日志如下:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2022.09.15 13:13:15 =~=~=~=~=~=~=~=~=~=~=~=
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Sep 05 2022 - 13:23:36)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2022-09-05#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x006ac5f0)
ramdisk @ 0x05bf0000 (0x00146428)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c4d8 … OK
[ 0.000000] Linux version 3.10.0 (tao@tao-virtual-machine) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #0 SMP PREEMPT Thu Sep 1 15:03:11 CST 2022
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7cc00000
[ 0.000000] ion_reserve: cma reserved base 7cc00000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f27000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),-@0x0039C000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2022-09-05_13:23:36
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1993620k/1993620k available, 103532k reserved, 1523712K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bbcd3c (11988 kB)
[ 0.000000] .init : 0xc0bbd000 - 0xc0c16440 ( 358 kB)
[ 0.000000] .data : 0xc0c18000 - 0xc0daadc0 (1612 kB)
[ 0.000000] .bss : 0xc0daadc0 - 0xc0ecbd3c (1156 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:14
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:14
[ 0.494476] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.494492] pid_max: default: 32768 minimum: 301
[ 0.494607] Security Framework initialized
[ 0.494623] SELinux: Initializing.
[ 0.494696] Mount-cache hash table entries: 512
[ 0.495338] Initializing cgroup subsys debug
[ 0.495353] Initializing cgroup subsys memory
[ 0.495380] Initializing cgroup subsys freezer
[ 0.495408] CPU: Testing write buffer coherency: ok
[ 0.495721] /cpus/cpu@0 missing clock-frequency property
[ 0.495733] /cpus/cpu@1 missing clock-frequency property
[ 0.495743] /cpus/cpu@2 missing clock-frequency property
[ 0.495752] /cpus/cpu@3 missing clock-frequency property
[ 0.495803] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.495855] Setting up static identity map for 0xc0863a28 - 0xc0863a80
[ 0.499078] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x17e4 (version 3.1)
[ 0.572612] CPU1: Booted secondary processor
[ 0.572645] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.592285] CPU2: Booted secondary processor
[ 0.592308] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.611996] CPU3: Booted secondary processor
[ 0.612020] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.612118] Brought up 4 CPUs
[ 0.612147] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.612156] CPU: All CPU(s) started in SVC mode.
[ 0.612886] devtmpfs: initialized
[ 0.617287] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.618369] pinctrl core: initialized pinctrl subsystem
[ 0.618618] regulator-dummy: no parameters
[ 0.632885] NET: Registered protocol family 16
[ 0.634730] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.635102] ion_snapshot: 0x1ea98000 map to 0xe0907000 and copy to 0xc0ea6fcc (version 0.1)
[ 0.635346] Registered FIQ tty driver
[ 0.635750] fiq-debugger is disabled in device tree
[ 0.636473] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.636494] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.636511] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.636528] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.636620] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.636686] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.636747] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.636810] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.636873] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.636935] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.636997] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.637060] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.637128] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.637193] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.637206] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.637218] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.637229] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.637840] rockchip_interrupts_register:bank_num=7
[ 0.639781] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 0.639802] of_get_gpio_init_config:gpio[1] = 136, value = 0
[ 0.639855] rockchip_pinctrl_probe:init ok
[ 0.646917] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.647006] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647019] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.647187] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.647261] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647273] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.647435] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.647507] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647520] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.647680] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.647756] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647769] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.647940] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.648017] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.648029] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.648193] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.648268] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.648280] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.648448] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.648530] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.648542] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.650314] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.650327] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.650912] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.650934] DDR DEBUG: version 1.00 20150126
[ 0.650963] DDR DEBUG: Channel a:
[ 0.650972] DDR DEBUG: DDR3 Device
[ 0.650985] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.650994] DDR DEBUG: Channel b:
[ 0.651001] DDR DEBUG: DDR3 Device
[ 0.651013] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.651022] DDR DEBUG: addr=0xdb4000
[ 0.651032] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.651041] DDR DEBUG: socAddr[0]=0xdb4000, socAddr[1]=0xdb4100
[ 0.651050] DDR DEBUG: chAddr[0]=0xdb4000, chAddr[1]=0xdb4000
[ 0.651061] DDR DEBUG: dtar[0]=0x401b6000, dtar[1]=0x401b6000
[ 0.651114] DDR DEBUG: init success!!! freq=200MHz
[ 0.651122] DDR DEBUG: Channel a:
[ 0.651135] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.651147] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.651160] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.651172] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.651184] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x-Dwn=0x19
[ 0.651203] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.651210] DDR DEBUG: Channel b:
[ 0.651221] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.651234] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.651246] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.651259] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.651270] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.651279] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.651287] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.675646] bio: create slab at 0
[ 0.676172] Rockchip hdmi driver version 2.0
[ 0.676172] .
[ 0.677365] SCSI subsystem initialized
[ 0.677521] usbcore: registered new interface driver usbfs
[ 0.677566] usbcore: registered new interface driver hub
[ 0.677657] usbcore: registered new device driver usb
[ 0.679930] host_en_gpio= -2
[ 0.682360] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.682835] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adaptC adapter
[ 0.683530] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.684498] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.684618] media: Linux media interface: v0.10
[ 0.684664] Linux video capture interface: v2.00
[ 0.684718] pps_core: LinuxPPS API ver. 1 registered
[ 0.684728] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.684748] PTP clock support registered
[ 0.684807] i2c-core: driver [bq24296] using legacy suspend method
[ 0.684816] i2c-core: driver [bq24296] using legacy resume method
[ 0.685137] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[ 0.685823] ion_drm_heap_create: 0@0
[ 0.685951] Rockchip ion module is successfully loaded (v1.1)
[ 0.686113] Advanced Linux Sound Architecture Driver Initialized.
[ 0.686545] Bluetooth: Core ver 2.16
[ 0.686584] NET: Registered protocol family 31
[ 0.686594] Bluetooth: HCI device and connection manager initialized
[ 0.686609] Bluetooth: HCI socket layer initialized
[ 0.686622] Bluetooth: L2CAP socket layer initialized
[ 0.686649] Bluetooth: SCO socket layer initialized
[ 0.686882] cfg80211: Calling CRDA to update world regulatory domain
[ 0.687569] act8846_i2c_probe,line=898
[ 0.688579] act8846_parse_dt,line=746
[ 0.689049] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.689069] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.689085] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.689099] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.691198] act_dcdc1: 1200 mV
[ 0.694165] vccio: 3300 mV
[ 0.696025] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.698987] act_dcdc4: 2000 mV
[ 0.700224] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.702527] act_ldo2: 1050 mV
[ 0.704828] act_ldo3: 2800 mV
[ 0.707143] act_ldo4: 3300 mV
[ 0.709443] act_ldo5: 3300 mV
[ 0.711854] act_ldo6: 1100 mV
[ 0.714165] vcc_18: 1800 mV
[ 0.716475] act_ldo8: 1850 mV
[ 0.721270] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.725982] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.726755] rk808_i2c_probe,line=1355
[ 0.728086] The device is not rk808 -11
[ 0.728172] rk808: probe of 0-001b failed with error -11
[ 0.728249] i2c-core: driver [rk818] using legacy suspend method
[ 0.728258] i2c-core: driver [rk818] using legacy resume method
[ 0.730226] Switching to clocksource arch_sys_counter
[ 0.754302] rga: Module initialized.
[ 0.755029] rga2 ff920000.rga: rga ion client create success!
[ 0.755202] rga: Driver loaded succesfully
[ 0.755401] fb disp policy is box
[ 0.755442] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.755454] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.755793] rk-screen rk_screen.8: rockchip screen probe success
[ 0.756062] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.756439] rk32-edp ff970000.edp: screen is not edp!
[ 0.756460] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.756933] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.757158] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.757470] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.757648] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.757810] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.758544] rk3288-lcdc lcdc0: lcdc0: dclk:297000000>>fps:120
[ 0.758559] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.772177] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.789525] alloc_buffer:ion_phy_addr=0x10000000
[ 0.802464] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.813195] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab6000
[ 0.813243] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.813455] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.813468] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.813742] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.814083] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.814254] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.814423] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.815226] unknow screen type: 0
[ 0.815243] vop ver:3007236,unsupport output color:1
[ 0.815304] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:868
[ 0.815318] rk3288-lcdc lcdc1: wakeup from standby!
[ 0.819153] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.819169] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 0.820032] rockchip_set_mux:warning ignore bank num 15
[ 0.820188] rockchip_set_mux:warning ignore bank num 15
[ 0.820304] rockchip_set_mux:warning ignore bank num 15
[ 0.820433] rockchip_set_mux:warning ignore bank num 15
[ 0.820547] rockchip_set_mux:warning ignore bank num 15
[ 0.820666] rockchip_set_mux:warning ignore bank num 15
[ 0.821247] rockchip_set_mux:warning ignore bank num 15
[ 0.821412] rockchip_set_mux:warning ignore bank num 15
[ 0.821955] rockchip_set_mux:warning ignore bank num 15
[ 0.822106] rockchip_set_mux:warning ignore bank num 15
[ 0.822643] rockchip_set_mux:warning ignore bank num 15
[ 0.822792] rockchip_set_mux:warning ignore bank num 15
[ 0.823328] rockchip_set_mux:warning ignore bank num 15
[ 0.823501] rockchip_set_mux:warning ignore bank num 15
[ 0.825036] NET: Registered protocol family 2
[ 0.825709] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.825806] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.825879] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.825935] TCP: reno registered
[ 0.825949] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.825974] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.826163] NET: Registered protocol family 1
[ 0.826805] Unpacking initramfs…
[ 0.897965] Freeing initrd memory: 1304K (c5bf0000 - c5d36000)
[ 0.898790] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.899410] vcodec_service: probe device ff9a0000.vpu_service
[ 0.899607] vcodec_service: No reset resource define
[ 0.899778] vcodec_service: ff9a0000.vpu_service: power on
[ 0.899862] vcodec_service: probe device ff9a0000.vpu_service
[ 0.899878] vcodec_service: checking hw id 4831
[ 0.900887] vcodec_service: ff9a0000.vpu_service: power off…
[ 0.900931] vcodec_service: done
[ 0.900939] vcodec_service: init success
[ 0.901005] vcodec_service: probe device ff9c0000.hevc_service
[ 0.901343] vcodec_service: ff9c0000.hevc_service: power on
[ 0.901403] vcodec_service: probe device ff9c0000.hevc_service
[ 0.901418] vcodec_service: checking hw id 6867
[ 0.902014] vcodec_service: ff9c0000.hevc_service: power off…
[ 0.902054] vcodec_service: done
[ 0.902062] vcodec_service: init success
[ 0.902202] rknandbase v1.0 2014-03-31
[ 0.902341] rknand: probe of ff400000.nandc failed with error -1
[ 0.902451] rknand_driver:ret = 0
[ 0.904338] audit: initializing netlink socket (disabled)
[ 0.904383] type=2000 audit(0.410:1): initialized
[ 0.905204] bounce pool size: 64 pages
[ 0.909926] fuse init (API version 7.22)
[ 0.910298] msgmni has been set to 952
[ 0.912099] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.912115] io scheduler noop registered
[ 0.912125] io scheduler deadline registered
[ 0.912223] io scheduler cfq registered (default)
[ 0.913408] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 0.914111] IEP Driver loaded succesfully
[ 0.914199] Module initialized.
[ 0.915015] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.915032] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.916349] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.916366] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.916668] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[ 0.916682] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[ 0.916691] pwm_regulator_probe:error
[ 0.916711] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[ 0.916900] rk_serial.c v1.8 2014-03-04
[ 0.917128] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 0.917286] --11
[ 0.917342] serial ff180000.serial: membase e0972000
[ 0.917531] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 0.917706] serial ff190000.serial: membase e097e000
[ 0.917848] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 0.919486] console [ttyS2] enabled
[ 0.919666] serial ff690000.serial: membase fed60000
[ 0.919833] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 0.920000] serial ff1b0000.serial: membase e41be000
[ 0.922803] loop: module loaded
[ 0.923197] zram: Created 1 device(s) …
[ 0.923282] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 0.923295] i2c-core: driver [mpu6050B1] using legacy resume method
[ 0.923313] mpu_init: Probe name mpu6050B1
[ 0.923480] ak8963_mod_init: Probe name ak8963_mod
[ 0.924207] SCSI Media Changer driver v0.25
[ 0.924465] dws->regs: e41e2000
[ 0.925711] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
[ 0.926004] tun: Universal TUN/TAP device driver, 1.6
[ 0.926017] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.926134] vmac_init.
[ 0.926714] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 0.926732] stmmac_probe_config_dt: clock input/output? (input).
[ 0.926745] stmmac_probe_config_dt: TX delay(0x1d).
[ 0.926757] stmmac_probe_config_dt: RX delay(0x16).
[ 0.926806] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 0.926818] stmmc_pltfr_init:
[ 0.926827] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 0.926851] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 0.926862] stmmc_pltfr_init: init for RGMII
[ 0.926873] tx delay=0x1d
[ 0.926873] rx delay=0x16
[ 0.926889] tx delay=0x1d
[ 0.926889] rx delay=0x16
[ 0.927400] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.927414] Normal descriptors
[ 0.927422] Ring mode enabled
[ 0.927433] DMA HW capability register supported
[ 0.927445] RX Checksum Offload Engine supported (type 2)
[ 0.927455] TX Checksum insertion supported
[ 0.927464] Wake-Up On Lan supported
[ 0.927500] Enable RX Mitigation via HW Watchdog Timer
[ 0.927944] PPP generic driver version 2.4.2
[ 0.928143] PPP BSD Compression module registered
[ 0.928157] PPP Deflate Compression module registered
[ 0.928180] PPP MPPE Compression module registered
[ 0.928193] NET: Registered protocol family 24
[ 0.928230] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.928244] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.928257] Rockchip WiFi SYS interface (V1.00) …
[ 0.928292] esp_mem_init enter date Sep 1 2022 15:05:23
[ 0.928304] esp_mem_init VERSION [V2.5]
[ 0.928347] esp_mem_init complete
[ 0.928433] usbcore: registered new interface driver catc
[ 0.928474] usbcore: registered new interface driver kaweth
[ 0.928488] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.928527] usbcore: registered new interface driver pegasus
[ 0.928566] usbcore: registered new interface driver rtl8150
[ 0.928608] usbcore: registered new interface driver r8152
[ 0.928620] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.928686] usbcore: registered new interface driver hso
[ 0.928729] usbcore: registered new interface driver asix
[ 0.928767] usbcore: registered new interface driver ax88179_178a
[ 0.928806] usbcore: registered new interface driver cdc_ether
[ 0.928843] usbcore: registered new interface driver cdc_eem
[ 0.928884] usbcore: registered new interface driver dm9601
[ 0.928922] usbcore: registered new interface driver dm9620
[ 0.928969] usbcore: registered new interface driver smsc75xx
[ 0.929015] usbcore: registered new interface driver smsc95xx
[ 0.929053] usbcore: registered new interface driver gl620a
[ 0.929092] usbcore: registered new interface driver net1080
[ 0.929136] usbcore: registered new interface driver plusb
[ 0.929177] usbcore: registered new interface driver rndis_host
[ 0.929215] usbcore: registered new interface driver cdc_subset
[ 0.929252] usbcore: registered new interface driver zaurus
[ 0.929292] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.929358] usbcore: registered new interface driver int51x1
[ 0.929399] usbcore: registered new interface driver kalmia
[ 0.929438] usbcore: registered new interface driver ipheth
[ 0.929486] usbcore: registered new interface driver sierra_net
[ 0.929527] usbcore: registered new interface driver cx82310_eth
[ 0.929574] usbcore: registered new interface driver cdc_ncm
[ 0.929614] usbcore: registered new interface driver qmi_wwan
[ 0.929653] usbcore: registered new interface driver cdc_mbim
[ 0.929667] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.932143] EHCI: ehci_rk_probe e4240000 e4240010
[ 0.932163] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 0.932193] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 0.932522] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 0.946784] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 0.946868] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.946884] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.946900] usb usb1: Product: EHCI Host Controller
[ 0.946914] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 0.946927] usb usb1: SerialNumber: ff500000.usb
[ 0.947378] hub 1-0:1.0: USB hub found
[ 0.947403] hub 1-0:1.0: 1 port detected
[ 0.947575] EHCI: ehci_rk_probe ok
[ 0.947681] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.947978] usbcore: registered new interface driver cdc_acm
[ 0.947991] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.948052] usbcore: registered new interface driver usblp
[ 0.948101] usbcore: registered new interface driver cdc_wdm
[ 0.948170] usbcore: registered new interface driver usb-storage
[ 0.948212] usbcore: registered new interface driver ums-alauda
[ 0.948252] usbcore: registered new interface driver ums-cypress
[ 0.948291] usbcore: registered new interface driver ums-datafab
[ 0.948329] usbcore: registered new interface driver ums_eneub6250
[ 0.948373] usbcore: registered new interface driver ums-freecom
[ 0.948414] usbcore: registered new interface driver ums-isd200
[ 0.948453] usbcore: registered new interface driver ums-jumpshot
[ 0.948491] usbcore: registered new interface driver ums-karma
[ 0.948531] usbcore: registered new interface driver ums-onetouch
[ 0.948571] usbcore: registered new interface driver ums-sddr09
[ 0.948610] usbcore: registered new interface driver ums-sddr55
[ 0.948650] usbcore: registered new interface driver ums-usbat
[ 0.948743] usbcore: registered new interface driver usbserial
[ 0.948786] usbcore: registered new interface driver usbserial_generic
[ 0.948820] usbserial: USB Serial support registered for generic
[ 0.948861] usbcore: registered new interface driver ch341
[ 0.948893] usbserial: USB Serial support registered for ch341-uart
[ 0.948935] usbcore: registered new interface driver cp210x
[ 0.948966] usbserial: USB Serial support registered for cp210x
[ 0.949012] usbcore: registered new interface driver option
[ 0.949045] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.949114] usbcore: registered new interface driver pl2303
[ 0.949156] usbserial: USB Serial support registered for pl2303
[ 0.949205] usbcore: registered new interface driver trancevibrator
[ 0.949218] usb20_otg: version 3.10a 21-DEC-2012
[ 0.949652] e4280040
[ 0.949666] Core Release: 3.10a
[ 0.949679] Setting default values for core params
[ 0.949827] Using Buffer DMA mode
[ 0.949840] Periodic Transfer Interrupt Enhancement - disabled
[ 0.949851] Multiprocessor Interrupt Enhancement - disabled
[ 0.949862] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.949874] ^^^^^^^^^^^^^^^^^Device Mode
[ 0.949888] Dedicated Tx FIFOs mode
[ 0.949906] pcd_init otg_dev = ddf8c540
[ 0.950067] usb20_otg ff580000.usb: DWC OTG Controller
[ 0.950099] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 0.950129] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 0.950189] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.950205] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.950220] usb usb2: Product: DWC OTG Controller
[ 0.950233] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.950245] usb usb2: SerialNumber: ff580000.usb
[ 0.950691] hub 2-0:1.0: USB hub found
[ 0.950714] hub 2-0:1.0: 1 port detected
[ 0.951028] usb20_host: version 3.10a 21-DEC-2012
[ 0.953544] e4300040
[ 0.953558] Core Release: 3.10a
[ 0.953569] Setting default values for core params
[ 0.953698] Using Buffer DMA mode
[ 0.953710] Periodic Transfer Interrupt Enhancement - disabled
[ 0.953721] Multiprocessor Interrupt Enhancement - disabled
[ 0.953732] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.953742] ^^^^^^^^^^^^^^^^^^Host Mode
[ 0.953788] usb20_host ff540000.usb: DWC OTG Controller
[ 0.953817] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 0.953848] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 0.953940] Init: Power Port (0)
[ 0.954003] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.954019] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.954033] usb usb3: Product: DWC OTG Controller
[ 0.954046] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.954059] usb usb3: SerialNumber: ff540000.usb
[ 0.954520] hub 3-0:1.0: USB hub found
[ 0.954548] hub 3-0:1.0: 1 port detected
[ 0.955261] usbcore: registered new interface driver xpad
[ 0.955318] usbcore: registered new interface driver usb_acecad
[ 0.955369] usbcore: registered new interface driver aiptek
[ 0.955416] usbcore: registered new interface driver gtco
[ 0.955462] usbcore: registered new interface driver hanwang
[ 0.955526] usbcore: registered new interface driver kbtab
[ 0.955582] usbcore: registered new interface driver wacom
[ 0.955714] ==gsl_ts_init==
[ 0.955762] ret=0
[ 0.956030] sensor_register_slave:mma8452,id=17
[ 0.956044] sensor_register_slave:gs_mc3230,id=23
[ 0.956054] gsensor_init
[ 0.956064] sensor_register_slave:mpu6880_acc,id=24
[ 0.956075] sensor_register_slave:mpu6500_acc,id=25
[ 0.956086] sensor_register_slave:cm3217,id=48
[ 0.956097] sensor_register_slave:cm3218,id=49
[ 0.956325] .. rk pwm remotectl v1.1 init
[ 0.956568] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 0.961656] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 0.962269] i2c /dev entries driver
[ 0.962539] hdmi->edidread:1[ 0.962971] IR NEC protocol handler initialized
[ 0.962984] IR RC5(x) protocol handler initialized
[ 0.962996] IR RC6 protocol handler initialized
[ 0.963006] IR JVC protocol handler initialized
[ 0.963017] IR Sony protocol handler initialized
[ 0.963027] IR RC5 (streamzap) protocol handler initialized
[ 0.963038] IR SANYO protocol handler initialized
[ 0.963048] IR MCE Keyboard/mouse protocol handler initialized
[ 0.963215] usbcore: registered new interface driver uvcvideo
[ 0.963228] USB Video Class driver (1.1.1)
[ 0.963241] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 0.964718] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 0.964742] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 0.964764] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 0.964786] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 0.964826] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 0.964826]
[ 0.964898] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 0.965050] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe41f8000 size: 0x4000)
[ 0.965724] D1:camsys_platform_probe(1446): ff910000.isp memory:
[ 0.965742] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe4220000 size: 0x10000)
[ 0.965759] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1dfe6000 vir: 0xddfe6000 size: 0x1000)
[ 0.965775] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 0.965788] D1:camsys_platform_probe(1471): Probe ff910000.isp device success
[ 0.966203] not find test_power_init dev node
[ 0.966281] i2c-core: driver [bq27320] using legacy suspend method
[ 0.966294] i2c-core: driver [bq27320] using legacy resume method
[ 0.966663] rockchip_temp_probe,line=364
[ 1.025496] tsadc ff280000.tsadc: initialized
[ 1.025878] device-mapper: uevent: version 1.0.3
[ 1.026124] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.026454] Bluetooth: HCI UART driver ver 2.2
[ 1.026471] Bluetooth: HCI H4 protocol initialized
[ 1.026483] Bluetooth: HCILL protocol initialized
[ 1.026494] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.026507] rtk_btusb: Register usb char device interface for BT driver
[ 1.026694] usbcore: registered new interface driver rtk_btusb
[ 1.027361] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(594000), use default, just enable dvfs
[ 1.031457] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.031652] cpuidle: using governor ladder
[ 1.031666] cpuidle: using governor menu
[ 1.031712] Synopsys Designware Multimedia Card Interface Driver
[ 1.031724] MHSC version = Ver 2.00 2015-06-10
[ 1.032058] dw cru_regsbase addr 0x1d8.
[ 1.032071] dw cru_reset_offset val 3.
[ 1.032087] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.032133] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.032452] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.032619] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.032751] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.045217] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.058901] hdmi output corlor mode is 3
[ 1.058918] hdmi connect to lcdc1
[ 1.058931] switch:en=1,lcdc_id=1,screen type=6,cur type=0
[ 1.064948] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.064970] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.064990] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.065344] dw cru_regsbase addr 0x1d8.
[ 1.065391] dw cru_reset_offset val 0.
[ 1.065407] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.065446] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.066108] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.066281] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.067771] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.067835] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.084550] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.096997] mmc0: BKOPS_EN bit is not set
[ 1.098871] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.101155] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.101178] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.101198] [mmc0] tuning regsbase addr 0x218.
[ 1.101757] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 1.101766] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.101796] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 1.101820] [mmc0] Data transmission error !!! MINTSTS: [0x00002000]
[ 1.101829] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.101849] dwmmc_rockchip ff0f0000.rksdmmc: data FIFO error (status=00002000)
[ 1.101873] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-5
[ 1.102103] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-180 (17 len)
[ 1.102115] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 214-282 (7 len)
[ 1.102126] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-180 (17 len)
[ 1.102136] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 90
[ 1.102179] mmc0: new HS200 MMC card at address 0001
[ 1.102455] mmcblk0: mmc0:0001 AGND3R 14.5 GiB
[ 1.102569] mmcblk0rpmb: mmc0:0001 AGND3R partition 3 4.00 MiB
[ 1.102917] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.102930] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.102939] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.102948] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.102956] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.102965] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.102974] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.102982] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.102991] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.103000] system: 0x012400000 – 0x072400000 (1536 MB)
[ 1.103009] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 1.103017] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 1.103026] userdata: 0x073800000 – 0x3a3a00000 (13058 MB)
[ 1.103053] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13[ 1.104252] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.104266] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.104590] dw cru_regsbase addr 0x1d8.
[ 1.104599] dw cru_reset_offset val 1.
[ 1.104610] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.104648] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.104895] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.106109] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.106367] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.123900] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.143576] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.143613] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.143626] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.143924] leds-gpio leds.29: pins are not configured from the driver
[ 1.144162] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.145597] usbcore: registered new interface driver usbhid
[ 1.145607] usbhid: USB HID core driver
[ 1.145727] ashmem: initialized
[ 1.145850] logger: created 256K log ‘log_main’
[ 1.145954] logger: created 256K log ‘log_events’
[ 1.146050] logger: created 256K log ‘log_radio’
[ 1.146147] logger: created 256K log ‘log_system’
[ 1.147303] input: rk29-keypad as /devices/ff100000.adc/key.32/input/input1
[ 1.148158] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.148175] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.148187] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.148198] ES8323 2-0010: Error applying setting, reverse things back
[ 1.148247] es8323_adc = 0
[ 1.148259] jp es8323_line_det_gpio:-1
[ 1.148516] es8323 probe i2c recv ok
[ 1.149483] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.150080] es8323_probe
[ 1.310839] rk_fb_switch_screen: wait update_regs_wait timeout
[ 1.310893] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
[ 1.310927] pixel clk is 74250000 tmds clk is 74250000
[ 1.310975] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output HDMI.
[ 1.783535] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 1.783547] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 1.783558] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 1.783566] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 1.783576] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 1.783585] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 1.783595] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 1.783603] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 1.783613] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 1.783621] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 1.783630] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 1.783638] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 1.783647] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 1.783654] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 1.783663] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 1.783670] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 1.783679] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 1.783686] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 1.783696] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 1.783703] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 1.783713] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 1.783720] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 1.783729] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 1.783737] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 1.783747] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 1.783754] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 1.783763] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 1.783771] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 1.783780] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 1.783787] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 1.783796] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 1.783804] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 1.783828] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 1.783836] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 1.783845] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 1.783852] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 1.783861] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 1.783869] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 1.783878] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 1.783885] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 1.783895] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 1.783902] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 1.783911] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 1.783918] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 1.784063] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 1.784074] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 1.784085] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 1.784094] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 1.784114] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 1.790468] rockchip-es8323 rockchip-es8323.27: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
[ 1.790898] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.27/sound/card0/input2
[ 1.791315] u32 classifier
[ 1.791322] Actions configured
[ 1.791333] Netfilter messages via NETLINK v0.30.
[ 1.791386] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.791667] ctnetlink v0.93: registering with nfnetlink.
[ 1.791726] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.791733] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.791949] xt_time: kernel timezone is -0000
[ 1.792117] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.792222] arp_tables: (C) 2002 David S. Miller
[ 1.792257] TCP: cubic registered
[ 1.792263] Initializing XFRM netlink socket
[ 1.792430] NET: Registered protocol family 10
[ 1.792870] mip6: Mobile IPv6
[ 1.792894] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.793057] sit: IPv6 over IPv4 tunneling driver
[ 1.793335] NET: Registered protocol family 17
[ 1.793357] NET: Registered protocol family 15
[ 1.793407] Bridge firewalling registered
[ 1.793417] Ebtables v2.0 registered
[ 1.793592] Bluetooth: RFCOMM TTY layer initialized
[ 1.793614] Bluetooth: RFCOMM socket layer initialized
[ 1.793620] Bluetooth: RFCOMM ver 1.11
[ 1.793628] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.793634] Bluetooth: BNEP filters: protocol multicast
[ 1.793643] Bluetooth: BNEP socket layer initialized
[ 1.793650] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.793659] Bluetooth: HIDP socket layer initialized
[ 1.793684] l2tp_core: L2TP core driver, V2.0
[ 1.793696] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.793702] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.793909] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.793919] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 1.793927] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.793934] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.793942] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.793950] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.793970] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 1.793989] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 1.793998] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.794024] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 1.794031] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.794068] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.794195] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 1.794211] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 1.794223] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 1.794235] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 1.794247] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 1.794290] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.794379] [BT_RFKILL]: ** disable irq
[ 1.794444] [BT_RFKILL]: ap6335 device registered.
[ 1.795128] rk3288_init_suspend
[ 1.795139] rk3288_suspend_init enter
[ 1.795347] rk3288_suspend_init: pm_ctrbits =200007
[ 1.795376] gpio_get_dts_info suspend:4
[ 1.795383] gpio_get_dts_info resume:4
[ 1.795388] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.795412] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.795541] clks_gating_suspend_init:clkgt info ok
[ 1.795621] Registering SWP/SWPB emulation handler
[ 1.795632] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
[ 1.798149] ddrfreq: verion 1.2 20140526
[ 1.798162] ddrfreq: normal 528MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 528MHz
[ 1.798169] ddrfreq: auto-freq=0
[ 1.798175] ddrfreq: auto-freq-table[0] 240MHz
[ 1.798179] ddrfreq: auto-freq-table[1] 324MHz
[ 1.798184] ddrfreq: auto-freq-table[2] 456MHz
[ 1.798189] ddrfreq: auto-freq-table[3] 528MHz
[ 1.806167] act_ldo3: operation not allowed
[ 1.806175] vga_edid_probe: turn on ldo3 done.
[ 1.806430] act_ldo4: operation not allowed
[ 1.806436] vga_edid_probe: turn on ldo done.
[ 1.806701] act_ldo2: operation not allowed
[ 1.806708] vga_edid_probe: turn on ldo2 done.
[ 1.806953] act_ldo8: operation not allowed
[ 1.806959] vga_edid_probe: turn on ldo done.
[ 1.812008] unable to read EDID block.
[ 1.846562] unable to read EDID block.
[ 1.881111] unable to read EDID block.
[ 1.881121] vga-ddc: read and parse edid failed errno:-5.
[ 1.881127] vga_edid_probe: success. 10
[ 1.881244] firefly_vga_get_enable 180, 0
[ 1.881251] firefly_vga_get_status 186
[ 1.881257] firefly_vga_set_enable 159 enable:1
[ 1.881277] firefly_vga_enable 130 start
[ 1.881285] firefly_switch_fb 55
[ 1.881292] switch:en=1,lcdc_id=0,screen type=1,cur type=1
[ 1.881310] regulator-dummy: disabling
[ 1.881339] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 1.881386] VGA ENABLE
[ 1.881622] =======================================================
[ 1.881630] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.881635] =======================================================
[ 1.881641] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 1.881693] dhd_module_init: in
[ 1.881700] ======== dhd_wlan_init_plat_data ========
[ 1.881706] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 1.881712] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 1.881717] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.881737] dhd_wlan_init_gpio: host_oob_irq: 196
[ 1.881743] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 1.881747] pcd_pullup, is_on 0
[ 1.881752] dhd_wifi_platform_load: Enter
[ 1.881766] Power-up adapter ‘DHD generic adapter’
[ 1.881778] file system registered
[ 1.881789] wifi_platform_set_power = 1
[ 1.881795] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.881800] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.881806] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 1.881812] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 1.882305] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.882313] android_usb gadget: Number of LUNs=2
[ 1.882321] lun0: LUN: removable file: (no medium)
[ 1.882327] lun1: LUN: removable file: (no medium)
[ 1.882462] android_usb gadget: android_usb ready
[ 1.882539] sensor_init: Probe name sensors
[ 1.882554] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 1.883079] rtc_hym8563 0-0051: setting system clock to 2022-09-15 05:17:21 UTC (1663219041)
[ 1.889035] rockchip-spdif-card rockchip-spdif-card.25: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
[ 1.889928] ret 1024
[ 1.890302] usbcore: registered new interface driver snd-usb-audio
[ 1.890310] ALSA device list:
[ 1.890315] #0: RK_ES8323
[ 1.890320] #1: RK-SPDIF-CARD
[ 1.890659] Freeing unused kernel memory: 356K (c0bbd000 - c0c16000)
[ 1.989806] [WLAN_RFKILL]: wifi turn on power. 156
[ 2.140370] type=1403 audit(1663219041.750:2): policy loaded auid=4294967295 ses=4294967295
[ 2.165130] init: /init.rk30board.rc: 161: ignored duplicate definition of service ‘catlog’
[ 2.165886] init: could not import file ‘init.box.samba.rc’ from ‘/init.rk30board.rc’
[ 2.167671] init: invalid gid ‘trace’
[ 2.196449] wifi_platform_bus_enumerate device present 1
[ 2.196465] ======== Card detection to detect SDIO card! ========
[ 2.196477] mmc2:mmc host rescan start!
[ 2.266281] init: /dev/hw_random not found
[ 2.266343] keychord: using input dev ff680000.pwm for fevent
[ 2.266358] keychord: using input dev rk29-keypad for fevent
[ 2.271127] init: /dev/hw_random not found
[ 2.272023] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.272804] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
[ 2.275352] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[ 2.283091] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.283180] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
[ 2.283860] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.288613] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.288658] e2fsck: system: clean, 1920/82176 files, 111869/393216 blocks
[ 2.292259] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.292330] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
[ 2.298928] EXT4-fs (mmcblk0p8): recovery complete
[ 2.299234] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.299293] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
[ 2.299625] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 2.303017] EXT4-fs (mmcblk0p11): recovery complete
[ 2.303035] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.303088] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
[ 2.303725] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
[ 2.307926] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.307963] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 2.311739] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.311810] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
[ 2.311854] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.312716] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 2.312755] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 2.313010] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
[ 2.313362] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[ 2.385002] EXT4-fs (mmcblk0p13): recovery complete
[ 2.385302] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.385382] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
[ 2.387145] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.401856] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.401892] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 374/837184 files, 115106/3342848 blocks
[ 2.405934] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 2.405997] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
[ 2.406020] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
[ 2.412929] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 2.420091] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
[ 2.420173] mali ffa30000.gpu: Continuing without Mali clock control
[ 2.420214] mali pd enabled
[ 2.420227] clk enabled
[ 2.420238] MALI_DVFS_STEP = 4, div_dvfs = 10
[ 2.420248] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 2.420258] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 2.420268] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
[ 2.420277] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
[ 2.420365] turn on mali power
[ 2.420376] kbase_platform_rk_init,register_reboot_notifier
[ 2.420417] hrtimer: interrupt took 11083 ns
[ 2.420525] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 2.421346] mali ffa30000.gpu: Probed as mali0
[ 2.422321] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.424919] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.425502] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.426253] zram0: detected capacity change from 0 to 533413888
[ 2.447767] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.449305] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.450852] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.453624] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.470808] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 2.499879] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
[ 2.507761] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 2.507809] bat_cap: oldcap_path no exist
[ 2.507949] binder: 157:157 transaction failed 29189, size 0-0
[ 2.507997] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.508024] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 2.508095] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
[ 2.508500] init: Warning! Service displayd needs a SELinux domain defined; please fix!
[ 2.510163] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.510194] mmc2: new high speed SDIO card at address 0001
[ 2.513224] type=1400 audit(1663219042.130:3): avc: denied { transition } for pid=163 comm=“init” path=“/system/xbin/vm” dev=“mmcblk0p10” ino=1919 scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
[ 2.513248] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 2.513269] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 2.513482] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 2.513943] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.513958] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.513977] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.513987] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.514008] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.514018] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.514032] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.514041] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.518011] type=1400 audit(1663219042.130:4): avc: denied { rlimitinh } for pid=163 comm=“vm” scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
[ 2.518045] type=1400 audit(1663219042.130:5): avc: denied { siginh } for pid=163 comm=“vm” scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
[ 2.525822] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
[ 2.526497] bcmsdh_register: register client driver
[ 2.526677] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.526765] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.526774] bus num (host idx)=2, slot num (rca)=1
[ 2.526782] found adapter info ‘DHD generic adapter’
[ 2.526822] sdioh_attach: set sd_f2_blocksize 128
[ 2.527054] F1 signature read @0x18000000=0x16224335
[ 2.527378] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
[ 2.527815] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[ 2.528028] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
[ 2.528252] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’
[ 2.529272] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 2.529338] android_usb: already disabled
[ 2.529592] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 2.529639] wifi_platform_get_mac_addr
[ 2.529647] ======== dhd_wlan_get_mac_addr ========
[ 2.529653] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 2.529663] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 2.529669] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 2.529681] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
[ 2.529734] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 2.531614] wl_create_event_handler(): thread:wl_event_handler:b0 started
[ 2.531717] wl_escan_attach: Enter
[ 2.531740] wl_escan_init: Enter
[ 2.531765] tsk Enter, tsk = 0xdd6c149c
[ 2.531952] wl_create_event_handler(): thread:wl_escan_handler:b1 started
[ 2.531969] tsk Enter, tsk = 0xdd710164
[ 2.532129] dhd_attach(): thread:dhd_watchdog_thread:b2 started
[ 2.532306] dhd_attach(): thread:dhd_dpc:b3 started
[ 2.532346] dhd_attach(): thread:dhd_rxf:b4 started
[ 2.532357] dhd_deferred_work_init: work queue initialized
[ 2.539659] read descriptors
[ 2.539674] read strings
[ 2.539690] mtp_bind_config
[ 2.539715] pcd_pullup, is_on 1
[ 2.540002] Dongle Host Driver, version 1.201.59.11 (r506368)
[ 2.540002] Compiled in drivers/net/wireless/bcmdhd on Sep 1 2022 at 15:05:23
[ 2.540358] Register interface [wlan0] MAC: e0:76:d0:ea:8f:f2
[ 2.540358]
[ 2.540371] dhd_prot_ioctl : bus is down. we have nothing to do
[ 2.540411] bcmsdh_oob_intr_unregister: Enter
[ 2.540418] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.540428] dhd_txglom_enable: enable 0
[ 2.540435] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
[ 2.540441] dhd_conf_set_txglom_params: txglom_bucket_size=0
[ 2.540450] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[ 2.540458] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0, txctl_tmo_fix=0
[ 2.540465] sdioh_set_mode: set txglom_mode to multi-desc
[ 2.540472] dhd_bus_devreset: WLAN OFF DONE
[ 2.540507] wifi_platform_set_power = 0
[ 2.540513] ======== PULL WL_REG_ON(-1) LOW! ========
[ 2.540520] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.639254] [WLAN_RFKILL]: wifi shut off power.
[ 2.639267] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 2.639274] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.639330] dhd_module_init: Exit err=0
[ 2.908652] logd.auditd: start
[ 2.924627] dwc_otg_hcd_enable, enable host controller
[ 3.058689] Using Buffer DMA mode
[ 3.058702] Periodic Transfer Interrupt Enhancement - disabled
[ 3.058707] Multiprocessor Interrupt Enhancement - disabled
[ 3.058714] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.058720] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.058734] EHCI: rk_ehci_hcd_enable, disable host controller
[ 3.101828] Init: Power Port (0)
[ 3.205657] firefly_vga_get_enable 180, 1
[ 3.205753] firefly_vga_get_status 186
[ 3.206293] firefly_vga_set_mode 203
[ 3.396960] Indeed it is in host mode hprt0 = 00021501
[ 3.492575] healthd: No charger supplies found
[ 3.492593] healthd: No battery devices found
[ 3.574074] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 3.574143] Indeed it is in host mode hprt0 = 00001101
[ 3.771094] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 3.771110] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.771120] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 3.771624] hub 3-1:1.0: USB hub found
[ 3.771742] hub 3-1:1.0: 4 ports detected
[ 3.924138] rk3288-lcdc lcdc0: blank mode:0
[ 3.950402] rk_iommu ff940300.vopl_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab9000
shell@firefly:/ $ [ 8.071790] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.071810] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.071819] D1:camsys_open(739): camsys_marvin(ddfdc410) is opened!
[ 8.071908] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 8.071922] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 8.071934] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 8.071952] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 8.071974] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 8.077014] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 8.077024] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 8.077130] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 8.077155] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 8.078218] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 8.079279] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 8.080336] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 8.083557] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 8.084746] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 8.084809] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 8.084822] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 8.084833] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 8.085914] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 8.085934] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 8.087982] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 8.087994] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 8.088004] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 8.088011] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 8.088018] D1:camsys_release(763): camsys_marvin(ddfdc410) is closed
[ 8.093231] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.093243] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.093250] D1:camsys_open(739): camsys_marvin(ddfdc410) is opened!
[ 8.093341] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
[ 8.093355] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
[ 8.093367] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
[ 8.093376] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 8.093470] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
[ 8.098508] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 8.098518] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 8.098623] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 8.098647] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 8.099709] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 8.100776] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 8.101843] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
[ 8.105064] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
[ 8.105134] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
[ 8.105146] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 8.105158] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 8.106246] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 8.106271] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 8.108320] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
[ 8.108332] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 8.108342] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 8.108350] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 8.108357] D1:camsys_release(763): camsys_marvin(ddfdc410) is closed
[ 8.110124] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.110136] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.110144] D1:camsys_open(739): camsys_marvin(ddfdc410) is opened!
[ 8.110222] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 8.110247] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 8.115283] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 8.115294] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 8.115399] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 8.115423] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 8.116480] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 8.117534] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 8.118587] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 8.122071] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
[ 8.123526] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
[ 8.123588] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 8.123598] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 8.123606] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 8.124683] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 8.124703] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 8.126749] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 8.126761] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 8.126771] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 8.126778] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 8.126786] D1:camsys_release(763): camsys_marvin(ddfdc410) is closed
[ 8.672340] warning: `main’ uses 32-bit capabilities (legacy support in use)
[ 8.838457] [otg id chg] last id -1 current id 1
[ 8.838483] PortPower off
[ 8.838491] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 8.937934] Using Buffer DMA mode
[ 8.937956] Periodic Transfer Interrupt Enhancement - disabled
[ 8.937963] Multiprocessor Interrupt Enhancement - disabled
[ 8.937970] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 8.937977] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.074917] es8323_mic_state_ctrl read: 0
[ 9.074935] mic_state_switch 0
[ 9.074943] hp_det = 0,insert hp
[ 9.074948] hp mic use intern
[ 9.428859] vbus detect**
[ 9.431049] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 9.608233] Using Buffer DMA mode
[ 9.608252] Periodic Transfer Interrupt Enhancement - disabled
[ 9.608258] Multiprocessor Interrupt Enhancement - disabled
[ 9.608264] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 9.608270] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.608310] soft connect!!!
[ 9.717196] USB RESET
[ 9.754941] android_work: sent uevent USB_STATE=CONNECTED
[ 9.758450] USB RESET
[ 9.823679] android_usb gadget: high-speed config #1: android
[ 9.823803] android_work: sent uevent USB_STATE=CONFIGURED
[ 12.236793] healthd: battery none chg=
[ 12.373233] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 12.373252] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 12.373259] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 12.373266] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 12.373272] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 12.373278] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 12.373284] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 12.716539] acc_open
[ 12.716567] acc_release
[ 13.831853] phy_power_on: enable = 1
[ 13.871253] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 13.871287] eth0: device MAC address 96:47:27:18:57:7d
[ 13.875312] libphy: stmmac: probed
[ 13.875325] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
[ 13.875333] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
[ 16.141760] type=1400 audit(1663219055.980:6): avc: denied { execute } for pid=850 comm=“ActivityManager” name=“sh” dev=“mmcblk0p10” ino=322 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 16.142001] type=1400 audit(1663219055.980:7): avc: denied { read open } for pid=850 comm=“ActivityManager” path=“/system/bin/sh” dev=“mmcblk0p10” ino=322 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 16.142089] type=1400 audit(1663219055.980:8): avc: denied { execute_no_trans } for pid=850 comm=“ActivityManager” path=“/system/bin/sh” dev=“mmcblk0p10” ino=322 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 16.145043] type=1400 audit(1663219055.980:9): avc: denied { write } for pid=853 comm=“vm” name=“server” dev=“tmpfs” ino=3206 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=sock_file permissive=1
[ 16.154708] init: untracked pid 855 exited with status 0
[ 16.155452] type=1400 audit(1663219055.990:10): avc: denied { read write } for pid=494 comm=“ActivityManager” name=“vmdrm0” dev=“tmpfs” ino=1213 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 16.155657] type=1400 audit(1663219055.990:11): avc: denied { open } for pid=494 comm=“ActivityManager” path=“/dev/vmdrm0” dev=“tmpfs” ino=1213 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 16.155745] type=1400 audit(1663219055.990:12): avc: denied { ioctl } for pid=494 comm=“ActivityManager” path=“/dev/vmdrm0” dev=“tmpfs” ino=1213 ioctlcmd=b503 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 16.167941] init: untracked pid 863 exited with status 0
[ 16.168789] type=1400 audit(1663219056.000:13): avc: denied { execute } for pid=867 comm=“ActivityManager” name=“sh” dev=“mmcblk0p10” ino=322 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 16.168972] type=1400 audit(1663219056.000:14): avc: denied { read open } for pid=867 comm=“ActivityManager” path=“/system/bin/sh” dev=“mmcblk0p10” ino=322 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 16.169061] type=1400 audit(1663219056.000:15): avc: denied { execute_no_trans } for pid=867 comm=“ActivityManager” path=“/system/bin/sh” dev=“mmcblk0p10” ino=322 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 16.191751] init: untracked pid 871 exited with status 0
[ 37.148255] INFO: rcu_preempt detected stalls on CPUs/tasks: { 0} (detected by 1, t=2111 jiffies, g=85, c=84, q=230)
[ 37.165486] Backtrace for cpu 1 (current):
[ 37.172761] CPU: 1 PID: 894 Comm: app_process Not tainted 3.10.0 #0
[ 37.184898] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 37.195275] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 37.205697] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_other_cpu_stall+0x264/0x2e0)
[ 37.215998] [] (print_other_cpu_stall+0x264/0x2e0) from [] (__rcu_pending+0x90/0x190)
[ 37.226154] [] (__rcu_pending+0x90/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 37.237038] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 37.247994] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 37.258224] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 37.268552] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 37.279418] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 37.291081] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 37.301973] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 37.312436] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 37.322020] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 37.331280] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 37.337725] Exception stack(0xdc919fb0 to 0xdc919ff8)
[ 37.344537] 9fa0: 040fb176 b0000000 b5c65b0d 00000000
[ 37.353173] 9fc0: b5cea154 b5c65ad2 b5c54148 00041202 00000002 0008fdb0 b5c54000 b5c80130
[ 37.360979] 9fe0: 0000ff00 be98a338 b6f21bab b6f2113e 600d0030 ffffffff
[ 37.366351]
[ 37.366351] sending IPI to all other CPUs:
[ 37.374912] IPI backtrace for cpu 3
[ 37.380778]
[ 37.387199] CPU: 3 PID: 897 Comm: adbd Not tainted 3.10.0 #0
[ 37.393794] task: dc9e5400 ti: dcad2000 task.ti: dcad2000
[ 37.401005] PC is at find_extend_vma+0x14/0x70
[ 37.406836] LR is at find_extend_vma+0x14/0x70
[ 37.413803] pc : [] lr : [] psr: 800f0113
[ 37.413803] sp : dcad3ea8 ip : 00000001 fp : c5b61a40
[ 37.423184] r10: dcad2000 r9 : 00000017 r8 : 00000017
[ 37.428981] r7 : dc9e5400 r6 : 00000000 r5 : befff000 r4 : 00000000
[ 37.435151] r3 : c5b61a40 r2 : beffe000 r1 : befff000 r0 : dcadc210
[ 37.441625] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 37.448175] Control: 10c5387d Table: 1cef006a DAC: 00000015
[ 37.453488]
[ 37.453488] PC: 0xc00efa6c:
[ 37.460187] fa6c e5940020 e280003c eb1dce44 e1a00004 ebff5de2 e5943044 e3530000 0a000002
[ 37.475189] fa8c e5930000 e2800004 ebfdaa44 e1a00008 e8bd85f8 e590300c e3c11eff e3c1100f
[ 37.489596] faac e3530000 0a000005 e5932004 e1520001 1a000002 e5933028 e3130c01 0a000000
[ 37.503872] facc eaffffa3 e3e0000b e12fff1e e92d4070 e3c15eff e3c5500f e1a01005 ebfff632
[ 37.517930] faec e2504000 0a000012 e5946000 e1560005 9a00000f e5943028 e2133c01 01a04003
[ 37.532006] fb0c 0a00000b e1a01005 ebffffe1 e2503000 13a04000 1a000006 e5942028 e3120a02
[ 37.546102] fb2c 0a000003 e1a00004 e1a01005 e1a02006 ebfff320 e1a00004 e8bd8070 e92d4ff0
[ 37.560238] fb4c e24dd034 e1a04002 e1a06003 e1a0200d e3c23d7f e3c3303f e1a0b624 e2505000
[ 37.574800]
[ 37.574800] LR: 0xc00efa6c:
[ 37.581334] fa6c e5940020 e280003c eb1dce44 e1a00004 ebff5de2 e5943044 e3530000 0a000002
[ 37.595513] fa8c e5930000 e2800004 ebfdaa44 e1a00008 e8bd85f8 e590300c e3c11eff e3c1100f
[ 37.609593] faac e3530000 0a000005 e5932004 e1520001 1a000002 e5933028 e3130c01 0a000000
[ 37.623643] facc eaffffa3 e3e0000b e12fff1e e92d4070 e3c15eff e3c5500f e1a01005 ebfff632
[ 37.637603] faec e2504000 0a000012 e5946000 e1560005 9a00000f e5943028 e2133c01 01a04003
[ 37.651668] fb0c 0a00000b e1a01005 ebffffe1 e2503000 13a04000 1a000006 e5942028 e3120a02
[ 37.665692] fb2c 0a000003 e1a00004 e1a01005 e1a02006 ebfff320 e1a00004 e8bd8070 e92d4ff0
[ 37.679761] fb4c e24dd034 e1a04002 e1a06003 e1a0200d e3c23d7f e3c3303f e1a0b624 e2505000
[ 37.694206]
[ 37.694206] SP: 0xdcad3e28:
[ 37.700594] 3e28 00000007 c0013020 fed91000 dcad3e60 c0c21484 dcad3e94 00000017 00000017
[ 37.714686] 3e48 dcad2000 c0008558 c00efaec 800f0113 ffffffff c000d600 dcadc210 befff000
[ 37.728747] 3e68 beffe000 c5b61a40 00000000 befff000 00000000 dc9e5400 00000017 00000017
[ 37.742621] 3e88 dcad2000 c5b61a40 00000001 dcad3ea8 c00efaec c00efaec 800f0113 ffffffff
[ 37.756637] 3ea8 00000000 befff9df 00000000 c00ebbac 000003ff 00000001 dcad2000 00000020
[ 37.770465] 3ec8 00000000 00020000 00000004 dcad2000 00000000 dd77bc00 00000001 befff9df
[ 37.784354] 3ee8 01ca0ce0 dcad2000 00000002 c010fab8 00000017 dcad3f0c 00000000 00000000
[ 37.798186] 3f08 befff000 00000000 befff9fd 00000000 0000001e 00000000 0000001e c010fbe0
[ 37.812462]
[ 37.812462] FP: 0xc5b619c0:
[ 37.818936] 19c0 00000000 00000000 00000000 00000000 00000000 00000001 00000007 00000000
[ 37.832344] 19e0 c0c46660 00000008 000003ba 00000000 00000000 b6f7a000 0001008d 00000000
[ 37.846183] 1a00 00000000 00000000 dc9d0000 dd4b6480 00000000 00000000 00000000 00000000
[ 37.859812] 1a20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 37.873096] 1a40 dcadc210 dcadc220 dcadc210 00000000 00000000 00000000 00000000 00000000
[ 37.886736] 1a60 ffffffff 40000000 bf000000 dc948000 00000001 00000001 00000001 00030003
[ 37.900557] 1a80 00000000 00020002 c5b61a88 c5b61a88 c5b61a90 c5b61a90 00000000 00000000
[ 37.914397] 1aa0 00000002 00000000 00000000 00000000 00000000 00000002 00000000 00000001
[ 37.928026]
[ 37.928026] R0: 0xdcadc190:
[ 37.934406] c190 00000000 00000000 00000000 dcadc19c dcadc19c dd733a60 00000000 000b6e1c
[ 37.948163] c1b0 00000000 00000000 00000000 b46d9000 00000000 00000000 dcfcf430 00000000
[ 37.961747] c1d0 00000000 b46b2000 c596c1c0 00000e9f 80000070 00000000 00000000 00000000
[ 37.975493] c1f0 00000000 dcadc1f4 dcadc1f4 00000000 00000000 000b46b2 00000000 00000000
[ 37.989182] c210 beffe000 bf000000 00000000 00000000 00000001 00000000 00000000 beffe000
[ 38.002879] c230 c5b61a40 0000079f 00118173 00000000 00000000 00000000 00000000 dcab5948
[ 38.016692] c250 dcab5948 dca6b9a0 00000000 000beffe 00000000 00000000 dcadc2c0 810ef040
[ 38.030577] c270 c040f890 011ff10c 2e16b2ce 80b7f240 f38cfa4f 2a3f1e5a 80f0f200 f012e8df
[ 38.045116]
[ 38.045116] R3: 0xc5b619c0:
[ 38.051511] 19c0 00000000 00000000 00000000 00000000 00000000 00000001 00000007 00000000
[ 38.064855] 19e0 c0c46660 00000008 000003ba 00000000 00000000 b6f7a000 0001008d 00000000
[ 38.078559] 1a00 00000000 00000000 dc9d0000 dd4b6480 00000000 00000000 00000000 00000000
[ 38.092128] 1a20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 38.105408] 1a40 dcadc210 dcadc220 dcadc210 00000000 00000000 00000000 00000000 00000000
[ 38.118995] 1a60 ffffffff 40000000 bf000000 dc948000 00000001 00000001 00000001 00030003
[ 38.132737] 1a80 00000000 00020002 c5b61a88 c5b61a88 c5b61a90 c5b61a90 00000000 00000000
[ 38.146517] 1aa0 00000002 00000000 00000000 00000000 00000000 00000002 00000000 00000001
[ 38.160123]
[ 38.160123] R7: 0xdc9e5380:
[ 38.166474] 5380 00000000 dc9e5384 dc9e5384 00000000 00000000 00000000 00000000 00000000
[ 38.180024] 53a0 00000000 00000020 00000000 0000c350 0000c350 00000000 00000000 00000000
[ 38.193619] 53c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 38.206929] 53e0 00000001 00000000 01a79cfc 00000017 01a79d00 00000017 01a79d04 00000017
[ 38.220885] 5400 00000000 dcad2000 00000002 00400040 00000000 00000000 00000001 00000001
[ 38.234446] 5420 00000078 00000078 00000078 00000000 c0869474 00000000 00000400 00400000
[ 38.248275] 5440 dd1434c1 00000000 00000000 dcfb790c dd7c954c 00000001 b35a0dd7 00000008
[ 38.261990] 5460 1bb6c2d7 00000000 9d23a81d 00000002 1bb6c2d7 00000000 00000007 00000000
[ 38.276105]
[ 38.276105] R10: 0xdcad1f80:
[ 38.282541] 1f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 38.295847] 1fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 38.309066] 1fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 38.322274] 1fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 38.335531] 2000 00000000 00000002 00000000 dc9e5400 c0c3c138 00000003 00000015 dc9e5400
[ 38.349206] 2020 c1f44cc0 dcad2000 dd6b9500 c5a3ea80 00000003 dd143480 dcad3eb4 dcad3e30
[ 38.363090] 2040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 38.376614] 2060 00044f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 38.392213] CPU: 3 PID: 897 Comm: adbd Not tainted 3.10.0 #0
[ 38.402959] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 38.412633] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 38.422010] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 38.431567] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 38.438109] Exception stack(0xdcad3e60 to 0xdcad3ea8)
[ 38.446192] 3e60: dcadc210 befff000 beffe000 c5b61a40 00000000 befff000 00000000 dc9e5400
[ 38.454716] 3e80: 00000017 00000017 dcad2000 c5b61a40 00000001 dcad3ea8 c00efaec c00efaec
[ 38.461119] 3ea0: 800f0113 ffffffff
[ 38.469845] [] (__irq_svc+0x40/0x70) from [] (find_extend_vma+0x14/0x70)
[ 38.480365] [] (find_extend_vma+0x14/0x70) from [] (__get_user_pages.part.70+0x6c/0x3f4)
[ 38.491189] [] (__get_user_pages.part.70+0x6c/0x3f4) from [] (get_arg_page+0x4c/0xb0)
[ 38.500652] [] (get_arg_page+0x4c/0xb0) from [] (copy_strings+0xc4/0x220)
[ 38.510003] [] (copy_strings+0xc4/0x220) from [] (do_execve_common+0x170/0x284)
[ 38.519226] [] (do_execve_common+0x170/0x284) from [] (do_execve+0x8/0xc)
[ 38.528659] [] (do_execve+0x8/0xc) from [] (SyS_execve+0x30/0x44)
[ 38.538280] [] (SyS_execve+0x30/0x44) from [] (ret_fast_syscall+0x0/0x30)
[ 38.545604] IPI backtrace for cpu 2
[ 38.551605]
[ 38.558237] CPU: 2 PID: 212 Comm: DispSync Not tainted 3.10.0 #0
[ 38.565373] task: dd7caa00 ti: dd48e000 task.ti: dd48e000
[ 38.571516] PC is at 0xb6e2e0c8
[ 38.576472] LR is at 0xb6e4584f
[ 38.583003] pc : [] lr : [] psr: 600d0030
[ 38.583003] sp : b6a01cf0 ip : b6e6a9a8 fp : b6e66598
[ 38.592206] r10: b6a01d38 r9 : 00000000 r8 : 0007a120
[ 38.598372] r7 : b6a01d24 r6 : b72eba1c r5 : b72eb9c8 r4 : b6a01d24
[ 38.604501] r3 : 00000010 r2 : 00000002 r1 : b73cf9b0 r0 : b6a01d24
[ 38.611043] Flags: nZCv IRQs on FIQs on Mode USER_32 ISA Thumb Segment user
[ 38.617453] Control: 10c5387d Table: 1d48806a DAC: 00000015
[ 38.624413] CPU: 2 PID: 212 Comm: DispSync Not tainted 3.10.0 #0
[ 38.635192] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 38.644847] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 38.654054] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 38.663461] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 38.669827] Exception stack(0xdd48ffb0 to 0xdd48fff8)
[ 38.676429] ffa0: b6a01d24 b73cf9b0 00000002 00000010
[ 38.684990] ffc0: b6a01d24 b72eb9c8 b72eba1c b6a01d24 0007a120 00000000 b6a01d38 b6e66598
[ 38.692671] ffe0: b6e6a9a8 b6a01cf0 b6e4584f b6e2e0c8 600d0030 ffffffff
[ 38.699348] IPI backtrace for cpu 0
[ 38.705326]
[ 38.712105] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 38.719162] task: dc9d0a80 ti: dcf64000 task.ti: dcf64000
[ 38.726539] PC is at __do_softirq+0x78/0x2b4
[ 38.732758] LR is at msecs_to_jiffies+0x18/0x24
[ 38.739709] pc : [] lr : [] psr: 60070113
[ 38.739709] sp : dcf65e68 ip : 00000000 fp : 0000000a
[ 38.749270] r10: dcf65f7c r9 : 00000000 r8 : b6f0f000
[ 38.755324] r7 : dcf65f0c r6 : 00000002 r5 : 00000000 r4 : dcf64000
[ 38.761407] r3 : 00000000 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 38.767968] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 38.774544] Control: 10c5387d Table: 1c94406a DAC: 00000015
[ 38.779920]
[ 38.779920] PC: 0xc003ddd8:
[ 38.786635] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 38.802385] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 38.817371] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 38.832215] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 38.846848] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 38.861458] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 38.876035] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 38.890630] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 38.905737]
[ 38.905737] LR: 0xc003cee4:
[ 38.912523] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 38.927367] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 38.942229] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 38.956839] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 38.971499] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 38.986045] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 39.000565] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 39.015315] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 39.030433]
[ 39.030433] SP: 0xdcf65de8:
[ 39.037896] 5de8 00000007 c0013020 fed91000 dcf65e20 c0c21484 dcf65e54 b6f0f000 00000000
[ 39.052871] 5e08 dcf65f7c c0008558 c003de58 60070113 ffffffff c000d600 00000001 c0e4c1c0
[ 39.067527] 5e28 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c b6f0f000 00000000
[ 39.081765] 5e48 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58 60070113 ffffffff
[ 39.096120] 5e68 dcf65f0c 0000001d 00000000 00400100 ffff9116 00000000 00000000 60070193
[ 39.110565] 5e88 00000000 c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150
[ 39.124957] 5ea8 dcf64000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c
[ 39.139496] 5ec8 c00f0988 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e
[ 39.154404]
[ 39.154404] R1: 0xc0e4c140:
[ 39.160938] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 39.174905] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 39.188647] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 39.202780] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 39.216575] c1c0 00000282 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 39.230576] c1e0 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 39.245698] c200 00000002 00000000 00000000 00001dd8 00000008 00000002 00000000 00000000
[ 39.259587] c220 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 39.273795]
[ 39.273795] R4: 0xdcf63f80:
[ 39.280273] 3f80 00000000 00000000 00000001 00000000 00000000 a7a9e9df 000000f0 c000db84
[ 39.294413] 3fa0 00000000 c000da00 00000000 00000000 b89fd3e0 00000000 00000001 00000000
[ 39.308482] 3fc0 00000000 00000000 a7a9e9df 000000f0 00000001 b89fd3e0 b878e970 b89fcf28
[ 39.322739] 3fe0 9e9499c8 9e9499b8 b4fa56a7 b6df4964 200f0010 b89fd3e0 000000ab 0312fa12
[ 39.337327] 4000 00000002 00000102 00000000 dc9d0a80 c0c3c138 00000000 00000015 dc9d0a80
[ 39.351565] 4020 c1f29cc0 dcf64000 dd75e000 dd75f180 00000000 dcfb78c0 dcf65d74 dcf65cf0
[ 39.366014] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 39.380004] 4060 b6fa9e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 39.394299]
[ 39.394299] R7: 0xdcf65e8c:
[ 39.400705] 5e8c c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150 dcf64000
[ 39.415275] 5eac c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c c00f0988
[ 39.429727] 5ecc 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e dca0ea50
[ 39.444123] 5eec 80100073 dd75ea80 b6f0e000 b6f0f000 00000000 dcf65f7c 80100071 dcda2500
[ 39.458561] 5f0c dcf65f20 c00f0c50 c00f0988 60070013 ffffffff dd75eac0 80070013 000000af
[ 39.472968] 5f2c dd75eac0 00000000 dc4916c0 b6eed000 00000001 00000000 00000003 b6f0f000
[ 39.487127] 5f4c 00000003 dca0ea50 b6f0e000 b6f0f000 80100073 00000003 c00f0c50 80100073
[ 39.501520] 5f6c 00000000 00001000 00000002 0000201f dca0e948 00000000 00000001 00001000
[ 39.516141]
[ 39.516141] R10: 0xdcf65efc:
[ 39.522559] 5efc 00000000 dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013
[ 39.537016] 5f1c ffffffff dd75eac0 80070013 000000af dd75eac0 00000000 dc4916c0 b6eed000
[ 39.551457] 5f3c 00000001 00000000 00000003 b6f0f000 00000003 dca0ea50 b6f0e000 b6f0f000
[ 39.565763] 5f5c 80100073 00000003 c00f0c50 80100073 00000000 00001000 00000002 0000201f
[ 39.579960] 5f7c dca0e948 00000000 00000001 00001000 00000000 0000007d c000db84 dcf64000
[ 39.594281] 5f9c 00000000 b6f0e024 c000da00 00000001 00001000 b6f0e000 00001000 00000003
[ 39.608485] 5fbc b6f927b8 00000001 00001000 00000000 0000007d b6f0e000 0000000c b6f8c7bc
[ 39.622764] 5fdc b6f0e024 b6f43af5 bebc1828 b6f6a02f b6f6c13c 20070010 b6f0e000 990ae00d
[ 39.639514] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 39.650132] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 39.659877] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 39.669141] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 39.678589] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 39.684989] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 39.692767] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 39.701016] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 39.707355] 5e60: 60070113 ffffffff
[ 39.715984] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 39.724974] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 39.733651] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 39.742705] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 39.751807] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 39.760819] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 39.767004] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 39.772978] 5ec0: 00000000 dcf65f7c
[ 39.781317] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 39.789675] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 39.799278] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 39.808655] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 39.818227] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 39.917060] BUG: soft lockup - CPU#0 stuck for 22s! [io:893]
[ 39.922489] Modules linked in: mali_kbase
[ 39.929287]
[ 39.935197] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 39.941532] task: dc9d0a80 ti: dcf64000 task.ti: dcf64000
[ 39.947973] PC is at __do_softirq+0x78/0x2b4
[ 39.953691] LR is at msecs_to_jiffies+0x18/0x24
[ 39.960462] pc : [] lr : [] psr: 60070113
[ 39.960462] sp : dcf65e68 ip : 00000000 fp : 0000000a
[ 39.969580] r10: dcf65f7c r9 : 00000000 r8 : b6f0f000
[ 39.975430] r7 : dcf65f0c r6 : 00000002 r5 : 00000000 r4 : dcf64000
[ 39.981348] r3 : 00000000 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 39.987807] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 39.994312] Control: 10c5387d Table: 1c94406a DAC: 00000015
[ 39.999620]
[ 39.999620] PC: 0xc003ddd8:
[ 40.006234] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 40.021382] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 40.036128] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 40.050719] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 40.065228] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 40.079816] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 40.094363] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 40.108966] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 40.123933]
[ 40.123933] LR: 0xc003cee4:
[ 40.130494] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 40.145277] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 40.159858] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 40.174419] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 40.188951] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 40.203531] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 40.218051] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 40.232541] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 40.247509]
[ 40.247509] SP: 0xdcf65de8:
[ 40.253976] 5de8 00000000 dcf65f7c 0000000a c009d544 0000001d c000e3cc 0000001d fed91000
[ 40.268496] 5e08 dcf65e20 c000853c c003de58 60070113 ffffffff c000d600 00000001 c0e4c1c0
[ 40.282963] 5e28 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c b6f0f000 00000000
[ 40.297172] 5e48 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58 60070113 ffffffff
[ 40.311560] 5e68 dcf65f0c 0000001d 00000000 00400100 ffff9116 00000000 00000000 60070193
[ 40.325836] 5e88 00000000 c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150
[ 40.340225] 5ea8 dcf64000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c
[ 40.354636] 5ec8 c00f0988 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e
[ 40.369423]
[ 40.369423] R1: 0xc0e4c140:
[ 40.375830] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 40.389793] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 40.403592] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 40.417785] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 40.431624] c1c0 00000282 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 40.445611] c1e0 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 40.459398] c200 00000082 00000000 00000000 00001dd8 00000008 00000002 00000000 00000000
[ 40.473294] c220 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 40.487434]
[ 40.487434] R4: 0xdcf63f80:
[ 40.493773] 3f80 00000000 00000000 00000001 00000000 00000000 a7a9e9df 000000f0 c000db84
[ 40.507918] 3fa0 00000000 c000da00 00000000 00000000 b89fd3e0 00000000 00000001 00000000
[ 40.521994] 3fc0 00000000 00000000 a7a9e9df 000000f0 00000001 b89fd3e0 b878e970 b89fcf28
[ 40.536161] 3fe0 9e9499c8 9e9499b8 b4fa56a7 b6df4964 200f0010 b89fd3e0 000000ab 0312fa12
[ 40.550647] 4000 00000002 00010101 00000000 dc9d0a80 c0c3c138 00000000 00000015 dc9d0a80
[ 40.565002] 4020 c1f29cc0 dcf64000 dd75e000 dd75f180 00000000 dcfb78c0 dcf65d74 dcf65cf0
[ 40.579451] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 40.593524] 4060 b6fa9e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 40.607750]
[ 40.607750] R7: 0xdcf65e8c:
[ 40.614135] 5e8c c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150 dcf64000
[ 40.628737] 5eac c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c c00f0988
[ 40.643190] 5ecc 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e dca0ea50
[ 40.657590] 5eec 80100073 dd75ea80 b6f0e000 b6f0f000 00000000 dcf65f7c 80100071 dcda2500
[ 40.672016] 5f0c dcf65f20 c00f0c50 c00f0988 60070013 ffffffff dd75eac0 80070013 000000af
[ 40.686457] 5f2c dd75eac0 00000000 dc4916c0 b6eed000 00000001 00000000 00000003 b6f0f000
[ 40.700587] 5f4c 00000003 dca0ea50 b6f0e000 b6f0f000 80100073 00000003 c00f0c50 80100073
[ 40.715032] 5f6c 00000000 00001000 00000002 0000201f dca0e948 00000000 00000001 00001000
[ 40.729717]
[ 40.729717] R10: 0xdcf65efc:
[ 40.736210] 5efc 00000000 dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013
[ 40.750915] 5f1c ffffffff dd75eac0 80070013 000000af dd75eac0 00000000 dc4916c0 b6eed000
[ 40.765303] 5f3c 00000001 00000000 00000003 b6f0f000 00000003 dca0ea50 b6f0e000 b6f0f000
[ 40.779545] 5f5c 80100073 00000003 c00f0c50 80100073 00000000 00001000 00000002 0000201f
[ 40.793802] 5f7c dca0e948 00000000 00000001 00001000 00000000 0000007d c000db84 dcf64000
[ 40.808168] 5f9c 00000000 b6f0e024 c000da00 00000001 00001000 b6f0e000 00001000 00000003
[ 40.822459] 5fbc b6f927b8 00000001 00001000 00000000 0000007d b6f0e000 0000000c b6f8c7bc
[ 40.836630] 5fdc b6f0e024 b6f43af5 bebc1828 b6f6a02f b6f6c13c 20070010 b6f0e000 990ae00d
[ 40.853097] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 40.863294] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 40.873302] [] (show_stack+0x10/0x14) from [] (watchdog_timer_fn+0x108/0x168)
[ 40.883604] [] (watchdog_timer_fn+0x108/0x168) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 40.893740] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 40.904411] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 40.915750] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 40.926443] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 40.936474] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 40.945892] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 40.954829] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 40.961194] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 40.968917] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 40.977305] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 40.983636] 5e60: 60070113 ffffffff
[ 40.992085] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 41.001085] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 41.009748] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 41.018659] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 41.027543] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 41.036367] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 41.042619] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 41.048688] 5ec0: 00000000 dcf65f7c
[ 41.056993] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 41.065328] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 41.074559] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 41.083665] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 41.093060] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 42.819738] [sched_delayed] sched: RT throttling activated
[ 44.161285] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD25): error = -110, timeout = 8000ms
[ 44.168617] [mmc0] – Timeout recovery procedure start –
[ 44.179509] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 44.186652] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 44.195758] [mmc0] – Timeout recovery procedure finished –
[ 54.163434] fence timeout on [c5accb00] after 3000ms
[ 54.898776] objs:
fb-timeline sw_sync: 158
pt signaled@4.338802: 11
pt signaled@4.422136: 12
pt signaled@4.505468: 13
pt signaled@14.138798: 134
pt signaled@14.155466: 135
pt signaled@16.022137: 158
pt active: 159
pt active: 159
fb-timeline sw_sync: 33
pt signaled@16.012498: 33
pt active: 34
pt active: 34
malitl_162_0xb7316b10 Mali: 148
malitl_162_0xb7373af0 Mali: 12
pt signaled@4.244760: 10(0)
pt signaled@4.328069: 11(0)
pt signaled@4.411328: 12(0)
pt signaled@4.411437: 12(0)
malitl_162_0xb7373ba8 Mali: 0
malitl_443_0xb8c61f30 Mali: 149
pt signaled@16.007783: 149(0)
pt signaled@16.009483: 149(0)
pt active: 150(0)
pt active: 151(0)
malitl_443_0xb8c62090 Mali: 0
fences:
[dd047580] FramebufferSurface:0: signaled
[ 55.210644] fb-timeline_pt signaled@4.338802: 11 / 158
[ 55.210644] malitl_162_0xb7373af0_pt signaled@4.244760: 10(0) / 12
[ 55.210644]
[ 55.210644] [dcc4e600] FramebufferSurface:1: signaled
[ 55.210644] fb-timeline_pt signaled@4.422136: 12 / 158
[ 55.210644] malitl_162_0xb7373af0_pt signaled@4.328069: 11(0) / 12
[dcc4e200] mali_fence: signaled
malitl_162_0xb7373af0_pt signaled@4.411328: 12(0) / 12
[c5a81f00] FramebufferSurface:2: signaled
fb-timeline_pt signaled@4.505468: 13 / 158
malitl_162_0xb7373af0_pt signaled@4.411437: 12(0) / 12
[c5a6f380] ret_fence: signaled
fb-timeline_pt signaled@14.138798: 134 / 158
[c5a6f400] ret_fence: signaled
fb-timeline_pt signaled@14.155466: 135 / 158
[c5a6fc00] ret_fence: signaled
fb-timeline_pt signaled@16.022137: 158 / 158
[c5a6f280] ret_fence: signaled
fb-timeline_pt signaled@16.012498: 33 / 33
[dcbb8200] mali_fence: signaled
malitl_443_0xb8c61f30_pt signaled@16.007783: 149(0) / 149
[c5a1aa80] ret_fence: active
fb-timeline_pt active: 159 / 158
[c5a6f180] ret_fence: active
fb-timeline_pt active: 34 / 33
[ 55.852575]
[ 55.852575] [dc900080] BootAnimation:1: active
[ 55.852575] fb-timeline_pt active: 34 / 33
[ 55.852575] malitl_443_0xb8c61f30_pt signaled@16.009483: 149(0) / 149
[ 55.852575] fb-timeline_pt active: 159 / 158
[ 55.852575]
[ 55.852575] [c5accb00] mali_fence: active
[ 55.852575] malitl_443_0xb8c61f30_pt active: 150(0) / 149
[ 55.852575]
[ 55.852575] [c5a6f900] mali_fence: active
[ 56.307660] malitl_443_0xb8c61f30_pt active: 151(0) / 149
[ 56.307660]
[ 68.743243] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 68.751176] [mmc0] – Timeout recovery procedure start –
[ 68.762598] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 68.769866] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 68.778622] [mmc0] – Timeout recovery procedure finished –
[ 71.533113] mmcblk0: error -110 sending status command, retrying
[ 96.230150] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 96.238373] [mmc0] – Timeout recovery procedure start –
[ 96.249667] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 96.257126] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 96.266360] [mmc0] – Timeout recovery procedure finished –
[ 96.272940] mmcblk0: error -110 sending status command, retrying
[ 99.193334] INFO: rcu_preempt detected stalls on CPUs/tasks: { 0} (detected by 2, t=8417 jiffies, g=85, c=84, q=744)
[ 99.207584] Backtrace for cpu 2 (current):
[ 99.214758] CPU: 2 PID: 212 Comm: DispSync Not tainted 3.10.0 #0
[ 99.226913] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 99.237181] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 99.247847] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_other_cpu_stall+0x264/0x2e0)
[ 99.258431] [] (print_other_cpu_stall+0x264/0x2e0) from [] (__rcu_pending+0x90/0x190)
[ 99.268511] [] (__rcu_pending+0x90/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 99.279565] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 99.290532] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 99.300773] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 99.311045] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 99.322159] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 99.333908] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 99.345112] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 99.355666] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 99.365407] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 99.374653] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 99.381277] Exception stack(0xdd48fd70 to 0xdd48fdb8)
[ 99.388327] fd60: c1f3bcc0 dd7caa00 dd48fdb8 00002c1f
[ 99.397087] fd80: dd143480 00000000 c1f3bcc0 00000000 00000000 00000017 de9a1a40 dd48fdcc
[ 99.404998] fda0: dd4e6044 dd48fdb8 c0061d08 c086342c 600d0013 ffffffff
[ 99.415360] [] (__irq_svc+0x40/0x70) from [] (_raw_spin_unlock_irq+0x1c/0x44)
[ 99.426436] [] (_raw_spin_unlock_irq+0x1c/0x44) from [] (finish_task_switch+0x5c/0xd4)
[ 99.437008] [] (finish_task_switch+0x5c/0xd4) from [] (__schedule+0x4a0/0x554)
[ 99.446991] [] (__schedule+0x4a0/0x554) from [] (futex_wait_queue_me+0xf8/0x154)
[ 99.456435] [] (futex_wait_queue_me+0xf8/0x154) from [] (futex_wait+0xe8/0x188)
[ 99.465887] [] (futex_wait+0xe8/0x188) from [] (do_futex+0xbc/0x184)
[ 99.475072] [] (do_futex+0xbc/0x184) from [] (SyS_futex+0x124/0x168)
[ 99.484667] [] (SyS_futex+0x124/0x168) from [] (ret_fast_syscall+0x0/0x30)
[ 99.490611]
[ 99.490611] sending IPI to all other CPUs:
[ 99.500071] IPI backtrace for cpu 3
[ 99.506154]
[ 99.512715] CPU: 3 PID: 866 Comm: app_process Not tainted 3.10.0 #0
[ 99.519889] task: dc9ac980 ti: dccee000 task.ti: dccee000
[ 99.527472] PC is at __do_softirq+0x78/0x2b4
[ 99.533886] LR is at msecs_to_jiffies+0x18/0x24
[ 99.541116] pc : [] lr : [] psr: 600d0113
[ 99.541116] sp : dcceff40 ip : 00000000 fp : 0000000a
[ 99.551072] r10: 00000036 r9 : b6d46148 r8 : b675262b
[ 99.557253] r7 : 0d209e6c r6 : 00000082 r5 : 00000000 r4 : dccee000
[ 99.563566] r3 : 00000003 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 99.570390] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 99.577236] Control: 10c5387d Table: 1c62006a DAC: 00000015
[ 99.582868]
[ 99.582868] PC: 0xc003ddd8:
[ 99.590177] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 99.606427] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 99.622037] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 99.637419] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 99.652601] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 99.667888] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 99.683145] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 99.698421] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 99.714099]
[ 99.714099] LR: 0xc003cee4:
[ 99.721209] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 99.736421] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 99.751588] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 99.766732] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 99.781910] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 99.797009] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 99.812135] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 99.827294] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 99.842822]
[ 99.842822] SP: 0xdccefec0:
[ 99.849815] fec0 00000007 c0013020 fed91000 dccefef8 c0c21484 dcceff2c b675262b b6d46148
[ 99.865057] fee0 00000036 c0008558 c003de58 600d0113 ffffffff c000d600 00000001 c0e4c1c0
[ 99.880258] ff00 00000000 00000003 dccee000 00000000 00000082 0d209e6c b675262b b6d46148
[ 99.895312] ff20 00000036 0000000a 00000000 dcceff40 c003cf64 c003de58 600d0113 ffffffff
[ 99.910287] ff40 0d209e6c 0000001d b6d46148 00400000 ffffb21d 00000003 00000000 600d0193
[ 99.925322] ff60 00000000 c0c21484 0d209e6c b675262b b6d46148 00000036 b6777a4c c003e150
[ 99.940452] ff80 dccee000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dcceffb0 c000853c
[ 99.955479] ffa0 b6fbe4a8 800d0010 ffffffff c000d7bc b6d46858 b675262b 69616700 00000043
[ 99.970958]
[ 99.970958] R1: 0xc0e4c140:
[ 99.977869] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 99.992333] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 100.006684] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 100.021437] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 100.035690] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 100.050071] c1e0 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 100.064313] c200 00000000 00000000 00000000 00001e36 00000008 00000002 00000000 00000000
[ 100.078581] c220 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 100.093162]
[ 100.093162] R4: 0xdccedf80:
[ 100.099666] df80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 100.113916] dfa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 100.128045] dfc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 100.142272] dfe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 100.156420] e000 00000002 00000102 00000000 dc9ac980 c0c3c138 00000003 00000015 dc9ac980
[ 100.171094] e020 c1f44cc0 dccee000 dd6b9340 dd75e1c0 00000003 dcfb39c0 dcceff9c dcceff18
[ 100.185919] e040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 100.200338] e060 b6fc8e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 100.216817] CPU: 3 PID: 866 Comm: app_process Not tainted 3.10.0 #0
[ 100.227378] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 100.236886] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 100.246173] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 100.255535] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 100.261979] Exception stack(0xdccefef8 to 0xdcceff40)
[ 100.268167] fee0: 00000001 c0e4c1c0
[ 100.276507] ff00: 00000000 00000003 dccee000 00000000 00000082 0d209e6c b675262b b6d46148
[ 100.284677] ff20: 00000036 0000000a 00000000 dcceff40 c003cf64 c003de58 600d0113 ffffffff
[ 100.294181] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 100.303156] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 100.311863] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 100.321007] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 100.330072] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 100.338949] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 100.345152] Exception stack(0xdcceffb0 to 0xdccefff8)
[ 100.351785] ffa0: b6d46858 b675262b 69616700 00000043
[ 100.360221] ffc0: b6d722a4 0000001a b6d462e8 0d209e6c b675262b b6d46148 00000036 b6777a4c
[ 100.367895] ffe0: 80000000 be9bc318 b6fbaa09 b6fbe4a8 800d0010 ffffffff
[ 100.374219] IPI backtrace for cpu 0
[ 100.379539]
[ 100.385739] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 100.392108] task: dc9d0a80 ti: dcf64000 task.ti: dcf64000
[ 100.399056] PC is at __do_softirq+0x78/0x2b4
[ 100.404929] LR is at msecs_to_jiffies+0x18/0x24
[ 100.411621] pc : [] lr : [] psr: 60070113
[ 100.411621] sp : dcf65e68 ip : 00000000 fp : 0000000a
[ 100.420795] r10: dcf65f7c r9 : 00000000 r8 : b6f0f000
[ 100.426675] r7 : dcf65f0c r6 : 00000002 r5 : 00000000 r4 : dcf64000
[ 100.432744] r3 : 00000000 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 100.439270] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 100.445921] Control: 10c5387d Table: 1c94406a DAC: 00000015
[ 100.451275]
[ 100.451275] PC: 0xc003ddd8:
[ 100.457866] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 100.473153] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 100.487929] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 100.502592] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 100.517203] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 100.531802] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 100.546503] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 100.561354] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 100.576468]
[ 100.576468] LR: 0xc003cee4:
[ 100.583243] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 100.597944] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 100.612708] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 100.627258] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 100.641782] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 100.656314] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 100.670860] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 100.685418] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 100.700454]
[ 100.700454] SP: 0xdcf65de8:
[ 100.707101] 5de8 00000007 c0013020 fed91000 dcf65e20 c0c21484 dcf65e54 b6f0f000 00000000
[ 100.721847] 5e08 dcf65f7c c0008558 c003de58 60070113 ffffffff c000d600 00000001 c0e4c1c0
[ 100.736525] 5e28 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c b6f0f000 00000000
[ 100.750718] 5e48 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58 60070113 ffffffff
[ 100.765114] 5e68 dcf65f0c 0000001d 00000000 00400100 ffff9116 00000000 00000000 60070193
[ 100.779503] 5e88 00000000 c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150
[ 100.794015] 5ea8 dcf64000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c
[ 100.808652] 5ec8 c00f0988 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e
[ 100.823499]
[ 100.823499] R1: 0xc0e4c140:
[ 100.830098] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 100.844020] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 100.857871] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 100.872068] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 100.885892] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 100.899875] c1e0 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 100.913775] c200 00000000 00000000 00000000 00001e36 00000008 00000002 00000000 00000000
[ 100.927705] c220 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 100.941954]
[ 100.941954] R4: 0xdcf63f80:
[ 100.948481] 3f80 00000000 00000000 00000001 00000000 00000000 a7a9e9df 000000f0 c000db84
[ 100.962599] 3fa0 00000000 c000da00 00000000 00000000 b89fd3e0 00000000 00000001 00000000
[ 100.976815] 3fc0 00000000 00000000 a7a9e9df 000000f0 00000001 b89fd3e0 b878e970 b89fcf28
[ 100.991155] 3fe0 9e9499c8 9e9499b8 b4fa56a7 b6df4964 200f0010 b89fd3e0 000000ab 0312fa12
[ 101.005818] 4000 00000002 00000102 00000000 dc9d0a80 c0c3c138 00000000 00000015 dc9d0a80
[ 101.020229] 4020 c1f29cc0 dcf64000 dd75e000 dd75f180 00000000 dcfb78c0 dcf65d74 dcf65cf0
[ 101.034907] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 101.049107] 4060 b6fa9e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 101.063380]
[ 101.063380] R7: 0xdcf65e8c:
[ 101.069899] 5e8c c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150 dcf64000
[ 101.084370] 5eac c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c c00f0988
[ 101.098838] 5ecc 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e dca0ea50
[ 101.113200] 5eec 80100073 dd75ea80 b6f0e000 b6f0f000 00000000 dcf65f7c 80100071 dcda2500
[ 101.127626] 5f0c dcf65f20 c00f0c50 c00f0988 60070013 ffffffff dd75eac0 80070013 000000af
[ 101.142075] 5f2c dd75eac0 00000000 dc4916c0 b6eed000 00000001 00000000 00000003 b6f0f000
[ 101.156234] 5f4c 00000003 dca0ea50 b6f0e000 b6f0f000 80100073 00000003 c00f0c50 80100073
[ 101.170803] 5f6c 00000000 00001000 00000002 0000201f dca0e948 00000000 00000001 00001000
[ 101.185500]
[ 101.185500] R10: 0xdcf65efc:
[ 101.191971] 5efc 00000000 dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013
[ 101.207393] 5f1c ffffffff dd75eac0 80070013 000000af dd75eac0 00000000 dc4916c0 b6eed000
[ 101.222023] 5f3c 00000001 00000000 00000003 b6f0f000 00000003 dca0ea50 b6f0e000 b6f0f000
[ 101.236355] 5f5c 80100073 00000003 c00f0c50 80100073 00000000 00001000 00000002 0000201f
[ 101.250725] 5f7c dca0e948 00000000 00000001 00001000 00000000 0000007d c000db84 dcf64000
[ 101.264974] 5f9c 00000000 b6f0e024 c000da00 00000001 00001000 b6f0e000 00001000 00000003
[ 101.279295] 5fbc b6f927b8 00000001 00001000 00000000 0000007d b6f0e000 0000000c b6f8c7bc
[ 101.293545] 5fdc b6f0e024 b6f43af5 bebc1828 b6f6a02f b6f6c13c 20070010 b6f0e000 990ae00d
[ 101.310351] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 101.320995] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 101.330635] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 101.339681] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 101.348926] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 101.355340] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 101.363130] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 101.371462] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 101.377835] 5e60: 60070113 ffffffff
[ 101.386569] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 101.395675] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 101.404315] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 101.413379] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 101.422501] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 101.431332] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 101.437600] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 101.443619] 5ec0: 00000000 dcf65f7c
[ 101.452011] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 101.460425] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 101.469904] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 101.479145] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 101.488507] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 101.495714] IPI backtrace for cpu 1
[ 101.501820]
[ 101.508588] CPU: 1 PID: 874 Comm: app_process Not tainted 3.10.0 #0
[ 101.515551] task: dcfb78c0 ti: dc98c000 task.ti: dc98c000
[ 101.522770] PC is at __do_softirq+0x78/0x2b4
[ 101.528883] LR is at msecs_to_jiffies+0x18/0x24
[ 101.535763] pc : [] lr : [] psr: 600f0113
[ 101.535763] sp : dc98df40 ip : 00000000 fp : 0000000a
[ 101.545351] r10: 0000002f r9 : b6ce3148 r8 : b5ff5925
[ 101.551626] r7 : 0d209e6c r6 : 00000082 r5 : 00000000 r4 : dc98c000
[ 101.557878] r3 : 00000001 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 101.564590] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 101.571184] Control: 10c5387d Table: 1cfa006a DAC: 00000015
[ 101.576594]
[ 101.576594] PC: 0xc003ddd8:
[ 101.583309] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 101.598886] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 101.613936] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 101.628656] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 101.643375] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 101.658016] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 101.672634] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 101.687282] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 101.702328]
[ 101.702328] LR: 0xc003cee4:
[ 101.708987] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 101.723665] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 101.738478] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 101.752961] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 101.767519] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 101.782084] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 101.796571] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 101.811061] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 101.826077]
[ 101.826077] SP: 0xdc98dec0:
[ 101.832600] dec0 00000007 c0013020 fed91000 dc98def8 c0c21484 dc98df2c b5ff5925 b6ce3148
[ 101.847196] dee0 0000002f c0008558 c003de58 600f0113 ffffffff c000d600 00000001 c0e4c1c0
[ 101.861720] df00 00000000 00000001 dc98c000 00000000 00000082 0d209e6c b5ff5925 b6ce3148
[ 101.876323] df20 0000002f 0000000a 00000000 dc98df40 c003cf64 c003de58 600f0113 ffffffff
[ 101.890719] df40 0d209e6c 0000001d b6ce3148 00400000 ffffb229 00000001 00000000 600f0193
[ 101.905179] df60 00000000 c0c21484 0d209e6c b5ff5925 b6ce3148 0000002f b60722ec c003e150
[ 101.919669] df80 dc98c000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dc98dfb0 c000853c
[ 101.934159] dfa0 b6f13a4e 800f0030 ffffffff c000d7bc ffffffff 5f5a4e00 5f5f6300 374e5a5f
[ 101.949134]
[ 101.949134] R1: 0xc0e4c140:
[ 101.955627] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 101.969459] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 101.983393] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 101.997552] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 102.011328] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 102.025420] c1e0 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 102.039154] c200 00000000 00000000 00000000 00001e36 00000008 00000002 00000000 00000000
[ 102.053035] c220 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 102.067454]
[ 102.067454] R4: 0xdc98bf80:
[ 102.073909] bf80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 102.087711] bfa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 102.101408] bfc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 102.115173] bfe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 102.128911] c000 00000002 00000102 00000000 dcfb78c0 c0c3c138 00000001 00000015 dcfb78c0
[ 102.143217] c020 c1f32cc0 dc98c000 dd75f180 00000000 00000017 de8e6e40 dc98df9c dc98df18
[ 102.157632] c040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 102.171682] c060 b6f21e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 102.187909] CPU: 1 PID: 874 Comm: app_process Not tainted 3.10.0 #0
[ 102.198357] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 102.207836] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 102.217089] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 102.226507] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 102.232966] Exception stack(0xdc98def8 to 0xdc98df40)
[ 102.239215] dee0: 00000001 c0e4c1c0
[ 102.247633] df00: 00000000 00000001 dc98c000 00000000 00000082 0d209e6c b5ff5925 b6ce3148
[ 102.255965] df20: 0000002f 0000000a 00000000 dc98df40 c003cf64 c003de58 600f0113 ffffffff
[ 102.265548] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 102.274624] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 102.283452] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 102.293024] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 102.302273] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 102.311335] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 102.317662] Exception stack(0xdc98dfb0 to 0xdc98dff8)
[ 102.324430] dfa0: ffffffff 5f5a4e00 5f5f6300 374e5a5f
[ 102.332852] dfc0: b6f0dbd4 00000015 b6ce3298 0d209e6c b5ff5925 b6ce3148 0000002f b60722ec
[ 102.340548] dfe0: 00000000 be8aa2f8 b6f13a09 b6f13a4e 800f0030 ffffffff
[ 120.904030] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 120.912136] [mmc0] – Timeout recovery procedure start –
[ 120.923186] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 120.930386] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 120.939207] [mmc0] – Timeout recovery procedure finished –
[ 120.945704] mmcblk0: error -110 sending status command, aborting
[ 120.955742] end_request: I/O error, dev mmcblk0, sector 340088
[ 120.964360] end_request: I/O error, dev mmcblk0, sector 340096
[ 120.971067] end_request: I/O error, dev mmcblk0, sector 340104
[ 120.977530] end_request: I/O error, dev mmcblk0, sector 340112
[ 120.983873] end_request: I/O error, dev mmcblk0, sector 340120
[ 121.633499] end_request: I/O error, dev mmcblk0, sector 340128
[ 121.801286] end_request: I/O error, dev mmcblk0, sector 340136
[ 121.990131] end_request: I/O error, dev mmcblk0, sector 340144
[ 122.097751] end_request: I/O error, dev mmcblk0, sector 340152
[ 122.244859] end_request: I/O error, dev mmcblk0, sector 340160
[ 123.089572] Aborting journal on device mmcblk0p8-8.
[ 132.744887] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD25): error = -110, timeout = 8000ms
[ 132.823831] [mmc0] – Timeout recovery procedure start –
[ 133.018616] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 133.176105] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 133.241487] [mmc0] – Timeout recovery procedure finished –
[ 157.925560] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 158.158429] [mmc0] – Timeout recovery procedure start –
[ 158.311274] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 158.543180] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 158.721043] [mmc0] – Timeout recovery procedure finished –
[ 158.780831] mmcblk0: error -110 sending status command, retrying
[ 161.234902] INFO: rcu_preempt self-detected stall on CPU
[ 161.243662] INFO: rcu_preempt detected stalls on CPUs/tasks: { 0} (detected by 2, t=14722 jiffies, g=85, c=84, q=1185)
[ 161.250847] { 0} (t=14722 jiffies g=85 c=84 q=1185)
[ 161.254976] Backtrace for cpu 0 (current):
[ 161.259920] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 161.267890] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 161.274861] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 161.282493] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_cpu_stall+0xb4/0x138)
[ 161.289622] [] (print_cpu_stall+0xb4/0x138) from [] (__rcu_pending+0x68/0x190)
[ 161.297179] [] (__rcu_pending+0x68/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 161.305326] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 161.313079] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 161.320328] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 161.327610] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 161.335788] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 161.344371] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 161.352432] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 161.360023] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 161.366983] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 161.373577] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 161.377878] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 161.383014] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 161.391865] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 161.398309] 5e60: 60070113 ffffffff
[ 161.406772] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 161.415837] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 161.424469] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 161.433372] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 161.442302] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 161.451179] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 161.457465] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 161.463499] 5ec0: 00000000 dcf65f7c
[ 161.471951] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 161.480370] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 161.489931] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 161.499259] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 161.509376] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 161.515350]
[ 161.515350] sending IPI to all other CPUs:
[ 161.524103] IPI backtrace for cpu 2
[ 161.529660]
[ 161.536131] CPU: 2 PID: 847 Comm: HeapTrimmerDaem Not tainted 3.10.0 #0
[ 161.542936] task: dc9e4440 ti: dca3a000 task.ti: dca3a000
[ 161.548857] PC is at 0xb6e0c7e8
[ 161.553903] LR is at 0xb6df4285
[ 161.560460] pc : [] lr : [] psr: 80070030
[ 161.560460] sp : b42aa700 ip : b5d21fa0 fp : 00000009
[ 161.569916] r10: 00000014 r9 : b8886860 r8 : b8886848
[ 161.575751] r7 : b8886848 r6 : 00000000 r5 : c0000000 r4 : 00000014
[ 161.581819] r3 : b6e3f2c8 r2 : 00000003 r1 : b6e3f0e8 r0 : 3677e038
[ 161.588414] Flags: Nzcv IRQs on FIQs on Mode USER_32 ISA Thumb Segment user
[ 161.594948] Control: 10c5387d Table: 1cfa806a DAC: 00000015
[ 161.601930] CPU: 2 PID: 847 Comm: HeapTrimmerDaem Not tainted 3.10.0 #0
[ 161.612991] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 161.622665] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 161.631978] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 161.641603] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 161.648040] Exception stack(0xdca3bfb0 to 0xdca3bff8)
[ 161.654913] bfa0: 3677e038 b6e3f0e8 00000003 b6e3f2c8
[ 161.663350] bfc0: 00000014 c0000000 00000000 b8886848 b8886848 b8886860 00000014 00000009
[ 161.671140] bfe0: b5d21fa0 b42aa700 b6df4285 b6e0c7e8 80070030 ffffffff
[ 161.677791] IPI backtrace for cpu 3
[ 161.683795]
[ 161.690465] CPU: 3 PID: 212 Comm: DispSync Not tainted 3.10.0 #0
[ 161.697360] task: dd7caa00 ti: dd48e000 task.ti: dd48e000
[ 161.705504] PC is at _raw_spin_unlock_irq+0x1c/0x44
[ 161.712633] LR is at finish_task_switch+0x5c/0xd4
[ 161.719667] pc : [] lr : [] psr: 600d0013
[ 161.719667] sp : dd48fe60 ip : de8b4044 fp : dd48fe74
[ 161.728957] r10: dd143480 r9 : 00000003 r8 : c5a3ea80
[ 161.735172] r7 : 00000000 r6 : c1f44cc0 r5 : c5a3ea80 r4 : de8924c0
[ 161.741534] r3 : 000035f6 r2 : dd48fe60 r1 : dd7caa00 r0 : c1f44cc0
[ 161.748046] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 161.754659] Control: 10c5387d Table: 1d48806a DAC: 00000015
[ 161.760303]
[ 161.760303] PC: 0xc08633ac:
[ 161.767273] 33ac e3c3303f e5932004 e2422001 e5832004 e5933000 e3130002 012fff1e eafffc38
[ 161.782564] 33cc f57ff05b e1d030b0 e2833001 e1c030b0 f57ff04f e320f004 e121f001 e1a0200d
[ 161.797220] 33ec e3c23d7f e3c3303f e5932004 e2422001 e5832004 e5933000 e3130002 012fff1e
[ 161.811495] 340c eafffc27 f57ff05b e1d030b0 e2833001 e1c030b0 f57ff04f e320f004 f1080080
[ 161.825952] 342c e1a0200d e3c23d7f e3c3303f e5932004 e2422001 e5832004 e5933000 e3130002
[ 161.840186] 344c 012fff1e eafffc16 f57ff05b e1903f9f e2433001 e1802f93 e3320000 1afffffa
[ 161.854263] 346c e3530000 1a000001 f57ff04f e320f004 e1a0200d e3c23d7f e3c3303f e5932004
[ 161.868452] 348c e2422001 e5832004 e5933000 e3130002 012fff1e eafffc02 f57ff05b e1903f9f
[ 161.883126]
[ 161.883126] LR: 0xc0061c88:
[ 161.889668] 1c88 e28db004 0a000001 e8bd4800 eaffc5ae e1a0200d e3c23d7f e3c3303f e593000c
[ 161.903850] 1ca8 e8bd8800 e92d48f0 e3a03000 e5905488 e1a0200d e5803488 e3c23d7f e3c3303f
[ 161.918261] 1cc8 e5917000 e1a04001 e28db014 e593100c e1a06000 e59f3098 e5933000 e3530000
[ 161.932293] 1ce8 0a000001 e1a00004 eb018daf f57ff05a e3a03000 e1a00006 e5843018 eb2005c1
[ 161.946712] 1d08 e3550000 0a00000b e2853034 f57ff05b e1932f9f e2422001 e1831f92 e3310000
[ 161.960803] 1d28 1afffffa f57ff05b e3520000 1a000001 e1a00005 ebff4b3d e3570040 18bd88f0
[ 161.975135] 1d48 e2843008 f57ff05b e1932f9f e2422001 e1831f92 e3310000 1afffffa f57ff05b
[ 161.989366] 1d68 e3520000 18bd88f0 e1a00004 e8bd48f0 eaff4b7b c0c21064 e92d4818 e1a04000
[ 162.003856]
[ 162.003856] SP: 0xdd48fde0:
[ 162.010319] fde0 00000007 c0013020 fed91000 dd48fe18 c0c21484 dd48fe4c c5a3ea80 00000003
[ 162.024873] fe00 dd143480 c0008558 c086342c 600d0013 ffffffff c000d600 c1f44cc0 dd7caa00
[ 162.038946] fe20 dd48fe60 000035f6 de8924c0 c5a3ea80 c1f44cc0 00000000 c5a3ea80 00000003
[ 162.053162] fe40 dd143480 dd48fe74 de8b4044 dd48fe60 c0061d08 c086342c 600d0013 ffffffff
[ 162.067234] fe60 c0c15cc0 c1f44cc0 dd48e000 c5a3ea80 dd48fefc c0862360 0132f000 c0062f50
[ 162.081473] fe80 c1f44cc0 00000003 dd48feac c0c15cc0 40400040 c1f44cc0 00000003 dd143480
[ 162.095372] fea0 c0c212a8 0132f000 dd48fecc c0063aac 00000001 00000000 00000001 dd1438d8
[ 162.109426] fec0 00000002 00000001 dd48fef4 c0065708 dd4e7e9c dd143480 dd143488 dd48e000
[ 162.123710]
[ 162.123710] IP: 0xde8b3fc4:
[ 162.130161] 3fc4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 162.144693] 3fe4 00000000 00000000 00000000 00000013 00000000 fffdffff fedbf7ff 00000000
[ 162.158608] 4004 00000002 00000000 de8924c0 c0c3c138 00000003 00000015 de8924c0 c1f44cc0
[ 162.172628] 4024 de8b4000 c5a3ea80 c5a3ea80 00000003 dd7caa00 de8b5ecc de8b5e48 c086234c
[ 162.186599] 4044 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 162.199826] 4064 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 162.213440] 4084 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 162.226667] 40a4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 162.240379]
[ 162.240379] FP: 0xdd48fdf4:
[ 162.246797] fdf4 dd48fe4c c5a3ea80 00000003 dd143480 c0008558 c086342c 600d0013 ffffffff
[ 162.260858] fe14 c000d600 c1f44cc0 dd7caa00 dd48fe60 000035f6 de8924c0 c5a3ea80 c1f44cc0
[ 162.274935] fe34 00000000 c5a3ea80 00000003 dd143480 dd48fe74 de8b4044 dd48fe60 c0061d08
[ 162.289060] fe54 c086342c 600d0013 ffffffff c0c15cc0 c1f44cc0 dd48e000 c5a3ea80 dd48fefc
[ 162.303054] fe74 c0862360 0132f000 c0062f50 c1f44cc0 00000003 dd48feac c0c15cc0 40400040
[ 162.317007] fe94 c1f44cc0 00000003 dd143480 c0c212a8 0132f000 dd48fecc c0063aac 00000001
[ 162.331155] feb4 00000000 00000001 dd1438d8 00000002 00000001 dd48fef4 c0065708 dd4e7e9c
[ 162.344833] fed4 dd143480 dd143488 dd48e000 7fffffff 00000001 c0e601d4 c0e601e0 dd48e000
[ 162.359105]
[ 162.359105] R0: 0xc1f44c40:
[ 162.365395] 4c40 00000000 de8871e8 de8871e8 00000000 00000001 00000000 00000000 00000000
[ 162.378983] 4c60 de85b400 00000000 00000000 00000001 00000000 00000000 00000000 00000000
[ 162.392397] 4c80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 162.405940] 4ca0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 162.419178] 4cc0 35f735f7 00000004 000029c4 00002ecd 0000281f 00002203 000020ef ffffcabb
[ 162.433131] 4ce0 00000000 00000000 00000000 00000000 000029c4 00000000 00003dc0 00000000
[ 162.446921] 4d00 00006e1d 00000000 000029c4 00062123 00000004 00000004 ef9bc73c 00000022
[ 162.460739] 4d20 fc55cc4a 0000000d fc55cc4a 0000000d de892500 dc89d440 dd7caa38 00000000
[ 162.474905]
[ 162.474905] R1: 0xdd7ca980:
[ 162.481466] a980 00000000 dd7ca984 dd7ca984 00000000 00000000 00000000 00000000 00000000
[ 162.495065] a9a0 00000000 00000020 00000000 0000c350 0000c350 00000000 00000000 00000000
[ 162.508668] a9c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 162.522214] a9e0 00000001 00000000 e300e59a e58d203c e3a02000 e001019e e58d2064 e1a06741
[ 162.536141] aa00 00000000 dd48e000 00000002 00400040 00000000 00000000 00000001 00000001
[ 162.549634] aa20 0000006f 0000006f 0000006f 00000000 c0869474 00000000 00001dc4 000899bc
[ 162.563752] aa40 dc89d441 00000000 00000000 ddeec48c de89250c 00000001 9b691339 00000025
[ 162.577630] aa60 2a2f0ec6 0000000d fc55cc4a 0000000d 2a2f0ec6 0000000d 00000089 00000000
[ 162.591762]
[ 162.591762] R2: 0xdd48fde0:
[ 162.598331] fde0 00000007 c0013020 fed91000 dd48fe18 c0c21484 dd48fe4c c5a3ea80 00000003
[ 162.612306] fe00 dd143480 c0008558 c086342c 600d0013 ffffffff c000d600 c1f44cc0 dd7caa00
[ 162.626420] fe20 dd48fe60 000035f6 de8924c0 c5a3ea80 c1f44cc0 00000000 c5a3ea80 00000003
[ 162.640448] fe40 dd143480 dd48fe74 de8b4044 dd48fe60 c0061d08 c086342c 600d0013 ffffffff
[ 162.654573] fe60 c0c15cc0 c1f44cc0 dd48e000 c5a3ea80 dd48fefc c0862360 0132f000 c0062f50
[ 162.668792] fe80 c1f44cc0 00000003 dd48feac c0c15cc0 40400040 c1f44cc0 00000003 dd143480
[ 162.682734] fea0 c0c212a8 0132f000 dd48fecc c0063aac 00000001 00000000 00000001 dd1438d8
[ 162.696524] fec0 00000002 00000001 dd48fef4 c0065708 dd4e7e9c dd143480 dd143488 dd48e000
[ 162.711037]
[ 162.711037] R4: 0xde892440:
[ 162.717440] 2440 00000000 de892444 de892444 00000000 00000000 00000000 00000000 00000000
[ 162.731039] 2460 00000000 00000020 00000000 0000c350 0000c350 00000000 00000000 00000000
[ 162.744785] 2480 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 162.758177] 24a0 00000001 00000000 ffebffdf fffdfdf5 ffebfeff fffffff7 f7ffffff fffffff7
[ 162.772066] 24c0 00000000 de8b4000 00000002 00208040 00000000 00000000 00000000 00000001
[ 162.785845] 24e0 00000078 00000078 00000078 00000000 c0869474 00000000 00000400 00400000
[ 162.800173] 2500 00000001 ddeec480 dc89d440 dd7caa4c c1f4519c 00000001 9b691339 00000025
[ 162.814671] 2520 d37a5e86 00000001 fca19c38 0000000d d31d075f 00000001 00000111 00000000
[ 162.829071]
[ 162.829071] R5: 0xc5a3ea00:
[ 162.835538] ea00 00000000 00000000 00000000 00000000 00000000 000000c3 0000003b 00000000
[ 162.849065] ea20 c0c46660 00000002 00000326 00000000 00000000 b6f6b000 0001008d 00000000
[ 162.862950] ea40 00000000 00000000 ddeee900 c5b16840 00000000 00000000 ffffffbf ffeffffa
[ 162.876816] ea60 ffffffff fffffffc fdb3bffe 7f9d74ff ebfff77d dbfffbea fdf7fffe fff77eff
[ 162.890972] ea80 dcf30b00 dd12b9b0 c5acfe18 c0019acc c00eed38 b6f4d000 00000000 bf000000
[ 162.905135] eaa0 00000000 b6f4d000 beb09000 dd488000 00000018 00000003 000000d5 00860086
[ 162.918933] eac0 00000000 7eea7eea c5a3eac8 c5a3eac8 c5a3ead0 c5a3ead0 00000cc8 000071ee
[ 162.933062] eae0 00007111 00000000 00000000 000055f9 00001668 00000022 00000000 00000038
[ 162.947191]
[ 162.947191] R6: 0xc1f44c40:
[ 162.953560] 4c40 00000000 de8871e8 de8871e8 00000000 00000001 00000000 00000000 00000000
[ 162.967193] 4c60 de85b400 00000000 00000000 00000001 00000000 00000000 00000000 00000000
[ 162.980883] 4c80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 162.994173] 4ca0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 163.007412] 4cc0 35f835f8 00000004 000029c4 00002ecd 0000281f 00002203 000020ef ffffcabb
[ 163.021680] 4ce0 00000000 00000000 00000000 00000000 000029c4 00000000 00003dc0 00000000
[ 163.035200] 4d00 00006e1d 00000000 000029c4 00062123 00000004 00000004 ef9bc73c 00000022
[ 163.049280] 4d20 fc55cc4a 0000000d fc55cc4a 0000000d de892500 dc89d440 dd7caa38 00000000
[ 163.063428]
[ 163.063428] R8: 0xc5a3ea00:
[ 163.069760] ea00 00000000 00000000 00000000 00000000 00000000 000000c3 0000003b 00000000
[ 163.083494] ea20 c0c46660 00000002 00000326 00000000 00000000 b6f6b000 0001008d 00000000
[ 163.097191] ea40 00000000 00000000 ddeee900 c5b16840 00000000 00000000 ffffffbf ffeffffa
[ 163.110922] ea60 ffffffff fffffffc fdb3bffe 7f9d74ff ebfff77d dbfffbea fdf7fffe fff77eff
[ 163.125137] ea80 dcf30b00 dd12b9b0 c5acfe18 c0019acc c00eed38 b6f4d000 00000000 bf000000
[ 163.139026] eaa0 00000000 b6f4d000 beb09000 dd488000 00000018 00000003 000000d5 00860086
[ 163.153162] eac0 00000000 7eea7eea c5a3eac8 c5a3eac8 c5a3ead0 c5a3ead0 00000cc8 000071ee
[ 163.167137] eae0 00007111 00000000 00000000 000055f9 00001668 00000022 00000000 00000038
[ 163.181285]
[ 163.181285] R10: 0xdd143400:
[ 163.187985] 3400 00000000 dd143404 dd143404 00000000 00000000 00000000 00000000 00000000
[ 163.201701] 3420 00000000 00000020 00000000 0000c350 0000c350 00000000 00000000 00000000
[ 163.215345] 3440 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 163.228798] 3460 00000001 00000000 11a1140e 11b1140e 11c1140e 11d1140e 11e1140e 11f1140e
[ 163.242750] 3480 00000001 dd4e6000 00000002 40400040 00000000 00000000 00000000 00000000
[ 163.256281] 34a0 0000006f 0000006f 0000006f 00000000 c0869474 00000000 00001dc4 000899bc
[ 163.270279] 34c0 de892500 00000000 00000000 dd1434cc dd1434cc 00000000 9b0bbc12 00000025
[ 163.284201] 34e0 ed28e910 0000000d fc229349 0000000d ece75649 0000000d 000000e6 00000000
[ 163.300304] CPU: 3 PID: 212 Comm: DispSync Not tainted 3.10.0 #0
[ 163.311392] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 163.320915] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 163.330059] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 163.339282] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 163.346076] Exception stack(0xdd48fe18 to 0xdd48fe60)
[ 163.352411] fe00: c1f44cc0 dd7caa00
[ 163.360833] fe20: dd48fe60 000035f6 de8924c0 c5a3ea80 c1f44cc0 00000000 c5a3ea80 00000003
[ 163.369300] fe40: dd143480 dd48fe74 de8b4044 dd48fe60 c0061d08 c086342c 600d0013 ffffffff
[ 163.379647] [] (__irq_svc+0x40/0x70) from [] (_raw_spin_unlock_irq+0x1c/0x44)
[ 163.390625] [] (_raw_spin_unlock_irq+0x1c/0x44) from [] (finish_task_switch+0x5c/0xd4)
[ 163.400893] [] (finish_task_switch+0x5c/0xd4) from [] (__schedule+0x4a0/0x554)
[ 163.410785] [] (__schedule+0x4a0/0x554) from [] (preempt_schedule+0x3c/0x58)
[ 163.420647] [] (preempt_schedule+0x3c/0x58) from [] (futex_wake+0x10c/0x120)
[ 163.430381] [] (futex_wake+0x10c/0x120) from [] (do_futex+0xd4/0x184)
[ 163.439615] [] (do_futex+0xd4/0x184) from [] (SyS_futex+0x124/0x168)
[ 163.449308] [] (SyS_futex+0x124/0x168) from [] (ret_fast_syscall+0x0/0x30)
[ 163.456519] IPI backtrace for cpu 1
[ 163.462760]
[ 163.469298] CPU: 1 PID: 188 Comm: logd.writer Not tainted 3.10.0 #0
[ 163.476250] task: dd7c8a80 ti: dd7dc000 task.ti: dd7dc000
[ 163.483397] PC is at __do_softirq+0x78/0x2b4
[ 163.489398] LR is at msecs_to_jiffies+0x18/0x24
[ 163.496214] pc : [] lr : [] psr: 60010113
[ 163.496214] sp : dd7ddf40 ip : 00000000 fp : 0000000a
[ 163.506166] r10: b6f1fdd4 r9 : 0000005c r8 : b836eb58
[ 163.512197] r7 : 000000c7 r6 : 00000082 r5 : 00000000 r4 : dd7dc000
[ 163.518288] r3 : 00000001 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 163.525796] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 163.532658] Control: 10c5387d Table: 05bb406a DAC: 00000015
[ 163.538038]
[ 163.538038] PC: 0xc003ddd8:
[ 163.544862] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 163.560480] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 163.575549] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 163.590310] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 163.605014] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 163.619580] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 163.634137] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 163.648864] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 163.663956]
[ 163.663956] LR: 0xc003cee4:
[ 163.670464] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 163.685082] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 163.699828] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 163.714371] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 163.728906] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 163.743475] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 163.758003] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 163.772722] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 163.787648]
[ 163.787648] SP: 0xdd7ddec0:
[ 163.794104] dec0 00000007 c0013020 fed91000 dd7ddef8 c0c21484 dd7ddf2c b836eb58 0000005c
[ 163.808808] dee0 b6f1fdd4 c0008558 c003de58 60010113 ffffffff c000d600 00000001 c0e4c1c0
[ 163.823434] df00 00000000 00000001 dd7dc000 00000000 00000082 000000c7 b836eb58 0000005c
[ 163.837838] df20 b6f1fdd4 0000000a 00000000 dd7ddf40 c003cf64 c003de58 60010113 ffffffff
[ 163.852267] df40 000000c7 0000001d 0000005c 00400040 ffffcabc 00000001 00000000 60010193
[ 163.866660] df60 00000000 c0c21484 000000c7 b836eb58 0000005c b6f1fdd4 0000000a c003e150
[ 163.881131] df80 dd7dc000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dd7ddfb0 c000853c
[ 163.895535] dfa0 b6f00d1c 80010010 ffffffff c000d7bc 0000040c 00000018 00000001 00000002
[ 163.910668]
[ 163.910668] R1: 0xc0e4c140:
[ 163.917108] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 163.931023] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 163.944867] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 163.959041] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 163.973129] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 163.987044] c1e0 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 164.000778] c200 00000000 00000000 00000000 00001e3e 00000008 00000002 00000000 00000000
[ 164.014655] c220 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 164.028954]
[ 164.028954] R4: 0xdd7dbf80:
[ 164.035405] bf80 00000000 00000000 00000000 b6b3bc7c 00000000 00000000 00000000 b8f87618
[ 164.049617] bfa0 0000014f c000da00 00000000 00000000 00000006 b6b3bcf4 00000000 00000000
[ 164.064029] bfc0 00000000 00000000 b8f87618 0000014f 00000000 00000000 00000000 00000004
[ 164.077951] bfe0 b6b3bc90 b6b3bc80 b6f0fd37 b6f36ed8 600f0010 00000006 4630e7e8 f948f7fd
[ 164.092366] c000 00000002 00000102 00000000 dd7c8a80 c0c3c138 00000001 00000015 dd7c8a80
[ 164.106818] c020 c1f32cc0 dd7dc000 c5a3e700 c5a3ea80 00000001 dd143f00 dd7ddf9c dd7ddf18
[ 164.121290] c040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 164.135404] c060 b6caadd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 164.151729] CPU: 1 PID: 188 Comm: logd.writer Not tainted 3.10.0 #0
[ 164.162655] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 164.172340] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 164.181589] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 164.190954] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 164.197421] Exception stack(0xdd7ddef8 to 0xdd7ddf40)
[ 164.203677] dee0: 00000001 c0e4c1c0
[ 164.212001] df00: 00000000 00000001 dd7dc000 00000000 00000082 000000c7 b836eb58 0000005c
[ 164.220378] df20: b6f1fdd4 0000000a 00000000 dd7ddf40 c003cf64 c003de58 60010113 ffffffff
[ 164.230003] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 164.239083] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 164.247783] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 164.256863] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 164.265879] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 164.274940] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 164.281189] Exception stack(0xdd7ddfb0 to 0xdd7ddff8)
[ 164.287618] dfa0: 0000040c 00000018 00000001 00000002
[ 164.295927] dfc0: b6ca9ca4 b6ca9c8c 000003e8 000000c7 b836eb58 0000005c b6f1fdd4 0000000a
[ 164.304029] dfe0: b6ca9c80 b6ca9c48 b6f41d15 b6f00d1c 80010010 ffffffff
[ 183.736971] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 183.978062] [mmc0] – Timeout recovery procedure start –
[ 184.317381] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 184.549663] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 184.748283] [mmc0] – Timeout recovery procedure finished –
[ 184.903858] mmcblk0: error -110 sending status command, retrying
[ 210.282329] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 210.358604] [mmc0] – Timeout recovery procedure start –
[ 210.449932] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 210.506768] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 210.567691] [mmc0] – Timeout recovery procedure finished –
[ 210.625562] mmcblk0: error -110 sending status command, aborting
[ 210.885094] blk_update_request: 1 callbacks suppressed
[ 210.919676] end_request: I/O error, dev mmcblk0, sector 4323776
[ 211.008956] end_request: I/O error, dev mmcblk0, sector 4323784
[ 211.057930] end_request: I/O error, dev mmcblk0, sector 4323792
[ 211.128866] end_request: I/O error, dev mmcblk0, sector 4323800
[ 211.200215] end_request: I/O error, dev mmcblk0, sector 4323808
[ 211.246058] end_request: I/O error, dev mmcblk0, sector 4323816
[ 211.275120] end_request: I/O error, dev mmcblk0, sector 4323824
[ 211.335634] end_request: I/O error, dev mmcblk0, sector 4323832
[ 211.363794] end_request: I/O error, dev mmcblk0, sector 4323840
[ 211.404599] end_request: I/O error, dev mmcblk0, sector 4323848
[ 211.825835] Aborting journal on device mmcblk0p13-8.
[ 211.907933] EXT4-fs error (device mmcblk0p13) in ext4_reserve_inode_write:4982: Journal has aborted
[ 212.626063] EXT4-fs error (device mmcblk0p13) in ext4_da_writepages:2568: IO failure
[ 220.084865] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD18): error = -110, timeout = 8000ms
[ 220.221856] [mmc0] – Timeout recovery procedure start –
[ 220.322403] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 220.366716] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 220.418236] [mmc0] – Timeout recovery procedure finished –
[ 223.306251] INFO: rcu_preempt detected stalls on CPUs/tasks: { 0} (detected by 1, t=21030 jiffies, g=85, c=84, q=1569)
[ 223.323208] Backtrace for cpu 1 (current):
[ 223.330547] CPU: 1 PID: 847 Comm: HeapTrimmerDaem Not tainted 3.10.0 #0
[ 223.342612] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 223.352808] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 223.363245] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_other_cpu_stall+0x264/0x2e0)
[ 223.374295] [] (print_other_cpu_stall+0x264/0x2e0) from [] (__rcu_pending+0x90/0x190)
[ 223.384447] [] (__rcu_pending+0x90/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 223.395609] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 223.406746] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 223.417100] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 223.427255] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 223.438106] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 223.449836] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 223.460976] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 223.471478] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 223.481129] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 223.490754] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 223.497228] Exception stack(0xdca3bfb0 to 0xdca3bff8)
[ 223.504041] bfa0: b0d4c008 b8798a78 b5200128 00000000
[ 223.512850] bfc0: 000049db b87924b8 b502fb11 b8798a78 b42aa6b8 00012768 0000ef16 00000009
[ 223.520614] bfe0: 0001276c b42aa6b0 b50644a1 b5064492 60070030 ffffffff
[ 223.526295]
[ 223.526295] sending IPI to all other CPUs:
[ 223.534999] IPI backtrace for cpu 3
[ 223.540762]
[ 223.547240] CPU: 3 PID: 826 Comm: putmethod.latin Not tainted 3.10.0 #0
[ 223.554192] task: dcfb39c0 ti: dca34000 task.ti: dca34000
[ 223.560110] PC is at 0xb51bc880
[ 223.565137] LR is at 0xb51ba758
[ 223.571660] pc : [] lr : [] psr: 600d0010
[ 223.571660] sp : beaf46d8 ip : 00000000 fp : 01266000
[ 223.581090] r10: beb04742 r9 : 0000000a r8 : beb04217
[ 223.587045] r7 : b892a270 r6 : 00000001 r5 : b892ab50 r4 : beaf9ee5
[ 223.593305] r3 : 00000093 r2 : 01200000 r1 : b892a40c r0 : beaf92b1
[ 223.599907] Flags: nZCv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
[ 223.606472] Control: 10c5387d Table: 1cfa806a DAC: 00000015
[ 223.613487] CPU: 3 PID: 826 Comm: putmethod.latin Not tainted 3.10.0 #0
[ 223.624496] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 223.634260] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 223.643524] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 223.653089] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 223.659458] Exception stack(0xdca35fb0 to 0xdca35ff8)
[ 223.666320] 5fa0: beaf92b1 b892a40c 01200000 00000093
[ 223.674764] 5fc0: beaf9ee5 b892ab50 00000001 b892a270 beb04217 0000000a beb04742 01266000
[ 223.682408] 5fe0: 00000000 beaf46d8 b51ba758 b51bc880 600d0010 ffffffff
[ 223.688671] IPI backtrace for cpu 0
[ 223.694089]
[ 223.700338] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 223.706996] task: dc9d0a80 ti: dcf64000 task.ti: dcf64000
[ 223.713952] PC is at __do_softirq+0x78/0x2b4
[ 223.719975] LR is at msecs_to_jiffies+0x18/0x24
[ 223.727092] pc : [] lr : [] psr: 60070113
[ 223.727092] sp : dcf65e68 ip : 00000000 fp : 0000000a
[ 223.736383] r10: dcf65f7c r9 : 00000000 r8 : b6f0f000
[ 223.742534] r7 : dcf65f0c r6 : 00000002 r5 : 00000000 r4 : dcf64000
[ 223.748527] r3 : 00000000 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 223.755170] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 223.762039] Control: 10c5387d Table: 1c94406a DAC: 00000015
[ 223.767333]
[ 223.767333] PC: 0xc003ddd8:
[ 223.774157] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 223.789952] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 223.805055] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 223.819906] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 223.834802] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 223.849702] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 223.864527] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 223.879261] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 223.895586]
[ 223.895586] LR: 0xc003cee4:
[ 223.902624] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 223.917630] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 223.932424] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 223.947095] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 223.961803] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 223.976647] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 223.991419] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 224.006063] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 224.021252]
[ 224.021252] SP: 0xdcf65de8:
[ 224.027862] 5de8 00000007 c0013020 fed91000 dcf65e20 c0c21484 dcf65e54 b6f0f000 00000000
[ 224.042672] 5e08 dcf65f7c c0008558 c003de58 60070113 ffffffff c000d600 00000001 c0e4c1c0
[ 224.057331] 5e28 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c b6f0f000 00000000
[ 224.071859] 5e48 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58 60070113 ffffffff
[ 224.086251] 5e68 dcf65f0c 0000001d 00000000 00400100 ffff9116 00000000 00000000 60070193
[ 224.100715] 5e88 00000000 c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150
[ 224.115276] 5ea8 dcf64000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c
[ 224.129883] 5ec8 c00f0988 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e
[ 224.144839]
[ 224.144839] R1: 0xc0e4c140:
[ 224.151355] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 224.165161] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 224.179159] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 224.193273] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 224.207161] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 224.221200] c1e0 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 224.234908] c200 00000002 00000000 00000000 00001e41 00000008 00000002 00000000 00000000
[ 224.248838] c220 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 224.262997]
[ 224.262997] R4: 0xdcf63f80:
[ 224.269393] 3f80 00000000 00000000 00000001 00000000 00000000 a7a9e9df 000000f0 c000db84
[ 224.283890] 3fa0 00000000 c000da00 00000000 00000000 b89fd3e0 00000000 00000001 00000000
[ 224.298023] 3fc0 00000000 00000000 a7a9e9df 000000f0 00000001 b89fd3e0 b878e970 b89fcf28
[ 224.312604] 3fe0 9e9499c8 9e9499b8 b4fa56a7 b6df4964 200f0010 b89fd3e0 000000ab 0312fa12
[ 224.327241] 4000 00000002 00000102 00000000 dc9d0a80 c0c3c138 00000000 00000015 dc9d0a80
[ 224.341870] 4020 c1f29cc0 dcf64000 dd75e000 dd75f180 00000000 dcfb78c0 dcf65d74 dcf65cf0
[ 224.356461] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 224.370797] 4060 b6fa9e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 224.385160]
[ 224.385160] R7: 0xdcf65e8c:
[ 224.391796] 5e8c c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150 dcf64000
[ 224.406429] 5eac c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c c00f0988
[ 224.421062] 5ecc 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e dca0ea50
[ 224.435856] 5eec 80100073 dd75ea80 b6f0e000 b6f0f000 00000000 dcf65f7c 80100071 dcda2500
[ 224.450380] 5f0c dcf65f20 c00f0c50 c00f0988 60070013 ffffffff dd75eac0 80070013 000000af
[ 224.465152] 5f2c dd75eac0 00000000 dc4916c0 b6eed000 00000001 00000000 00000003 b6f0f000
[ 224.479417] 5f4c 00000003 dca0ea50 b6f0e000 b6f0f000 80100073 00000003 c00f0c50 80100073
[ 224.493971] 5f6c 00000000 00001000 00000002 0000201f dca0e948 00000000 00000001 00001000
[ 224.508705]
[ 224.508705] R10: 0xdcf65efc:
[ 224.515168] 5efc 00000000 dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013
[ 224.529914] 5f1c ffffffff dd75eac0 80070013 000000af dd75eac0 00000000 dc4916c0 b6eed000
[ 224.544359] 5f3c 00000001 00000000 00000003 b6f0f000 00000003 dca0ea50 b6f0e000 b6f0f000
[ 224.558940] 5f5c 80100073 00000003 c00f0c50 80100073 00000000 00001000 00000002 0000201f
[ 224.573309] 5f7c dca0e948 00000000 00000001 00001000 00000000 0000007d c000db84 dcf64000
[ 224.587942] 5f9c 00000000 b6f0e024 c000da00 00000001 00001000 b6f0e000 00001000 00000003
[ 224.602233] 5fbc b6f927b8 00000001 00001000 00000000 0000007d b6f0e000 0000000c b6f8c7bc
[ 224.616761] 5fdc b6f0e024 b6f43af5 bebc1828 b6f6a02f b6f6c13c 20070010 b6f0e000 990ae00d
[ 224.633334] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 224.643944] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 224.653719] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 224.663013] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 224.672879] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 224.679587] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 224.687429] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 224.695874] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 224.702277] 5e60: 60070113 ffffffff
[ 224.711052] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 224.720564] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 224.729430] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 224.738686] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 224.748048] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 224.757011] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 224.763407] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 224.769516] 5ec0: 00000000 dcf65f7c
[ 224.778374] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 224.786958] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 224.796827] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 224.806208] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 224.815964] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 224.823018] IPI backtrace for cpu 2
[ 224.828879]
[ 224.835609] CPU: 2 PID: 894 Comm: app_process Not tainted 3.10.0 #0
[ 224.842478] task: dcf72f40 ti: dc918000 task.ti: dc918000
[ 224.848456] PC is at 0xb6f254a0
[ 224.853543] LR is at 0xb6f21a09
[ 224.860145] pc : [] lr : [] psr: 000f0010
[ 224.860145] sp : be98a308 ip : 00000003 fp : b53c4ff4
[ 224.869605] r10: 00000b82 r9 : b5293148 r8 : b52f44d3
[ 224.875722] r7 : 0a3fda85 r6 : b529fb98 r5 : 00000ca5 r4 : b5cea934
[ 224.882027] r3 : 53390000 r2 : 5f004565 r1 : b52f44d3 r0 : b52f44d4
[ 224.888697] Flags: nzcv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
[ 224.895408] Control: 10c5387d Table: 1cefc06a DAC: 00000015
[ 224.902454] CPU: 2 PID: 894 Comm: app_process Not tainted 3.10.0 #0
[ 224.913504] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 224.923306] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 224.932686] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 224.942258] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 224.948853] Exception stack(0xdc919fb0 to 0xdc919ff8)
[ 224.956564] 9fa0: b52f44d4 b52f44d3 5f004565 53390000
[ 224.965340] 9fc0: b5cea934 00000ca5 b529fb98 0a3fda85 b52f44d3 b5293148 00000b82 b53c4ff4
[ 224.973164] 9fe0: 00000003 be98a308 b6f21a09 b6f254a0 000f0010 ffffffff
[ 245.174827] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 245.223377] [mmc0] – Timeout recovery procedure start –
[ 245.246281] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 245.311287] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 245.391938] [mmc0] – Timeout recovery procedure finished –
[ 245.430013] mmcblk0: error -110 sending status command, retrying
[ 270.199222] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 270.225495] [mmc0] – Timeout recovery procedure start –
[ 270.398174] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 270.471944] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 270.552561] [mmc0] – Timeout recovery procedure finished –
[ 270.623368] mmcblk0: error -110 sending status command, retrying
[ 285.406685] INFO: rcu_preempt detected stalls on CPUs/tasks: { 0} (detected by 1, t=27341 jiffies, g=85, c=84, q=1614)
[ 285.425025] Backtrace for cpu 1 (current):
[ 285.432173] CPU: 1 PID: 874 Comm: app_process Not tainted 3.10.0 #0
[ 285.444080] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 285.454291] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 285.465458] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_other_cpu_stall+0x264/0x2e0)
[ 285.476023] [] (print_other_cpu_stall+0x264/0x2e0) from [] (__rcu_pending+0x90/0x190)
[ 285.486061] [] (__rcu_pending+0x90/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 285.498371] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 285.509361] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 285.519824] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 285.530254] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 285.541172] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 285.553290] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 285.564193] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 285.574559] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 285.584575] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 285.593948] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 285.600569] Exception stack(0xdc98dfb0 to 0xdc98dff8)
[ 285.607772] dfa0: b6ccb934 0d209e6c b66ab62b 0000dd68
[ 285.616600] dfc0: b6ccb934 b66ab62b 00000000 0d209e6c b66ab62b b6af3148 b66a1000 b66cc9fc
[ 285.624432] dfe0: b6f0be5c be8aa2f8 b6f13e45 b6f139a8 800f0030 ffffffff
[ 285.629880]
[ 285.629880] sending IPI to all other CPUs:
[ 285.638572] IPI backtrace for cpu 0
[ 285.643923]
[ 285.650119] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 285.656540] task: dc9d0a80 ti: dcf64000 task.ti: dcf64000
[ 285.663391] PC is at __do_softirq+0x78/0x2b4
[ 285.669290] LR is at msecs_to_jiffies+0x18/0x24
[ 285.676185] pc : [] lr : [] psr: 60070113
[ 285.676185] sp : dcf65e68 ip : 00000000 fp : 0000000a
[ 285.685363] r10: dcf65f7c r9 : 00000000 r8 : b6f0f000
[ 285.691397] r7 : dcf65f0c r6 : 00000002 r5 : 00000000 r4 : dcf64000
[ 285.697477] r3 : 00000000 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 285.704019] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 285.710576] Control: 10c5387d Table: 1c94406a DAC: 00000015
[ 285.715805]
[ 285.715805] PC: 0xc003ddd8:
[ 285.722464] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 285.737838] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 285.752692] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 285.767284] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 285.781872] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 285.796452] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 285.810991] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 285.825602] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 285.840581]
[ 285.840581] LR: 0xc003cee4:
[ 285.847077] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 285.861695] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 285.876317] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 285.890935] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 285.905440] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 285.920039] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 285.934578] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 285.949095] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 285.964066]
[ 285.964066] SP: 0xdcf65de8:
[ 285.970653] 5de8 00000007 c0013020 fed91000 dcf65e20 c0c21484 dcf65e54 b6f0f000 00000000
[ 285.985211] 5e08 dcf65f7c c0008558 c003de58 60070113 ffffffff c000d600 00000001 c0e4c1c0
[ 285.999716] 5e28 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c b6f0f000 00000000
[ 286.013970] 5e48 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58 60070113 ffffffff
[ 286.028475] 5e68 dcf65f0c 0000001d 00000000 00400100 ffff9116 00000000 00000000 60070193
[ 286.042829] 5e88 00000000 c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150
[ 286.057233] 5ea8 dcf64000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c
[ 286.071644] 5ec8 c00f0988 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e
[ 286.086555]
[ 286.086555] R1: 0xc0e4c140:
[ 286.093203] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 286.107020] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 286.120803] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 286.135049] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 286.148746] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 286.162608] c1e0 00000004 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 286.176335] c200 00000002 00000000 00000000 00001e82 00000008 00000002 00000000 00000000
[ 286.190171] c220 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 286.204228]
[ 286.204228] R4: 0xdcf63f80:
[ 286.210545] 3f80 00000000 00000000 00000001 00000000 00000000 a7a9e9df 000000f0 c000db84
[ 286.224704] 3fa0 00000000 c000da00 00000000 00000000 b89fd3e0 00000000 00000001 00000000
[ 286.238777] 3fc0 00000000 00000000 a7a9e9df 000000f0 00000001 b89fd3e0 b878e970 b89fcf28
[ 286.253135] 3fe0 9e9499c8 9e9499b8 b4fa56a7 b6df4964 200f0010 b89fd3e0 000000ab 0312fa12
[ 286.267577] 4000 00000002 00000102 00000000 dc9d0a80 c0c3c138 00000000 00000015 dc9d0a80
[ 286.281774] 4020 c1f29cc0 dcf64000 dd75e000 dd75f180 00000000 dcfb78c0 dcf65d74 dcf65cf0
[ 286.296151] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 286.310156] 4060 b6fa9e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 286.324409]
[ 286.324409] R7: 0xdcf65e8c:
[ 286.330782] 5e8c c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150 dcf64000
[ 286.345253] 5eac c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c c00f0988
[ 286.359627] 5ecc 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e dca0ea50
[ 286.373978] 5eec 80100073 dd75ea80 b6f0e000 b6f0f000 00000000 dcf65f7c 80100071 dcda2500
[ 286.388370] 5f0c dcf65f20 c00f0c50 c00f0988 60070013 ffffffff dd75eac0 80070013 000000af
[ 286.402702] 5f2c dd75eac0 00000000 dc4916c0 b6eed000 00000001 00000000 00000003 b6f0f000
[ 286.416866] 5f4c 00000003 dca0ea50 b6f0e000 b6f0f000 80100073 00000003 c00f0c50 80100073
[ 286.431201] 5f6c 00000000 00001000 00000002 0000201f dca0e948 00000000 00000001 00001000
[ 286.445846]
[ 286.445846] R10: 0xdcf65efc:
[ 286.452331] 5efc 00000000 dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013
[ 286.466806] 5f1c ffffffff dd75eac0 80070013 000000af dd75eac0 00000000 dc4916c0 b6eed000
[ 286.481206] 5f3c 00000001 00000000 00000003 b6f0f000 00000003 dca0ea50 b6f0e000 b6f0f000
[ 286.495381] 5f5c 80100073 00000003 c00f0c50 80100073 00000000 00001000 00000002 0000201f
[ 286.509604] 5f7c dca0e948 00000000 00000001 00001000 00000000 0000007d c000db84 dcf64000
[ 286.523876] 5f9c 00000000 b6f0e024 c000da00 00000001 00001000 b6f0e000 00001000 00000003
[ 286.538159] 5fbc b6f927b8 00000001 00001000 00000000 0000007d b6f0e000 0000000c b6f8c7bc
[ 286.552405] 5fdc b6f0e024 b6f43af5 bebc1828 b6f6a02f b6f6c13c 20070010 b6f0e000 990ae00d
[ 286.568993] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 286.579283] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 286.588972] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 286.598176] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 286.608012] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 286.614490] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 286.622276] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 286.630627] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 286.637026] 5e60: 60070113 ffffffff
[ 286.645805] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 286.654922] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 286.663540] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 286.672650] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 286.681801] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 286.690802] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 286.697141] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 286.703175] 5ec0: 00000000 dcf65f7c
[ 286.711604] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 286.719902] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 286.729730] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 286.739126] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 286.748559] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 286.755492] IPI backtrace for cpu 2
[ 286.761327]
[ 286.767997] CPU: 2 PID: 894 Comm: app_process Not tainted 3.10.0 #0
[ 286.774757] task: dcf72f40 ti: dc918000 task.ti: dc918000
[ 286.780694] PC is at 0xb6f21e12
[ 286.785758] LR is at 0xb6f21e45
[ 286.792338] pc : [] lr : [] psr: a00f0030
[ 286.792338] sp : be98a338 ip : b6f1987c fp : b6b22430
[ 286.801628] r10: b6b01000 r9 : 000467c4 r8 : 00000002
[ 286.807858] r7 : b6cd9004 r6 : 00000000 r5 : b6b0751a r4 : b6cd9934
[ 286.814133] r3 : 00000209 r2 : b6f2f714 r1 : b6cdeec0 r0 : 00000000
[ 286.820765] Flags: NzCv IRQs on FIQs on Mode USER_32 ISA Thumb Segment user
[ 286.827371] Control: 10c5387d Table: 1cefc06a DAC: 00000015
[ 286.834222] CPU: 2 PID: 894 Comm: app_process Not tainted 3.10.0 #0
[ 286.845110] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 286.854863] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 286.864018] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 286.873440] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 286.879831] Exception stack(0xdc919fb0 to 0xdc919ff8)
[ 286.886573] 9fa0: 00000000 b6cdeec0 b6f2f714 00000209
[ 286.894938] 9fc0: b6cd9934 b6b0751a 00000000 b6cd9004 00000002 000467c4 b6b01000 b6b22430
[ 286.902612] 9fe0: b6f1987c be98a338 b6f21e45 b6f21e12 a00f0030 ffffffff
[ 286.909037] IPI backtrace for cpu 3
[ 286.914910]
[ 286.921583] CPU: 3 PID: 99 Comm: kconsole Not tainted 3.10.0 #0
[ 286.928644] task: ddee8fc0 ti: dde88000 task.ti: dde88000
[ 286.936604] PC is at console_thread+0x58/0xd4
[ 286.943179] LR is at console_thread+0x9c/0xd4
[ 286.950049] pc : [] lr : [] psr: 600d0113
[ 286.950049] sp : dde89f50 ip : dca34044 fp : 00000000
[ 286.959414] r10: 00000000 r9 : 00000000 r8 : c0e96ce4
[ 286.965464] r7 : c0e96ce4 r6 : de01e410 r5 : dde88000 r4 : c0c5a14c
[ 286.971547] r3 : 00000000 r2 : 00000005 r1 : 00000038 r0 : de01e410
[ 286.978096] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 286.984721] Control: 10c5387d Table: 1c62006a DAC: 00000015
[ 286.990026]
[ 286.990026] PC: 0xc0300414:
[ 286.996790] 0414 1affffdf e59f3008 e5930014 e8bd41f0 eaf594c1 c0e96ce4 c0dcbd0c c0c20404
[ 287.011773] 0434 c0c5a14c 00080001 e92d41f0 e1a0300d e59f70bc e3c35d7f e59f40b8 e3c5503f
[ 287.026342] 0454 e1a06000 e1a08007 e595300c e3a02001 e5832000 f57ff05b eb158825 ebf5561d
[ 287.040520] 0474 e3500000 1a000020 e595300c e5830000 f57ff05b e5d73018 e3530000 1a000011
[ 287.054536] 0494 e5963008 e5932098 e3520000 0a00000d e894000c e1520003 0a00000a e5942008
[ 287.068571] 04b4 e0033002 e0843003 e5d31014 f57ff05a e5943004 e1a00006 e2833001 e5843004
[ 287.082512] 04d4 ebffff5d eaffffea e5d83018 e3530000 0a000000 eaffffdb e5963008 e593207c
[ 287.096525] 04f4 e3120004 0afffffb eaffffd6 e3a00000 e8bd81f0 c0e96ce4 c0c5a14c e92d45f8
[ 287.110985]
[ 287.110985] LR: 0xc0300458:
[ 287.117407] 0458 e1a08007 e595300c e3a02001 e5832000 f57ff05b eb158825 ebf5561d e3500000
[ 287.131585] 0478 1a000020 e595300c e5830000 f57ff05b e5d73018 e3530000 1a000011 e5963008
[ 287.145605] 0498 e5932098 e3520000 0a00000d e894000c e1520003 0a00000a e5942008 e0033002
[ 287.159595] 04b8 e0843003 e5d31014 f57ff05a e5943004 e1a00006 e2833001 e5843004 ebffff5d
[ 287.173555] 04d8 eaffffea e5d83018 e3530000 0a000000 eaffffdb e5963008 e593207c e3120004
[ 287.187508] 04f8 0afffffb eaffffd6 e3a00000 e8bd81f0 c0e96ce4 c0c5a14c e92d45f8 e1a08002
[ 287.201483] 0518 e59f30f0 e1a0a001 e1d022fa e7934102 ebf671ad e10f5000 f10c0080 e5943078
[ 287.215461] 0538 e3530000 13a06000 1a000009 e59f30c8 e1a00004 e5933000 e3530000 0a000002
[ 287.229816]
[ 287.229816] SP: 0xdde89ed0:
[ 287.236140] 9ed0 00000007 c0013020 fed91000 dde89f08 c0c21484 dde89f3c c0e96ce4 00000000
[ 287.250284] 9ef0 00000000 c0008558 c0300494 600d0113 ffffffff c000d600 de01e410 00000038
[ 287.264282] 9f10 00000005 00000000 c0c5a14c dde88000 de01e410 c0e96ce4 c0e96ce4 00000000
[ 287.278212] 9f30 00000000 00000000 dca34044 dde89f50 c03004d8 c0300494 600d0113 ffffffff
[ 287.292070] 9f50 de873d68 00000000 de01e410 c030043c 00000000 c00561bc d9ffffef 00000000
[ 287.305850] 9f70 9dffffff de01e410 00000000 00000000 dde89f80 dde89f80 00000000 00000000
[ 287.319562] 9f90 dde89f90 dde89f90 dde89fac de873d68 c005611c 00000000 00000000 c000da98
[ 287.333450] 9fb0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.347094]
[ 287.347094] IP: 0xdca33fc4:
[ 287.353407] 3fc4 00004f4c 00004216 00004f50 00004316 00004f54 00004416 00004f58 00004516
[ 287.367258] 3fe4 00004f5c 00004616 00004f60 00004716 00004f64 00004a16 00004f68 00000000
[ 287.380910] 4004 00000002 bf000000 dcfb39c0 c0c3c138 00000003 00000015 dcfb39c0 c1f44cc0
[ 287.394862] 4024 dca34000 dd75e1c0 dd6b9340 00000003 dc9ac980 dca35f9c dca35f18 c086234c
[ 287.408830] 4044 00000000 00000000 00000000 00000000 00000000 01010000 01000000 b6f6be30
[ 287.422534] 4064 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.437002] 4084 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.450352] 40a4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.464076]
[ 287.464076] R0: 0xde01e390:
[ 287.470433] e390 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.483679] e3b0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.496898] e3d0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.510125] e3f0 00000000 00000000 00000000 00000000 de017500 de017200 c030c284 00000000
[ 287.523657] e410 00250025 ff690000 fed60000 00000000 00000000 00000000 00000000 00000000
[ 287.537365] e430 00000000 00000059 0001c200 00000020 016e3600 00000040 00020200 00000023
[ 287.551388] e450 00000000 de9ecd88 00000000 00000000 00000000 00000000 00000000 00000012
[ 287.564909] e470 00000000 00000000 00000000 00000000 00000000 c0cda240 00000000 00000000
[ 287.578639]
[ 287.578639] R4: 0xc0c5a0cc:
[ 287.585001] a0cc c0a9a62e 00000120 c02fd5dc 00000000 c0a9a63d 00000120 c02fd5a0 00000000
[ 287.599059] a0ec c0a9a645 00000120 c02fd568 00000000 c0a9a651 00000120 c02fd530 00000000
[ 287.612943] a10c c0a9a65e 00000120 c02fd4f8 00000000 c0a9a66d 00000120 c02fd4c0 00000000
[ 287.626742] a12c c0a9a675 00000120 c02fd488 00000000 c0a9a680 00000120 c02fd450 00000000
[ 287.640619] a14c 00030583 0002c31b 0007ffff 00000001 c0c5a160 2020205b 302e3020 30303030
[ 287.654534] a16c 42205d30 69746f6f 4c20676e 78756e69 206e6f20 73796870 6c616369 55504320
[ 287.668561] a18c 35783020 0a0d3030 2020205b 302e3020 30303030 49205d30 6974696e 7a696c61
[ 287.682514] a1ac 20676e69 6f726763 73207075 79736275 70632073 5b0a0d75 20202020 30302e30
[ 287.696820]
[ 287.696820] R5: 0xdde87f80:
[ 287.703178] 7f80 00000001 de030f40 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.716660] 7fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.729966] 7fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.743249] 7fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.756525] 8000 00000000 00000002 00000000 ddee8fc0 c0c3c138 00000003 00000015 ddee8fc0
[ 287.770180] 8020 c1f44cc0 dde88000 dd6b9340 dd75e1c0 00000003 dcfb39c0 dde89ef4 dde89e70
[ 287.784121] 8040 c086234c 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.797548] 8060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.811102]
[ 287.811102] R6: 0xde01e390:
[ 287.817425] e390 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.830712] e3b0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.843969] e3d0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.857215] e3f0 00000000 00000000 00000000 00000000 de017500 de017200 c030c284 00000000
[ 287.870897] e410 00250025 ff690000 fed60000 00000000 00000000 00000000 00000000 00000000
[ 287.885744] e430 00000000 00000059 0001c200 00000020 016e3600 00000040 00020200 00000023
[ 287.899708] e450 00000000 de9ecd88 00000000 00000000 00000000 00000000 00000000 00000012
[ 287.913149] e470 00000000 00000000 00000000 00000000 00000000 c0cda240 00000000 00000000
[ 287.926917]
[ 287.926917] R7: 0xc0e96c64:
[ 287.933275] 6c64 00000000 c0e96bd0 c5ac8da4 c5ac8da4 00500002 00000001 00000000 00000000
[ 287.947009] 6c84 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.960229] 6ca4 00000000 00000001 00010001 00000000 00000000 00000000 00000000 00000000
[ 287.973629] 6cc4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 287.986987] 6ce4 de01dc10 de01e010 de01e410 de01e810 00000000 ddee8fc0 00000000 ddd8d700
[ 288.000838] 6d04 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 288.014178] 6d24 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 288.027596] 6d44 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 288.041315]
[ 288.041315] R8: 0xc0e96c64:
[ 288.047733] 6c64 00000000 c0e96bd0 c5ac8da4 c5ac8da4 00500002 00000001 00000000 00000000
[ 288.061626] 6c84 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 288.074920] 6ca4 00000000 00000001 00010001 00000000 00000000 00000000 00000000 00000000
[ 288.088260] 6cc4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 288.101603] 6ce4 de01dc10 de01e010 de01e410 de01e810 00000000 ddee8fc0 00000000 ddd8d700
[ 288.115507] 6d04 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 288.128794] 6d24 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 288.142115] 6d44 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 288.157857] CPU: 3 PID: 99 Comm: kconsole Not tainted 3.10.0 #0
[ 288.168640] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 288.178299] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 288.187570] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 288.196955] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 288.203312] Exception stack(0xdde89f08 to 0xdde89f50)
[ 288.210524] 9f00: de01e410 00000038 00000005 00000000 c0c5a14c dde88000
[ 288.218701] 9f20: de01e410 c0e96ce4 c0e96ce4 00000000 00000000 00000000 dca34044 dde89f50
[ 288.225574] 9f40: c03004d8 c0300494 600d0113 ffffffff
[ 288.235033] [] (__irq_svc+0x40/0x70) from [] (console_thread+0x58/0xd4)
[ 288.245305] [] (console_thread+0x58/0xd4) from [] (kthread+0xa0/0xac)
[ 288.255464] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 295.401142] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 295.455354] [mmc0] – Timeout recovery procedure start –
[ 295.497505] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 295.563902] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 295.634127] [mmc0] – Timeout recovery procedure finished –
[ 295.683947] mmcblk0: error -110 sending status command, aborting
[ 295.940363] blk_update_request: 3 callbacks suppressed
[ 296.017852] end_request: I/O error, dev mmcblk0, sector 1062128
[ 296.054431] end_request: I/O error, dev mmcblk0, sector 1062136
[ 296.109620] end_request: I/O error, dev mmcblk0, sector 1062144
[ 296.135145] end_request: I/O error, dev mmcblk0, sector 1062152
[ 296.184928] end_request: I/O error, dev mmcblk0, sector 1062160
[ 296.236031] end_request: I/O error, dev mmcblk0, sector 1062168
[ 296.291953] end_request: I/O error, dev mmcblk0, sector 1062176
[ 296.383406] end_request: I/O error, dev mmcblk0, sector 1062184
[ 296.442727] end_request: I/O error, dev mmcblk0, sector 1062192
[ 296.469226] end_request: I/O error, dev mmcblk0, sector 1062200
[ 304.629889] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD18): error = -110, timeout = 8000ms
[ 304.708908] [mmc0] – Timeout recovery procedure start –
[ 304.767467] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 304.803049] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 304.845267] [mmc0] – Timeout recovery procedure finished –
[ 329.524595] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 329.570386] [mmc0] – Timeout recovery procedure start –
[ 329.614709] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 329.668876] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 329.730608] [mmc0] – Timeout recovery procedure finished –
[ 329.787110] mmcblk0: error -110 sending status command, retrying
[ 347.448106] INFO: rcu_preempt detected stalls on CPUs/tasks: { 0} (detected by 3, t=33646 jiffies, g=85, c=84, q=1741)
[ 347.465871] Backtrace for cpu 3 (current):
[ 347.473150] CPU: 3 PID: 726 Comm: ndroid.systemui Not tainted 3.10.0 #0
[ 347.485279] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 347.495344] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 347.506044] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_other_cpu_stall+0x264/0x2e0)
[ 347.516429] [] (print_other_cpu_stall+0x264/0x2e0) from [] (__rcu_pending+0x90/0x190)
[ 347.526633] [] (__rcu_pending+0x90/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 347.537427] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 347.548203] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 347.558471] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 347.568761] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 347.579679] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 347.591267] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 347.602125] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 347.612641] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 347.622229] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 347.631417] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 347.637926] Exception stack(0xdcef7ea8 to 0xdcef7ef0)
[ 347.645494] 7ea0: c1f44cc0 dc89e900 dcef7ef0 0000db3a dd7caa00 00000000
[ 347.654209] 7ec0: c1f44cc0 00000001 dd75efc0 00000003 dcf75e80 dcef7f04 dd48e044 dcef7ef0
[ 347.661281] 7ee0: c0061d08 c086342c 600d0013 ffffffff
[ 347.672361] [] (__irq_svc+0x40/0x70) from [] (_raw_spin_unlock_irq+0x1c/0x44)
[ 347.683374] [] (_raw_spin_unlock_irq+0x1c/0x44) from [] (finish_task_switch+0x5c/0xd4)
[ 347.694145] [] (finish_task_switch+0x5c/0xd4) from [] (__schedule+0x4a0/0x554)
[ 347.704511] [] (__schedule+0x4a0/0x554) from [] (sys_sched_yield+0x74/0x80)
[ 347.714989] [] (sys_sched_yield+0x74/0x80) from [] (ret_fast_syscall+0x0/0x30)
[ 347.720855]
[ 347.720855] sending IPI to all other CPUs:
[ 347.729472] IPI backtrace for cpu 2
[ 347.735499]
[ 347.742116] CPU: 2 PID: 440 Comm: surfaceflinger Not tainted 3.10.0 #0
[ 347.748902] task: dd140540 ti: dd4a4000 task.ti: dd4a4000
[ 347.756584] PC is at binder_ioctl+0x330/0x5d0
[ 347.762171] LR is at 0xb73cc088
[ 347.768754] pc : [] lr : [] psr: 600e0013
[ 347.768754] sp : dd4a5f28 ip : 00000008 fp : 00007205
[ 347.778206] r10: dd581a80 r9 : dd4a4000 r8 : dd0abc00
[ 347.784248] r7 : 00000000 r6 : b261bb50 r5 : c5ab5000 r4 : c0186201
[ 347.790271] r3 : 00000000 r2 : 00000000 r1 : dd4a5f00 r0 : 00000000
[ 347.796828] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 347.803385] Control: 10c5387d Table: 1d48806a DAC: 00000015
[ 347.808720]
[ 347.808720] PC: 0xc062baf8:
[ 347.815555] baf8 e59f3304 e1540003 0a00002a e59f32fc e1540003 1a000033 e1a0000a e1a01004
[ 347.830482] bb18 e1a02006 e1a03005 ebfffe7c ea000012 e1a0100d e3c13d7f e3c3303f e2880d05
[ 347.844991] bb38 e5933008 e2962004 30d22003 33a03000 e3530000 1a000003 e1a01006 e3a02004
[ 347.859229] bb58 ebf12b24 ea00001b e3a01004 ebf13485 ea00001c e1a0000a ebffe97b e1a07000
[ 347.873351] bb78 ea000019 e59f3288 e5933024 e3130c01 0a000003 e59f027c e5981018 e5952010
[ 347.887435] bb98 eb086cc8 e1a00008 e1a01005 ebfff018 e3a07000 ea00000f e1a0200d e3c23d7f
[ 347.901466] bbb8 e3c3303f e3a02007 e1a00006 e5931008 e2411001 ebf134a8 e3500000 01a07000
[ 347.915554] bbd8 13e07015 ea000000 e3e07015 e5953014 e3c33020 e5853014 e59f21ec e5923040
[ 347.930130]
[ 347.930130] SP: 0xdd4a5ea8:
[ 347.936695] 5ea8 00000007 c0013020 fed91000 dd4a5ee0 c0c21484 dd4a5f14 dd0abc00 dd4a4000
[ 347.950896] 5ec8 dd581a80 c0008558 c062bb78 600e0013 ffffffff c000d600 00000000 dd4a5f00
[ 347.965029] 5ee8 00000000 00000000 c0186201 c5ab5000 b261bb50 00000000 dd0abc00 dd4a4000
[ 347.979026] 5f08 dd581a80 00007205 00000008 dd4a5f28 b73cc088 c062bb78 600e0013 ffffffff
[ 347.993125] 5f28 00000001 dd4a4000 00000000 c023b5d0 00006201 dd4a5f50 b73cbe60 ddf22550
[ 348.007134] 5f48 b261bb50 00000003 b261bb50 c0186201 00000003 dd4a4000 00000000 c011a810
[ 348.021147] 5f68 dd581a80 00000003 c0186201 dd581a80 00000001 c011a890 00000003 00000001
[ 348.034998] 5f88 b261bb50 b73cbe90 b73cbec0 b73cbe60 00000036 c000db84 00000000 c000da00
[ 348.049537]
[ 348.049537] R1: 0xdd4a5e80:
[ 348.056180] 5e80 c0ae6ffe dd4a5e9c 00000001 dd4a5e9c dd4a5ee0 c000ea28 dd4a5ee0 00000000
[ 348.070185] 5ea0 00000002 c000ea30 00000007 c0013020 fed91000 dd4a5ee0 c0c21484 dd4a5f14
[ 348.084175] 5ec0 dd0abc00 dd4a4000 dd581a80 c0008558 c062bb78 600e0013 ffffffff c000d600
[ 348.098286] 5ee0 00000000 dd4a5f00 00000000 00000000 c0186201 c5ab5000 b261bb50 00000000
[ 348.112107] 5f00 dd0abc00 dd4a4000 dd581a80 00007205 00000008 dd4a5f28 b73cc088 c062bb78
[ 348.126067] 5f20 600e0013 ffffffff 00000001 dd4a4000 00000000 c023b5d0 00006201 dd4a5f50
[ 348.139970] 5f40 b73cbe60 ddf22550 b261bb50 00000003 b261bb50 c0186201 00000003 dd4a4000
[ 348.153829] 5f60 00000000 c011a810 dd581a80 00000003 c0186201 dd581a80 00000001 c011a890
[ 348.168026]
[ 348.168026] R4: 0xc0186181:
[ 348.174346] 6180 e5902234 e58d1020 ea000000 e1a0200c e3520008 0a00000d e2820001 f57ff05b
[ 348.188558] 61a0 e58d3014 e59d3020 e193cf9f e3a0e000 e13c0002 0183ef90 e35e0000 1afffff8
[ 348.202754] 61c0 e59d3014 f57ff05b e15c0002 1affffee e1a00003 eb1b7399 e59d0024 e59d1028
[ 348.216865] 61e0 eb03c8ee e3a02001 e599001c e211317e 42433001 41e03d83 41e03da3 42833001
[ 348.230878] 6200 e1a03312 e3510000 e281201f b1a01002 e1a012c1 e7902101 e1120003 e1c2c003
[ 348.244913] 6220 e780c101 03a03000 13a03001 e2232001 e3550000 13822001 e3520000 0a000009
[ 348.259046] 6240 e5942260 e59d101c e5920138 e58d3018 e0800301 eb1b744c e59d3018 e3530000
[ 348.273043] 6260 0a00005d ea000053 e59d202c e1a01007 e1a00004 e2025a0f e2453901 e2735000
[ 348.287105] 6280 e0a55003 eb0069e7 e1a01007 e2802001 e1a00004 eb006a17 e3550000 0a00000d
[ 348.301520]
[ 348.301520] R5: 0xc5ab4f80:
[ 348.307896] 4f80 75636573 79746972 6c65732e 78756e69 ffbfff00 fffdffbf fffbffff deffdfff
[ 348.322067] 4fa0 77ff7fff ffff3fff ffffecbf 5ff6fefe dd5ff79c fffffffd fefffffe ffffbdff
[ 348.336117] 4fc0 00000001 00000000 c5aef680 c0acacdc c5aef1d0 00000000 00000000 00000000
[ 348.349780] 4fe0 00000000 4b4554b8 c0d270d4 00000000 00000000 81240002 00003f24 00000000
[ 348.363541] 5000 dd0abc00 00000001 dd77bf04 dd060804 000001b8 00000000 00000000 c5ab501c
[ 348.377380] 5020 c5ab501c 00007201 00007201 01300130 c5ab5030 c5ab5030 00000000 00000000
[ 348.391367] 5040 00000000 0000004c 00000000 00000000 000001e7 00000000 00000000 00000000
[ 348.404819] 5060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 348.418448]
[ 348.418448] R8: 0xdd0abb80:
[ 348.424761] bb80 c1d7f420 00000000 00001000 759a1000 c1d7f440 00000000 00001000 759a2000
[ 348.438683] bba0 c1d7f460 00000000 00001000 759a3000 c1d7f480 00000000 00001000 759a4000
[ 348.452602] bbc0 c1d7f4a0 00000000 00001000 759a5000 c1d7f4c2 00000000 00001000 759a6000
[ 348.466524] bbe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 348.479774] bc00 dd0aae00 dd0aa200 c5ab5004 dd7c6d10 dd25ae44 dcc3a1d0 000000a2 dd12b948
[ 348.493771] bc20 c5a3ea80 ddeee3c0 ddfb3800 00000000 00000000 00000000 e4b00000 d2002000
[ 348.507577] bc40 e4b00000 e4b000d8 e4b000e0 e4b00008 0007f000 c5bc7400 000fe000 00000000
[ 348.521657] bc60 dd0abc60 dd0abc60 06700670 dd751e84 dd48de84 00000000 00000000 00000195
[ 348.535911]
[ 348.535911] R9: 0xdd4a3f80:
[ 348.542186] 3f80 a8671721 89a58899 5eb52191 8ea93845 b301f0eb 47af2bed 573a69df 294b973a
[ 348.556251] 3fa0 fbf388af 67fb95cb 9ef25dac 41be3a49 62bfaa4f 15b6dc66 0abe6b57 6c37b8a9
[ 348.570335] 3fc0 3ad855f2 f77d3955 7c4e75e1 4caf9547 d9f64d10 65733beb d49a537f 15a9eb0d
[ 348.584393] 3fe0 d69227b2 e48eea6c 392d70d3 f3e2c9f2 e78d99e3 df9ca52d d23adeb4 55c6fe24
[ 348.598439] 4000 00000000 00000002 00000000 dd140540 c0c3c138 00000002 00000015 dd140540
[ 348.612185] 4020 c1f3bcc0 dd4a4000 c5a3ea80 c5a3ea80 00000002 dd1424c0 dd4a5c9c dd4a5c18
[ 348.626228] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 348.639853] 4060 b261bdd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 348.653674]
[ 348.653674] R10: 0xdd581a00:
[ 348.660099] 1a00 00000000 00000000 00000000 00000000 c5a81100 00000000 00000000 00000000
[ 348.673556] 1a20 00000000 00000200 00000000 00000000 00000034 00000000 00000000 00000000
[ 348.686985] 1a40 dd60fb00 00000000 dd581a48 dd581a48 dd581a50 dd581a50 dd8b7974 00000000
[ 348.700930] 1a60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 348.714244] 1a80 dd581840 dd270000 ddf22550 de7f76e8 c5ae9288 c08f0580 00000000 00000002
[ 348.728128] 1aa0 00000007 00020002 0000001f 00000000 00000000 00000000 00000000 00000000
[ 348.741607] 1ac0 00000000 00000000 00000000 00000000 c5a81100 00000000 00000000 00000000
[ 348.754999] 1ae0 00000000 00000000 00000000 00000000 ffffffff ffffffff 00000000 00000000
[ 348.770930] CPU: 2 PID: 440 Comm: surfaceflinger Not tainted 3.10.0 #0
[ 348.781705] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 348.791311] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 348.800635] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 348.810039] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 348.816588] Exception stack(0xdd4a5ee0 to 0xdd4a5f28)
[ 348.824412] 5ee0: 00000000 dd4a5f00 00000000 00000000 c0186201 c5ab5000 b261bb50 00000000
[ 348.832875] 5f00: dd0abc00 dd4a4000 dd581a80 00007205 00000008 dd4a5f28 b73cc088 c062bb78
[ 348.839214] 5f20: 600e0013 ffffffff
[ 348.848460] [] (__irq_svc+0x40/0x70) from [] (binder_ioctl+0x330/0x5d0)
[ 348.858449] [] (binder_ioctl+0x330/0x5d0) from [] (do_vfs_ioctl+0x210/0x240)
[ 348.867458] [] (do_vfs_ioctl+0x210/0x240) from [] (SyS_ioctl+0x50/0x6c)
[ 348.876992] [] (SyS_ioctl+0x50/0x6c) from [] (ret_fast_syscall+0x0/0x30)
[ 348.883816] IPI backtrace for cpu 0
[ 348.889204]
[ 348.895438] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 348.901987] task: dc9d0a80 ti: dcf64000 task.ti: dcf64000
[ 348.909067] PC is at __do_softirq+0x78/0x2b4
[ 348.915034] LR is at msecs_to_jiffies+0x18/0x24
[ 348.921925] pc : [] lr : [] psr: 60070113
[ 348.921925] sp : dcf65e68 ip : 00000000 fp : 0000000a
[ 348.931257] r10: dcf65f7c r9 : 00000000 r8 : b6f0f000
[ 348.937224] r7 : dcf65f0c r6 : 00000002 r5 : 00000000 r4 : dcf64000
[ 348.943281] r3 : 00000000 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 348.950214] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 348.956854] Control: 10c5387d Table: 1c94406a DAC: 00000015
[ 348.962125]
[ 348.962125] PC: 0xc003ddd8:
[ 348.968994] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 348.984522] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 348.999651] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 349.014634] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 349.029699] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 349.044674] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 349.059604] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 349.074778] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 349.090205]
[ 349.090205] LR: 0xc003cee4:
[ 349.096969] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 349.111801] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 349.126708] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 349.141526] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 349.156373] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 349.170900] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 349.185338] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 349.199877] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 349.214762]
[ 349.214762] SP: 0xdcf65de8:
[ 349.221093] 5de8 00000007 c0013020 fed91000 dcf65e20 c0c21484 dcf65e54 b6f0f000 00000000
[ 349.235583] 5e08 dcf65f7c c0008558 c003de58 60070113 ffffffff c000d600 00000001 c0e4c1c0
[ 349.250070] 5e28 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c b6f0f000 00000000
[ 349.264316] 5e48 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58 60070113 ffffffff
[ 349.278764] 5e68 dcf65f0c 0000001d 00000000 00400100 ffff9116 00000000 00000000 60070193
[ 349.293100] 5e88 00000000 c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150
[ 349.307526] 5ea8 dcf64000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c
[ 349.321945] 5ec8 c00f0988 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e
[ 349.336702]
[ 349.336702] R1: 0xc0e4c140:
[ 349.343060] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 349.356806] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 349.370469] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 349.384696] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 349.398366] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 349.412382] c1e0 00000005 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 349.426064] c200 00000000 00000000 00000000 00001ecb 00000008 00000002 00000000 00000000
[ 349.439893] c220 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 349.454063]
[ 349.454063] R4: 0xdcf63f80:
[ 349.460421] 3f80 00000000 00000000 00000001 00000000 00000000 a7a9e9df 000000f0 c000db84
[ 349.474580] 3fa0 00000000 c000da00 00000000 00000000 b89fd3e0 00000000 00000001 00000000
[ 349.488612] 3fc0 00000000 00000000 a7a9e9df 000000f0 00000001 b89fd3e0 b878e970 b89fcf28
[ 349.502812] 3fe0 9e9499c8 9e9499b8 b4fa56a7 b6df4964 200f0010 b89fd3e0 000000ab 0312fa12
[ 349.517246] 4000 00000002 00000102 00000000 dc9d0a80 c0c3c138 00000000 00000015 dc9d0a80
[ 349.531454] 4020 c1f29cc0 dcf64000 dd75e000 dd75f180 00000000 dcfb78c0 dcf65d74 dcf65cf0
[ 349.545858] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 349.559949] 4060 b6fa9e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 349.574439]
[ 349.574439] R7: 0xdcf65e8c:
[ 349.580820] 5e8c c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150 dcf64000
[ 349.595321] 5eac c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c c00f0988
[ 349.609751] 5ecc 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e dca0ea50
[ 349.624125] 5eec 80100073 dd75ea80 b6f0e000 b6f0f000 00000000 dcf65f7c 80100071 dcda2500
[ 349.638510] 5f0c dcf65f20 c00f0c50 c00f0988 60070013 ffffffff dd75eac0 80070013 000000af
[ 349.652943] 5f2c dd75eac0 00000000 dc4916c0 b6eed000 00000001 00000000 00000003 b6f0f000
[ 349.667133] 5f4c 00000003 dca0ea50 b6f0e000 b6f0f000 80100073 00000003 c00f0c50 80100073
[ 349.681454] 5f6c 00000000 00001000 00000002 0000201f dca0e948 00000000 00000001 00001000
[ 349.696053]
[ 349.696053] R10: 0xdcf65efc:
[ 349.702482] 5efc 00000000 dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013
[ 349.717010] 5f1c ffffffff dd75eac0 80070013 000000af dd75eac0 00000000 dc4916c0 b6eed000
[ 349.731353] 5f3c 00000001 00000000 00000003 b6f0f000 00000003 dca0ea50 b6f0e000 b6f0f000
[ 349.745524] 5f5c 80100073 00000003 c00f0c50 80100073 00000000 00001000 00000002 0000201f
[ 349.759751] 5f7c dca0e948 00000000 00000001 00001000 00000000 0000007d c000db84 dcf64000
[ 349.774023] 5f9c 00000000 b6f0e024 c000da00 00000001 00001000 b6f0e000 00001000 00000003
[ 349.788276] 5fbc b6f927b8 00000001 00001000 00000000 0000007d b6f0e000 0000000c b6f8c7bc
[ 349.802424] 5fdc b6f0e024 b6f43af5 bebc1828 b6f6a02f b6f6c13c 20070010 b6f0e000 990ae00d
[ 349.819049] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 349.829295] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 349.838826] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 349.848026] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 349.857734] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 349.864212] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 349.871931] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 349.880266] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 349.886650] 5e60: 60070113 ffffffff
[ 349.895316] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 349.904531] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 349.913224] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 349.922289] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 349.931421] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 349.940294] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 349.946660] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 349.952765] 5ec0: 00000000 dcf65f7c
[ 349.961168] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 349.969613] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 349.979268] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 349.988709] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 349.998172] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 350.005263] IPI backtrace for cpu 1
[ 350.011170]
[ 350.017971] CPU: 1 PID: 874 Comm: app_process Not tainted 3.10.0 #0
[ 350.024829] task: dcfb78c0 ti: dc98c000 task.ti: dc98c000
[ 350.031953] PC is at __do_softirq+0x78/0x2b4
[ 350.037999] LR is at msecs_to_jiffies+0x18/0x24
[ 350.044974] pc : [] lr : [] psr: 600b0113
[ 350.044974] sp : dc98df40 ip : 00000000 fp : 0000000a
[ 350.054177] r10: b66a1000 r9 : 0008c464 r8 : 00000002
[ 350.060054] r7 : b5e65d24 r6 : 00000082 r5 : 00000000 r4 : dc98c000
[ 350.066103] r3 : 00000001 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 350.072642] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 350.079191] Control: 10c5387d Table: 1cfa006a DAC: 00000015
[ 350.084459]
[ 350.084459] PC: 0xc003ddd8:
[ 350.091200] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 350.106652] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 350.121643] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 350.136302] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 350.150852] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 350.165361] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 350.179998] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 350.194458] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 350.209373]
[ 350.209373] LR: 0xc003cee4:
[ 350.215915] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 350.230491] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 350.244921] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 350.259318] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 350.273744] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 350.288151] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 350.302551] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 350.317007] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 350.331870]
[ 350.331870] SP: 0xdc98dec0:
[ 350.338318] dec0 00000007 c0013020 fed91000 dc98def8 c0c21484 dc98df2c 00000002 0008c464
[ 350.352890] dee0 b66a1000 c0008558 c003de58 600b0113 ffffffff c000d600 00000001 c0e4c1c0
[ 350.367493] df00 00000000 00000001 dc98c000 00000000 00000082 b5e65d24 00000002 0008c464
[ 350.381668] df20 b66a1000 0000000a 00000000 dc98df40 c003cf64 c003de58 600b0113 ffffffff
[ 350.396064] df40 b5e65d24 0000001d 0008c464 00400000 000014b6 00000001 00000000 600b0193
[ 350.410498] df60 00000000 c0c21484 b5e65d24 00000002 0008c464 b66a1000 b66d407c c003e150
[ 350.424909] df80 dc98c000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dc98dfb0 c000853c
[ 350.439294] dfa0 b6f13e44 800b0030 ffffffff c000d7bc 00000000 00000001 b6f21714 00000012
[ 350.454039]
[ 350.454039] R1: 0xc0e4c140:
[ 350.460532] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 350.474361] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 350.488028] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 350.502104] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 350.515729] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 350.529656] c1e0 00000005 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 350.543273] c200 00000000 00000000 00000000 00001ecb 00000008 00000002 00000000 00000000
[ 350.557388] c220 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 350.571622]
[ 350.571622] R4: 0xdc98bf80:
[ 350.578074] bf80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 350.591914] bfa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 350.605637] bfc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 350.619281] bfe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 350.632993] c000 00000002 00000102 00000000 dcfb78c0 c0c3c138 00000001 00000015 dcfb78c0
[ 350.647250] c020 c1f32cc0 dc98c000 dd75f180 00000000 00000050 de894980 dc98df9c dc98df18
[ 350.661698] c040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 350.675696] c060 b6f21e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 350.691769] CPU: 1 PID: 874 Comm: app_process Not tainted 3.10.0 #0
[ 350.702349] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 350.711936] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 350.721144] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 350.730818] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 350.737356] Exception stack(0xdc98def8 to 0xdc98df40)
[ 350.743680] dee0: 00000001 c0e4c1c0
[ 350.752132] df00: 00000000 00000001 dc98c000 00000000 00000082 b5e65d24 00000002 0008c464
[ 350.760531] df20: b66a1000 0000000a 00000000 dc98df40 c003cf64 c003de58 600b0113 ffffffff
[ 350.770231] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 350.779405] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 350.788075] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 350.797212] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 350.806344] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 350.815382] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 350.821605] Exception stack(0xdc98dfb0 to 0xdc98dff8)
[ 350.828158] dfa0: 00000000 00000001 b6f21714 00000012
[ 350.836591] dfc0: b68eb7e4 b66ab63e 00000000 b5e65d24 00000002 0008c464 b66a1000 b66d407c
[ 350.844532] dfe0: 00ff0000 be8aa328 b6f13a09 b6f13e44 800b0030 ffffffff
[ 354.441650] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 354.524334] [mmc0] – Timeout recovery procedure start –
[ 354.568932] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 354.595093] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 354.684966] [mmc0] – Timeout recovery procedure finished –
[ 354.751758] mmcblk0: error -110 sending status command, retrying
[ 379.484287] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 379.853789] [mmc0] – Timeout recovery procedure start –
[ 380.113874] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 380.267502] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 380.456689] [mmc0] – Timeout recovery procedure finished –
[ 380.584619] mmcblk0: error -110 sending status command, aborting
[ 380.841463] blk_update_request: 22 callbacks suppressed
[ 380.888017] end_request: I/O error, dev mmcblk0, sector 1062384
[ 380.965498] end_request: I/O error, dev mmcblk0, sector 1062392
[ 381.045081] end_request: I/O error, dev mmcblk0, sector 1062400
[ 381.094375] end_request: I/O error, dev mmcblk0, sector 1062408
[ 389.746270] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD18): error = -110, timeout = 8000ms
[ 390.413781] [mmc0] – Timeout recovery procedure start –
[ 390.798266] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 390.954897] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 391.114270] [mmc0] – Timeout recovery procedure finished –
[ 409.503672] INFO: rcu_preempt detected stalls on CPUs/tasks: { 0} (detected by 1, t=39952 jiffies, g=85, c=84, q=2140)
[ 409.521207] Backtrace for cpu 1 (current):
[ 409.528441] CPU: 1 PID: 188 Comm: logd.writer Not tainted 3.10.0 #0
[ 409.540687] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 409.550970] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 409.561835] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_other_cpu_stall+0x264/0x2e0)
[ 409.572536] [] (print_other_cpu_stall+0x264/0x2e0) from [] (__rcu_pending+0x90/0x190)
[ 409.582657] [] (__rcu_pending+0x90/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 409.593609] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 409.604347] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 409.615107] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 409.625375] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 409.636444] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 409.648235] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 409.659224] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 409.669740] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 409.679305] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 409.688573] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 409.694942] Exception stack(0xdd7ddfb0 to 0xdd7ddff8)
[ 409.701807] dfa0: 00000000 00000000 000004f3 b6caa7a8
[ 409.710778] dfc0: b6ca9ca4 b6ca9c60 b6ca9c70 b6ca9c80 b836eb58 b836ebb0 b6f1fdd4 0000000a
[ 409.718561] dfe0: 00000004 b6ca9c44 b6f41caf b6ed6c50 200f0010 ffffffff
[ 409.724129]
[ 409.724129] sending IPI to all other CPUs:
[ 409.734051] IPI backtrace for cpu 0
[ 409.738973]
[ 409.744996] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 409.751297] task: dc9d0a80 ti: dcf64000 task.ti: dcf64000
[ 409.757850] PC is at __do_softirq+0x78/0x2b4
[ 409.763674] LR is at msecs_to_jiffies+0x18/0x24
[ 409.770528] pc : [] lr : [] psr: 60070113
[ 409.770528] sp : dcf65e68 ip : 00000000 fp : 0000000a
[ 409.779856] r10: dcf65f7c r9 : 00000000 r8 : b6f0f000
[ 409.785864] r7 : dcf65f0c r6 : 00000002 r5 : 00000000 r4 : dcf64000
[ 409.791895] r3 : 00000000 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 409.798336] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 409.804844] Control: 10c5387d Table: 1c94406a DAC: 00000015
[ 409.810141]
[ 409.810141] PC: 0xc003ddd8:
[ 409.816788] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 409.831963] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 409.846603] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 409.861124] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 409.875599] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 409.890066] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 409.904492] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 409.918990] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 409.933988]
[ 409.933988] LR: 0xc003cee4:
[ 409.940417] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 409.955042] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 409.969668] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 409.984169] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 409.998735] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 410.013247] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 410.027783] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 410.042220] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 410.057131]
[ 410.057131] SP: 0xdcf65de8:
[ 410.063523] 5de8 00000007 c0013020 fed91000 dcf65e20 c0c21484 dcf65e54 b6f0f000 00000000
[ 410.077990] 5e08 dcf65f7c c0008558 c003de58 60070113 ffffffff c000d600 00000001 c0e4c1c0
[ 410.092394] 5e28 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c b6f0f000 00000000
[ 410.106576] 5e48 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58 60070113 ffffffff
[ 410.120904] 5e68 dcf65f0c 0000001d 00000000 00400100 ffff9116 00000000 00000000 60070193
[ 410.135184] 5e88 00000000 c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150
[ 410.149520] 5ea8 dcf64000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c
[ 410.163946] 5ec8 c00f0988 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e
[ 410.178669]
[ 410.178669] R1: 0xc0e4c140:
[ 410.185042] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 410.198848] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 410.212594] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 410.226666] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 410.240401] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 410.254316] c1e0 00000006 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 410.268058] c200 00000002 00000000 00000000 00001f53 00000008 00000002 00000000 00000000
[ 410.281830] c220 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 410.295989]
[ 410.295989] R4: 0xdcf63f80:
[ 410.302283] 3f80 00000000 00000000 00000001 00000000 00000000 a7a9e9df 000000f0 c000db84
[ 410.316261] 3fa0 00000000 c000da00 00000000 00000000 b89fd3e0 00000000 00000001 00000000
[ 410.330184] 3fc0 00000000 00000000 a7a9e9df 000000f0 00000001 b89fd3e0 b878e970 b89fcf28
[ 410.344381] 3fe0 9e9499c8 9e9499b8 b4fa56a7 b6df4964 200f0010 b89fd3e0 000000ab 0312fa12
[ 410.358837] 4000 00000002 00000102 00000000 dc9d0a80 c0c3c138 00000000 00000015 dc9d0a80
[ 410.373011] 4020 c1f29cc0 dcf64000 dd75e000 dd75f180 00000000 dcfb78c0 dcf65d74 dcf65cf0
[ 410.387321] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 410.401243] 4060 b6fa9e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 410.415485]
[ 410.415485] R7: 0xdcf65e8c:
[ 410.421730] 5e8c c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150 dcf64000
[ 410.436187] 5eac c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c c00f0988
[ 410.450530] 5ecc 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e dca0ea50
[ 410.464828] 5eec 80100073 dd75ea80 b6f0e000 b6f0f000 00000000 dcf65f7c 80100071 dcda2500
[ 410.479179] 5f0c dcf65f20 c00f0c50 c00f0988 60070013 ffffffff dd75eac0 80070013 000000af
[ 410.493564] 5f2c dd75eac0 00000000 dc4916c0 b6eed000 00000001 00000000 00000003 b6f0f000
[ 410.507701] 5f4c 00000003 dca0ea50 b6f0e000 b6f0f000 80100073 00000003 c00f0c50 80100073
[ 410.521958] 5f6c 00000000 00001000 00000002 0000201f dca0e948 00000000 00000001 00001000
[ 410.536572]
[ 410.536572] R10: 0xdcf65efc:
[ 410.542904] 5efc 00000000 dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013
[ 410.557386] 5f1c ffffffff dd75eac0 80070013 000000af dd75eac0 00000000 dc4916c0 b6eed000
[ 410.571797] 5f3c 00000001 00000000 00000003 b6f0f000 00000003 dca0ea50 b6f0e000 b6f0f000
[ 410.585998] 5f5c 80100073 00000003 c00f0c50 80100073 00000000 00001000 00000002 0000201f
[ 410.600232] 5f7c dca0e948 00000000 00000001 00001000 00000000 0000007d c000db84 dcf64000
[ 410.614584] 5f9c 00000000 b6f0e024 c000da00 00000001 00001000 b6f0e000 00001000 00000003
[ 410.628833] 5fbc b6f927b8 00000001 00001000 00000000 0000007d b6f0e000 0000000c b6f8c7bc
[ 410.643113] 5fdc b6f0e024 b6f43af5 bebc1828 b6f6a02f b6f6c13c 20070010 b6f0e000 990ae00d
[ 410.659723] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 410.669747] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 410.679289] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 410.688267] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 410.697546] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 410.703912] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 410.711552] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 410.719887] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 410.726248] 5e60: 60070113 ffffffff
[ 410.734862] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 410.743870] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 410.752582] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 410.761654] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 410.770745] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 410.779712] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 410.785980] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 410.791995] 5ec0: 00000000 dcf65f7c
[ 410.800327] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 410.808662] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 410.818291] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 410.827608] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 410.837018] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 410.843827] IPI backtrace for cpu 3
[ 410.849742]
[ 410.856539] CPU: 3 PID: 99 Comm: kconsole Not tainted 3.10.0 #0
[ 410.863536] task: ddee8fc0 ti: dde88000 task.ti: dde88000
[ 410.870766] PC is at __do_softirq+0x78/0x2b4
[ 410.876910] LR is at msecs_to_jiffies+0x18/0x24
[ 410.883880] pc : [] lr : [] psr: 600e0113
[ 410.883880] sp : dde89e98 ip : 00000000 fp : 0000000a
[ 410.893276] r10: 00000000 r9 : 00000000 r8 : c0e96ce4
[ 410.899295] r7 : dde89f3c r6 : 00000002 r5 : 00000000 r4 : dde88000
[ 410.905386] r3 : 00000003 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 410.911988] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 410.918699] Control: 10c5387d Table: 1c62006a DAC: 00000015
[ 410.924113]
[ 410.924113] PC: 0xc003ddd8:
[ 410.931016] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 410.946706] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 410.961636] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 410.976370] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 410.990996] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 411.005610] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 411.020258] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 411.035004] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 411.050107]
[ 411.050107] LR: 0xc003cee4:
[ 411.056716] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 411.071440] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 411.086020] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 411.100623] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 411.115241] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 411.129896] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 411.144375] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 411.158922] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 411.173938]
[ 411.173938] SP: 0xdde89e18:
[ 411.180334] 9e18 00000007 c0013020 fed91000 dde89e50 c0c21484 dde89e84 c0e96ce4 00000000
[ 411.194963] 9e38 00000000 c0008558 c003de58 600e0113 ffffffff c000d600 00000001 c0e4c1c0
[ 411.209438] 9e58 00000000 00000003 dde88000 00000000 00000002 dde89f3c c0e96ce4 00000000
[ 411.223646] 9e78 00000000 0000000a 00000000 dde89e98 c003cf64 c003de58 600e0113 ffffffff
[ 411.237978] 9e98 dde89f3c 0000001d 00000000 00208040 00002d2e 00000003 00000000 600e0193
[ 411.252423] 9eb8 00000000 c0c21484 dde89f3c c0e96ce4 00000000 00000000 00000000 c003e150
[ 411.266703] 9ed8 dde88000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dde89f08 c000853c
[ 411.281174] 9ef8 c0300494 600e0113 ffffffff c000d600 de01e410 00000020 00000005 00000000
[ 411.295969]
[ 411.295969] R1: 0xc0e4c140:
[ 411.302360] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.316358] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.330160] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 411.344346] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.358193] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 411.372251] c1e0 00000006 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.386068] c200 00000002 00000000 00000000 00001f53 00000008 00000002 00000000 00000000
[ 411.399956] c220 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.414183]
[ 411.414183] R4: 0xdde87f80:
[ 411.420586] 7f80 00000001 de030f40 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.434569] 7fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.448393] 7fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.462177] 7fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.475918] 8000 00000002 00000102 00000000 ddee8fc0 c0c3c138 00000003 00000015 ddee8fc0
[ 411.490209] 8020 c1f44cc0 dde88000 dd75efc0 c5a3ea80 00000003 dd1424c0 dde89ef4 dde89e70
[ 411.504643] 8040 c086234c 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.518543] 8060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.532713]
[ 411.532713] R7: 0xdde89ebc:
[ 411.539079] 9ebc c0c21484 dde89f3c c0e96ce4 00000000 00000000 00000000 c003e150 dde88000
[ 411.553535] 9edc c003e3bc 0000001d c000e3d0 0000001d fed91000 dde89f08 c000853c c0300494
[ 411.568100] 9efc 600e0113 ffffffff c000d600 de01e410 00000020 00000005 00000000 c0c5a14c
[ 411.582564] 9f1c dde88000 de01e410 c0e96ce4 c0e96ce4 00000000 00000000 00000000 dc918044
[ 411.596998] 9f3c dde89f50 c03004d8 c0300494 600e0113 ffffffff de873d68 00000000 de01e410
[ 411.611537] 9f5c c030043c 00000000 c00561bc d9ffffef 00000000 9dffffff de01e410 00000000
[ 411.625982] 9f7c 00000000 dde89f80 dde89f80 00000000 00000000 dde89f90 dde89f90 dde89fac
[ 411.640299] 9f9c de873d68 c005611c 00000000 00000000 c000da98 00000000 00000000 00000000
[ 411.654977]
[ 411.654977] R8: 0xc0e96c64:
[ 411.661418] 6c64 00000000 c0e96bd0 c5ac8da4 c5ac8da4 00500002 00000001 00000000 00000000
[ 411.675810] 6c84 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.689631] 6ca4 00000000 00000001 00010001 00000000 00000000 00000000 00000000 00000000
[ 411.703557] 6cc4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.717340] 6ce4 de01dc10 de01e010 de01e410 de01e810 00000000 ddee8fc0 00000000 ddd8d700
[ 411.731763] 6d04 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.745538] 6d24 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.759401] 6d44 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 411.775421] CPU: 3 PID: 99 Comm: kconsole Not tainted 3.10.0 #0
[ 411.786005] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 411.795588] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 411.804868] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 411.814320] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 411.820647] Exception stack(0xdde89e50 to 0xdde89e98)
[ 411.827253] 9e40: 00000001 c0e4c1c0 00000000 00000003
[ 411.835374] 9e60: dde88000 00000000 00000002 dde89f3c c0e96ce4 00000000 00000000 0000000a
[ 411.842980] 9e80: 00000000 dde89e98 c003cf64 c003de58 600e0113 ffffffff
[ 411.852278] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 411.861189] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 411.869979] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 411.879281] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 411.888308] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 411.897305] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 411.903426] Exception stack(0xdde89f08 to 0xdde89f50)
[ 411.910603] 9f00: de01e410 00000020 00000005 00000000 c0c5a14c dde88000
[ 411.918830] 9f20: de01e410 c0e96ce4 c0e96ce4 00000000 00000000 00000000 dc918044 dde89f50
[ 411.925823] 9f40: c03004d8 c0300494 600e0113 ffffffff
[ 411.935339] [] (__irq_svc+0x40/0x70) from [] (console_thread+0x58/0xd4)
[ 411.945911] [] (console_thread+0x58/0xd4) from [] (kthread+0xa0/0xac)
[ 411.956288] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 411.963168] IPI backtrace for cpu 2
[ 411.969229]
[ 411.975948] CPU: 2 PID: 874 Comm: app_process Not tainted 3.10.0 #0
[ 411.982919] task: dcfb78c0 ti: dc98c000 task.ti: dc98c000
[ 411.990047] PC is at __do_softirq+0x78/0x2b4
[ 411.996138] LR is at msecs_to_jiffies+0x18/0x24
[ 412.003120] pc : [] lr : [] psr: 600f0113
[ 412.003120] sp : dc98df40 ip : 00000000 fp : 0000000a
[ 412.012771] r10: 00000b40 r9 : b68ec148 r8 : b66ab660
[ 412.018836] r7 : 02649e06 r6 : 00000002 r5 : 00000000 r4 : dc98c000
[ 412.024844] r3 : 00000002 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 412.031374] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 412.038055] Control: 10c5387d Table: 1cfa006a DAC: 00000015
[ 412.043556]
[ 412.043556] PC: 0xc003ddd8:
[ 412.050406] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 412.065870] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 412.080763] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 412.095474] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 412.110044] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 412.124635] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 412.139231] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 412.153879] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 412.168884]
[ 412.168884] LR: 0xc003cee4:
[ 412.175452] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 412.190093] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 412.204681] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 412.219250] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 412.233811] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 412.248407] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 412.262949] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 412.277560] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 412.292576]
[ 412.292576] SP: 0xdc98dec0:
[ 412.299032] dec0 00000007 c0013020 fed91000 dc98def8 c0c21484 dc98df2c b66ab660 b68ec148
[ 412.313650] dee0 00000b40 c0008558 c003de58 600f0113 ffffffff c000d600 00000001 c0e4c1c0
[ 412.328275] df00 00000000 00000002 dc98c000 00000000 00000002 02649e06 b66ab660 b68ec148
[ 412.342701] df20 00000b40 0000000a 00000000 dc98df40 c003cf64 c003de58 600f0113 ffffffff
[ 412.357131] df40 02649e06 0000001d b68ec148 00400000 00002d2e 00000002 00000000 600f0193
[ 412.371678] df60 00000000 c0c21484 02649e06 b66ab660 b68ec148 00000b40 b66d4c0c c003e150
[ 412.386164] df80 dc98c000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dc98dfb0 c000853c
[ 412.400662] dfa0 b6f13984 800f0030 ffffffff c000d7bc b6902ff1 00000001 40000000 40000001
[ 412.415648]
[ 412.415648] R1: 0xc0e4c140:
[ 412.422100] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 412.436083] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 412.450031] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 412.464375] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 412.478245] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 412.492283] c1e0 00000006 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 412.506202] c200 00000002 00000000 00000000 00001f53 00000008 00000002 00000000 00000000
[ 412.520290] c220 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 412.534600]
[ 412.534600] R4: 0xdc98bf80:
[ 412.541059] bf80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 412.555019] bfa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 412.568859] bfc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 412.582803] bfe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 412.596669] c000 00000002 00000102 00000000 dcfb78c0 c0c3c138 00000002 00000015 dcfb78c0
[ 412.610983] c020 c1f3bcc0 dc98c000 dd75f180 c5b60e00 00000002 dc89d400 dc98df9c dc98df18
[ 412.625627] c040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 412.639707] c060 b6f21e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 412.655889] CPU: 2 PID: 874 Comm: app_process Not tainted 3.10.0 #0
[ 412.666778] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 412.676504] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 412.685765] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 412.695367] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 412.701713] Exception stack(0xdc98def8 to 0xdc98df40)
[ 412.707902] dee0: 00000001 c0e4c1c0
[ 412.716222] df00: 00000000 00000002 dc98c000 00000000 00000002 02649e06 b66ab660 b68ec148
[ 412.724513] df20: 00000b40 0000000a 00000000 dc98df40 c003cf64 c003de58 600f0113 ffffffff
[ 412.734100] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 412.743244] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 412.751872] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 412.761110] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 412.770442] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 412.779544] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 412.785868] Exception stack(0xdc98dfb0 to 0xdc98dff8)
[ 412.792572] dfa0: b6902ff1 00000001 40000000 40000001
[ 412.801027] dfc0: 00004cc9 b68eb004 b68eda18 02649e06 b66ab660 b68ec148 00000b40 b66d4c0c
[ 412.808709] dfe0: 000018d0 be8aa2e8 b6f13975 b6f13984 800f0030 ffffffff
[ 415.909211] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 415.965325] [mmc0] – Timeout recovery procedure start –
[ 416.010446] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 416.073828] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 416.105828] [mmc0] – Timeout recovery procedure finished –
[ 416.142628] mmcblk0: error -110 sending status command, retrying
[ 440.540140] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 440.691850] [mmc0] – Timeout recovery procedure start –
[ 440.817888] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 440.902934] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 441.022160] [mmc0] – Timeout recovery procedure finished –
[ 441.414107] mmcblk0: error -110 sending status command, retrying
[ 466.321698] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 466.476739] [mmc0] – Timeout recovery procedure start –
[ 466.990432] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 467.174318] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 467.354260] [mmc0] – Timeout recovery procedure finished –
[ 467.559246] mmcblk0: error -110 sending status command, aborting
[ 467.827253] end_request: I/O error, dev mmcblk0, sector 22675640
[ 468.022915] Buffer I/O error on device mmcblk0p13, logical block 2360343
[ 471.549593] INFO: rcu_preempt detected stalls on CPUs/tasks: { 0} (detected by 1, t=46258 jiffies, g=85, c=84, q=2572)
[ 471.566336] Backtrace for cpu 1 (current):
[ 471.573543] CPU: 1 PID: 765 Comm: HeapTrimmerDaem Not tainted 3.10.0 #0
[ 471.585665] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 471.595914] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 471.606749] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_other_cpu_stall+0x264/0x2e0)
[ 471.617337] [] (print_other_cpu_stall+0x264/0x2e0) from [] (__rcu_pending+0x90/0x190)
[ 471.627503] [] (__rcu_pending+0x90/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 471.638260] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 471.649047] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 471.659288] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 471.669364] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 471.680189] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 471.691889] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 471.702650] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 471.712707] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 471.722283] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 471.731167] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 471.737612] Exception stack(0xdcfefde8 to 0xdcfefe30)
[ 471.744917] fde0: c0a76625 dcfefe58 c0a76626 00000030 dcfefe58 c0a76625
[ 471.753316] fe00: c59fdd56 c0a76625 c59fdd6d 00000001 c0a76625 000002aa 0000001c dcfefe30
[ 471.760264] fe20: c02833a8 c02818bc 600d0013 ffffffff
[ 471.769148] [] (__irq_svc+0x40/0x70) from [] (format_decode+0xe0/0x3cc)
[ 471.778217] [] (format_decode+0xe0/0x3cc) from [] (vsnprintf+0x74/0x3a0)
[ 471.787609] [] (vsnprintf+0x74/0x3a0) from [] (seq_vprintf+0x34/0x60)
[ 471.797068] [] (seq_vprintf+0x34/0x60) from [] (seq_printf+0x18/0x24)
[ 471.807265] [] (seq_printf+0x18/0x24) from [] (show_map_vma+0x114/0x258)
[ 471.817390] [] (show_map_vma+0x114/0x258) from [] (show_pid_map+0x1c/0x54)
[ 471.827105] [] (show_pid_map+0x1c/0x54) from [] (seq_read+0x2e0/0x424)
[ 471.836783] [] (seq_read+0x2e0/0x424) from [] (vfs_read+0xac/0x124)
[ 471.846348] [] (vfs_read+0xac/0x124) from [] (SyS_read+0x3c/0x60)
[ 471.856371] [] (SyS_read+0x3c/0x60) from [] (ret_fast_syscall+0x0/0x30)
[ 471.862345]
[ 471.862345] sending IPI to all other CPUs:
[ 471.870891] IPI backtrace for cpu 2
[ 471.876798]
[ 471.883370] CPU: 2 PID: 866 Comm: app_process Not tainted 3.10.0 #0
[ 471.890220] task: dc9ac980 ti: dccee000 task.ti: dccee000
[ 471.896067] PC is at 0xb6fbaa58
[ 471.901154] LR is at 0xb6fbae45
[ 471.907752] pc : [] lr : [] psr: 600b0030
[ 471.907752] sp : be9bc318 ip : b6fb201c fp : b6f1b4c4
[ 471.916990] r10: 00000004 r9 : b6d85148 r8 : b6ef0bee
[ 471.923062] r7 : 0e82d735 r6 : 00000000 r5 : 00000000 r4 : b6fb4d24
[ 471.929307] r3 : 00000011 r2 : b6ef0bee r1 : b6d853e8 r0 : 00da8521
[ 471.935984] Flags: nZCv IRQs on FIQs on Mode USER_32 ISA Thumb Segment user
[ 471.942620] Control: 10c5387d Table: 1c62006a DAC: 00000015
[ 471.949696] CPU: 2 PID: 866 Comm: app_process Not tainted 3.10.0 #0
[ 471.960689] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 471.970281] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 471.979635] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 471.989140] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 471.995569] Exception stack(0xdcceffb0 to 0xdccefff8)
[ 472.002483] ffa0: 00da8521 b6d853e8 b6ef0bee 00000011
[ 472.010995] ffc0: b6fb4d24 00000000 00000000 0e82d735 b6ef0bee b6d85148 00000004 b6f1b4c4
[ 472.018778] ffe0: b6fb201c be9bc318 b6fbae45 b6fbaa58 600b0030 ffffffff
[ 472.025489] IPI backtrace for cpu 3
[ 472.031474]
[ 472.037802] CPU: 3 PID: 200 Comm: rild Not tainted 3.10.0 #0
[ 472.044517] task: c5be6900 ti: c5b3e000 task.ti: c5b3e000
[ 472.052619] PC is at _raw_spin_unlock_irq+0x38/0x44
[ 472.059564] LR is at finish_task_switch+0x5c/0xd4
[ 472.066508] pc : [] lr : [] psr: 600d0013
[ 472.066508] sp : c5b3fd00 ip : dd48e044 fp : c5b3fd14
[ 472.075795] r10: dd7caa00 r9 : 00000003 r8 : c5a3ea80
[ 472.081731] r7 : 00000001 r6 : c1f44cc0 r5 : 00000000 r4 : dd7caa00
[ 472.087886] r3 : 00000000 r2 : 40000001 r1 : c5be6900 r0 : c1f44cc0
[ 472.094484] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 472.101128] Control: 10c5387d Table: 1d64c06a DAC: 00000015
[ 472.106437]
[ 472.106437] PC: 0xc08633c8:
[ 472.113182] 33c8 eafffc38 f57ff05b e1d030b0 e2833001 e1c030b0 f57ff04f e320f004 e121f001
[ 472.128811] 33e8 e1a0200d e3c23d7f e3c3303f e5932004 e2422001 e5832004 e5933000 e3130002
[ 472.143779] 3408 012fff1e eafffc27 f57ff05b e1d030b0 e2833001 e1c030b0 f57ff04f e320f004
[ 472.158509] 3428 f1080080 e1a0200d e3c23d7f e3c3303f e5932004 e2422001 e5832004 e5933000
[ 472.173033] 3448 e3130002 012fff1e eafffc16 f57ff05b e1903f9f e2433001 e1802f93 e3320000
[ 472.188888] 3468 1afffffa e3530000 1a000001 f57ff04f e320f004 e1a0200d e3c23d7f e3c3303f
[ 472.203446] 3488 e5932004 e2422001 e5832004 e5933000 e3130002 012fff1e eafffc02 f57ff05b
[ 472.217959] 34a8 e1903f9f e2433001 e1802f93 e3320000 1afffffa e3530000 1a000001 f57ff04f
[ 472.233039]
[ 472.233039] LR: 0xc0061c88:
[ 472.239532] 1c88 e28db004 0a000001 e8bd4800 eaffc5ae e1a0200d e3c23d7f e3c3303f e593000c
[ 472.254323] 1ca8 e8bd8800 e92d48f0 e3a03000 e5905488 e1a0200d e5803488 e3c23d7f e3c3303f
[ 472.270900] 1cc8 e5917000 e1a04001 e28db014 e593100c e1a06000 e59f3098 e5933000 e3530000
[ 472.285544] 1ce8 0a000001 e1a00004 eb018daf f57ff05a e3a03000 e1a00006 e5843018 eb2005c1
[ 472.300162] 1d08 e3550000 0a00000b e2853034 f57ff05b e1932f9f e2422001 e1831f92 e3310000
[ 472.314697] 1d28 1afffffa f57ff05b e3520000 1a000001 e1a00005 ebff4b3d e3570040 18bd88f0
[ 472.330270] 1d48 e2843008 f57ff05b e1932f9f e2422001 e1831f92 e3310000 1afffffa f57ff05b
[ 472.344805] 1d68 e3520000 18bd88f0 e1a00004 e8bd48f0 eaff4b7b c0c21064 e92d4818 e1a04000
[ 472.359784]
[ 472.359784] SP: 0xc5b3fc80:
[ 472.366368] fc80 00000007 c0013020 fed91000 c5b3fcb8 c0c21484 c5b3fcec c5a3ea80 00000003
[ 472.380862] fca0 dd7caa00 c0008558 c0863448 600d0013 ffffffff c000d600 c1f44cc0 c5be6900
[ 472.395367] fcc0 40000001 00000000 dd7caa00 00000000 c1f44cc0 00000001 c5a3ea80 00000003
[ 472.409612] fce0 dd7caa00 c5b3fd14 dd48e044 c5b3fd00 c0061d08 c0863448 600d0013 ffffffff
[ 472.424129] fd00 c0c15cc0 c1f44cc0 c5b3e000 c5b61500 c5b3fd9c c0862360 c0c15cc0 c5b3e000
[ 472.438630] fd20 c0c1a084 00000001 00000100 c0c15cc0 00000003 c5b3e000 c0c1a088 c003e048
[ 472.453015] fd40 c5b3fde4 0000001d 00000000 00400140 000045d0 00000003 00000000 600d0193
[ 472.467355] fd60 00000000 c0c21484 c5b3fde4 ddf22790 00000000 de40ab28 0000001d c5b3e000
[ 472.482055]
[ 472.482055] IP: 0xdd48dfc4:
[ 472.488473] dfc4 b72ebd08 b72ebca8 00000036 00000001 b72ea310 b6eb357d b6b01dd0 b72ea1f8
[ 472.502975] dfe4 b6b01d00 b6edfafd b6ed9828 600d0010 00000003 e59d5078 e1a071c7 00000000
[ 472.517379] e004 00000002 bf000000 dd7caa00 c0c3c138 00000003 00000015 dd7caa00 c1f44cc0
[ 472.531681] e024 dd48e000 c5a3ea80 c5b61500 00000003 c5be6900 dd48fe54 dd48fdd0 c086234c
[ 472.546118] e044 00000000 00000000 00000000 00000000 00000000 01010000 00000000 b6a01dd0
[ 472.561315] e064 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 472.575268] e084 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 472.589040] e0a4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 472.603218]
[ 472.603218] FP: 0xc5b3fc94:
[ 472.609816] fc94 c5b3fcec c5a3ea80 00000003 dd7caa00 c0008558 c0863448 600d0013 ffffffff
[ 472.624340] fcb4 c000d600 c1f44cc0 c5be6900 40000001 00000000 dd7caa00 00000000 c1f44cc0
[ 472.638766] fcd4 00000001 c5a3ea80 00000003 dd7caa00 c5b3fd14 dd48e044 c5b3fd00 c0061d08
[ 472.653151] fcf4 c0863448 600d0013 ffffffff c0c15cc0 c1f44cc0 c5b3e000 c5b61500 c5b3fd9c
[ 472.667634] fd14 c0862360 c0c15cc0 c5b3e000 c0c1a084 00000001 00000100 c0c15cc0 00000003
[ 472.682037] fd34 c5b3e000 c0c1a088 c003e048 c5b3fde4 0000001d 00000000 00400140 000045d0
[ 472.696407] fd54 00000003 00000000 600d0193 00000000 c0c21484 c5b3fde4 ddf22790 00000000
[ 472.710596] fd74 de40ab28 0000001d c5b3e000 200d0013 ffffffff c5b3fde4 c000d620 c5b3e000
[ 472.725391]
[ 472.725391] R0: 0xc1f44c40:
[ 472.731828] 4c40 00000000 de8871e8 de8871e8 00000000 00000001 00000000 00000000 00000000
[ 472.745953] 4c60 de85b400 00000000 00000000 00000001 00000000 00000000 00000000 00000000
[ 472.759812] 4c80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 472.773508] 4ca0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 472.787254] 4cc0 4c8d4c8d 00000003 00000800 0000145b 00001dcd 0000215d 00002141 000045cf
[ 472.801725] 4ce0 00000000 00000000 00000000 00000001 000025c4 00000000 0000b455 00000000
[ 472.815663] 4d00 0000ddfc 00000000 000025c4 00000000 00000003 00000003 fc64732b 0000006a
[ 472.829709] 4d20 b7128eaa 00000024 b7128eaa 00000024 dcf75ec0 dd7caa40 c5be6938 dd7caa38
[ 472.845621]
[ 472.845621] R1: 0xc5be6880:
[ 472.852110] 6880 00000000 c5be6884 c5be6884 00000000 00000000 00000000 00000000 00000000
[ 472.866202] 68a0 00000000 00000020 00000000 0000c350 0000c350 00000000 00000000 00000000
[ 472.880150] 68c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 472.893858] 68e0 00000001 00000000 fbfaefef ce9efb77 dffadffd fbdfdf6e ffffffff efeefef7
[ 472.908191] 6900 00000000 c5b3e000 00000002 00400140 00000000 00000000 00000001 00000001
[ 472.922207] 6920 00000078 00000078 00000078 00000000 c0869474 00000000 00000400 00400000
[ 472.936494] 6940 00000001 dcf75ec0 00000000 dcf75ecc dd7caa4c 00000001 dd7d7365 0000006d
[ 472.950702] 6960 bfa0c419 00000002 b752d166 00000024 bf260d9c 00000002 0000003d 00000000
[ 472.965260]
[ 472.965260] R4: 0xdd7ca980:
[ 472.971640] a980 00000000 dd7ca984 dd7ca984 00000000 00000000 00000000 00000000 00000000
[ 472.985615] a9a0 00000000 00000020 00000000 0000c350 0000c350 00000000 00000000 00000000
[ 472.999628] a9c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 473.013400] a9e0 00000001 00000000 e300e59a e58d203c e3a02000 e001019e e58d2064 e1a06741
[ 473.027819] aa00 00000000 dd48e000 00000002 40400040 00000000 00000000 00000000 00000001
[ 473.041888] aa20 0000006f 0000006f 0000006f 00000000 c0869474 00000000 00001dc4 000899bc
[ 473.056190] aa40 dcf75ec0 00000000 00000000 c5be694c c1f4519c 00000001 dd02bce8 0000006d
[ 473.070383] aa60 00d84e4d 0000001c b6c6436a 00000024 fff61901 0000001b 000000bc 00000000
[ 473.085091]
[ 473.085091] R6: 0xc1f44c40:
[ 473.091441] 4c40 00000000 de8871e8 de8871e8 00000000 00000001 00000000 00000000 00000000
[ 473.105390] 4c60 de85b400 00000000 00000000 00000001 00000000 00000000 00000000 00000000
[ 473.119234] 4c80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 473.132900] 4ca0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 473.146552] 4cc0 4c8e4c8e 00000003 00000800 0000145b 00001dcd 0000215d 00002141 000045cf
[ 473.160820] 4ce0 00000000 00000000 00000000 00000001 000025c4 00000000 0000b455 00000000
[ 473.174683] 4d00 0000ddfc 00000000 000025c4 00000000 00000003 00000003 fc64732b 0000006a
[ 473.188680] 4d20 b7128eaa 00000024 b7128eaa 00000024 dcf75ec0 dd7caa40 c5be6938 dd7caa38
[ 473.203403]
[ 473.203403] R8: 0xc5a3ea00:
[ 473.209772] ea00 00000000 00000000 00000000 00000000 00000000 000000c3 0000003b 00000000
[ 473.223672] ea20 c0c46660 00000002 00000326 00000000 00000000 b6f6b000 0001008d 00000000
[ 473.237813] ea40 00000000 00000000 ddeee900 c5b16840 00000000 00000000 ffffffbf ffeffffa
[ 473.252040] ea60 ffffffff fffffffc fdb3bffe 7f9d74ff ebfff77d dbfffbea fdf7fffe fff77eff
[ 473.266447] ea80 dcf30b00 dd12b9b0 c5acfe18 c0019acc c00eed38 b6f4d000 00000000 bf000000
[ 473.280873] eaa0 00000000 b6f4d000 beb09000 dd488000 00000018 00000002 000000d5 00860086
[ 473.295134] eac0 00000000 7eea7eea c5a3eac8 c5a3eac8 c5a3ead0 c5a3ead0 00000cc8 000071ee
[ 473.309474] eae0 00007111 00000000 00000000 000055f9 00001668 00000022 00000000 00000038
[ 473.323983]
[ 473.323983] R10: 0xdd7ca980:
[ 473.330378] a980 00000000 dd7ca984 dd7ca984 00000000 00000000 00000000 00000000 00000000
[ 473.344443] a9a0 00000000 00000020 00000000 0000c350 0000c350 00000000 00000000 00000000
[ 473.358403] a9c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 473.372047] a9e0 00000001 00000000 e300e59a e58d203c e3a02000 e001019e e58d2064 e1a06741
[ 473.386391] aa00 00000000 dd48e000 00000002 40400040 00000000 00000000 00000000 00000001
[ 473.400370] aa20 0000006f 0000006f 0000006f 00000000 c0869474 00000000 00001dc4 000899bc
[ 473.414653] aa40 dcf75ec0 00000000 00000000 c5be694c c1f4519c 00000001 dd02bce8 0000006d
[ 473.428854] aa60 00d84e4d 0000001c b6c6436a 00000024 fff61901 0000001b 000000bc 00000000
[ 473.445336] CPU: 3 PID: 200 Comm: rild Not tainted 3.10.0 #0
[ 473.456108] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 473.465993] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 473.475268] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 473.484682] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 473.491063] Exception stack(0xc5b3fcb8 to 0xc5b3fd00)
[ 473.497326] fca0: c1f44cc0 c5be6900
[ 473.505605] fcc0: 40000001 00000000 dd7caa00 00000000 c1f44cc0 00000001 c5a3ea80 00000003
[ 473.514046] fce0: dd7caa00 c5b3fd14 dd48e044 c5b3fd00 c0061d08 c0863448 600d0013 ffffffff
[ 473.524457] [] (__irq_svc+0x40/0x70) from [] (_raw_spin_unlock_irq+0x38/0x44)
[ 473.536056] [] (_raw_spin_unlock_irq+0x38/0x44) from [] (finish_task_switch+0x5c/0xd4)
[ 473.546801] [] (finish_task_switch+0x5c/0xd4) from [] (__schedule+0x4a0/0x554)
[ 473.556889] [] (__schedule+0x4a0/0x554) from [] (preempt_schedule_irq+0x44/0x64)
[ 473.566999] [] (preempt_schedule_irq+0x44/0x64) from [] (svc_preempt+0x8/0x18)
[ 473.577334] [] (svc_preempt+0x8/0x18) from [] (follow_managed+0x10/0x138)
[ 473.587230] [] (follow_managed+0x10/0x138) from [] (lookup_fast+0x184/0x1d0)
[ 473.596983] [] (lookup_fast+0x184/0x1d0) from [] (link_path_walk+0x208/0x80c)
[ 473.606923] [] (link_path_walk+0x208/0x80c) from [] (path_lookupat+0x54/0x778)
[ 473.616876] [] (path_lookupat+0x54/0x778) from [] (filename_lookup+0x20/0xb0)
[ 473.626944] [] (filename_lookup+0x20/0xb0) from [] (user_path_at_empty+0x54/0x7c)
[ 473.637137] [] (user_path_at_empty+0x54/0x7c) from [] (user_path_at+0x10/0x14)
[ 473.647232] [] (user_path_at+0x10/0x14) from [] (SyS_faccessat+0xac/0x1b8)
[ 473.657530] [] (SyS_faccessat+0xac/0x1b8) from [] (ret_fast_syscall+0x0/0x30)
[ 473.664587] IPI backtrace for cpu 0
[ 473.669693]
[ 473.675727] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 473.682104] task: dc9d0a80 ti: dcf64000 task.ti: dcf64000
[ 473.688822] PC is at __do_softirq+0x78/0x2b4
[ 473.694725] LR is at msecs_to_jiffies+0x18/0x24
[ 473.701493] pc : [] lr : [] psr: 60070113
[ 473.701493] sp : dcf65e68 ip : 00000000 fp : 0000000a
[ 473.710655] r10: dcf65f7c r9 : 00000000 r8 : b6f0f000
[ 473.716554] r7 : dcf65f0c r6 : 00000002 r5 : 00000000 r4 : dcf64000
[ 473.722600] r3 : 00000000 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 473.729127] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 473.735628] Control: 10c5387d Table: 1c94406a DAC: 00000015
[ 473.740914]
[ 473.740914] PC: 0xc003ddd8:
[ 473.747490] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 473.762709] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 473.777538] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 473.792174] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 473.806789] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 473.821399] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 473.835957] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 473.850620] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 473.865719]
[ 473.865719] LR: 0xc003cee4:
[ 473.872291] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 473.886999] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 473.901674] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 473.916303] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 473.930921] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 473.945516] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 473.960198] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 473.974778] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 473.989836]
[ 473.989836] SP: 0xdcf65de8:
[ 473.996341] 5de8 00000007 c0013020 fed91000 dcf65e20 c0c21484 dcf65e54 b6f0f000 00000000
[ 474.011008] 5e08 dcf65f7c c0008558 c003de58 60070113 ffffffff c000d600 00000001 c0e4c1c0
[ 474.025569] 5e28 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c b6f0f000 00000000
[ 474.039691] 5e48 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58 60070113 ffffffff
[ 474.054117] 5e68 dcf65f0c 0000001d 00000000 00400100 ffff9116 00000000 00000000 60070193
[ 474.068517] 5e88 00000000 c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150
[ 474.082883] 5ea8 dcf64000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c
[ 474.097313] 5ec8 c00f0988 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e
[ 474.112040]
[ 474.112040] R1: 0xc0e4c140:
[ 474.118631] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 474.132546] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 474.146340] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 474.160529] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 474.174301] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 474.188310] c1e0 00000007 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 474.202075] c200 00000002 00000000 00000000 00001ff4 00000008 00000002 00000000 00000000
[ 474.215903] c220 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 474.230093]
[ 474.230093] R4: 0xdcf63f80:
[ 474.236473] 3f80 00000000 00000000 00000001 00000000 00000000 a7a9e9df 000000f0 c000db84
[ 474.250572] 3fa0 00000000 c000da00 00000000 00000000 b89fd3e0 00000000 00000001 00000000
[ 474.264649] 3fc0 00000000 00000000 a7a9e9df 000000f0 00000001 b89fd3e0 b878e970 b89fcf28
[ 474.278939] 3fe0 9e9499c8 9e9499b8 b4fa56a7 b6df4964 200f0010 b89fd3e0 000000ab 0312fa12
[ 474.293475] 4000 00000002 00000102 00000000 dc9d0a80 c0c3c138 00000000 00000015 dc9d0a80
[ 474.307724] 4020 c1f29cc0 dcf64000 dd75e000 dd75f180 00000000 dcfb78c0 dcf65d74 dcf65cf0
[ 474.322226] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 474.336291] 4060 b6fa9e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 474.350563]
[ 474.350563] R7: 0xdcf65e8c:
[ 474.356898] 5e8c c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150 dcf64000
[ 474.371437] 5eac c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c c00f0988
[ 474.385931] 5ecc 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e dca0ea50
[ 474.400470] 5eec 80100073 dd75ea80 b6f0e000 b6f0f000 00000000 dcf65f7c 80100071 dcda2500
[ 474.415024] 5f0c dcf65f20 c00f0c50 c00f0988 60070013 ffffffff dd75eac0 80070013 000000af
[ 474.429522] 5f2c dd75eac0 00000000 dc4916c0 b6eed000 00000001 00000000 00000003 b6f0f000
[ 474.443749] 5f4c 00000003 dca0ea50 b6f0e000 b6f0f000 80100073 00000003 c00f0c50 80100073
[ 474.458163] 5f6c 00000000 00001000 00000002 0000201f dca0e948 00000000 00000001 00001000
[ 474.472875]
[ 474.472875] R10: 0xdcf65efc:
[ 474.479229] 5efc 00000000 dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013
[ 474.493750] 5f1c ffffffff dd75eac0 80070013 000000af dd75eac0 00000000 dc4916c0 b6eed000
[ 474.508101] 5f3c 00000001 00000000 00000003 b6f0f000 00000003 dca0ea50 b6f0e000 b6f0f000
[ 474.522305] 5f5c 80100073 00000003 c00f0c50 80100073 00000000 00001000 00000002 0000201f
[ 474.536611] 5f7c dca0e948 00000000 00000001 00001000 00000000 0000007d c000db84 dcf64000
[ 474.550973] 5f9c 00000000 b6f0e024 c000da00 00000001 00001000 b6f0e000 00001000 00000003
[ 474.565219] 5fbc b6f927b8 00000001 00001000 00000000 0000007d b6f0e000 0000000c b6f8c7bc
[ 474.579529] 5fdc b6f0e024 b6f43af5 bebc1828 b6f6a02f b6f6c13c 20070010 b6f0e000 990ae00d
[ 474.596090] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 474.606264] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 474.615754] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 474.625018] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 474.634496] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 474.640858] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 474.648520] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 474.656818] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 474.663146] 5e60: 60070113 ffffffff
[ 474.671748] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 474.680816] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 474.689742] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 474.698916] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 474.708154] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 474.717181] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 474.723463] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 474.729487] 5ec0: 00000000 dcf65f7c
[ 474.737856] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 474.746236] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 474.755929] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 474.765407] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 474.774999] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 478.609673] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD18): error = -110, timeout = 8000ms
[ 478.804523] [mmc0] – Timeout recovery procedure start –
[ 478.849004] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 478.991450] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 479.300085] [mmc0] – Timeout recovery procedure finished –
[ 504.222715] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 504.260159] [mmc0] – Timeout recovery procedure start –
[ 504.305359] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 504.421930] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 504.479161] [mmc0] – Timeout recovery procedure finished –
[ 504.536888] mmcblk0: error -110 sending status command, retrying
[ 529.304537] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 529.362836] [mmc0] – Timeout recovery procedure start –
[ 529.397054] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 529.530254] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 530.171470] [mmc0] – Timeout recovery procedure finished –
[ 530.183129] mmcblk0: error -110 sending status command, retrying
[ 533.677049] INFO: rcu_preempt detected stalls on CPUs/tasks: { 0} (detected by 1, t=52571 jiffies, g=85, c=84, q=2991)
[ 533.694701] Backtrace for cpu 1 (current):
[ 533.701973] CPU: 1 PID: 894 Comm: app_process Not tainted 3.10.0 #0
[ 533.714150] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 533.724313] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 533.735190] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_other_cpu_stall+0x264/0x2e0)
[ 533.745811] [] (print_other_cpu_stall+0x264/0x2e0) from [] (__rcu_pending+0x90/0x190)
[ 533.755952] [] (__rcu_pending+0x90/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 533.766941] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 533.777856] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 533.788195] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 533.798467] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 533.809359] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 533.821262] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 533.832026] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 533.842535] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 533.852186] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 533.861443] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 533.867876] Exception stack(0xdc919fb0 to 0xdc919ff8)
[ 533.874974] 9fa0: 0793f63f b0000000 b6c7d2a9 0793f68f
[ 533.883840] 9fc0: b6cd93f4 b6c7d299 b6c73148 00022a02 00000002 000314d4 b6c73000 b6c8d9e8
[ 533.891735] 9fe0: 000000ff be98a338 b6f21bab b6f2113c 600e0030 ffffffff
[ 533.897097]
[ 533.897097] sending IPI to all other CPUs:
[ 533.906064] IPI backtrace for cpu 2
[ 533.912064]
[ 533.918584] CPU: 2 PID: 441 Comm: EventThread Not tainted 3.10.0 #0
[ 533.925475] task: dd143480 ti: dd4e6000 task.ti: dd4e6000
[ 533.932679] PC is at __do_softirq+0x78/0x2b4
[ 533.938650] LR is at msecs_to_jiffies+0x18/0x24
[ 533.945579] pc : [] lr : [] psr: 600d0113
[ 533.945579] sp : dd4e7cc0 ip : 00000000 fp : 0000000a
[ 533.955008] r10: dd4e7e10 r9 : 00000000 r8 : 0000005c
[ 533.960802] r7 : dd4e7d64 r6 : 00000002 r5 : 00000000 r4 : dd4e6000
[ 533.966867] r3 : 00000002 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 533.973375] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 533.979849] Control: 10c5387d Table: 1d48806a DAC: 00000015
[ 533.985143]
[ 533.985143] PC: 0xc003ddd8:
[ 533.991681] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 534.006780] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 534.021112] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 534.035441] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 534.049487] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 534.063571] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 534.077625] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 534.091792] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 534.106324]
[ 534.106324] LR: 0xc003cee4:
[ 534.112836] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 534.127021] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 534.141090] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 534.155178] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 534.169296] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 534.183380] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 534.197404] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 534.211537] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 534.225997]
[ 534.225997] SP: 0xdd4e7c40:
[ 534.232422] 7c40 00000007 c0013020 fed91000 dd4e7c78 c0c21484 dd4e7cac 0000005c 00000000
[ 534.246604] 7c60 dd4e7e10 c0008558 c003de58 600d0113 ffffffff c000d600 00000001 c0e4c1c0
[ 534.260666] 7c80 00000000 00000002 dd4e6000 00000000 00000002 dd4e7d64 0000005c 00000000
[ 534.274366] 7ca0 dd4e7e10 0000000a 00000000 dd4e7cc0 c003cf64 c003de58 600d0113 ffffffff
[ 534.288232] 7cc0 dd4e7d64 0000001d 00000000 00400040 00005e79 00000002 00000000 600d0193
[ 534.302042] 7ce0 00000000 c0c21484 dd4e7d64 0000005c 00000000 dd4e7e10 de7a9080 c003e150
[ 534.315904] 7d00 dd4e6000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dd4e7d30 c000853c
[ 534.329898] 7d20 c073e288 800d0013 ffffffff c000d600 dc9430c0 00000000 dd4e7f00 00000000
[ 534.344279]
[ 534.344279] R1: 0xc0e4c140:
[ 534.350584] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 534.364036] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 534.377357] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 534.391032] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 534.404273] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 534.417797] c1e0 00000008 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 534.431039] c200 00000002 00000000 00000000 0000206b 00000008 00000002 00000000 00000000
[ 534.444379] c220 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 534.458106]
[ 534.458106] R4: 0xdd4e5f80:
[ 534.464362] 5f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 534.477732] 5fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 534.491026] 5fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 534.504388] 5fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 534.517728] 6000 00000000 00000102 00000000 dd143480 c0c3c138 00000002 00000015 dd143480
[ 534.531609] 6020 c1f3bcc0 dd4e6000 c5a3ea80 c5a3ea80 00000002 dd1424c0 dd4e7f9c dd4e7f18
[ 534.545614] 6040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 534.559236] 6060 b251bdd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 534.573143]
[ 534.573143] R7: 0xdd4e7ce4:
[ 534.579584] 7ce4 c0c21484 dd4e7d64 0000005c 00000000 dd4e7e10 de7a9080 c003e150 dd4e6000
[ 534.593592] 7d04 c003e3bc 0000001d c000e3d0 0000001d fed91000 dd4e7d30 c000853c c073e288
[ 534.607545] 7d24 800d0013 ffffffff c000d600 dc9430c0 00000000 dd4e7f00 00000000 deb85f80
[ 534.621456] 7d44 dc9430c0 dd6e61c0 dd4e7e30 0000005c 00000000 dd4e7e10 de7a9080 dca83c00
[ 534.635469] 7d64 dd4e7d78 c073e26c c073e288 800d0013 ffffffff 0000005c 00000004 00000093
[ 534.649368] 7d84 c02368b0 0000005c 00000000 00000000 00000000 dd1434b8 c0d8bd80 00000000
[ 534.663050] 7da4 dd6e61c0 00000000 00000000 00000000 00000000 00000000 ffffffff ffffffff
[ 534.676608] 7dc4 00000093 00000000 dd4e7e30 dd4e7e70 0000005c de7a9080 dd4e7f00 dd4e7f80
[ 534.690903]
[ 534.690903] R10: 0xdd4e7d90:
[ 534.697335] 7d90 00000000 00000000 dd1434b8 c0d8bd80 00000000 dd6e61c0 00000000 00000000
[ 534.711025] 7db0 00000000 00000000 00000000 ffffffff ffffffff 00000093 00000000 dd4e7e30
[ 534.724684] 7dd0 dd4e7e70 0000005c de7a9080 dd4e7f00 dd4e7f80 dd143480 00000000 c06741b4
[ 534.738610] 7df0 dd4e7f00 00000000 00000000 dd4e7e70 00000006 c0674234 00000006 dd1434b8
[ 534.752375] 7e10 0005ce7f 00000000 ffffffff 0000005c de7a9080 00009768 dd4e7db0 dd4e7e30
[ 534.766331] 7e30 00000000 00000000 dd4e7f00 00000006 00000000 00000000 00000040 dd4e7e70
[ 534.779998] 7e50 dd4e7f00 dd4e7f80 dd581b40 0000005c 00000006 c010ac64 00000000 00000000
[ 534.793811] 7e70 00000001 dd581b40 00000000 00000000 00000000 dd143480 00000000 00000000
[ 534.809523] CPU: 2 PID: 441 Comm: EventThread Not tainted 3.10.0 #0
[ 534.820174] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 534.829728] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 534.838988] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 534.848410] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 534.854791] Exception stack(0xdd4e7c78 to 0xdd4e7cc0)
[ 534.860866] 7c60: 00000001 c0e4c1c0
[ 534.868954] 7c80: 00000000 00000002 dd4e6000 00000000 00000002 dd4e7d64 0000005c 00000000
[ 534.877097] 7ca0: dd4e7e10 0000000a 00000000 dd4e7cc0 c003cf64 c003de58 600d0113 ffffffff
[ 534.886703] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 534.895682] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 534.904393] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 534.913571] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 534.922744] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 534.931753] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 534.938017] Exception stack(0xdd4e7d30 to 0xdd4e7d78)
[ 534.944525] 7d20: dc9430c0 00000000 dd4e7f00 00000000
[ 534.952747] 7d40: deb85f80 dc9430c0 dd6e61c0 dd4e7e30 0000005c 00000000 dd4e7e10 de7a9080
[ 534.960331] 7d60: dca83c00 dd4e7d78 c073e26c c073e288 800d0013 ffffffff
[ 534.970200] [] (__irq_svc+0x40/0x70) from [] (unix_dgram_sendmsg+0x238/0x5f0)
[ 534.980957] [] (unix_dgram_sendmsg+0x238/0x5f0) from [] (do_sock_write+0xc0/0xc4)
[ 534.991165] [] (do_sock_write+0xc0/0xc4) from [] (sock_aio_write+0x7c/0x94)
[ 535.001425] [] (sock_aio_write+0x7c/0x94) from [] (do_sync_readv_writev+0x74/0x98)
[ 535.011467] [] (do_sync_readv_writev+0x74/0x98) from [] (do_readv_writev+0xd8/0x22c)
[ 535.021374] [] (do_readv_writev+0xd8/0x22c) from [] (vfs_writev+0x5c/0x68)
[ 535.030860] [] (vfs_writev+0x5c/0x68) from [] (SyS_writev+0x3c/0x60)
[ 535.040760] [] (SyS_writev+0x3c/0x60) from [] (ret_fast_syscall+0x0/0x30)
[ 535.047362] IPI backtrace for cpu 0
[ 535.052253]
[ 535.058261] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 535.064675] task: dc9d0a80 ti: dcf64000 task.ti: dcf64000
[ 535.071537] PC is at __do_softirq+0x78/0x2b4
[ 535.077402] LR is at msecs_to_jiffies+0x18/0x24
[ 535.084072] pc : [] lr : [] psr: 60070113
[ 535.084072] sp : dcf65e68 ip : 00000000 fp : 0000000a
[ 535.093167] r10: dcf65f7c r9 : 00000000 r8 : b6f0f000
[ 535.099010] r7 : dcf65f0c r6 : 00000002 r5 : 00000000 r4 : dcf64000
[ 535.105025] r3 : 00000000 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 535.111552] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 535.118045] Control: 10c5387d Table: 1c94406a DAC: 00000015
[ 535.123219]
[ 535.123219] PC: 0xc003ddd8:
[ 535.129802] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 535.145131] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 535.159745] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 535.174329] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 535.188857] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 535.203392] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 535.217871] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 535.232417] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 535.247392]
[ 535.247392] LR: 0xc003cee4:
[ 535.253818] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 535.268503] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 535.283084] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 535.297611] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 535.312128] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 535.326656] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 535.341172] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 535.355662] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 535.370581]
[ 535.370581] SP: 0xdcf65de8:
[ 535.376942] 5de8 00000007 c0013020 fed91000 dcf65e20 c0c21484 dcf65e54 b6f0f000 00000000
[ 535.391425] 5e08 dcf65f7c c0008558 c003de58 60070113 ffffffff c000d600 00000001 c0e4c1c0
[ 535.405870] 5e28 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c b6f0f000 00000000
[ 535.419980] 5e48 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58 60070113 ffffffff
[ 535.434395] 5e68 dcf65f0c 0000001d 00000000 00400100 ffff9116 00000000 00000000 60070193
[ 535.448705] 5e88 00000000 c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150
[ 535.463060] 5ea8 dcf64000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c
[ 535.477475] 5ec8 c00f0988 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e
[ 535.492224]
[ 535.492224] R1: 0xc0e4c140:
[ 535.498571] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 535.512346] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 535.526122] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 535.540263] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 535.554136] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 535.568096] c1e0 00000008 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 535.581831] c200 00000002 00000000 00000000 0000206b 00000008 00000002 00000000 00000000
[ 535.595670] c220 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 535.609803]
[ 535.609803] R4: 0xdcf63f80:
[ 535.616296] 3f80 00000000 00000000 00000001 00000000 00000000 a7a9e9df 000000f0 c000db84
[ 535.630489] 3fa0 00000000 c000da00 00000000 00000000 b89fd3e0 00000000 00000001 00000000
[ 535.644495] 3fc0 00000000 00000000 a7a9e9df 000000f0 00000001 b89fd3e0 b878e970 b89fcf28
[ 535.658774] 3fe0 9e9499c8 9e9499b8 b4fa56a7 b6df4964 200f0010 b89fd3e0 000000ab 0312fa12
[ 535.673245] 4000 00000002 00000102 00000000 dc9d0a80 c0c3c138 00000000 00000015 dc9d0a80
[ 535.687469] 4020 c1f29cc0 dcf64000 dd75e000 dd75f180 00000000 dcfb78c0 dcf65d74 dcf65cf0
[ 535.701842] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 535.715889] 4060 b6fa9e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 535.730074]
[ 535.730074] R7: 0xdcf65e8c:
[ 535.736556] 5e8c c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150 dcf64000
[ 535.751125] 5eac c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c c00f0988
[ 535.765675] 5ecc 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e dca0ea50
[ 535.780087] 5eec 80100073 dd75ea80 b6f0e000 b6f0f000 00000000 dcf65f7c 80100071 dcda2500
[ 535.794618] 5f0c dcf65f20 c00f0c50 c00f0988 60070013 ffffffff dd75eac0 80070013 000000af
[ 535.809101] 5f2c dd75eac0 00000000 dc4916c0 b6eed000 00000001 00000000 00000003 b6f0f000
[ 535.823354] 5f4c 00000003 dca0ea50 b6f0e000 b6f0f000 80100073 00000003 c00f0c50 80100073
[ 535.837720] 5f6c 00000000 00001000 00000002 0000201f dca0e948 00000000 00000001 00001000
[ 535.852413]
[ 535.852413] R10: 0xdcf65efc:
[ 535.858872] 5efc 00000000 dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013
[ 535.873490] 5f1c ffffffff dd75eac0 80070013 000000af dd75eac0 00000000 dc4916c0 b6eed000
[ 535.887875] 5f3c 00000001 00000000 00000003 b6f0f000 00000003 dca0ea50 b6f0e000 b6f0f000
[ 535.902068] 5f5c 80100073 00000003 c00f0c50 80100073 00000000 00001000 00000002 0000201f
[ 535.916352] 5f7c dca0e948 00000000 00000001 00001000 00000000 0000007d c000db84 dcf64000
[ 535.930714] 5f9c 00000000 b6f0e024 c000da00 00000001 00001000 b6f0e000 00001000 00000003
[ 535.944952] 5fbc b6f927b8 00000001 00001000 00000000 0000007d b6f0e000 0000000c b6f8c7bc
[ 535.959205] 5fdc b6f0e024 b6f43af5 bebc1828 b6f6a02f b6f6c13c 20070010 b6f0e000 990ae00d
[ 535.975929] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 535.986366] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 535.995807] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 536.004879] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 536.014308] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 536.020674] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 536.028178] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 536.036299] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 536.042522] 5e60: 60070113 ffffffff
[ 536.050913] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 536.059911] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 536.068611] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 536.077642] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 536.086597] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 536.095474] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 536.101685] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 536.107686] 5ec0: 00000000 dcf65f7c
[ 536.115980] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 536.124270] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 536.133854] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 536.143095] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 536.152408] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 536.159379] IPI backtrace for cpu 3
[ 536.165492]
[ 536.172121] CPU: 3 PID: 212 Comm: DispSync Not tainted 3.10.0 #0
[ 536.179009] task: dd7caa00 ti: dd48e000 task.ti: dd48e000
[ 536.186182] PC is at __do_softirq+0x78/0x2b4
[ 536.192284] LR is at msecs_to_jiffies+0x18/0x24
[ 536.199270] pc : [] lr : [] psr: 600d0113
[ 536.199270] sp : dd48ff40 ip : 00000000 fp : 0000000a
[ 536.208511] r10: 005790d6 r9 : 0000007e r8 : 00000001
[ 536.214350] r7 : 00000000 r6 : 00000002 r5 : 00000000 r4 : dd48e000
[ 536.220388] r3 : 00000003 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 536.226994] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 536.233619] Control: 10c5387d Table: 1d48806a DAC: 00000015
[ 536.238924]
[ 536.238924] PC: 0xc003ddd8:
[ 536.245744] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 536.261505] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 536.276525] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 536.291136] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 536.305664] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 536.320244] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 536.334685] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 536.349247] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 536.364207]
[ 536.364207] LR: 0xc003cee4:
[ 536.370775] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 536.385356] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 536.399891] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 536.414343] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 536.428792] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 536.443211] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 536.457659] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 536.472108] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 536.486940]
[ 536.486940] SP: 0xdd48fec0:
[ 536.493388] fec0 00000007 c0013020 fed91000 dd48fef8 c0c21484 dd48ff2c 00000001 0000007e
[ 536.507901] fee0 005790d6 c0008558 c003de58 600d0113 ffffffff c000d600 00000001 c0e4c1c0
[ 536.522342] ff00 00000000 00000003 dd48e000 00000000 00000002 00000000 00000001 0000007e
[ 536.536329] ff20 005790d6 0000000a 00000000 dd48ff40 c003cf64 c003de58 600d0113 ffffffff
[ 536.550657] ff40 00000000 0000001d 0000007e 00400040 00005e79 00000003 00000000 600d0193
[ 536.565065] ff60 00000000 c0c21484 00000000 00000001 0000007e 005790d6 00000000 c003e150
[ 536.579265] ff80 dd48e000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dd48ffb0 c000853c
[ 536.593703] ffa0 b6eb4078 400d0030 ffffffff c000d7bc b6efa2a8 b6efa0e8 00000003 b6efa2c8
[ 536.608557]
[ 536.608557] R1: 0xc0e4c140:
[ 536.615182] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 536.628984] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 536.642783] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 536.656825] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 536.670496] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 536.684351] c1e0 00000008 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 536.698119] c200 00000002 00000000 00000000 0000206b 00000008 00000002 00000000 00000000
[ 536.711801] c220 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 536.725851]
[ 536.725851] R4: 0xdd48df80:
[ 536.732257] df80 00000003 00000001 b6b01d18 b72ebcd8 b72ebd08 b72ebca8 00000036 c000db84
[ 536.746560] dfa0 00000000 c000da00 b72ebcd8 b72ebd08 00000003 c0186201 b6b01d18 b6b01d10
[ 536.760869] dfc0 b72ebcd8 b72ebd08 b72ebca8 00000036 00000001 b72ea310 b6eb357d b6b01dd0
[ 536.775164] dfe0 b72ea1f8 b6b01d00 b6edfafd b6ed9828 600d0010 00000003 e59d5078 e1a071c7
[ 536.789522] e000 00000002 00000102 00000000 dd7caa00 c0c3c138 00000003 00000015 dd7caa00
[ 536.803618] e020 c1f44cc0 dd48e000 c5a3ea80 dd75e1c0 00000003 dcfb39c0 dd48fe54 dd48fdd0
[ 536.817972] e040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 536.831887] e060 b6a01dd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 536.847941] CPU: 3 PID: 212 Comm: DispSync Not tainted 3.10.0 #0
[ 536.858476] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 536.868150] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 536.877422] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 536.886870] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 536.893262] Exception stack(0xdd48fef8 to 0xdd48ff40)
[ 536.899420] fee0: 00000001 c0e4c1c0
[ 536.907353] ff00: 00000000 00000003 dd48e000 00000000 00000002 00000000 00000001 0000007e
[ 536.915685] ff20: 005790d6 0000000a 00000000 dd48ff40 c003cf64 c003de58 600d0113 ffffffff
[ 536.925393] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 536.934536] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 536.943383] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 536.952602] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 536.961937] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 536.971021] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 536.977326] Exception stack(0xdd48ffb0 to 0xdd48fff8)
[ 536.984003] ffa0: b6efa2a8 b6efa0e8 00000003 b6efa2c8
[ 536.992094] ffc0: b6efa2a8 00000000 00000000 00000000 00000001 0000007e 005790d6 00000000
[ 536.999787] ffe0: b6ef463c b6a01c08 b6ec77f1 b6eb4078 400d0030 ffffffff
[ 554.788469] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 554.796414] [mmc0] – Timeout recovery procedure start –
[ 554.807614] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 554.814874] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 554.823758] [mmc0] – Timeout recovery procedure finished –
[ 554.830169] mmcblk0: error -110 sending status command, aborting
[ 554.839260] end_request: I/O error, dev mmcblk0, sector 1062408
[ 563.244375] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD25): error = -110, timeout = 8000ms
[ 563.320187] [mmc0] – Timeout recovery procedure start –
[ 563.483161] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 563.645639] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 563.786277] [mmc0] – Timeout recovery procedure finished –
[ 588.366438] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 588.649657] [mmc0] – Timeout recovery procedure start –
[ 588.860624] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 589.238864] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 589.526350] [mmc0] – Timeout recovery procedure finished –
[ 589.880565] mmcblk0: error -110 sending status command, retrying
[ 595.786150] INFO: rcu_preempt detected stalls on CPUs/tasks: { 0} (detected by 1, t=58883 jiffies, g=85, c=84, q=3376)
[ 595.800708] Backtrace for cpu 1 (current):
[ 595.807930] CPU: 1 PID: 874 Comm: app_process Not tainted 3.10.0 #0
[ 595.819901] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 595.830199] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 595.840730] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_other_cpu_stall+0x264/0x2e0)
[ 595.851201] [] (print_other_cpu_stall+0x264/0x2e0) from [] (__rcu_pending+0x90/0x190)
[ 595.861525] [] (__rcu_pending+0x90/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 595.872463] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 595.883366] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 595.893698] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 595.903984] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 595.915132] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 595.927047] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 595.938108] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 595.948560] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 595.958268] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 595.967618] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 595.974239] Exception stack(0xdc98deb8 to 0xdc98df00)
[ 595.980729] dea0: c1f32cc0 dcfb78c0
[ 595.989361] dec0: dc98df00 0000361d dd143480 00000000 c1f32cc0 00000001 c5a3ea80 00000001
[ 595.998072] dee0: dd143480 dc98df14 dd4e6044 dc98df00 c0061d08 c086342c 600d0013 ffffffff
[ 596.008491] [] (__irq_svc+0x40/0x70) from [] (_raw_spin_unlock_irq+0x1c/0x44)
[ 596.019439] [] (_raw_spin_unlock_irq+0x1c/0x44) from [] (finish_task_switch+0x5c/0xd4)
[ 596.029854] [] (finish_task_switch+0x5c/0xd4) from [] (__schedule+0x4a0/0x554)
[ 596.039249] [] (__schedule+0x4a0/0x554) from [] (do_work_pending+0x24/0x94)
[ 596.048630] [] (do_work_pending+0x24/0x94) from [] (work_pending+0xc/0x20)
[ 596.054476]
[ 596.054476] sending IPI to all other CPUs:
[ 596.063022] IPI backtrace for cpu 2
[ 596.068940]
[ 596.075445] CPU: 2 PID: 212 Comm: DispSync Not tainted 3.10.0 #0
[ 596.082201] task: dd7caa00 ti: dd48e000 task.ti: dd48e000
[ 596.089953] PC is at _raw_spin_unlock_irq+0x1c/0x44
[ 596.096744] LR is at finish_task_switch+0x5c/0xd4
[ 596.103737] pc : [] lr : [] psr: 60070113
[ 596.103737] sp : dd48fdb8 ip : de8d8044 fp : dd48fdcc
[ 596.112824] r10: dcf72f40 r9 : 00000002 r8 : c5b61c00
[ 596.118761] r7 : 00000000 r6 : c1f3bcc0 r5 : c5b61c00 r4 : de896e40
[ 596.124972] r3 : 0000f3dd r2 : dd48fdb8 r1 : dd7caa00 r0 : c1f3bcc0
[ 596.131435] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 596.137905] Control: 10c5387d Table: 1d48806a DAC: 00000015
[ 596.143165]
[ 596.143165] PC: 0xc08633ac:
[ 596.149974] 33ac e3c3303f e5932004 e2422001 e5832004 e5933000 e3130002 012fff1e eafffc38
[ 596.165303] 33cc f57ff05b e1d030b0 e2833001 e1c030b0 f57ff04f e320f004 e121f001 e1a0200d
[ 596.180011] 33ec e3c23d7f e3c3303f e5932004 e2422001 e5832004 e5933000 e3130002 012fff1e
[ 596.194422] 340c eafffc27 f57ff05b e1d030b0 e2833001 e1c030b0 f57ff04f e320f004 f1080080
[ 596.208638] 342c e1a0200d e3c23d7f e3c3303f e5932004 e2422001 e5832004 e5933000 e3130002
[ 596.223038] 344c 012fff1e eafffc16 f57ff05b e1903f9f e2433001 e1802f93 e3320000 1afffffa
[ 596.237182] 346c e3530000 1a000001 f57ff04f e320f004 e1a0200d e3c23d7f e3c3303f e5932004
[ 596.251210] 348c e2422001 e5832004 e5933000 e3130002 012fff1e eafffc02 f57ff05b e1903f9f
[ 596.265734]
[ 596.265734] LR: 0xc0061c88:
[ 596.272381] 1c88 e28db004 0a000001 e8bd4800 eaffc5ae e1a0200d e3c23d7f e3c3303f e593000c
[ 596.286690] 1ca8 e8bd8800 e92d48f0 e3a03000 e5905488 e1a0200d e5803488 e3c23d7f e3c3303f
[ 596.300763] 1cc8 e5917000 e1a04001 e28db014 e593100c e1a06000 e59f3098 e5933000 e3530000
[ 596.314851] 1ce8 0a000001 e1a00004 eb018daf f57ff05a e3a03000 e1a00006 e5843018 eb2005c1
[ 596.328935] 1d08 e3550000 0a00000b e2853034 f57ff05b e1932f9f e2422001 e1831f92 e3310000
[ 596.343012] 1d28 1afffffa f57ff05b e3520000 1a000001 e1a00005 ebff4b3d e3570040 18bd88f0
[ 596.356987] 1d48 e2843008 f57ff05b e1932f9f e2422001 e1831f92 e3310000 1afffffa f57ff05b
[ 596.371048] 1d68 e3520000 18bd88f0 e1a00004 e8bd48f0 eaff4b7b c0c21064 e92d4818 e1a04000
[ 596.385471]
[ 596.385471] SP: 0xdd48fd38:
[ 596.391956] fd38 00000007 c0013020 fed91000 dd48fd70 c0c21484 dd48fda4 c5b61c00 00000002
[ 596.406198] fd58 dcf72f40 c0008558 c086342c 60070113 ffffffff c000d600 c1f3bcc0 dd7caa00
[ 596.420384] fd78 dd48fdb8 0000f3dd de896e40 c5b61c00 c1f3bcc0 00000000 c5b61c00 00000002
[ 596.434363] fd98 dcf72f40 dd48fdcc de8d8044 dd48fdb8 c0061d08 c086342c 60070113 ffffffff
[ 596.448417] fdb8 c0c15cc0 c1f3bcc0 dd48e000 c5a3ea80 dd48fe54 c0862360 dd48fec8 dd48e000
[ 596.462550] fdd8 c1f396f0 00000002 c0c136b8 c0c15cc0 0000c350 00000000 00000038 0000ac65
[ 596.476494] fdf8 00000001 00000000 dd142500 c0059d50 eb70ccf3 0000008c c1f3bcc0 a00d0013
[ 596.490500] fe18 b72eba20 dd48fe90 dd48fec8 eb7009a3 0000008c b72eba20 ffffecc8 dd48e000
[ 596.504956]
[ 596.504956] IP: 0xde8d7fc4:
[ 596.511370] 7fc4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 596.524807] 7fe4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 596.538140] 8004 00000002 00000000 de896e40 c0c3c138 00000002 00000015 de896e40 c1f3bcc0
[ 596.551998] 8024 de8d8000 c5b61c00 c5a3ea80 00000002 dd7caa00 de8d9f44 de8d9ec0 c086234c
[ 596.566014] 8044 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 596.579316] 8064 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 596.592603] 8084 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 596.605872] 80a4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 596.619602]
[ 596.619602] FP: 0xdd48fd4c:
[ 596.626122] fd4c dd48fda4 c5b61c00 00000002 dcf72f40 c0008558 c086342c 60070113 ffffffff
[ 596.640266] fd6c c000d600 c1f3bcc0 dd7caa00 dd48fdb8 0000f3dd de896e40 c5b61c00 c1f3bcc0
[ 596.654271] fd8c 00000000 c5b61c00 00000002 dcf72f40 dd48fdcc de8d8044 dd48fdb8 c0061d08
[ 596.668257] fdac c086342c 60070113 ffffffff c0c15cc0 c1f3bcc0 dd48e000 c5a3ea80 dd48fe54
[ 596.682319] fdcc c0862360 dd48fec8 dd48e000 c1f396f0 00000002 c0c136b8 c0c15cc0 0000c350
[ 596.696343] fdec 00000000 00000038 0000ac65 00000001 00000000 dd142500 c0059d50 eb70ccf3
[ 596.710197] fe0c 0000008c c1f3bcc0 a00d0013 b72eba20 dd48fe90 dd48fec8 eb7009a3 0000008c
[ 596.724304] fe2c b72eba20 ffffecc8 dd48e000 dd48fec8 eb7009a3 0000008c b72eba20 ffffecc8
[ 596.738723]
[ 596.738723] R0: 0xc1f3bc40:
[ 596.745257] bc40 00000000 de886978 de886978 00000000 00000001 00000000 00000000 00000000
[ 596.758849] bc60 de85b380 00000000 00000000 00000001 00000000 00000000 00000000 00000000
[ 596.772328] bc80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 596.785551] bca0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 596.798793] bcc0 f3ddf3dd 00000003 00000800 00001ba1 000024fc 00002814 00002900 00007720
[ 596.812647] bce0 00000000 00000000 00000000 00000000 000025c4 00000000 0000e4e6 00000000
[ 596.826164] bd00 00010a5f 00000000 000025c4 00000000 00000003 00000003 dc4cb4a2 00000086
[ 596.839849] bd20 6fa21fbb 00000058 6fa21fbb 00000058 de896e80 de896e80 dd7caa38 00000000
[ 596.854106]
[ 596.854106] R1: 0xdd7ca980:
[ 596.860644] a980 00000000 dd7ca984 dd7ca984 00000000 00000000 00000000 00000000 00000000
[ 596.874277] a9a0 00000000 00000020 00000000 0000c350 0000c350 00000000 00000000 00000000
[ 596.887940] a9c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 596.901363] a9e0 00000001 00000000 e300e59a e58d203c e3a02000 e001019e e58d2064 e1a06741
[ 596.915345] aa00 00000000 dd48e000 00000002 40400040 00000000 00000000 00000001 00000001
[ 596.928967] aa20 0000006f 0000006f 0000006f 00000000 c0869474 00000000 00001dc4 000899bc
[ 596.942867] aa40 de896e80 00000000 00000000 de896e8c c1f3c19c 00000001 c7ca73a7 0000008a
[ 596.956684] aa60 8f3d0ef2 00000028 6f560671 00000058 8f3d0ef2 00000028 000000e9 00000000
[ 596.970956]
[ 596.970956] R2: 0xdd48fd38:
[ 596.977524] fd38 00000007 c0013020 fed91000 dd48fd70 c0c21484 dd48fda4 c5b61c00 00000002
[ 596.991544] fd58 dcf72f40 c0008558 c086342c 60070113 ffffffff c000d600 c1f3bcc0 dd7caa00
[ 597.005572] fd78 dd48fdb8 0000f3dd de896e40 c5b61c00 c1f3bcc0 00000000 c5b61c00 00000002
[ 597.019423] fd98 dcf72f40 dd48fdcc de8d8044 dd48fdb8 c0061d08 c086342c 60070113 ffffffff
[ 597.033514] fdb8 c0c15cc0 c1f3bcc0 dd48e000 c5a3ea80 dd48fe54 c0862360 dd48fec8 dd48e000
[ 597.047561] fdd8 c1f396f0 00000002 c0c136b8 c0c15cc0 0000c350 00000000 00000038 0000ac65
[ 597.061427] fdf8 00000001 00000000 dd142500 c0059d50 eb70ccf3 0000008c c1f3bcc0 a00d0013
[ 597.075353] fe18 b72eba20 dd48fe90 dd48fec8 eb7009a3 0000008c b72eba20 ffffecc8 dd48e000
[ 597.089768]
[ 597.089768] R4: 0xde896dc0:
[ 597.096088] 6dc0 00000000 de896dc4 de896dc4 00000000 00000000 00000000 00000000 00000000
[ 597.109785] 6de0 00000000 00000020 00000000 0000c350 0000c350 00000000 00000000 00000000
[ 597.123489] 6e00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 597.136874] 6e20 00000001 00000000 ffffefff fffbffff fdfdf6ff f7eefbff fffeffff ffff7fdf
[ 597.150842] 6e40 00000000 de8d8000 00000003 04208040 00000000 00000000 00000000 00000001
[ 597.164520] 6e60 00000078 00000078 00000078 00000000 c0869474 00000000 00000400 00400000
[ 597.178483] 6e80 00000001 dcf72f80 00000000 dcf72f8c dd7caa4c 00000001 c7ca73a7 0000008a
[ 597.192473] 6ea0 a4611b2e 00000003 6fa21fbb 00000058 a437ea55 00000003 00000001 00000000
[ 597.206618]
[ 597.206618] R5: 0xc5b61b80:
[ 597.213009] 1b80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 597.226353] 1ba0 c0c46660 00000008 000003c2 00000000 00000000 b6f5f000 0000008d 00000000
[ 597.239970] 1bc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 597.253254] 1be0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 597.266537] 1c00 dced9e18 dc9f6118 dc9f6e70 c0019acc c00eed38 b6f36000 00000000 bf000000
[ 597.280576] 1c20 00000000 b6f36000 be98b000 dcefc000 00000001 00000003 000000ff 00670067
[ 597.294348] 1c40 00000000 131a131a c5b61c48 c5b61c48 c5b61c50 c5b61c50 0000012e 00001d6b
[ 597.308282] 1c60 00001d6a 00000000 00000000 00001c88 00001aff 00000022 00000000 0000000d
[ 597.322215]
[ 597.322215] R6: 0xc1f3bc40:
[ 597.328648] bc40 00000000 de886978 de886978 00000000 00000001 00000000 00000000 00000000
[ 597.342247] bc60 de85b380 00000000 00000000 00000001 00000000 00000000 00000000 00000000
[ 597.355726] bc80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 597.369028] bca0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 597.382315] bcc0 f3ddf3dd 00000003 00000800 00001ba1 000024fc 00002814 00002900 00007720
[ 597.396158] bce0 00000000 00000000 00000000 00000000 000025c4 00000000 0000e4e6 00000000
[ 597.409600] bd00 00010a5f 00000000 000025c4 00000000 00000003 00000003 dc4cb4a2 00000086
[ 597.423311] bd20 6fa21fbb 00000058 6fa21fbb 00000058 de896e80 de896e80 dd7caa38 00000000
[ 597.437696]
[ 597.437696] R8: 0xc5b61b80:
[ 597.444095] 1b80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 597.457427] 1ba0 c0c46660 00000008 000003c2 00000000 00000000 b6f5f000 0000008d 00000000
[ 597.471038] 1bc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 597.484344] 1be0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 597.497612] 1c00 dced9e18 dc9f6118 dc9f6e70 c0019acc c00eed38 b6f36000 00000000 bf000000
[ 597.511579] 1c20 00000000 b6f36000 be98b000 dcefc000 00000001 00000003 000000ff 00670067
[ 597.525310] 1c40 00000000 131a131a c5b61c48 c5b61c48 c5b61c50 c5b61c50 0000012e 00001d6b
[ 597.539255] 1c60 00001d6a 00000000 00000000 00001c88 00001aff 00000022 00000000 0000000d
[ 597.553422]
[ 597.553422] R10: 0xdcf72ec0:
[ 597.560028] 2ec0 00000000 dcf72ec4 dcf72ec4 00000000 00000000 00000000 00000000 00000000
[ 597.573634] 2ee0 00000000 00000020 00000000 0000c350 0000c350 00000000 00000000 00000000
[ 597.587207] 2f00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 597.600531] 2f20 00000001 00000000 6e4f246e 63656843 4364656b 676e6168 73694c65 656e6574
[ 597.614473] 2f40 00000000 dc918000 00000002 00400000 00000000 00000000 00000000 00000001
[ 597.628049] 2f60 00000078 00000078 00000078 00000000 c0869474 00000000 00000400 00400000
[ 597.641810] 2f80 de896e80 00000000 00000000 c1f3c19c de896e8c 00000001 c7a142ce 0000008a
[ 597.655604] 2fa0 db95f807 0000001a 6fe030de 00000058 db1a0d14 0000001a 00000084 00000000
[ 597.671505] CPU: 2 PID: 212 Comm: DispSync Not tainted 3.10.0 #0
[ 597.682156] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 597.691834] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 597.701060] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 597.710565] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 597.716941] Exception stack(0xdd48fd70 to 0xdd48fdb8)
[ 597.723818] fd60: c1f3bcc0 dd7caa00 dd48fdb8 0000f3dd
[ 597.732225] fd80: de896e40 c5b61c00 c1f3bcc0 00000000 c5b61c00 00000002 dcf72f40 dd48fdcc
[ 597.739966] fda0: de8d8044 dd48fdb8 c0061d08 c086342c 60070113 ffffffff
[ 597.749956] [] (__irq_svc+0x40/0x70) from [] (_raw_spin_unlock_irq+0x1c/0x44)
[ 597.760539] [] (_raw_spin_unlock_irq+0x1c/0x44) from [] (finish_task_switch+0x5c/0xd4)
[ 597.770841] [] (finish_task_switch+0x5c/0xd4) from [] (__schedule+0x4a0/0x554)
[ 597.780714] [] (__schedule+0x4a0/0x554) from [] (futex_wait_queue_me+0xf8/0x154)
[ 597.790189] [] (futex_wait_queue_me+0xf8/0x154) from [] (futex_wait+0xe8/0x188)
[ 597.799524] [] (futex_wait+0xe8/0x188) from [] (do_futex+0xbc/0x184)
[ 597.808728] [] (do_futex+0xbc/0x184) from [] (SyS_futex+0x124/0x168)
[ 597.818248] [] (SyS_futex+0x124/0x168) from [] (ret_fast_syscall+0x0/0x30)
[ 597.824910] IPI backtrace for cpu 0
[ 597.829922]
[ 597.835938] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 597.842126] task: dc9d0a80 ti: dcf64000 task.ti: dcf64000
[ 597.848852] PC is at __do_softirq+0x78/0x2b4
[ 597.854763] LR is at msecs_to_jiffies+0x18/0x24
[ 597.861500] pc : [] lr : [] psr: 60070113
[ 597.861500] sp : dcf65e68 ip : 00000000 fp : 0000000a
[ 597.870674] r10: dcf65f7c r9 : 00000000 r8 : b6f0f000
[ 597.876490] r7 : dcf65f0c r6 : 00000002 r5 : 00000000 r4 : dcf64000
[ 597.882499] r3 : 00000000 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 597.889138] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 597.895729] Control: 10c5387d Table: 1c94406a DAC: 00000015
[ 597.900951]
[ 597.900951] PC: 0xc003ddd8:
[ 597.907557] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 597.922935] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 597.937662] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 597.952171] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 597.966759] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 597.981399] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 597.995983] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 598.010627] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 598.025591]
[ 598.025591] LR: 0xc003cee4:
[ 598.032054] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 598.046601] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 598.061065] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 598.075570] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 598.089962] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 598.104347] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 598.118751] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 598.133290] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 598.148216]
[ 598.148216] SP: 0xdcf65de8:
[ 598.154638] 5de8 00000007 c0013020 fed91000 dcf65e20 c0c21484 dcf65e54 b6f0f000 00000000
[ 598.169256] 5e08 dcf65f7c c0008558 c003de58 60070113 ffffffff c000d600 00000001 c0e4c1c0
[ 598.183749] 5e28 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c b6f0f000 00000000
[ 598.197954] 5e48 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58 60070113 ffffffff
[ 598.212327] 5e68 dcf65f0c 0000001d 00000000 00400100 ffff9116 00000000 00000000 60070193
[ 598.226607] 5e88 00000000 c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150
[ 598.240950] 5ea8 dcf64000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c
[ 598.255335] 5ec8 c00f0988 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e
[ 598.270141]
[ 598.270141] R1: 0xc0e4c140:
[ 598.276540] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 598.290339] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 598.304103] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 598.318210] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 598.331850] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 598.345795] c1e0 00000009 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 598.359560] c200 00000002 00000000 00000000 000020b1 00000008 00000002 00000000 00000000
[ 598.373403] c220 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 598.387483]
[ 598.387483] R4: 0xdcf63f80:
[ 598.393800] 3f80 00000000 00000000 00000001 00000000 00000000 a7a9e9df 000000f0 c000db84
[ 598.407944] 3fa0 00000000 c000da00 00000000 00000000 b89fd3e0 00000000 00000001 00000000
[ 598.422077] 3fc0 00000000 00000000 a7a9e9df 000000f0 00000001 b89fd3e0 b878e970 b89fcf28
[ 598.436368] 3fe0 9e9499c8 9e9499b8 b4fa56a7 b6df4964 200f0010 b89fd3e0 000000ab 0312fa12
[ 598.450877] 4000 00000002 00000102 00000000 dc9d0a80 c0c3c138 00000000 00000015 dc9d0a80
[ 598.465160] 4020 c1f29cc0 dcf64000 dd75e000 dd75f180 00000000 dcfb78c0 dcf65d74 dcf65cf0
[ 598.479590] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 598.493524] 4060 b6fa9e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 598.507754]
[ 598.507754] R7: 0xdcf65e8c:
[ 598.514093] 5e8c c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150 dcf64000
[ 598.528617] 5eac c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c c00f0988
[ 598.543010] 5ecc 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e dca0ea50
[ 598.557372] 5eec 80100073 dd75ea80 b6f0e000 b6f0f000 00000000 dcf65f7c 80100071 dcda2500
[ 598.571840] 5f0c dcf65f20 c00f0c50 c00f0988 60070013 ffffffff dd75eac0 80070013 000000af
[ 598.586341] 5f2c dd75eac0 00000000 dc4916c0 b6eed000 00000001 00000000 00000003 b6f0f000
[ 598.600553] 5f4c 00000003 dca0ea50 b6f0e000 b6f0f000 80100073 00000003 c00f0c50 80100073
[ 598.614844] 5f6c 00000000 00001000 00000002 0000201f dca0e948 00000000 00000001 00001000
[ 598.629435]
[ 598.629435] R10: 0xdcf65efc:
[ 598.636004] 5efc 00000000 dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013
[ 598.650509] 5f1c ffffffff dd75eac0 80070013 000000af dd75eac0 00000000 dc4916c0 b6eed000
[ 598.664826] 5f3c 00000001 00000000 00000003 b6f0f000 00000003 dca0ea50 b6f0e000 b6f0f000
[ 598.679038] 5f5c 80100073 00000003 c00f0c50 80100073 00000000 00001000 00000002 0000201f
[ 598.693220] 5f7c dca0e948 00000000 00000001 00001000 00000000 0000007d c000db84 dcf64000
[ 598.707582] 5f9c 00000000 b6f0e024 c000da00 00000001 00001000 b6f0e000 00001000 00000003
[ 598.721824] 5fbc b6f927b8 00000001 00001000 00000000 0000007d b6f0e000 0000000c b6f8c7bc
[ 598.736021] 5fdc b6f0e024 b6f43af5 bebc1828 b6f6a02f b6f6c13c 20070010 b6f0e000 990ae00d
[ 598.752590] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 598.762749] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 598.772235] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 598.781431] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 598.790691] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 598.797000] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 598.804651] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 598.812912] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 598.819299] 5e60: 60070113 ffffffff
[ 598.827849] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 598.836914] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 598.845603] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 598.854690] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 598.863751] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 598.872895] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 598.879268] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 598.885249] 5ec0: 00000000 dcf65f7c
[ 598.893536] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 598.901868] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 598.911504] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 598.920918] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 598.930344] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 598.937341] IPI backtrace for cpu 3
[ 598.943488]
[ 598.950090] CPU: 3 PID: 826 Comm: putmethod.latin Not tainted 3.10.0 #0
[ 598.957125] task: dcfb39c0 ti: dca34000 task.ti: dca34000
[ 598.964456] PC is at __do_softirq+0x78/0x2b4
[ 598.970536] LR is at msecs_to_jiffies+0x18/0x24
[ 598.977431] pc : [] lr : [] psr: 600d0113
[ 598.977431] sp : dca35f40 ip : 00000000 fp : 0000000a
[ 598.986966] r10: 000007c7 r9 : fffffffc r8 : beb04874
[ 598.992854] r7 : b52048c0 r6 : 00000002 r5 : 00000000 r4 : dca34000
[ 598.998881] r3 : 00000003 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 599.005648] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 599.012269] Control: 10c5387d Table: 1cfa806a DAC: 00000015
[ 599.017649]
[ 599.017649] PC: 0xc003ddd8:
[ 599.024334] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 599.039907] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 599.054732] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 599.069320] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 599.083915] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 599.098420] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 599.112895] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 599.127562] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 599.142590]
[ 599.142590] LR: 0xc003cee4:
[ 599.149102] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 599.163701] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 599.178172] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 599.192674] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 599.207141] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 599.221695] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 599.236140] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 599.250698] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 599.265557]
[ 599.265557] SP: 0xdca35ec0:
[ 599.271911] 5ec0 00000007 c0013020 fed91000 dca35ef8 c0c21484 dca35f2c beb04874 fffffffc
[ 599.286532] 5ee0 000007c7 c0008558 c003de58 600d0113 ffffffff c000d600 00000001 c0e4c1c0
[ 599.301034] 5f00 00000000 00000003 dca34000 00000000 00000002 b52048c0 beb04874 fffffffc
[ 599.315238] 5f20 000007c7 0000000a 00000000 dca35f40 c003cf64 c003de58 600d0113 ffffffff
[ 599.329649] 5f40 b52048c0 0000001d fffffffc 00400140 00007721 00000003 00000000 600d0193
[ 599.344076] 5f60 00000000 c0c21484 b52048c0 beb04874 fffffffc 000007c7 00000aec c003e150
[ 599.358476] 5f80 dca34000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dca35fb0 c000853c
[ 599.372887] 5fa0 b514f676 800d0030 ffffffff c000d7bc 00000003 00000001 0000002f af9bdf5b
[ 599.387670]
[ 599.387670] R1: 0xc0e4c140:
[ 599.394126] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 599.407939] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 599.421775] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 599.435923] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 599.449623] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 599.463580] c1e0 00000009 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 599.477299] c200 00000002 00000000 00000000 000020b1 00000008 00000002 00000000 00000000
[ 599.491071] c220 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 599.505170]
[ 599.505170] R4: 0xdca33f80:
[ 599.511498] 3f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 599.525341] 3fa0 00000000 00000000 dce36518 dce36540 dce36500 dce36500 000001c0 00000001
[ 599.539707] 3fc0 00003c16 00004f4c 00004216 00004f50 00004316 00004f54 00004416 00004f58
[ 599.554028] 3fe0 00004516 00004f5c 00004616 00004f60 00004716 00004f64 00004a16 00004f68
[ 599.568278] 4000 00000002 00000102 00000000 dcfb39c0 c0c3c138 00000003 00000015 dcfb39c0
[ 599.582632] 4020 c1f44cc0 dca34000 dd75e1c0 dd75efc0 00000003 dcf75e80 dca35f9c dca35f18
[ 599.597096] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 01000000
[ 599.611282] 4060 b6f6be30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 599.627471] CPU: 3 PID: 826 Comm: putmethod.latin Not tainted 3.10.0 #0
[ 599.638157] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 599.647872] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 599.656955] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 599.666445] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 599.672953] Exception stack(0xdca35ef8 to 0xdca35f40)
[ 599.679198] 5ee0: 00000001 c0e4c1c0
[ 599.687556] 5f00: 00000000 00000003 dca34000 00000000 00000002 b52048c0 beb04874 fffffffc
[ 599.695971] 5f20: 000007c7 0000000a 00000000 dca35f40 c003cf64 c003de58 600d0113 ffffffff
[ 599.705674] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 599.714679] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 599.723526] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 599.732628] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 599.741794] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 599.750855] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 599.757194] Exception stack(0xdca35fb0 to 0xdca35ff8)
[ 599.763808] 5fa0: 00000003 00000001 0000002f af9bdf5b
[ 599.772282] 5fc0: 00000200 07fffffe 00000001 b52048c0 beb04874 fffffffc 000007c7 00000aec
[ 599.779994] 5fe0: 00000009 beb04868 b500202d b514f676 800d0030 ffffffff
[ 614.896832] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 615.048921] [mmc0] – Timeout recovery procedure start –
[ 615.119797] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 615.134753] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 615.210159] [mmc0] – Timeout recovery procedure finished –
[ 615.476211] mmcblk0: error -110 sending status command, retrying
[ 640.311073] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 640.603635] [mmc0] – Timeout recovery procedure start –
[ 640.756383] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 641.196245] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 641.334029] [mmc0] – Timeout recovery procedure finished –
[ 641.578834] mmcblk0: error -110 sending status command, aborting
[ 641.717739] end_request: I/O error, dev mmcblk0, sector 340056
[ 641.846834] Buffer I/O error on device mmcblk0p8, logical block 523
[ 641.961657] lost page write due to I/O error on mmcblk0p8
[ 642.209508] JBD2: Error -5 detected when updating journal superblock for mmcblk0p8-8.
[ 650.477313] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD25): error = -110, timeout = 8000ms
[ 650.564874] [mmc0] – Timeout recovery procedure start –
[ 650.604893] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 650.789700] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 650.837005] [mmc0] – Timeout recovery procedure finished –
[ 657.866300] INFO: rcu_preempt detected stalls on CPUs/tasks: { 0} (detected by 1, t=65192 jiffies, g=85, c=84, q=3849)
[ 657.880625] Backtrace for cpu 1 (current):
[ 657.887825] CPU: 1 PID: 1 Comm: init Not tainted 3.10.0 #0
[ 657.899593] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 657.909725] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 657.920467] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_other_cpu_stall+0x264/0x2e0)
[ 657.931096] [] (print_other_cpu_stall+0x264/0x2e0) from [] (__rcu_pending+0x90/0x190)
[ 657.941240] [] (__rcu_pending+0x90/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 657.952305] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 657.963253] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 657.973566] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 657.983909] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 657.994959] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 658.006682] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 658.018063] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 658.028774] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 658.038411] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 658.047528] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 658.053984] Exception stack(0xde873e08 to 0xde873e50)
[ 658.061270] 3e00: de76c1a0 00000001 de80fc00 c0152cfc de76c1a0 00000001
[ 658.069688] 3e20: de872000 dd2c7020 00000000 de873e88 00000004 0005358c 6b736174 de873e50
[ 658.076614] 3e40: c0114d28 c0152cfc a0070013 ffffffff
[ 658.085972] [] (__irq_svc+0x40/0x70) from [] (proc_pid_permission+0x0/0xc0)
[ 658.095059] [] (proc_pid_permission+0x0/0xc0) from [] (0xde76c1a0)
[ 658.100702]
[ 658.100702] sending IPI to all other CPUs:
[ 658.109669] IPI backtrace for cpu 0
[ 658.114636]
[ 658.120535] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 658.126709] task: dc9d0a80 ti: dcf64000 task.ti: dcf64000
[ 658.133390] PC is at __do_softirq+0x78/0x2b4
[ 658.139229] LR is at msecs_to_jiffies+0x18/0x24
[ 658.145895] pc : [] lr : [] psr: 60070113
[ 658.145895] sp : dcf65e68 ip : 00000000 fp : 0000000a
[ 658.155065] r10: dcf65f7c r9 : 00000000 r8 : b6f0f000
[ 658.160923] r7 : dcf65f0c r6 : 00000002 r5 : 00000000 r4 : dcf64000
[ 658.166870] r3 : 00000000 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 658.173465] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 658.179853] Control: 10c5387d Table: 1c94406a DAC: 00000015
[ 658.185128]
[ 658.185128] PC: 0xc003ddd8:
[ 658.191850] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 658.207010] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 658.221695] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 658.236332] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 658.250890] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 658.265485] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 658.280017] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 658.294687] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 658.309644]
[ 658.309644] LR: 0xc003cee4:
[ 658.316182] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 658.330668] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 658.345222] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 658.359697] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 658.374161] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 658.388655] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 658.403089] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 658.417598] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 658.432449]
[ 658.432449] SP: 0xdcf65de8:
[ 658.438968] 5de8 00000007 c0013020 fed91000 dcf65e20 c0c21484 dcf65e54 b6f0f000 00000000
[ 658.453507] 5e08 dcf65f7c c0008558 c003de58 60070113 ffffffff c000d600 00000001 c0e4c1c0
[ 658.467948] 5e28 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c b6f0f000 00000000
[ 658.482115] 5e48 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58 60070113 ffffffff
[ 658.496492] 5e68 dcf65f0c 0000001d 00000000 00400100 ffff9116 00000000 00000000 60070193
[ 658.510851] 5e88 00000000 c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150
[ 658.525232] 5ea8 dcf64000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c
[ 658.539677] 5ec8 c00f0988 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e
[ 658.554618]
[ 658.554618] R1: 0xc0e4c140:
[ 658.561232] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 658.575147] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 658.588892] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 658.603138] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 658.616888] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 658.630855] c1e0 0000000a 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 658.644574] c200 00000082 00000000 00000000 00002117 00000008 00000002 00000000 00000000
[ 658.658523] c220 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 658.672675]
[ 658.672675] R4: 0xdcf63f80:
[ 658.679160] 3f80 00000000 00000000 00000001 00000000 00000000 a7a9e9df 000000f0 c000db84
[ 658.693372] 3fa0 00000000 c000da00 00000000 00000000 b89fd3e0 00000000 00000001 00000000
[ 658.707445] 3fc0 00000000 00000000 a7a9e9df 000000f0 00000001 b89fd3e0 b878e970 b89fcf28
[ 658.721759] 3fe0 9e9499c8 9e9499b8 b4fa56a7 b6df4964 200f0010 b89fd3e0 000000ab 0312fa12
[ 658.736328] 4000 00000002 00000102 00000000 dc9d0a80 c0c3c138 00000000 00000015 dc9d0a80
[ 658.750769] 4020 c1f29cc0 dcf64000 dd75e000 dd75f180 00000000 dcfb78c0 dcf65d74 dcf65cf0
[ 658.765210] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 658.779313] 4060 b6fa9e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 658.793638]
[ 658.793638] R7: 0xdcf65e8c:
[ 658.800180] 5e8c c0c21484 dcf65f0c b6f0f000 00000000 dcf65f7c 80100071 c003e150 dcf64000
[ 658.814737] 5eac c003e3bc 0000001d c000e3d0 0000001d fed91000 dcf65ed8 c000853c c00f0988
[ 658.829228] 5ecc 60070013 ffffffff c000d600 00000000 dcf65f7c 00000000 000b6f0e dca0ea50
[ 658.843579] 5eec 80100073 dd75ea80 b6f0e000 b6f0f000 00000000 dcf65f7c 80100071 dcda2500
[ 658.858054] 5f0c dcf65f20 c00f0c50 c00f0988 60070013 ffffffff dd75eac0 80070013 000000af
[ 658.872555] 5f2c dd75eac0 00000000 dc4916c0 b6eed000 00000001 00000000 00000003 b6f0f000
[ 658.886778] 5f4c 00000003 dca0ea50 b6f0e000 b6f0f000 80100073 00000003 c00f0c50 80100073
[ 658.901163] 5f6c 00000000 00001000 00000002 0000201f dca0e948 00000000 00000001 00001000
[ 658.915868]
[ 658.915868] R10: 0xdcf65efc:
[ 658.922466] 5efc 00000000 dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013
[ 658.936967] 5f1c ffffffff dd75eac0 80070013 000000af dd75eac0 00000000 dc4916c0 b6eed000
[ 658.951375] 5f3c 00000001 00000000 00000003 b6f0f000 00000003 dca0ea50 b6f0e000 b6f0f000
[ 658.965602] 5f5c 80100073 00000003 c00f0c50 80100073 00000000 00001000 00000002 0000201f
[ 658.979881] 5f7c dca0e948 00000000 00000001 00001000 00000000 0000007d c000db84 dcf64000
[ 658.994210] 5f9c 00000000 b6f0e024 c000da00 00000001 00001000 b6f0e000 00001000 00000003
[ 659.008538] 5fbc b6f927b8 00000001 00001000 00000000 0000007d b6f0e000 0000000c b6f8c7bc
[ 659.022731] 5fdc b6f0e024 b6f43af5 bebc1828 b6f6a02f b6f6c13c 20070010 b6f0e000 990ae00d
[ 659.039282] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 659.049478] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 659.058968] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 659.068307] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 659.077721] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 659.084053] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 659.091618] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 659.099961] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 659.106281] 5e60: 60070113 ffffffff
[ 659.114921] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 659.123850] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 659.132565] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 659.141626] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 659.150710] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 659.159572] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 659.165892] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 659.171862] 5ec0: 00000000 dcf65f7c
[ 659.180152] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 659.188484] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 659.197925] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 659.207373] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 659.216795] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 659.223736] IPI backtrace for cpu 3
[ 659.229575]
[ 659.236128] CPU: 3 PID: 441 Comm: EventThread Not tainted 3.10.0 #0
[ 659.243072] task: dd143480 ti: dd4e6000 task.ti: dd4e6000
[ 659.250227] PC is at __do_softirq+0x78/0x2b4
[ 659.256246] LR is at msecs_to_jiffies+0x18/0x24
[ 659.263044] pc : [] lr : [] psr: 600d0113
[ 659.263044] sp : dd4e7f40 ip : 00000000 fp : 0000000a
[ 659.272458] r10: 00000001 r9 : b251bd08 r8 : b73cbde8
[ 659.278395] r7 : b6e61bc6 r6 : 00000002 r5 : 00000000 r4 : dd4e6000
[ 659.284403] r3 : 00000003 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 659.290900] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 659.297528] Control: 10c5387d Table: 1d48806a DAC: 00000015
[ 659.302766]
[ 659.302766] PC: 0xc003ddd8:
[ 659.309488] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 659.325129] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 659.339995] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 659.354587] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 659.369092] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 659.383571] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 659.398072] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 659.412570] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 659.427515]
[ 659.427515] LR: 0xc003cee4:
[ 659.433974] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 659.448528] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 659.463014] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 659.477489] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 659.491916] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 659.506364] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 659.520821] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 659.535239] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 659.550105]
[ 659.550105] SP: 0xdd4e7ec0:
[ 659.556666] 7ec0 00000007 c0013020 fed91000 dd4e7ef8 c0c21484 dd4e7f2c b73cbde8 b251bd08
[ 659.571322] 7ee0 00000001 c0008558 c003de58 600d0113 ffffffff c000d600 00000001 c0e4c1c0
[ 659.585786] 7f00 00000000 00000003 dd4e6000 00000000 00000002 b6e61bc6 b73cbde8 b251bd08
[ 659.600106] 7f20 00000001 0000000a 00000000 dd4e7f40 c003cf64 c003de58 600d0113 ffffffff
[ 659.614382] 7f40 b6e61bc6 0000001d b251bd08 00400040 00008fc6 00000003 00000000 600d0193
[ 659.628748] 7f60 00000000 c0c21484 b6e61bc6 b73cbde8 b251bd08 00000001 b73b9d6c c003e150
[ 659.643096] 7f80 dd4e6000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dd4e7fb0 c000853c
[ 659.657507] 7fa0 b6e2df3e 600d0030 ffffffff c000d7bc b251bd24 00000000 ffffffc8 b6e33530
[ 659.672380]
[ 659.672380] R1: 0xc0e4c140:
[ 659.678866] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 659.692713] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 659.706470] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 659.720532] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 659.734198] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 659.748064] c1e0 0000000a 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 659.761769] c200 00000082 00000000 00000000 00002117 00000008 00000002 00000000 00000000
[ 659.775582] c220 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 659.789644]
[ 659.789644] R4: 0xdd4e5f80:
[ 659.796046] 5f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 659.809758] 5fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 659.823395] 5fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 659.837111] 5fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 659.850751] 6000 00000002 00000102 00000000 dd143480 c0c3c138 00000003 00000015 dd143480
[ 659.864925] 6020 c1f44cc0 dd4e6000 c5a3ea80 c5b61c00 00000003 dcf72f40 dd4e7d54 dd4e7cd0
[ 659.879291] 6040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 659.893304] 6060 b251bdd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 659.909452] CPU: 3 PID: 441 Comm: EventThread Not tainted 3.10.0 #0
[ 659.920096] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 659.929631] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 659.938752] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 659.948061] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 659.954618] Exception stack(0xdd4e7ef8 to 0xdd4e7f40)
[ 659.960859] 7ee0: 00000001 c0e4c1c0
[ 659.969108] 7f00: 00000000 00000003 dd4e6000 00000000 00000002 b6e61bc6 b73cbde8 b251bd08
[ 659.977316] 7f20: 00000001 0000000a 00000000 dd4e7f40 c003cf64 c003de58 600d0113 ffffffff
[ 659.987129] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 659.996355] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 660.005108] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 660.014312] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 660.023625] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 660.032675] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 660.038874] Exception stack(0xdd4e7fb0 to 0xdd4e7ff8)
[ 660.045525] 7fa0: b251bd24 00000000 ffffffc8 b6e33530
[ 660.053827] 7fc0: b251bd24 00000001 b251bd38 b6e61bc6 b73cbde8 b251bd08 00000001 b73b9d6c
[ 660.061501] 7fe0: b6e6aae0 b251bcf8 b6e46789 b6e2df3e 600d0030 ffffffff
[ 660.067990] IPI backtrace for cpu 2
[ 660.073938]
[ 660.080720] CPU: 2 PID: 212 Comm: DispSync Not tainted 3.10.0 #0
[ 660.087484] task: dd7caa00 ti: dd48e000 task.ti: dd48e000
[ 660.094816] PC is at __do_softirq+0x78/0x2b4
[ 660.100831] LR is at msecs_to_jiffies+0x18/0x24
[ 660.107761] pc : [] lr : [] psr: 600d0113
[ 660.107761] sp : dd48fd30 ip : 00000000 fp : 0000000a
[ 660.117100] r10: c0059d50 r9 : 00000000 r8 : c0c136b8
[ 660.123247] r7 : dd48fdd4 r6 : 00000102 r5 : 00000000 r4 : dd48e000
[ 660.129297] r3 : 00000002 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 660.135899] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 660.142486] Control: 10c5387d Table: 1d48806a DAC: 00000015
[ 660.147723]
[ 660.147723] PC: 0xc003ddd8:
[ 660.154370] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 660.169849] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 660.184779] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 660.200424] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 660.215113] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 660.230825] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 660.246297] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 660.260990] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 660.276104]
[ 660.276104] LR: 0xc003cee4:
[ 660.282657] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 660.297185] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 660.311626] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 660.326098] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 660.340479] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 660.355841] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 660.370376] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 660.384761] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 660.399623]
[ 660.399623] SP: 0xdd48fcb0:
[ 660.406026] fcb0 00000007 c0013020 fed91000 dd48fce8 c0c21484 dd48fd1c c0c136b8 00000000
[ 660.420486] fcd0 c0059d50 c0008558 c003de58 600d0113 ffffffff c000d600 00000001 c0e4c1c0
[ 660.434916] fcf0 00000000 00000002 dd48e000 00000000 00000102 dd48fdd4 c0c136b8 00000000
[ 660.449177] fd10 c0059d50 0000000a 00000000 dd48fd30 c003cf64 c003de58 600d0113 ffffffff
[ 660.463524] fd30 dd48fdd4 0000001d 00000000 00400040 00008fc6 00000002 00000000 600d0193
[ 660.477894] fd50 00000000 c0c21484 dd48fdd4 c0c136b8 00000000 c0059d50 dd48fde8 c003e150
[ 660.492215] fd70 dd48e000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dd48fda0 c000853c
[ 660.506679] fd90 c0059cd0 200d0013 ffffffff c000d600 00000001 600d0093 00000000 a00d0013
[ 660.521519]
[ 660.521519] R1: 0xc0e4c140:
[ 660.527910] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 660.541765] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 660.555578] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 660.569749] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 660.583502] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 660.597492] c1e0 0000000a 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 660.611305] c200 00000082 00000000 00000000 00002117 00000008 00000002 00000000 00000000
[ 660.625187] c220 00000003 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 660.639289]
[ 660.639289] R4: 0xdd48df80:
[ 660.645674] df80 00000003 00000001 b6b01d18 b72ebcd8 b72ebd08 b72ebca8 00000036 c000db84
[ 660.660073] dfa0 00000000 c000da00 b72ebcd8 b72ebd08 00000003 c0186201 b6b01d18 b6b01d10
[ 660.674349] dfc0 b72ebcd8 b72ebd08 b72ebca8 00000036 00000001 b72ea310 b6eb357d b6b01dd0
[ 660.688572] dfe0 b72ea1f8 b6b01d00 b6edfafd b6ed9828 600d0010 00000003 e59d5078 e1a071c7
[ 660.702938] e000 00000002 00000102 00000000 dd7caa00 c0c3c138 00000002 00000015 dd7caa00
[ 660.717147] e020 c1f3bcc0 dd48e000 c5a3ea80 dd6b9340 00000002 dc9ac980 dd48fe54 dd48fdd0
[ 660.731573] e040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 660.745570] e060 b6a01dd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 660.759884]
[ 660.759884] R7: 0xdd48fd54:
[ 660.766369] fd54 c0c21484 dd48fdd4 c0c136b8 00000000 c0059d50 dd48fde8 c003e150 dd48e000
[ 660.780908] fd74 c003e3bc 0000001d c000e3d0 0000001d fed91000 dd48fda0 c000853c c0059cd0
[ 660.795259] fd94 200d0013 ffffffff c000d600 00000001 600d0093 00000000 a00d0013 dd48fec8
[ 660.809524] fdb4 dd48e000 c1f396f0 00000002 c0c136b8 00000000 c0059d50 dd48fde8 00000110
[ 660.823773] fdd4 dd48fde8 c0065708 c0059cd0 200d0013 ffffffff 0000c350 00000000 00000038
[ 660.838087] fdf4 0000a516 00000001 00000000 dd7caa38 c0059d50 99b62c95 0000009b c1f3bcc0
[ 660.852366] fe14 a00d0013 b72eba20 dd48fe90 dd48fec8 99b56945 0000009b b72eba20 ffffeaa8
[ 660.866755] fe34 00000000 ffffffff c0059d50 0000c350 00000000 00000001 0000009b dd48fe90
[ 660.881309]
[ 660.881309] R8: 0xc0c13638:
[ 660.887772] 3638 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 660.901559] 3658 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 660.915327] 3678 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 660.929156] 3698 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 660.942924] 36b8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 660.956719] 36d8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 660.970487] 36f8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 660.984217] 3718 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 660.998456]
[ 660.998456] R10: 0xc0059cd0:
[ 661.005821] 9cd0 ea000005 e3a00008 ebff91d5 e5943024 e59d102c e5930000 eb2025b7 e1a00009
[ 661.020747] 9cf0 e28dd034 e8bd8ff0 c0da7dc4 c0c136b8 c0c204b8 c0c212a8 e92d401f e3a01000
[ 661.035346] 9d10 e58d1000 e59d1018 e58d1004 e3a01001 e58d1008 ebffff12 e28dd014 e8bd8000
[ 661.049837] 9d30 e92d401f e59d1018 e58d1000 e59d101c e58d1004 e3a01001 e58d1008 ebffff08
[ 661.064330] 9d50 e28dd014 e8bd8000 e92d47f0 e24dd018 e59f40dc e1a07000 ee1d5f90 e1a03004
[ 661.078723] 9d70 e2844018 e0855003 e1a00005 eb2024c3 ee1d3f90 e7933004 e3530000 e1a09000
[ 661.093172] 9d90 1a00001c e2856038 e2858f46 e285a044 e3e02000 e1a04006 e3e03102 e1cd20f0
[ 661.107575] 9db0 e0663004 e083300a e5933004 e3530000 0a00000c e1c301d0 e5943020 e1cd00f8
[ 661.124396] CPU: 2 PID: 212 Comm: DispSync Not tainted 3.10.0 #0
[ 661.135142] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 661.144786] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 661.154068] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 661.163479] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 661.169852] Exception stack(0xdd48fce8 to 0xdd48fd30)
[ 661.177093] fce0: 00000001 c0e4c1c0 00000000 00000002 dd48e000 00000000
[ 661.185477] fd00: 00000102 dd48fdd4 c0c136b8 00000000 c0059d50 0000000a 00000000 dd48fd30
[ 661.192553] fd20: c003cf64 c003de58 600d0113 ffffffff
[ 661.201596] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 661.210593] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 661.219364] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 661.228406] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 661.237407] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 661.246277] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 661.252522] Exception stack(0xdd48fda0 to 0xdd48fde8)
[ 661.260274] fda0: 00000001 600d0093 00000000 a00d0013 dd48fec8 dd48e000 c1f396f0 00000002
[ 661.268696] fdc0: c0c136b8 00000000 c0059d50 dd48fde8 00000110 dd48fde8 c0065708 c0059cd0
[ 661.274982] fde0: 200d0013 ffffffff
[ 661.284047] [] (__irq_svc+0x40/0x70) from [] (__hrtimer_start_range_ns+0x35c/0x394)
[ 661.294462] [] (__hrtimer_start_range_ns+0x35c/0x394) from [] (hrtimer_start_range_ns+0x20/0x28)
[ 661.304643] [] (hrtimer_start_range_ns+0x20/0x28) from [] (futex_wait_queue_me+0xa8/0x154)
[ 661.314637] [] (futex_wait_queue_me+0xa8/0x154) from [] (futex_wait+0xe8/0x188)
[ 661.324077] [] (futex_wait+0xe8/0x188) from [] (do_futex+0xbc/0x184)
[ 661.333353] [] (do_futex+0xbc/0x184) from [] (SyS_futex+0x124/0x168)
[ 661.342910] [] (SyS_futex+0x124/0x168) from [] (ret_fast_syscall+0x0/0x30)
[ 675.529218] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 675.567669] [mmc0] – Timeout recovery procedure start –
[ 675.580750] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 675.588382] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 675.597387] [mmc0] – Timeout recovery procedure finished –
[ 675.823062] mmcblk0: error -110 sending status command, retrying
[ 700.526239] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 700.534138] [mmc0] – Timeout recovery procedure start –
[ 700.545237] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 700.552459] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 700.561268] [mmc0] – Timeout recovery procedure finished –
[ 700.567784] mmcblk0: error -110 sending status command, retrying
[ 719.879937] INFO: rcu_preempt self-detected stall on CPU { 0} (t=71495 jiffies g=85 c=84 q=4276)
[ 719.892453] Backtrace for cpu 0 (current):
[ 719.899213] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 719.910003] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 719.919768] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 719.929840] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_cpu_stall+0xb4/0x138)
[ 719.939972] [] (print_cpu_stall+0xb4/0x138) from [] (__rcu_pending+0x68/0x190)
[ 719.949887] [] (__rcu_pending+0x68/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 719.960866] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 719.971769] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 719.981920] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 719.992553] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 720.003757] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 720.015984] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 720.027451] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 720.038162] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 720.048272] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 720.057803] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 720.064180] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 720.071884] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 720.080099] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 720.086359] 5e60: 60070113 ffffffff
[ 720.094728] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 720.103812] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 720.112688] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 720.121693] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 720.130825] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 720.139777] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 720.146022] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 720.151997] 5ec0: 00000000 dcf65f7c
[ 720.160370] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 720.168720] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 720.178078] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 720.187399] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 720.196851] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 720.202584]
[ 720.202584] sending IPI to all other CPUs:
[ 720.211055] IPI backtrace for cpu 2
[ 720.217003]
[ 720.223537] CPU: 2 PID: 437 Comm: RepaintThread Not tainted 3.10.0 #0
[ 720.230290] task: dd1424c0 ti: dd578000 task.ti: dd578000
[ 720.237621] PC is at drop_futex_key_refs+0x50/0x98
[ 720.243840] LR is at futex_wake+0x114/0x120
[ 720.250728] pc : [] lr : [] psr: 800d0013
[ 720.250728] sp : dd579f08 ip : dd579f20 fp : b2b94dd0
[ 720.259932] r10: c0e601dc r9 : dd578000 r8 : c0e601e0
[ 720.265827] r7 : c0e601d4 r6 : 00000000 r5 : 7fffffff r4 : ffffffff
[ 720.272038] r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : c5a3ea80
[ 720.278614] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 720.285182] Control: 10c5387d Table: 1d48806a DAC: 00000015
[ 720.290589]
[ 720.290589] PC: 0xc0083454:
[ 720.297206] 3454 e3a03000 e5848018 e584302c e3a01003 e5940014 ebff88bf ea000000 e3e06015
[ 720.312422] 3474 e1a00006 e28dd014 e8bd85f0 c0a67a91 e92d4010 e1a03000 e5900004 e3500000
[ 720.326950] 3494 1a000009 e59f4074 e5d43000 e3530001 08bd8010 e59f0068 e3a010d0 ebfecd72
[ 720.341304] 34b4 e3a03001 e5c43000 e8bd8010 e5933008 e2033003 e3530001 0a000002 e3530002
[ 720.355464] 34d4 18bd8010 ea000001 e8bd4010 ea02794c e2803034 f57ff05b e1932f9f e2422001
[ 720.369544] 34f4 e1831f92 e3310000 1afffffa f57ff05b e3520000 18bd8010 e8bd4010 eafec548
[ 720.383624] 3514 c0da7a82 c0a67a91 e92d4ff7 e1a08003 e59da030 e1a0300d e3c35d7f e1a06000
[ 720.397644] 3534 e3c5503f e1a09001 e1a07002 e288401c e1a00006 e2071001 e3a03000 e1a02004
[ 720.412251]
[ 720.412251] LR: 0xc00838b8:
[ 720.418740] 38b8 e59d3008 e1520003 1a000010 e5902024 e59d300c e1520003 1a00000c e5903028
[ 720.433058] 38d8 e3530000 1a000010 e590302c e3530000 1a00000d e5903034 e1140003 0a000003
[ 720.447168] 38f8 e2866001 ebfffbde e1560005 aa000007 e597300c e1a00007 e243700c e280300c
[ 720.461305] 3918 e1530008 1affffde ea000000 e3e06015 e1a0000a eb1f7e96 e28d0004 ebfffed2
[ 720.475404] 3938 e1a00006 e28dd014 e8bd85f0 e92d4ff0 e24dd044 e1a0a001 e1a04002 e59d506c
[ 720.489469] 3958 e3a01000 e58d0020 e3a0200c e28d0028 e58d3024 eb07d4cb e3a0200c e28d0034
[ 720.503598] 3978 e3a01000 eb07d4c7 e7ab8655 e3a03001 e3550000 b1a08813 e7e20e55 e7ab6055
[ 720.517633] 3998 e1a0300d e7e35c55 e58d501c e3c35d7f e1e02008 e3c5503f e58d0018 e58d2014
[ 720.532109]
[ 720.532109] SP: 0xdd579e88:
[ 720.538504] 9e88 00000007 c0013020 fed91000 dd579ec0 c0c21484 dd579ef4 c0e601e0 dd578000
[ 720.552757] 9ea8 c0e601dc c0008558 c00834d4 800d0013 ffffffff c000d600 c5a3ea80 00000000
[ 720.566935] 9ec8 00000000 00000000 ffffffff 7fffffff 00000000 c0e601d4 c0e601e0 dd578000
[ 720.580741] 9ee8 c0e601dc b2b94dd0 dd579f20 dd579f08 c0083938 c00834d4 800d0013 ffffffff
[ 720.594788] 9f08 ffffffff c0083938 00000000 b73b9000 c5a3ea80 00000d70 0000c350 00000002
[ 720.608706] 9f28 00000001 00000000 000000f0 7fffffff b73b9d70 c00851c4 b73b9d70 00000081
[ 720.622610] 9f48 7fffffff 00000000 00000001 00000000 00000081 c0085398 7fffffff 00000000
[ 720.636468] 9f68 ffffffff 61657268 00000064 00000000 00000000 000000a2 c000db84 00000000
[ 720.650688]
[ 720.650688] IP: 0xdd579ea0:
[ 720.657237] 9ea0 c0e601e0 dd578000 c0e601dc c0008558 c00834d4 800d0013 ffffffff c000d600
[ 720.671449] 9ec0 c5a3ea80 00000000 00000000 00000000 ffffffff 7fffffff 00000000 c0e601d4
[ 720.685349] 9ee0 c0e601e0 dd578000 c0e601dc b2b94dd0 dd579f20 dd579f08 c0083938 c00834d4
[ 720.699437] 9f00 800d0013 ffffffff ffffffff c0083938 00000000 b73b9000 c5a3ea80 00000d70
[ 720.713491] 9f20 0000c350 00000002 00000001 00000000 000000f0 7fffffff b73b9d70 c00851c4
[ 720.727372] 9f40 b73b9d70 00000081 7fffffff 00000000 00000001 00000000 00000081 c0085398
[ 720.741189] 9f60 7fffffff 00000000 ffffffff 61657268 00000064 00000000 00000000 000000a2
[ 720.754916] 9f80 c000db84 00000000 b731bfd0 7fffffff b73b9d6c b73b9d38 000000f0 c000db84
[ 720.769169]
[ 720.769169] R0: 0xc5a3ea00:
[ 720.775591] ea00 00000000 00000000 00000000 00000000 00000000 000000c3 0000003b 00000000
[ 720.789028] ea20 c0c46660 00000002 00000326 00000000 00000000 b6f6b000 0001008d 00000000
[ 720.802879] ea40 00000000 00000000 ddeee900 c5b16840 00000000 00000000 ffffffbf ffeffffa
[ 720.816670] ea60 ffffffff fffffffc fdb3bffe 7f9d74ff ebfff77d dbfffbea fdf7fffe fff77eff
[ 720.830769] ea80 dcf30b00 dd12b9b0 c5acfe18 c0019acc c00eed38 b6f4d000 00000000 bf000000
[ 720.844736] eaa0 00000000 b6f4d000 beb09000 dd488000 00000018 00000002 000000d5 00860086
[ 720.858576] eac0 00000000 7eea7eea c5a3eac8 c5a3eac8 c5a3ead0 c5a3ead0 00000cc8 000071ee
[ 720.872495] eae0 00007111 00000000 00000000 000055f9 00001668 00000022 00000000 00000038
[ 720.886594]
[ 720.886594] R7: 0xc0e60154:
[ 720.892907] 0154 dcf9de9c 00170017 c0e6015c c0e6015c 01800180 c0e60168 c0e60168 00160016
[ 720.907220] 0174 c0e60174 c0e60174 00140014 dcfd1e9c dcfd1e9c 00410041 c0e6018c c0e6018c
[ 720.921500] 0194 00110011 c0e60198 c0e60198 00120012 c0e601a4 c0e601a4 00160016 c0e601b0
[ 720.935621] 01b4 c0e601b0 002b002b dd7e5e9c dcb59e9c 000f000f c0e601c8 c0e601c8 318b318b
[ 720.949777] 01d4 c0e601d4 c0e601d4 2f922f92 c0e601e0 c0e601e0 000b000b c0e601ec c0e601ec
[ 720.963992] 01f4 00970097 c5b07e9c c5b07e9c 00390039 c0e60204 c0e60204 001c001c dd42fe9c
[ 720.978182] 0214 dd42fe9c 000a000a c0e6021c c0e6021c 00110011 dca3be9c dca3be9c 00080008
[ 720.992224] 0234 dcfe5e9c dcfe5e9c 0d680d68 c0e60240 c0e60240 000b000b c0e6024c c0e6024c
[ 721.006681]
[ 721.006681] R8: 0xc0e60160:
[ 721.012884] 0160 c0e6015c 01800180 c0e60168 c0e60168 00160016 c0e60174 c0e60174 00140014
[ 721.026950] 0180 dcfd1e9c dcfd1e9c 00410041 c0e6018c c0e6018c 00110011 c0e60198 c0e60198
[ 721.040876] 01a0 00120012 c0e601a4 c0e601a4 00160016 c0e601b0 c0e601b0 002b002b dd7e5e9c
[ 721.054836] 01c0 dcb59e9c 000f000f c0e601c8 c0e601c8 318b318b c0e601d4 c0e601d4 2f922f92
[ 721.068818] 01e0 c0e601e0 c0e601e0 000b000b c0e601ec c0e601ec 00970097 c5b07e9c c5b07e9c
[ 721.082842] 0200 00390039 c0e60204 c0e60204 001c001c dd42fe9c dd42fe9c 000a000a c0e6021c
[ 721.096817] 0220 c0e6021c 00110011 dca3be9c dca3be9c 00080008 dcfe5e9c dcfe5e9c 0d680d68
[ 721.110773] 0240 c0e60240 c0e60240 000b000b c0e6024c c0e6024c 000a000a c0e60258 c0e60258
[ 721.125166]
[ 721.125166] R9: 0xdd577f80:
[ 721.131527] 7f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7f0f1e7e
[ 721.145269] 7fa0 00000000 00000000 00000000 00000000 00000000 7f0f7e7e 7f0f8e7e 00000000
[ 721.159022] 7fc0 7f0fae7e 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 721.172569] 7fe0 00000000 00000000 00000000 00000000 7f106e7e 7f107e7e 7f108e7e 00000000
[ 721.186288] 8000 00000000 00000002 00000000 dd1424c0 c0c3c138 00000002 00000015 dd1424c0
[ 721.200019] 8020 c1f3bcc0 dd578000 c5a3ea80 c5a3ea80 00000002 dd143480 dd579efc dd579e78
[ 721.214077] 8040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 721.227747] 8060 b2b94dd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 721.241673]
[ 721.241673] R10: 0xc0e6015c:
[ 721.248170] 015c c0e6015c c0e6015c 01800180 c0e60168 c0e60168 00160016 c0e60174 c0e60174
[ 721.262359] 017c 00140014 dcfd1e9c dcfd1e9c 00410041 c0e6018c c0e6018c 00110011 c0e60198
[ 721.276459] 019c c0e60198 00120012 c0e601a4 c0e601a4 00160016 c0e601b0 c0e601b0 002b002b
[ 721.290554] 01bc dd7e5e9c dcb59e9c 000f000f c0e601c8 c0e601c8 318b318b c0e601d4 c0e601d4
[ 721.304608] 01dc 2f922f92 c0e601e0 c0e601e0 000b000b c0e601ec c0e601ec 00970097 c5b07e9c
[ 721.318681] 01fc c5b07e9c 00390039 c0e60204 c0e60204 001c001c dd42fe9c dd42fe9c 000a000a
[ 721.332686] 021c c0e6021c c0e6021c 00110011 dca3be9c dca3be9c 00080008 dcfe5e9c dcfe5e9c
[ 721.346702] 023c 0d680d68 c0e60240 c0e60240 000b000b c0e6024c c0e6024c 000a000a c0e60258
[ 721.363136] CPU: 2 PID: 437 Comm: RepaintThread Not tainted 3.10.0 #0
[ 721.373720] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 721.383288] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 721.392534] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 721.401922] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 721.408358] Exception stack(0xdd579ec0 to 0xdd579f08)
[ 721.416280] 9ec0: c5a3ea80 00000000 00000000 00000000 ffffffff 7fffffff 00000000 c0e601d4
[ 721.424871] 9ee0: c0e601e0 dd578000 c0e601dc b2b94dd0 dd579f20 dd579f08 c0083938 c00834d4
[ 721.431225] 9f00: 800d0013 ffffffff
[ 721.440204] [] (__irq_svc+0x40/0x70) from [] (drop_futex_key_refs+0x50/0x98)
[ 721.449889] [] (drop_futex_key_refs+0x50/0x98) from [] (futex_wake+0x114/0x120)
[ 721.459123] [] (futex_wake+0x114/0x120) from [] (do_futex+0xd4/0x184)
[ 721.468180] [] (do_futex+0xd4/0x184) from [] (SyS_futex+0x124/0x168)
[ 721.477711] [] (SyS_futex+0x124/0x168) from [] (ret_fast_syscall+0x0/0x30)
[ 721.484753] IPI backtrace for cpu 3
[ 721.490671]
[ 721.497164] CPU: 3 PID: 212 Comm: DispSync Not tainted 3.10.0 #0
[ 721.503909] task: dd7caa00 ti: dd48e000 task.ti: dd48e000
[ 721.509853] PC is at 0xb6e93704
[ 721.514816] LR is at 0xb6e94094
[ 721.521354] pc : [] lr : [] psr: 800d0010
[ 721.521354] sp : b6a01898 ip : b6e93708 fp : b6e66598
[ 721.530682] r10: b6a01d38 r9 : 000000aa r8 : ffffffb4
[ 721.536799] r7 : b73b9ca0 r6 : b73b9ccc r5 : 00000001 r4 : b73b9dec
[ 721.542875] r3 : 00000000 r2 : 00000000 r1 : b73b9dec r0 : 00000001
[ 721.549519] Flags: Nzcv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
[ 721.556211] Control: 10c5387d Table: 1d48806a DAC: 00000015
[ 721.563216] CPU: 3 PID: 212 Comm: DispSync Not tainted 3.10.0 #0
[ 721.574153] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 721.583812] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 721.593102] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 721.602592] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 721.609085] Exception stack(0xdd48ffb0 to 0xdd48fff8)
[ 721.615739] ffa0: 00000001 b73b9dec 00000000 00000000
[ 721.624233] ffc0: b73b9dec 00000001 b73b9ccc b73b9ca0 ffffffb4 000000aa b6a01d38 b6e66598
[ 721.631989] ffe0: b6e93708 b6a01898 b6e94094 b6e93704 800d0010 ffffffff
[ 721.638550] IPI backtrace for cpu 1
[ 721.644517]
[ 721.651224] CPU: 1 PID: 99 Comm: kconsole Not tainted 3.10.0 #0
[ 721.658150] task: ddee8fc0 ti: dde88000 task.ti: dde88000
[ 721.665334] PC is at __do_softirq+0x78/0x2b4
[ 721.671444] LR is at msecs_to_jiffies+0x18/0x24
[ 721.678415] pc : [] lr : [] psr: 600e0113
[ 721.678415] sp : dde89e98 ip : 00000000 fp : 0000000a
[ 721.687611] r10: 00000000 r9 : 00000000 r8 : c0e96ce4
[ 721.693548] r7 : dde89f3c r6 : 00000002 r5 : 00000000 r4 : dde88000
[ 721.699544] r3 : 00000001 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 721.706147] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 721.712801] Control: 10c5387d Table: 1cfa006a DAC: 00000015
[ 721.718148]
[ 721.718148] PC: 0xc003ddd8:
[ 721.724927] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 721.740432] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 721.755373] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 721.770074] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 721.784598] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 721.799186] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 721.814969] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 721.829801] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 721.847551]
[ 721.847551] LR: 0xc003cee4:
[ 721.854165] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 721.868764] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 721.887653] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 721.904023] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 721.919701] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 721.934176] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 721.950670] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 721.965126] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 721.980094]
[ 721.980094] SP: 0xdde89e18:
[ 721.986666] 9e18 00000007 c0013020 fed91000 dde89e50 c0c21484 dde89e84 c0e96ce4 00000000
[ 722.001303] 9e38 00000000 c0008558 c003de58 600e0113 ffffffff c000d600 00000001 c0e4c1c0
[ 722.015767] 9e58 00000000 00000001 dde88000 00000000 00000002 dde89f3c c0e96ce4 00000000
[ 722.030020] 9e78 00000000 0000000a 00000000 dde89e98 c003cf64 c003de58 600e0113 ffffffff
[ 722.044341] 9e98 dde89f3c 0000001d 00000000 00208040 0000a865 00000001 00000000 600e0193
[ 722.058756] 9eb8 00000000 c0c21484 dde89f3c c0e96ce4 00000000 00000000 00000000 c003e150
[ 722.072866] 9ed8 dde88000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dde89f08 c000853c
[ 722.087315] 9ef8 c03004d8 200e0113 ffffffff c000d600 de01e410 00000020 00000005 fed60000
[ 722.102151]
[ 722.102151] R1: 0xc0e4c140:
[ 722.108652] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.122518] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.136323] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 722.150332] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.164074] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 722.177940] c1e0 0000000a 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.191603] c200 00000000 00000000 00000000 00002195 00000008 00000002 00000000 00000000
[ 722.205432] c220 00000004 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.219542]
[ 722.219542] R4: 0xdde87f80:
[ 722.225930] 7f80 00000001 de030f40 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.240694] 7fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.254598] 7fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.268276] 7fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.281950] 8000 00000002 00000102 00000000 ddee8fc0 c0c3c138 00000001 00000015 ddee8fc0
[ 722.296188] 8020 c1f32cc0 dde88000 dd75efc0 dd75e1c0 00000001 dcfb39c0 dde89ef4 dde89e70
[ 722.310577] 8040 c086234c 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.324394] 8060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.338614]
[ 722.338614] R7: 0xdde89ebc:
[ 722.344979] 9ebc c0c21484 dde89f3c c0e96ce4 00000000 00000000 00000000 c003e150 dde88000
[ 722.359251] 9edc c003e3bc 0000001d c000e3d0 0000001d fed91000 dde89f08 c000853c c03004d8
[ 722.373576] 9efc 200e0113 ffffffff c000d600 de01e410 00000020 00000005 fed60000 c0c5a14c
[ 722.389070] 9f1c dde88000 de01e410 c0e96ce4 c0e96ce4 00000000 00000000 00000000 de8c2044
[ 722.403338] 9f3c dde89f50 c03004d8 c03004d8 200e0113 ffffffff de873d68 00000000 de01e410
[ 722.417734] 9f5c c030043c 00000000 c00561bc d9ffffef 00000000 9dffffff de01e410 00000000
[ 722.432066] 9f7c 00000000 dde89f80 dde89f80 00000000 00000000 dde89f90 dde89f90 dde89fac
[ 722.446304] 9f9c de873d68 c005611c 00000000 00000000 c000da98 00000000 00000000 00000000
[ 722.460716]
[ 722.460716] R8: 0xc0e96c64:
[ 722.467085] 6c64 00000000 c0e96bd0 c5ac8da4 c5ac8da4 00500002 00000001 00000000 00000000
[ 722.481406] 6c84 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.495061] 6ca4 00000000 00000001 00010001 00000000 00000000 00000000 00000000 00000000
[ 722.508863] 6cc4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.522534] 6ce4 de01dc10 de01e010 de01e410 de01e810 00000000 ddee8fc0 00000000 ddd8d700
[ 722.536892] 6d04 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.550690] 6d24 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.564447] 6d44 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 722.580472] CPU: 1 PID: 99 Comm: kconsole Not tainted 3.10.0 #0
[ 722.591465] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 722.601124] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 722.610527] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 722.621359] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 722.628134] Exception stack(0xdde89e50 to 0xdde89e98)
[ 722.634740] 9e40: 00000001 c0e4c1c0 00000000 00000001
[ 722.642899] 9e60: dde88000 00000000 00000002 dde89f3c c0e96ce4 00000000 00000000 0000000a
[ 722.650595] 9e80: 00000000 dde89e98 c003cf64 c003de58 600e0113 ffffffff
[ 722.659957] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 722.668856] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 722.677507] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 722.686647] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 722.695641] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 722.704476] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 722.710732] Exception stack(0xdde89f08 to 0xdde89f50)
[ 722.717925] 9f00: de01e410 00000020 00000005 fed60000 c0c5a14c dde88000
[ 722.727102] 9f20: de01e410 c0e96ce4 c0e96ce4 00000000 00000000 00000000 de8c2044 dde89f50
[ 722.734347] 9f40: c03004d8 c03004d8 200e0113 ffffffff
[ 722.744345] [] (__irq_svc+0x40/0x70) from [] (console_thread+0x9c/0xd4)
[ 722.754913] [] (console_thread+0x9c/0xd4) from [] (kthread+0xa0/0xac)
[ 722.765264] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 725.506006] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 725.513104] [mmc0] – Timeout recovery procedure start –
[ 725.524030] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 726.671283] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 726.682202] [mmc0] – Timeout recovery procedure finished –
[ 726.688860] mmcblk0: error -110 sending status command, aborting
[ 726.697805] end_request: I/O error, dev mmcblk0, sector 4321264
[ 726.705606] Buffer I/O error on device mmcblk0p13, logical block 66046
[ 726.711750] lost page write due to I/O error on mmcblk0p13
[ 726.724206] JBD2: Error -5 detected when updating journal superblock for mmcblk0p13-8.
[ 726.855057] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p13, blocknr = 0). There’s a risk of filesystem corruption in case of system crash.
[ 735.039414] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD18): error = -110, timeout = 8000ms
[ 735.047193] [mmc0] – Timeout recovery procedure start –
[ 735.058149] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 735.065432] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 735.074293] [mmc0] – Timeout recovery procedure finished –
[ 759.888337] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 759.896395] [mmc0] – Timeout recovery procedure start –
[ 759.907426] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 759.914633] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 759.923401] [mmc0] – Timeout recovery procedure finished –
[ 760.327842] mmcblk0: error -110 sending status command, retrying
[ 781.901514] INFO: rcu_preempt self-detected stall on CPU { 0} (t=77798 jiffies g=85 c=84 q=4855)
[ 781.914237] Backtrace for cpu 0 (current):
[ 781.921204] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 781.932611] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 781.942597] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 781.952992] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_cpu_stall+0xb4/0x138)
[ 781.965035] [] (print_cpu_stall+0xb4/0x138) from [] (__rcu_pending+0x68/0x190)
[ 781.975250] [] (__rcu_pending+0x68/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 781.986168] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 781.996839] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 782.006979] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 782.017371] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 782.030331] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 782.042016] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 782.052949] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 782.063364] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 782.072944] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 782.082046] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 782.088535] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 782.097927] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 782.106221] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 782.112530] 5e60: 60070113 ffffffff
[ 782.120994] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 782.129994] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 782.138679] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 782.147819] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 782.156760] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 782.165644] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 782.173187] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 782.179510] 5ec0: 00000000 dcf65f7c
[ 782.188169] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 782.196610] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 782.206096] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 782.215518] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 782.225034] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 782.232222]
[ 782.232222] sending IPI to all other CPUs:
[ 782.241129] IPI backtrace for cpu 3
[ 782.246957]
[ 782.253510] CPU: 3 PID: 437 Comm: RepaintThread Not tainted 3.10.0 #0
[ 782.260458] task: dd1424c0 ti: dd578000 task.ti: dd578000
[ 782.267970] PC is at SyS_nanosleep+0x0/0xa4
[ 782.274674] LR is at ret_fast_syscall+0x0/0x30
[ 782.281686] pc : [] lr : [] psr: 800d0013
[ 782.281686] sp : dd579fa8 ip : 10c5387d fp : b2b94dd0
[ 782.290935] r10: 00000000 r9 : dd578000 r8 : c000db84
[ 782.297044] r7 : 000000a2 r6 : b2b94d7c r5 : b731bfd0 r4 : b731bff8
[ 782.303199] r3 : 00000000 r2 : 02faf080 r1 : 00000000 r0 : b2b94d58
[ 782.309764] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 782.316148] Control: 10c5387d Table: 1d48806a DAC: 00000015
[ 782.321468]
[ 782.321468] PC: 0xc005a284:
[ 782.328352] a284 e1500007 11a00007 1a000016 e1560007 059f005c 0a000013 e1550007 0a000004
[ 782.343447] a2a4 e28d0010 e1a01005 ebfffb3a e3500000 da00000c e1a0300d e3c31d7f e59f3034
[ 782.357892] a2c4 e3c1103f e3a00e22 e5813210 e59d3034 e5933008 e581521c e5813218 e1cd22d0
[ 782.372055] a2e4 e18120f0 e59f0010 e28dd064 e8bd80f0 3b9aca00 fffffdfe c0861708 fffffdfc
[ 782.386230] a304 e92d4013 e1a04001 e1a0100d e3c12d7f e3c2203f e1a03000 e5922008 e2901008
[ 782.400317] a324 30d11002 33a02000 e3520000 e1a0000d 1a000005 e1a01003 e3a02008 eb08712a
[ 782.414473] a344 e3500000 0a000003 ea00000a e3a01008 eb087a89 ea000007 e59d3000 e3530000
[ 782.428580] a364 ba000006 e59d2004 e59f3030 e1520003 9a000004 ea000001 e3e0000d ea000000
[ 782.443160]
[ 782.443160] LR: 0xc000d980:
[ 782.449905] d980 e51f0268 e5900000 ee010f10 e1a0200d eb003662 e1a096ad e1a09689 e3a08000
[ 782.464222] d9a0 ea00002b e281c01c e5923060 e8ac6ff0 ee0d3f70 e3a04000 ee0d4f50 e1a05000
[ 782.478468] d9c0 e282401c e59f000c e3a01002 eb013660 e1a00005 e894aff0 c0dab150 e320f000
[ 782.492597] d9e0 e320f000 e320f000 e320f000 e320f000 e320f000 e320f000 e320f000 e320f000
[ 782.506783] da00 f10c0080 e5991000 e3110007 1a000007 e59d1048 e5bde044 e16ff001 f57ff01f
[ 782.520923] da20 e95d7ffe e1a00000 e28dd00c e1b0f00e e5ad0008 e1a0000d e1a02008 eb000d55
[ 782.535071] da40 e3500000 0a000006 b3a07000 e89d007f ea000029 f10c0080 e5991000 e3110007
[ 782.549283] da60 1afffff3 e59d1040 e5bde03c e16ff001 f57ff01f e95d7fff e1a00000 e28dd00c
[ 782.563852]
[ 782.563852] SP: 0xdd579f28:
[ 782.570601] 9f28 00000007 c0013020 fed91000 dd579f60 c0c21484 dd579f94 c000db84 dd578000
[ 782.584828] 9f48 00000000 c0008558 c005a304 800d0013 ffffffff c000d600 b2b94d58 00000000
[ 782.598882] 9f68 02faf080 00000000 b731bff8 b731bfd0 b2b94d7c 000000a2 c000db84 dd578000
[ 782.612932] 9f88 00000000 b2b94dd0 10c5387d dd579fa8 c000da00 c005a304 800d0013 ffffffff
[ 782.626986] 9fa8 b731bff8 b731bfd0 b2b94d58 00000000 02faf080 00000000 b731bff8 b731bfd0
[ 782.640950] 9fc8 b2b94d7c 000000a2 b731bfdc b731e938 b6eb357d b2b94dd0 b6e69bdc b2b94d58
[ 782.654977] 9fe8 b6ec1b15 b6eda1dc 600d0010 b2b94d58 005ba0bb 005ba0c3 00000002 000003e8
[ 782.669065] a008 000003e8 000003e8 000003e8 000003e8 000003e8 000003e8 000003e8 00000010
[ 782.683285]
[ 782.683285] R8: 0xc000db04:
[ 782.689872] db04 e31a0c0f 1a000008 e3570d06 e24fef46 3798f107 e28d1008 e3a08000 e357080f
[ 782.704223] db24 e2270000 2a000fc9 ea012418 e1a01007 e28d0008 eb0008e5 e28fe024 e1a07000
[ 782.718506] db44 e28d1008 e3570d06 3891007f 388d0030 3798f107 e3770001 1affffee e28dd008
[ 782.732756] db64 eaffffba e5ad0008 e1a0000d eb000924 eaffffb6 e320f000 e320f000 c0c295fc
[ 782.747005] db84 c0048c08 c003c1b4 c00360fc c010b8c0 c010b920 c010aa90 c010aac8 c0056b94
[ 782.761194] dba4 c010aabc c0118c60 c0118a8c c0111738 c010a314 c0056b94 c011898c c010a5a4
[ 782.775380] dbc4 c0056b94 c0056b94 c0056b94 c010b078 c004bc34 c0127118 c0056b94 c0056b94
[ 782.789569] dbe4 c0056b94 c0056b94 c0042714 c0056b94 c0056b94 c0049c98 c0056b94 c0056b94
[ 782.804078]
[ 782.804078] R9: 0xdd577f80:
[ 782.810571] 7f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 7f0f1e7e
[ 782.824028] 7fa0 00000000 00000000 00000000 00000000 00000000 7f0f7e7e 7f0f8e7e 00000000
[ 782.837574] 7fc0 7f0fae7e 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 782.851015] 7fe0 00000000 00000000 00000000 00000000 7f106e7e 7f107e7e 7f108e7e 00000000
[ 782.864625] 8000 00000000 00000002 00000000 dd1424c0 c0c3c138 00000003 00000015 dd1424c0
[ 782.878292] 8020 c1f44cc0 dd578000 c5a3ea80 c5a3ea80 00000003 dd143480 dd579efc dd579e78
[ 782.892248] 8040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 782.905750] 8060 b2b94dd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 782.921398] CPU: 3 PID: 437 Comm: RepaintThread Not tainted 3.10.0 #0
[ 782.932030] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 782.941584] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 782.950656] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 782.960044] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 782.966406] Exception stack(0xdd579f60 to 0xdd579fa8)
[ 782.974456] 9f60: b2b94d58 00000000 02faf080 00000000 b731bff8 b731bfd0 b2b94d7c 000000a2
[ 782.982847] 9f80: c000db84 dd578000 00000000 b2b94dd0 10c5387d dd579fa8 c000da00 c005a304
[ 782.989130] 9fa0: 800d0013 ffffffff
[ 782.998157] [] (__irq_svc+0x40/0x70) from [] (SyS_nanosleep+0x0/0xa4)
[ 783.006831] [] (SyS_nanosleep+0x0/0xa4) from [<00000000>] ( (null))
[ 783.013519] IPI backtrace for cpu 2
[ 783.019238]
[ 783.025919] CPU: 2 PID: 858 Comm: app_process Not tainted 3.10.0 #0
[ 783.032642] task: dc89d400 ti: dccd4000 task.ti: dccd4000
[ 783.040161] PC is at seq_read+0x29c/0x424
[ 783.046993] LR is at show_tid_map+0x34/0x54
[ 783.053899] pc : [] lr : [] psr: 80070113
[ 783.053899] sp : dccd5f18 ip : dccee044 fp : 00000000
[ 783.063043] r10: 000003cb r9 : b73fbd7d r8 : dccd5f28
[ 783.068897] r7 : 000001a2 r6 : 00000035 r5 : dc94fb00 r4 : dc55bd00
[ 783.074905] r3 : 00000000 r2 : 000000e1 r1 : b67b3000 r0 : 00000000
[ 783.081338] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 783.087839] Control: 10c5387d Table: 1cb8406a DAC: 00000015
[ 783.092971]
[ 783.092971] PC: 0xc0128558:
[ 783.099580] 8558 e1a00004 e12fff33 e5940000 ebfedfe1 e5940004 e1a00080 e5840004 ebfffdeb
[ 783.114729] 8578 e3500000 e5840000 0a00005d e3a02000 e3a03000 e1c422f0 e1a00004 e1c421d0
[ 783.129286] 8598 e1a01008 e584b00c e1cd21f0 e5943040 e5933000 e12fff33 e1a05000 eaffffc9
[ 783.143472] 85b8 e5943040 e1a00004 e1a01005 e5933004 e12fff33 e3a03000 e584300c ea000049
[ 783.157590] 85d8 e1cd21d0 e1a01005 e1a00004 e1cd21f8 e28d2018 e5943040 e5933008 e12fff33
[ 783.171648] 85f8 e2505000 0a000014 e3750a01 8a000012 e5943040 e1a00004 e1a01005 e593300c
[ 783.185717] 8618 e12fff33 e594200c e5943004 e1520003 0a000001 e3500000 0a000002 e3500000
[ 783.199793] 8638 e584700c da000004 e1cd21d8 e1cd21f0 e594700c e157000a 3affffe0 e5943040
[ 783.214366]
[ 783.214366] LR: 0xc014fbac:
[ 783.220893] fbac ebff5f87 e28dd03c e8bd8ff0 e59f6030 ea000000 e59f602c e1a00005 e59d1034
[ 783.235139] fbcc ebfffeca e1a00005 e1a01006 ebff601d eafffff0 c0a76610 c0ae6ffe c0a70ec8
[ 783.249339] fbec c0a7663d c0a70ec1 c0a70ecf e92d4070 e3a02000 e5903048 e1a04000 e1a05001
[ 783.263382] fc0c e5936004 ebffff62 e594200c e5943004 e1520003 2a000007 e596021c ebfafc10
[ 783.277462] fc2c e3a03000 e1550000 15951000 03a02000 11a02001 e1c422f0 e3a00000 e8bd8070
[ 783.291464] fc4c e92d4070 e3a02001 e5903048 e1a04000 e1a05001 e5936004 ebffff4d e594200c
[ 783.305548] fc6c e5943004 e1520003 2a000007 e596021c ebfafbfb e3a03000 e1550000 15951000
[ 783.319594] fc8c 03a02000 11a02001 e1c422f0 e3a00000 e8bd8070 e92d4ff0 e24dd08c e5903048
[ 783.334058]
[ 783.334058] SP: 0xdccd5e98:
[ 783.340416] 5e98 00000007 c0013020 fed91000 dccd5ed0 c0c21484 dccd5f04 dccd5f28 b73fbd7d
[ 783.354616] 5eb8 000003cb c0008558 c01285d8 80070113 ffffffff c000d600 00000000 b67b3000
[ 783.368697] 5ed8 000000e1 00000000 dc55bd00 dc94fb00 00000035 000001a2 dccd5f28 b73fbd7d
[ 783.382796] 5ef8 000003cb 00000000 dccee044 dccd5f18 c014fc2c c01285d8 80070113 ffffffff
[ 783.396741] 5f18 00000000 dccd5f80 dcfbc600 dc55bd28 000000e1 00000000 000000e1 00000000
[ 783.410535] 5f38 c0c1a088 00000400 dcfbc600 b73fbd48 dccd5f80 00004000 00000000 00000000
[ 783.424480] 5f58 b73f1c60 c010b760 dcfbc600 b73fbd48 dcfbc600 00000000 b73fbd48 00000400
[ 783.438497] 5f78 00004000 c010b8fc 00004000 00000000 00000400 b6dd5cbc bedefca8 00000014
[ 783.452889]
[ 783.452889] IP: 0xdccedfc4:
[ 783.459296] dfc4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 783.472793] dfe4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 783.486114] e004 40000002 bf000000 dc9ac980 c0c3c138 00000002 00000015 dc9ac980 c1f3bcc0
[ 783.500014] e024 dccee000 dd6b9340 c5b60e00 00000002 dc89d400 dccefe34 dccefdb0 c086234c
[ 783.514026] e044 00000000 00000000 00000000 00000000 00000000 01010000 01000000 b6fc8e30
[ 783.527678] e064 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 783.541067] e084 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 783.554380] e0a4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 783.568152]
[ 783.568152] R4: 0xdc55bc80:
[ 783.574570] bc80 00000000 000003e8 000003e8 000003e8 000003e8 000003e8 000003e8 000003e8
[ 783.588297] bca0 000003e8 00000010 00000000 00000000 07813c20 00000010 07813c20 00000010
[ 783.602110] bcc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dcf117c0
[ 783.615581] bce0 c5b12140 c0c3da94 c5a06780 dcfbca80 c005ba9c 16171718 13141515 10111212
[ 783.629714] bd00 dd2c4000 00001000 000003ff 000001a2 000000dc 00000000 00004000 00000000
[ 783.643663] bd20 b67b3000 00000000 00000000 00000000 dc55bd30 dc55bd30 dc89d400 00000000
[ 783.657469] bd40 c0872c60 00000000 dcf11800 00000000 00000000 00000000 00000000 00000000
[ 783.671034] bd60 00000000 00000001 22222222 20202121 1e1e1f1f 1b1c1c1d 1819191a 15161617
[ 783.685329]
[ 783.685329] R5: 0xdc94fa80:
[ 783.691743] fa80 dcadc8c4 dcbbd4fc 00000005 dd35bd08 dd35bd08 dcda2c40 c0878c90 00000005
[ 783.705680] faa0 dd0f1300 00000000 b6c9a000 b6c9b000 dc94fc60 dcfcfdc0 c58fb901 dc94fe28
[ 783.719648] fac0 c58fbab8 b4ff3000 ddec3c00 00000e9f 80200070 00000000 00000000 00000000
[ 783.733393] fae0 00000000 dc94fae4 dc94fae4 00000000 00000000 000b6c9a 00000000 00000000
[ 783.746992] fb00 b67b3000 b67b4000 dd1b9aa8 dcc6dec8 dd1b98a9 dd1b9ab8 dcc6ded8 00000000
[ 783.761016] fb20 c5b60e00 0000079f 80100073 dc977764 dcadc974 dd280294 0000000d dcfcd688
[ 783.774939] fb40 dcfcd688 dc48b1c0 c0878c90 0000000d dc5ec3c0 00000000 b52b8000 b52b9000
[ 783.788831] fb60 dd01d0b0 dcd3db58 dcd3db68 00000000 00000000 00000000 c596c1c0 0000079f
[ 783.803058]
[ 783.803058] R8: 0xdccd5ea8:
[ 783.809393] 5ea8 c0c21484 dccd5f04 dccd5f28 b73fbd7d 000003cb c0008558 c01285d8 80070113
[ 783.823534] 5ec8 ffffffff c000d600 00000000 b67b3000 000000e1 00000000 dc55bd00 dc94fb00
[ 783.837441] 5ee8 00000035 000001a2 dccd5f28 b73fbd7d 000003cb 00000000 dccee044 dccd5f18
[ 783.851337] 5f08 c014fc2c c01285d8 80070113 ffffffff 00000000 dccd5f80 dcfbc600 dc55bd28
[ 783.865414] 5f28 000000e1 00000000 000000e1 00000000 c0c1a088 00000400 dcfbc600 b73fbd48
[ 783.879276] 5f48 dccd5f80 00004000 00000000 00000000 b73f1c60 c010b760 dcfbc600 b73fbd48
[ 783.893236] 5f68 dcfbc600 00000000 b73fbd48 00000400 00004000 c010b8fc 00004000 00000000
[ 783.907256] 5f88 00000400 b6dd5cbc bedefca8 00000014 00000003 c000db84 dccd4000 c000da00
[ 783.923457] CPU: 2 PID: 858 Comm: app_process Not tainted 3.10.0 #0
[ 783.933980] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 783.943500] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 783.952824] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 783.962562] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 783.969029] Exception stack(0xdccd5ed0 to 0xdccd5f18)
[ 783.976154] 5ec0: 00000000 b67b3000 000000e1 00000000
[ 783.985034] 5ee0: dc55bd00 dc94fb00 00000035 000001a2 dccd5f28 b73fbd7d 000003cb 00000000
[ 783.992836] 5f00: dccee044 dccd5f18 c014fc2c c01285d8 80070113 ffffffff
[ 784.002965] [] (__irq_svc+0x40/0x70) from [] (seq_read+0x29c/0x424)
[ 784.013176] [] (seq_read+0x29c/0x424) from [] (vfs_read+0xac/0x124)
[ 784.022685] [] (vfs_read+0xac/0x124) from [] (SyS_read+0x3c/0x60)
[ 784.032460] [] (SyS_read+0x3c/0x60) from [] (ret_fast_syscall+0x0/0x30)
[ 784.039626] IPI backtrace for cpu 1
[ 784.045788]
[ 784.052887] CPU: 1 PID: 703 Comm: Binder_5 Not tainted 3.10.0 #0
[ 784.060323] task: dcf75e80 ti: dc940000 task.ti: dc940000
[ 784.067625] PC is at __do_softirq+0x78/0x2b4
[ 784.073780] LR is at msecs_to_jiffies+0x18/0x24
[ 784.080562] pc : [] lr : [] psr: 600d0113
[ 784.080562] sp : dc941cf0 ip : 00000000 fp : 0000000a
[ 784.089499] r10: 00000000 r9 : 00000000 r8 : 00000002
[ 784.095552] r7 : dc941d94 r6 : 00000002 r5 : 00000000 r4 : dc940000
[ 784.101613] r3 : 00000001 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 784.108200] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 784.114878] Control: 10c5387d Table: 1d76406a DAC: 00000015
[ 784.121130]
[ 784.121130] PC: 0xc003ddd8:
[ 784.128289] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 784.143813] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 784.158746] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 784.173658] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 784.189806] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 784.204401] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 784.218978] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 784.233664] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 784.251015]
[ 784.251015] LR: 0xc003cee4:
[ 784.257963] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 784.272795] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 784.287443] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 784.302144] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 784.318183] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 784.332658] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 784.349096] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 784.363676] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 784.378542]
[ 784.378542] SP: 0xdc941c70:
[ 784.384922] 1c70 00000007 c0013020 fed91000 dc941ca8 c0c21484 dc941cdc 00000002 00000000
[ 784.400514] 1c90 00000000 c0008558 c003de58 600d0113 ffffffff c000d600 00000001 c0e4c1c0
[ 784.418497] 1cb0 00000000 00000001 dc940000 00000000 00000002 dc941d94 00000002 00000000
[ 784.433717] 1cd0 00000000 0000000a 00000000 dc941cf0 c003cf64 c003de58 600d0113 ffffffff
[ 784.448274] 1cf0 dc941d94 0000001d 00000000 00400040 0000c104 00000001 00000000 600d0193
[ 784.465043] 1d10 00000000 c0c21484 dc941d94 00000002 00000000 00000000 00020000 c003e150
[ 784.479398] 1d30 dc940000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dc941d60 c000853c
[ 784.495756] 1d50 c0234ae4 400d0013 ffffffff c000d600 dc941e0c c5b85b48 00000000 00040257
[ 784.510961]
[ 784.510961] R1: 0xc0e4c140:
[ 784.517401] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 784.531316] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 784.546333] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 784.560575] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 784.574347] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 784.588619] c1e0 0000000a 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 784.602387] c200 00000000 00000000 00000000 00002207 00000008 00000002 00000000 00000000
[ 784.616264] c220 00000005 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 784.630435]
[ 784.630435] R4: 0xdc93ff80:
[ 784.636954] ff80 00000008 00000001 a2c08ae8 b89422a8 b89422d8 b8942278 00000036 c000db84
[ 784.652565] ffa0 00000000 c000da00 b89422a8 b89422d8 00000008 c0186201 a2c08ae8 a2c08ae0
[ 784.666991] ffc0 b89422a8 b89422d8 b8942278 00000036 00000001 b6e74614 b6e3ddd4 00007205
[ 784.681492] ffe0 b891d8c8 a2c08ad0 b6e24afd b6e1e828 600d0010 00000008 ffffbb76 ff7dfebf
[ 784.696035] 0000 00000002 00000102 00000000 dcf75e80 c0c3c138 00000001 00000015 dcf75e80
[ 784.710345] 0020 c1f32cc0 dc940000 dd75efc0 c5a3ea80 00000001 dd7caa00 dc941e2c dc941da8
[ 784.724767] 0040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 01000000
[ 784.738893] 0060 9dd56dd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 784.753458]
[ 784.753458] R7: 0xdc941d14:
[ 784.759887] 1d14 c0c21484 dc941d94 00000002 00000000 00000000 00020000 c003e150 dc940000
[ 784.774197] 1d34 c003e3bc 0000001d c000e3d0 0000001d fed91000 dc941d60 c000853c c0234ae4
[ 784.790424] 1d54 400d0013 ffffffff c000d600 dc941e0c c5b85b48 00000000 00040257 dc941e0c
[ 784.804955] 1d74 00000006 000000c3 000000c3 00000002 00000000 00000000 00020000 0000000c
[ 784.818893] 1d94 dc941da8 00000000 c0234ae4 400d0013 ffffffff b5d25000 00000007 000000c3
[ 784.833439] 1db4 000000c3 00800000 dc941e2c 00000000 c0234b1c 00000000 dd57ae00 de801e80
[ 784.848836] 1dd4 000000d0 00000050 00000000 dc9da300 dd608528 00000002 00000024 00000004
[ 784.862991] 1df4 dd8e96a0 dc9da480 c0238320 00000000 dc941e0c dc941ec0 00040257 00000000
[ 784.880256] CPU: 1 PID: 703 Comm: Binder_5 Not tainted 3.10.0 #0
[ 784.892355] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 784.902754] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 784.912195] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 784.921610] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 784.928565] Exception stack(0xdc941ca8 to 0xdc941cf0)
[ 784.935833] 1ca0: 00000001 c0e4c1c0 00000000 00000001 dc940000 00000000
[ 784.943984] 1cc0: 00000002 dc941d94 00000002 00000000 00000000 0000000a 00000000 dc941cf0
[ 784.951714] 1ce0: c003cf64 c003de58 600d0113 ffffffff
[ 784.961576] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 784.970874] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 784.979438] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 784.988372] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 784.997448] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 785.008095] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 785.014630] Exception stack(0xdc941d60 to 0xdc941da8)
[ 785.022544] 1d60: dc941e0c c5b85b48 00000000 00040257 dc941e0c 00000006 000000c3 000000c3
[ 785.030658] 1d80: 00000002 00000000 00000000 00020000 0000000c dc941da8 00000000 c0234ae4
[ 785.036993] 1da0: 400d0013 ffffffff
[ 785.045922] [] (__irq_svc+0x40/0x70) from [] (avc_has_perm_noaudit+0x74/0xb8)
[ 785.056630] [] (avc_has_perm_noaudit+0x74/0xb8) from [] (selinux_inode_permission+0xb4/0x130)
[ 785.067146] [] (selinux_inode_permission+0xb4/0x130) from [] (security_inode_permission+0x20/0x30)
[ 785.077786] [] (security_inode_permission+0x20/0x30) from [] (may_open+0x98/0xf8)
[ 785.088039] [] (may_open+0x98/0xf8) from [] (do_last+0x61c/0x798)
[ 785.097758] [] (do_last+0x61c/0x798) from [] (path_openat+0xa8/0x41c)
[ 785.107488] [] (path_openat+0xa8/0x41c) from [] (do_filp_open+0x2c/0x78)
[ 785.117456] [] (do_filp_open+0x2c/0x78) from [] (do_sys_open+0xe4/0x170)
[ 785.127441] [] (do_sys_open+0xe4/0x170) from [] (ret_fast_syscall+0x0/0x30)
[ 785.187380] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 785.478291] [mmc0] – Timeout recovery procedure start –
[ 785.697192] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 785.842529] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 785.952905] [mmc0] – Timeout recovery procedure finished –
[ 786.098768] mmcblk0: error -110 sending status command, retrying
[ 810.897811] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 811.141316] [mmc0] – Timeout recovery procedure start –
[ 811.401390] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 811.694467] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 811.803541] [mmc0] – Timeout recovery procedure finished –
[ 811.819385] mmcblk0: error -110 sending status command, aborting
[ 811.832811] end_request: I/O error, dev mmcblk0, sector 1062408
[ 820.697749] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD25): error = -110, timeout = 8000ms
[ 820.754679] [mmc0] – Timeout recovery procedure start –
[ 820.916601] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 821.642389] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 821.653247] [mmc0] – Timeout recovery procedure finished –
[ 843.923215] INFO: rcu_preempt self-detected stall on CPU { 0} (t=84101 jiffies g=85 c=84 q=5361)
[ 843.935622] Backtrace for cpu 0 (current):
[ 843.942469] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 843.953590] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 843.963741] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 843.974017] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_cpu_stall+0xb4/0x138)
[ 843.984097] [] (print_cpu_stall+0xb4/0x138) from [] (__rcu_pending+0x68/0x190)
[ 843.994094] [] (__rcu_pending+0x68/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 844.005212] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 844.016081] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 844.026341] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 844.036451] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 844.047325] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 844.059142] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 844.070007] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 844.080474] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 844.090141] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 844.099476] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 844.105921] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 844.113707] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 844.122042] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 844.128332] 5e60: 60070113 ffffffff
[ 844.136822] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 844.145740] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 844.154361] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 844.163366] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 844.172487] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 844.181375] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 844.187951] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 844.193933] 5ec0: 00000000 dcf65f7c
[ 844.202291] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 844.210701] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 844.220236] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 844.229696] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 844.238990] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 844.245190]
[ 844.245190] sending IPI to all other CPUs:
[ 844.253762] IPI backtrace for cpu 3
[ 844.259650]
[ 844.266210] CPU: 3 PID: 169 Comm: mediaserver Not tainted 3.10.0 #0
[ 844.272925] task: c5be4440 ti: dd646000 task.ti: dd646000
[ 844.280565] PC is at zap_pte_range+0x368/0x450
[ 844.286994] LR is at page_remove_rmap+0xc0/0x150
[ 844.293841] pc : [] lr : [] psr: a00e0113
[ 844.293841] sp : dd647d40 ip : dd647d60 fp : 70a5759f
[ 844.303067] r10: dd1cb624 r9 : c0e8a880 r8 : dd14d4d0
[ 844.308989] r7 : 00000000 r6 : 00000000 r5 : b4d89000 r4 : dd647df0
[ 844.315230] r3 : 00000054 r2 : 00000000 r1 : fffffffe r0 : c596c1c0
[ 844.321870] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 844.328348] Control: 10c5387d Table: 1cfa806a DAC: 00000015
[ 844.333649]
[ 844.333649] PC: 0xc00ea188:
[ 844.340240] a188 e1a02005 ebfff79a e3a01000 e59d0008 e1a02001 ebfcc688 e59d2050 e2866a01
[ 844.355524] a1a8 e1560002 1affff5a e1a05006 e3a06000 ea000001 e1a05006 e3a06001 e1a0000d
[ 844.369972] a1c8 e3c03d7f e3c3303f e59d100c e593300c e593321c e1530001 1a000001 e1a00001
[ 844.384135] a1e8 ebfffa07 e28dc01c e3a02000 e49c1004 e3510000 0a000008 e59d000c e2823054
[ 844.398392] a208 e0803103 e2830004 e190ef9f e08ee001 e180af9e e33a0000 1afffffa e2822001
[ 844.412416] a228 e3520003 1afffff0 e59d0010 eb1de454 e3560000 0a000026 e5946004 e594a010
[ 844.426493] a248 e3560000 e5845010 1a000002 e5940008 e3500000 1a000002 e5940000 ebfca459
[ 844.440539] a268 ea000007 e5942018 e3520000 0a000004 e5941014 ebfca4b2 e3a034bf e5846018
[ 844.455142]
[ 844.455142] LR: 0xc00f22bc:
[ 844.461650] 22bc e3e06000 e1932f9f e0822006 e1831f92 e3310000 1afffffa f57ff05b e3520000
[ 844.475847] 22dc aa00001c e3550000 e1a00004 0a000004 eb0054e9 e1a00004 e3a01007 ebffbd6b
[ 844.490044] 22fc ea00000e e3a01008 ebffbd68 e1a00004 e1a01005 e1a02006 eb0053fe e59f30a4
[ 844.504147] 231c e5933030 e3530000 1a000004 ea00001c e1a00004 e28d1004 eb0053ee ebfd8514
[ 844.518261] 233c e5943000 e3130602 0a00001d e1a00004 ebffe8c6 ea00001a e3550000 1a000018
[ 844.532349] 235c e59f3060 e5933030 e3530000 1a000014 ea00000f e1a00004 e28d1004 eb0053dd
[ 844.546429] 237c ebfd8503 ea00000e ebfd8485 e59f3038 e5cd5003 e5933000 e3530000 0affffc5
[ 844.560694] 239c eaffffc0 e5dd3003 e3530000 0affffe2 eaffffde e5dd3003 e3530000 0affffef
[ 844.575330]
[ 844.575330] SP: 0xdd647cc0:
[ 844.581808] 7cc0 00000007 c0013020 fed91000 dd647cf8 c0c21484 dd647d2c dd14d4d0 c0e8a880
[ 844.595975] 7ce0 dd1cb624 c0008558 c00ea208 a00e0113 ffffffff c000d600 c596c1c0 fffffffe
[ 844.610127] 7d00 00000000 00000054 dd647df0 b4d89000 00000000 00000000 dd14d4d0 c0e8a880
[ 844.624053] 7d20 dd1cb624 70a5759f dd647d60 dd647d40 c00f233c c00ea208 a00e0113 ffffffff
[ 844.638231] 7d40 c5bebfa4 00000000 dd1cb620 c596c1c0 c126f97c dd6aed30 dd647df0 fffffffe
[ 844.652300] 7d60 00000000 00000000 00000000 dd647df0 b4d87000 dd14d4d0 00000000 dd6aed30
[ 844.666159] 7d80 b4d89000 b4d89000 dd6aed30 c00ea444 b4d89000 00000000 dd647e3c b4d88fff
[ 844.680254] 7da0 c5aa9440 dd14d4d0 ffffffff 00000000 dd647df0 00000000 c5aa9440 b6f2b828
[ 844.694658]
[ 844.694658] IP: 0xdd647ce0:
[ 844.701185] 7ce0 dd1cb624 c0008558 c00ea208 a00e0113 ffffffff c000d600 c596c1c0 fffffffe
[ 844.715461] 7d00 00000000 00000054 dd647df0 b4d89000 00000000 00000000 dd14d4d0 c0e8a880
[ 844.729417] 7d20 dd1cb624 70a5759f dd647d60 dd647d40 c00f233c c00ea208 a00e0113 ffffffff
[ 844.743505] 7d40 c5bebfa4 00000000 dd1cb620 c596c1c0 c126f97c dd6aed30 dd647df0 fffffffe
[ 844.757540] 7d60 00000000 00000000 00000000 dd647df0 b4d87000 dd14d4d0 00000000 dd6aed30
[ 844.771364] 7d80 b4d89000 b4d89000 dd6aed30 c00ea444 b4d89000 00000000 dd647e3c b4d88fff
[ 844.785411] 7da0 c5aa9440 dd14d4d0 ffffffff 00000000 dd647df0 00000000 c5aa9440 b6f2b828
[ 844.799378] 7dc0 c5bebfa4 c00ead9c 00000000 dcfcff78 dcfcff78 c596c1c0 c5be4894 c596c200
[ 844.813868]
[ 844.813868] R0: 0xc596c140:
[ 844.820384] c140 00000000 00000000 00000000 00000000 00000000 00000040 0000003e 00000000
[ 844.833904] c160 c0c46660 0000000e 00000315 00000000 00000000 b6f9e000 0001008d 00000000
[ 844.847823] c180 00000000 00000000 de890000 c581e540 00000000 00000000 e59d0018 ebffe87b
[ 844.861636] c1a0 e59f0380 e6ef4074 e1a01008 ebffe956 e1a00004 ebffe939 e3500000 ba00000d
[ 844.875743] c1c0 dcfcff78 dd01dab8 dcfcf420 c0019acc c00eed38 b6ff2000 00000000 bf000000
[ 844.889861] c1e0 00000000 b6ff2000 bea7f000 dd6ac000 00000000 00000001 0000017e 00d900d9
[ 844.903817] c200 00000000 49c149c1 c596c208 c596c208 c596c210 c596c210 000009ef 00002c30
[ 844.917894] c220 000029fe 00000000 00000000 00001b72 00001778 00000022 00000000 00000015
[ 844.932151]
[ 844.932151] R4: 0xdd647d70:
[ 844.938580] 7d70 b4d87000 dd14d4d0 00000000 dd6aed30 b4d89000 b4d89000 dd6aed30 c00ea444
[ 844.952904] 7d90 b4d89000 00000000 dd647e3c b4d88fff c5aa9440 dd14d4d0 ffffffff 00000000
[ 844.967045] 7db0 dd647df0 00000000 c5aa9440 b6f2b828 c5bebfa4 c00ead9c 00000000 dcfcff78
[ 844.981058] 7dd0 dcfcff78 c596c1c0 c5be4894 c596c200 dd647efc c00ef0a8 c0f7c440 dd646000
[ 844.995157] 7df0 c596c1c0 00000001 00000000 00000000 ffffffff c5822168 00000000 00000086
[ 845.008917] 7e10 00000400 dc470000 c0e8b1f8 dd647efc c5aa9440 b6f2b828 c5bebfa4 c00fe0c8
[ 845.022968] 7e30 0001008d c596c1c0 c596c1c0 c5be4440 c5be4894 c0034eb4 c596c1c0 c003bd90
[ 845.037131] 7e50 c5be4440 00000053 c5be4440 00000007 dd646000 00000001 dd647efc c003bf9c
[ 845.051504]
[ 845.051504] R8: 0xdd14d450:
[ 845.057918] d450 dd14d5ac dd14d604 00000002 dd296e48 dd296e48 dd09ecc0 c0878c90 00000001
[ 845.071995] d470 dcc14000 00000000 b4d8a000 b4d8b000 dd14d3c8 dd14d318 dd14d3d8 00000000
[ 845.085970] d490 00000000 00000000 c596c1c0 0000079f 80100073 dd14d344 00000000 00000000
[ 845.099599] d4b0 00000002 dd2962e8 dd2962e8 dd09e0a0 c0878c90 00000002 dd507180 00000000
[ 845.113386] d4d0 b4d87000 b4d89000 dd14d318 dd14d580 dd14d329 00000000 dd14d590 00000000
[ 845.127346] d4f0 c596c1c0 0000059f 80000075 dd14d344 00000000 00000000 00000001 dd14d50c
[ 845.141141] d510 dd14d50c 00000000 c0878c90 00000000 dd507180 00000000 b4c81000 b4c82000
[ 845.154958] d530 dd14d688 dd14d790 dd14d7f9 dd14d698 dd14d7a0 00000000 c596c1c0 0000079f
[ 845.169369]
[ 845.169369] R9: 0xc0e8a800:
[ 845.175757] a800 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 845.189254] a820 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 845.202643] a840 000001a5 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 845.216069] a860 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 845.229401] a880 c0ecc000 00000000 00000000 00000000 e0000000 00080000 00080000 00000000
[ 845.243237] a8a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 845.256640] a8c0 0eb90eb9 00000000 0022593e 00000000 c0c4fdf0 c0c1a290 c0c18a1c 00000000
[ 845.270634] a8e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 845.284500]
[ 845.284500] R10: 0xdd1cb5a4:
[ 845.290937] b5a4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 845.304322] b5c4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 845.317680] b5e4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 845.330922] b604 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 845.344265] b624 70a5b7df 70a5c75f 70a5359f 00000000 70a5d7df 70a5e75f 70a4c59f 00000000
[ 845.358256] b644 00000000 00000000 70a5059f 70a5159f 70a5f7df 70a6075f 70a627df 70a3f59f
[ 845.372261] b664 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 845.385623] b684 00000000 00000000 00000000 70a4959f 00000000 70a617df 70a3875f 70a4359f
[ 845.401670] CPU: 3 PID: 169 Comm: mediaserver Not tainted 3.10.0 #0
[ 845.412486] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 845.422153] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 845.431368] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 845.440827] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 845.447227] Exception stack(0xdd647cf8 to 0xdd647d40)
[ 845.453340] 7ce0: c596c1c0 fffffffe
[ 845.461581] 7d00: 00000000 00000054 dd647df0 b4d89000 00000000 00000000 dd14d4d0 c0e8a880
[ 845.469969] 7d20: dd1cb624 70a5759f dd647d60 dd647d40 c00f233c c00ea208 a00e0113 ffffffff
[ 845.480113] [] (__irq_svc+0x40/0x70) from [] (zap_pte_range+0x368/0x450)
[ 845.490347] [] (zap_pte_range+0x368/0x450) from [] (unmap_page_range+0x154/0x15c)
[ 845.500341] [] (unmap_page_range+0x154/0x15c) from [] (unmap_vmas+0x34/0x50)
[ 845.509860] [] (unmap_vmas+0x34/0x50) from [] (exit_mmap+0xc0/0x1e0)
[ 845.519064] [] (exit_mmap+0xc0/0x1e0) from [] (mmput.part.44+0x28/0xc8)
[ 845.528904] [] (mmput.part.44+0x28/0xc8) from [] (exit_mm+0x17c/0x184)
[ 845.538856] [] (exit_mm+0x17c/0x184) from [] (do_exit+0x204/0x400)
[ 845.548853] [] (do_exit+0x204/0x400) from [] (do_group_exit+0x88/0xb4)
[ 845.558869] [] (do_group_exit+0x88/0xb4) from [] (get_signal_to_deliver+0x3b4/0x3fc)
[ 845.568242] [] (get_signal_to_deliver+0x3b4/0x3fc) from [] (do_signal+0xa0/0x150)
[ 845.577138] [] (do_signal+0xa0/0x150) from [] (do_work_pending+0x4c/0x94)
[ 845.586560] [] (do_work_pending+0x4c/0x94) from [] (work_pending+0xc/0x20)
[ 845.593440] IPI backtrace for cpu 2
[ 845.599362]
[ 845.605934] CPU: 2 PID: 858 Comm: app_process Not tainted 3.10.0 #0
[ 845.612912] task: dc89d400 ti: dccd4000 task.ti: dccd4000
[ 845.620777] PC is at _raw_spin_unlock+0x14/0x40
[ 845.627199] LR is at expand_downwards+0x118/0x140
[ 845.634117] pc : [] lr : [] psr: 600f0113
[ 845.634117] sp : dccd5df0 ip : dc48b978 fp : 00004000
[ 845.643888] r10: dc5febec r9 : c5b60e00 r8 : 00000000
[ 845.649881] r7 : dc5febe4 r6 : 000beab2 r5 : dc5febe4 r4 : dc5febb0
[ 845.656149] r3 : 000005c0 r2 : 38951000 r1 : 00000000 r0 : c5b60e3c
[ 845.662920] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 845.669417] Control: 10c5387d Table: 1cb8406a DAC: 00000015
[ 845.674745]
[ 845.674745] PC: 0xc0863320:
[ 845.681253] 3320 1a000001 f57ff04f e320f004 e1a0100d e3c12d7f e3c2203f e1a00003 e5921004
[ 845.696454] 3340 e2411001 e5821004 e49de004 eadf6b82 e52de004 f57ff05b e3a02000 e5802000
[ 845.711011] 3360 f57ff04f e320f004 e1a0100d e3c12d7f e3c2203f e1a0000e e5921004 e2411001
[ 845.725212] 3380 e5821004 e49de004 eadf6b73 f57ff05b e1d030b0 e2833001 e1c030b0 f57ff04f
[ 845.739322] 33a0 e320f004 e1a0200d e3c23d7f e3c3303f e5932004 e2422001 e5832004 e5933000
[ 845.753519] 33c0 e3130002 012fff1e eafffc38 f57ff05b e1d030b0 e2833001 e1c030b0 f57ff04f
[ 845.767927] 33e0 e320f004 e121f001 e1a0200d e3c23d7f e3c3303f e5932004 e2422001 e5832004
[ 845.782293] 3400 e5933000 e3130002 012fff1e eafffc27 f57ff05b e1d030b0 e2833001 e1c030b0
[ 845.796929]
[ 845.796929] LR: 0xc00ef9f8:
[ 845.803393] f9f8 eb1dcd90 e5ba703c ea000004 e5971004 e1a00007 e2811018 ebffdbe3 e5977008
[ 845.817822] fa18 e2477008 e2873008 e15a0003 1afffff6 e594304c e5845000 e0666003 e594503c
[ 845.831944] fa38 e584604c ea000004 e5951004 e1a00005 e2811018 ebffdbb3 e5955008 e2455008
[ 845.846235] fa58 e2853008 e15a0003 1afffff6 e1a00004 ebfff58f e5940020 e280003c eb1dce44
[ 845.860334] fa78 e1a00004 ebff5de2 e5943044 e3530000 0a000002 e5930000 e2800004 ebfdaa44
[ 845.874486] fa98 e1a00008 e8bd85f8 e590300c e3c11eff e3c1100f e3530000 0a000005 e5932004
[ 845.888762] fab8 e1520001 1a000002 e5933028 e3130c01 0a000000 eaffffa3 e3e0000b e12fff1e
[ 845.903015] fad8 e92d4070 e3c15eff e3c5500f e1a01005 ebfff632 e2504000 0a000012 e5946000
[ 845.917505]
[ 845.917505] SP: 0xdccd5d70:
[ 845.924088] 5d70 00000007 c0013020 fed91000 dccd5da8 c0c21484 dccd5ddc 00000000 c5b60e00
[ 845.938353] 5d90 dc5febec c0008558 c08633a0 600f0113 ffffffff c000d600 c5b60e3c 00000000
[ 845.952670] 5db0 38951000 000005c0 dc5febb0 dc5febe4 000beab2 dc5febe4 00000000 c5b60e00
[ 845.966826] 5dd0 dc5febec 00004000 dc48b978 dccd5df0 c00efa78 c08633a0 600f0113 ffffffff
[ 845.980970] 5df0 dc584160 dc5febb0 be8a5000 dcb86fa0 dcb86fa0 c5b60e00 000000a8 c00e8810
[ 845.995355] 5e10 c5b60e00 dc5febb0 be8a5000 be8a5000 dcb84000 000005f4 dcb86fa0 c5b60e00
[ 846.009435] 5e30 dc5febb0 000000a8 00004000 c00eb944 000000a8 000000a8 c5b60e00 dc5febb0
[ 846.023763] 5e50 00000080 000000a8 be8a5000 00000017 dccd4000 c00eba00 000000a8 dccd5fb0
[ 846.038171]
[ 846.038171] IP: 0xdc48b8f8:
[ 846.044551] b8f8 00000000 dc48b9a0 dc48bc40 00000000 00000000 dc48b90c dc48b90c 00000000
[ 846.058598] b918 00000000 dc48b8a0 dc48b920 00000000 00120012 dc48b92c dc48b92c 00000001
[ 846.072561] b938 dd278690 dc48bac0 dc48b940 00000000 001e001e dc48b94c dc48b94c 00000001
[ 846.086566] b958 dd278a50 dc48ba80 dc48b960 ffffffff 0a6b0a6b dc48b96c dc48b96c 00000001
[ 846.100575] b978 dd278350 dc48b980 dc48b980 00000000 001e001e dc48b98c dc48b98c 00000001
[ 846.114618] b998 dc97f8b0 dc48ba60 dc48bc00 00000000 00100010 dc48b9ac dc48b9ac 00000000
[ 846.128732] b9b8 00000000 dc48bf80 dc48b9c0 00000000 006e006e dc48b9cc dc48b9cc 00000001
[ 846.142685] b9d8 dd278630 dc48b920 dc48b9e0 00000000 001c001c dc48b9ec dc48b9ec 00000001
[ 846.157051]
[ 846.157051] R0: 0xc5b60dbc:
[ 846.163435] 0dbc 00000000 00000000 00000000 dc9acec0 dcd226c0 00000000 00000000 00000000
[ 846.177274] 0ddc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 846.190866] 0dfc 00000000 dc584c60 dc5fe430 dc5febb0 c0019acc c00eed38 b6f05000 00000000
[ 846.204890] 0e1c bf000000 00000000 b6f05000 bedf2000 dcb84000 00000001 00000002 0000014d
[ 846.218771] 0e3c 05c005c0 00000001 4ca34ca3 c5b60e48 c5b60e48 c5b60e50 c5b60e50 00000989
[ 846.232840] 0e5c 00008b98 0004e13d 00000000 00000000 0004db15 00003391 0000054e 00000000
[ 846.246830] 0e7c 0000001e b6f00000 b6f02574 b6f03d58 b6f04000 b73ea000 b73ff000 bedf1740
[ 846.260918] 0e9c bedf18d3 bedf19e8 bedf19e8 bedf1fe4 00000010 002fb0d7 00000006 00001000
[ 846.275412]
[ 846.275412] R4: 0xdc5feb30:
[ 846.281766] eb30 00000000 00000000 00000000 dd278608 dd278608 dc48b9c0 00000000 000b6eec
[ 846.295880] eb50 00000000 00000000 b6eee000 b6eef000 dc5fed68 dc5feb00 dc5fe489 dc5fed78
[ 846.309723] eb70 dc5feb10 00000000 c5b60e00 0000059f 00040075 00000000 00000000 00000000
[ 846.323619] eb90 00000000 dc5feb94 dc5feb94 00000000 c0870734 000b6eee 00000000 c0dab158
[ 846.337515] ebb0 be8a4000 bedf2000 00000000 dc584160 dc584170 00000000 00000000 074a5000
[ 846.351404] ebd0 c5b60e00 0000079f 00100173 00000000 00000000 00000000 00000000 dd278348
[ 846.365345] ebf0 dd278348 dc48b960 00000000 000beab2 00000000 00000000 b6f03000 b6f04000
[ 846.379279] ec10 dc5fe738 dc5fe268 dc5fe489 dc584170 dc5fe640 074a5000 c5b60e00 0000079f
[ 846.393814]
[ 846.393814] R5: 0xdc5feb64:
[ 846.400191] eb64 dc5feb00 dc5fe489 dc5fed78 dc5feb10 00000000 c5b60e00 0000059f 00040075
[ 846.414418] eb84 00000000 00000000 00000000 00000000 dc5feb94 dc5feb94 00000000 c0870734
[ 846.428171] eba4 000b6eee 00000000 c0dab158 be8a4000 bedf2000 00000000 dc584160 dc584170
[ 846.442142] ebc4 00000000 00000000 074a5000 c5b60e00 0000079f 00100173 00000000 00000000
[ 846.456008] ebe4 00000000 00000000 dd278348 dd278348 dc48b960 00000000 000beab2 00000000
[ 846.469743] ec04 00000000 b6f03000 b6f04000 dc5fe738 dc5fe268 dc5fe489 dc584170 dc5fe640
[ 846.483819] ec24 074a5000 c5b60e00 0000079f 00100871 dc97db84 dcff1f4c dd5d46b4 00000002
[ 846.497941] ec44 dd278688 dd278688 dc48b920 c0878c90 00000002 dd249600 00000000 b6e00000
[ 846.512438]
[ 846.512438] R7: 0xdc5feb64:
[ 846.518781] eb64 dc5feb00 dc5fe489 dc5fed78 dc5feb10 00000000 c5b60e00 0000059f 00040075
[ 846.532741] eb84 00000000 00000000 00000000 00000000 dc5feb94 dc5feb94 00000000 c0870734
[ 846.546607] eba4 000b6eee 00000000 c0dab158 be8a4000 bedf2000 00000000 dc584160 dc584170
[ 846.560796] ebc4 00000000 00000000 074a5000 c5b60e00 0000079f 00100173 00000000 00000000
[ 846.574591] ebe4 00000000 00000000 dd278348 dd278348 dc48b960 00000000 000beab2 00000000
[ 846.588472] ec04 00000000 b6f03000 b6f04000 dc5fe738 dc5fe268 dc5fe489 dc584170 dc5fe640
[ 846.602488] ec24 074a5000 c5b60e00 0000079f 00100871 dc97db84 dcff1f4c dd5d46b4 00000002
[ 846.616753] ec44 dd278688 dd278688 dc48b920 c0878c90 00000002 dd249600 00000000 b6e00000
[ 846.631408]
[ 846.631408] R9: 0xc5b60d80:
[ 846.637815] 0d80 00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[ 846.651143] 0da0 c0c46660 00000004 000003b7 00000000 00000000 b6f68000 0001008d 00000000
[ 846.665205] 0dc0 00000000 00000000 dc9acec0 dcd226c0 00000000 00000000 00000000 00000000
[ 846.678800] 0de0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 846.692132] 0e00 dc584c60 dc5fe430 dc5febb0 c0019acc c00eed38 b6f05000 00000000 bf000000
[ 846.706209] 0e20 00000000 b6f05000 bedf2000 dcb84000 00000001 00000002 0000014d 05c005c0
[ 846.720357] 0e40 00000001 4ca34ca3 c5b60e48 c5b60e48 c5b60e50 c5b60e50 00000989 00008b98
[ 846.734392] 0e60 0004e13d 00000000 00000000 0004db15 00003391 0000054e 00000000 0000001e
[ 846.749070]
[ 846.749070] R10: 0xdc5feb6c:
[ 846.755488] eb6c dc5fed78 dc5feb10 00000000 c5b60e00 0000059f 00040075 00000000 00000000
[ 846.769452] eb8c 00000000 00000000 dc5feb94 dc5feb94 00000000 c0870734 000b6eee 00000000
[ 846.783506] ebac c0dab158 be8a4000 bedf2000 00000000 dc584160 dc584170 00000000 00000000
[ 846.797669] ebcc 074a5000 c5b60e00 0000079f 00100173 00000000 00000000 00000000 00000000
[ 846.811509] ebec dd278348 dd278348 dc48b960 00000000 000beab2 00000000 00000000 b6f03000
[ 846.825548] ec0c b6f04000 dc5fe738 dc5fe268 dc5fe489 dc584170 dc5fe640 074a5000 c5b60e00
[ 846.839692] ec2c 0000079f 00100871 dc97db84 dcff1f4c dd5d46b4 00000002 dd278688 dd278688
[ 846.853859] ec4c dc48b920 c0878c90 00000002 dd249600 00000000 b6e00000 b6e01000 dc5fecb8
[ 846.870044] CPU: 2 PID: 858 Comm: app_process Not tainted 3.10.0 #0
[ 846.880854] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 846.890313] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 846.899667] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 846.909146] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 846.915598] Exception stack(0xdccd5da8 to 0xdccd5df0)
[ 846.922895] 5da0: c5b60e3c 00000000 38951000 000005c0 dc5febb0 dc5febe4
[ 846.931445] 5dc0: 000beab2 dc5febe4 00000000 c5b60e00 dc5febec 00004000 dc48b978 dccd5df0
[ 846.938506] 5de0: c00efa78 c08633a0 600f0113 ffffffff
[ 846.947841] [] (__irq_svc+0x40/0x70) from [] (_raw_spin_unlock+0x14/0x40)
[ 846.958041] [] (_raw_spin_unlock+0x14/0x40) from [] (expand_downwards+0x118/0x140)
[ 846.968283] [] (expand_downwards+0x118/0x140) from [] (do_anonymous_page.isra.64+0x68/0x264)
[ 846.979025] [] (do_anonymous_page.isra.64+0x68/0x264) from [] (__handle_mm_fault+0x70/0x7c)
[ 846.989236] [] (__handle_mm_fault+0x70/0x7c) from [] (handle_mm_fault+0xb0/0x12c)
[ 846.999042] [] (handle_mm_fault+0xb0/0x12c) from [] (do_page_fault+0xc0/0x2c4)
[ 847.007994] [] (do_page_fault+0xc0/0x2c4) from [] (do_DataAbort+0x34/0x98)
[ 847.017220] [] (do_DataAbort+0x34/0x98) from [] (__dabt_usr+0x34/0x40)
[ 847.023420] Exception stack(0xdccd5fb0 to 0xdccd5ff8)
[ 847.029812] 5fa0: ffffffff 00000000 00000003 00000000
[ 847.038215] 5fc0: be8a5000 be5f2000 bedf0000 b73fb6c8 b5197ae8 be5f3000 0000035a 00004000
[ 847.045900] 5fe0: b6dcc6c0 bedf00e0 b6d8cb2d b50c6cfa 800f0030 ffffffff
[ 847.052517] IPI backtrace for cpu 1
[ 847.058562]
[ 847.065213] CPU: 1 PID: 188 Comm: logd.writer Not tainted 3.10.0 #0
[ 847.071898] task: dd7c8a80 ti: dd7dc000 task.ti: dd7dc000
[ 847.079012] PC is at __do_softirq+0x78/0x2b4
[ 847.085020] LR is at msecs_to_jiffies+0x18/0x24
[ 847.091893] pc : [] lr : [] psr: 600f0113
[ 847.091893] sp : dd7ddf40 ip : 00000000 fp : 0000000a
[ 847.100995] r10: b836e718 r9 : b6f47e40 r8 : 00000000
[ 847.106872] r7 : b6ca9bf0 r6 : 00000002 r5 : 00000000 r4 : dd7dc000
[ 847.112955] r3 : 00000001 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 847.119576] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 847.126231] Control: 10c5387d Table: 05bb406a DAC: 00000015
[ 847.131528]
[ 847.131528] PC: 0xc003ddd8:
[ 847.138371] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 847.153963] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 847.169137] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 847.184199] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 847.198843] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 847.213671] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 847.228515] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 847.243422] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 847.258676]
[ 847.258676] LR: 0xc003cee4:
[ 847.265240] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 847.280276] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 847.295078] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 847.309703] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 847.324261] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 847.338871] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 847.353674] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 847.368465] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 847.383421]
[ 847.383421] SP: 0xdd7ddec0:
[ 847.390019] dec0 00000007 c0013020 fed91000 dd7ddef8 c0c21484 dd7ddf2c 00000000 b6f47e40
[ 847.404788] dee0 b836e718 c0008558 c003de58 600f0113 ffffffff c000d600 00000001 c0e4c1c0
[ 847.419567] df00 00000000 00000001 dd7dc000 00000000 00000002 b6ca9bf0 00000000 b6f47e40
[ 847.433975] df20 b836e718 0000000a 00000000 dd7ddf40 c003cf64 c003de58 600f0113 ffffffff
[ 847.448435] df40 b6ca9bf0 0000001d b6f47e40 00400040 0000d9a3 00000001 00000000 600f0193
[ 847.463132] df60 00000000 c0c21484 b6ca9bf0 00000000 b6f47e40 b836e718 0000000a c003e150
[ 847.477795] df80 dd7dc000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dd7ddfb0 c000853c
[ 847.492420] dfa0 b6eee7e8 800f0030 ffffffff c000d7bc 3677e038 b6f210e8 00000003 b6f212c8
[ 847.507504]
[ 847.507504] R1: 0xc0e4c140:
[ 847.514061] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 847.528153] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 847.542207] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 847.556750] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 847.570646] c1c0 000002c2 00000000 00000000 00001458 0000000b 00000001 00000000 00000000
[ 847.584914] c1e0 0000000a 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 847.598776] c200 00000000 00000000 00000000 00002246 00000008 00000002 00000000 00000000
[ 847.613026] c220 00000006 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 847.627256]
[ 847.627256] R4: 0xdd7dbf80:
[ 847.633795] bf80 00000000 00000000 00000000 b6b3bc7c 00000000 00000000 00000000 b8f87618
[ 847.648236] bfa0 0000014f c000da00 00000000 00000000 00000006 b6b3bcf4 00000000 00000000
[ 847.662696] bfc0 00000000 00000000 b8f87618 0000014f 00000000 00000000 00000000 00000004
[ 847.676806] bfe0 b6b3bc90 b6b3bc80 b6f0fd37 b6f36ed8 600f0010 00000006 4630e7e8 f948f7fd
[ 847.691477] c000 00000002 00000102 00000000 dd7c8a80 c0c3c138 00000001 00000015 dd7c8a80
[ 847.705866] c020 c1f32cc0 dd7dc000 c5a3e700 00000000 000000c4 de894980 dd7ddf9c dd7ddf18
[ 847.720461] c040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 847.734556] c060 b6caadd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 847.750776] CPU: 1 PID: 188 Comm: logd.writer Not tainted 3.10.0 #0
[ 847.761863] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 847.771691] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 847.781437] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 847.790926] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 847.797453] Exception stack(0xdd7ddef8 to 0xdd7ddf40)
[ 847.803691] dee0: 00000001 c0e4c1c0
[ 847.812000] df00: 00000000 00000001 dd7dc000 00000000 00000002 b6ca9bf0 00000000 b6f47e40
[ 847.820275] df20: b836e718 0000000a 00000000 dd7ddf40 c003cf64 c003de58 600f0113 ffffffff
[ 847.830269] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 847.839284] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 847.848225] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 847.857444] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 847.866471] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 847.875566] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 847.881916] Exception stack(0xdd7ddfb0 to 0xdd7ddff8)
[ 847.888815] dfa0: 3677e038 b6f210e8 00000003 b6f212c8
[ 847.897207] dfc0: 00000051 c0000000 00000051 b6ca9bf0 00000000 b6f47e40 b836e718 0000000a
[ 847.904986] dfe0: b6e95f9c b6ca9b68 b6ed6285 b6eee7e8 800f0030 ffffffff
[ 851.688340] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 851.695999] [mmc0] – Timeout recovery procedure start –
[ 852.703005] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 852.711322] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 852.720458] [mmc0] – Timeout recovery procedure finished –
[ 852.726842] mmcblk0: error -110 sending status command, retrying
[ 871.733206] binder: release 169:471 transaction 2956 in, still active
[ 871.741241] binder: send failed reply for transaction 2956 to 473:816
[ 871.775793] binder: release 169:541 transaction 3103 in, still active
[ 871.782816] binder: send failed reply for transaction 3103 to 726:878
[ 877.436467] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 877.444629] [mmc0] – Timeout recovery procedure start –
[ 877.455796] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 877.462932] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normml clock [mmc0]
[ 877.471820] [mmc0] – Timeout recovery procedure finished –
[ 877.478159] mmcblk0: error -110 sending status command, retrying
[ 902.119066] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD13): error = -110, timeout = 25000ms
[ 902.127146] [mmc0] – Timeout recovery procedure start –
[ 902.138395] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 902.145546] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 902.154441] [mmc0] – Timeout recovery procedure finished –
[ 902.160916] mmcblk0: error -110 sending status command, aborting
[ 902.168849] end_request: I/O error, dev mmcblk0, sector 3792896
[ 902.176161] Buffer I/O error on device mmcblk0p13, logical block 0
[ 902.182170] lost page write due to I/O error on mmcblk0p13
[ 902.373248] Kernel panic - not syncing: EXT4-fs (device mmcblk0p13): panic forced after error
[ 902.373248]
[ 902.851486] EXT4-fs (mmcblk0p13): I/O error while writing superblock
[ 902.909544] CPU: 1 PID: 814 Comm: watchdog Not tainted 3.10.0 #0
[ 902.926753] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 902.943999] [] (show_stack+0x10/0x14) from [] (panic+0x84/0x1e8)
[ 902.960685] [] (panic+0x84/0x1e8) from [] (ext4_handle_error.part.172+0x80/0x8c)
[ 902.964561] EXT4-fs (mmcblk0p13): I/O error while writing superblock
[ 902.990424] [] (ext4_handle_error.part.172+0x80/0x8c) from [] (__ext4_std_error+0x84/0x90)
[ 903.008791] [] (__ext4_std_error+0x84/0x90) from [] (ext4_reserve_inode_write+0x6c/0x78)
[ 903.027762] [] (ext4_reserve_inode_write+0x6c/0x78) from [] (ext4_xattr_set_handle+0xb0/0x3a4)
[ 903.048919] [] (ext4_xattr_set_handle+0xb0/0x3a4) from [] (ext4_initxattrs+0x40/0x60)
[ 903.067360] [] (ext4_initxattrs+0x40/0x60) from [] (security_inode_init_security+0xac/0xe8)
[ 903.085964] [] (security_inode_init_security+0xac/0xe8) from [] (ext4_init_security+0x1c/0x24)
[ 903.105650] [] (ext4_init_security+0x1c/0x24) from [] (__ext4_new_inode+0xd94/0xf94)
[ 903.123836] [] (__ext4_new_inode+0xd94/0xf94) from [] (ext4_mkdir+0xa8/0x208)
[ 903.141157] [] (ext4_mkdir+0xa8/0x208) from [] (vfs_mkdir+0xdc/0x160)
[ 903.157858] [] (vfs_mkdir+0xdc/0x160) from [] (SyS_mkdirat+0x74/0xa8)
[ 903.174683] [] (SyS_mkdirat+0x74/0xa8) from [] (ret_fast_syscall+0x0/0x30)
[ 903.191556] CPU2: stopping
[ 903.201787] CPU: 2 PID: 440 Comm: surfaceflinger Not tainted 3.10.0 #0
[ 903.218563] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 903.235444] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 903.251558] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 903.268026] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 903.281313] Exception stack(0xdd4a5c08 to 0xdd4a5c50)
[ 903.292837] 5c00: 00000001 c0e4c1c0 00000000 00000002 dd4a4000 00000000
[ 903.307944] 5c20: 00000002 dd4a5cf4 00000032 00000000 b73cc1bc 0000000a 00000000 dd4a5c50
[ 903.321697] 5c40: c003cf64 c003de58 600e0113 ffffffff
[ 903.334958] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 903.350846] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 903.366314] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 903.381876] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 903.397433] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 903.413345] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 903.426372] Exception stack(0xdd4a5cc0 to 0xdd4a5d08)
[ 903.438234] 5cc0: c5b408c0 000000c3 00000032 00000093 200e0013 000212a6 000000c3 00000093
[ 903.453277] 5ce0: 00000032 00000000 b73cc1bc dd0aa400 00000032 dd4a5d0c c0234b5c c02344e8
[ 903.466297] 5d00: 600e0013 ffffffff
[ 903.477652] [] (__irq_svc+0x40/0x70) from [] (avc_lookup+0x64/0xbc)
[ 903.493499] [] (avc_lookup+0x64/0xbc) from [] (avc_has_perm_flags+0x34/0x11c)
[ 903.510568] [] (avc_has_perm_flags+0x34/0x11c) from [] (selinux_binder_transaction+0xa0/0xa4)
[ 903.529078] [] (selinux_binder_transaction+0xa0/0xa4) from [] (security_binder_transaction+0x14/0x1c)
[ 903.548952] [] (security_binder_transaction+0x14/0x1c) from [] (binder_transaction+0x228/0x13e0)
[ 903.568281] [] (binder_transaction+0x228/0x13e0) from [] (binder_thread_write+0x7e4/0xe30)
[ 903.586786] [] (binder_thread_write+0x7e4/0xe30) from [] (binder_ioctl_write_read+0xe8/0x330)
[ 903.605412] [] (binder_ioctl_write_read+0xe8/0x330) from [] (binder_ioctl+0x2dc/0x5d0)
[ 903.623121] [] (binder_ioctl+0x2dc/0x5d0) from [] (do_vfs_ioctl+0x210/0x240)
[ 903.639355] [] (do_vfs_ioctl+0x210/0x240) from [] (SyS_ioctl+0x50/0x6c)
[ 903.655635] [] (SyS_ioctl+0x50/0x6c) from [] (ret_fast_syscall+0x0/0x30)
[ 903.669050] CPU0: stopping
[ 903.678337] CPU: 0 PID: 893 Comm: io Not tainted 3.10.0 #0
[ 903.693116] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 903.709392] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 903.725112] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 903.741440] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 903.754502] Exception stack(0xdcf65e20 to 0xdcf65e68)
[ 903.766228] 5e20: 00000001 c0e4c1c0 00000000 00000000 dcf64000 00000000 00000002 dcf65f0c
[ 903.781102] 5e40: b6f0f000 00000000 dcf65f7c 0000000a 00000000 dcf65e68 c003cf64 c003de58
[ 903.794028] 5e60: 60070113 ffffffff
[ 903.805330] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 903.820831] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 903.836160] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 903.851579] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 903.867050] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 903.882740] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 903.895677] Exception stack(0xdcf65ed8 to 0xdcf65f20)
[ 903.905678] 5ec0: 00000000 dcf65f7c
[ 903.920691] 5ee0: 00000000 000b6f0e dca0ea50 80100073 dd75ea80 b6f0e000 b6f0f000 00000000
[ 903.935655] 5f00: dcf65f7c 80100071 dcda2500 dcf65f20 c00f0c50 c00f0988 60070013 ffffffff
[ 903.951649] [] (__irq_svc+0x40/0x70) from [] (mprotect_fixup+0x90/0x1f4)
[ 903.967748] [] (mprotect_fixup+0x90/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 903.984340] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 903.998319] CPU3: stopping
[ 904.008714] CPU: 3 PID: 8 Comm: rcu_preempt Not tainted 3.10.0 #0
[ 904.025332] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 904.042270] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
[ 904.058463] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 904.074916] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 904.088056] Exception stack(0xde8b5d30 to 0xde8b5d78)
[ 904.098809] 5d20: 00000001 c0e4c1c0 00000000 00000003
[ 904.113788] 5d40: de8b4000 00000000 00000002 de8b5e1c dd75e1c0 00000003 dcfb39c0 0000000a
[ 904.128237] 5d60: 00000000 de8b5d78 c003cf64 c003de58 600f0113 ffffffff
[ 904.143005] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 904.158590] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 904.173993] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 904.189611] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 904.205184] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 904.221088] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 904.234104] Exception stack(0xde8b5de8 to 0xde8b5e30)
[ 904.245406] 5de0: c1f44cc0 de8924c0 de8b5e30 0000df0a dd143f00 00000000
[ 904.260359] 5e00: c1f44cc0 00000001 dd75e1c0 00000003 dcfb39c0 de8b5e44 dcc46044 de8b5e30
[ 904.274067] 5e20: c0061d08 c086342c 600f0013 ffffffff
[ 904.287632] [] (__irq_svc+0x40/0x70) from [] (_raw_spin_unlock_irq+0x1c/0x44)
[ 904.305453] [] (_raw_spin_unlock_irq+0x1c/0x44) from [] (finish_task_switch+0x5c/0xd4)
[ 904.323654] [] (finish_task_switch+0x5c/0xd4) from [] (__schedule+0x4a0/0x554)
[ 904.340570] [] (__schedule+0x4a0/0x554) from [] (schedule_timeout+0x220/0x260)
[ 904.357966] [] (schedule_timeout+0x220/0x260) from [] (rcu_gp_kthread+0x184/0x268)
[ 904.376077] [] (rcu_gp_kthread+0x184/0x268) from [] (kthread+0xa0/0xac)
[ 904.392951] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 904.405839] CRU:
[ 904.416096] 00000000: 0000ffff 9fff0042 0fff0021 00000008 00000001 9fff002b 0fff0015 00000008
[ 904.432383] 00000020: 00000103 9fff007f 0fff0040 00000008 00000007 9fff00c5 0fff0014 00000008
[ 904.448087] 00000040: 00000b00 9fff0270 0fff0138 00000008 00005111 00000000 00000000 00000000
[ 904.463826] 00000060: 00004031 0000b108 00000003 00000200 00008100 00008100 00008585 00010014
[ 904.479564] 00000080: 01885091 01885091 0000a101 00002745 00004345 00008a00 00000200 00000200
[ 904.495378] 000000a0: 00000200 0bb8ea60 00010014 00010014 00010014 00000910 00000900 001f05dc
[ 904.511135] 000000c0: 00001703 0000078c 00000040 00000301 00000542 00000742 00004141 00004040
[ 904.526610] 000000e0: 00004141 00000505 00008042 00008f8f 00000000 00000631 00001ee5 00008307
[ 904.541931] 00000100: 00001200 00010014 00004141 00000000 00000000 00000000 00000000 00000000
[ 904.557068] 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.572163] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.587642] 00000160: 00001000 0000ff00 00003d60 0000faf0 00004f80 0000ae7d 0000fbe0 0000c12b
[ 904.603099] 00000180: 00000fa4 00000000 0000080d 000005cc 00000000 0000fe84 00000000 0000c01e
[ 904.618250] 000001a0: 0000017f 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.633301] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.648487] 000001e0: 00000000 00000000 00000000 00640064 00000004 00000000 00000000 00000000
[ 904.663612] 00000200: 00000002 00000000 00000002 00000000 00000002 00000000 00000004 000004e0
[ 904.678651] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.693701] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.708755] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.723843] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.738860] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.753955] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.768994] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.784067] 00000300: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.799133] 00000320: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.814145] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.829203] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.844250] 00000380: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.859311] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.874403] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.889483] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 904.905139] 00000400: 0000ffff 9fff0042 0fff0021 00000008 00000001 9fff002b 0fff0015 00000008
[ 904.918497] Rebooting in 5 seconds..DDR Version 1.00 20160530
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-10 (Sep 05 2022 - 13:23:36)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 20
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2022-09-05#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x006ac5f0)
ramdisk @ 0x05bf0000 (0x00146428)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c4d8 … OK
[ 0.000000] Linux version 3.10.0 (tao@tao-virtual-machine) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #0 SMP PREEMPT Thu Sep 1 15:03:11 CST 2022
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7cc00000
[ 0.000000] ion_reserve: cma reserved base 7cc00000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] Boot mode: PANIC (7) flag: NORMAL (0xc3524200)
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f27000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),-@0x0039C000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2022-09-05_13:23:36
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1993620k/1993620k available, 103532k reserved, 1523712K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bbcd3c (11988 kB)
[ 0.000000] .init : 0xc0bbd000 - 0xc0c16440 ( 358 kB)
[ 0.000000] .data : 0xc0c18000 - 0xc0daadc0 (1612 kB)
[ 0.000000] .bss : 0xc0daadc0 - 0xc0ecbd3c (1156 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:14
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:14
[ 0.493683] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.493698] pid_max: default: 32768 minimum: 301
[ 0.493817] Security Framework initialized
[ 0.493832] SELinux: Initializing.
[ 0.493905] Mount-cache hash table entries: 512
[ 0.494549] Initializing cgroup subsys debug
[ 0.494563] Initializing cgroup subsys memory
[ 0.494590] Initializing cgroup subsys freezer
[ 0.494618] CPU: Testing write buffer coherency: ok
[ 0.494932] /cpus/cpu@0 missing clock-frequency property
[ 0.494945] /cpus/cpu@1 missing clock-frequency property
[ 0.494955] /cpus/cpu@2 missing clock-frequency property
[ 0.494964] /cpus/cpu@3 missing clock-frequency property
[ 0.495017] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.495070] Setting up static identity map for 0xc0863a28 - 0xc0863a80
[ 0.497572] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1825 (version 3.1)
[ 0.571824] CPU1: Booted secondary processor
[ 0.571855] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.591494] CPU2: Booted secondary processor
[ 0.591518] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.611209] CPU3: Booted secondary processor
[ 0.611233] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.611333] Brought up 4 CPUs
[ 0.611363] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.611372] CPU: All CPU(s) started in SVC mode.
[ 0.612108] devtmpfs: initialized
[ 0.616527] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.617621] pinctrl core: initialized pinctrl subsystem
[ 0.617869] regulator-dummy: no parameters
[ 0.631972] NET: Registered protocol family 16
[ 0.633809] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.634185] ion_snapshot: 0x1ea98000 map to 0xe0907000 and copy to 0xc0ea6fcc (version 0.1)
[ 0.634423] Registered FIQ tty driver
[ 0.634820] fiq-debugger is disabled in device tree
[ 0.635546] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.635569] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.635586] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.635603] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.635695] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.635762] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.635823] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.635885] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.635949] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.636012] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.636075] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.636138] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.636205] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.636269] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.636282] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.636293] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.636305] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.636916] rockchip_interrupts_register:bank_num=7
[ 0.638848] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 0.638869] of_get_gpio_init_config:gpio[1] = 136, value = 0
[ 0.638922] rockchip_pinctrl_probe:init ok
[ 0.646003] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.646097] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646110] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.646283] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.646358] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646370] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.646534] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.646605] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646617] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.646778] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.646860] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646872] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.647039] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.647116] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647129] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.647292] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.647371] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647383] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.647555] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.647637] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647649] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.649431] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.649444] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.650032] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.650054] DDR DEBUG: version 1.00 20150126
[ 0.650083] DDR DEBUG: Channel a:
[ 0.650091] DDR DEBUG: DDR3 Device
[ 0.650105] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.650114] DDR DEBUG: Channel b:
[ 0.650121] DDR DEBUG: DDR3 Device
[ 0.650133] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.650143] DDR DEBUG: addr=0xdb4000
[ 0.650152] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.650162] DDR DEBUG: socAddr[0]=0xdb4000, socAddr[1]=0xdb4100
[ 0.650171] DDR DEBUG: chAddr[0]=0xdb4000, chAddr[1]=0xdb4000
[ 0.650183] DDR DEBUG: dtar[0]=0x401b6000, dtar[1]=0x401b6000
[ 0.650236] DDR DEBUG: init success!!! freq=200MHz
[ 0.650245] DDR DEBUG: Channel a:
[ 0.650257] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.650270] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.650282] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.650294] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=18x0, OPD=0x0, OPU=0x0
[ 0.650316] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.650324] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.650331] DDR DEBUG: Channel b:
[ 0.650343] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.650355] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.650367] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.650379] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.650390] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.650399] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.650407] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.674699] bio: create slab at 0
[ 0.675228] Rockchip hdmi driver version 2.0
[ 0.675228] .
[ 0.676418] SCSI subsystem initialized
[ 0.676574] usbcore: registered new interface driver usbfs
[ 0.676619] usbcore: registered new interface driver hub
[ 0.676708] usbcore: registered new device driver usb
[ 0.678980] host_en_gpio= -2
[ 0.681417] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.681879] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.682326] rockch rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.683542] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.683667] media: Linux media interface: v0.10
[ 0.683714] Linux video capture interface: v2.00
[ 0.683771] pps_core: LinuxPPS API ver. 1 registered
[ 0.683781] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.683802] PTP clock support registered
[ 0.683863] i2c-core: driver [bq24296] using legacy suspend method
[ 0.683872] i2c-core: driver [bq24296] using legacy resume method
[ 0.684198] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[ 0.684888] ion_drm_heap_create: 0@0
[ 0.685013] Rockchip ion module is successfully loaded (v1.1)
[ 0.685171] Advanced Linux Sound Architecture Driver Initialized.
[ 0.685608] Bluetooth: Core ver 2.16
[ 0.685646] NET: Registered protocol family 31
[ 0.685656] Bluetooth: HCI device and connection manager initialized
[ 0.685672] Bluetooth: HCI socket layer initialized
[ 0.685685] Bluetooth: L2CAP socket layer initialized
[ 0.685711] Bluetooth: SCO socket layer initialized
[ 0.685942] cfg80211: Calling CRDA to update world regulatory domain
[ 0.686641] act8846_i2c_probe,line=898
[ 0.687649] act8846_parse_dt,line=746
[ 0.688129] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.688151] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.688166] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.688181] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.690309] act_dcdc1: 1200 mV
[ 0.693274] vccio: 3300 mV
[ 0.695138] vdd_logic: 700 ↔ 1500 mV at 1150 mV
[ 0.698104] act_dcdc4: 2000 mV
[ 0.699346] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.701650] act_ldo2: 1050 mV
[ 0.703951] act_ldo3: 2800 mV
[ 0.706265] act_ldo4: 3300 mV
[ 0.708564] act_ldo5: 3300 mV
[ 0.710975] act_ldo6: 1100 mV
[ 0.713288] vcc_18: 1800 mV
[ 0.715598] act_ldo8: 1850 mV
[ 0.720381] vdd_arm: 712 ↔ 1500 mV at 1350 mV
[ 0.725094] vdd_gpu: 712 ↔ 1500 mV at 900 mV
[ 0.725865] rk808_i2c_probe,line=1355
[ 0.727199] The device is not rk808 -11
[ 0.727285] rk808: probe of 0-001b failed with error -11
[ 0.727362] i2c-core: driver [rk818] using legacy suspend method
[ 0.727372] i2c-core: driver [rk818] using legacy resume method
[ 0.729334] Switching to clocksource arch_sys_counter
[ 0.753467] rga: Module initialized.
[ 0.754177] rga2 ff920000.rga: rga ion client create success!
[ 0.754351] rga: Driver loaded succesfully
[ 0.754557] fb disp policy is box
[ 0.754598] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.754610] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.754950] rk-screen rk_screen.8: rockchip screen probe success
[ 0.755214] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.755587] rk32-edp ff970000.edp: screen is not edp!
[ 0.755606] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.756083] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.756308] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.756601] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.756777] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.756938] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.757654] rk3288-lcdc lcdc0: lcdc0: dclk:297000000>>fps:120
[ 0.757669] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.761503] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.788545] alloc_buffer:ion_phy_addr=0x10000000
[ 0.801462] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.813391] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab6000
[ 0.813437] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.813652] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.813663] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.813940] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.814270] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.814444] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.814617] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.815423] unknow screen type: 0
[ 0.815439] vop ver:3007236,unsupport output color:1
[ 0.815500] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:868
[ 0.815513] rk3288-lcdc lcdc1: wakeup from standby!
[ 0.819354] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.819370] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 0.820248] rockchip_set_mux:warning ignore bank num 15
[ 0.820407] rockchip_set_mux:warning ignore bank num 15
[ 0.820526] rockchip_set_mux:warning ignore bank num 15
[ 0.820653] rockchip_set_mux:warning ignore bank num 15
[ 0.820768] rockchip_set_mux:warning ignore bank num 15
[ 0.820887] rockchip_set_mux:warning ignore bank num 15
[ 0.821474] rockchip_set_mux:warning ignore bank num 15
[ 0.821640] rockchip_set_mux:warning ignore bank num 15
[ 0.822185] rockchip_set_mux:warning ignore bank num 15
[ 0.822342] rockchip_set_mux:warning ignore bank nushell@firefly:/ $ m 15
[ 0.822876] rockchip_set_mux:warning ignore bank num 15
[ 0.823024] rockchip_set_mux:warning ignore bank num 15
[ 0.823560] rockchip_set_mux:warning ignore bank num 15
[ 0.823734] rockchip_set_mux:warning ignore bank num 15
[ 0.825263] NET: Registered protocol family 2
[ 0.825933] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.826033] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.826106] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.826164] TCP: reno registered
[ 0.826178] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.826203] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.826392] NET: Registered protocol family 1
[ 0.827024] Unpacking initramfs…
[ 0.898449] Freeing initrd memory: 1304K (c5bf0000 - c5d36000)
[ 0.899288] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.899919] vcodec_service: probe device ff9a0000.vpu_service
[ 0.900117] vcodec_service: No reset resource define
[ 0.900294] vcodec_service: ff9a0000.vpu_service: power on
[ 0.900380] vcodec_service: probe device ff9a0000.vpu_service
[ 0.900396] vcodec_service: checking hw id 4831
[ 0.901432] vcodec_service: ff9a0000.vpu_service: power off…
[ 0.901477] vcodec_service: done
[ 0.901485] vcodec_service: init success
[ 0.901549] vcodec_service: probe device ff9c0000.hevc_service
[ 0.901904] vcodec_service: ff9c0000.hevc_service: power on
[ 0.901964] vcodec_service: probe device ff9c0000.hevc_service
[ 0.901979] vcodec_service: checking hw id 6867
[ 0.902544] vcodec_service: ff9c0000.hevc_service: power off…
[ 0.902584] vcodec_service: done
[ 0.902592] vcodec_service: init success
[ 0.902730] rknandbase v1.0 2014-03-31
[ 0.902869] rknand: probe of ff400000.nandc failed with error -1
[ 0.902978] rknand_driver:ret = 0
[ 0.904858] audit: initializing netlink socket (disabled)
[ 0.904903] type=2000 audit(0.410:1): initialized
[ 0.905717] bounce pool size: 64 pages
[ 0.910451] fuse init (API version 7.22)
[ 0.910812] msgmni has been set to 952
[ 0.912678] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.912693] io scheduler noop registered
[ 0.912703] io scheduler deadline registered
[ 0.912793] io scheduler cfq registered (default)
[ 0.914004] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 0.914712] IEP Driver loaded succesfully
[ 0.914800] Module initialized.
[ 0.915662] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.915680] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.916392] --11
[ 0.917048] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.917064] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.917372] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[ 0.917387] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[ 0.917396] pwm_regulator_probe:error
[ 0.917416] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[ 0.917623] rk_serial.c v1.8 2014-03-04
[ 0.917875] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 0.918075] serial ff180000.serial: membase e0972000
[ 0.918238] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 0.918410] serial ff190000.serial: membase e097e000
[ 0.918552] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 0.920228] console [ttyS2] enabled
[ 0.920399] serial ff690000.serial: membase fed60000
[ 0.920564] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 0.920734] serial ff1b0000.serial: membase e41be000
[ 0.923606] loop: module loaded
[ 0.923978] zram: Created 1 device(s) …
[ 0.924061] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 0.924073] i2c-core: driver [mpu6050B1] using legacy resume method
[ 0.924090] mpu_init: Probe name mpu6050B1
[ 0.924235] ak8963_mod_init: Probe name ak8963_mod
[ 0.924955] SCSI Media Changer driver v0.25
[ 0.925210] dws->regs: e41e2000
[ 0.926500] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
[ 0.926781] tun: Universal TUN/TAP device driver, 1.6
[ 0.926794] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.926927] vmac_init.
[ 0.927511] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 0.927527] stmmac_probe_config_dt: clock input/output? (input).
[ 0.927540] stmmac_probe_config_dt: TX delay(0x1d).
[ 0.927552] stmmac_probe_config_dt: RX delay(0x16).
[ 0.927600] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 0.927612] stmmc_pltfr_init:
[ 0.927621] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 0.927644] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 0.927654] stmmc_pltfr_init: init for RGMII
[ 0.927665] tx delay=0x1d
[ 0.927665] rx delay=0x16
[ 0.927682] tx delay=0x1d
[ 0.927682] rx delay=0x16
[ 0.928176] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.928199] Normal descriptors
[ 0.928209] Ring mode enabled
[ 0.928219] DMA HW capability register supported
[ 0.928231] RX Checksum Offload Engine supported (type 2)
[ 0.928242] TX Checksum insertion supported
[ 0.928251] Wake-Up On Lan supported
[ 0.928288] Enable RX Mitigation via HW Watchdog Timer
[ 0.928726] PPP generic driver version 2.4.2
[ 0.928879] PPP BSD Compression module registered
[ 0.928893] PPP Deflate Compression module registered
[ 0.928917] PPP MPPE Compression module registered
[ 0.928931] NET: Registered protocol family 24
[ 0.928966] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.928980] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.928993] Rockchip WiFi SYS interface (V1.00) …
[ 0.929028] esp_mem_init enter date Sep 1 2022 15:05:23
[ 0.929039] esp_mem_init VERSION [V2.5]
[ 0.929107] esp_mem_init complete
[ 0.929198] usbcore: registered new interface driver catc
[ 0.929238] usbcore: registered new interface driver kaweth
[ 0.929252] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.929291] usbcore: registered new interface driver pegasus
[ 0.929331] usbcore: registered new interface driver rtl8150
[ 0.929368] usbcore: registered new interface driver r8152
[ 0.929380] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.929444] usbcore: registered new interface driver hso
[ 0.929491] usbcore: registered new interface driver asix
[ 0.929531] usbcore: registered new interface driver ax88179_178a
[ 0.929570] usbcore: registered new interface driver cdc_ether
[ 0.929607] usbcore: registered new interface driver cdc_eem
[ 0.929644] usbcore: registered new interface driver dm9601
[ 0.929681] usbcore: registered new interface driver dm9620
[ 0.929728] usbcore: registered new interface driver smsc75xx
[ 0.929779] usbcore: registered new interface driver smsc95xx
[ 0.929818] usbcore: registered new interface driver gl620a
[ 0.929856] usbcore: registered new interface driver net1080
[ 0.929895] usbcore: registered new interface driver plusb
[ 0.929935] usbcore: registered new interface driver rndis_host
[ 0.929974] usbcore: registered new interface driver cdc_subset
[ 0.930012] usbcore: registered new interface driver zaurus
[ 0.930057] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.930121] usbcore: registered new interface driver int51x1
[ 0.930161] usbcore: registered new interface driver kalmia
[ 0.930200] usbcore: registered new interface driver ipheth
[ 0.930261] usbcore: registered new interface driver sierra_net
[ 0.930307] usbcore: registered new interface driver cx82310_eth
[ 0.930361] usbcore: registered new interface driver cdc_ncm
[ 0.930402] usbcore: registered new interface driver qmi_wwan
[ 0.930443] usbcore: registered new interface driver cdc_mbim
[ 0.930456] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.932918] EHCI: ehci_rk_probe e4240000 e4240010
[ 0.932937] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 0.932968] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 0.933300] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 0.945889] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 0.945974] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.945990] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.946006] usb usb1: Product: EHCI Host Controller
[ 0.946019] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 0.946033] usb usb1: SerialNumber: ff500000.usb
[ 0.946546] hub 1-0:1.0: USB hub found
[ 0.946575] hub 1-0:1.0: 1 port detected
[ 0.946747] EHCI: ehci_rk_probe ok
[ 0.946860] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.947161] usbcore: registered new interface driver cdc_acm
[ 0.947175] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.947229] usbcore: registered new interface driver usblp
[ 0.947274] usbcore: registered new interface driver cdc_wdm
[ 0.947349] usbcore: registered new interface driver usb-storage
[ 0.947392] usbcore: registered new interface driver ums-alauda
[ 0.947430] usbcore: registered new interface driver ums-cypress
[ 0.947469] usbcore: registered new interface driver ums-datafab
[ 0.947507] usbcore: registered new interface driver ums_eneub6250
[ 0.947546] usbcore: registered new interface driver ums-freecom
[ 0.947585] usbcore: registered new interface driver ums-isd200
[ 0.947623] usbcore: registered new interface driver ums-jumpshot
[ 0.947660] usbcore: registered new interface driver ums-karma
[ 0.947700] usbcore: registered new interface driver ums-onetouch
[ 0.947746] usbcore: registered new interface driver ums-sddr09
[ 0.947787] usbcore: registered new interface driver ums-sddr55
[ 0.947827] usbcore: registered new interface driver ums-usbat
[ 0.947919] usbcore: registered new interface driver usbserial
[ 0.947962] usbcore: registered new interface driver usbserial_generic
[ 0.947996] usbserial: USB Serial support registered for generic
[ 0.948041] usbcore: registered new interface driver ch341
[ 0.948074] usbserial: USB Serial support registered for ch341-uart
[ 0.948122] usbcore: registered new interface driver cp210x
[ 0.948153] usbserial: USB Serial support registered for cp210x
[ 0.948203] usbcore: registered new interface driver option
[ 0.948235] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.948327] usbcore: registered new interface driver pl2303
[ 0.948359] usbserial: USB Serial support registered for pl2303
[ 0.948408] usbcore: registered new interface driver trancevibrator
[ 0.948421] usb20_otg: version 3.10a 21-DEC-2012
[ 0.948862] e4280040
[ 0.948876] Core Release: 3.10a
[ 0.948894] Setting default values for core params
[ 0.949026] Using Buffer DMA mode
[ 0.949038] Periodic Transfer Interrupt Enhancement - disabled
[ 0.949049] Multiprocessor Interrupt Enhancement - disabled
[ 0.949060] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.949071] ^^^^^^^^^^^^^^^^^Device Mode
[ 0.949085] Dedicated Tx FIFOs mode
[ 0.949104] pcd_init otg_dev = ddfadd00
[ 0.949279] usb20_otg ff580000.usb: DWC OTG Controller
[ 0.949311] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 0.949343] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 0.949404] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.949420] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.949434] usb usb2: Product: DWC OTG Controller
[ 0.949447] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.949460] usb usb2: SerialNumber: ff580000.usb
[ 0.949922] hub 2-0:1.0: USB hub found
[ 0.949946] hub 2-0:1.0: 1 port detected
[ 0.950261] usb20_host: version 3.10a 21-DEC-2012
[ 0.952821] e4300040
[ 0.952835] Core Release: 3.10a
[ 0.952851] Setting default values for core params
[ 0.952965] Using Buffer DMA mode
[ 0.952976] Periodic Transfer Interrupt Enhancement - disabled
[ 0.952987] Multiprocessor Interrupt Enhancement - disabled
[ 0.952999] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.953009] ^^^^^^^^^^^^^^^^^^Host Mode
[ 0.953039] usb20_host ff540000.usb: DWC OTG Controller
[ 0.953065] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 0.953096] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 0.953188] Init: Power Port (0)
[ 0.953245] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.953261] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.953275] usb usb3: Product: DWC OTG Controller
[ 0.953289] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.953302] usb usb3: SerialNumber: ff540000.usb
[ 0.953726] hub 3-0:1.0: USB hub found
[ 0.953749] hub 3-0:1.0: 1 port detected
[ 0.954439] usbcore: registered new interface driver xpad
[ 0.954496] usbcore: registered new interface driver usb_acecad
[ 0.954541] usbcore: registered new interface driver aiptek
[ 0.954591] usbcore: registered new interface driver gtco
[ 0.954638] usbcore: registered new interface driver hanwang
[ 0.954684] usbcore: registered new interface driver kbtab
[ 0.954734] usbcore: registered new interface driver wacom
[ 0.954865] ==gsl_ts_init==
[ 0.954913] ret=0
[ 0.955189] sensor_register_slave:mma8452,id=17
[ 0.955203] sensor_register_slave:gs_mc3230,id=23
[ 0.955214] gsensor_init
[ 0.955224] sensor_register_slave:mpu6880_acc,id=24
[ 0.955235] sensor_register_slave:mpu6500_acc,id=25
[ 0.955247] sensor_register_slave:cm3217,id=48
[ 0.955258] sensor_register_slave:cm3218,id=49
[ 0.955487] .. rk pwm remotectl v1.1 init
[ 0.955761] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 0.960789] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 0.961413] i2c /dev entries driver
[ 0.962094] IR NEC protocol handler initialized
[ 0.962107] IR RC5(x) protocol handler initialized
[ 0.962119] IR RC6 protocol handler initialized
[ 0.962129] IR JVC protocol handler initialized
[ 0.962139] IR Sony protocol handler initialized
[ 0.962149] IR RC5 (streamzap) protocol handler initialized
[ 0.962159] IR SANYO protocol handler initialized
[ 0.962169] IR MCE Keyboard/mouse protocol handler initialized
[ 0.962344] usbcore: registered new interface driver uvcvideo
[ 0.962356] USB Video Class driver (1.1.1)
[ 0.962370] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 0.962604] hdmi->edidread:1[ 0.963852] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 0.963878] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 0.963899] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 0.963922] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 0.963962] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 0.963962]
[ 0.964036] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 0.964187] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe41f8000 size: 0x4000)
[ 0.964836] D1:camsys_platform_probe(1446): ff910000.isp memory:
[ 0.964855] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe4220000 size: 0x10000)
[ 0.964872] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1df2d000 vir: 0xddf2d000 size: 0x1000)
[ 0.964887] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 0.964900] D1:camsys_platform_probe(1471): Probe ff910000.isp device success
[ 0.965325] not find test_power_init dev node
[ 0.965383] i2c-core: driver [bq27320] using legacy suspend method
[ 0.965395] i2c-core: driver [bq27320] using legacy resume method
[ 0.965771] rockchip_temp_probe,line=364
[ 1.024606] tsadc ff280000.tsadc: initialized
[ 1.025004] device-mapper: uevent: version 1.0.3
[ 1.025269] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.025567] Bluetooth: HCI UART driver ver 2.2
[ 1.025584] Bluetooth: HCI H4 protocol initialized
[ 1.025595] Bluetooth: HCILL protocol initialized
[ 1.025607] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.025620] rtk_btusb: Register usb char device interface for BT driver
[ 1.025811] usbcore: registered new interface driver rtk_btusb
[ 1.026452] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(594000), use default, just enable dvfs
[ 1.030596] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.030803] cpuidle: using governor ladder
[ 1.030817] cpuidle: using governor menu
[ 1.030854] Synopsys Designware Multimedia Card Interface Driver
[ 1.030865] MHSC version = Ver 2.00 2015-06-10
[ 1.031197] dw cru_regsbase addr 0x1d8.
[ 1.031211] dw cru_reset_offset val 3.
[ 1.031227] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.031275] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.031599] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.031767] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.031913] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.044295] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.058823] hdmi output corlor mode is 3
[ 1.058841] hdmi connect to lcdc1
[ 1.058853] switch:en=1,lcdc_id=1,screen type=6,cur type=0
[ 1.064005] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.064031] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.064051] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.064363] dw cru_regsbase addr 0x1d8.
[ 1.064376] dw cru0.
[ 1.064390] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.064430] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.065157] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.065317] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.065772] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.065842] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.083651] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.096088] mmc0: BKOPS_EN bit is not set
[ 1.097949] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.100228] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.100250] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.100270] [mmc0] tuning regsbase addr 0x218.
[ 1.100780] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 1.100791] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.100818] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 1.100843] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 1.100852] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.100878] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 1.101089] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-180 (17 len)
[ 1.101101] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 214-282 (7 len)
[ 1.101111] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-180 (17 len)
[ 1.101122] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 90
[ 1.101161] mmc0: new HS200 MMC card at address 0001
[ 1.101454] mmcblk0: mmc0:0001 AGND3R 14.5 GiB
[ 1.101572] mmcblk0rpmb: mmc0:0001 AGND3R partition 3 4.00 MiB
[ 1.101889] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.101900] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.101910] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.101919] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.101927] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.101935] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.101944] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.101952] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.101960] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.101968] system: 0x012400000 – 0x072400000 (1536 MB)
[ 1.101977] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 1.101986] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 1.101994] userdata: 0x073800000 – 0x3a3a00000 (13058 MB)
[ 1.102022] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13[ 1.103392] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.103407] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.103729] dw cru_regsbase addr 0x1d8.
[ 1.103738] dw cru_reset_offset val 1.
[ 1.103748] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.103787] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.104043] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.104171] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.104420] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.123004] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.142691] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.142712] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.142724] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.143021] leds-gpio leds.29: pins are not configured from the driver
[ 1.143231] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.144664] usbcore: registered new interface driver usbhid
[ 1.144673] usbhid: USB HID core driver
[ 1.144794] ashmem: initialized
[ 1.144911] logger: created 256K log ‘log_main’
[ 1.145012] logger: created 256K log ‘log_events’
[ 1.145105] logger: created 256K log ‘log_radio’
[ 1.145197] logger: created 256K log ‘log_system’
[ 1.146314] input: rk29-keypad as /devices/ff100000.adc/key.32/input/input1
[ 1.147201] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.147220] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.147231] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.147242] ES8323 2-0010: Error applying setting, reverse things back
[ 1.147292] es8323_adc = 0
[ 1.147304] jp es8323_line_det_gpio:-1
[ 1.147556] es8323 probe i2c recv ok
[ 1.148508] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.149093] es8323_probe
[ 1.309950] rk_fb_switch_screen: wait update_regs_wait timeout
[ 1.310004] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
[ 1.310039] pixel clk is 74250000 tmds clk is 74250000
[ 1.310087] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output HDMI.
[ 1.782642] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 1.782655] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 1.782665] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 1.782673] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 1.782683] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 1.782691] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 1.782701] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 1.782709] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 1.782719] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 1.782727] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 1.782736] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 1.782744] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 1.782754] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 1.782761] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 1.782770] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 1.782777] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 1.782786] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 1.782794] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 1.782803] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 1.782811] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 1.782819] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 1.782827] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 1.782836] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 1.782844] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 1.782854] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 1.782862] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 1.782871] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 1.782878] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 1.782887] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 1.782894] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 1.782903] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 1.782911] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 1.782932] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 1.782939] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 1.782948] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 1.782956] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 1.782965] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 1.782973] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 1.782982] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 1.782990] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 1.782999] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 1.783007] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 1.783015] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 1.783023] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 1.783172] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 1.783185] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 1.783195] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 1.783206] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 1.783227] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 1.789648] rockchip-es8323 rockchip-es8323.27: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
[ 1.790043] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.27/sound/card0/input2
[ 1.790445] u32 classifier
[ 1.790453] Actions configured
[ 1.790464] Netfilter messages via NETLINK v0.30.
[ 1.790516] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.790792] ctnetlink v0.93: registering with nfnetlink.
[ 1.790853] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.790860] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.791075] xt_time: kernel timezone is -0000
[ 1.791237] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.791354] arp_tables: (C) 2002 David S. Miller
[ 1.791388] TCP: cubic registered
[ 1.791394] Initializing XFRM netlink socket
[ 1.791562] NET: Registered protocol family 10
[ 1.792023] mip6: Mobile IPv6
[ 1.792048] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.792196] sit: IPv6 over IPv4 tunneling driver
[ 1.792486] NET: Registered protocol family 17
[ 1.792507] NET: Registered protocol family 15
[ 1.792552] Bridge firewalling registered
[ 1.792563] Ebtables v2.0 registered
[ 1.792727] Bluetooth: RFCOMM TTY layer initialized
[ 1.792763] Bluetooth: RFCOMM socket layer initialized
[ 1.792771] Bluetooth: RFCOMM ver 1.11
[ 1.792777] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.792783] Bluetooth: BNEP filters: protocol multicast
[ 1.792792] Bluetooth: BNEP socket layer initialized
[ 1.792799] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.792809] Bluetooth: HIDP socket layer initialized
[ 1.792832] l2tp_core: L2TP core driver, V2.0
[ 1.792844] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.792850] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.793053] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.793062] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 1.793071] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.793078] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.793086] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.793094] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.793115] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 1.793133] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 1.793141] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.793166] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 1.793174] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.793210] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.793334] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 1.793349] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 1.793362] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 1.793374] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 1.793387] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 1.793429] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.793522] [BT_RFKILL]: ** disable irq
[ 1.793593] [BT_RFKILL]: ap6335 device registered.
[ 1.794274] rk3288_init_suspend
[ 1.794285] rk3288_suspend_init enter
[ 1.794491] rk3288_suspend_init: pm_ctrbits =200007
[ 1.794518] gpio_get_dts_info suspend:4
[ 1.794524] gpio_get_dts_info resume:4
[ 1.794530] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.794555] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.794683] clks_gating_suspend_init:clkgt info ok
[ 1.794769] Registering SWP/SWPB emulation handler
[ 1.794780] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
[ 1.797372] ddrfreq: verion 1.2 20140526
[ 1.797386] ddrfreq: normal 528MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 528MHz
[ 1.797406] ddrfreq: auto-freq=0
[ 1.797411] ddrfreq: auto-freq-table[0] 240MHz
[ 1.797417] ddrfreq: auto-freq-table[1] 324MHz
[ 1.797422] ddrfreq: auto-freq-table[2] 456MHz
[ 1.797427] ddrfreq: auto-freq-table[3] 528MHz
[ 1.806370] act_ldo3: operation not allowed
[ 1.806378] vga_edid_probe: turn on ldo3 done.
[ 1.806626] act_ldo4: operation not allowed
[ 1.806632] vga_edid_probe: turn on ldo done.
[ 1.806876] act_ldo2: operation not allowed
[ 1.806882] vga_edid_probe: turn on ldo2 done.
[ 1.807133] act_ldo8: operation not allowed
[ 1.807139] vga_edid_probe: turn on ldo done.
[ 1.812196] unable to read EDID block.
[ 1.846754] unable to read EDID block.
[ 1.881314] unable to read EDID block.
[ 1.881324] vga-ddc: read and parse edid failed errno:-5.
[ 1.881330] vga_edid_probe: success. 10
[ 1.881445] firefly_vga_get_enable 180, 0
[ 1.881452] firefly_vga_get_status 186
[ 1.881458] firefly_vga_set_enable 159 enable:1
[ 1.881477] firefly_vga_enable 130 start
[ 1.881484] firefly_switch_fb 55
[ 1.881491] switch:en=1,lcdc_id=0,screen type=1,cur type=1
[ 1.881512] regulator-dummy: disabling
[ 1.881539] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 1.881585] VGA ENABLE
[ 1.881787] =======================================================
[ 1.881795] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.881800] =======================================================
[ 1.881807] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 1.881855] dhd_module_init: in
[ 1.881862] ======== dhd_wlan_init_plat_data ========
[ 1.881868] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 1.881873] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 1.881879] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.881899] dhd_wlan_init_gpio: host_oob_irq: 196
[ 1.881904] pcd_pullup, is_on 0
[ 1.881909] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 1.881914] dhd_wifi_platform_load: Enter
[ 1.881928] Power-up adapter ‘DHD generic adapter’
[ 1.881937] file system registered
[ 1.881947] wifi_platform_set_power = 1
[ 1.881953] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.881959] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.881965] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 1.881971] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 1.882469] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.882477] android_usb gadget: Number of LUNs=2
[ 1.882484] lun0: LUN: removable file: (no medium)
[ 1.882489] lun1: LUN: removable file: (no medium)
[ 1.882625] android_usb gadget: android_usb ready
[ 1.882702] sensor_init: Probe name sensors
[ 1.882716] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 1.883242] rtc_hym8563 0-0051: setting system clock to 2022-09-15 05:32:48 UTC (1663219968)
[ 1.889248] rockchip-spdif-card rockchip-spdif-card.25: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
[ 1.890025] ret 1024
[ 1.890390] usbcore: registered new interface driver snd-usb-audio
[ 1.890398] ALSA device list:
[ 1.890403] #0: RK_ES8323
[ 1.890408] #1: RK-SPDIF-CARD
[ 1.890757] Freeing unused kernel memory: 356K (c0bbd000 - c0c16000)
[ 1.988916] [WLAN_RFKILL]: wifi turn on power. 156
[ 2.110250] type=1403 audit(1663219968.720:2): policy loaded auid=4294967295 ses=4294967295
[ 2.134873] init: /init.rk30board.rc: 161: ignored duplicate definition of service ‘catlog’
[ 2.135631] init: could not import file ‘init.box.samba.rc’ from ‘/init.rk30board.rc’
[ 2.137395] init: invalid gid ‘trace’
[ 2.195569] wifi_platform_bus_enumerate device present 1
[ 2.195585] ======== Card detection to detect SDIO card! ========
[ 2.195593] mmc2:mmc host rescan start!
[ 2.236067] init: /dev/hw_random not found
[ 2.236127] keychord: using input dev ff680000.pwm for fevent
[ 2.236142] keychord: using input dev rk29-keypad for fevent
[ 2.240943] init: /dev/hw_random not found
[ 2.241797] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.242537] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
[ 2.244886] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[ 2.248600] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.248688] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
[ 2.249346] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.253984] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.254028] e2fsck: system: clean, 1920/82176 files, 111869/393216 blocks
[ 2.257593] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.257660] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
[ 2.264361] EXT4-fs (mmcblk0p8): recovery complete
[ 2.264674] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.264728] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
[ 2.265062] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 2.268496] EXT4-fs (mmcblk0p11): recovery complete
[ 2.268513] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.268575] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
[ 2.269187] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
[ 2.273245] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.273279] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 2.276994] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.277059] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
[ 2.277102] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.277931] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 2.277968] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 2.278201] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
[ 2.278484] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[ 2.320673] EXT4-fs (mmcblk0p13): recovery complete
[ 2.320952] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.321028] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
[ 2.322220] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.336970] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.337006] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 375/837184 files, 115106/3342848 blocks
[ 2.341007] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 2.341070] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
[ 2.341092] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
[ 2.355162] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
[ 2.355239] mali ffa30000.gpu: Continuing without Mali clock control
[ 2.355281] mali pd enabled
[ 2.355293] clk enabled
[ 2.355306] MALI_DVFS_STEP = 4, div_dvfs = 10
[ 2.355316] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 2.355326] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 2.355335] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
[ 2.355345] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
[ 2.355436] turn on mali power
[ 2.355450] kbase_platform_rk_init,register_reboot_notifier
[ 2.355491] hrtimer: interrupt took 11083 ns
[ 2.355588] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 2.357820] mali ffa30000.gpu: Probed as mali0
[ 2.358801] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.361393] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.361977] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.362705] zram0: detected capacity change from 0 to 533413888
[ 2.407286] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 2.412057] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 2.437498] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
[ 2.445278] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 2.445329] bat_cap: oldcap_path no exist
[ 2.445472] binder: 157:157 transaction failed 29189, size 0-0
[ 2.446007] init: Warning! Service displayd needs a SELinux domain defined; please fix!
[ 2.447389] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.448976] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.450540] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.453332] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.475268] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 2.475303] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 2.475340] type=1400 audit(1663219969.090:3): avc: denied { transition } for pid=163 comm=“init” path=“/system/xbin/vm” dev=“mmcblk0p10” ino=1919 scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
[ 2.475525] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 2.476007] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.476026] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.476044] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.476054] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.476076] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.476086] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.476100] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.476110] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.484198] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
[ 2.485734] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
[ 2.486172] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[ 2.486372] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
[ 2.486597] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’
[ 2.509534] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.509560] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 2.509618] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
[ 2.511407] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.511431] mmc2: new high speed SDIO card at address 0001
[ 2.527614] bcmsdh_register: register client driver
[ 2.527709] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.527775] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.527783] bus num (host idx)=2, slot num (rca)=1
[ 2.527789] found adapter info ‘DHD generic adapter’
[ 2.527820] sdioh_attach: set sd_f2_blocksize 128
[ 2.528058] F1 signature read @0x18000000=0x16224335
[ 2.530249] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 2.530588] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 2.530636] wifi_platform_get_mac_addr
[ 2.530643] ======== dhd_wlan_get_mac_addr ========
[ 2.530649] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 2.530658] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 2.530665] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 2.530677] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
[ 2.530719] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 2.531001] wl_create_event_handler(): thread:wl_event_handler:ae started
[ 2.531078] wl_escan_attach: Enter
[ 2.531101] wl_escan_init: Enter
[ 2.531121] tsk Enter, tsk = 0xdd7c149c
[ 2.531136] wl_create_event_handler(): thread:wl_escan_handler:af started
[ 2.531150] tsk Enter, tsk = 0xdd090164
[ 2.531174] dhd_attach(): thread:dhd_watchdog_thread:b0 started
[ 2.531208] dhd_attach(): thread:dhd_dpc:b1 started
[ 2.531249] dhd_attach(): thread:dhd_rxf:b2 started
[ 2.531261] dhd_deferred_work_init: work queue initialized
[ 2.539194] Dongle Host Driver, version 1.201.59.11 (r506368)
[ 2.539194] Compiled in drivers/net/wireless/bcmdhd on Sep 1 2022 at 15:05:23
[ 2.539518] Register interface [wlan0] MAC: e0:76:d0:ea:8f:f2
[ 2.539518]
[ 2.539531] dhd_prot_ioctl : bus is down. we have nothing to do
[ 2.539567] bcmsdh_oob_intr_unregister: Enter
[ 2.539574] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.539584] dhd_txglom_enable: enable 0
[ 2.539591] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
[ 2.539597] dhd_conf_set_txglom_params: txglom_bucket_size=0
[ 2.539603] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[ 2.539611] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0, txctl_tmo_fix=0
[ 2.539618] sdioh_set_mode: set txglom_mode to multi-desc
[ 2.539624] dhd_bus_devreset: WLAN OFF DONE
[ 2.539656] wifi_platform_set_power = 0
[ 2.539663] ======== PULL WL_REG_ON(-1) LOW! ========
[ 2.539670] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.638358] [WLAN_RFKILL]: wifi shut off power.
[ 2.638370] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 2.638377] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.638427] dhd_module_init: Exit err=0
[ 2.728671] type=1400 audit(1663219969.350:4): avc: denied { rlimitinh } for pid=163 comm=“vm” scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
[ 2.728697] type=1400 audit(1663219969.350:5): avc: denied { siginh } for pid=163 comm=“vm” scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
[ 2.890397] logd.auditd: start
[ 2.923721] EHCI: rk_ehci_hcd_enable, disable host controller
[ 2.923733] dwc_otg_hcd_enable, enable host controller
[ 2.979836] firefly_vga_get_enable 180, 1
[ 2.979961] firefly_vga_get_status 186
[ 2.980496] firefly_vga_set_mode 203
[ 3.056574] Using Buffer DMA mode
[ 3.056585] Periodic Transfer Interrupt Enhancement - disabled
[ 3.056590] Multiprocessor Interrupt Enhancement - disabled
[ 3.056596] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.056601] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.100925] Init: Power Port (0)
[ 3.190572] android_usb: already disabled
[ 3.195233] read descriptors
[ 3.195247] read strings
[ 3.195264] mtp_bind_config
[ 3.195288] pcd_pullup, is_on 1
[ 3.386227] Indeed it is in host mode hprt0 = 00021501
[ 3.430048] healthd: No charger supplies found
[ 3.430061] healthd: No battery devices found
[ 3.563348] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 3.563432] Indeed it is in host mode hprt0 = 00001101
[ 3.683783] rk3288-lcdc lcdc0: blank mode:0
[ 3.703700] rk_iommu ff940300.vopl_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab9000
[ 3.760384] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 3.760397] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.760404] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 3.760972] hub 3-1:1.0: USB hub found
[ 3.761056] hub 3-1:1.0: 4 ports detected
[ 8.091098] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.091118] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.091127] D1:camsys_open(739): camsys_marvin(deb68a10) is opened!
[ 8.091209] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 8.091222] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 8.091233] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 8.091248] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 8.091268] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 8.096305] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 8.096317] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 8.096423] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 8.096448] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 8.097513] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 8.098576] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 8.099636] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 8.102853] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 8.104039] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 8.104118] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 8.104130] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 8.104141] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 8.105219] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 8.105245] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 8.107292] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 8.107310] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 8.107320] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 8.107327] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 8.107333] D1:camsys_release(763): camsys_marvin(deb68a10) is closed
[ 8.112661] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.112672] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.112680] D1:camsys_open(739): camsys_marvin(deb68a10) is opened!
[ 8.112778] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
[ 8.112792] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
[ 8.112804] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
[ 8.112812] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 8.112906] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
[ 8.117936] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 8.117947] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 8.118052] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 8.118079] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 8.119143] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 8.120205] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 8.121266] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
[ 8.124478] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
[ 8.124552] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
[ 8.124564] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 8.124575] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 8.125676] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 8.125705] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 8.127755] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
[ 8.127768] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 8.127779] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 8.127786] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 8.127793] D1:camsys_release(763): camsys_marvin(deb68a10) is closed
[ 8.129579] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.129589] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.129597] D1:camsys_open(739): camsys_marvin(deb68a10) is opened!
[ 8.129667] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 8.129697] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 8.134731] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 8.134742] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 8.134847] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 8.134871] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 8.135925] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 8.136984] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 8.138037] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 8.141524] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
[ 8.142986] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
[ 8.143051] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 8.143060] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 8.143067] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 8.144140] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 8.144166] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 8.146207] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 8.146222] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 8.146231] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 8.146237] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 8.146244] D1:camsys_release(763): camsys_marvin(deb68a10) is closed
[ 8.827724] [otg id chg] last id -1 current id 1
[ 8.827746] PortPower off
[ 8.827753] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 8.928491] Using Buffer DMA mode
[ 8.928510] Periodic Transfer Interrupt Enhancement - disabled
[ 8.928516] Multiprocessor Interrupt Enhancement - disabled
[ 8.928522] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 8.928528] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.024961] es8323_mic_state_ctrl read: 0
[ 9.024977] mic_state_switch 0
[ 9.024983] hp_det = 0,insert hp
[ 9.024988] hp mic use intern
[ 9.418139] vbus detect**
[ 9.420330] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 9.597540] Using Buffer DMA mode
[ 9.597559] Periodic Transfer Interrupt Enhancement - disabled
[ 9.597565] Multiprocessor Interrupt Enhancement - disabled
[ 9.597571] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 9.597577] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.597616] soft connect!!!
[ 9.708491] USB RESET
[ 9.750902] android_work: sent uevent USB_STATE=CONNECTED
[ 9.754472] USB RESET
[ 9.817397] android_usb gadget: high-speed config #1: android
[ 9.821625] android_work: sent uevent USB_STATE=CONFIGURED
[ 24.253791] warning: `main’ uses 32-bit capabilities (legacy support in use)
[ 36.580334] healthd: battery none chg=
[ 36.718747] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 36.718769] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 36.718776] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 36.718782] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 36.718789] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 36.718795] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 36.718801] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 37.039509] acc_open
[ 37.039538] acc_release
[ 38.157899] phy_power_on: enable = 1
[ 38.197300] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 38.197336] eth0: device MAC address 96:66:88:c7:6a:0c
[ 38.201361] libphy: stmmac: probed
[ 38.201372] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
[ 38.201380] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
[ 40.399257] type=1400 audit(1663220007.630:6): avc: denied { execute } for pid=1091 comm=“ActivityManager” name=“sh” dev=“mmcblk0p10” ino=322 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 40.399532] type=1400 audit(1663220007.630:7): avc: denied { read open } for pid=1091 comm=“ActivityManager” path=“/system/bin/sh” dev=“mmcblk0p10” ino=322 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 40.399740] type=1400 audit(1663220007.630:8): avc: denied { execute_no_trans } for pid=1091 comm=“ActivityManager” path=“/system/bin/sh” dev=“mmcblk0p10” ino=322 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 40.403325] type=1400 audit(1663220007.630:9): avc: denied { write } for pid=1093 comm=“vm” name=“server” dev=“tmpfs” ino=3163 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=sock_file permissive=1
[ 40.417250] init: untracked pid 1095 exited with status 0
[ 40.417985] type=1400 audit(1663220007.650:10): avc: denied { read write } for pid=546 comm=“ActivityManager” name=“vmdrm0” dev=“tmpfs” ino=8632 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 40.418195] type=1400 audit(1663220007.650:11): avc: denied { open } for pid=546 comm=“ActivityManager” path=“/dev/vmdrm0” dev=“tmpfs” ino=8632 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 40.418275] type=1400 audit(1663220007.650:12): avc: denied { ioctl } for pid=546 comm=“ActivityManager” path=“/dev/vmdrm0” dev=“tmpfs” ino=8632 ioctlcmd=b503 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 40.478665] init: untracked pid 1118 exited with status 0
[ 40.517451] init: untracked pid 1141 exited with status 0
[ 41.724856] saradc-reg[0x00-0x0c]: 0x000003fe 0x00000000 0x00000069 0x00000008
[ 41.928778] read channel() error: -110
[ 43.315197] saradc-reg[0x00-0x0c]: 0x000003fe 0x00000000 0x00000069 0x00000008
[ 43.671010] read channel() error: -110
[ 45.343863] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 45.767667] read channel() error: -110
[ 47.459018] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 47.645837] read channel() error: -110
[ 49.222102] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 49.495760] read channel() error: -110
[ 50.873832] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 51.100035] read channel() error: -110
[ 52.775738] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 52.949897] read channel() error: -110
[ 54.368282] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 54.454621] read channel() error: -110
[ 55.901569] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 56.059051] read channel() error: -110
[ 57.341464] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 57.495836] read channel() error: -110
[ 58.944660] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 59.089753] read channel() error: -110
[ 60.529207] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 60.634578] read channel() error: -110
[ 61.219037] INFO: rcu_preempt self-detected stall on CPU { 0} (t=2100 jiffies g=726 c=725 q=430)
[ 61.232482] Backtrace for cpu 0 (current):
[ 61.239810] CPU: 0 PID: 1157 Comm: io Not tainted 3.10.0 #0
[ 61.244419] INFO: rcu_preempt detected stalls on CPUs/tasks: {[ 61.253093] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 61.261131] [] (show_stack+0x10/0x14) from [] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 61.268948] [] (smp_send_all_cpu_backtrace+0x60/0xcc) from [] (print_cpu_stall+0xb4/0x138)
[ 61.276483] [] (print_cpu_stall+0xb4/0x138) from [] (__rcu_pending+0x68/0x190)
[ 61.284269] [] (__rcu_pending+0x68/0x190) from [] (rcu_check_callbacks+0x160/0x230)
[ 61.292465] [] (rcu_check_callbacks+0x160/0x230) from [] (update_process_times+0x38/0x64)
[ 61.300631] [] (update_process_times+0x38/0x64) from [] (tick_sched_timer+0xac/0xe0)
[ 61.309395] [] (tick_sched_timer+0xac/0xe0) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 61.317753] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 61.326311] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 61.334999] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 61.342974] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 61.350542] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 61.357498] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 61.364175] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 61.368600] Exception stack(0xdc383de8 to 0xdc383e30)
[ 61.373507] 3de0: 00000001 c0e4c1c0 00000000 00000000 dc382000 00000000
[ 61.379019] 3e00: 00000282 dc383ed4 b6f25000 00000001 80100073 0000000a 00000000 dc383e30
[ 61.382978] 3e20: c003cf64 c003de58 60070113 ffffffff
[ 61.389941] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 61.396487] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 61.402886] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 61.409574] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 61.416447] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 61.422993] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 61.427317] Exception stack(0xdc383ea0 to 0xdc383ee8)
0[ 61.432998] 3ea0: dc5e16e0 80100073 dcd3af60 00000000 dc5e16e0 dc5e13c8 dc5e17e8 b6f26000
} (detected by 3, t=2102 jiffies, g=726, c=725, q=430)
[ 61.446706] 3ec0: b6f25000 00000001 80100073 000b6f25 00000000 dc383ee8 c00ee658 c00ed248
[ 61.454432] 3ee0: 60070013 ffffffff
[ 61.464286] [] (__irq_svc+0x40/0x70) from [] (can_vma_merge_after+0x0/0xc0)
[ 61.474227] [] (can_vma_merge_after+0x0/0xc0) from [] (vma_merge+0x90/0x1e0)
[ 61.483341] [] (vma_merge+0x90/0x1e0) from [] (mprotect_fixup+0xc8/0x1f4)
[ 61.492710] [] (mprotect_fixup+0xc8/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 61.502252] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 61.508204]
[ 61.508204] sending IPI to all other CPUs:
[ 61.516795] IPI backtrace for cpu 1
[ 61.522593]
[ 61.529153] CPU: 1 PID: 839 Comm: Binder_4 Not tainted 3.10.0 #0
[ 61.535733] task: dc2af380 ti: dc3d0000 task.ti: dc3d0000
[ 61.543362] PC is at run_timer_softirq+0x18/0x284
[ 61.550186] LR is at run_timer_softirq+0x18/0x284
[ 61.556931] pc : [] lr : [] psr: 200d0113
[ 61.556931] sp : dc3d1f00 ip : 00000000 fp : 0000000a
[ 61.565928] r10: b6f3f57d r9 : 000000fe r8 : 00000001
[ 61.571846] r7 : 00000100 r6 : 00000001 r5 : c0c1a084 r4 : de8d0000
[ 61.578128] r3 : c0c136b0 r2 : 0131d000 r1 : 00001203 r0 : c0c1a084
[ 61.584640] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 61.590971] Control: 10c5387d Table: 1d40006a DAC: 00000015
[ 61.596194]
[ 61.596194] PC: 0xc0044694:
[ 61.602822] 4694 e28d7008 e1a04000 e5272008 e5827004 e5932004 e58d2004 e5827000 e1a0700d
[ 61.617842] 46b4 e7813185 e59d1000 e5833004 e5916000 ea000008 e591300c e3c33003 e1540003
[ 61.632167] 46d4 0a000000 e7f001f2 e1a00004 ebfff9d9 e1a01006 e5966000 e1510007 1afffff4
[ 61.646270] 46f4 e1a00005 e8bd80fe e92d4ff0 e24dd01c e59f3264 ee1d2f90 e7924003 eb005681
[ 61.660399] 4714 e59f3258 e5932000 e5943008 e0633002 e3530000 ba00008e e1a00004 eb207a6d
[ 61.674397] 4734 e1a0200d e3c26d7f e3c6603f ea00007e e6ef5072 e3550000 1a00001c e2841e81
[ 61.688357] 4754 e1a00004 e2811004 e7e52452 ebffffc7 e3500000 1a000015 e5942008 e2841ea1
[ 61.702332] 4774 e1a00004 e2811004 e7e52752 ebffffbf e3500000 1a00000d e5942008 e2841ec1
[ 61.716732]
[ 61.716732] LR: 0xc0044694:
[ 61.723229] 4694 e28d7008 e1a04000 e5272008 e5827004 e5932004 e58d2004 e5827000 e1a0700d
[ 61.737425] 46b4 e7813185 e59d1000 e5833004 e5916000 ea000008 e591300c e3c33003 e1540003
[ 61.751509] 46d4 0a000000 e7f001f2 e1a00004 ebfff9d9 e1a01006 e5966000 e1510007 1afffff4
[ 61.765522] 46f4 e1a00005 e8bd80fe e92d4ff0 e24dd01c e59f3264 ee1d2f90 e7924003 eb005681
[ 61.779587] 4714 e59f3258 e5932000 e5943008 e0633002 e3530000 ba00008e e1a00004 eb207a6d
[ 61.793589] 4734 e1a0200d e3c26d7f e3c6603f ea00007e e6ef5072 e3550000 1a00001c e2841e81
[ 61.807639] 4754 e1a00004 e2811004 e7e52452 ebffffc7 e3500000 1a000015 e5942008 e2841ea1
[ 61.821614] 4774 e1a00004 e2811004 e7e52752 ebffffbf e3500000 1a00000d e5942008 e2841ec1
[ 61.836029]
[ 61.836029] SP: 0xdc3d1e80:
[ 61.842424] 1e80 00000007 c0013020 fed91000 dc3d1eb8 c0c21484 dc3d1eec 00000001 000000fe
[ 61.856448] 1ea0 b6f3f57d c0008558 c0044714 200d0113 ffffffff c000d600 c0c1a084 00001203
[ 61.870495] 1ec0 0131d000 c0c136b0 de8d0000 c0c1a084 00000001 00000100 00000001 000000fe
[ 61.884379] 1ee0 b6f3f57d 0000000a 00000000 dc3d1f00 c0044714 c0044714 200d0113 ffffffff
[ 61.898261] 1f00 701f188c 0000000e 70ae1900 0000000e 701f188c 0000000e 00000000 dc3d0000
[ 61.911957] 1f20 c0c1a084 00000001 00000100 00000001 000000fe b6f3f57d 0000000a c003df24
[ 61.925741] 1f40 b19febd4 0000001d 000000fe 00400040 ffffa30b 00000001 00000000 600d0193
[ 61.939554] 1f60 00000000 c0c21484 b19febd4 b19febd4 000000fe b6f3f57d b6f25c7b c003e150
[ 61.953886]
[ 61.953886] R0: 0xc0c1a004:
[ 61.960251] a004 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 61.973617] a024 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 61.986961] a044 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 62.000300] a064 00000000 00000000 00000000 00000000 00000000 00000000 00000000 c003e62c
[ 62.013824] a084 c00446fc c0683c8c c0687e58 c0269618 c0269b00 c003e70c c006f838 c005a118
[ 62.027886] a0a4 c00a5a20 00000000 00000000 00000000 00000000 00000000 00000000 ffffa30a
[ 62.041455] a0c4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 62.054836] a0e4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 07b307b3
[ 62.068660]
[ 62.068660] R3: 0xc0c13630:
[ 62.075101] 3630 00000000 00000000 0000000e 0006861b 00000000 00000000 00000000 00000000
[ 62.088504] 3650 00000000 00000000 00000000 00000000 00000000 b1807a2a 00000000 00000000
[ 62.101791] 3670 00000000 00000000 00000000 00000000 0000001c 04c4b438 00000000 00000000
[ 62.115240] 3690 6322b91d e7441a38 00000000 ea020000 003c0607 00000000 00000024 00000000
[ 62.128990] 36b0 696c6573 0078756e 00000000 00000000 00000000 00000000 00000000 00000000
[ 62.142457] 36d0 00000000 00000000 00000000 626f3a75 7463656a 643a725f 69766c61 6361636b
[ 62.156169] 36f0 645f6568 5f617461 656c6966 0030733a 03e881a4 000051b0 6311b645 6322b91e
[ 62.170174] 3710 6311b645 00000000 000103e8 00000030 00080080 00000001 0001f30a 00000004
[ 62.184491]
[ 62.184491] R4: 0xde8cff80:
[ 62.190853] ff80 de8cff80 de8cff80 00000000 00000000 de8cff90 de8cff90 de8cffac de873ed0
[ 62.204820] ffa0 c005611c 00000000 00000000 c000da98 00000000 00000000 00000000 00000000
[ 62.218318] ffc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 62.231608] ffe0 00000000 00000000 00000000 00000000 00000013 00000000 fff7f7ff fffdffff
[ 62.245136] 0000 40df40df 00000000 ffffa30a ffff9ab5 00000004 de8d0014 de8d0014 de8d001c
[ 62.259032] 0020 de8d001c de8d0024 de8d0024 de8d002c de8d002c de8d0034 de8d0034 de8d003c
[ 62.273011] 0040 de8d003c de8d0044 de8d0044 de8d004c de8d004c de8d0054 de8d0054 de8d005c
[ 62.287027] 0060 de8d005c de8d0064 de8d0064 de8d006c de8d006c deb6856c deb6856c de8d007c
[ 62.301393]
[ 62.301393] R5: 0xc0c1a004:
[ 62.307781] a004 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 62.321219] a024 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 62.334600] a044 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 62.347935] a064 00000000 00000000 00000000 00000000 00000000 00000000 00000000 c003e62c
[ 62.361354] a084 c00446fc c0683c8c c0687e58 c0269618 c0269b00 c003e70c c006f838 c005a118
[ 62.375359] a0a4 c00a5a20 00000000 00000000 00000000 00000000 00000000 00000000 ffffa30a
[ 62.388842] a0c4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 62.402072] a0e4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 07b307b3
[ 62.417792] CPU: 1 PID: 839 Comm: Binder_4 Not tainted 3.10.0 #0
[ 62.428300] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 62.437831] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 62.446892] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 62.456096] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 62.462608] Exception stack(0xdc3d1eb8 to 0xdc3d1f00)
[ 62.468797] 1ea0: c0c1a084 00001203
[ 62.477162] 1ec0: 0131d000 c0c136b0 de8d0000 c0c1a084 00000001 00000100 00000001 000000fe
[ 62.485445] 1ee0: b6f3f57d 0000000a 00000000 dc3d1f00 c0044714 c0044714 200d0113 ffffffff
[ 62.495487] [] (__irq_svc+0x40/0x70) from [] (run_timer_softirq+0x18/0x284)
[ 62.505289] [] (run_timer_softirq+0x18/0x284) from [] (__do_softirq+0x144/0x2b4)
[ 62.514316] [] (__do_softirq+0x144/0x2b4) from [] (do_softirq+0x44/0x50)
[ 62.522779] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 62.531893] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 62.541052] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 62.550162] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 62.556542] Exception stack(0xdc3d1fb0 to 0xdc3d1ff8)
[ 62.563118] 1fa0: b6f862a8 b6f860e8 00000003 b6f862c8
[ 62.571457] 1fc0: 00000400 c0000000 00000400 b19febd4 b19febd4 000000fe b6f3f57d b6f25c7b
[ 62.579150] 1fe0: b6f80714 b19feb10 b6f3b285 b6f537ec 800d0030 ffffffff
[ 62.585643] IPI backtrace for cpu 2
[ 62.591632]
[ 62.598347] CPU: 2 PID: 1127 Comm: app_process Not tainted 3.10.0 #0
[ 62.605389] task: dc2ae3c0 ti: dc400000 task.ti: dc400000
[ 62.611329] PC is at 0xb6fe7126
[ 62.616386] LR is at 0xb6fe7bab
[ 62.622872] pc : [] lr : [] psr: 60070030
[ 62.622872] sp : bee91348 ip : b6fdf8fc fp : b6be3d80
[ 62.632019] r10: b6bc7000 r9 : 00044e00 r8 : 00000002
[ 62.638061] r7 : 00006802 r6 : b6bc7148 r5 : b6bcd10a r4 : b6d9f934
[ 62.644295] r3 : 02fe73a2 r2 : b6bcd119 r1 : 40000000 r0 : 02fe73e2
[ 62.650878] Flags: nZCv IRQs on FIQs on Mode USER_32 ISA Thumb Segment user
[ 62.657454] Control: 10c5387d Table: 1c45406a DAC: 00000015
[ 62.664440] CPU: 2 PID: 1127 Comm: app_process Not tainted 3.10.0 #0
[ 62.675422] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 62.684927] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 62.694303] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 62.703767] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_usr+0x3c/0x60)
[ 62.710106] Exception stack(0xdc401fb0 to 0xdc401ff8)
[ 62.716945] 1fa0: 02fe73e2 40000000 b6bcd119 02fe73a2
[ 62.725378] 1fc0: b6d9f934 b6bcd10a b6bc7148 00006802 00000002 00044e00 b6bc7000 b6be3d80
[ 62.733033] 1fe0: b6fdf8fc bee91348 b6fe7bab b6fe7126 60070030 ffffffff
[ 62.739229] IPI backtrace for cpu 3
[ 62.744511]
[ 62.750993] CPU: 3 PID: 193 Comm: DispSync Not tainted 3.10.0 #0
[ 62.757986] task: dd6c9500 ti: dd714000 task.ti: dd714000
[ 62.765322] PC is at __do_softirq+0x78/0x2b4
[ 62.771529] LR is at msecs_to_jiffies+0x18/0x24
[ 62.778462] pc : [] lr : [] psr: 600d0113
[ 62.778462] sp : dd715e18 ip : 00000000 fp : 0000000a
[ 62.787846] r10: 600d0013 r9 : dd714000 r8 : 00000002
[ 62.793854] r7 : dd715ebc r6 : 00000082 r5 : 00000000 r4 : dd714000
[ 62.799878] r3 : 00000003 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 62.806356] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 62.812879] Control: 10c5387d Table: 1d40006a DAC: 00000015
[ 62.818312]
[ 62.818312] PC: 0xc003ddd8:
[ 62.825102] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 62.840400] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 62.855225] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 62.869858] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 62.884461] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 62.899241] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 62.913610] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 62.928097] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 62.942963]
[ 62.942963] LR: 0xc003cee4:
[ 62.949441] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 62.963972] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 62.978579] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 62.993050] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 63.007435] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 63.021910] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 63.036415] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 63.050966] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 63.065993]
[ 63.065993] SP: 0xdd715d98:
[ 63.072419] 5d98 00000007 c0013020 fed91000 dd715dd0 c0c21484 dd715e04 00000002 dd714000
[ 63.086849] 5db8 600d0013 c0008558 c003de58 600d0113 ffffffff c000d600 00000001 c0e4c1c0
[ 63.101222] 5dd8 00000000 00000003 dd714000 00000000 00000082 dd715ebc 00000002 dd714000
[ 63.115284] 5df8 600d0013 0000000a 00000000 dd715e18 c003cf64 c003de58 600d0113 ffffffff
[ 63.129567] 5e18 dd715ebc 0000001d dd714000 00400040 ffffa30b 00000003 00000000 600d0193
[ 63.143956] 5e38 00000000 c0c21484 dd715ebc 00000002 dd714000 600d0013 dd715ef4 c003e150
[ 63.160018] 5e58 dd714000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dd715e88 c000853c
[ 63.174399] 5e78 c08633e8 400d0013 ffffffff c000d600 dcca8998 600d0013 00000800 000012e1
[ 63.189280]
[ 63.189280] R1: 0xc0e4c140:
[ 63.195581] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 63.209395] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 63.223242] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 63.238461] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 63.252203] c1c0 00000282 00000000 00000000 0000f6ed 00000006 00000002 00000000 00000000
[ 63.266118] c1e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 63.279807] c200 00000000 00000000 00000000 00011c3a 00000009 00000000 00000000 00000000
[ 63.293576] c220 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 63.307708]
[ 63.307708] R4: 0xdd713f80:
[ 63.313976] 3f80 00000004 00000001 bec5d7b8 b77a34f0 b77a3520 b77a34c0 00000036 c000db84
[ 63.328316] 3fa0 00000000 c000da00 b77a34f0 b77a3520 00000004 c0186201 bec5d7b8 bec5d7b0
[ 63.342561] 3fc0 b77a34f0 b77a3520 b77a34c0 00000036 00000001 b6ec7dd4 00000000 bec5d8cc
[ 63.356800] 3fe0 b77a2f68 bec5d7a0 b6eaeafd b6ea8828 600d0010 00000004 21001d14 2b04edd0
[ 63.371034] 4000 00000002 00000104 00000000 dd6c9500 c0c3c138 00000003 00000015 dd6c9500
[ 63.385344] 4020 c1f44cc0 dd714000 ddec3c00 00000000 0000000e de8e0a80 dd715e54 dd715dd0
[ 63.399597] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 63.413471] 4060 b6a8fdd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 63.427664]
[ 63.427664] R7: 0xdd715e3c:
[ 63.433912] 5e3c c0c21484 dd715ebc 00000002 dd714000 600d0013 dd715ef4 c003e150 dd714000
[ 63.448369] 5e5c c003e3bc 0000001d c000e3d0 0000001d fed91000 dd715e88 c000853c c08633e8
[ 63.462682] 5e7c 400d0013 ffffffff c000d600 dcca8998 600d0013 00000800 000012e1 00000001
[ 63.477206] 5e9c 00000000 00000001 dcca8998 00000002 dd714000 600d0013 dd715ef4 00000110
[ 63.491320] 5ebc dd715ed0 c0065708 c08633e8 400d0013 ffffffff dd48de9c dcca8540 dcca8548
[ 63.505652] 5edc dd48de90 00000000 c0e607f8 dd714000 c0e607f4 b6ef2598 c00828e4 ffffffff
[ 63.519962] 5efc ffffffff 7fffffff 00000001 c0e607ec c0083900 dd715f10 b8a54000 ddec3c00
[ 63.534242] 5f1c 00000ce0 00000000 00000002 00000001 00000000 000000f0 7fffffff b8a54ce0
[ 63.548897]
[ 63.548897] R9: 0xdd713f80:
[ 63.555206] 3f80 00000004 00000001 bec5d7b8 b77a34f0 b77a3520 b77a34c0 00000036 c000db84
[ 63.569568] 3fa0 00000000 c000da00 b77a34f0 b77a3520 00000004 c0186201 bec5d7b8 bec5d7b0
[ 63.583810] 3fc0 b77a34f0 b77a3520 b77a34c0 00000036 00000001 b6ec7dd4 00000000 bec5d8cc
[ 63.598000] 3fe0 b77a2f68 bec5d7a0 b6eaeafd b6ea8828 600d0010 00000004 21001d14 2b04edd0
[ 63.613418] 4000 00000002 00000104 00000000 dd6c9500 c0c3c138 00000003 00000015 dd6c9500
[ 63.627510] 4020 c1f44cc0 dd714000 ddec3c00 00000000 0000000e de8e0a80 dd715e54 dd715dd0
[ 63.641752] 4040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 63.655844] 4060 b6a8fdd0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 63.671999] CPU: 3 PID: 193 Comm: DispSync Not tainted 3.10.0 #0
[ 63.682703] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 63.692460] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x1d8/0x2c8)
[ 63.701803] [] (handle_IPI+0x1d8/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
[ 63.711304] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
[ 63.717658] Exception stack(0xdd715dd0 to 0xdd715e18)
[ 63.724245] 5dc0: 00000001 c0e4c1c0 00000000 00000003
[ 63.732577] 5de0: dd714000 00000000 00000082 dd715ebc 00000002 dd714000 600d0013 0000000a
[ 63.740137] 5e00: 00000000 dd715e18 c003cf64 c003de58 600d0113 ffffffff
[ 63.749405] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 63.758406] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 63.767080] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 63.776382] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 63.785431] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 63.794301] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 63.800515] Exception stack(0xdd715e88 to 0xdd715ed0)
[ 63.807708] 5e80: dcca8998 600d0013 00000800 000012e1 00000001 00000000
[ 63.816028] 5ea0: 00000001 dcca8998 00000002 dd714000 600d0013 dd715ef4 00000110 dd715ed0
[ 63.822957] 5ec0: c0065708 c08633e8 400d0013 ffffffff
[ 63.832605] [] (__irq_svc+0x40/0x70) from [] (_raw_spin_unlock_irqrestore+0x1c/0x44)
[ 63.844147] [] (_raw_spin_unlock_irqrestore+0x1c/0x44) from [] (try_to_wake_up+0x1e8/0x1fc)
[ 63.854874] [] (try_to_wake_up+0x1e8/0x1fc) from [] (wake_futex+0x68/0xa0)
[ 63.864225] [] (wake_futex+0x68/0xa0) from [] (futex_wake+0xdc/0x120)
[ 63.873342] [] (futex_wake+0xdc/0x120) from [] (do_futex+0xd4/0x184)
[ 63.882632] [] (do_futex+0xd4/0x184) from [] (SyS_futex+0x124/0x168)
[ 63.892186] [] (SyS_futex+0x124/0x168) from [] (ret_fast_syscall+0x0/0x30)
[ 63.943751] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 63.947451] [sched_delayed] sched: RT throttling activated
[ 64.492627] read channel() error: -110
[ 66.167744] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 66.381896] read channel() error: -110
[ 66.474341] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD25): error = -110, timeout = 8000ms
[ 66.482428] [mmc0] – Timeout recovery procedure start –
[ 66.493448] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 66.500938] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 66.510126] [mmc0] – Timeout recovery procedure finished –
[ 67.468114] BUG: soft lockup - CPU#0 stuck for 22s! [io:1157]
[ 67.474084] Modules linked in: mali_kbase
[ 67.480946]
[ 67.487021] CPU: 0 PID: 1157 Comm: io Not tainted 3.10.0 #0
[ 67.493406] task: dd590000 ti: dc382000 task.ti: dc382000
[ 67.500421] PC is at __do_softirq+0x78/0x2b4
[ 67.506226] LR is at msecs_to_jiffies+0x18/0x24
[ 67.512945] pc : [] lr : [] psr: 60070113
[ 67.512945] sp : dc383e30 ip : 00000000 fp : 0000000a
[ 67.522044] r10: 80100073 r9 : 00000001 r8 : b6f25000
[ 67.527999] r7 : dc383ed4 r6 : 00000282 r5 : 00000000 r4 : dc382000
[ 67.533947] r3 : 00000000 r2 : 00000000 r1 : c0e4c1c0 r0 : 00000001
[ 67.540538] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 67.547170] Control: 10c5387d Table: 1c11c06a DAC: 00000015
[ 67.552396]
[ 67.552396] PC: 0xc003ddd8:
[ 67.558878] ddd8 e3a00c02 eaffffd4 e59f3290 e3a00002 e92d4ff0 e24dd01c e5934000 ebfffc54
[ 67.574263] ddf8 e1a0100d e0804004 e58d4010 e3c14d7f e3c4403f e594300c e593200c e58d200c
[ 67.589133] de18 e3c22b02 e583200c e59f3254 e5942014 e7936302 e5942004 e2822c01 e5842004
[ 67.604006] de38 e5941014 e3a0b00a e58d1014 e5943014 e3a02000 e59f1228 e7812303 f1080080
[ 67.618459] de58 e59f5220 e3160001 0a000061 e59f2214 e59f3214 e0628005 e5947004 ee1d2f90
[ 67.633013] de78 e1a08148 e0833108 e2833004 e7921003 e2811001 e7821003 e59f31f0 e5932004
[ 67.647544] de98 e3520000 0a00001d e5942004 e2822001 e5842004 e5939010 e3590000 0a000010
[ 67.662324] deb8 e2892008 e1a0c005 e1a0a009 e1a05002 e59a3000 e1a01008 e59a0004 e28aa008
[ 67.677280]
[ 67.677280] LR: 0xc003cee4:
[ 67.683676] cee4 e3a05000 e59f4050 e3e07000 e59f604c ea000002 e0922006 e2811001 e0a33007
[ 67.698313] cf04 e1540002 e0d5c003 bafffff9 ea000003 e0922004 e2411001 e0a33005 ea000001
[ 67.712844] cf24 e59f401c e3a05000 e3520000 e2d3c000 bafffff6 e8800006 e8bd80f0 3b9ac9ff
[ 67.727334] cf44 c4653600 3b9aca00 e3500000 e92d4008 ba000003 e3a0100a e2800009 eb08ecde
[ 67.742039] cf64 e8bd8008 e3e00107 e8bd8008 e92d4008 e59f3020 e1500003 8a000004 e2800c27
[ 67.756480] cf84 e3021710 e280000f eb08ecd3 e8bd8008 e3e00107 e8bd8008 ffffb1e0 e590c000
[ 67.770985] cfa4 e59f303c e5902004 e15c0003 959f3034 83a03000 859fc030 90823003 e59f202c
[ 67.785456] cfc4 e0c32293 e1a00ea2 e1a01ea3 e1800183 e3a03332 e0a10c93 e1a00ca0 e1800381
[ 67.800243]
[ 67.800243] SP: 0xdc383db0:
[ 67.806797] 3db0 00000001 80100073 0000000a c009d544 0000001d c000e3cc 0000001d fed91000
[ 67.821407] 3dd0 dc383de8 c000853c c003de58 60070113 ffffffff c000d600 00000001 c0e4c1c0
[ 67.835901] 3df0 00000000 00000000 dc382000 00000000 00000282 dc383ed4 b6f25000 00000001
[ 67.850541] 3e10 80100073 0000000a 00000000 dc383e30 c003cf64 c003de58 60070113 ffffffff
[ 67.864934] 3e30 dc383ed4 0000001d 00000001 00400100 ffff9abc 00000000 00000000 60070193
[ 67.879165] 3e50 00000000 c0c21484 dc383ed4 b6f25000 00000001 80100073 000b6f25 c003e150
[ 67.893561] 3e70 dc382000 c003e3bc 0000001d c000e3d0 0000001d fed91000 dc383ea0 c000853c
[ 67.908028] 3e90 c00ed248 60070013 ffffffff c000d600 dc5e16e0 80100073 dcd3af60 00000000
[ 67.922924]
[ 67.922924] R1: 0xc0e4c140:
[ 67.929301] c140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 67.943317] c160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 67.957353] c180 00000000 00000000 00010001 c0d7b7dc c0da78d4 00000000 00000000 00000000
[ 67.971602] c1a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 67.985483] c1c0 00000282 00000000 00000000 0000f6ed 00000006 00000002 00000000 00000000
[ 67.999488] c1e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 68.013317] c200 00000000 00000000 00000000 00011c3f 00000009 00000000 00000000 00000000
[ 68.027434] c220 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 68.041646]
[ 68.041646] R4: 0xdc381f80:
[ 68.048106] 1f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 68.061908] 1fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 68.075590] 1fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 68.089241] 1fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 68.102882] 2000 00000002 00010101 00000000 dd590000 c0c3c138 00000000 00000015 dd590000
[ 68.117165] 2020 c1f29cc0 dc382000 dd0e21c0 00000000 00000009 ddc70540 dc383f9c dc383f18
[ 68.131715] 2040 c086234c 00000000 00000000 00000000 00000000 00000000 01010000 00000000
[ 68.145777] 2060 b6fc0e30 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 68.159996]
[ 68.159996] R7: 0xdc383e54:
[ 68.166297] 3e54 c0c21484 dc383ed4 b6f25000 00000001 80100073 000b6f25 c003e150 dc382000
[ 68.180788] 3e74 c003e3bc 0000001d c000e3d0 0000001d fed91000 dc383ea0 c000853c c00ed248
[ 68.195289] 3e94 60070013 ffffffff c000d600 dc5e16e0 80100073 dcd3af60 00000000 dc5e16e0
[ 68.209636] 3eb4 dc5e13c8 dc5e17e8 b6f26000 b6f25000 00000001 80100073 000b6f25 00000000
[ 68.223999] 3ed4 dc383ee8 c00ee658 c00ed248 60070013 ffffffff 000b6f25 00000000 c0c2a470
[ 68.238338] 3ef4 00000000 dc383fb0 dc5e17e8 80100073 dd0e21c0 b6f25000 b6f26000 00000000
[ 68.252765] 3f14 dc383f7c 80100071 c00f09c0 80100073 dcd3af60 00000000 000b6f25 00000000
[ 68.267055] 3f34 00000000 b6f04000 00000001 00000000 00000003 b6f26000 00000003 dc5e17e8
[ 68.284719] CPU: 0 PID: 1157 Comm: io Not tainted 3.10.0 #0
[ 68.295588] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 68.305901] [] (show_stack+0x10/0x14) from [] (watchdog_timer_fn+0x108/0x168)
[ 68.316229] [] (watchdog_timer_fn+0x108/0x168) from [] (__run_hrtimer+0x1a4/0x2b8)
[ 68.326539] [] (__run_hrtimer+0x1a4/0x2b8) from [] (hrtimer_interrupt+0x11c/0x278)
[ 68.337291] [] (hrtimer_interrupt+0x11c/0x278) from [] (arch_timer_handler_phys+0x28/0x30)
[ 68.348830] [] (arch_timer_handler_phys+0x28/0x30) from [] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 68.359602] [] (handle_percpu_devid_irq+0xf8/0x1b4) from [] (generic_handle_irq+0x20/0x30)
[ 68.369968] [] (generic_handle_irq+0x20/0x30) from [] (handle_IRQ+0x64/0x8c)
[ 68.379630] [] (handle_IRQ+0x64/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 68.388755] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 68.395094] Exception stack(0xdc383de8 to 0xdc383e30)
[ 68.402260] 3de0: 00000001 c0e4c1c0 00000000 00000000 dc382000 00000000
[ 68.410588] 3e00: 00000282 dc383ed4 b6f25000 00000001 80100073 0000000a 00000000 dc383e30
[ 68.417592] 3e20: c003cf64 c003de58 60070113 ffffffff
[ 68.426308] [] (__irq_svc+0x40/0x70) from [] (__do_softirq+0x78/0x2b4)
[ 68.435173] [] (__do_softirq+0x78/0x2b4) from [] (do_softirq+0x44/0x50)
[ 68.443760] [] (do_softirq+0x44/0x50) from [] (irq_exit+0x74/0xbc)
[ 68.453637] [] (irq_exit+0x74/0xbc) from [] (handle_IRQ+0x68/0x8c)
[ 68.463176] [] (handle_IRQ+0x68/0x8c) from [] (gic_handle_irq+0x38/0x5c)
[ 68.472132] [] (gic_handle_irq+0x38/0x5c) from [] (__irq_svc+0x40/0x70)
[ 68.478313] Exception stack(0xdc383ea0 to 0xdc383ee8)
[ 68.486144] 3ea0: dc5e16e0 80100073 dcd3af60 00000000 dc5e16e0 dc5e13c8 dc5e17e8 b6f26000
[ 68.494367] 3ec0: b6f25000 00000001 80100073 000b6f25 00000000 dc383ee8 c00ee658 c00ed248
[ 68.500717] 3ee0: 60070013 ffffffff
[ 68.509913] [] (__irq_svc+0x40/0x70) from [] (can_vma_merge_after+0x0/0xc0)
[ 68.519974] [] (can_vma_merge_after+0x0/0xc0) from [] (vma_merge+0x90/0x1e0)
[ 68.528987] [] (vma_merge+0x90/0x1e0) from [] (mprotect_fixup+0xc8/0x1f4)
[ 68.538194] [] (mprotect_fixup+0xc8/0x1f4) from [] (SyS_mprotect+0x164/0x1ec)
[ 68.547861] [] (SyS_mprotect+0x164/0x1ec) from [] (ret_fast_syscall+0x0/0x30)
[ 68.585996] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 68.959675] read channel() error: -110
[ 70.230658] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 70.425546] read channel() error: -110
[ 71.854898] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 72.176887] read channel() error: -110
[ 73.989878] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 74.183743] read channel() error: -110
[ 75.633646] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 75.924625] read channel() error: -110
[ 77.608675] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 77.904628] read channel() error: -110
[ 78.675706] fence timeout on [dd6ad400] after 3000ms
[ 79.451194] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 79.501714] objs:
fb-timeline sw_sync: 454
pt signaled@4.073237: 11
pt signaled@4.156567: 12
pt signaled@4.239914: 13
pt signaled@38.789893: 431
pt signaled@38.806557: 432
pt signaled@40.706568: 454
pt active: 455
pt active: 455
fb-timeline sw_sync: 30
pt signaled@40.695753: 30
pt active: 31
pt active: 31
malitl_162_0xb89b1b00 Mali: 446
malitl_162_0xb8a0dd90 Mali: 12
pt signaled@3.979314: 10(0)
pt signaled@4.062646: 11(0)
pt signaled@4.145776: 12(0)
pt signaled@4.145878: 12(0)
malitl_162_0xb8a0de48 Mali: 0
malitl_384_0xb77d0f28 Mali: 447
pt signaled@40.683481: 447(0)
pt signaled@40.692135: 447(0)
pt active: 448(0)
pt active: 449(0)
malitl_384_0xb77d1088 Mali: 0
fences:
[dcdabe00] FramebufferSurface:0: signaled
[ 79.557908] fb-timeline_pt signaled@4.073237: 11 / 454
[ 79.557908] malitl_162_0xb8a0dd90_pt signaled@3.979314: 10(0) / 12
[ 79.557908]
[ 79.557908] [dcdaba80] FramebufferSurface:1: signaled
[ 79.557908] fb-timeline_pt signaled@4.156567: 12 / 454
[ 79.557908] malitl_162_0xb8a0dd90_pt signaled@4.062646: 11(0)[ 79.685153] read channel() error: -110
[ 80.056523] / 12
[c5b9ab00] mali_fence: signaled
malitl_162_0xb8a0dd90_pt signaled@4.145776: 12(0) / 12
[dcdabb80] FramebufferSurface:2: signaled
fb-timeline_pt signaled@4.239914: 13 / 454
malitl_162_0xb8a0dd90_pt signaled@4.145878: 12(0) / 12
[dc059400] ret_fence: signaled
fb-timeline_pt signaled@38.789893: 431 / 454
[dd288080] ret_fence: signaled
fb-timeline_pt signaled@38.806557: 432 / 454
[dc476d00] ret_fence: signaled
fb-timeline_pt signaled@40.706568: 454 / 454
[dc476f00] ret_fence: signaled
fb-timeline_pt signaled@40.695753: 30 / 30
[dc701080] mali_fence: signaled
malitl_384_0xb77d0f28_pt signaled@40.683481: 447(0) / 447
[dc476300] ret_fence: active
fb-timeline_pt active: 455 / 454
[dc476280] ret_fence: active
fb-timeline_pt active: 31 / 30
[ 80.106036]
[ 80.106036] [dc476b80] BootAnimation:2: active
[ 80.106036] fb-timeline_pt active: 31 / 30
[ 80.106036] malitl_384_0xb77d0f28_pt signaled@40.692135: 447(0) / 447
[ 80.106036] fb-timeline_pt active: 455 / 454
[ 80.106036]
[ 80.106036] [dd6ad400] mali_fence: active
[ 80.106036] malit
