] Memory: 1994540K/2064384K available (13246K kernel code, 1808K rwdata, 5088K rodata, 1216K init, 1975K bss, 69844K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8009270000 - 0xffffff80093a0000 ( 1216 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008d70000 ( 13248 KB)
[ 0.000000] .rodata : 0xffffff8008d70000 - 0xffffff8009270000 ( 5120 KB)
[ 0.000000] .data : 0xffffff80093a0000 - 0xffffff8009564008 ( 1809 KB)
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.001434] Console: colour dummy device 80x25
[ 0.001467] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.001486] pid_max: default: 32768 minimum: 301
[ 0.001605] Security Framework initialized
[ 0.001706] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.001721] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.002758] Initializing cgroup subsys io
[ 0.002786] Initializing cgroup subsys memory
[ 0.002830] Initializing cgroup subsys devices
[ 0.002850] Initializing cgroup subsys freezer
[ 0.002870] Initializing cgroup subsys perf_event
[ 0.002896] Initializing cgroup subsys net_prio
[ 0.002916] Initializing cgroup subsys pids
[ 0.002963] ftrace: allocating 48427 entries in 190 pages
[ 0.143463] sched-energy: CPU device node has no sched-energy-costs
[ 0.143489] Invalid sched_group_energy for CPU0
[ 0.143498] CPU0: update cpu_capacity 1024
[ 0.143583] ASID allocator initialised with 32768 entries
[ 0.150254] Detected VIPT I-cache on CPU1
[ 0.150327] Invalid sched_group_energy for CPU1
[ 0.150333] CPU1: update cpu_capacity 1024
[ 0.150338] CPU1: Booted secondary processor [410fd034]
[ 0.151209] Detected VIPT I-cache on CPU2
[ 0.151264] Invalid sched_group_energy for CPU2
[ 0.151270] CPU2: update cpu_capacity 1024
[ 0.151277] CPU2: Booted secondary processor [410fd034]
[ 0.152111] Detected VIPT I-cache on CPU3
[ 0.152165] Invalid sched_group_energy for CPU3
[ 0.152170] CPU3: update cpu_capacity 1024
[ 0.152177] CPU3: Booted secondary processor [410fd034]
[ 0.152297] Brought up 4 CPUs
[ 0.152364] SMP: Total of 4 processors activated.
[ 0.152380] CPU features: kernel page table isolation forced OFF by command line option
[ 0.152393] CPU features: detected feature: 32-bit EL0 Support
[ 0.152407] CPU: All CPU(s) started at EL2
[ 0.152453] alternatives: patching kernel code
[ 0.152769] Invalid sched_group_energy for CPU3
[ 0.152783] Invalid sched_group_energy for Cluster3
[ 0.152793] Invalid sched_group_energy for CPU2
[ 0.152803] Invalid sched_group_energy for Cluster2
[ 0.152814] Invalid sched_group_energy for CPU1
[ 0.152823] Invalid sched_group_energy for Cluster1
[ 0.152835] Invalid sched_group_energy for CPU0
[ 0.152847] Invalid sched_group_energy for Cluster0
[ 0.153780] devtmpfs: initialized
[ 0.185455] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.185504] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.186212] xor: measuring software checksum speed
[ 0.196272] 8regs : 1080.000 MB/sec
[ 0.206357] 8regs_prefetch: 968.000 MB/sec
[ 0.216440] 32regs : 1456.000 MB/sec
[ 0.226532] 32regs_prefetch: 1224.000 MB/sec
[ 0.226545] xor: using function: 32regs (1456.000 MB/sec)
[ 0.226595] pinctrl core: initialized pinctrl subsystem
[ 0.230197] Failed to find legacy iommu devices
[ 0.231011] NET: Registered protocol family 16
[ 0.236328] cpuidle: using governor ladder
[ 0.240354] cpuidle: using governor menu
[ 0.240398] Registered FIQ tty driver
[ 0.241695] vdso: 2 pages (1 code @ ffffff8008d76000, 1 data @ ffffff80093a4000)
[ 0.241748] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.241967] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.273491] genirq: Setting trigger mode 8 for irq 178 failed (gic_set_type+0x0/0x64)
[ 0.333009] console [ttyFIQ0] enabled
[ 0.333739] Registered fiq debugger ttyFIQ0
[ 0.422570] raid6: int64x1 gen() 199 MB/s
[ 0.439635] raid6: int64x1 xor() 181 MB/s
[ 0.456759] raid6: int64x2 gen() 324 MB/s
[ 0.473955] raid6: int64x2 xor() 261 MB/s
[ 0.491110] raid6: int64x4 gen() 468 MB/s
[ 0.508204] raid6: int64x4 xor() 320 MB/s
[ 0.525436] raid6: int64x8 gen() 394 MB/s
[ 0.542656] raid6: int64x8 xor() 302 MB/s
[ 0.559782] raid6: neonx1 gen() 359 MB/s
[ 0.576983] raid6: neonx1 xor() 353 MB/s
[ 0.594140] raid6: neonx2 gen() 562 MB/s
[ 0.611361] raid6: neonx2 xor() 457 MB/s
[ 0.628502] raid6: neonx4 gen() 753 MB/s
[ 0.645678] raid6: neonx4 xor() 556 MB/s
[ 0.662897] raid6: neonx8 gen() 769 MB/s
[ 0.680104] raid6: neonx8 xor() 568 MB/s
[ 0.680485] raid6: using algorithm neonx8 gen() 769 MB/s
[ 0.680955] raid6: … xor() 568 MB/s, rmw enabled
[ 0.681405] raid6: using intx1 recovery algorithm
[ 0.682375] mpp venc_srv: mpp_probe enter
[ 0.682795] mpp venc_srv: init success
[ 0.685541] vcc_sd: regulator get failed, ret=-517
[ 0.687111] vcc_host_5v: supplied by vcc_sys
[ 0.689682] iommu: Adding device ff350000.vpu_service to group 0
[ 0.690332] iommu: Adding device ff351000.avsd to group 1
[ 0.690905] iommu: Adding device ff360000.rkvdec to group 2
[ 0.691508] iommu: Adding device ff330000.h265e to group 3
[ 0.692103] iommu: Adding device ff340000.vepu to group 4
[ 0.692704] iommu: Adding device ff370000.vop to group 5
[ 0.693920] rk_iommu ff350800.iommu: can’t get sclk
[ 0.694886] rk_iommu ff360480.iommu: can’t get aclk
[ 0.695334] rk_iommu ff360480.iommu: can’t get hclk
[ 0.695802] rk_iommu ff360480.iommu: can’t get sclk
[ 0.696560] rk_iommu ff330200.iommu: can’t get sclk
[ 0.697327] rk_iommu ff340800.iommu: can’t get sclk
[ 0.697980] rk_iommu ff373f00.iommu: can’t get sclk
[ 0.699215] SCSI subsystem initialized
[ 0.700319] usbcore: registered new interface driver usbfs
[ 0.700932] usbcore: registered new interface driver hub
[ 0.701562] usbcore: registered new device driver usb
[ 0.702162] media: Linux media interface: v0.10
[ 0.702631] Linux video capture interface: v2.00
[ 0.703256] pps_core: LinuxPPS API ver. 1 registered
[ 0.703705] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.704554] PTP clock support registered
[ 0.707205] Advanced Linux Sound Architecture Driver Initialized.
[ 0.708766] Bluetooth: Core ver 2.21
[ 0.709169] NET: Registered protocol family 31
[ 0.709566] Bluetooth: HCI device and connection manager initialized
[ 0.710154] Bluetooth: HCI socket layer initialized
[ 0.710597] Bluetooth: L2CAP socket layer initialized
[ 0.711087] Bluetooth: SCO socket layer initialized
[ 0.712926] rockchip-cpuinfo cpuinfo: Serial : 6692c53970c52f4b
[ 0.715299] clocksource: Switched to clocksource arch_sys_counter
[ 0.839446] NET: Registered protocol family 2
[ 0.840728] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.841655] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.843024] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.843805] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.844521] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.845607] NET: Registered protocol family 1
[ 0.846623] RPC: Registered named UNIX socket transport module.
[ 0.847158] RPC: Registered udp transport module.
[ 0.847617] RPC: Registered tcp transport module.
[ 0.848046] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.849675] Trying to unpack rootfs image as initramfs…
[ 1.705310] Freeing initrd memory: 8760K
[ 1.707449] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.713485] Initialise system trusted keyring
[ 1.732961] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.735211] NFS: Registering the id_resolver key type
[ 1.735753] Key type id_resolver registered
[ 1.736136] Key type id_legacy registered
[ 1.736538] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.738737] ntfs: driver 2.1.32 [Flags: R/O].
[ 1.739986] fuse init (API version 7.23)
[ 1.741139] SGI XFS with security attributes, no debug enabled
[ 1.751003] NET: Registered protocol family 38
[ 1.751476] Key type asymmetric registered
[ 1.751862] Asymmetric key parser ‘x509’ registered
[ 1.752698] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.753640] io scheduler noop registered
[ 1.754005] io scheduler deadline registered
[ 1.754482] io scheduler cfq registered (default)
[ 1.757808] phy phy-ff450000.syscon:usb2-phy@100.1: Failed to get VBUS supply regulator
[ 1.759950] rockchip-u3phy ff470000.usb3-phy: Failed to get VBUS supply regulator
[ 1.763493] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully
[ 1.767877] ace test_init function.
[ 1.768393] ace test_init end.ret=0
[ 1.769136] radar end.ret=0
[ 1.771221] Module initialized.
[ 1.771968] rk-vcodec vpu_combo: no regulator for vcodec
[ 1.772805] rk-vcodec vpu_combo: failed on clk_get clk_cabac
[ 1.773356] rk-vcodec vpu_combo: failed on clk_get clk_core
[ 1.773947] platform ff350000.vpu_service: probe device
[ 1.774866] platform ff350000.vpu_service: drm allocator with mmu enabled
[ 1.776654] platform ff351000.avsd: probe device
[ 1.777601] platform ff351000.avsd: drm allocator with mmu enabled
[ 1.780531] rk-vcodec vpu_combo: could not find power_model node
[ 1.781086] rk-vcodec vpu_combo: init success
[ 1.781958] rk-vcodec ff360000.rkvdec: no regulator for vcodec
[ 1.782561] rk-vcodec ff360000.rkvdec: parent devfreq is disabled
[ 1.783775] rk-vcodec ff360000.rkvdec: probe device
[ 1.784838] rk-vcodec ff360000.rkvdec: drm allocator with mmu enabled
[ 1.786536] rk-vcodec ff360000.rkvdec: init success
[ 1.788121] probe device ff330000.h265e
[ 1.788938] mpp_dev ff330000.h265e: try to get iommu dev ffffffc07cc1d410
[ 1.790112] mpp_dev ff330000.h265e: resource ready, register device
[ 1.791259] probe device ff340000.vepu
[ 1.792044] mpp_dev ff340000.vepu: try to get iommu dev ffffffc07cc1dc10
[ 1.793141] mpp_dev ff340000.vepu: resource ready, register device
[ 1.797872] dma-pl330 ff1f0000.dmac: Loaded driver for PL330 DMAC-241330
[ 1.798505] dma-pl330 ff1f0000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.800591] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.802573] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.805022] [drm] Initialized drm 1.1.0 20060810
[ 1.809792] [drm] Rockchip DRM driver version: v1.0.1
[ 1.810585] rockchip-drm display-subsystem: devfreq is not set
[ 1.811618] rockchip-vop ff370000.vop: failed to get vop register byname
[ 1.812267] rockchip-vop ff370000.vop: missing rockchip,grf property
[ 1.813159] rockchip-drm display-subsystem: bound ff370000.vop (ops 0xffffff8008e31418)
[ 1.814381] i2c i2c-4: of_i2c: modalias failure on /hdmi@ff3c0000/ports
[ 1.814986] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.815840] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
[ 1.818275] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops 0xffffff8008e26508)
[ 1.819116] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.819721] [drm] No driver support for vblank timestamp query.
[ 1.820753] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 1.821540] get_framebuffer_by_node: failed to get logo,offset
[ 1.822065] rockchip-drm display-subsystem: can’t not find any loader display
[ 1.822740] rockchip-drm display-subsystem: failed to show loader logo
[ 1.823562] Freeing drm_logo memory: 616K
[ 1.823948] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 1.824682] [drm] Cannot find any crtc or sizes - going 1024x768
[ 1.852749] Console: switching to colour frame buffer device 128x48
[ 1.872565] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.883646] Unable to detect cache hierarchy for CPU 0
[ 1.885793] brd: module loaded
[ 1.897383] loop: module loaded
[ 1.898912] zram: Added device: zram0
[ 1.899731] lkdtm: No crash points registered, enable through debugfs
[ 1.903589] register spi return v = :0
[ 1.906892] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.907710] rk_gmac-dwmac ff540000.ethernet: clock input or output? (input).
[ 1.908372] rk_gmac-dwmac ff540000.ethernet: TX delay(0x28).
[ 1.908886] rk_gmac-dwmac ff540000.ethernet: RX delay(0x16).
[ 1.909423] rk_gmac-dwmac ff540000.ethernet: integrated PHY? (no).
[ 1.910231] rk_gmac-dwmac ff540000.ethernet: cannot get clock clk_mac_speed
[ 1.910874] rk_gmac-dwmac ff540000.ethernet: clock input from PHY
[ 1.916455] rk_gmac-dwmac ff540000.ethernet: init for RGMII
[ 1.917121] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.917589] Ring mode enabled
[ 1.917870] DMA HW capability register supported
[ 1.918289] Normal descriptors
[ 1.918604] RX Checksum Offload Engine supported (type 2)
[ 1.919095] Wake-Up On Lan supported
[ 1.919525] rk_gmac-dwmac ff540000.ethernet: rk_get_eth_addr: rk_vendor_read eth mac address failed (-1)
[ 1.920413] rk_gmac-dwmac ff540000.ethernet: rk_get_eth_addr: generate random eth mac address: e2:a2:95:60:f9:2c
[ 1.921328] rk_gmac-dwmac ff540000.ethernet: rk_get_eth_addr: rk_vendor_write eth mac address failed (-1)
[ 1.922186] rk_gmac-dwmac ff540000.ethernet: rk_get_eth_addr: mac address: e2:a2:95:60:f9:2c
[ 1.922954] eth%d: device MAC address e2:a2:95:60:f9:2c
[ 1.923443] Enable RX Mitigation via HW Watchdog Timer
[ 1.995471] libphy: stmmac: probed
[ 1.995795] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[ 1.996388] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01)
[ 1.998749] usbcore: registered new interface driver rtl8192cu
[ 1.999395] usbcore: registered new interface driver rndis_wlan
[ 2.000361] usbcore: registered new interface driver mt7601u
[ 2.001005] Rockchip WiFi SYS interface (V1.00) …
[ 2.001604] usbcore: registered new interface driver rtl8150
[ 2.002197] usbcore: registered new interface driver r8152
[ 2.002804] usbcore: registered new interface driver asix
[ 2.003375] usbcore: registered new interface driver ax88179_178a
[ 2.003984] usbcore: registered new interface driver cdc_ether
[ 2.004589] usbcore: registered new interface driver rndis_host
[ 2.005238] usbcore: registered new interface driver cdc_ncm
[ 2.005837] usbcore: registered new interface driver qmi_wwan
[ 2.006444] usbcore: registered new interface driver cdc_mbim
[ 2.009464] phy phy-ff470000.usb3-phy.2: u3phy u2 power on
[ 2.009988] phy phy-ff470000.usb3-phy.3: u3phy u3 power on
[ 2.011919] ff580000.usb supply vusb_d not found, using dummy regulator
[ 2.012656] ff580000.usb supply vusb_a not found, using dummy regulator
[ 2.126377] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 2.127743] dwc2 ff580000.usb: DWC OTG Controller
[ 2.128206] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[ 2.128910] dwc2 ff580000.usb: irq 41, io mem 0xff580000
[ 2.129676] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.130313] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.130956] usb usb1: Product: DWC OTG Controller
[ 2.131402] usb usb1: Manufacturer: Linux 4.4.194-g021a2d9d5f48-dirty dwc2_hsotg
[ 2.132058] usb usb1: SerialNumber: ff580000.usb
[ 2.133509] hub 1-0:1.0: USB hub found
[ 2.133899] hub 1-0:1.0: 1 port detected
[ 2.136057] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.136693] ehci-pci: EHCI PCI platform driver
[ 2.137211] ehci-platform: EHCI generic platform driver
[ 2.140488] ehci-platform ff5c0000.usb: EHCI Host Controller
[ 2.141432] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2
[ 2.142337] ehci-platform ff5c0000.usb: irq 42, io mem 0xff5c0000
[ 2.148334] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.149222] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.149859] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.150525] usb usb2: Product: EHCI Host Controller
[ 2.150968] usb usb2: Manufacturer: Linux 4.4.194-g021a2d9d5f48-dirty ehci_hcd
[ 2.151628] usb usb2: SerialNumber: ff5c0000.usb
[ 2.153028] hub 2-0:1.0: USB hub found
[ 2.153452] hub 2-0:1.0: 1 port detected
[ 2.154660] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.155249] ohci-platform: OHCI generic platform driver
[ 2.156395] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[ 2.157396] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3
[ 2.158257] ohci-platform ff5d0000.usb: irq 43, io mem 0xff5d0000
[ 2.213615] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.214232] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.214896] usb usb3: Product: Generic Platform OHCI controller
[ 2.215446] usb usb3: Manufacturer: Linux 4.4.194-g021a2d9d5f48-dirty ohci_hcd
[ 2.216088] usb usb3: SerialNumber: ff5d0000.usb
[ 2.217508] hub 3-0:1.0: USB hub found
[ 2.217897] hub 3-0:1.0: 1 port detected
[ 2.219887] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.220798] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[ 2.221760] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x04210010
[ 2.222627] xhci-hcd xhci-hcd.10.auto: irq 181, io mem 0xff600000
[ 2.223641] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.224256] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.224924] usb usb4: Product: xHCI Host Controller
[ 2.225384] usb usb4: Manufacturer: Linux 4.4.194-g021a2d9d5f48-dirty xhci-hcd
[ 2.226026] usb usb4: SerialNumber: xhci-hcd.10.auto
[ 2.227511] hub 4-0:1.0: USB hub found
[ 2.227900] hub 4-0:1.0: 1 port detected
[ 2.228916] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.229750] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 5
[ 2.230588] usb usb5: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.231524] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.232137] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.232824] usb usb5: Product: xHCI Host Controller
[ 2.232832] usb usb5: Manufacturer: Linux 4.4.194-g021a2d9d5f48-dirty xhci-hcd
[ 2.232841] usb usb5: SerialNumber: xhci-hcd.10.auto
[ 2.235065] hub 5-0:1.0: USB hub found
[ 2.235485] hub 5-0:1.0: 1 port detected
[ 2.236712] usbcore: registered new interface driver cdc_acm
[ 2.237220] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.238039] usbcore: registered new interface driver cdc_wdm
[ 2.238658] usbcore: registered new interface driver uas
[ 2.239407] usbcore: registered new interface driver usb-storage
[ 2.240119] usbcore: registered new interface driver usbserial
[ 2.240730] usbcore: registered new interface driver usbserial_generic
[ 2.241383] usbserial: USB Serial support registered for generic
[ 2.242001] usbcore: registered new interface driver ch341
[ 2.242571] usbserial: USB Serial support registered for ch341-uart
[ 2.243210] usbcore: registered new interface driver cp210x
[ 2.243779] usbserial: USB Serial support registered for cp210x
[ 2.244473] usbcore: registered new interface driver ftdi_sio
[ 2.245043] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.246131] usbcore: registered new interface driver keyspan
[ 2.246711] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.247473] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.248170] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.248889] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.249655] usbcore: registered new interface driver option
[ 2.250197] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.251442] usbcore: registered new interface driver oti6858
[ 2.251998] usbserial: USB Serial support registered for oti6858
[ 2.252639] usbcore: registered new interface driver pl2303
[ 2.253181] usbserial: USB Serial support registered for pl2303
[ 2.253851] usbcore: registered new interface driver qcserial
[ 2.254446] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.255204] usbcore: registered new interface driver sierra
[ 2.255778] usbserial: USB Serial support registered for Sierra USB modem
[ 2.258444] usbcore: registered new interface driver usbtouchscreen
[ 2.259575] .. rk pwm remotectl v1.1 init
[ 2.260546] input: ff1b0030.pwm as /devices/platform/ff1b0030.pwm/input/input0
[ 2.262059] sensor_register_slave:mma8452,id=17
[ 2.262506] sensor_register_slave:lis3dh,id=7
[ 2.262911] sensor_register_slave:mma7660,id=18
[ 2.263341] sensor_register_slave:lsm303d,id=22
[ 2.263754] sensor_register_slave:gs_mc3230,id=23
[ 2.264179] [Gsensor] gsensor_init
[ 2.264532] sensor_register_slave:mpu6880_acc,id=24
[ 2.264979] sensor_register_slave:mpu6500_acc,id=25
[ 2.265439] sensor_register_slave:lsm330_acc,id=26
[ 2.265875] sensor_register_slave:akm8975,id=30
[ 2.266302] sensor_register_slave:akm8963,id=31
[ 2.266715] sensor_register_slave:l3g4200d,id=45
[ 2.267140] sensor_register_slave:l3g20d,id=46
[ 2.267567] sensor_register_slave:ewtsa,id=47
[ 2.267969] sensor_register_slave:lsm330_gyro,id=51
[ 2.268430] sensor_register_slave:cm3217,id=53
[ 2.268843] sensor_register_slave:cm3218,id=54
[ 2.270099] i2c /dev entries driver
[ 2.273743] rk808 1-0018: Pmic Chip id: 0x8050
[ 2.275321] rk808 1-0018: source: on=0x10, off=0x00
[ 2.292213] vcc_sd: supplied by vcc_io
[ 2.299585] vdd_11: Bringing 1000000uV into 1100000-1100000uV
[ 2.303628] rk808 1-0018: register rk8050 regulators
[ 2.304585] rk8xx-gpio rk8xx-gpio: register rk8050 gpio successful
[ 2.307392] input: rk8xx_pwrkey as /devices/platform/ff160000.i2c/i2c-1/1-0018/input/input1
[ 2.318446] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.319889] rk808 1-0018: Can not read property pmic,hold-gpio
[ 2.320463] rk808 1-0018: Can not read property pmic,stby-gpio
[ 2.321032] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff80097f6000
[ 2.324145] IR NEC protocol handler initialized
[ 2.325661] usbcore: registered new interface driver npu_acm
[ 2.326376] usbcore: registered new interface driver uvcvideo
[ 2.326893] USB Video Class driver (1.1.1)
[ 2.332174] Boot mode: normal
[ 2.333457] rockchip-thermal ff250000.tsadc: Missing tshut mode property, using default (cru)
[ 2.334227] rockchip-thermal ff250000.tsadc: Missing tshut-polarity property, using default (low)
[ 2.335436] rockchip-thermal ff250000.tsadc: tsadc is probed successfully!
[ 2.337973] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.339046] Bluetooth: Virtual HCI driver ver 1.5
[ 2.339764] Bluetooth: HCI UART driver ver 2.3
[ 2.340173] Bluetooth: HCI UART protocol H4 registered
[ 2.340654] Bluetooth: HCI UART protocol LL registered
[ 2.341115] Bluetooth: HCI UART protocol ATH3K registered
[ 2.341618] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 2.342340] usbcore: registered new interface driver bfusb
[ 2.342958] usbcore: registered new interface driver btusb
[ 2.343985] cpu cpu0: leakage=9
[ 2.344311] cpu cpu0: leakage-volt-sel=1
[ 2.344918] cpu cpu0: Failed to get pvtm
[ 2.347459] cpu cpu0: avs=0
[ 2.347795] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[ 2.349752] cpu cpu0: failed to find power_model node
[ 2.350736] sdhci: Secure Digital Host Controller Interface driver
[ 2.351314] sdhci: Copyright(c) Pierre Ossman
[ 2.351717] Synopsys Designware Multimedia Card Interface Driver
[ 2.353846] dwmmc_rockchip ff500000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.354565] dwmmc_rockchip ff500000.dwmmc: Using internal DMA controller.
[ 2.355186] dwmmc_rockchip ff500000.dwmmc: Version ID is 270a
[ 2.355795] dwmmc_rockchip ff500000.dwmmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo
[ 2.356708] dwmmc_rockchip ff500000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.358360] rockchip-iodomain ff100000.syscon:io-domains: Setting to 3300000 done
[ 2.359032] enter gpio_regulator_set_voltage line 111 ,gpio=27 state=0
[ 2.359644] rockchip-iodomain ff100000.syscon:io-domains: Setting to 3300000 done
[ 2.372900] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.386479] dwmmc_rockchip ff500000.dwmmc: 1 slots initialized
[ 2.388086] dwmmc_rockchip ff520000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.388816] dwmmc_rockchip ff520000.dwmmc: Using internal DMA controller.
[ 2.389458] dwmmc_rockchip ff520000.dwmmc: Version ID is 270a
[ 2.390052] dwmmc_rockchip ff520000.dwmmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo
[ 2.404922] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.418485] dwmmc_rockchip ff520000.dwmmc: 1 slots initialized
[ 2.420025] dwmmc_rockchip ff5f0000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.420790] dwmmc_rockchip ff5f0000.dwmmc: Using internal DMA controller.
[ 2.421434] dwmmc_rockchip ff5f0000.dwmmc: Version ID is 270a
[ 2.422067] dwmmc_rockchip ff5f0000.dwmmc: DW MMC controller at irq 44,32 bit host data width,256 deep fifo
[ 2.422983] dwmmc_rockchip ff5f0000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.424032] dwmmc_rockchip ff5f0000.dwmmc: No vqmmc regulator found
[ 2.425165] dwmmc_rockchip ff5f0000.dwmmc: allocated mmc-pwrseq
[ 2.436629] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.450251] dwmmc_rockchip ff5f0000.dwmmc: 1 slots initialized
[ 2.451272] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.451952] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[ 2.453936] mmc1: new high speed MMC card at address 0001
[ 2.456468] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 2.457923] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 2.459514] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 2.460100] dwmmc_rockchip ff5f0000.dwmmc: card claims to support voltages below defined range
[ 2.460426] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.461382] usbcore: registered new interface driver usbhid
[ 2.461386] usbhid: USB HID core driver
[ 2.461699] inv_mpu_iio: inv_mpu_init:746
[ 2.463808] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 2.469739] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8
[ 2.470857] usbcore: registered new interface driver snd-usb-audio
[ 2.474354] rk3328-codec ff410000.codec: rk3328 have no io-channels defined
[ 2.474695] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.475927] rk3328-codec ff410000.codec: spk_depop_time use default value.
[ 2.476790] mmc2: new high speed SDIO card at address 0001
[ 2.485839] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.487611] IPVS: Registered protocols (TCP, UDP)
[ 2.488116] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 2.489091] IPVS: Creating netns size=2104 id=0
[ 2.489586] IPVS: ipvs loaded.
[ 2.489883] IPVS: [rr] scheduler registered.
[ 2.490774] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.491427] Initializing XFRM netlink socket
[ 2.493336] NET: Registered protocol family 10
[ 2.495358] NET: Registered protocol family 17
[ 2.495804] NET: Registered protocol family 15
[ 2.496267] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.497468] Bridge firewalling registered
[ 2.498029] Bluetooth: RFCOMM socket layer initialized
[ 2.498558] Bluetooth: RFCOMM ver 1.11
[ 2.498916] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.499476] Bluetooth: HIDP socket layer initialized
[ 2.500023] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.501213] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.501695] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = rtl8723ds
[ 2.502344] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.502986] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.503787] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 97, flags = 0.
[ 2.504620] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 2.505270] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.505763] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.506333] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.507112] [BT_RFKILL]: bluetooth_platdata_parse_dt: uart_rts_gpios is no-in-use.
[ 2.507859] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 56.
[ 2.508692] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 58.
[ 2.509527] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.510056] [BT_RFKILL]: ** disable irq
[ 2.510621] [BT_RFKILL]: bt_default device registered.
[ 2.511219] Key type dns_resolver registered
[ 2.511830] sensor_register_slave:mpu6880_gyro,id=50
[ 2.512906] vendor storage:20190527 ret = 0
[ 2.513697] Registered cp15_barrier emulation handler
[ 2.514152] Registered setend emulation handler
[ 2.515566] Loading compiled-in X.509 certificates
[ 2.519128] Btrfs loaded
[ 2.520666] rga2: Driver loaded successfully ver:4.00
[ 2.521396] rga2: Module initialized.
[ 2.521752] pvtm list NULL
[ 2.544177] asoc-simple-card sound: rk3328-hifi ↔ ff010000.i2s mapping ok
[ 2.547508] asoc-simple-card hdmi-sound: i2s-hifi ↔ ff000000.i2s mapping ok
[ 2.549211]
[ 2.549401] =======================================================
[ 2.549959] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.550524] =======================================================
[ 2.551082] Realtek 8723DS SDIO WiFi driver (Powered by Rockchip,Ver v5.6.5_31752.20181221_COEX20181130-2e2e) init.
[ 2.552007] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.552443] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.552866] mmc2:mmc host rescan start!
[ 2.553209] RTW: module init start
[ 2.553530] RTW: rtl8723ds v5.6.5_31752.20181221_COEX20181130-2e2e
[ 2.554075] RTW: build time: Sep 2 2022 01:33:54
[ 2.554510] RTW: rtl8723ds BT-Coex version = COEX20181130-2e2e
[ 3.555362] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 3.556583] RTW: == SDIO Card Info ==
[ 3.556923] RTW: clock: 50000000 Hz
[ 3.557255] RTW: timing spec: sd high-speed
[ 3.557714] RTW: sd3_bus_mode: FALSE
[ 3.558053] RTW: ================
[ 3.618646] RTW: HW EFUSE
[ 3.618922] RTW: 0x000: 29 81 00 7C E1 88 07 00 A0 04 EC 35 12 C0 A2 D8
[ 3.619846] RTW: 0x010: 24 24 24 24 24 24 24 24 24 24 24 02 FF FF FF FF
[ 3.620717] RTW: 0x020: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.621627] RTW: 0x030: FF FF FF FF FF FF FF FF FF FF 22 22 22 22 22 22
[ 3.622514] RTW: 0x040: 21 21 21 21 21 02 FF FF FF FF FF FF FF FF FF FF
[ 3.623412] RTW: 0x050: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.624299] RTW: 0x060: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.625174] RTW: 0x070: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.626084] RTW: 0x080: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.626972] RTW: 0x090: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.627868] RTW: 0x0A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.628755] RTW: 0x0B0: FF FF FF FF FF FF FF FF 20 19 1D 00 00 00 FF FF
[ 3.629642] RTW: 0x0C0: FF 29 20 11 00 00 00 FF 00 FF 11 FF FF FF FF FF
[ 3.630529] RTW: 0x0D0: 3E 10 01 12 23 FF FF FF 20 04 4C 02 23 D7 21 02
[ 3.631428] RTW: 0x0E0: 0C 00 22 04 00 08 00 32 FF 21 02 0C 00 22 2A 01
[ 3.632330] RTW: 0x0F0: 01 00 00 00 [ 3.632392] RTW: 0x100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 3.632467] RTW: 0x110: 00 EB 00 6E 01 00 00 00 00 FF AC 5D 5C 41 11 2D
[ 3.632543] RTW: 0x120: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.632619] RTW: 0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.632702] RTW: 0x140: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.632778] RTW: 0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.632856] RTW: 0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.632936] RTW: 0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.633016] RTW: 0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.633096] RTW: 0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.633176] RTW: 0x1A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.633255] RTW: 0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.633349] RTW: 0x1C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.633426] RTW: 0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.633506] RTW: 0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.633585] RTW: 0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
[ 3.633888] RTW: hal_com_config_channel_plan chplan:0x20
00 00 00 00 00 00 00 00 02 00 FF FF
[ 3.768781] random: nonblocking pool is initialized
[ 3.965972] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
[ 3.967098] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 3.967634] [WLAN_RFKILL]: get_wifi_addr_vendor: rk_vendor_read wifi mac address failed (-1)
[ 3.970451] RTW: rtw_ndev_init(wlan0) if1 mac_addr=ac:5d:5c:41:11:2d
[ 3.973737] RTW: rtw_ndev_init(p2p0) if2 mac_addr=ae:5d:5c:41:11:2d
[ 3.976723] RTW: module init ret=0
[ 3.977528] ==gsl_ts_init==
[ 3.977872] ret=0
[ 3.980031] rk808-rtc rk808-rtc: setting system clock to 2016-01-21 08:54:02 UTC (1453366442)
[ 4.004940] vcc_sd: disabling
[ 4.005230] vccio_sd: disabling
u▒ 4.006063]
