camera调试,找不到可以输出的video device?
sensor ID 能正常读到,但是使用 media-ctl -d /dev/media0 -e “rkisp1_mainpath” ,找不到可以输出的video device .这可能是什么原因?
root@kylin:/# media-ctl -p -d /dev/media0
Media controller API version 5.10.66
Media device information
driver rkcif
model rkcif-mipi-lvds2
serial
bus info
hw revision 0x0
driver version 5.10.66
Device topology
  • entity 1: stream_cif_mipi_id0 (1 pad, 8 links)
    type Node subtype V4L flags 0
    device node name /dev/video0
    pad0: Sink
    ← “rockchip-mipi-csi2”:1 [ENABLED]
    ← “rockchip-mipi-csi2”:2
    ← “rockchip-mipi-csi2”:3
    ← “rockchip-mipi-csi2”:4
    ← “rockchip-mipi-csi2”:5
    ← “rockchip-mipi-csi2”:6
    ← “rockchip-mipi-csi2”:7
    ← “rockchip-mipi-csi2”:8
  • entity 5: stream_cif_mipi_id1 (1 pad, 8 links)
    device node name /dev/video1
    pad0: Sink
    ← “rockchip-mipi-csi2”:2 [ENABLED]
  • entity 9: stream_cif_mipi_id2 (1 pad, 8 links)
    device node name /dev/video2
    pad0: Sink
    ← “rockchip-mipi-csi2”:3 [ENABLED]
  • entity 13: stream_cif_mipi_id3 (1 pad, 8 links)
    device node name /dev/video3
    pad0: Sink
    ← “rockchip-mipi-csi2”:4 [ENABLED]
  • entity 17: rkcif_scale_ch0 (1 pad, 8 links)
    device node name /dev/video4
    pad0: Sink
    ← “rockchip-mipi-csi2”:5 [ENABLED]
  • entity 21: rkcif_scale_ch1 (1 pad, 8 links)
    device node name /dev/video5
    pad0: Sink
    ← “rockchip-mipi-csi2”:6 [ENABLED]
  • entity 25: rkcif_scale_ch2 (1 pad, 8 links)
    device node name /dev/video6
    pad0: Sink
    ← “rockchip-mipi-csi2”:7 [ENABLED]
  • entity 29: rkcif_scale_ch3 (1 pad, 8 links)
    device node name /dev/video7
    pad0: Sink
    ← “rockchip-mipi-csi2”:8 [ENABLED]
  • entity 33: rockchip-mipi-csi2 (9 pads, 65 links)
    type V4L2 subdev subtype Unknown flags 0
    device node name /dev/v4l-subdev0
    pad0: Sink
    [fmt:UYVY8_2X8/640x480 field:none colorspace:smpte170m
    crop.bounds:(0,0)/640x480
    crop:(0,0)/640x480]
    ← “rockchip-csi2-dphy0”:1 [ENABLED]
    pad1: Source
    → “stream_cif_mipi_id0”:0 [ENABLED]
    → “stream_cif_mipi_id1”:0
    → “stream_cif_mipi_id2”:0
    → “stream_cif_mipi_id3”:0
    → “rkcif_scale_ch0”:0
    → “rkcif_scale_ch1”:0
    → “rkcif_scale_ch2”:0
    → “rkcif_scale_ch3”:0
    pad2: Source
    → “stream_cif_mipi_id1”:0 [ENABLED]
    pad3: Source
    → “stream_cif_mipi_id2”:0 [ENABLED]
    pad4: Source
    → “stream_cif_mipi_id3”:0 [ENABLED]
    pad5: Source
    → “rkcif_scale_ch0”:0 [ENABLED]
    pad6: Source
    → “rkcif_scale_ch1”:0 [ENABLED]
    pad7: Source
    → “rkcif_scale_ch2”:0 [ENABLED]
    pad8: Source
    → “rkcif_scale_ch3”:0 [ENABLED]
  • entity 43: rockchip-csi2-dphy0 (2 pads, 2 links)
    device node name /dev/v4l-subdev1
    pad0: Sink
    [fmt:UYVY8_2X8/640x480@10000/600000 field:none colorspace:smpte170m]
    ← “m00_f_tc35874x 3-000f”:0 [ENABLED]
    pad1: Source
    → “rockchip-mipi-csi2”:0 [ENABLED]
  • entity 48: m00_f_tc35874x 3-000f (1 pad, 1 link)
    type V4L2 subdev subtype Sensor flags 0
    device node name /dev/v4l-subdev2
    pad0: Source
    [dv.caps:BT.656/1120 min:1x1@0 max:10000x10000@310000000 stds:CEA-861,DMT,C]
    [dv.query:no-link]
    [dv.current:BT.656/1120 640x480p59 (800x525) stds:CEA-861,DMT flags:has-cea]
    → “rockchip-csi2-dphy0”:0 [ENABLED]
root@kylin:/# media-ctl -d /dev/media0 -e “stream_cif”
Entity ‘stream_cif’ not found
root@kylin:/# media-ctl -d /dev/media0 -e “rkisp1_mainpath”
Entity ‘rkisp1_mainpath’ not found
root@kylin:/# media-ctl -d /dev/media0 -e “rkisp1_selfpath”
Entity ‘rkisp1_selfpath’ not found
isp没有enable
wx__KIyr4p 发表于 2022-7-9 17:12
isp没有enable
enable 还是一样的
