ITX-3588J和ROC-RK3588S-PC 代码是一样的吧,只是编译参数不一样吧?现在ROC-RK3588S编译错误呢?./FFTools/make.sh -d roc-rk3588s-pc -j8 -l roc_rk3588s_pc-userdebug
[W][2022-07-06T06:49:44+0000][9115] void cmdline::logParams(nsjconf_t *)():250 Process will be UID/EUID=0 in the global user namespace, and will
have user root-level access to files
[W][2022-07-06T06:49:44+0000][9115] void cmdline::logParams(nsjconf_t *)():260 Process will be GID/EGID=0 in the global user namespace, and will
have group root-level access to files
In file included from build/make/core/config.mk:313:
In file included from build/make/core/envsetup.mk:312:
build/make/core/product_config.mk:160: error: Can not locate config makefile for product “roc_rk3588s_pc”.
Update package verification took 0.3 s (result 0).
Installing update...
I:old spl: 2022-02-05 new spl: 2022-02-05 CHECK passes
SELinux: Loaded file_contexts
Source: Firefly/rk3588/rk3588:12/SQ1D.220205.004/yangjie07082111:userdebug/release-keys
Target: Firefly/rk3588/rk3588:12/SQ1D.220205.004/yangjie07082214:userdebug/release-keys
Verifying current system...
Partition contents don't have the expected checksum
Failed to read "/cache/saved.file": No such file or directory
Both of partition contents and backup don't have the expected checksum
script aborted: E3005: "EMMC:/dev/block/by-name/boot:39518208:453c7bc5d08540554b7c719bf26ba224c312fb5e" or "EMMC:/dev/block/by-name/boot:39518208:5f1936627a602e30bc3913a1199ff82206c6ff04" has unexpected contents.
E:Error in /cache/recovery/update.zip (status 1)
