系统无法启动卡在 1.568760] dwc3 fd000000.dwc3: Failed to get clk 'ref': -2
[ 1.555160] rockchip-drm display-subsystem: devfreq is ready
[ 1.555585] vp0: rgb_pixelclk: 0
[ 1.555633] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4
[ 1.555653] vp1: rgb_pixelclk: 0
[ 1.555671] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x22, primary plane phy id: 5
[ 1.555689] vp2: rgb_pixelclk: 1
[ 1.555705] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x8, primary plane phy id: 3
[ 1.556115] [drm] failed to init overlay plane Cluster0-win1
[ 1.556174] [drm] failed to init overlay plane Cluster1-win1
[ 1.556382] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8008fba6d8)
[ 1.558403] rockchip-drm display-subsystem: bound fe0c0000.edp (ops 0xffffff8008fbd790)
[ 1.558726] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.559883] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.562014] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8008fbe1f8)
[ 1.562114] rockchip-rgb fdc60000.syscon:rgb: [drm:rockchip_rgb_bind] ERROR failed to find panel or bridge: -517
[ 1.562736] mmc3 mmc_send_io_op_cond err: -110
[ 1.565720] /rgb0_panel: could not find display-timings node
[ 1.565871] /rgb0_panel: no timings specified
[ 1.565983] panel-simple rgb0_panel: rgb0_panel supply power not found, using dummy regulator
[ 1.566134] panel-simple rgb0_panel: rgb0_panel supply vsp not found, using dummy regulator
[ 1.566218] panel-simple rgb0_panel: rgb0_panel supply vsn not found, using dummy regulator
[ 1.567366] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.568760] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
小白一个不懂请教下这是什么问题?
你好,请问使用的是什么系统,固件是公版固件吗
硬件是
ICore-11JQ
ICore-3568JQ
V1.0 2022.04.13
糸统RTLinux
固件是公版固件
就这个内容不停的打印
底板是哪个,是firefly的底板吗。还是自制的底板,自制的底板dts是怎么配置的
自己做的底板。
怎么改?
不清楚你底板设计有哪些接口,不用的可以disabled掉,相关的电源之类控制脚配好,可以参考sdk的dts。kernel/arch/arm64/boot/dts/rockchip/rk3568-firefly-itx-3568q.*
[ 1.859817] rockchip-usb2phy fe8a0000.usb2-phy: failed to create phy
dts关那个?
dts关那个?
如果这个不用,dts中根据fe8a0000搜索然后disabled
我们自己的底板也出现了这个问题,请问您现在解决了吗?希望得到您的帮助,这是我的邮箱15030469869@163.com
你们解决了吗?
其实就是主板上的IO扩展芯片PCA9555PW没有装
