固件文件名称:iCore-3568JQ V1.0 2022.04.13
固件下载地址:官网
Log日志:文档.txt
iCore-3568JQ最小系统有那些条件?
我开机 后只有40-50ma是什么问题?
文档.txt (3 Bytes)
固件下载地址:官网
Log日志:文档.txt
文档.txt (3 Bytes)
你好。最小系统,你指的是什么,硬件最小系统?还是指功耗方面的问题
硬件
硬件最小电路跟单片机最小电路差不多,时钟、电源(PMU)、复位、启动介质等电路;底板设计参考ITX-3568JQ
核心板说明上
我自己做了个底板,只提供sys_5V电源,没有外设,开机后会无法启动。循环打log
[ 1.496056] rockchip-usb2phy fe8a0000.usb2-phy: failed to create phy
[ 1.496790] rockchip-usb2phy fe8b0000.usb2-phy: failed to create phy
[ 1.498167] rockchip-drm display-subsystem: devfreq is ready
[ 1.498546] vp0: rgb_pixelclk: 0
[ 1.498588] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4
[ 1.498605] vp1: rgb_pixelclk: 0
[ 1.498620] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x22, primary plane phy id: 5
[ 1.498632] vp2: rgb_pixelclk: 1
[ 1.498642] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[ 1.498940] [drm] failed to init overlay plane Cluster0-win1
[ 1.498989] [drm] failed to init overlay plane Cluster1-win1
[ 1.499169] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8009032338)
[ 1.501220] rockchip-drm display-subsystem: bound fe0c0000.edp (ops 0xffffff80090353e8)
[ 1.501556] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.502506] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.504799] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8009035e50)
[ 1.504899] rockchip-rgb fdc60000.syscon:rgb: [drm:rockchip_rgb_bind] ERROR failed to find panel or bridge: -517
[ 1.508223] /rgb0_panel: could not find display-timings node
[ 1.508257] /rgb0_panel: no timings specified
[ 1.508361] panel-simple rgb0_panel: rgb0_panel supply power not found, using dummy regulator
[ 1.508495] panel-simple rgb0_panel: rgb0_panel supply vsp not found, using dummy regulator
[ 1.508564] panel-simple rgb0_panel: rgb0_panel supply vsn not found, using dummy regulator
[ 1.509448] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.511032] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 1.517597] rockchip-usb2phy fe8a0000.usb2-phy: failed to create phy
[ 1.518445] rockchip-usb2phy fe8b0000.usb2-phy: failed to create phy
[ 1.519524] rockchip-drm display-subsystem: devfreq is ready
[ 1.519890] vp0: rgb_pixelclk: 0
[ 1.519931] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4
[ 1.519952] vp1: rgb_pixelclk: 0
[ 1.519964] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x22, primary plane phy id: 5
[ 1.519979] vp2: rgb_pixelclk: 1
[ 1.519991] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[ 1.520338] [drm] failed to init overlay plane Cluster0-win1
[ 1.520389] [drm] failed to init overlay plane Cluster1-win1
[ 1.520580] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8009032338)
[ 1.522303] rockchip-drm display-subsystem: bound fe0c0000.edp (ops 0xffffff80090353e8)
[ 1.522595] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.523454] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.525501] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8009035e50)
[ 1.525596] rockchip-rgb fdc60000.syscon:rgb: [drm:rockchip_rgb_bind] ERROR failed to find panel or bridge: -517
[ 1.529013] /rgb0_panel: could not find display-timings node
[ 1.529046] /rgb0_panel: no timings specified
[ 1.529146] panel-simple rgb0_panel: rgb0_panel supply power not found, using dummy regulator
[ 1.529278] panel-simple rgb0_panel: rgb0_panel supply vsp not found, using dummy regulator
[ 1.529344] panel-simple rgb0_panel: rgb0_panel supply vsn not found, using dummy regulator
[ 1.530345] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.531781] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 1.538380] rockchip-usb2phy fe8a0000.usb2-phy: failed to create phy
[ 1.539185] rockchip-usb2phy fe8b0000.usb2-phy: failed to create phy
[ 1.540528] rockchip-drm display-subsystem: devfreq is ready
[ 1.540936] vp0: rgb_pixelclk: 0
[ 1.540977] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4
[ 1.540993] vp1: rgb_pixelclk: 0
[ 1.541006] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x22, primary plane phy id: 5
[ 1.541021] vp2: rgb_pixelclk: 1
[ 1.541033] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[ 1.541157] mmc_host mmc3: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 1.541736] [drm] failed to init overlay plane Cluster0-win1
[ 1.541828] [drm] failed to init overlay plane Cluster1-win1
[ 1.542064] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8009032338)
[ 1.542301] mmc3: new high speed SDIO card at address 0001
[ 1.544281] rockchip-drm display-subsystem: bound fe0c0000.edp (ops 0xffffff80090353e8)
[ 1.544581] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.545492] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.547517] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8009035e50)
[ 1.547606] rockchip-rgb fdc60000.syscon:rgb: [drm:rockchip_rgb_bind] ERROR failed to find panel or bridge: -517
[ 1.550856] /rgb0_panel: could not find display-timings node
[ 1.550894] /rgb0_panel: no timings specified
[ 1.550988] panel-simple rgb0_panel: rgb0_panel supply power not found, using dummy regulator
[ 1.551124] panel-simple rgb0_panel: rgb0_panel supply vsp not found, using dummy regulator
[ 1.551191] panel-simple rgb0_panel: rgb0_panel supply vsn not found, using dummy regulator
[ 1.551870] vendor storage:20190527 ret = 0
[ 1.552156] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.553379] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
你的问题找解决了吗?
