请问HDMI IN 即HDMI输入的视频数据如何实现推流出去?怎么用
那个test_hdmi.sh 也报错。
./test_hdmirx.sh
[ 200.016457] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 200.016487] stream_cif_Failed to open /dev/video0: No such device
mipi_id0: update sensor info failed -19
[ 200.016519] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 200.016527] stream_cif_mipi_id1: update sensor info failed -19
[ 200.016553] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 200.016559] stream_cif_mipi_id2: update sensor info failed -19
[ 200.016585] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 200.016592] stream_cif_mipi_id3: update sensor info failed -19
[ 200.016617] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 200.016624] rkcif_scale_ch0: update sensor info failed -19
[ 200.016649] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 200.016656] rkcif_scale_ch1: update sensor info failed -19
[ 200.016680] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 200.016687] rkcif_scale_ch2: update sensor info failed -19
[ 200.016712] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 200.016719] rkcif_scale_ch3: update sensor info failed -19
[ 200.017067] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 200.017077] stream_cif_mipi_id0: update sensor info failed -19
VIDIOC_S_DV_TIMINGS: failed: Invalid argument
[Ctrl + C] exit
[ 200.107626] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 200.107636] stream_cif_mipi_id0: update sensor info failed -19
[ 200.107694] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 200.107697] stream_cif_mipi_id1: update sensor info failed -19
[ 200.107752] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 200.107754] stream_cif_mipi_id2: update sensor info failed -19
root@firefly:/usr/local/bin# v4l2-ctl -d /dev/video8 -V -D
Driver Info:
Driver name : rk_hdmirx
Card type : rk_hdmirx
Bus info : fdee0000.hdmirx-controller
Driver version : 5.10.66
Capabilities : 0x84201000
Video Capture Multiplanar
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04201000
Streaming
Extended Pix Format
Format Video Capture Multiplanar:
Width/Height : 1920/1080
Pixel Format : ‘RGB3’ (24-bit RGB 8-8-8)
Field : None
Number of planes : 1
Flags : premultiplied-alpha, 0x000000fe
Colorspace : Unknown (0x10603628)
Transfer Function : Default
YCbCr/HSV Encoding: Unknown (0x000000ff)
Quantization : Default
Plane 0 :
Bytes per Line : 5760
Size Image : 6220800
