编译了app目录下的rkmedia_rtspget_vdec_rknn_venc_rtsp_test测试demo,终于编译成功,修改了ffrtsp-nn.cfg测试文件,rknn的几个配置文件都是用默认的,确定路径和文件正常,ffrtsp-nn.cfg的内容如下:
video_type=6 video_fps=25 width=1920 height=1080 image_type=3 port=8554 video_url=rtsp://admin:fs123456@192.168.0.66:554/Streaming/Channels/101
上面的image_type用4也试过,错误一样,log如下:
[URL:“rtsp://admin:fs123456@192.168.0.66:554/Streaming/Channels/101/”]: Started playing session…
[RKMEDIA][VDEC][Info]:MppDec Info change get, 1920x1080 in (1920x1088)
[RKMEDIA][RGA][Error]:Src(0Bytes) or Dst(6266880Bytes) Buffer is invalid!
[RKMEDIA][RGA][Error]:Src(0Bytes) or Dst(270000Bytes) Buffer is invalid!
[RKMEDIA][VDEC][Info]:Failed to put a packet to MPP (ret = -1)
mpp[2281]: h264e_sps: set level to 4
[RKMEDIA][VDEC][Info]:Received a errinfo frame.
最终通过vlc拉流失败,麻烦有碰到过或者了解的大佬给指点一下,多谢。
