我下载的Linux SDK :linux_release_v0.0.1a ,这个版本的代码不支持MIPI屏吗?没有 itx-3588j-BE45-A1-ubuntu.mk这个文件?
有的,请更新 SDK
Liuth 发表于 2022-6-27 10:48
有的,请更新 SDK
谢谢您的回复,我是一定要更新到SDK b吗?在linux_release_v0.0.1a上如何改?
一定要更新,更新到最新,应该是1.0.0c了吧
0.0.1是最初的版本,很多问题的
我申请的Linux_SDK, 在百度网盘上有个一个版本:rk3588_repo_sdk_v0.1.0a.7Z 和一个rk3588_repo_sdk_v0.0.1a.7Z,我该怎么获取您说的1.0.0c版本?
网盘上的说明文档里面应该有说怎么更新吧?
root@liuyi5-QiTianM415-D071:/home/liuyi5/3588/Linux_SDK-o/rk3588# .repo/repo/repo sync -c --no-tags
ssh: connect to host git.t-firefly.com port 8022: Connection timed out
fatal: 无法读取远程仓库。
请确认您有正确的访问权限并且仓库存在。
fatal: 无法读取远程仓库。
请确认您有正确的访问权限并且仓库存在。
Fetching project app/qcamera
Fetching project external/drm-cursor
Fetching project external/app
Fetching project external/rk_pcba_test
Fetching project external/chromium
Fetching project u-boot
Fetching project external/pcba_adb_test
Fetching project external/xserver
Fetching project external/rkupdate
Fetching project prebuilts/gcc/linux-x86/aarch64/gcc-arm-10.3-2021.07-x86_64-aarch64-none-linux-gnu
Fetching projects: 12% (7/55) Fetching project external/security/bin
Fetching projects: 14% (8/55) Fetching project app/eptz_demo
Fetching projects: 16% (9/55) Fetching project buildroot
Fetching projects: 18% (10/55) Fetching project external/uac_app
Fetching projects: 20% (11/55) Fetching project external/rkwifibt
Fetching projects: 21% (12/55) Fetching project external/update_engine
Fetching projects: 23% (13/55) Fetching project external/mpp
Fetching projects: 25% (14/55) Fetching project external/rknn-toolkit2
Fetching projects: 29% (16/55) Fetching project rkbin
Fetching project docs
Fetching projects: 30% (17/55) Fetching project external/ble_wificonfig
Fetching projects: 32% (18/55) Fetching project app/qplayer
Fetching projects: 34% (19/55) Fetching project docs-soc_internal
Fetching projects: 36% (20/55) Fetching project kernel
Fetching projects: 40% (22/55) Fetching project external/rktoolkit
Fetching project external/alsa-config
Fetching projects: 41% (23/55) Fetching project external/softapDemo
Fetching projects: 43% (24/55) Fetching project external/libmali
Fetching projects: 45% (25/55) Fetching project external/linux-rga
Fetching projects: 49% (27/55) Fetching project debian
Fetching project external/bluez-alsa
Fetching projects: 50% (28/55) Fetching project external/broadcom_bsa
Fetching projects: 52% (29/55) Fetching project external/bluetooth_bsa
Fetching projects: 54% (30/55) Fetching project repo
Fetching projects: 56% (31/55) Fetching project external/minigui_desktop
Fetching projects: 58% (32/55) Fetching project tools
Fetching projects: 60% (33/55) Fetching project device/rockchip
Fetching projects: 61% (34/55) Fetching project external/security/rk_tee_user
Fetching projects: 63% (35/55) Fetching project external/avb
Fetching projects: 65% (36/55) Fetching project app/multivideoplayer
Fetching projects: 67% (37/55) Fetching project app/CameraFactoryTestServer
Fetching projects: 69% (38/55) Fetching project external/recovery
Fetching projects: 70% (39/55) Fetching project app/qfm
Fetching projects: 72% (40/55) Fetching project app/QLauncher
Fetching projects: 74% (41/55) Fetching project external/libglCompositor
Fetching projects: 76% (42/55) Fetching project external/camera_engine_rkaiq
Fetching projects: 78% (43/55) Fetching project external/minilogger
Fetching projects: 80% (44/55) Fetching project external/deviceio_release
Fetching projects: 83% (46/55) Fetching project external/minigui
Fetching project external/rknpu2
Fetching projects: 85% (47/55) Fetching project external/eq_drc_process
Fetching projects: 87% (48/55) Fetching project app/qsetting
Fetching projects: 89% (49/55) Fetching project external/gstreamer-rockchip
Fetching projects: 90% (50/55) Fetching project external/rkscript
Fetching projects: 92% (51/55) Fetching project external/common_algorithm
Fetching projects: 98% (54/55) ssh: connect to host git.t-firefly.com port 8022: Connection timed out
fatal: 无法读取远程仓库。
请确认您有正确的访问权限并且仓库存在。
fatal: 无法读取远程仓库。
请确认您有正确的访问权限并且仓库存在。
error: Cannot fetch repo
error: Exited sync due to fetch errors
我是否需要申请一个SSH公钥才能sync代码?
看网盘里的文档,通过bundle的方式升级,不是repo
我通过bundle的方式升级了:
root@liuyi5-QiTianM415-D071:/home/liuyi5/3588/Linux_SDK-o/rk3588# cd kernel
root@liuyi5-QiTianM415-D071:/home/liuyi5/3588/Linux_SDK-o/rk3588/kernel# git tag
rk3588/linux_release_v0.0.1a
rk3588/linux_release_v0.0.1b
但,
在/rk3588/device/rockchip/rk3588 目录下,
需要升级到v1.0.0c,升级的初始版本需要是 0.1.0
0.0.1好像是升不到1.0.0的,文档里都有说的呀
root@lilong-virtual-machine:/home/myfile/rk3588/rk3588/kernel# git tag
rk3588/linux_release_v0.0.1c
rk3588/linux_release_v0.1.0a
rk3588/linux_release_v0.1.1a
rk3588/linux_release_v1.0.0a
rk3588/linux_release_v1.0.0b
rk3588/linux_release_v1.0.0c
这个是不是标志升级成功了,升级到1.0.0c
rk3588/linux_release_v0.0.1a …
请问您使用的是哪个Linux SDK? 在/rk3588/device/rockchip/rk3588 目录下,
有没有 itx-3588j-BE45-A1-ubuntu.mk 这个文件?
