ROC-RK3588S-PC 主板上面引出的接口I2C调试
ROC-RK3588S-PC 主板上面引出的接口,怎么调试上面的I2C接口。
/omit-if-no-ref/
i2c3m0_xfer: i2c3m0-xfer {
rockchip,pins =
/* i2c3_scl_m0 /
<1 RK_PC1 9 &pcfg_pull_none_smt>,
i2c3_sda_m0 */
<1 RK_PC0 9 &pcfg_pull_none_smt>;
	/omit-if-no-ref/
	i2c3m1_xfer: i2c3m1-xfer {
		rockchip,pins =
			/* i2c3_scl_m1 */
			<3 RK_PB7 9 &pcfg_pull_none_smt>,
			/* i2c3_sda_m1 */
			<3 RK_PC0 9 &pcfg_pull_none_smt>;
	/omit-if-no-ref/
	i2c3m2_xfer: i2c3m2-xfer {
		rockchip,pins =
			/* i2c3_scl_m2 */
			<4 RK_PA4 9 &pcfg_pull_none_smt>,
			/* i2c3_sda_m2 */
			<4 RK_PA5 9 &pcfg_pull_none_smt>;
	/omit-if-no-ref/
	i2c3m4_xfer: i2c3m4-xfer {
		rockchip,pins =
			/* i2c3_scl_m4 */
			<4 RK_PD0 9 &pcfg_pull_none_smt>,
			/* i2c3_sda_m4 */
			<4 RK_PD1 9 &pcfg_pull_none_smt>;
这4组选择哪一组才能调试出来。
