编译的Ubuntu固件烧录无法使用
SDK包名称:rk356x_linux_release_20211019
SDK修改内容:无修改
Log日志:2022.8.1_rklog.zip
1.下载官方根文件系统
7z x ubuntu-aarch64-rootfs.7z
mkdir ubuntu_rootfs
mv ubuntu-aarch64-rootfs.img ubuntu_rootfs/rk356x_ubuntu_rootfs.img
2.全自动编译
./build.sh
3.烧录固件
cd rockdev/pack
upgrade_tool uf ITX-3568Q_Itx-r124a_v1.2.4a_220801.img
4.系统启动报错进入(initramfs) - 详细日志见附件
[ 0.000000] Linux version 4.19.232 (root@szagv-ThinkPad-T470p) (firefly: 6fc252772dd7ded6bce5031578af6441b48ac0ec) (sdk version: rk356x_linux_release_20220516_v1.2.4a.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #12 SMP Mon Aug 1 10:01:32 CST 2022
[ 0.000000] Machine model: ITX-3568Q HDMI (Linux)
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options ‘’)
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-cubic-lut@00000000’: base 0x0000000000000000, size 0 MiB
[ 0.000000] cma: Reserved 16 MiB at 0x00000000ef000000
[ 0.000000] On node 0 totalpages: 1043968
[ 0.000000] DMA32 zone: 15288 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 978432 pages, LIFO batch:63
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 65536 pages, LIFO batch:15
[ 0.000000] percpu: Embedded 24 pages/cpu s60136 r8192 d29976 u98304
[ 0.000000] pcpu-alloc: s60136 r8192 d29976 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1027656
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal storagenode=/sdhci@fe310000 androidboot.verifiedbootstate=orange ro rootwait earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] software IO TLB: mapped [mem 0xe9f00000-0xedf00000] (64MB)
[ 0.000000] Memory: 3967524K/4175872K available (15166K kernel code, 1952K rwdata, 5304K rodata, 1600K init, 598K bss, 191964K reserved, 16384K cma-reserved)
[ 0.000000] ftrace: allocating 54399 entries in 213 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @ee810000 (indirect, esz 8, psz 64K, shr 0)
[ 0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @ee820000 (flat, esz 2, psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x00000000ee830000
[ 0.000000] CPU0: using LPI pending table @0x00000000ee840000
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x514 with crng_init=0
[ 0.002240] Console: colour dummy device 80x25
[ 0.002701] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003651] pid_max: default: 32768 minimum: 301
[ 0.004218] Security Framework initialized
[ 0.004614] AppArmor: AppArmor disabled by boot time parameter
[ 0.005222] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.005897] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.008529] ASID allocator initialised with 32768 entries
[ 0.009249] rcu: Hierarchical SRCU implementation.
[ 0.012689] Platform MSI: interrupt-controller@fd440000 domain created
[ 0.013830] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[ 0.015459] smp: Bringing up secondary CPUs …
[ 0.017475] Detected VIPT I-cache on CPU1
[ 0.017517] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 0.017571] CPU1: using LPI pending table @0x00000000ee850000
[ 0.017629] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.019259] Detected VIPT I-cache on CPU2
[ 0.019295] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 0.019347] CPU2: using LPI pending table @0x00000000ee860000
[ 0.019397] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 0.021013] Detected VIPT I-cache on CPU3
[ 0.021049] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 0.021100] CPU3: using LPI pending table @0x00000000ee870000
[ 0.021148] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 0.021288] smp: Brought up 1 node, 4 CPUs
[ 0.028139] SMP: Total of 4 processors activated.
[ 0.028580] CPU features: detected: GIC system register CPU interface
[ 0.029172] CPU features: detected: Privileged Access Never
[ 0.029685] CPU features: detected: LSE atomic instructions
[ 0.030221] CPU features: detected: User Access Override
[ 0.030698] CPU features: detected: 32-bit EL0 Support
[ 0.031175] CPU features: detected: RAS Extension Support
[ 0.031866] CPU: All CPU(s) started at EL2
[ 0.032278] alternatives: patching kernel code
[ 0.039790] devtmpfs: initialized
[ 0.073955] Registered cp15_barrier emulation handler
[ 0.074449] Registered setend emulation handler
[ 0.075250] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.076220] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.077677] pinctrl core: initialized pinctrl subsystem
[ 0.078514] regulator-dummy: no parameters
[ 0.079327] NET: Registered protocol family 16
[ 0.081002] audit: initializing netlink subsys (disabled)
[ 0.081762] audit: type=2000 audit(0.073:1): state=initialized audit_enabled=0 res=1
[ 0.085738] cpuidle: using governor menu
[ 0.086142] Registered FIQ tty driver
[ 0.087436] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.089608] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.094285] console [pstore-1] enabled
[ 0.094642] pstore: Registered ramoops as persistent store backend
[ 0.095219] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.140445] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio)
[ 0.141792] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[ 0.143136] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[ 0.144461] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio)
[ 0.145763] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[ 0.146500] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.165699] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.166577] cryptd: max_cpu_qlen set to 1000
[ 0.168998] console [ttyFIQ0] enabled
[ 0.169707] bootconsole [uart8250] disabled
[ 0.170383] Registered fiq debugger ttyFIQ0
[ 0.171069] dc_12v: 12000 mV
[ 0.171360] reg-fixed-voltage dc-12v: dc_12v supplying 12000000uV
[ 0.171513] reg-fixed-voltage vcc3v3-sys: Looking up vin-supply from device tree
[ 0.171527] vcc3v3_sys: supplied by dc_12v
[ 0.171563] dc_12v: could not add device link regulator.2 err -2
[ 0.171616] vcc3v3_sys: 3300 mV
[ 0.171884] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[ 0.172029] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree
[ 0.172042] vcc5v0_sys: supplied by dc_12v
[ 0.172078] dc_12v: could not add device link regulator.3 err -2
[ 0.172131] vcc5v0_sys: 5000 mV
[ 0.172390] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[ 0.172750] vcc5v0_otg: no parameters
[ 0.172997] reg-fixed-voltage vcc5v0-otg-regulator: vcc5v0_otg supplying 0uV
[ 0.173174] reg-fixed-voltage vcc2v5-ddr: Looking up vin-supply from device tree
[ 0.173187] vcc2v5-sys: supplied by vcc3v3_sys
[ 0.173229] vcc3v3_sys: could not add device link regulator.5 err -2
[ 0.173281] vcc2v5-sys: 2500 mV
[ 0.173543] reg-fixed-voltage vcc2v5-ddr: vcc2v5-sys supplying 2500000uV
[ 0.173681] reg-fixed-voltage pcie30-avdd0v9: Looking up vin-supply from device tree
[ 0.173695] pcie30_avdd0v9: supplied by vcc3v3_sys
[ 0.173729] vcc3v3_sys: could not add device link regulator.6 err -2
[ 0.173780] pcie30_avdd0v9: 900 mV
[ 0.174050] reg-fixed-voltage pcie30-avdd0v9: pcie30_avdd0v9 supplying 900000uV
[ 0.174187] reg-fixed-voltage pcie30-avdd1v8: Looking up vin-supply from device tree
[ 0.174199] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.174235] vcc3v3_sys: could not add device link regulator.7 err -2
[ 0.174285] pcie30_avdd1v8: 1800 mV
[ 0.174542] reg-fixed-voltage pcie30-avdd1v8: pcie30_avdd1v8 supplying 1800000uV
[ 0.174703] pcie30_3v3: 3300 mV
[ 0.174899] reg-fixed-voltage gpio-regulator: Looking up vin-supply from device tree
[ 0.174912] pcie30_3v3: supplied by dc_12v
[ 0.175053] reg-fixed-voltage gpio-regulator: pcie30_3v3 supplying 3300000uV
[ 0.175200] reg-fixed-voltage vcc3v3-bu: Looking up vin-supply from device tree
[ 0.175214] vcc3v3_bu: supplied by vcc5v0_sys
[ 0.175247] vcc5v0_sys: could not add device link regulator.9 err -2
[ 0.175328] vcc3v3_bu: 3300 mV
[ 0.175566] reg-fixed-voltage vcc3v3-bu: vcc3v3_bu supplying 3300000uV
[ 0.177232] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_npu-supply from device tree
[ 0.177258] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_npu-supply property in node /power-management@fdd90000/power-controller failed
[ 0.177316] rk_iommu fde4b000.iommu: version = 2
[ 0.178106] rk_iommu fdea0800.iommu: version = 2
[ 0.178428] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vpu-supply from device tree
[ 0.178454] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vpu-supply property in node /power-management@fdd90000/power-controller failed
[ 0.178645] rk_iommu fded0480.iommu: version = 2
[ 0.179046] rk_iommu fdee0800.iommu: version = 2
[ 0.179427] rk_iommu fdef0800.iommu: version = 2
[ 0.179830] rk_iommu fdf40f00.iommu: version = 2
[ 0.180285] rk_iommu fdf80800.iommu: version = 2
[ 0.180683] rk_iommu fdff1a00.iommu: version = 2
[ 0.181043] rk_iommu fe043e00.iommu: version = 2
[ 0.182192] SCSI subsystem initialized
[ 0.182280] libata version 3.00 loaded.
[ 0.182554] usbcore: registered new interface driver usbfs
[ 0.182646] usbcore: registered new interface driver hub
[ 0.182726] usbcore: registered new device driver usb
[ 0.182871] media: Linux media interface: v0.10
[ 0.182942] videodev: Linux video capture interface: v2.00
[ 0.183091] pps_core: LinuxPPS API ver. 1 registered
[ 0.183151] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.183196] PTP clock support registered
[ 0.183637] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 0.184442] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rga-supply from device tree
[ 0.184471] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rga-supply property in node /power-management@fdd90000/power-controller failed
[ 0.184560] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvenc-supply from device tree
[ 0.184583] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvenc-supply property in node /power-management@fdd90000/power-controller failed
[ 0.184637] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvdec-supply from device tree
[ 0.184659] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvdec-supply property in node /power-management@fdd90000/power-controller failed
[ 0.184702] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vi-supply from device tree
[ 0.184723] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vi-supply property in node /power-management@fdd90000/power-controller failed
[ 0.187006] Advanced Linux Sound Architecture Driver Initialized.
[ 0.187744] Bluetooth: Core ver 2.22
[ 0.187824] NET: Registered protocol family 31
[ 0.187849] Bluetooth: HCI device and connection manager initialized
[ 0.187877] Bluetooth: HCI socket layer initialized
[ 0.187905] Bluetooth: L2CAP socket layer initialized
[ 0.187973] Bluetooth: SCO socket layer initialized
[ 0.190090] rockchip-cpuinfo cpuinfo: SoC : 35682000
[ 0.190135] rockchip-cpuinfo cpuinfo: Serial : 89df34ca33e2c93a
[ 0.191803] clocksource: Switched to clocksource arch_sys_counter
[ 0.294016] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.294450] NET: Registered protocol family 2
[ 0.294849] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.297344] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes)
[ 0.297474] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.297798] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.298894] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.299153] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.299387] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.299819] NET: Registered protocol family 1
[ 0.300783] PCI: CLS 0 bytes, default 64
[ 0.301868] Trying to unpack rootfs image as initramfs…
[ 0.784758] Freeing initrd memory: 8988K
[ 0.786607] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.787506] kvm [1]: 16-bit VMID
[ 0.787548] kvm [1]: GICv3: no GICV resource entry
[ 0.787562] kvm [1]: disabling GICv2 emulation
[ 0.787575] kvm [1]: GIC system register CPU interface enabled
[ 0.787762] kvm [1]: vgic interrupt IRQ1
[ 0.787985] kvm [1]: VHE mode initialized successfully
[ 0.790652] Initialise system trusted keyrings
[ 0.790926] workingset: timestamp_bits=45 max_order=20 bucket_order=0
[ 0.801859] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.802307] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.802641] fuse init (API version 7.27)
[ 0.803283] SGI XFS with security attributes, no debug enabled
[ 0.807335] NET: Registered protocol family 38
[ 0.807393] Key type asymmetric registered
[ 0.807408] Asymmetric key parser ‘x509’ registered
[ 0.807472] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.807676] io scheduler noop registered
[ 0.807700] io scheduler deadline registered
[ 0.807904] io scheduler cfq registered (default)
[ 0.807922] io scheduler mq-deadline registered
[ 0.807935] io scheduler kyber registered
[ 0.809533] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.809759] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 0.813233] phy phy-fe8a0000.usb2-phy.0: Looking up phy-supply from device tree
[ 0.813265] rockchip-usb2phy fe8a0000.usb2-phy: failed to create phy
[ 0.813969] phy phy-fe8b0000.usb2-phy.0: Looking up phy-supply from device tree
[ 0.813995] rockchip-usb2phy fe8b0000.usb2-phy: failed to create phy
[ 0.817270] phy phy-fe820000.phy.0: Looking up phy-supply from device tree
[ 0.817285] phy phy-fe820000.phy.0: Looking up phy-supply property in node /phy@fe820000 failed
[ 0.817903] phy phy-fe830000.phy.1: Looking up phy-supply from device tree
[ 0.817917] phy phy-fe830000.phy.1: Looking up phy-supply property in node /phy@fe830000 failed
[ 0.818575] phy phy-fe840000.phy.2: Looking up phy-supply from device tree
[ 0.818588] phy phy-fe840000.phy.2: Looking up phy-supply property in node /phy@fe840000 failed
[ 0.819027] phy phy-fdcb0000.syscon:edp-phy.3: Looking up phy-supply from device tree
[ 0.819040] phy phy-fdcb0000.syscon:edp-phy.3: Looking up phy-supply property in node /syscon@fdcb0000/edp-phy failed
[ 0.820390] phy phy-fe8c0000.phy.4: Looking up phy-supply from device tree
[ 0.820405] phy phy-fe8c0000.phy.4: Looking up phy-supply property in node /phy@fe8c0000 failed
[ 0.825367] rk-pcie 3c0000000.pcie: Looking up vpcie3v3-supply from device tree
[ 0.825386] rk-pcie 3c0000000.pcie: Looking up vpcie3v3-supply property in node /pcie@fe260000 failed
[ 0.825409] rk-pcie 3c0000000.pcie: no vpcie3v3 regulator found
[ 0.825779] rk-pcie 3c0800000.pcie: Looking up vpcie3v3-supply from device tree
[ 0.825786] rk-pcie 3c0000000.pcie: missing legacy IRQ resource
[ 0.825810] rk-pcie 3c0000000.pcie: Missing config reg space
[ 0.825823] rk-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges:
[ 0.825868] rk-pcie 3c0000000.pcie: err 0xf4000000..0xf40fffff → 0xf4000000
[ 0.825917] rk-pcie 3c0000000.pcie: IO 0xf4100000..0xf41fffff → 0xf4100000
[ 0.825961] rk-pcie 3c0000000.pcie: MEM 0xf4200000..0xf5ffffff → 0xf4200000
[ 0.825966] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.8
[ 0.825996] rk-pcie 3c0000000.pcie: MEM 0x300000000..0x33fffffff → 0x300000000
[ 0.826742] mpp_service mpp-srv: 44f7b7b author: Caesar Wang 2022-04-27 Revert “Revert “video: rockchip: mpp: rkvdec2: setup link mode clk””
[ 0.826776] mpp_service mpp-srv: probe start
[ 0.828053] iommu: Adding device fdf40000.rkvenc to group 5
[ 0.828095] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu
[ 0.828378] mpp_rkvenc fdf40000.rkvenc: probing start
[ 0.829103] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[ 0.829126] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry
[ 0.829156] rkvenc_init:1199: failed to add venc devfreq
[ 0.829629] mpp_rkvenc fdf40000.rkvenc: probing finish
[ 0.831242] iommu: Adding device fdea0400.vdpu to group 1
[ 0.831303] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu
[ 0.831548] mpp_vdpu2 fdea0400.vdpu: probe device
[ 0.832418] mpp_vdpu2 fdea0400.vdpu: probing finish
[ 0.833231] iommu: Adding device fdee0000.vepu to group 3
[ 0.833287] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu
[ 0.833555] mpp_vepu2 fdee0000.vepu: probe device
[ 0.834347] mpp_vepu2 fdee0000.vepu: probing finish
[ 0.835182] iommu: Adding device fdef0000.iep to group 4
[ 0.835232] mpp-iep2 fdef0000.iep: Linked as a consumer to fdef0800.iommu
[ 0.835454] mpp-iep2 fdef0000.iep: probe device
[ 0.836106] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[ 0.836349] mpp-iep2 fdef0000.iep: probing finish
[ 0.837125] iommu: Adding device fded0000.jpegd to group 2
[ 0.837183] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu
[ 0.837437] mpp_jpgdec fded0000.jpegd: probe device
[ 0.838237] mpp_jpgdec fded0000.jpegd: probing finish
[ 0.839071] iommu: Adding device fdf80200.rkvdec to group 6
[ 0.839129] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu
[ 0.839448] mpp_rkvdec2 fdf80200.rkvdec: probing start
[ 0.839671] mpp_rkvdec2 fdf80200.rkvdec: 16 task capacity link mode detected
[ 0.840159] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[ 0.840190] rkvdec2_init:661: No niu aclk reset resource define
[ 0.840216] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[ 0.840238] rkvdec2_init:664: No niu hclk reset resource define
[ 0.840487] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[ 0.840518] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[ 0.840542] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[ 0.840557] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[ 0.840575] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[ 0.840661] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[ 0.840767] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[ 0.841265] mpp_service mpp-srv: probe success
[ 0.848760] rk-pcie 3c0800000.pcie: missing legacy IRQ resource
[ 0.848804] rk-pcie 3c0800000.pcie: Missing config reg space
[ 0.848835] rk-pcie 3c0800000.pcie: host bridge /pcie@fe280000 ranges:
[ 0.848881] rk-pcie 3c0800000.pcie: err 0xf0000000..0xf00fffff → 0xf0000000
[ 0.848916] rk-pcie 3c0800000.pcie: IO 0xf0100000..0xf01fffff → 0xf0100000
[ 0.848953] rk-pcie 3c0800000.pcie: MEM 0xf0200000..0xf1ffffff → 0xf0200000
[ 0.848984] rk-pcie 3c0800000.pcie: MEM 0x380000000..0x3bfffffff → 0x380000000
[ 0.852222] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.852261] dma-pl330 fe530000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.855817] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.855854] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.857770] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.859326] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.860236] fdd50000.serial: ttyS0 at MMIO 0xfdd50000 (irq = 16, base_baud = 1500000) is a 16550A
[ 0.861377] fe670000.serial: ttyS3 at MMIO 0xfe670000 (irq = 74, base_baud = 1500000) is a 16550A
[ 0.862309] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 75, base_baud = 1500000) is a 16550A
[ 0.863179] fe6d0000.serial: ttyS9 at MMIO 0xfe6d0000 (irq = 76, base_baud = 1500000) is a 16550A
[ 0.867021] random: fast init done
[ 0.867369] random: crng init done
[ 0.867865] iommu: Adding device fe040000.vop to group 8
[ 0.867925] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu
[ 0.876104] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop
[ 0.877170] rockchip-drm display-subsystem: Linked as a consumer to fe0c0000.edp
[ 0.878084] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi
[ 0.880034] rockchip-drm display-subsystem: Linked as a consumer to fdc60000.syscon:rgb
[ 0.885228] /edp-panel: could not find display-timings node
[ 0.885262] /edp-panel: no timings specified
[ 0.885294] panel-simple edp-panel: Looking up power-supply from device tree
[ 0.885308] panel-simple edp-panel: Looking up power-supply property in node /edp-panel failed
[ 0.885331] panel-simple edp-panel: edp-panel supply power not found, using dummy regulator
[ 0.885455] panel-simple edp-panel: Linked as a consumer to regulator.0
[ 0.885490] panel-simple edp-panel: Looking up vsp-supply from device tree
[ 0.885505] panel-simple edp-panel: Looking up vsp-supply property in node /edp-panel failed
[ 0.885522] panel-simple edp-panel: edp-panel supply vsp not found, using dummy regulator
[ 0.885616] panel-simple edp-panel: Looking up vsn-supply from device tree
[ 0.885632] panel-simple edp-panel: Looking up vsn-supply property in node /edp-panel failed
[ 0.885646] panel-simple edp-panel: edp-panel supply vsn not found, using dummy regulator
[ 0.885925] /rgb0_panel: could not find display-timings node
[ 0.885954] /rgb0_panel: no timings specified
[ 0.885987] panel-simple rgb0_panel: Looking up power-supply from device tree
[ 0.886002] panel-simple rgb0_panel: Looking up power-supply property in node /rgb0_panel failed
[ 0.886017] panel-simple rgb0_panel: rgb0_panel supply power not found, using dummy regulator
[ 0.886104] panel-simple rgb0_panel: Linked as a consumer to regulator.0
[ 0.886142] panel-simple rgb0_panel: Looking up vsp-supply from device tree
[ 0.886156] panel-simple rgb0_panel: Looking up vsp-supply property in node /rgb0_panel failed
[ 0.886171] panel-simple rgb0_panel: rgb0_panel supply vsp not found, using dummy regulator
[ 0.886275] panel-simple rgb0_panel: Looking up vsn-supply from device tree
[ 0.886290] panel-simple rgb0_panel: Looking up vsn-supply property in node /rgb0_panel failed
[ 0.886305] panel-simple rgb0_panel: rgb0_panel supply vsn not found, using dummy regulator
[ 0.888052] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_gpu-supply from device tree
[ 0.888089] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_gpu-supply property in node /power-management@fdd90000/power-controller failed
[ 0.888156] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 0.888290] mali fde60000.gpu: Looking up mali-supply from device tree
[ 0.888306] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.888332] mali fde60000.gpu: Device initialization Deferred
[ 0.889549] brd: module loaded
[ 0.899887] loop: module loaded
[ 0.900664] zram: Added device: zram0
[ 0.900862] lkdtm: No crash points registered, enable through debugfs
[ 0.904460] rockchip-pinctrl pinctrl: pin gpio3-19 already requested by fdc60000.syscon:rgb; cannot claim for fe620000.spi
[ 0.904500] rockchip-pinctrl pinctrl: pin-115 (fe620000.spi) status -22
[ 0.904518] rockchip-pinctrl pinctrl: could not request pin 115 (gpio3-19) from group spi1m1-pins on device rockchip-pinctrl
[ 0.904534] rockchip-spi fe620000.spi: Error applying setting, reverse things back
[ 0.904569] rockchip-spi: probe of fe620000.spi failed with error -22
[ 0.905408] CAN device driver interface
[ 0.909005] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[ 0.909031] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply property in node /ethernet@fe010000 failed
[ 0.909054] rk_gmac-dwmac fe010000.ethernet: no regulator found
[ 0.909093] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[ 0.909112] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4d).
[ 0.909129] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2d).
[ 0.909150] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[ 0.909229] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[ 0.914265] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[ 0.914601] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.914633] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5
[ 0.914661] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[ 0.914684] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[ 0.914704] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[ 0.914724] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[ 0.914786] rk_gmac-dwmac fe010000.ethernet: TSO supported
[ 0.914803] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.914820] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[ 1.052613] rk_gmac-dwmac fe2a0000.ethernet: Looking up phy-supply from device tree
[ 1.052637] rk_gmac-dwmac fe2a0000.ethernet: Looking up phy-supply property in node /ethernet@fe2a0000 failed
[ 1.052662] rk_gmac-dwmac fe2a0000.ethernet: no regulator found
[ 1.052707] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (input).
[ 1.052727] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x3e).
[ 1.052744] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x34).
[ 1.052766] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[ 1.052855] rk_gmac-dwmac fe2a0000.ethernet: clock input from PHY
[ 1.057894] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[ 1.058245] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 1.058276] rk_gmac-dwmac fe2a0000.ethernet: DWMAC4/5
[ 1.058302] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[ 1.058324] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[ 1.058345] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[ 1.058365] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[ 1.058427] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[ 1.058443] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.058505] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[ 1.199019] usbcore: registered new interface driver rndis_wlan
[ 1.199124] usbcore: registered new interface driver rtl8150
[ 1.199218] usbcore: registered new interface driver r8152
[ 1.199310] usbcore: registered new interface driver asix
[ 1.199393] usbcore: registered new interface driver ax88179_178a
[ 1.199473] usbcore: registered new interface driver cdc_ether
[ 1.199552] usbcore: registered new interface driver rndis_host
[ 1.199637] usbcore: registered new interface driver cdc_ncm
[ 1.199731] usbcore: registered new interface driver qmi_wwan_q
[ 1.199812] usbcore: registered new interface driver qmi_wwan
[ 1.199880] usbcore: registered new interface driver cdc_mbim
[ 1.201579] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.203139] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 1.206331] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.206381] ehci-pci: EHCI PCI platform driver
[ 1.206482] ehci-platform: EHCI generic platform driver
[ 1.207348] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.207395] ohci-platform: OHCI generic platform driver
[ 1.209217] usbcore: registered new interface driver cdc_acm
[ 1.209249] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.209321] usbcore: registered new interface driver cdc_wdm
[ 1.209676] usbcore: registered new interface driver uas
[ 1.209777] usbcore: registered new interface driver usb-storage
[ 1.209910] usbcore: registered new interface driver usbserial_generic
[ 1.209973] usbserial: USB Serial support registered for generic
[ 1.210054] usbcore: registered new interface driver cp210x
[ 1.210111] usbserial: USB Serial support registered for cp210x
[ 1.210186] usbcore: registered new interface driver ftdi_sio
[ 1.210242] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.210317] usbcore: registered new interface driver keyspan
[ 1.210379] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.210433] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.210487] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.210540] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.210611] usbcore: registered new interface driver option
[ 1.210667] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.210743] usbcore: registered new interface driver oti6858
[ 1.210799] usbserial: USB Serial support registered for oti6858
[ 1.210864] usbcore: registered new interface driver pl2303
[ 1.210920] usbserial: USB Serial support registered for pl2303
[ 1.210996] usbcore: registered new interface driver qcserial
[ 1.211052] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.211127] usbcore: registered new interface driver sierra
[ 1.211197] usbserial: USB Serial support registered for Sierra USB modem
[ 1.212907] usbcore: registered new interface driver usbtouchscreen
[ 1.212979] ============ himax_hx83102_init 1742 jjlook ==========
[ 1.213005] ============ himax_hx83102_probe 1725 jjlook ==========
[ 1.213095] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[ 1.213123] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[ 1.213579] .. rk pwm remotectl v2.0 init
[ 1.213973] input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input0
[ 1.214496] remotectl-pwm fe6e0030.pwm: pwm version is 0x2130000
[ 1.214538] remotectl-pwm fe6e0030.pwm: cannot find PWR IRQ
[ 1.214557] remotectl-pwm fe6e0030.pwm: pwm sip wakeup config error!!
[ 1.214571] remotectl-pwm fe6e0030.pwm: Donot support ATF Wakeup
[ 1.215546] i2c /dev entries driver
[ 1.217822] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[ 1.218356] vdd_cpu: override max_uV, 1390000 → 1387500
[ 1.219313] fan53555-regulator 0-001c: Looking up vin-supply from device tree
[ 1.219332] vdd_cpu: supplied by vcc5v0_sys
[ 1.219356] vcc5v0_sys: could not add device link regulator.10 err -2
[ 1.221756] vdd_cpu: 712 ↔ 1387 mV at 825 mV
[ 1.224548] rk808 0-0020: chip id: 0x8090
[ 1.224628] rk808 0-0020: No cache defaults, reading back from HW
[ 1.248447] rk808 0-0020: source: on=0x40, off=0x00
[ 1.248520] rk808 0-0020: support dcdc3 fb mode:-22, 63
[ 1.248541] rk808 0-0020: support pmic reset mode:0,0
[ 1.255293] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.255361] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.255823] rk808 0-0020: Looking up vcc1-supply from device tree
[ 1.255844] vdd_logic: supplied by vcc3v3_sys
[ 1.255880] vcc3v3_sys: could not add device link regulator.11 err -2
[ 1.255982] vdd_logic: 500 ↔ 1350 mV at 900 mV
[ 1.256772] rk808 0-0020: Looking up vcc2-supply from device tree
[ 1.256787] vdd_gpu: supplied by vcc3v3_sys
[ 1.256822] vcc3v3_sys: could not add device link regulator.12 err -2
[ 1.256891] vdd_gpu: 500 ↔ 1350 mV at 900 mV
[ 1.257272] rk808 0-0020: Looking up vcc3-supply from device tree
[ 1.257287] vcc_ddr: supplied by vcc3v3_sys
[ 1.257322] vcc3v3_sys: could not add device link regulator.13 err -2
[ 1.257379] vcc_ddr: at 500 mV
[ 1.257776] rk808 0-0020: Looking up vcc4-supply from device tree
[ 1.257791] vdd_npu: supplied by vcc3v3_sys
[ 1.257825] vcc3v3_sys: could not add device link regulator.14 err -2
[ 1.257892] vdd_npu: 500 ↔ 1350 mV at 900 mV
[ 1.258667] rk808 0-0020: Looking up vcc9-supply from device tree
[ 1.258683] vcc_1v8: supplied by vcc3v3_sys
[ 1.258718] vcc3v3_sys: could not add device link regulator.15 err -2
[ 1.258778] vcc_1v8: 1800 mV
[ 1.259143] rk808 0-0020: Looking up vcc5-supply from device tree
[ 1.259158] vdda0v9_image: supplied by vcc3v3_sys
[ 1.259192] vcc3v3_sys: could not add device link regulator.16 err -2
[ 1.259260] vdda0v9_image: 900 mV
[ 1.259976] rk808 0-0020: Looking up vcc5-supply from device tree
[ 1.259992] vdda_0v9: supplied by vcc3v3_sys
[ 1.260026] vcc3v3_sys: could not add device link regulator.17 err -2
[ 1.260100] vdda_0v9: 900 mV
[ 1.260468] rk808 0-0020: Looking up vcc5-supply from device tree
[ 1.260483] vdda0v9_pmu: supplied by vcc3v3_sys
[ 1.260518] vcc3v3_sys: could not add device link regulator.18 err -2
[ 1.260587] vdda0v9_pmu: 900 mV
[ 1.260948] rk808 0-0020: Looking up vcc6-supply from device tree
[ 1.260963] vccio_acodec: supplied by vcc3v3_sys
[ 1.260997] vcc3v3_sys: could not add device link regulator.19 err -2
[ 1.261063] vccio_acodec: 3300 mV
[ 1.261764] rk808 0-0020: Looking up vcc6-supply from device tree
[ 1.261779] vccio_sd: supplied by vcc3v3_sys
[ 1.261852] vcc3v3_sys: could not add device link regulator.20 err -2
[ 1.261941] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 1.262303] rk808 0-0020: Looking up vcc6-supply from device tree
[ 1.262319] vcc3v3_pmu: supplied by vcc3v3_sys
[ 1.262353] vcc3v3_sys: could not add device link regulator.21 err -2
[ 1.262436] vcc3v3_pmu: 3300 mV
[ 1.263157] rk808 0-0020: Looking up vcc7-supply from device tree
[ 1.263173] vcca_1v8: supplied by vcc3v3_sys
[ 1.263207] vcc3v3_sys: could not add device link regulator.22 err -2
[ 1.263286] vcca_1v8: 1800 mV
[ 1.263647] rk808 0-0020: Looking up vcc7-supply from device tree
[ 1.263662] vcca1v8_pmu: supplied by vcc3v3_sys
[ 1.263699] vcc3v3_sys: could not add device link regulator.23 err -2
[ 1.263761] vcca1v8_pmu: 1800 mV
[ 1.264142] rk808 0-0020: Looking up vcc7-supply from device tree
[ 1.264157] vcca1v8_image: supplied by vcc3v3_sys
[ 1.264195] vcc3v3_sys: could not add device link regulator.24 err -2
[ 1.264256] vcca1v8_image: 1800 mV
[ 1.265002] rk808 0-0020: Looking up vcc9-supply from device tree
[ 1.265017] vcc_3v3: supplied by vcc3v3_sys
[ 1.265053] vcc3v3_sys: could not add device link regulator.25 err -2
[ 1.265112] vcc_3v3: at 3300 mV
[ 1.265868] rk808 0-0020: Looking up vcc8-supply from device tree
[ 1.265883] vcc3v3_sd: supplied by vcc3v3_sys
[ 1.265919] vcc3v3_sys: could not add device link regulator.26 err -2
[ 1.265978] vcc3v3_sd: at 3300 mV
[ 1.266528] rk817-battery rk817-battery: Failed to find matching dt id
[ 1.266893] rk817-charger rk817-charger: Failed to find matching dt id
[ 1.270398] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[ 1.271089] rk808-rtc rk808-rtc: device is disabled
[ 1.271132] rk808-rtc: probe of rk808-rtc failed with error -22
[ 1.273507] pca953x 1-0021: Looking up vcc-supply from device tree
[ 1.273520] pca953x 1-0021: Looking up vcc-supply property in node /i2c@fe5a0000/gpio@21 failed
[ 1.273558] pca953x 1-0021: 1-0021 supply vcc not found, using dummy regulator
[ 1.273670] pca953x 1-0021: Linked as a consumer to regulator.0
[ 1.278088] rtc-hym8563 1-0051: rtc information is valid
[ 1.283716] rtc-hym8563 1-0051: rtc core: registered hym8563 as rtc0
[ 1.284801] rtc-hym8563 1-0051: setting system clock to 2022-08-01 02:30:45 UTC (1659321045)
[ 1.286478] pca953x 1-0022: Looking up vcc-supply from device tree
[ 1.286491] pca953x 1-0022: Looking up vcc-supply property in node /i2c@fe5a0000/gpio@22 failed
[ 1.286527] pca953x 1-0022: 1-0022 supply vcc not found, using dummy regulator
[ 1.286634] pca953x 1-0022: Linked as a consumer to regulator.0
[ 1.290703] rockchip-pinctrl pinctrl: pin gpio3-11 already requested by fdc60000.syscon:rgb; cannot claim for fe5e0000.i2c
[ 1.290742] rockchip-pinctrl pinctrl: pin-107 (fe5e0000.i2c) status -22
[ 1.290761] rockchip-pinctrl pinctrl: could not request pin 107 (gpio3-11) from group i2c5m0-xfer on device rockchip-pinctrl
[ 1.290776] rk3x-i2c fe5e0000.i2c: Error applying setting, reverse things back
[ 1.290811] rk3x-i2c: probe of fe5e0000.i2c failed with error -22
[ 1.295202] iommu: Adding device fdff0000.rkisp to group 7
[ 1.295261] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iommu
[ 1.295521] rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[ 1.295543] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[ 1.295598] rkisp_hw fdff0000.rkisp: can’t request region for resource [mem 0xfdff0000-0xfdffffff]
[ 1.296868] rkisp rkisp-vir0: rkisp driver version: v01.08.00
[ 1.297273] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 1.297315] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[ 1.300137] usbcore: registered new interface driver uvcvideo
[ 1.300167] USB Video Class driver (1.1.1)
[ 1.300435] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply from device tree
[ 1.300565] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.21
[ 1.300632] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[ 1.300683] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio2-supply from device tree
[ 1.300789] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[ 1.300843] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio1-supply from device tree
[ 1.300939] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.19
[ 1.300988] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[ 1.301040] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply from device tree
[ 1.301057] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply property in node /syscon@fdc20000/io-domains failed
[ 1.301096] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio3-supply from device tree
[ 1.301200] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.20
[ 1.301248] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[ 1.301303] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio4-supply from device tree
[ 1.301391] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.15
[ 1.301449] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[ 1.301499] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio5-supply from device tree
[ 1.301587] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.25
[ 1.301646] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[ 1.301696] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio6-supply from device tree
[ 1.301865] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[ 1.301920] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio7-supply from device tree
[ 1.302041] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[ 1.306751] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[ 1.308797] pc9202: sw2001_read(0x1) return 0x1
[ 1.308829] status=0x1
[ 1.308848] ====== i2c detect success watchdog init========
[ 1.309092] gpio -2 request failed!
[ 1.309388] Bluetooth: HCI UART driver ver 2.3
[ 1.309406] Bluetooth: HCI UART protocol H4 registered
[ 1.309431] Bluetooth: HCI UART protocol ATH3K registered
[ 1.309753] Bluetooth: HCI UART protocol Broadcom registered
[ 1.309862] usbcore: registered new interface driver bfusb
[ 1.309951] usbcore: registered new interface driver btusb
[ 1.310365] cpu cpu0: leakage=33
[ 1.310444] cpu cpu0: pvtm = 90050, from nvmem
[ 1.310482] cpu cpu0: pvtm-volt-sel=1
[ 1.310851] cpu cpu0: Looking up cpu-supply from device tree
[ 1.311445] cpu cpu0: Linked as a consumer to regulator.10
[ 1.311540] cpu cpu0: Dropping the link to regulator.10
[ 1.311715] cpu cpu0: Looking up cpu-supply from device tree
[ 1.312371] cpu cpu0: Linked as a consumer to regulator.10
[ 1.313604] cpu cpu0: avs=0
[ 1.313706] energy_model: pd0: hertz/watts ratio non-monotonically decreasing: em_cap_state 2 >= em_cap_state1
[ 1.314010] energy_model: Created perf domain 0-3
[ 1.314064] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.316408] cpu cpu0: failed to find power_model node
[ 1.318661] sdhci: Secure Digital Host Controller Interface driver
[ 1.318686] sdhci: Copyright(c) Pierre Ossman
[ 1.318701] Synopsys Designware Multimedia Card Interface Driver
[ 1.319884] dwmmc_rockchip fe000000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.320127] dwmmc_rockchip fe000000.dwmmc: Using internal DMA controller.
[ 1.320155] dwmmc_rockchip fe000000.dwmmc: Version ID is 270a
[ 1.320231] dwmmc_rockchip fe000000.dwmmc: DW MMC controller at irq 43,32 bit host data width,256 deep fifo
[ 1.320272] dwmmc_rockchip fe000000.dwmmc: Looking up vmmc-supply from device tree
[ 1.320285] dwmmc_rockchip fe000000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe000000 failed
[ 1.320321] dwmmc_rockchip fe000000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.320328] dwmmc_rockchip fe000000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe000000 failed
[ 1.320405] dwmmc_rockchip fe000000.dwmmc: allocated mmc-pwrseq
[ 1.320428] mmc_host mmc3: card is non-removable.
[ 1.439497] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.452820] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.452965] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[ 1.452986] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[ 1.453044] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 57,32 bit host data width,256 deep fifo
[ 1.453076] dwmmc_rockchip fe2b0000.dwmmc: Looking up vmmc-supply from device tree
[ 1.453159] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.26
[ 1.453172] dwmmc_rockchip fe2b0000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.453233] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.20
[ 1.466092] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.479021] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.480465] sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply from device tree
[ 1.480478] sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply property in node /sdhci@fe310000 failed
[ 1.480536] sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply from device tree
[ 1.480545] sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe310000 failed
[ 1.480569] mmc0: Unknown controller version (5). You may experience problems.
[ 1.488291] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.490322] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.492167] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.495422] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.511082] mmc0: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[ 1.514739] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.515232] usbcore: registered new interface driver usbhid
[ 1.515251] usbhid: USB HID core driver
[ 1.515853] rockchip,bus bus-npu: Looking up bus-supply from device tree
[ 1.515942] rockchip,bus bus-npu: Linked as a consumer to regulator.11
[ 1.515970] rockchip,bus bus-npu: Failed to get leakage
[ 1.516033] rockchip,bus bus-npu: pvtm = 90050, from nvmem
[ 1.516055] rockchip,bus bus-npu: pvtm-volt-sel=1
[ 1.516339] rockchip,bus bus-npu: avs=0
[ 1.520209] rockchip-saradc fe720000.saradc: Looking up vref-supply from device tree
[ 1.520313] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.22
[ 1.521043] rksfc_base v1.1 2016-01-08
[ 1.521855] rksfc fe300000.sfc: rksfc_probe clk rate = 50000000
[ 1.521925] rkflash_dev_init enter
[ 1.521944] sfc nor id: 20 41 18
[ 1.521960] rkflash[1] init success
[ 1.523107] sfc_nor_mtd_init register mtd succuss
[ 1.523142] rkflash_dev_init device register as mtd dev, ret= 0
[ 1.523987] usbcore: registered new interface driver snd-usb-audio
[ 1.526544] rk817-codec rk817-codec: DMA mask not set
[ 1.527265] rk817_codec_parse_dt_property: rk809 hp adc effective value of detection 0~400
[ 1.527297] invalid rk817->hp_det_gpio: -2
[ 1.527308] invalid gpio: -2
[ 1.534754] NET: Registered protocol family 10
[ 1.535799] Segment Routing with IPv6
[ 1.535871] NET: Registered protocol family 17
[ 1.535887] can: controller area network core (rev 20170425 abi 9)
[ 1.536031] NET: Registered protocol family 29
[ 1.536057] can: raw protocol (rev 20170425)
[ 1.536072] can: broadcast manager protocol (rev 20170425 t)
[ 1.536090] can: netlink gateway (rev 20170425) max_hops=1
[ 1.536331] Bluetooth: RFCOMM socket layer initialized
[ 1.536376] Bluetooth: RFCOMM ver 1.11
[ 1.536392] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.536404] Bluetooth: HIDP socket layer initialized
[ 1.536420] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.536432] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.537036] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.537086] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275s
[ 1.537101] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.537112] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.537174] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 124, flags = 0.
[ 1.537193] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.537205] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.537219] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 1.537230] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.537879] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 73.
[ 1.537915] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 41.
[ 1.538008] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 36.
[ 1.538034] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 42.
[ 1.538113] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.538222] [BT_RFKILL]: ** disable irq
[ 1.538392] [BT_RFKILL]: bt_default device registered.
[ 1.538570] Key type dns_resolver registered
[ 1.538889] flash vendor_init_thread!
[ 1.538900] flash vendor storage:20170308 ret = -1
[ 1.541131] Loading compiled-in X.509 certificates
[ 1.541719] pstore: Using compression: deflate
[ 1.542636] rga2: Driver loaded successfully ver:3.2.63318
[ 1.542965] rga2: Module initialized.
[ 1.544158] mmc0: new HS200 MMC card at address 0001
[ 1.545194] mmcblk0: mmc0:0001 AGUF4R 14.6 GiB
[ 1.545853] mmcblk0boot0: mmc0:0001 AGUF4R partition 1 31.9 MiB
[ 1.546498] mmcblk0boot1: mmc0:0001 AGUF4R partition 2 31.9 MiB
[ 1.546727] mmcblk0rpmb: mmc0:0001 AGUF4R partition 3 4.00 MiB, chardev (238:0)
[ 1.549359] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 1.567758] vcc5v0_host: no parameters
[ 1.567969] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[ 1.569568] usb2_hub_reset_n: no parameters
[ 1.569762] reg-fixed-voltage usb2-hub-reset-regulator: usb2_hub_reset_n supplying 0uV
[ 1.571303] usb3_hub_reset_n: no parameters
[ 1.571447] reg-fixed-voltage usb3-hub-reset-regulator: usb3_hub_reset_n supplying 0uV
[ 1.573092] vcc5v0_usb2_host_en: no parameters
[ 1.573243] reg-fixed-voltage vcc5v0-usb2-host-regulator: vcc5v0_usb2_host_en supplying 0uV
[ 1.574854] vcc_4g_power_en: no parameters
[ 1.574987] reg-fixed-voltage vcc-4g-power-regulator: vcc_4g_power_en supplying 0uV
[ 1.576594] vcc3v3_vga_pwr: no parameters
[ 1.576739] reg-fixed-voltage vcc3v3-vga-pwr: vcc3v3_vga_pwr supplying 0uV
[ 1.578292] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 1.578347] vcc3v3_vga_rst: no parameters
[ 1.578517] reg-fixed-voltage vcc3v3-vga-rst: vcc3v3_vga_rst supplying 0uV
[ 1.578807] phy phy-fe8a0000.usb2-phy.5: Looking up phy-supply from device tree
[ 1.578827] vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.5 err -2
[ 1.578874] phy phy-fe8a0000.usb2-phy.5: Linked as a consumer to regulator.27
[ 1.578959] phy phy-fe8a0000.usb2-phy.6: Looking up phy-supply from device tree
[ 1.578965] phy phy-fe8a0000.usb2-phy.6: Looking up phy-supply property in node /usb2-phy@fe8a0000/otg-port failed
[ 1.579031] phy phy-fe8a0000.usb2-phy.6: Looking up vbus-supply from device tree
[ 1.579069] phy phy-fe8a0000.usb2-phy.6: Linked as a consumer to regulator.4
[ 1.580326] extcon extcon3: failed to create extcon usb2-phy link
[ 1.580378] phy phy-fe8b0000.usb2-phy.7: Looking up phy-supply from device tree
[ 1.580398] vcc5v0_host: could not add device link phy-fe8b0000.usb2-phy.7 err -2
[ 1.580445] phy phy-fe8b0000.usb2-phy.7: Linked as a consumer to regulator.27
[ 1.580526] phy phy-fe8b0000.usb2-phy.8: Looking up phy-supply from device tree
[ 1.580543] vcc5v0_host: could not add device link phy-fe8b0000.usb2-phy.8 err -2
[ 1.580568] phy phy-fe8b0000.usb2-phy.8: Linked as a consumer to regulator.27
[ 1.580631] phy phy-fe8b0000.usb2-phy.8: Looking up vbus-supply from device tree
[ 1.580636] phy phy-fe8b0000.usb2-phy.8: Looking up vbus-supply property in node /usb2-phy@fe8b0000/otg-port failed
[ 1.580659] phy phy-fe8b0000.usb2-phy.8: No vbus specified for otg port
[ 1.581767] rockchip-dp fe0c0000.edp: Looking up vcc-supply from device tree
[ 1.581779] rockchip-dp fe0c0000.edp: Looking up vcc-supply property in node /edp@fe0c0000 failed
[ 1.581829] rockchip-dp fe0c0000.edp: Looking up vccio-supply from device tree
[ 1.581838] rockchip-dp fe0c0000.edp: Looking up vccio-supply property in node /edp@fe0c0000 failed
[ 1.581979] rockchip-drm display-subsystem: defer getting devfreq
[ 1.582211] vp0: rgb_pixelclk: 0
[ 1.582236] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4
[ 1.582249] vp1: rgb_pixelclk: 0
[ 1.582258] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x22, primary plane phy id: 5
[ 1.582270] vp2: rgb_pixelclk: 1
[ 1.582278] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[ 1.582458] [drm] unsupported AFBC format[3432564e]
[ 1.582499] [drm] failed to init overlay plane Cluster0-win1
[ 1.582539] [drm] failed to init overlay plane Cluster1-win1
[ 1.582688] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff800902e2d8)
[ 1.583794] rockchip-drm display-subsystem: bound fe0c0000.edp (ops 0xffffff8009031388)
[ 1.583964] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.584561] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.585326] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 256
[ 1.585923] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8009031df0)
[ 1.585964] rockchip-rgb fdc60000.syscon:rgb: [drm:rockchip_rgb_bind] ERROR failed to find panel or bridge: -517
[ 1.587047] mmc3: new ultra high speed SDR104 SDIO card at address 0001
[ 1.587821] /rgb0_panel: could not find display-timings node
[ 1.587840] /rgb0_panel: no timings specified
[ 1.587859] panel-simple rgb0_panel: Looking up power-supply from device tree
[ 1.587866] panel-simple rgb0_panel: Looking up power-supply property in node /rgb0_panel failed
[ 1.587896] panel-simple rgb0_panel: rgb0_panel supply power not found, using dummy regulator
[ 1.587949] panel-simple rgb0_panel: Looking up vsp-supply from device tree
[ 1.587956] panel-simple rgb0_panel: Looking up vsp-supply property in node /rgb0_panel failed
[ 1.587969] panel-simple rgb0_panel: rgb0_panel supply vsp not found, using dummy regulator
[ 1.588020] panel-simple rgb0_panel: Looking up vsn-supply from device tree
[ 1.588026] panel-simple rgb0_panel: Looking up vsn-supply property in node /rgb0_panel failed
[ 1.588039] panel-simple rgb0_panel: rgb0_panel supply vsn not found, using dummy regulator
[ 1.589169] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 1.589185] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.589270] mali fde60000.gpu: Looking up mali-supply from device tree
[ 1.589338] mali fde60000.gpu: Linked as a consumer to regulator.12
[ 1.589353] mali fde60000.gpu: Looking up shadercores-supply from device tree
[ 1.589362] mali fde60000.gpu: Looking up shadercores-supply property in node /gpu@fde60000 failed
[ 1.589414] mali fde60000.gpu: Looking up mali-supply from device tree
[ 1.589432] vdd_gpu: could not add device link fde60000.gpu err -17
[ 1.589438] vdd_gpu: Failed to create debugfs directory
[ 1.589446] mali fde60000.gpu: Looking up shadercores-supply from device tree
[ 1.589452] mali fde60000.gpu: Looking up shadercores-supply property in node /gpu@fde60000 failed
[ 1.589468] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19
[ 1.589553] mali fde60000.gpu: leakage=9
[ 1.589594] mali fde60000.gpu: pvtm = 90050, from nvmem
[ 1.589610] mali fde60000.gpu: pvtm-volt-sel=1
[ 1.589999] mali fde60000.gpu: avs=0
[ 1.590018] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 1.590283] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[ 1.590349] mali fde60000.gpu: No priority control manager is configured
[ 1.590364] mali fde60000.gpu: No memory group manager is configured
[ 1.590874] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 1.591445] mali fde60000.gpu: Probed as mali0
[ 1.593459] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 1.597394] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.597603] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 1.598027] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010
[ 1.598077] xhci-hcd xhci-hcd.0.auto: irq 90, io mem 0xfd000000
[ 1.598315] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.598329] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.598338] usb usb1: Product: xHCI Host Controller
[ 1.598349] usb usb1: Manufacturer: Linux 4.19.232 xhci-hcd
[ 1.598359] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 1.598779] hub 1-0:1.0: USB hub found
[ 1.598814] hub 1-0:1.0: 1 port detected
[ 1.599044] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.599203] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 1.599223] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 1.599278] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.599371] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 1.599384] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.599394] usb usb2: Product: xHCI Host Controller
[ 1.599400] usb usb2: Manufacturer: Linux 4.19.232 xhci-hcd
[ 1.599407] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 1.599705] hub 2-0:1.0: USB hub found
[ 1.599741] hub 2-0:1.0: 1 port detected
[ 1.602347] ehci-platform fd800000.usb: EHCI Host Controller
[ 1.602513] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 3
[ 1.602810] ehci-platform fd800000.usb: irq 11, io mem 0xfd800000
[ 1.615159] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[ 1.615413] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.615436] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.615454] usb usb3: Product: EHCI Host Controller
[ 1.615470] usb usb3: Manufacturer: Linux 4.19.232 ehci_hcd
[ 1.615481] usb usb3: SerialNumber: fd800000.usb
[ 1.616083] hub 3-0:1.0: USB hub found
[ 1.616143] hub 3-0:1.0: 1 port detected
[ 1.619030] ehci-platform fd880000.usb: EHCI Host Controller
[ 1.619303] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 4
[ 1.619704] ehci-platform fd880000.usb: irq 13, io mem 0xfd880000
[ 1.631952] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[ 1.632198] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.632221] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.632242] usb usb4: Product: EHCI Host Controller
[ 1.632258] usb usb4: Manufacturer: Linux 4.19.232 ehci_hcd
[ 1.632273] usb usb4: SerialNumber: fd880000.usb
[ 1.632897] hub 4-0:1.0: USB hub found
[ 1.632956] hub 4-0:1.0: 1 port detected
[ 1.633788] ohci-platform fd840000.usb: Generic Platform OHCI controller
[ 1.634090] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 5
[ 1.634375] ohci-platform fd840000.usb: irq 12, io mem 0xfd840000
[ 1.668335] vendor storage:20190527 ret = 0
[ 1.692705] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.692727] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.692737] usb usb5: Product: Generic Platform OHCI controller
[ 1.692745] usb usb5: Manufacturer: Linux 4.19.232 ohci_hcd
[ 1.692752] usb usb5: SerialNumber: fd840000.usb
[ 1.693272] hub 5-0:1.0: USB hub found
[ 1.693314] hub 5-0:1.0: 1 port detected
[ 1.694031] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[ 1.694301] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 6
[ 1.694540] ohci-platform fd8c0000.usb: irq 14, io mem 0xfd8c0000
[ 1.703422] devfreq fde60000.gpu: Couldn’t update frequency transition information.
[ 1.752687] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.752713] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.752722] usb usb6: Product: Generic Platform OHCI controller
[ 1.752730] usb usb6: Manufacturer: Linux 4.19.232 ohci_hcd
[ 1.752738] usb usb6: SerialNumber: fd8c0000.usb
[ 1.753266] hub 6-0:1.0: USB hub found
[ 1.753310] hub 6-0:1.0: 1 port detected
[ 1.754062] input: adc-keys as /devices/platform/adc-keys/input/input2
[ 1.754730] rockchip-dmc dmc: Looking up center-supply from device tree
[ 1.754800] rockchip-dmc dmc: Linked as a consumer to regulator.11
[ 1.754907] rockchip-dmc dmc: leakage=60
[ 1.754931] rockchip-dmc dmc: leakage-volt-sel=0
[ 1.754977] rockchip-dmc dmc: pvtm = 90050, from nvmem
[ 1.754998] rockchip-dmc dmc: pvtm-volt-sel=1
[ 1.755207] rockchip-dmc dmc: avs=0
[ 1.755235] rockchip-dmc dmc: current ATF version 0x101
[ 1.756154] rockchip-dmc dmc: normal_rate = 780000000
[ 1.756167] rockchip-dmc dmc: reboot_rate = 1560000000
[ 1.756186] rockchip-dmc dmc: suspend_rate = 324000000
[ 1.756200] rockchip-dmc dmc: video_4k_rate = 780000000
[ 1.756213] rockchip-dmc dmc: video_4k_10b_rate = 780000000
[ 1.756226] rockchip-dmc dmc: boost_rate = 1560000000
[ 1.756238] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1560000000
[ 1.756251] rockchip-dmc dmc: performance_rate = 1560000000
[ 1.756280] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 1.756453] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.756505] rockchip-dmc dmc: could not find power_model node
[ 1.759921] rk817-codec rk817-codec: rk817_probe: chip_name:0x80, chip_ver:0x94
[ 1.766008] asoc-simple-card rk809-sound: rk817-hifi ↔ fe410000.i2s mapping ok
[ 1.766076] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 1.766089] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 1.766104] asoc-simple-card rk809-sound: ASoC: no source widget found for Mic Jack
[ 1.766118] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 1.766132] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 1.766144] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 1.766157] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 1.766169] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 1.769416] rockchip-dp fe0c0000.edp: Looking up vcc-supply from device tree
[ 1.769437] rockchip-dp fe0c0000.edp: Looking up vcc-supply property in node /edp@fe0c0000 failed
[ 1.769507] rockchip-dp fe0c0000.edp: Looking up vccio-supply from device tree
[ 1.769517] rockchip-dp fe0c0000.edp: Looking up vccio-supply property in node /edp@fe0c0000 failed
[ 1.769849] rockchip-drm display-subsystem: devfreq is ready
[ 1.770420] vp0: rgb_pixelclk: 0
[ 1.770462] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4
[ 1.770485] vp1: rgb_pixelclk: 0
[ 1.770504] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x22, primary plane phy id: 5
[ 1.770522] vp2: rgb_pixelclk: 1
[ 1.770538] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[ 1.770883] [drm] failed to init overlay plane Cluster0-win1
[ 1.770954] [drm] failed to init overlay plane Cluster1-win1
[ 1.771168] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff800902e2d8)
[ 1.773424] rockchip-drm display-subsystem: bound fe0c0000.edp (ops 0xffffff8009031388)
[ 1.773793] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.774753] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.777738] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8009031df0)
[ 1.777851] rockchip-drm display-subsystem: bound fdc60000.syscon:rgb (ops 0xffffff8009034ec0)
[ 1.777879] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.777892] [drm] No driver support for vblank timestamp query.
[ 1.778332] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 1.778364] rockchip-drm display-subsystem: can’t not find any loader display
[ 1.778382] rockchip-drm display-subsystem: failed to show loader logo
[ 1.852132] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 1.865220] usb 3-1: new high-speed USB device number 2 using ehci-platform
[ 1.878557] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 1.896148] fbcon: Deferring console take-over
[ 1.896203] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.897605] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 1.899843] asoc-simple-card hdmi-sound: i2s-hifi ↔ fe400000.i2s mapping ok
[ 1.904723] register spi return v = :0
[ 1.904783] dhd_module_init: in Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 1.904798] ======== dhd_wlan_init_plat_data ========
[ 1.904808] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.904909] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=119, oob_irq_flags=0x414
[ 1.904925] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 1.904946] dhd_wifi_platform_load: Enter
[ 1.904965] Power-up adapter ‘DHD generic adapter’
[ 1.905717] wifi_platform_set_power = 1, delay: 200 msec
[ 1.905745] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.905760] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.905774] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 1.905786] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 1.958568] rk-pcie 3c0000000.pcie: PCIe Link up, LTSSM is 0x130011
[ 1.958828] rk-pcie 3c0000000.pcie: PCI host bridge to bus 0000:00
[ 1.958860] pci_bus 0000:00: root bus resource [bus 00-0f]
[ 1.958878] pci_bus 0000:00: root bus resource [??? 0xf4000000-0xf40fffff flags 0x0]
[ 1.958897] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff])
[ 1.958913] pci_bus 0000:00: root bus resource [mem 0xf4200000-0xf5ffffff]
[ 1.958924] pci_bus 0000:00: root bus resource [mem 0x300000000-0x33fffffff pref]
[ 1.958975] pci 0000:00:00.0: [1d87:3566] type 01 class 0x060400
[ 1.959018] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[ 1.959079] pci 0000:00:00.0: supports D1 D2
[ 1.959084] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 1.968893] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f])
[ 1.968977] pci 0000:01:00.0: [1b21:0611] type 00 class 0x010185
[ 1.969109] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 1.969150] pci 0000:01:00.0: reg 0x10: [io size 0x0008]
[ 1.969178] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[ 1.969188] pci 0000:01:00.0: reg 0x14: [io size 0x0004]
[ 1.969214] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[ 1.969224] pci 0000:01:00.0: reg 0x18: [io size 0x0008]
[ 1.969250] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[ 1.969259] pci 0000:01:00.0: reg 0x1c: [io size 0x0004]
[ 1.969285] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[ 1.969303] pci 0000:01:00.0: reg 0x20: [io size 0x0010]
[ 1.969330] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x000001ff]
[ 1.985809] pci 0000:00:00.0: BAR 8: assigned [mem 0xf4200000-0xf42fffff]
[ 1.985889] pci 0000:00:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref]
[ 1.985902] pci 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 1.985926] pci 0000:01:00.0: BAR 5: assigned [mem 0xf4200000-0xf42001ff]
[ 1.985954] pci 0000:01:00.0: BAR 4: assigned [io 0x1000-0x100f]
[ 1.985972] pci 0000:01:00.0: BAR 0: assigned [io 0x1010-0x1017]
[ 1.985990] pci 0000:01:00.0: BAR 2: assigned [io 0x1018-0x101f]
[ 1.986008] pci 0000:01:00.0: BAR 1: assigned [io 0x1020-0x1023]
[ 1.986025] pci 0000:01:00.0: BAR 3: assigned [io 0x1024-0x1027]
[ 1.986044] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 1.986087] pci 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 1.986104] pci 0000:00:00.0: bridge window [mem 0xf4200000-0xf42fffff]
[ 1.989018] pcieport 0000:00:00.0: Signaling PME with IRQ 121
[ 1.990487] pcieport 0000:00:00.0: AER enabled with IRQ 130
[ 1.991903] ahci 0000:01:00.0: version 3.0
[ 1.991940] ahci 0000:01:00.0: enabling device (0000 → 0003)
[ 1.992467] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
[ 1.992548] ahci 0000:01:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl IDE mode
[ 1.992565] ahci 0000:01:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs
[ 1.994444] scsi host0: ahci
[ 1.995115] scsi host1: ahci
[ 1.995517] ata1: SATA max UDMA/133 abar m512@0xf4200000 port 0xf4200100 irq 131
[ 1.995540] ata2: SATA max UDMA/133 abar m512@0xf4200000 port 0xf4200180 irq 131
[ 2.010855] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1024x768p60, type: 17 for vp2
[ 2.011185] dclk_inv : 1
[ 2.084446] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.91
[ 2.084515] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.084534] usb 1-1: Product: USB2.1 Hub
[ 2.084548] usb 1-1: Manufacturer: GenesysLogic
[ 2.087058] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
[ 2.087100] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.087114] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 2.088152] hub 3-1:1.0: USB hub found
[ 2.088367] hub 3-1:1.0: 4 ports detected
[ 2.144303] hub 1-1:1.0: USB hub found
[ 2.144742] hub 1-1:1.0: 4 ports detected
[ 2.207474] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 2.212025] wifi_platform_bus_enumerate device present 1
[ 2.212098] ======== Card detection to detect SDIO card! ========
[ 2.212118] mmc3:mmc host rescan start!
[ 2.225392] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.91
[ 2.225420] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.225429] usb 2-1: Product: USB3.2 Hub
[ 2.225437] usb 2-1: Manufacturer: GenesysLogic
[ 2.228341] bcmsdh_register: register client driver
[ 2.228811] bcmsdh_sdmmc_probe: Enter num=1
[ 2.230333] bcmsdh_sdmmc_probe: Enter num=2
[ 2.230357] bus num (host idx)=3, slot num (rca)=1
[ 2.230366] found adapter info ‘DHD generic adapter’
[ 2.230569] sdioh_attach: set sd_f2_blocksize 256
[ 2.230658] sdioh_attach: sd clock rate = 0
[ 2.231150] dhdsdio_probe : no mutex held. set lock
[ 2.231387] F1 signature read @0x18000000=0x1042aae8
[ 2.235286] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 2.235954] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 2.236057] [dhd] dhd_conf_set_chiprev : chip=0xaae8, chiprev=2
[ 2.237295] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.237324] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.237337] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.237344] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.237725] dhd_log_dump_init: kernel log buf size = 256KB; logdump_prsrv_tailsize = 80KB; limit prsrv tail size to = 38KB
[ 2.240307] dhd_attach(): thread:dhd_watchdog_thread:75 started
[ 2.240548] dhd_attach(): thread:dhd_dpc:76 started
[ 2.240724] dhd_attach(): thread:dhd_rxf:77 started
[ 2.240752] dhd_deferred_work_init: work queue initialized
[ 2.240773] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 2.240932] get_mem_val_from_file: File [/data/misc/wifi/.memdump.info] doesn’t exist
[ 2.240948] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[ 2.240965] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 2.248865] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 2.249035] Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 2.249920] Register interface [wlan0] MAC: 10:2c:6b:7f:ad:80
[ 2.249920]
[ 2.250093] dhd_dbg_detach_pkt_monitor, 2100
[ 2.250115] dhd_bus_devreset: == Power OFF ==
[ 2.250365] dhd_bus_stop: making DHD_BUS_DOWN
[ 2.250410] bcmsdh_oob_intr_unregister: Enter
[ 2.250422] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.250441] dhd_bus_devreset: making dhdpub up FALSE
[ 2.250455] dhd_txglom_enable: enable 0
[ 2.250465] dhd_bus_devreset: making DHD_BUS_DOWN
[ 2.250476] dhd_bus_devreset: WLAN OFF DONE
[ 2.250521] wifi_platform_set_power = 0, delay: 0 msec
[ 2.250538] ======== PULL WL_REG_ON(-1) LOW! ========
[ 2.250546] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.250580] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 2.250592] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 2.250607] dhdsdio_probe : the lock is released.
[ 2.252104] dhd_module_init: Exit err=0
[ 2.253043] ==gsl_ts_init==
[ 2.253175] ret=0
[ 2.255202] iommu: Adding device fde40000.npu to group 0
[ 2.255318] RKNPU fde40000.npu: Linked as a consumer to fde4b000.iommu
[ 2.256027] hub 2-1:1.0: USB hub found
[ 2.256452] hub 2-1:1.0: 4 ports detected
[ 2.256469] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 2.256552] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[ 2.256730] RKNPU fde40000.npu: Linked as a consumer to regulator.14
[ 2.256774] RKNPU fde40000.npu: can’t request region for resource [mem 0xfde40000-0xfde4ffff]
[ 2.257574] [drm] Initialized rknpu 0.4.2 20210701 for fde40000.npu on minor 1
[ 2.258215] RKNPU fde40000.npu: leakage=4
[ 2.258264] RKNPU fde40000.npu: pvtm = 90050, from nvmem
[ 2.258287] RKNPU fde40000.npu: pvtm-volt-sel=1
[ 2.259103] RKNPU fde40000.npu: avs=0
[ 2.259919] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 2.259960] RKNPU fde40000.npu: failed to find power_model node
[ 2.259976] RKNPU fde40000.npu: RKNPU: failed to initialize power model
[ 2.259983] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient
[ 2.262040] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.270675] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 2.272103] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.272139] cfg80211: failed to load regulatory.db
[ 2.273266] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 2.275577] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘16:16:30’, on ‘Jul 9 2022’.
[ 2.276402] Mali:
[ 2.276405] Mali device driver loaded
[ 2.277056] xc7160 4-001b: T-chip firefly camera driver version: 00.01.02
[ 2.277693] xc7160 4-001b: Failed to get power-gpios, maybe no use
[ 2.280012] xc7160 4-001b: Looking up avdd-supply from device tree
[ 2.280029] xc7160 4-001b: Looking up avdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.280099] xc7160 4-001b: 4-001b supply avdd not found, using dummy regulator
[ 2.280246] xc7160 4-001b: Linked as a consumer to regulator.0
[ 2.280262] xc7160 4-001b: Looking up dovdd-supply from device tree
[ 2.280269] xc7160 4-001b: Looking up dovdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.280287] xc7160 4-001b: 4-001b supply dovdd not found, using dummy regulator
[ 2.280365] xc7160 4-001b: Looking up dvdd-supply from device tree
[ 2.280373] xc7160 4-001b: Looking up dvdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.280386] xc7160 4-001b: 4-001b supply dvdd not found, using dummy regulator
[ 2.280448] xc7160 4-001b: could not get default pinstate
[ 2.280461] xc7160 4-001b: could not get sleep pinstate
[ 2.280490] xc7160 4-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 2.280504] xc7160 4-001b: xc7160 num data lanes is 4
[ 2.298617] xc7160 4-001b: write XC7160_REG_HIGH_SELECT failed
[ 2.299852] xc7160: probe of 4-001b failed with error -5
[ 2.299983] rkisp rkisp-vir0: clear unready subdev num: 4
[ 2.300006] rockchip-csi2-dphy0: No link between dphy and sensor
[ 2.300655] rockchip-csi2-dphy0: No link between dphy and sensor
[ 2.300670] rkisp-vir0: update sensor failed
[ 2.303609] ret 1024 0
[ 2.304363] ALSA device list:
[ 2.304382] #0: rockchip,rk809-codec
[ 2.304389] #1: rockchip,hdmi
[ 2.791074] phy phy-fe8a0000.usb2-phy.6: charger = USB_CDP_CHARGER
[ 2.892162] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 3.336427] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.336507] ata1: ready = 1 sstatus = 0
[ 3.905509] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x1
[ 4.669701] ata2: SATA link down (SStatus 0 SControl 300)
[ 4.669783] ata2: ready = 1 sstatus = 0
[ 4.674537] Freeing unused kernel memory: 1600K
[ 4.674774] Run /init as init process
[ 4.918612] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 5.932073] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 6.945477] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 7.014711] phy phy-fe8a0000.usb2-phy.6: charger = USB_SDP_CHARGER
[ 7.958801] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 8.972135] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 9.985409] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 10.998781] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x1
[ 11.140026] EXT4-fs (mmcblk0p7): recovery complete
[ 11.140902] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 12.012182] rk-pcie 3c0800000.pcie: PCIe Link Fail
[ 12.012291] rk-pcie 3c0800000.pcie: failed to initialize host
[ 33.772112] vcc5v0_otg: disabling
[ 33.772203] pcie30_3v3: disabling
(initramfs)
5.使用官方固件包可以烧录成功,请求大神解惑!
2022.8.1_rklog.zip (20.2 KB)
你下载的文件系统,具体是哪个?是不是下错了
