固件文件名称:ROC-RK3568-PC_Debian10-r21156_v1.2.4a_220519
固件下载地址:百度网盘
Log日志:新建文本文档.txt
解码一个mp4文件,视频码流是mpeg-4格式的,gstreamer解码一直失败。同一个文件我用debian映像中的mppplayer播放是成功的,但是软解。
新建文本文档.txt (10.9 KB)
固件下载地址:百度网盘
Log日志:新建文本文档.txt
我看datasheet,是支持mpeg-4解码的。有大侠分析一下吗?下面是log
firefly@firefly:~$ gst-play-1.0 -v /home/firefly/Videos/64a85ecd433f58730f7c43929f44415c_baofeng.mp4
Press 'k' to see a list of keyboard shortcuts.
Now playing /home/firefly/Videos/64a85ecd433f58730f7c43929f44415c_baofeng.mp4
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0: ring-buffer-max-size = 0
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0: buffer-size = -1
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0: buffer-duration = -1
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0: use-buffering = false
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0: download = false
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0: uri = file:///home/firefly/Videos/64a85ecd433f58730f7c43929f44415c_baofeng.mp4
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0: connection-speed = 0
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0: source = "\(GstFileSrc\)\ source"
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = video/quicktime, variant=(string)iso
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = NULL
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstPad:src_0: caps = video/mpeg, mpegversion=(int)4, systemstream=(boolean)false, profile=(string)simple, level=(string)1, codec_data=(buffer)000001b001000001b58913000001000000012000c48d8800cd1aa43c1463000001b24c61766335312e35342e30, width=(int)852, height=(int)480, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMpeg4VParse:mpeg4vparse0.GstPad:sink: caps = video/mpeg, mpegversion=(int)4, systemstream=(boolean)false, profile=(string)simple, level=(string)1, codec_data=(buffer)000001b001000001b58913000001000000012000c48d8800cd1aa43c1463000001b24c61766335312e35342e30, width=(int)852, height=(int)480, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstPad:src_1: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)1, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1310, rate=(int)24000, channels=(int)2
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/avdec_aac:avdec_aac0.GstPad:sink: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)1, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1310, rate=(int)24000, channels=(int)2
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstAacParse:aacparse0.GstPad:src: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)1, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1310, rate=(int)24000, channels=(int)2
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstAacParse:aacparse0.GstPad:sink: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)1, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1310, rate=(int)24000, channels=(int)2
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-buffers = 5
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-time = 0
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-bytes = 2097152
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstMultiQueuePad:sink_0: caps = video/mpeg, mpegversion=(int)4, systemstream=(boolean)false, profile=(string)simple, level=(string)1, codec_data=(buffer)000001b001000001b58913000001000000012000c48d8800cd1aa43c1463000001b24c61766335312e35342e30, width=(int)852, height=(int)480, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstMultiQueuePad:sink_1: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)1, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1310, rate=(int)24000, channels=(int)2
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/avdec_aac:avdec_aac0.GstPad:src: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)24000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
mpp[1219]: mpp_info: mpp version: 41c9c809 author: sayon.chen 2020-12-24 [mpp2str]: Add rc_gop_mode 2 str
mpp[1219]: mpp_rt: NOT found ion allocator
mpp[1219]: mpp_rt: found drm allocator
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMppVideoDec:mppvideodec0.GstPad:sink: caps = video/mpeg, mpegversion=(int)4, systemstream=(boolean)false, profile=(string)simple, level=(string)1, codec_data=(buffer)000001b001000001b58913000001000000012000c48d8800cd1aa43c1463000001b24c61766335312e35342e30, width=(int)852, height=(int)480, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1, parsed=(boolean)true
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMpeg4VParse:mpeg4vparse0.GstPad:src: caps = video/mpeg, mpegversion=(int)4, systemstream=(boolean)false, profile=(string)simple, level=(string)1, codec_data=(buffer)000001b001000001b58913000001000000012000c48d8800cd1aa43c1463000001b24c61766335312e35342e30, width=(int)852, height=(int)480, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1, parsed=(boolean)true
mpp[1219]: mpp: deprecated block control, use timeout control instead
执行这个试一下
gst-play-1.0 test.mp4 --videosink=“xvimagesink”
Liuth 发表于 2022-9-2 16:46
执行这个试一下
这个测试视频的码流为h.264,是可以硬解成功的。
firefly@firefly:~$ gst-play-1.0 -v /usr/local/test.mp4 --videosink="xvimagesink"
Now playing /usr/local/test.mp4
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0: uri = file:///usr/local/test.mp4
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstPad:src_0: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4.1, profile=(string)constrained-baseline, codec_data=(buffer)0142c029ffe1001b6742c0299a7200f0044fcb8088000003000800000301e078c1924001000468ce32c8, width=(int)1920, height=(int)1080, framerate=(fraction)24000/1001, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4.1, profile=(string)constrained-baseline, codec_data=(buffer)0142c029ffe1001b6742c0299a7200f0044fcb8088000003000800000301e078c1924001000468ce32c8, width=(int)1920, height=(int)1080, framerate=(fraction)24000/1001, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
mpp[1320]: mpp_info: mpp version: 41c9c809 author: sayon.chen 2020-12-24 [mpp2str]: Add rc_gop_mode 2 str
mpp[1320]: mpp_rt: NOT found ion allocator
mpp[1320]: mpp_rt: found drm allocator
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMppVideoDec:mppvideodec0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4.1, profile=(string)constrained-baseline, codec_data=(buffer)0142c029ffe1001b6742c0299a7200f0044fcb8088000003000800000301e078c1924001000468ce32c8, width=(int)1920, height=(int)1080, framerate=(fraction)24000/1001, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4.1, profile=(string)constrained-baseline, codec_data=(buffer)0142c029ffe1001b6742c0299a7200f0044fcb8088000003000800000301e078c1924001000468ce32c8, width=(int)1920, height=(int)1080, framerate=(fraction)24000/1001, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4.1, profile=(string)constrained-baseline, codec_data=(buffer)0142c029ffe1001b6742c0299a7200f0044fcb8088000003000800000301e078c1924001000468ce32c8, width=(int)1920, height=(int)1080, framerate=(fraction)24000/1001, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4.1, profile=(string)constrained-baseline, codec_data=(buffer)0142c029ffe1001b6742c0299a7200f0044fcb8088000003000800000301e078c1924001000468ce32c8, width=(int)1920, height=(int)1080, framerate=(fraction)24000/1001, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstPad:src_1: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1190, rate=(int)48000, channels=(int)2
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/avdec_aac:avdec_aac0.GstPad:sink: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1190, rate=(int)48000, channels=(int)2
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstAacParse:aacparse0.GstPad:src: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1190, rate=(int)48000, channels=(int)2
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstAacParse:aacparse0.GstPad:sink: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1190, rate=(int)48000, channels=(int)2
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstMultiQueuePad:sink_0: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)4.1, profile=(string)constrained-baseline, codec_data=(buffer)0142c029ffe1001b6742c0299a7200f0044fcb8088000003000800000301e078c1924001000468ce32c8, width=(int)1920, height=(int)1080, framerate=(fraction)24000/1001, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstMultiQueuePad:sink_1: caps = audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1190, rate=(int)48000, channels=(int)2
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/avdec_aac:avdec_aac0.GstPad:src: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
mpp[1320]: mpp: deprecated block control, use timeout control instead
mpp[1320]: h264d_api: is_avcC=1
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0/GstMppVideoDec:mppvideodec0.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: always-ok = false
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: always-ok = false
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: active = true
/GstPlayBin:playbin/GstInputSelector:inputselector0: active-pad = "\(GstSelectorPad\)\ sink_0"
/GstPlayBin:playbin/GstInputSelector:inputselector1: active-pad = "\(GstSelectorPad\)\ sink_0"
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin/GstPulseSink:pulsesink0: ts-offset = 0
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vbin/GstXvImageSink:xvimagesink0: ts-offset = 0
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink.GstGhostPad:video_sink.GstProxyPad:proxypad7: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink/GstStreamSynchronizer:streamsynchronizer0.GstPad:src_0: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vdbin.GstGhostPad:sink.GstProxyPad:proxypad11: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstPad:src: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink.GstGhostPad:audio_sink.GstProxyPad:proxypad6: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstTee:audiotee.GstTeePad:src_0: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstStreamSynchronizer:streamsynchronizer0.GstPad:src_1: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin.GstGhostPad:sink.GstProxyPad:proxypad15: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin/GstQueue:aqueue.GstPad:sink: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin.GstGhostPad:sink: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstStreamSynchronizer:streamsynchronizer0.GstPad:sink_1: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstTee:audiotee.GstPad:sink: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink.GstGhostPad:audio_sink: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0.GstGhostPad:src_1.GstProxyPad:proxypad5: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin/GstPlaySinkAudioConvert:aconv.GstGhostPad:sink.GstProxyPad:proxypad13: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin/GstPlaySinkAudioConvert:aconv/GstAudioConvert:conv.GstPad:src: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin/GstPlaySinkAudioConvert:aconv/GstAudioResample:resample.GstPad:src: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin/GstPlaySinkAudioConvert:aconv.GstGhostPad:src: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vdbin/GstVideoConvert:vdconv.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vdbin/GstDeinterlace:deinterlace.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
Redistribute latency...
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin/GstPulseSink:pulsesink0.GstPad:sink: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin/GstPlaySinkAudioConvert:aconv.GstGhostPad:src.GstProxyPad:proxypad14: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin/GstPlaySinkAudioConvert:aconv/GstAudioResample:resample.GstPad:sink: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vbin/GstQueue:vqueue.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin/GstPlaySinkAudioConvert:aconv.GstGhostPad:sink: caps = audio/x-raw, format=(string)F32LE, layout=(string)interleaved, rate=(int)48000, channels=(int)2, channel-mask=(bitmask)0x0000000000000003
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vdbin/GstDeinterlace:deinterlace.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vdbin/GstVideoConvert:vdconv.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vdbin.GstGhostPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink/GstStreamSynchronizer:streamsynchronizer0.GstPad:sink_0: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink.GstGhostPad:video_sink: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0.GstGhostPad:src_0.GstProxyPad:proxypad4: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0.GstDecodePad:src_0.GstProxyPad:proxypad2: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vbin/GstPlaySinkVideoConvert:vconv.GstGhostPad:sink.GstProxyPad:proxypad8: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC\ audio", maximum-bitrate=(uint)196608;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC\ audio", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A";
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A";
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)131250, bitrate=(uint)127050;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)130875, bitrate=(uint)127397;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)126749, bitrate=(uint)127343;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)126000, bitrate=(uint)127240;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)126428;
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vbin/GstPlaySinkVideoConvert:vconv/GstVideoConvert:conv.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vbin/GstPlaySinkVideoConvert:vconv/GstVideoScale:scale.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vbin/GstPlaySinkVideoConvert:vconv.GstGhostPad:src: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)130855;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)133732;
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vbin/GstXvImageSink:xvimagesink0.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vbin/GstPlaySinkVideoConvert:vconv.GstGhostPad:src.GstProxyPad:proxypad9: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vbin/GstPlaySinkVideoConvert:vconv/GstVideoScale:scale.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vbin/GstPlaySinkVideoConvert:vconv/GstVideoConvert:conv.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:vbin/GstPlaySinkVideoConvert:vconv.GstGhostPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)24000/1001
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)136793;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)140030;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ /\ AVC", bitrate=(uint)6633470;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ /\ AVC", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A";
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A";
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)143045;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)146097;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)149187;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)152372;
/GstPlayBin:playbin/GstPlaySink:playsink: volume = 1
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin/GstPulseSink:pulsesink0: volume = 1
/GstPlayBin:playbin/GstPlaySink:playsink: mute = false
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin/GstPulseSink:pulsesink0: mute = false
/GstPlayBin:playbin/GstPlaySink:playsink/GstBin:abin/GstPulseSink:pulsesink0: current-device = auto_null
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)155758;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)1521600;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)1648560;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)159208;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)2373120;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)2543280;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)3161520;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)3539040;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)3611040;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)3897600;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)162705;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)3947520;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)4218000;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)4464480;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)4526640;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)4651200;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)4842240;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)166031;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)5029200;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)5388720;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)1521600, maximum-bitrate=(uint)9935760;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)169548;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)506400, maximum-bitrate=(uint)9935760;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)506400, maximum-bitrate=(uint)70740480;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)166217;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)162901;
/GstPlayBin:playbin/GstInputSelector:inputselector1.GstSelectorPad:sink_0: tags = taglist, audio-codec=(string)"MPEG-4\ AAC", maximum-bitrate=(uint)196608, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)115875, bitrate=(uint)166273;
/GstPlayBin:playbin/GstInputSelector:inputselector0.GstSelectorPad:sink_0: tags = taglist, video-codec=(string)"H.264\ \(Constrained\ Baseline\ Profile\)", bitrate=(uint)6633470, datetime=(datetime)1970-01-01T00:00:00Z, encoder=(string)Lavf52.64.2, container-format=(string)"ISO\ MP4/M4A", minimum-bitrate=(uint)469920, maximum-bitrate=(uint)70740480;
0:00:09.9 / 0:00:10.0
Reached end of play list.
同样的命令,播放我自己的mp4文件就失败了。
firefly@firefly:~$ gst-play-1.0 -v Videos/64a85ecd433f58730f7c43929f44415c_baofeng.mp4 --videosink="xvimagesink"
mpp[1491]: mpp_info: mpp version: 41c9c809 author: sayon.chen 2020-12-24 [mpp2str]: Add rc_gop_mode 2 str
mpp[1491]: mpp_rt: NOT found ion allocator
mpp[1491]: mpp_rt: found drm allocator
mpp[1491]: mpp: deprecated block control, use timeout control instead
这个问题能不能发给rockchip的工程师看一看?我可以提供出问题的mp4文件,大概70MB大小。
除了/usr/local/test.mp4,你有多试过几个mp4视频吗?
然后你的意思是只有一个你自己的mp4无法解码,其他的都没问题?
除了/usr/local/test.mp4,我还试验了手上的另外一个mp4文件,也是h.264编码的,没有问题。
就是这个mpeg-4编码的有问题。我现在就是怀疑mppvideodec无法解码mpeg-4编码。
就是这个mpeg- …
h264是属于mpeg-4的,你这说法不对
安装一个工具
apt install mediainfo
然后执行mediainfo test.mp4可以检查文件的信息
firefly@firefly:~$ mediainfo /usr/local/test.mp4
General
Complete name : /usr/local/test.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 8.15 MiB
Duration : 10 s 0 ms
Overall bit rate mode : Variable
Overall bit rate : 6 836 kb/s
Encoded date : UTC 1970-01-01 00:00:00
Tagged date : UTC 1970-01-01 00:00:00
Writing application : Lavf52.64.2
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L4.1
Format settings : 3 Ref Frames
Format settings, CABAC : No
Format settings, ReFrames : 3 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 6 665 kb/s
Nominal bit rate : 10.2 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 24.000 FPS
Minimum frame rate : 15.000 FPS
Maximum frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.134
Stream size : 7.94 MiB (97%)
Writing library : x264 core 85 Ubuntu_2:0.85.1448+git1a6d32-4
Encoding settings : cabac=0 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=4 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=0 / wpredp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=10240 / ratetol=0.4 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Duration : 9 s 920 ms
Bit rate mode : Variable
Bit rate : 167 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 202 KiB (2%)
firefly@firefly:~$ mediainfo Videos/64a85ecd433f58730f7c43929f44415c_baofeng.mp4
General
Complete name : Videos/64a85ecd433f58730f7c43929f44415c_baofeng.mp4
Format : MPEG-4
Codec ID : isom (mp41)
File size : 78.2 MiB
Duration : 10 min 11 s
Overall bit rate : 1 074 kb/s
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : mp4v-20
Duration : 10 min 8 s
Bit rate : 1 028 kb/s
Width : 852 pixels
Height : 480 pixels
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.101
Stream size : 74.5 MiB (95%)
Writing library : Lavc51.54.0
Audio
Format : AAC LC
Bit rate : 48.0 kb/s
Sampling rate : 24.0 kHz
Frame rate : 23.438 FPS (1024 SPF)
Stream size : 3.50 MiB (4%)
你看,所以你这个视频是H263的
所以mpp无法解码{:5_241:}
如果mppdecode不支持h263,decodebin或者playbin应该选择其他软解压组件,而不应该一直卡在那里吧?
