3588编译出错
INSTALL drivers/media/tuners/xc5000.ko
INSTALL drivers/net/wireless/rockchip_wlan/rkwifi/bcmdhd/bcmdhd.ko
INSTALL drivers/net/wireless/rockchip_wlan/rtl8821cu/8821cu.ko
DEPMOD 5.10.66
__populate_fs: Could not allocate block in ext2 filesystem while writing file “modules.order”
mkfs.ext4: Could not allocate block in ext2 filesystem while populating file system
ERROR: Running build_extboot failed!
ERROR: exit code 1 from line 707:
fakeroot ${TOP_DIR}/device/rockchip/common/mkfs.ext4 -Fq -L “boot” -d $EXTBOOT_DIR $EXTBOOT_IMG
请问这个该如何解决?硬盘空间足够
环境问题,可以参考RK3588 编译的wiki 说明
请问楼主解决了没 我更新到rk3588-v1.0.1a-to-v1.0.1b后遇到了同样的问题.
