Failed to get pvtm
[ 0.940990] cpu cpu0: l=0 h=55000 hyst=5000 l_limit=1200000000 h_limit=1008000000
[ 0.942493] Synopsys Designware Multimedia Card Interface Driver
[ 0.944343] dwmmc_rockchip ff480000.dwmmc: num-slots property not found, assuming 1 slot is available
[ 0.944503] dwmmc_rockchip ff480000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.944568] dwmmc_rockchip ff480000.dwmmc: Using internal DMA controller.
[ 0.944594] dwmmc_rockchip ff480000.dwmmc: Version ID is 270a
[ 0.944672] dwmmc_rockchip ff480000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 0.945522] rockchip-iodomain ff000000.grf:io-domains: Setting to 3300000 done
[ 0.945563] rockchip-iodomain ff000000.grf:io-domains: Setting to 3300000 done
[ 0.955966] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.967011] dwmmc_rockchip ff480000.dwmmc: 1 slots initialized
[ 0.967172] rockchip-iodomain ff000000.grf:io-domains: Setting to 3300000 done
[ 0.967207] rockchip-iodomain ff000000.grf:io-domains: Setting to 3300000 done
[ 0.967220] set vqmmc to 3.3v, ret=0
[ 0.968001] dwmmc_rockchip ff490000.dwmmc: No default pinctrl state
[ 0.968020] dwmmc_rockchip ff490000.dwmmc: No off pinctrl state
[ 0.968153] dwmmc_rockchip ff490000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.968207] dwmmc_rockchip ff490000.dwmmc: Using internal DMA controller.
[ 0.968230] dwmmc_rockchip ff490000.dwmmc: Version ID is 270a
[ 0.968300] dwmmc_rockchip ff490000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 0.968385] dwmmc_rockchip ff490000.dwmmc: No vmmc regulator found
[ 0.968401] dwmmc_rockchip ff490000.dwmmc: No vqmmc regulator found
[ 0.975758] hub 2-1:1.0: USB hub found
[ 0.975939] hub 2-1:1.0: 4 ports detected
[ 0.978940] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.987303] Unable to handle kernel paging request at virtual address dffeef76ffef6f6d
[ 0.988003] pgd = ffffff8008ad0000
[ 0.988144] Unable to handle kernel paging request at virtual addre[ 0.988147] pgd = ffffff8008ad0000
[ 0.988157] [ffffef80089b59c8] *pgd=000000000fffe003, *pud=000000000fffe003, *pmd=000000000fffb003, *pte=00e8000000bb5713
[ 0.988162] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[ 0.988168] Modules linked in:
[ 0.988177] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.143 #214
