core-rk3399-jd4核心板配置eDP后,系统启动过程中崩溃,请问应该如何正确配置eDP屏?
SDK包名称:rk3399_linux_release_v2.5.1_20210301_firefly_split
SDK修改内容:rk3399-firefly-aiojd4.dtsi
Log日志:edp崩溃日志.txt
使用的core-rk3399-jd4核心板 + AIO载板,因为要使用eDP显示屏,修改了rk3399-firefly-aiojd4.dtsi。
但是修改后,系统在启动过程中会崩溃,请问应该如何排查????
使用硬件如图所示
rk3399-firefly-aiojd4.dtsi文件内容如下:
/dts-v1/;
#include "rk3399-firefly-port.dtsi"
#include <dt-bindings/sensor-dev.h>
#include <dt-bindings/display/media-bus-format.h>
	test-power {
		status = "okay";
	rt5640-sound {
		simple-audio-card,cpu {
		        sound-dai = <&i2s1>;
		simple-audio-card,codec {
		        sound-dai = <&rt5640>;
	adc-keys {
		compatible = "adc-keys";
		io-channels = <&saradc 1>;
		io-channel-names = "buttons";
		poll-interval = <300>;
		keyup-threshold-microvolt = <1800000>;
		esc-key {
			linux,code = <KEY_ESC>;
			label = "esc";
			press-threshold-microvolt = <0>;
	fan_ctl: fan-ctl-regulator {
		compatible = "regulator-fixed";
		enable-active-high;
		regulator-always-on;
		regulator-boot-on;
		gpio = <&gpio3 10 GPIO_ACTIVE_HIGH>;
		pinctrl-names = "default";
		regulator-name = "fan_ctl";
		pinctrl-0 = <&fan_drv>;
	NPU5801_PWR_EN: HUB20-PWR-EN {
		enable-active-high;
		regulator-boot-on;
		gpio = <&gpio0 2 GPIO_ACTIVE_HIGH>;
		pinctrl-0 = <&npu5801_pwr_en>;
		regulator-name = "vcc5v0_5801_en";
		status = "okay";
&gmac {
	tx_delay = <0x2F>;
	rx_delay = <0x1E>;
&vcc_sd_h {
	rockchip,pins = <1 22 RK_FUNC_GPIO &pcfg_pull_up>;
&vcc_sd {
	gpio = <&gpio1 22 GPIO_ACTIVE_HIGH>;
&hdmi_dp_sound {
	status = "okay";
&i2c2 {
	status = "disabled";
	i2c-scl-rising-time-ns = <300>;
	i2c-scl-falling-time-ns = <15>;
	sensor@4c {
		compatible = "gs_mc3230";
		reg = <0x4c>;
		type = <SENSOR_TYPE_ACCEL>;
		irq_enable = <0>;
		poll_delay_ms = <30>;
		layout = <1>;
&rt5640 {
    hp-det-adc-value = <900>;
    aux-det-adc-value = <900>;
    hp-con-gpio = <&gpio3 16 GPIO_ACTIVE_HIGH>;
    io-channels = <&saradc 3>,<&saradc 2>;
    io-channel-names = "hp-det","aux-det";
&rt5640_hpcon{
    rockchip,pins = <3 16 RK_FUNC_GPIO &pcfg_pull_none>;
&vcca1v8_codec {
	regulator-min-microvolt = <900000>;
	regulator-max-microvolt = <900000>;
&spi1 {
	dev-port = <0>;
	status = "okay";
&spi_wk2xxx {
    status = "okay";
	reset-gpio = <&gpio1 2 GPIO_ACTIVE_HIGH>;
	irq-gpio = <&gpio2 8 IRQ_TYPE_EDGE_FALLING>;
	cs-gpio = <&gpio1 10 GPIO_ACTIVE_HIGH>;
// &spi2 {
//     status = "okay";
//     max-freq = <48000000>;
//     spidev@00 {
//         compatible = "linux,spidev";
//         reg = <0x00>;
//         spi-max-frequency = <48000000>;
// 		status = "okay";
&vcc3v3_3g {
	gpio = <&gpio2 28 GPIO_ACTIVE_HIGH>;
&vcc3v3_pcie {
	/delete-property/ gpio;
&pcie0 {
	ep-gpios = <&gpio4 30 GPIO_ACTIVE_HIGH>;
&uart4 {
&dp_in_vopb {
&hdmi_in_vopl {
&wdt {
	status = "okay";//2022.7.25
&io_domains {
	bt656-supply = <&vcc_3v0>;
&vcc2v8_dvp {
	regulator-min-microvolt = <1800000>;
	regulator-max-microvolt = <1800000>;
&vcca1v8_codec {
&fusb0 {
&cdn_dp {
&tcphy0 {
    /delete-property/ extcon;
    status = "okay";
&u2phy0 {
    status = "okay";
    u2phy0_otg: otg-port {
        rockchip,vbus-always-on;
        vbus-5v-gpios = <&gpio1 3 GPIO_ACTIVE_HIGH>;
        status = "okay";
&usbdrd3_0 {
    status = "okay";
&usbdrd_dwc3_0 {
    dr_mode = "host";
&route_hdmi {
	status = "okay";
	// status = "disabled";
// 20220802 edp
&hdmi_in_vopb {
&hdmi {
	// status = "okay";
&edp_in_vopb {
	status = "okay";
&edp_in_vopl {
&route_edp {
	status = "okay";
	connect = <&edp_in_vopb>;
&backlight {
	status = "okay";
&edp_panel {
	status = "okay";
	compatible = "simple-panel";//20220812
	backlight = <&backlight>;//20220812
	// power-supply = <&vcc_lcd>;
	enable-gpios = <&gpio1 4 GPIO_ACTIVE_HIGH>;
	// enable-delay-ms = <120>;
	// prepare-delay-ms = <120>;
	// disable-delay-ms = <120>;
	// unprepare-delay-ms = <120>;
	display-timings {
		native-mode = <&timing0>;
		timing0: timing0 {
			clock-frequency = <157080000>;
			hactive = <1920>;
			vactive = <1200>;
			hfront-porch = <120>;
			hsync-len = <0>;
			hback-porch = <120>;
			vfront-porch = <4>;
			vsync-len = <4>;
			vback-porch = <4>;
			hsync-active = <0>;
			vsync-active = <0>;
			de-active = <0>;
			pixelclk-active = <0>;
&edp {
	status = "okay";
// &uart0 {
// 20220802 edp
&rk808 {
     /delete-property/ pmic,stby-gpio;
     /delete-property/ pmic,hold-gpio;
&vcc_mipi {
	status = "okay";
&dvdd_1v2 {
	status = "okay";
&ov13850 {
	pwdn-gpios = <&gpio2 1 GPIO_ACTIVE_HIGH>;
	status = "okay";
&ov13850_1 {
	pwdn-gpios = <&gpio2 0 GPIO_ACTIVE_HIGH>;
	status = "okay";
&rkisp1_0 {
	status = "okay";
&mipi_dphy_rx0 {
	status = "okay";
&isp0_mmu {
	status = "okay";
&rkisp1_1 {
	status = "okay";
&mipi_dphy_tx1rx1 {
	status = "okay";
&isp1_mmu {
	status = "okay";
&pinctrl {
	pinctrl-0 = <&host_hub_vcc>;
	npu_pwr_en {
		// control VCC5V0_HOST3
		npu5801_pwr_en: npu5801-pwr-en {
			rockchip,pins =
				<0 2 RK_FUNC_GPIO &pcfg_pull_up>;
	host-hub-vcc {
		host_hub_vcc: host-hub-vcc {
			rockchip,pins =
				<2 4 RK_FUNC_GPIO &pcfg_output_high>,
				<4 29 RK_FUNC_GPIO &pcfg_output_high>;
	pcie {
		pcie_3g_drv: pcie-3g-drv {
			rockchip,pins =
				<2 6 RK_FUNC_GPIO &pcfg_pull_up>;
	vcc_sd {
		vcc_sd_h: vcc-sd-h {
			rockchip,pins =
	fan-ctl {
		fan_drv: fan-drv {
			rockchip,pins = <3 10 RK_FUNC_GPIO &pcfg_pull_none>;
edp崩溃日志.txt (107 KB)
panel dts配置有问题,SDK中应该有edp相关dts配置,可以参考配置
谢谢回复。确实是panel的问题,panel部分注释掉,系统就可以正常启动。
但是参照SDK中的rk3399-firefly-edp.dts修改,还有同样的问题。
rk3399-firefly-edp.dts是这样的
 * Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd
 * This file is dual-licensed: you can use it either under the terms
 * of the GPL or the X11 license, at your option. Note that this dual
 * licensing only applies to this file, and not this project as a
 * whole.
 *  a) This file is free software; you can redistribute it and/or
 *     modify it under the terms of the GNU General Public License as
 *     published by the Free Software Foundation; either version 2 of the
 *     License, or (at your option) any later version.
 *     This file is distributed in the hope that it will be useful,
 *     but WITHOUT ANY WARRANTY; without even the implied warranty of
 *     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *     GNU General Public License for more details.
 * Or, alternatively,
 *  b) Permission is hereby granted, free of charge, to any person
 *     obtaining a copy of this software and associated documentation
 *     files (the "Software"), to deal in the Software without
 *     restriction, including without limitation the rights to use,
 *     copy, modify, merge, publish, distribute, sublicense, and/or
 *     sell copies of the Software, and to permit persons to whom the
 *     Software is furnished to do so, subject to the following
 *     conditions:
 *     The above copyright notice and this permission notice shall be
 *     included in all copies or substantial portions of the Software.
 *     THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 *     EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
 *     OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
 *     NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
 *     HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
 *     WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 *     FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
 *     OTHER DEALINGS IN THE SOFTWARE.
/dts-v1/;
	model = "Firefly-RK3399 Board EDP LP079QX1 (Linux Opensource)";
	compatible = "rockchip,rk3399-firefly", "rockchip,rk3399";
	test-power {
		status = "okay";
	vcc_lcd: vcc-lcd {
		enable-active-high;
		gpio = <&gpio1 1 GPIO_ACTIVE_HIGH>;
		regulator-boot-on;
		regulator-name = "vcc_lcd";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
		startup-delay-us = <20000>;
		vin-supply = <&vcc_3v0>;
&backlight {
    status = "okay";
&edp_panel {
	compatible = "sharp,lcd-f402", "panel-simple";
	reset-gpios = <&gpio4 29 GPIO_ACTIVE_LOW>;
	status = "okay";
&edp {
	status = "okay";
&route_edp {
	status = "okay";
	logo,mode = "center";
&edp_in_vopl {
&hdmi_dp_sound {
	status = "okay";
&i2c4 {
	status = "okay";
	gsl3680: gsl3680@41 {
		compatible = "gslX680";
		reg = <0x41>;
		screen_max_x = <1536>;
		screen_max_y = <2048>;
		touch-gpio = <&gpio1 20 IRQ_TYPE_LEVEL_LOW>;
		reset-gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>;
	mpu6050: mpu@68 {
		compatible = "invensense,mpu6050";
		reg = <0x68>;
		irq-gpio = <&gpio1 4 IRQ_TYPE_LEVEL_LOW>;
		mpu-debug = <1>;
		mpu-int_config = <0x10>;
		mpu-level_shifter = <0>;
		mpu-orientation = <0 1 0 1 0 0 0 0 1>;
		orientation-x= <1>;
		orientation-y= <1>;
		orientation-z= <1>;
&uart4 {
	status = "okay";
&dp_in_vopb {
&hdmi_in_vopb {
&wdt {
	edp_panel: edp-panel {
		status = "okay";
		bus-format = <MEDIA_BUS_FMT_RGB666_1X18>;
        display-timings {
                timing0: timing0 {
                        clock-frequency = <140000000>;
                        hactive = <1920>;
                        vactive = <1080>;
                        hfront-porch = <40>;
                        hsync-len = <40>;
                        hback-porch = <80>;
                        vfront-porch = <16>;
                        vsync-len = <8>;
                        vback-porch = <16>;
                        hsync-active = <0>;
                        vsync-active = <0>;
                        de-active = <0>;
		ports {
			panel_in_edp: endpoint {
				remote-endpoint = <&edp_out_panel>;
		power_ctr: power_ctr {
			rockchip,debug = <0>;
			lcd_en: lcd-en {
					gpios = <&gpio1 1 GPIO_ACTIVE_HIGH>;
					pinctrl-0 = <&lcd_panel_enable>;
					rockchip,delay = <20>;
			lcd_rst: lcd-rst {
					gpios = <&gpio4 29 GPIO_ACTIVE_HIGH>;
					pinctrl-0 = <&lcd_panel_reset>;
	backlight: backlight {
		status = "okay";
		compatible = "pwm-backlight";
		pwms = <&pwm0 0 500000 0>;
		brightness-levels = <
			  0   1   2   3   4   5   6   7
			  8   9  10  11  12  13  14  15
			 16  17  18  19  20  21  22  23
			 24  25  26  27  28  29  30  31
			 32  33  34  35  36  37  38  39
			 40  41  42  43  44  45  46  47
			 48  49  50  51  52  53  54  55
			 56  57  58  59  60  61  62  63
			 64  65  66  67  68  69  70  71
			 72  73  74  75  76  77  78  79
			 80  81  82  83  84  85  86  87
			 88  89  90  91  92  93  94  95
			 96  97  98  99 100 101 102 103
			104 105 106 107 108 109 110 111
			112 113 114 115 116 117 118 119
			120 121 122 123 124 125 126 127
			128 129 130 131 132 133 134 135
			136 137 138 139 140 141 142 143
			144 145 146 147 148 149 150 151
			152 153 154 155 156 157 158 159
			160 161 162 163 164 165 166 167
			168 169 170 171 172 173 174 175
			176 177 178 179 180 181 182 183
			184 185 186 187 188 189 190 191
			192 193 194 195 196 197 198 199
			200 201 202 203 204 205 206 207
			208 209 210 211 212 213 214 215
			216 217 218 219 220 221 222 223
			224 225 226 227 228 229 230 231
			232 233 234 235 236 237 238 239
			240 241 242 243 244 245 246 247
			248 249 250 251 252 253 254 255>;
		default-brightness-level = <200>;
&edp {
	status = "okay";
	force-hpd;
	ports {
		edp_out: port@1 {
			reg = <1>;
			#address-cells = <1>;
			#size-cells = <0>;
			edp_out_panel: endpoint@0 {
				reg = <0>;
				remote-endpoint = <&panel_in_edp>;
panel 的dts配置参考这份改
luwy 发表于 2022-8-17 10:17
panel 的dts配置参考这份改
参照你的代码,系统可以启动了,屏的背光也亮了,但是显示黑屏,示波器上EDP_TX0N没有信号,我在查查文档。
请问下在我这个板子的原理图上,lcd-en是对应LCD_EN吧,lcd-rst是对应那个引脚? 看原理图是不是eDP用不上lcd-rst。
dts只是参考,实际还是按照原理图来,如果原理图没有就不用配置;可以检查一下vcc供电是否都正常
屏点亮了,感谢帮助
abcxyztt 发表于 2022-8-30 13:52
修改了什么点亮的?
/dts-v1/;
	model = "AIO-3399-JD4-t Board (Linux Opensource)";
	test-power {
		status = "okay";
	// vcc_lcd: vcc-lcd {
	// 	compatible = "regulator-fixed";
	// 	enable-active-high;
	// 	gpio = <&gpio1 4 GPIO_ACTIVE_HIGH>;
	// 	regulator-always-on;
	// 	regulator-boot-on;
	// 	regulator-name = "vcc_lcd";
	// 	regulator-min-microvolt = <3300000>;
	// 	regulator-max-microvolt = <3300000>;
	// 	startup-delay-us = <20000>;
	// 	vin-supply = <&vcc_3v0>;
	rt5640-sound {
	adc-keys {
		esc-key {
			label = "esc";
		enable-active-high;
		regulator-boot-on;
		enable-active-high;
		regulator-boot-on;
		status = "okay";
&usbdrd_dwc3_0 {
    dr_mode = "host";
&gmac {
	tx_delay = <0x2F>;
	rx_delay = <0x1E>;
&vcc_sd_h {
&vcc_sd {
&hdmi_dp_sound {
	status = "okay";
&i2c2 {
	sensor@4c {
		reg = <0x4c>;
		irq_enable = <0>;
		layout = <1>;
&rt5640 {
&rt5640_hpcon{
&vcca1v8_codec {
&spi1 {
	dev-port = <0>;
	status = "okay";
&spi_wk2xxx {
    status = "okay";
// &spi2 {
//     status = "okay";
//     spidev@00 {
//         reg = <0x00>;
// 		status = "okay";
&vcc3v3_3g {
&vcc3v3_pcie {
&pcie0 {
&uart4 {
&dp_in_vopb {
&hdmi_in_vopl {
&wdt {
	status = "disabled";//2022.7.25
&io_domains {
&vcc2v8_dvp {
&vcca1v8_codec {
&fusb0 {
&cdn_dp {
&tcphy0 {
    status = "okay";
&u2phy0 {
    status = "okay";
        status = "okay";
&usbdrd3_0 {
    status = "okay";
&usbdrd_dwc3_0 {
    dr_mode = "host";
&route_hdmi {
	// status = "okay";
// 20220802 edp
&hdmi_in_vopb {
&hdmi {
	// status = "okay";
&backlight {
	status = "okay";
	pwms = <&pwm0 0 20000 0>;
&edp_in_vopl {
&edp_in_vopb {
	status = "okay";
&route_edp {
	status = "okay";
	connect = <&vopb_out_edp>;
&edp_panel {
	// compatible = "auo,b125han03","simple-panel";//20220830
	//gpio1 4 LCD_EN; gpio4 29 LCD_RST; GPIO0_A1 LCD_BL_EN
	enable-gpios = <&gpio1 4 GPIO_ACTIVE_HIGH>;//LCD_EN
	reset-gpios = <&gpio4 29 GPIO_ACTIVE_LOW>;//LCD_RST
	status = "okay";
	bus-format = <MEDIA_BUS_FMT_RGB888_1X24>;//MEDIA_BUS_FMT_RGB888_2X12_BE MEDIA_BUS_FMT_RGB888_2X12_LE MEDIA_BUS_FMT_RGB888_1X24
	display-timings {
		timing0: timing0 {
			clock-frequency = <157075200>;
			hactive = <1920>;
			vactive = <1200>;
			hfront-porch = <90>;
			hsync-len = <60>;
			hback-porch = <90>;
			vfront-porch = <4>;
			vsync-len = <4>;
			vback-porch = <4>;
			hsync-active = <0>;
			vsync-active = <0>;
			de-active = <0>;
	// power_ctr: power_ctr {
	// 	power_enable = <1>;
	// 	rockchip,debug = <0>;
	// 	lcd_en: lcd-en {
	// 			gpios = <&gpio1 4 GPIO_ACTIVE_HIGH>;
	// 			pinctrl-names = "default";
	// 			pinctrl-0 = <&lcd_panel_enable>;
	// 			rockchip,delay = <20>;
		// lcd_pwr_en: lcd-pwr-en {
				// gpios = <&gpio0 1 GPIO_ACTIVE_HIGH>;
	// 			pinctrl-0 = <&lcd_panel_pwr_en>;
	// 			rockchip,delay = <10>;
	// 	lcd_en: lcd-en {
	// 	lcd_rst: lcd-rst {
	// 		gpios = <&gpio4 29 GPIO_ACTIVE_HIGH>;
	// 		pinctrl-0 = <&lcd_panel_reset>;
&edp {
	status = "okay";
	hpd-gpios = <&gpio2 7 GPIO_ACTIVE_HIGH>;
	// /delete-property/ force-hpd;
// &uart0 {
// 20220802 edp
&rk808 {
&vcc_mipi {
	status = "okay";
&dvdd_1v2 {
	status = "okay";
&ov13850 {
	status = "okay";
// &ov13850_1 {
// 	pwdn-gpios = <&gpio2 0 GPIO_ACTIVE_HIGH>;
// 	status = "okay";
&rkisp1_0 {
	status = "okay";
&mipi_dphy_rx0 {
	status = "okay";
&isp0_mmu {
	status = "okay";
&rkisp1_1 {
	status = "okay";
&mipi_dphy_tx1rx1 {
	status = "okay";
&isp1_mmu {
	status = "okay";
&pinctrl {
	npu_pwr_en {
			rockchip,pins =
	host-hub-vcc {
			rockchip,pins =
	pcie {
			rockchip,pins =
	vcc_sd {
			rockchip,pins =
	fan-ctl {
		fan_drv: fan-drv {
	// lcd-panel {
	// 	lcd_panel_enable: lcd-panel-enable {
	// 		rockchip,pins = <1 4 RK_FUNC_GPIO &pcfg_pull_up>;
    //     lcd_panel_pwr_en: lcd-panel-pwr-en {
    //         rockchip,pins = <0 1 RK_FUNC_GPIO &pcfg_pull_up>;
	// lcd-panel {
    //     lcd_panel_reset: lcd-panel-reset {
    //         rockchip,pins = <4 29 RK_FUNC_GPIO &pcfg_pull_up>;
