固件文件名称:rk3588_repo_sdk_v0.1.0a.7z
固件下载地址:百度网盘-链接不存在
Log日志:log.zip
下载SDK进行系统编译(想修改dts以支持NVME协议硬盘),遇到ERROR: No find /home/fuxi/sdk/firefly/rk3588/u-boot/aarch64-linux-gnu-gcc的错误。想问一下这个是什么情况?步骤根据wiki上的执行的,在执行./build.sh后出现。
log.zip (1.05 KB)
rk3588_repo_sdk_v0.1.0a.7z 这个只是基础包,下载完成后还需要打 bundle 更新 ,这些下载 链接 文档里都有的
板蓝根 发表于 2022-6-28 14:50
rk3588_repo_sdk_v0.1.0a.7z 这个只是基础包,下载完成后还需要打 bundle 更新 ,这些下载 链接 文档里都 …
好的,已经更新SDK后进行编译,有以下报错
Value of CONFIG_PC9202_WATCHDOG is redefined by fragment ./arch/arm64/configs/firefly-linux.config:
Previous value: # CONFIG_PC9202_WATCHDOG is not set
New value: CONFIG_PC9202_WATCHDOG=y
# merged configuration written to .config (needs make)
.config:7006:warning: override: reassigning to symbol BT_RTKBTUSB
.config:7011:warning: override: reassigning to symbol IP_VS
.config:7012:warning: override: reassigning to symbol VXLAN
.config:7015:warning: override: reassigning to symbol SCSI
SYNC include/config/auto.conf.cmd
CALL scripts/atomic/check-atomics.sh
CALL scripts/checksyscalls.sh
CHK include/generated/compile.h
Image: resource.img (with roc-rk3588s-pc.dtb logo.bmp logo_kernel.bmp) is ready
Image: boot.img (with Image ramdisk.img resource.img) is ready
Image: zboot.img (with Image.lz4 ramdisk.img resource.img) is ready
Generate extLinuxBoot image start
DTC arch/arm64/boot/dts/rockchip/rk3588-firefly-itx-3588j.dtb
Error: arch/arm64/boot/dts/rockchip/rk3588-firefly-itx-cam-8ms1m.dtsi:7.1-2 syntax error
FATAL ERROR: Unable to parse input tree
scripts/Makefile.lib:379: recipe for target 'arch/arm64/boot/dts/rockchip/rk3588-firefly-itx-3588j.dtb' failed
make[1]: *** [arch/arm64/boot/dts/rockchip/rk3588-firefly-itx-3588j.dtb] Error 1
Makefile:1444: recipe for target 'rockchip/rk3588-firefly-itx-3588j.dtb' failed
make: *** [rockchip/rk3588-firefly-itx-3588j.dtb] Error 2
ERROR: Running build_extboot failed!
ERROR: exit code 2 from line 797:
make ARCH=$RK_ARCH rockchip/$i.dtb -j$RK_JOBS
编译之前是有执行过这个命令的
./build.sh roc-rk3588s-pc-ubuntu.mk
板蓝根 发表于 2022-6-28 16:44
- cd kernel; git log ,确认是不是更新到 v1.0.0c
- cd kernel;git status 看看自己修改了什么,这里 …
在kernel目录一下执行git reset --hard就解决了
