SDK包名称:rk3399_linux_release_v2.5.1_20210301_firefly_split
SDK修改内容:修改了设备树
Log日志:日志.zip
ov13850的文档上显示,支持4224*3136 30FPS,但是在core-rk3399-jd4使用media-ctl命令配置后,帧率仅有7.5FPS。
请问如何操作可以在最大分辨率下提高帧率,是否能够达到30FPS。
[root@rk3399:/]# media-ctl -p
Media controller API version 0.1.0
Media device information
driver rkisp1
model rkisp1
serial
bus info
hw revision 0x0
driver version 0.0.0
Device topology
- entity 1: rkisp1-isp-subdev (4 pads, 6 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
[fmt:SBGGR10_1X10/4224x3136 field:none
crop.bounds:(0,0)/4224x3136
crop:(0,0)/4224x3136]
<- "rkisp1_dmapath":0 []
<- "rockchip-mipi-dphy-rx":1 [ENABLED]
pad1: Sink
<- "rkisp1-input-params":0 [ENABLED]
pad2: Source
[fmt:YUYV8_2X8/4224x3136 field:none
-> "rkisp1_selfpath":0 [ENABLED]
-> "rkisp1_mainpath":0 [ENABLED]
pad3: Source
-> "rkisp1-statistics":0 [ENABLED]
- entity 2: rkisp1_mainpath (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "rkisp1-isp-subdev":2 [ENABLED]
- entity 3: rkisp1_selfpath (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
- entity 4: rkisp1_dmapath (1 pad, 1 link)
device node name /dev/video2
pad0: Source
-> "rkisp1-isp-subdev":0 []
- entity 5: rkisp1-statistics (1 pad, 1 link)
device node name /dev/video3
pad0: Sink
<- "rkisp1-isp-subdev":3 [ENABLED]
- entity 6: rkisp1-input-params (1 pad, 1 link)
device node name /dev/video4
pad0: Source
-> "rkisp1-isp-subdev":1 [ENABLED]
- entity 7: rockchip-mipi-dphy-rx (2 pads, 2 links)
device node name /dev/v4l-subdev1
pad0: Sink
[fmt:SBGGR10_1X10/4224x3136@20000/150000 field:none]
<- "m00_b_ov13850 1-0036":0 [ENABLED]
pad1: Source
-> "rkisp1-isp-subdev":0 [ENABLED]
- entity 8: m00_b_ov13850 1-0036 (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev2
pad0: Source
-> "rockchip-mipi-dphy-rx":0 [ENABLED]
日志.zip (21.8 KB)
