[ 3.630017] pci 0002:21:00.0: reg 0x18: [mem 0x00000000-0x003fffff 64bit]
[ 3.630478] pci 0002:21:00.0: supports D1 D2
[ 3.630481] pci 0002:21:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 3.658383] pci_bus 0002:21: busn_res: [bus 21-2f] end is updated to 21
[ 3.658403] pci 0002:20:00.0: BAR 8: assigned [mem 0xf2200000-0xf27fffff]
[ 3.658407] pci 0002:20:00.0: BAR 6: assigned [mem 0xf2800000-0xf280ffff pref]
[ 3.658414] pci 0002:21:00.0: BAR 2: assigned [mem 0xf2400000-0xf27fffff 64bit]
[ 3.658451] pci 0002:21:00.0: BAR 0: assigned [mem 0xf2200000-0xf220ffff 64bit]
[ 3.658488] pci 0002:20:00.0: PCI bridge to [bus 21]
[ 3.658492] pci 0002:20:00.0: bridge window [mem 0xf2200000-0xf27fffff]
[ 3.658847] pcie20_avdd0v85: supplied by avdd_0v85_s0
[ 3.659117] mali fb000000.gpu: Kernel DDK version g11p0-01eac0
[ 3.659377] pcieport 0002:20:00.0: PME: Signaling with IRQ 163
[ 3.659600] pcie20_avdd1v8: supplied by avcc_1v8_s0
[ 3.660689] pcie30_avdd0v75: supplied by avdd_0v75_s0
[ 3.660819] mali fb000000.gpu: leakage=18
[ 3.661207] pcie30_avdd1v8: supplied by avcc_1v8_s0
[ 3.661679] vcc3v3_lcd0_n: supplied by vcc_1v8_s0
[ 3.662315] mali fb000000.gpu: pvtm=806
[ 3.662394] mali fb000000.gpu: pvtm-volt-sel=0
[ 3.663415] mali fb000000.gpu: avs=0
[ 3.663577] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 132; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 3.664082] mali fb000000.gpu: r0p0 status 5 is unknown; treating as r0p0 status 0
[ 3.664131] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0
[ 3.664356] mali fb000000.gpu: No priority control manager is configured
[ 3.664386] mali fb000000.gpu: No memory group manager is configured
[ 3.664456] mali fb000000.gpu: Protected memory allocator not available
[ 3.667191] mali fb000000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 3.668835] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 2
[ 3.668854] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 3
[ 3.668879] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 8
[ 3.668893] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 9
[ 3.669304] [drm] failed to init overlay plane Cluster0-win1
[ 3.669356] [drm] failed to init overlay plane Cluster1-win1
[ 3.669405] [drm] failed to init overlay plane Cluster2-win1
[ 3.669455] [drm] failed to init overlay plane Cluster3-win1
[ 3.669733] mali fb000000.gpu: Probed as mali0
[ 3.693256] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffffffc011141968)
[ 3.695535] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver
[ 3.696811] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffffffc011149628)
[ 3.698815] dwhdmi-rockchip fdea0000.hdmi: registered ddc I2C bus driver
[ 3.699826] debugfs: Directory ‘dw-hdmi’ with parent ‘/’ already present!
[ 3.699850] dwhdmi-rockchip fdea0000.hdmi: failed to create debugfs dir!
[ 3.699901] rockchip-drm display-subsystem: bound fdea0000.hdmi (ops 0xffffffc011149628)
[ 3.699929] dw-mipi-dsi2 fde20000.dsi: [drm:dw_mipi_dsi2_bind] ERROR Failed to find panel or bridge: -517
[ 3.704881] input: adc-keys as /devices/platform/adc-keys/input/input3
[ 3.710403] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 2
[ 3.710426] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 3
[ 3.710479] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 8
[ 3.710488] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 9
[ 3.710737] [drm] failed to init overlay plane Cluster0-win1
[ 3.710770] [drm] failed to init overlay plane Cluster1-win1
[ 3.710801] [drm] failed to init overlay plane Cluster2-win1
[ 3.710832] [drm] failed to init overlay plane Cluster3-win1
[ 3.722978] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffffffc011141968)
[ 3.725168] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver
[ 3.725988] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffffffc011149628)
[ 3.727935] dwhdmi-rockchip fdea0000.hdmi: registered ddc I2C bus driver
[ 3.728636] debugfs: Directory ‘dw-hdmi’ with parent ‘/’ already present!
[ 3.728644] dwhdmi-rockchip fdea0000.hdmi: failed to create debugfs dir!
[ 3.728722] rockchip-drm display-subsystem: bound fdea0000.hdmi (ops 0xffffffc011149628)
[ 3.728758] rockchip-drm display-subsystem: bound fde20000.dsi (ops 0xffffffc01114b540)
[ 3.728825] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffffffc01114b948)
[ 3.728866] rockchip-drm display-subsystem: bound fde60000.dp (ops 0xffffffc01114b948)
[ 3.729892] get_framebuffer_by_node: failed to get logo,offset
[ 3.729902] get_framebuffer_by_node: failed to get logo,offset
[ 3.779980] rockchip-vop2 fdd90000.vop: [drm:vop2_wait_power_domain_off] ERROR wait pd7 off timeout power_ctrl: 0x23230039
[ 3.966267] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[ 3.968768] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
[ 3.972156] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card2/input4
[ 3.976805] input: rockchip-hdmi1 rockchip-hdmi1 as /devices/platform/hdmi1-sound/sound/card3/input5
[ 3.979695] rkcif rkcif-mipi-lvds: clear unready subdev num: 1
[ 3.979738] rockchip-csi2-dphy0: No link between dphy and sensor
[ 3.980317] rockchip-csi2-dphy0: No link between dphy and sensor
[ 3.980347] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 3.980357] rkcif-mipi-lvds: Async subdev notifier completed
[ 3.980368] rockchip-csi2-dphy0: No link between dphy and sensor
[ 3.980397] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 3.980407] rkcif-mipi-lvds: There is not terminal subdev, not synchronized with ISP
[ 3.981778] RKNPU fdab0000.npu: Adding to iommu group 0
[ 3.981964] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 3.982711] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdab0000-0xfdabffff]
[ 3.982737] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdac0000-0xfdacffff]
[ 3.982767] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdad0000-0xfdadffff]
[ 3.983363] [drm] Initialized rknpu 0.6.4 20211227 for fdab0000.npu on minor 1
[ 3.985143] RKNPU fdab0000.npu: leakage=9
[ 3.986710] RKNPU fdab0000.npu: pvtm=836
[ 3.986766] RKNPU fdab0000.npu: pvtm-volt-sel=0
[ 3.988094] RKNPU fdab0000.npu: avs=0
[ 3.988297] RKNPU fdab0000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 3.988810] RKNPU fdab0000.npu: failed to find power_model node
[ 3.988822] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
[ 3.988829] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
[ 3.989373] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.996666] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 3.997643] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.997671] cfg80211: failed to load regulatory.db
[ 3.998095] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 3.999369] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 405; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘01:12:18’, on ‘Jun 27 2022’.
[ 3.999937] Mali:
[ 3.999942] Mali device driver loaded
[ 3.999960] rkisp rkisp0-vir0: clear unready subdev num: 1
[ 4.000429] rkisp0-vir0: Async subdev notifier completed
v▒ 4.002251]
不清楚什么原因,操作流程是什么?
log信息不全,无法判断
