固件文件名称:android12
Log日志:1.txt
在编译android12时遇到如下问题:
./FFTools/make.sh -d roc-rk3588s-pc -j8 -l roc_rk3588s_pc-userdebug
上面这条指令出现如下打印信息,请问该怎么解决?
log:
[ 88% 13380/15041] //packages/services/Telecomm:Telecom r8 [common]
Warning: Missing class androidx.palette.graphics.Palette$Builder (referenced from: android.graphics.Bitmap androidx.mediarouter.app.MediaRouteControllerDialog$FetchArtTask.doInBackground(java.lang.Void ) and 1 other context)
Missing class androidx.palette.graphics.Palette$Swatch (referenced from: android.graphics.Bitmap androidx.mediarouter.app.MediaRouteControllerDialog$FetchArtTask.doInBackground(java.lang.Void ) and 1 other context)
Missing class androidx.palette.graphics.Palette (referenced from: android.graphics.Bitmap androidx.mediarouter.app.MediaRouteControllerDialog$FetchArtTask.doInBackground(java.lang.Void ) and 1 other context)
Missing class com.google.common.util.concurrent.ListenableFuture (referenced from: com.google.common.util.concurrent.ListenableFuture androidx.mediarouter.media.MediaRouter$PrepareTransferNotifier.mFuture and 3 other contexts)
Missing class org.jetbrains.annotations.NotNull (referenced from: kotlin.Unit kotlin.Unit.INSTANCE and 179 other contexts)
Missing class org.jetbrains.annotations.Nullable (referenced from: okio.Segment okio.Buffer.head and 18 other contexts)
11:00:58 ninja failed with: exit status 1
1.txt (4.16 KB)
jpchen
August 24, 2022, 3:23am
3
首先确认一下,编译机器的内存是否够16GB, 同时再进行编译试一下有没有明显的fail 出错
目前编译rk3588s是没有问题的,但是编译rk3588的时候又报错了.
[ 89% 116583/130348] //external/e2fsprogs/misc:mke2fs link mke2fs
FAILED: out/soong/.intermediates/external/e2fsprogs/misc/mke2fs/android_arm64_armv8-a/unstripped/mke2fs
prebuilts/clang/host/linux-x86/clang-r416183b1/bin/clang++ out/soong/.intermediates/bionic/libc/crtbegin_dynamic/android_arm64_armv8-a/crtbegin_dynamic.o @out /soong/.intermediates/external/e2fsprogs/misc/mke2fs/android_arm64_armv8-a/unstripped/mke2fs.rsp out/soong/.intermediates/external/libcxx/libc++_static/android_arm64_armv8-a_static/libc++_static.a out/soong/.intermediates/external/libcxxabi/libc++demangle/android_arm64_armv8-a_static/libc++demangle.a -Wl,–start-group prebuilts/clang/host/linux-x86/clang-r416183b1/lib64/clang/12.0.7/lib/linux/libclang_rt.builtins-aarch64-android.a -Wl,–end-group out/soong/.intermediates/external/e2fsprogs/lib/ext2fs/libext2fs/android_arm64_armv8-a_shared/libext2fs.so out/soong/.intermediates/external/e2fsprogs/lib/blkid/libext2_blkid/android_arm64_armv8-a_shared/libext2_blkid.so out/soong/.intermediates/external/e2fsprogs/misc/libext2_misc/android_arm64_armv8-a_shared/libext2_misc.so out/soong/.intermediates/external/e2fsprogs/lib/uuid/libext2_uuid/android_arm64_armv8-a_shared/libext2_uuid.so out/soong/.intermediates/external/e2fsprogs/lib/support/libext2_quota/android_arm64_armv8-a_shared/libext2_quota.so out/soong/.intermediates/external/e2fsprogs/lib/et/libext2_com_err/android_arm64_armv8-a_shared/libext2_com_err.so out/soong/.intermediates/external/e2fsprogs/lib/e2p/libext2_e2p/android_arm64_armv8-a_shared/libext2_e2p.so out/soong/.intermediates/bionic/libc/libc/android_arm64_armv8-a_shared_current/libc.so out/soong/.intermediates/bionic/libm/libm/android_arm64_armv8-a_shared_current/libm.so out/soong/.intermediates/bionic/libdl/libdl/android_arm64_armv8-a_shared_current/libdl.so out/soong/.intermediates/bionic/libc/crtend_android/android_arm64_armv8-a/obj/bionic/libc/arch-common/bionic/crtend.o -o out/soong/.intermediates/external/e2fsprogs/misc/mke2fs/android_arm64_armv8-a/unstripped/mke2fs -target aarch64-linux-android10000 -Bprebuilts/gcc/linux-x86/aarch64/aarch64-linux-android-4.9/aarch64-linux-android/bin -Wl,-z,noexecstack -Wl,-z,relro -Wl,-z,now -Wl,–build-id=md5 -Wl,–warn-shared-textrel -Wl,–fatal-warnings -Wl,–no-undefined-version -Wl,–exclude-libs,libgcc.a -Wl,–exclude-libs,libgcc_stripped.a -Wl,–exclude-libs,libunwind_llvm.a -Wl,–exclude-libs,libunwind.a -Wl,–icf=safe -fuse-ld=lld -Wl,–pack-dyn-relocs=android+relr -Wl,–no-undefined -Wl,–hash-style=gnu -Wl,-z,separate-code -Wl,-z,max-page-size=4096 -Wl,–exclude-libs=libclang_rt.builtins-aarch64-android.a -pie -nostdlib -Bdynamic -Wl,–gc-sections -Wl,-z,nocopyreloc -Wl,-dynamic-linker,/system/bin/linker64
ld.lld: error: out/soong/.intermediates/external/e2fsprogs/misc/mke2fs/android_arm64_armv8-a/obj/external/e2fsprogs/misc/util.o:1: unclosed comment in
jpchen
August 26, 2022, 1:57am
5
[ 89% 116583/130348] //external/e2fspro …
在 .bashrc 添加export LC_ALL=C 看是否可以
每次编译android都需要很长时间,最后才知道编译有没有成功.请问android12编译一般多久?有没有什么办法能加快编译速度
硬件: 内存16G 磁盘剩余空间大于250G
修改环境还是一样报错:
ld.lld: error: out/soong/.intermediates/external/e2fsprogs/misc/mke2fs/android_arm64_armv8-a/obj/external/e2fsprogs/misc/util.o:1: unclosed comment in a linker script
clang-12: error: linker command failed with exit code 1 (use -v to see invocation)
12:26:28 ninja failed with: exit status 1
jpchen
August 26, 2022, 6:20am
9
修改环境还是一样报错:
编译的时间主要看服务器性能,服务器好一点整体编译第一次编译都有可能5-6小时,差一些可能要12小时或是更久
jpchen
August 26, 2022, 6:31am
10
修改环境还是一样报错:
出现如下这种问题,有可能是你编译的过程中,手动中断,其他中断导致,需要make clean 后再重新编译
