SDK包名称:firefly_rk3308_release_defconfig
SDK修改内容:firefly_rk3308_release_defconfig
Log日志:log.txt
从https://gitlab.com/TeeFirefly/rk3308-linux上Fork了整个目录,本机ubutun16.04 64bits,执行./build.sh 编译uboot\kernel\rootfs,发现uboot\kernel编译完成后,buildroot出现问题,日志如下:
==========Start build buildroot==========
TARGET_BUILDROOT_CONFIG=firefly_rk3308_release
Top of tree: /home/xinhy/Desktop/work/wanZilian/rockchip/rk3308
You’re building on Linux
Lunch menu…pick a combo:
- firefly_rk3308_release
- firefly_rk3308_recovery
- firefly_rk3308_pcba
- firefly_rk3308_qt_release
Which would you like? [1] firefly_rk3308_release
#TARGET_BOARD=rk3308
#BUILD_TYPE=64
#OUTPUT_DIR=output/firefly_rk3308_release
#CONFIG=firefly_rk3308_release_defconfig
make: Entering directory ‘/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot’
/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/build/defconfig_hook.py -m /home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/configs/firefly_rk3308_release_defconfig /home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/.rockchipconfig
BR2_DEFCONFIG=‘’ KCONFIG_AUTOCONFIG=/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/build/buildroot-config/tristate.config BR2_CONFIG=/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/.config HOST_GCC_VERSION=“7” BUILD_DIR=/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/build SKIP_LEGACY= BR2_DEFCONFIG=/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/configs/firefly_rk3308_release_defconfig /home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/build/buildroot-config/conf --defconfig=/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/.rockchipconfig Config.in
/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/.rockchipconfig:142
override: reassigning to symbol BR2_PACKAGE_NTP
/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/.rockchipconfig:143
override: reassigning to symbol BR2_PACKAGE_NTP_NTPDATE
/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/.rockchipconfig:158
override: reassigning to symbol BR2_TARGET_ENABLE_ROOT_LOGIN
# configuration written to /home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/.config
make: Leaving directory ‘/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot’
Makefile:1: *** missing separator. Stop.
you take 0:00.30 to build builroot
====Build buildroot failed!====
对buildroot目录中的makefile文件进行了查看,文件格式ascii,也没有找到明显的语法错误。
单独进入buildroot目录,进行编译,make后,出现如下错误:
rkwifibt 1.0.0 Building
mkdir -p /home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/target/system/lib/modules/
/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/../build.sh modules
/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/../build.sh: line 1: device/rockchip/common/build.sh: No such file or directory
package/pkg-generic.mk:247: recipe for target ‘/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/build/rkwifibt-1.0.0/.stamp_built’ failed
make[1]: *** [/home/xinhy/Desktop/work/wanZilian/rockchip/rk3308/buildroot/output/firefly_rk3308_release/build/rkwifibt-1.0.0/.stamp_built] Error 127
Makefile:83: recipe for target ‘_all’ failed
make: *** [_all] Error 2
fork的整个目录均进行了核对,device/rochip/common/build.sh文件是存在的。
这个问题该怎么解决?
log.txt (3.75 KB)
