3588J Android12 怎么单独更新内核?
我用 msk ARCH=arm64 BOOT_IMG=../rockdev/Image-rk3588_firefly_itx_3588j/boot.img rk3588-firefly-itx-3588j.img -j8 命令编译的boot.img
用 sudo ../RKTools/linux/Linux_Upgrade_Tool/Linux_Upgrade_Tool_v2.4/upgrade_tool di -b boot.img 命令烧录的内核
发现修改的打印都没有变化,所以请问 要怎么才能更新内核?
kernel前开机打印如下:
DDR Version V1.07 20220412
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-gc060f28d70-220414 #zyf (Apr 18 2022 - 18:13:34)
Failed to set cpub01
Failed to set cpub23
unknown raw ID phN
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 1
spl: mmc init failed with error: -123
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(581130cddd…) + OK
## Checking uboot 0x00200000 … sha256(48b3755843…) + OK
## Checking fdt 0x00328498 … sha256(c07f4a4d71…) + OK
## Checking atf-2 0x000f0000 … sha256(6a00298af8…) + OK
## Checking atf-3 0xff100000 … sha256(71c3a5841b…) + OK
## Checking atf-4 0xff001000 … sha256(2301cf73be…) + OK
## Checking optee 0x08400000 … sha256(603cfbd25d…) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 116.2 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-364-g55ca4fb1c:derrick.huang
NOTICE: BL31: Built : 12:00:02, May 13 2022
INFO: timer_hp_init no valid 32k timer source, use normal mode
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing BL32
INFO: hdmirx_handler: dma not on, ret
I/TC:
I/TC: OP-TEE version: 3.13.0-639-g8e053a881-dev #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Mon Mar 14 09:09:01 CST 2022 aarch64
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Aug 11 2022 - 15:34:50 +0800)
Model: Rockchip RK3588 Evaluation Board
PreSerial: 2, raw, 0xfeb50000
DRAM: 7.7 GiB
Sysmem: init
Relocation Offset: edb4e000
Relocation fdt: eb9fa168 - eb9fecd0
CR: M/C/I
mmc@fe2c0000: 1, mmc@fe2e0000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
DM: v2
boot mode: None
Android 12.0, Build 2022.4, v2
Found DTB in boot part
DTB: rk-kernel.dtb
HASH(c): OK
ANDROID: fdt overlay OK
I2c0 speed: 100000Hz
vsel-gpios- not found!
en-gpios- not found!
vdd_cpu_big0_s0 1000000 uV
vdd_cpu_big1_s0 675000 uV
I2c1 speed: 100000Hz
vdd_npu_s0 812500 uV
spi2: RK806: 2
ON=0x00, OFF=0x00
vdd_gpu_s0 750000 uV
vdd_cpu_lit_s0 750000 uV
vdd_log_s0 750000 uV
vdd_vdenc_s0 init 750000 uV
vdd_ddr_s0 850000 uV
I2c6 speed: 400000Hz
Error reading output register
Model: Firefly ITX-3588J HDMI(Android)
CLK: (uboot. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
b0pll 1200000 KHz
b1pll 1200000 KHz
lpll 1200000 KHz
v0pll 24000 KHz
aupll 786431 KHz
cpll 1500000 KHz
gpll 1188000 KHz
npll 850000 KHz
ppll 1100000 KHz
aclk_center_root 702000 KHz
pclk_center_root 100000 KHz
hclk_center_root 396000 KHz
aclk_center_low_root 500000 KHz
aclk_top_root 750000 KHz
pclk_top_root 100000 KHz
aclk_low_top_root 396000 KHz
Net: eth1: ethernet@fe1c0000, eth0: ethernet@fe1b0000
optee api revision: 2.0
Vboot=0, AVB images, AVB verify
read_is_device_unlocked() ops returned that device is UNLOCKED
avb_footer.c:41: ERROR: Footer magic is incorrect.
avb_vbmeta_image.c:65: ERROR: Magic is incorrect.
avb_slot_verify.c:773: ERROR: recovery: Error verifying vbmeta image: invalid vbmeta header
Verify recovery with vbmeta.
avb_slot_verify.c:762: ERROR: vbmeta: Error verifying vbmeta image: OK_NOT_SIGNED
get image from preloaded partition…
ANDROID: Hash OK
Could not find “system” partition
Booting IMAGE kernel at 0x00400000 with fdt at 0x0a100000…
Fdt Ramdisk skip relocation
## Booting Android Image at 0x003ff800 …
Kernel: 0x00400000 - 0x026e6008 (35737 KiB)
ramdisk: 0x0a200000 - 0x0d05f2f2 (47485 KiB)
## Flattened Device Tree blob at 0x0a100000
XIP Kernel Image from 0x00400000 to 0x00400000 … OK
kernel loaded at 0x00400000, end = 0x026e6008
‘reserved-memory’ cma: addr=10000000 size=10000000
Using Device Tree in place at 000000000a100000, end 000000000a140979
Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000)
Total: 2864.620 ms
我编译安卓的时候用eng的flag编译出debug版本就可以正常替换内核了。。
兄弟,你咋编译的,我和你遇到的情况一样
