安卓编译不过
SDK包名称:android12
SDK更新到哪个COMMIT:2022-08-30 10:48:04
SDK修改内容:无修改
Log日志:android_3588j_err.zip
执行全编译命令
./FFTools/make.sh -d rk3588-firefly-itx-3588j-mipi101-M101014-BE45-A1 -j8 -l rk3588_firefly_itx_3588j_mipi-userdebug
在uboot和kernel通过以后,编译android不过,出现如下log:
#### build completed successfully (12:04 (mm:ss)) ####
Build kernel ok!
====== start build android
make installclean
build/make/core/soong_config.mk:195: warning: BOARD_PLAT_PUBLIC_SEPOLICY_DIR has been deprecated.
Use SYSTEM_EXT_PUBLIC_SEPOLICY_DIRS instead.
build/make/core/soong_config.mk:196: warning: BOARD_PLAT_PRIVATE_SEPOLICY_DIR has been deprecated.
 Use SYSTEM_EXT_PRIVATE_SEPOLICY_DIRS instead.
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=12
TARGET_PRODUCT=rk3588_firefly_itx_3588j_mipi
TARGET_BUILD_VARIANT=userdebug
TARGET_BUILD_TYPE=release
TARGET_ARCH=arm64
TARGET_ARCH_VARIANT=armv8-a
TARGET_CPU_VARIANT=generic
TARGET_2ND_ARCH=arm
TARGET_2ND_ARCH_VARIANT=armv8-a
TARGET_2ND_CPU_VARIANT=generic
HOST_ARCH=x86_64
HOST_2ND_ARCH=x86
HOST_OS=linux
HOST_OS_EXTRA=Linux-5.10.0-1044-oem-x86_64-Ubuntu-20.04.3-LTS
HOST_CROSS_OS=windows
HOST_CROSS_ARCH=x86
HOST_CROSS_2ND_ARCH=x86_64
HOST_BUILD_TYPE=release
BUILD_ID=SP2A.220405.004
OUT_DIR=out
16:55:30 Entire data directory removed.
16:55:30 Deleted images and staging directories.
#### build completed successfully (1 seconds) ####
make -j8
PLATFORM_VERSION=12
TARGET_ARCH=arm64
TARGET_2ND_ARCH=arm
HOST_ARCH=x86_64
HOST_2ND_ARCH=x86
HOST_OS=linux
HOST_CROSS_ARCH=x86
OUT_DIR=out
[100% 1/1] out/soong/.bootstrap/bin/soong_build out/soong/build.ninja
FAILED: out/soong/build.ninja
cd "$(dirname "out/soong/.bootstrap/bin/soong_build")" && BUILDER="$PWD/$(basename "out/soong/.boo
tstrap/bin/soong_build")" && cd / && env -i "$BUILDER"     --top "$TOP"     --out "out/soong"
-n "out"     -d "out/soong/build.ninja.d"     -t -l out/.module_paths/Android.bp.list -globFile ou
t/soong/.bootstrap/build-globs.ninja -o out/soong/build.ninja --available_env out/soong/soong.envi
ronment.available --used_env out/soong/soong.environment.used Android.bp
libRkTeeWeaver want to conditional Compile
libgralloc_priv want to conditional Compile
libmpimmz conditional Compile
librga want to conditional Compile
librknnrt want to conditional Compile
Rockchip conditional compile
[hardware/rockchip/libgralloc frameworks/native/include system/core/libsync system/core/libsync/in
clude external/libdrm/include/drm] 32
Optee Version: v2
>>>>>>>>>>>>>>>>>>>>> rk3588
librknnrt enabled on RK3588
Killed
16:57:07 soong bootstrap failed with: exit status 1
android_3588j_err.zip (1.21 KB)
