Ubuntu烧录固件Prepare IDB Fail
固件文件名称:FIREFLY-RK3399-UBUNTU18.04-GPT-20200221-1527.img.7
Log日志:log2022-09-21.txt.zip
13:53:37 Upgrade Tool v1.34
13:53:37 Error:stat config.ini failed,err=2
13:58:15 Upgrade Tool v1.34
13:58:15 Error:stat config.ini failed,err=2
13:59:05 Upgrade Tool v1.34
13:59:05 Error:stat config.ini failed,err=2
13:59:05 Test Device Start
13:59:05 Test Device Success
13:59:05 Check Chip Start
13:59:05 Check Chip Success
13:59:05 Get FlashInfo Start
13:59:05 <LAYER 3-4> INFO:FlashInfo: 0 0 0 0 0 4 4 0 28 0 0
13:59:05 Get FlashInfo Success
13:59:05 Prepare IDB Start
13:59:05 <LAYER 3-4> ERROR:PrepareIDB–>No Found 1st Flash CS
13:59:05 Prepare IDB Fail
14:08:14 Upgrade Tool v1.34
14:08:14 Error:stat config.ini failed,err=2
14:10:27 Test Device Start
14:10:27 Test Device Success
14:10:27 Check Chip Start
14:10:27 Check Chip Success
14:10:27 Get FlashInfo Start
14:10:27 <LAYER 3-4> INFO:FlashInfo: 0 0 0 0 0 4 4 0 28 0 0
14:10:27 Get FlashInfo Success
14:10:27 Prepare IDB Start
14:10:27 <LAYER 3-4> ERROR:PrepareIDB–>No Found 1st Flash CS
14:10:27 Prepare IDB Fail
log2022-09-21.txt.zip (490 Bytes)
