SDK包名称:rk3399_linux_release_v2.5.1_20210301
SDK修改内容:无修改
Log日志:log.zip
买了一个店铺里面的OV13850摄像头,接在了mipi-csi0上,内核加载打印的信息如下,无法使用摄像头出图
firefly@firefly:~$ dmesg | grep ov13850
[ 3.357792] ov13850 1-0036: driver version: 00.01.03
[ 3.358279] ov13850 1-0036: GPIO lookup for consumer reset
[ 3.358287] ov13850 1-0036: using device tree for GPIO lookup
[ 3.358319] of_get_named_gpiod_flags: parsed ‘reset-gpios’ property of node ‘/i2c@ff110000/ov13850@36[0]’ - status (0)
[ 3.358348] ov13850 1-0036: Looking up avdd-supply from device tree
[ 3.358485] ov13850 1-0036: Looking up dovdd-supply from device tree
[ 3.358553] ov13850 1-0036: Looking up dvdd-supply from device tree
[ 3.358638] ov13850 1-0036: could not get default pinstate
[ 3.359122] ov13850 1-0036: could not get sleep pinstate
[ 3.359603] ov13850 1-0036: GPIO lookup for consumer pwdn
[ 3.359610] ov13850 1-0036: using device tree for GPIO lookup
[ 3.359635] of_get_named_gpiod_flags: parsed ‘pwdn-gpios’ property of node ‘/i2c@ff110000/ov13850@36[0]’ - status (0)
[ 3.364182] ov13850 1-0036: Detected OV00d850 sensor, REVISION 0xb2
[ 3.364958] ov13850 1-0046: driver version: 00.01.03
[ 3.364969] ov13850 1-0046: GPIO lookup for consumer pwdn
[ 3.364972] ov13850 1-0046: using device tree for GPIO lookup
[ 3.365037] of_get_named_gpiod_flags: parsed ‘pwdn-gpios’ property of node ‘/i2c@ff110000/ov13850@46[0]’ - status (0)
[ 3.367740] ov13850 1-0046: write SCCB_ID failed
[ 3.368195] ov13850: probe of 1-0046 failed with error -5
log.zip (148 Bytes)
