core-rk3399-jd4配置LVDS屏,显示不正常,请问如何设置?
SDK包名称:rk3399_linux_release_v2.5.1_20210301_firefly_split
SDK修改内容:设备树中增加dsi节点
Log日志:日志.zip
在设备树中增加了dsi节点和TC358775G的panel-init-sequence后,LVDS屏可以点亮,但是显示不正确(如图所示)。
怀疑是按照TC358764_5_774_5XBG_DSI-LVDS_Tv11p_nm表格生成的panel-init-sequence不对,
以下是屏的参数和我的配置,请专家大神帮忙看下,是否有哪里配置错了?
/dts-v1/;
#include "rk3399-firefly-port.dtsi"
#include <dt-bindings/sensor-dev.h>
#include <dt-bindings/display/media-bus-format.h>
	model = "AIO-3399-JD4-SCLVDS Board (Linux Opensource)";
	compatible = "rockchip,rk3399-firefly", "rockchip,rk3399";
	test-power {
		status = "okay";
	rt5640-sound {
		simple-audio-card,cpu {
		        sound-dai = <&i2s1>;
		simple-audio-card,codec {
		        sound-dai = <&rt5640>;
	adc-keys {
		compatible = "adc-keys";
		io-channels = <&saradc 1>;
		io-channel-names = "buttons";
		poll-interval = <300>;
		keyup-threshold-microvolt = <1800000>;
		esc-key {
			linux,code = <KEY_ESC>;
			label = "esc";
			press-threshold-microvolt = <0>;
	fan_ctl: fan-ctl-regulator {
		compatible = "regulator-fixed";
		enable-active-high;
		regulator-always-on;
		regulator-boot-on;
		gpio = <&gpio3 10 GPIO_ACTIVE_HIGH>;
		pinctrl-names = "default";
		regulator-name = "fan_ctl";
		pinctrl-0 = <&fan_drv>;
	NPU5801_PWR_EN: HUB20-PWR-EN {
		enable-active-high;
		regulator-boot-on;
		gpio = <&gpio0 2 GPIO_ACTIVE_HIGH>;
		pinctrl-0 = <&npu5801_pwr_en>;
		regulator-name = "vcc5v0_5801_en";
		status = "okay";
&usbdrd_dwc3_0 {
    dr_mode = "host";
&gmac {
	tx_delay = <0x2F>;
	rx_delay = <0x1E>;
&vcc_sd_h {
	rockchip,pins = <1 22 RK_FUNC_GPIO &pcfg_pull_up>;
&vcc_sd {
	gpio = <&gpio1 22 GPIO_ACTIVE_HIGH>;
&hdmi_dp_sound {
	status = "okay";
&i2c2 {
	status = "disabled";
	i2c-scl-rising-time-ns = <300>;
	i2c-scl-falling-time-ns = <15>;
	sensor@4c {
		compatible = "gs_mc3230";
		reg = <0x4c>;
		type = <SENSOR_TYPE_ACCEL>;
		irq_enable = <0>;
		poll_delay_ms = <30>;
		layout = <1>;
&rt5640 {
    hp-det-adc-value = <900>;
    aux-det-adc-value = <900>;
    hp-con-gpio = <&gpio3 16 GPIO_ACTIVE_HIGH>;
    io-channels = <&saradc 3>,<&saradc 2>;
    io-channel-names = "hp-det","aux-det";
&rt5640_hpcon{
    rockchip,pins = <3 16 RK_FUNC_GPIO &pcfg_pull_none>;
&vcca1v8_codec {
	regulator-min-microvolt = <900000>;
	regulator-max-microvolt = <900000>;
&spi1 {
	dev-port = <0>;
	status = "okay";
&spi_wk2xxx {
    status = "okay";
	reset-gpio = <&gpio1 2 GPIO_ACTIVE_HIGH>;
	irq-gpio = <&gpio2 8 IRQ_TYPE_EDGE_FALLING>;
	cs-gpio = <&gpio1 10 GPIO_ACTIVE_HIGH>;
// &spi2 {
//     status = "okay";
//     max-freq = <48000000>;
//     spidev@00 {
//         compatible = "linux,spidev";
//         reg = <0x00>;
//         spi-max-frequency = <48000000>;
// 		status = "okay";
&vcc3v3_3g {
	gpio = <&gpio2 28 GPIO_ACTIVE_HIGH>;
&vcc3v3_pcie {
	/delete-property/ gpio;
&pcie0 {
	ep-gpios = <&gpio4 30 GPIO_ACTIVE_HIGH>;
&uart4 {
&dp_in_vopb {
&hdmi_in_vopl {
&wdt {
&io_domains {
	bt656-supply = <&vcc_3v0>;
&vcc2v8_dvp {
	regulator-min-microvolt = <1800000>;
	regulator-max-microvolt = <1800000>;
&vcca1v8_codec {
&fusb0 {
&cdn_dp {
&tcphy0 {
    /delete-property/ extcon;
    status = "okay";
&u2phy0 {
    status = "okay";
    u2phy0_otg: otg-port {
        rockchip,vbus-always-on;
        vbus-5v-gpios = <&gpio1 3 GPIO_ACTIVE_HIGH>;
        status = "okay";
&usbdrd3_0 {
    status = "okay";
&usbdrd_dwc3_0 {
    dr_mode = "host";
&route_hdmi {
	// status = "okay";
&hdmi_in_vopb {
&hdmi {
	// status = "okay";
&backlight {
	status = "okay";
	pwms = <&pwm0 0 100000 0>;
&edp_in_vopl {
&edp_in_vopb {
&dsi_in_vopl {
&dsi_in_vopb {
	status = "okay";
&vopb_out_dsi {
	status = "okay";
&vopl_out_dsi {
	status = "okay";
&route_dsi {
	connect = <&vopb_out_dsi>;
&dsi {
	status = "okay";
	rockchip,lane-rate = <550>;
	panel@0 {
		status = "okay";
		compatible = "simple-panel-dsi";
		// compatible = "auo,g101evn013", "simple-panel-dsi";
		reg = <0>;
		backlight = <&backlight>;
		enable-gpios = <&gpio0 12 GPIO_ACTIVE_HIGH>;
		reset-gpios = <&gpio1 13 GPIO_ACTIVE_LOW>;
		bus-format = <MEDIA_BUS_FMT_RGB888_1X24>;
		dsi,lanes = <4>;
		reset-delay-ms = <120>;
		init-delay-ms = <120>;
		enable-delay-ms = <120>;
		prepare-delay-ms = <120>;
		unprepare-delay-ms = <12>;
		disable-delay-ms = <120>;
		panel-init-sequence = [
			29 00 06 3C 01 09 00 07 00
			29 00 06 14 01 06 00 00 00
			29 00 06 64 01 0A 00 00 00
			29 00 06 68 01 0A 00 00 00
			29 00 06 6C 01 0A 00 00 00
			29 00 06 70 01 0A 00 00 00
			29 00 06 34 01 1F 00 00 00
			29 00 06 10 02 1F 00 00 00
			29 00 06 04 01 01 00 00 00
			29 00 06 04 02 01 00 00 00
			29 00 06 50 04 20 01 F0 03
			29 00 06 54 04 20 00 20 00
			29 00 06 58 04 00 05 48 00
			29 00 06 5C 04 04 00 04 00
			29 00 06 60 04 20 03 08 00
			29 00 06 64 04 01 00 00 00
			29 00 06 A0 04 2D 80 44 00
			29 00 06 A0 04 2D 80 04 00
			29 00 06 04 05 04 00 00 00
			29 00 06 80 04 00 01 02 03
			29 00 06 84 04 04 07 05 08
			29 00 06 88 04 09 0A 0E 0F
			29 00 06 8C 04 0B 0C 0D 10
			29 00 06 90 04 16 17 11 12
			29 00 06 94 04 13 14 15 1B
			29 00 06 98 04 18 19 1A 06
			29 00 06 9C 04 63 06 00 00
		panel-exit-sequence = [
			05 05 01 28
			05 78 01 10
			native-mode = <&timing0>;
			timing0: timing0 {
				clock-frequency = <69327360>; //@60 71214000
				hactive = <1280>;
				vactive = <800>;
				hsync-len = <32>;
				hback-porch = <32>;
				hfront-porch = <72>;
				vsync-len = <4>;
				vback-porch = <4>;
				vfront-porch = <8>;
				hsync-active = <0>;
				vsync-active = <0>;
				de-active = <0>;
				pixelclk-active = <0>;
&rk808 {
     /delete-property/ pmic,stby-gpio;
     /delete-property/ pmic,hold-gpio;
&vcc_mipi {
	status = "okay";
&dvdd_1v2 {
	status = "okay";
&ov13850 {
	pwdn-gpios = <&gpio2 1 GPIO_ACTIVE_HIGH>;
	status = "okay";
&rkisp1_0 {
	status = "okay";
&mipi_dphy_rx0 {
	status = "okay";
&isp0_mmu {
	status = "okay";
&rkisp1_1 {
	status = "okay";
&mipi_dphy_tx1rx1 {
	status = "okay";
&isp1_mmu {
	status = "okay";
&pinctrl {
	pinctrl-0 = <&host_hub_vcc>;
	npu_pwr_en {
		// control VCC5V0_HOST3
		npu5801_pwr_en: npu5801-pwr-en {
			rockchip,pins =
				<0 2 RK_FUNC_GPIO &pcfg_pull_up>;
	host-hub-vcc {
		host_hub_vcc: host-hub-vcc {
			rockchip,pins =
				<2 4 RK_FUNC_GPIO &pcfg_output_high>,
				<4 29 RK_FUNC_GPIO &pcfg_output_high>;
	pcie {
		pcie_3g_drv: pcie-3g-drv {
			rockchip,pins =
				<2 6 RK_FUNC_GPIO &pcfg_pull_up>;
	vcc_sd {
		vcc_sd_h: vcc-sd-h {
			rockchip,pins =
	fan-ctl {
		fan_drv: fan-drv {
			rockchip,pins = <3 10 RK_FUNC_GPIO &pcfg_pull_none>;
日志.zip (21.8 KB)
TC358764_5_774_5XBG_DSI-LVDS_Tv11p_nm.zip (272 KB)
abcxyztt 发表于 2022-9-20 18:09
参数设定有问题
能给具体看下哪个参数不对吗?图片红框里的参数应该怎么填?
hactive 和vactive的参数交换一下试试
交换一下 屏不亮了
abcxyztt 发表于 2022-9-21 14:32
Q我
加好友了{:4_189:}
