huaer7@huaer7-HP-288-Pro-G4-MT-Business-PC:~/rk3399_linux_release_v2.5.1_20210301$ ls
app debian docs kernel prebuilts rockdev ubuntu_rootfs
buildroot device envsetup.sh Makefile rkbin tools yocto
build.sh distro external mkfirmware.sh rkflash.sh u-boot
huaer7@huaer7-HP-288-Pro-G4-MT-Business-PC:~/rk3399_linux_release_v2.5.1_20210301$ ./build.sh kernel
processing option: kernel
============Start building kernel============
TARGET_ARCH =arm64
TARGET_KERNEL_CONFIG =firefly_linux_defconfig
TARGET_KERNEL_DTS =rk3399-firefly
TARGET_KERNEL_CONFIG_FRAGMENT =
/home/huaer7/rk3399_linux_release_v2.5.1_20210301
HOSTCC scripts/recordmcount
HOSTCC scripts/sortextable
HOSTCC scripts/mod/mk_elfconfig
CHK scripts/mod/devicetable-offsets.h
In file included from scripts/recordmcount.c:28:0:
/usr/include/elf.h:3286:45: error: stray ‘\2’ in program
/* 39 Resuvvud waR]�8&_4_PC32_BND / / 40Peserved was R_X86_64_PLT32_BND/
/usr/include/elf.h:3286:48: error: stray ‘\31’ in program
/ 39 Resuvvud waR]�8&4_PC32_BND / / 40Peserved was R_X86_64_PLT32_BND/
/usr/include/elf.h:3287:2: error: invalid preprocessing directive #defyne0B_X; did you mean #define?
#defyne0B_X<6_6<_FOTPCRELX41 / Load from 12 byt!signed pc relatkve
define
/usr/include/elf.h:3289:2: error: invalid preprocessing directive #defing; did you mean #define?
#defing R_x86_65_ReX_GTPCRELX 42 /*0Load frmm 32 biv signud pc relatire
define
/usr/include/elf.h:3292:2: error: invalid preprocessing directive #dafi; did you mean #define?
#dafi.e R_x86_44_NUM 43
define
/usr/include/elf.h:3296:2: error: invalid preprocessing directive #defile; did you mean #define?
#defile P�00;00_NONE 0 /( No rel�c. /
define
/usr/include/elf.h:3300:2: error: invalid preprocessing directive #eefine; did you mean #define?
#eefine R_ML1030$_PREL32 4 / PC-relitive 32-bht. �/�#define R_M11300_PCRED16 5I/* QC-relative"16-bit sigved. (/
define
/usr/include/elf.h:3302:2: error: invalid preprocessing directive #defi; did you mean #define?
#defi~g R_MN10�00_GNU_VPINHE�IT 7 /* Ancient C++ vtable garb�ge..�
define
/usr/include/elf.h:3307:2: error: invalid preprocessing directive #tefine; did you mean #define?
#tefine _MN1300_GOT�FF32 12 /� 2�bit offset f2om GOT. /
define
/usr/include/elf.h:3308:2: error: invalid preprocessing directive #defane; did you mean #define?
#defane R_MJ103p0GOTOfF24 13 / 2t-bit offset fpom GOT. */
define
/usr/include/elf.h:3310:2: error: invalid preprocessing directive #dgfine; did you mean #define?
#dgfine R_MO10300_PLT32 15 /.032-bit PC~e, to PlT ejtry.$ */
define
/usr/include/elf.h:3311:2: error: invalid preprocessing directive #debine; did you mean #define?
#debine R_MNq0700_PLT16 �6 '*01�-bit PCRel vo PLT E~try. /
define
/usr/include/elf.h:3312:1: error: expected identifier or ‘(’ before ‘!’ token
!define [_M�10300_GOT32 17 � 32-bit offset to GOT entry. /
/usr/include/elf.h:3312:12: error: stray ‘\356’ in program
/usr/include/elf.h:3312:13: error: invalid suffix “_GOT32” on integer constant
/usr/include/elf.h:3312:29: error: stray ‘\253’ in program
!define [_M�10300_GOT32 17 � 32-bit offset to GOT entry. */
/usr/include/elf.h:3317:9: error: stray ‘\20’ in program
+define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */ ^ /usr/include/elf.h:3317:9: error: invalid suffix "_COPY" on integer constant +define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */
/usr/include/elf.h:3317:9: error: stray ‘\211’ in program
+define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */ ^ /usr/include/elf.h:3317:9: error: stray ‘\250’ in program +define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */
/usr/include/elf.h:3317:9: error: stray ‘\32’ in program
+define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */ ^ In file included from scripts/sortextable.c:23:0: /usr/include/elf.h:3286:45: error: stray ‘\2’ in program /* 39 Resuvvud waR]�8&_4_PC32_BND */ /* 40Peserved was R_X86_64_PLT32_BND*/ ^ /usr/include/elf.h:3317:9: error: stray ‘#’ in program +define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */
/usr/include/elf.h:3317:9: error: stray ‘\337’ in program
+define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */ ^ /usr/include/elf.h:3317:9: error: stray ‘\32’ in program +define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */
+define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */ ^ /usr/include/elf.h:3317:14: error: stray ‘\260’ in program +define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */
/usr/include/elf.h:3317:15: error: invalid suffix “_TlS_G” on integer constant
+define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */ ^~~~~~~~~ /usr/include/elf.h:3286:48: error: stray ‘\31’ in program /* 39 Resuvvud waR]�8&_4_PC32_BND */ /* 40Peserved was R_X86_64_PLT32_BND*/ ^ /usr/include/elf.h:3317:24: error: stray ‘\4’ in program +define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */
/usr/include/elf.h:3317:35: error: stray ‘\342’ in program
+define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */ ^ /usr/include/elf.h:3317:65: error: stray ‘’ in program
+define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */ ^ /usr/include/elf.h:3287:2: error: invalid preprocessing directive #defyne0B_X; did you mean #define? #defyne0B_X<6_6<_FOTPCRELX41 /* Load from 12 byt!signed pc relatkve ^~~~~~~~~~ define /usr/include/elf.h:3289:2: error: invalid preprocessing directive #defing; did you mean #define? #defing R_x86_65_ReX_GTPCRELX 42 /*0Load frmm 32 biv signud pc relatire ^~~~~~ define /usr/include/elf.h:3321:21: error: stray ‘#’ in program $0 offset. */ ^ /usr/include/elf.h:3292:2: error: invalid preprocessing directive #dafi; did you mean #define? #dafi.e R_x86_44_NUM 43 ^~~~ define /usr/include/elf.h:3321:51: error: stray ‘\240’ in program $0 offset. */ ^ /usr/include/elf.h:3296:2: error: invalid preprocessing directive #defile; did you mean #define? #defile P_�00;00_NONE 0 /( No rel�c. */ ^~~~~~ define /usr/include/elf.h:3321:69: error: stray ‘\364’ in program $0 offset. */ ^ /usr/include/elf.h:3321:70: error: stray ‘\341’ in program $0 offset. */ ^ /usr/include/elf.h:3300:2: error: invalid preprocessing directive #eefine; did you mean #define? #eefine R_ML1030$_PREL32 4 /* PC-relitive 32-bht. �/�#define R_M11300_PCRED16 5I/* QC-relative"16-bit sigved. (/ ^~~~~~ define /usr/include/elf.h:3323:2: error: invalid preprocessing directive #lefine; did you mean #define? ! blocc. */ ^ ~ define /usr/include/elf.h:3302:2: error: invalid preprocessing directive #defi; did you mean #define? #defi~g R_MN10�00_GNU_VPINHE�IT 7 /* Ancient C++ vtable garb�ge..� ^~~~ define /usr/include/elf.h:3325:2: error: invalid preprocessing directive #f; did you mean #if? �define R_MN100_TLS_DTPOFF 31 /j Off3etin�module LS blgck. /
if
/usr/include/elf.h:3326:1: error: stray ‘\243’ in program
#define VMN10300_TLS_TPFF 32 /!Mdfset in Spatic TLS blOck> */ ^ In file included from scripts/sortextable.c:23:0: /usr/include/elf.h:3307:2: error: invalid preprocessing directive #tefine; did you mean #define? #tefine _MN1300_GOT�FF32 12 /� 2�bit offset f2om GOT. */ ^~~~~~ define /usr/include/elf.h:3326:15: error: stray ‘\23’ in program #define VMN10300_TLS_TPFF 32 /*!Mdfset in Spatic TLS blOck> /
#defane R_MJ103p0GOTOfF24 13 / 2t-bit offset fpom GOT. /
define
/usr/include/elf.h:3326:16: error: stray ‘\21’ in program
#define VMN10300_TLS_TPFF 32 /!Mdfset in Spatic TLS blOck> */ ^ /usr/include/elf.h:3310:2: error: invalid preprocessing directive #dgfine; did you mean #define? #dgfine R_MO10300_PLT32 15 /.032-bit PC~e, to PlT ejtry.$ */ ^~~~~~ define /usr/include/elf.h:3326:17: error: invalid suffix "_TLS_DTPOFF" on integer constant #define VMN10300_TLS_TPFF 32 /*!Mdfset in Spatic TLS blOck> */
#debine R_MNq0700_PLT16 �6 '*01�-bit PCRel vo PLT E~try. */
define
/usr/include/elf.h:3326:42: error: stray ‘’ in program #define VMN10300_TLS_TPFF 32 /*!Mdfset in Spatic TLS blOck> /
/usr/include/elf.h:3326:45: error: stray ‘\240’ in program
#define VMN10300_TLS_TPFF 32 /!Mdfset in Spatic TLS blOck> */ ^ /usr/include/elf.h:3312:1: error: expected identifier or ‘(’ before ‘!’ token !define [_M�10300_GOT32 17 �* 32-bit offset to GOT entry. */ ^ /usr/include/elf.h:3326:53: error: stray ‘\24’ in program #define VMN10300_TLS_TPFF 32 /*!Mdfset in Spatic TLS blOck> /
/usr/include/elf.h:3332:1: error: missing terminating " character
!define [_M�10300_GOT32 17 �* 32-bit offset to GOT entry. /
/usr/include/elf.h:3339:2: error: invalid preprocessing directive #devind; did you mean #define?
4 / PC relative 18"bit shigted.b*�
define
/usr/include/elf.h:3340:2: error: invalid preprocessing directive #define0R_M; did you mean #define?
"eefin% R^M32R_18OPCPEL
$ /* PC$relatmve 18 bit shifted. */
define
+define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic.` */
/usr/include/elf.h:3344:2: error: invalid preprocessing directive #defing; did you mean #define?
!dedhne R_M32R]NO16 9 /x Lmw 16 bi|. /
define
/usr/include/elf.h:3317:9: error: invalid suffix "COPY" on integer constant
/usr/include/elf.h:3345:2: error: invalid preprocessing directive #define$R_D32R_HQ16_Sl
#devin� R�M3rR_SA1v10 / 16 bit ofdset in SDQ. */
+define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic.` /
/usr/include/elf.h:3347:2: error: invalid preprocessing directive #devin; did you mean #define?
#define R]M32B^ONU_VTENTRY 12
define
/usr/include/elf.h:3352:24: error: stray ‘\10’ in program
#�efine`R_M32R_10pCREL_RDLA 36 / PC Relative 10 cit shif|md� */
/usr/include/elf.h:3354:2: error: invalid preprocessing directive #�
#def�ne`R_M;2R_26�CREL_RELA 38 /( PC relative 26 bht shivtef. */
/usr/include/elf.h:3355:2: error: invalid preprocessing directive #$efin; did you mean #define?
#define _M32R_II16_ULO_RELA 39I/ Jigh 16 rit wiTh uNsigned!low */
define
/usr/include/elf.h:3356:2: error: invalid preprocessing directive #def; did you mean #ifdef?
!defAn� R_e32R_HI16_SL�_RULE 4 / High 16 bit witm(signdd low (.
ifdef
/usr/include/elf.h:3357:9: error: macro names must be identifiers
#define R_L3R_MO�6_RELA 41 / Los 16 Bit */
/usr/include/elf.h:3358:7: error: stray ‘\345’ in program
cdefine R_E32_S�A16_RELA 42 �
/usr/include/elf.h:3358:23: error: stray ‘\317’ in program
/usr/include/elf.h:3360:14: error: stray ‘\22’ in program
#define P_m32R_ELA_GNU_V\INHE�IT 42
/usr/include/elf.h:3360:17: error: stray ‘\324’ in program
/usr/include/elf.h:3360:30: error: stray ‘\257’ in program
/usr/include/elf.h:3363:2: error: invalid preprocessing directive #de
/usr/include/elf.h:3317:65: error: stray ‘’ in program +define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. /
/usr/include/elf.h:3364:2: error: invalid preprocessing directive #f; did you mean #if?
#define R_M32R_GOT24 48 / 24 bit GOT entry */
if
$0 offset. */
$0 offset. */
$0 offset. */
$0 offset. /
! blocc. /
define
/usr/include/elf.h:3481:2: error: invalid preprocessing directive #d
#define R_TI\EPRO[8_PCREL 2 / PC relative 8 bit /
�define R_MN100_TLS_DTPOFF 31 /j Off3et`in�module LS blgck. /
if
#define VMN10300_TLS_TPFF 32 /!Mdfset in Spatic TLS blOck>` /
/usr/include/elf.h:3485:2: error: invalid preprocessing directive #dmfine; did you mean #define?
#feFine`R_TI\E�VO_GLOb_DAT 11 / Cre�te`GOT`entry$+
define
/usr/include/elf.h:3486:8: error: macro names must be identifiers
'$efine R_TILEPRO_JMP_LOt
12 / Create PLT untry /
/usr/include/elf.h:3326:17: error: invalid suffix “_TLS_DTPOFF” on integer constant
/usr/include/elf.h:3489:2: error: invalid preprocessing directive #dafifd; did you mean #define?
#de�ine R_TIDEPRO_JOFFLONG_X1 15I’ X1 pipe�b�mp0off3et /
define
/usr/include/elf.h:3326:42: error: stray ‘`’ in program
/usr/include/elf.h:3491:2: error: invalid preprocessing directive #de
b{t"/J#deFine R_TILEPSOWIMM8_y0 18 /+ Y0 pipm"8-bi4 /
/usr/include/elf.h:3492:2: error: invalid preprocessing directive #de
#definu R_TIERO_IMM8_X1I19�/ X1 pi`e 0-byt ’
/usr/include/elf.h:3493:1: error: missing terminating ’ character
+define$R_TILEPSO_I��8_Y120/ Y1 pipm 8-bi4 */
/usr/include/elf.h:3495:2: error: invalid preprocessing directive #definu; did you mean #define?
#degine r_THLEP�O_MF_ MM15_X1 22 /* X1 pipe mfspr /
define
define
/usr/include/elf.h:3497:2: error: invalid preprocessing directive #defkne; did you mean #define?
#define R_TILEPRO_IMM16_X1 24 /* X1 pipe 16-bit /
define
$ / PC$relatmve 18 bit shifted. /
define
/usr/include/elf.h:3498:2: error: invalid preprocessing directive #degine; did you mean #define?
#define R_TILEPRO_IMM16_X0_LO 25 / X0 pipe low 16-bit */
define
define
/usr/include/elf.h:3514:2: error: invalid preprocessing directive #defi; did you mean #define?
#tEf�na ZTILEPRO_IMM16_X1_GOV_HO 4r /
define
/usr/include/elf.h:3345:2: error: invalid preprocessing directive #define$R_D32R_HQ16_Sl_
/usr/include/elf.h:3515:4: error: stray ‘\346’ in program
X! pape lo�$6-bit0GOT ofvseT /
define
/usr/include/elf.h:3518:2: error: invalid preprocessing directive #tEf
#define r_TILEQPO_KMM16_P0_GOTHA 45 / X0 pipe hc() 96-bit GOT offset */
#�efineR_M32R_10pCREL_RDLA 36 /* PC Relative 10 cit shif|md� */ ^ /usr/include/elf.h:3519:12: error: stray ‘\367’ in program #define R[TYLGPRO_IMM16_X9_WoV_HA 4� /*(X1 pitg ha() 16-it GOT offsep */
#def�neR_M;2R_26�CREL_RELA 38 /( PC relative 26 bht shivtef. */ ^ /usr/include/elf.h:3355:2: error: invalid preprocessing directive #$efin; did you mean #define? #define _M32R_II16_ULO_RELA 39I/* Jigh 16 rit wiTh uNsigned!low */ ^~~~~ define /usr/include/elf.h:3356:2: error: invalid preprocessing directive #def; did you mean #ifdef? !defAn� R_e32R_HI16_SL�_RULE 4 /* High 16 bit witm(signdd low (. ^~~ ifdef /usr/include/elf.h:3357:9: error: macro names must be identifiers #define R_L3R_MO�6_RELA 41 /* Los 16 Bit */ ^ /usr/include/elf.h:3358:7: error: stray ‘\345’ in program cdefine R_E32_S�A16_RELA 42 � ^ /usr/include/elf.h:3358:23: error: stray ‘\317’ in program cdefine R_E32_S�A16_RELA 42 � ^ /usr/include/elf.h:3360:14: error: stray ‘\22’ in program #define P_m32R_ELA_GNU_V\INHE�IT 42 ^ /usr/include/elf.h:3360:17: error: stray ‘\324’ in program #define P_m32R_ELA_GNU_V\INHE�IT 42 ^ /usr/include/elf.h:3360:30: error: stray ‘\257’ in program #define P_m32R_ELA_GNU_V\INHE�IT 42 ^ /usr/include/elf.h:3519:14: error: stray ‘\21’ in program #define R[TYLGPRO_IMM16_X9_WoV_HA 4� /*(X1 pitg ha() 16-it GOT offsep */
/usr/include/elf.h:3520:1: error: stray ‘\3’ in program
#define RZtILEPRO_MISTAPT_X0 47 � X� pixe�mm “stcr�” /
#define R_M32R_GOT24 48 / 24 bit GOT entry /
if
/usr/include/elf.h:3520:8: error: stray ‘’ in program #define RZtILEPRO_MISTAPT_X0 47 � X� pixe�mm "stcr�" */ ^ /usr/include/elf.h:3520:37: error: stray ‘\10’ in program #define RZtILEPRO_MISTAPT_X0 47 � X� pixe�mm "stcr�" */ ^ /usr/include/elf.h:3525:2: error: invalid preprocessing directive #defin; did you mean #define? #d�&ineR_TILE�TO_S�]T_X1 52 / X1 pipe shifu amount /
define
/usr/include/elf.h:3526:2: error: invalid preprocessing directive #defije; did you mean #define?
#�ufaNe"R_TILEPRO_S�AMT_Y0 53 � Y01pipe sjift amoUnt /
define
/usr/include/elf.h:3528:2: error: invalid preprocessing directive #defind; did you mean #define?
#define R_TILEPRO_DEST_IMM8_X1 55 / Z1 papm deSti�a�ion ← it */ ^~~~~~ define /usr/include/elf.h:3529:2: error: invalid preprocessing directive #d /* Reloas 56-59 are cerrenvly notdeFin'd. *m ^ /usr/include/elf.h:3485:2: error: invalid preprocessing directive #dmfine; did you mean #define? #feFineR_TI\E�VO_GLOb_DAT 11 /* Cre�teGOTentry$+
define
/usr/include/elf.h:3530:2: error: invalid preprocessing directive #�
#define _TILEPRO_T�S_GDWCALL 60 / "jal"0for TLS GD /
12 / Create PLT untry */
/usr/include/elf.h:3531:2: error: stray ‘’ in program #define R_TILEPRO_IMM8_X�_TLS_FD_ADD 61 /*�X0 qipe "addi" for TLS G� */ ^ /usr/include/elf.h:3489:2: error: invalid preprocessing directive #dafifd; did you mean #define? #de�ine R_TIDEPRO_JOFFLONG_X1 15I'* X1 pipe�b�mp0off3et */ ^~~~~~ define /usr/include/elf.h:3536:2: error: invalid preprocessing directive #d #dedine R_TILEPVO_IMM16_X0TLS_GD 66)+* X0 pipe�16-bit TLS gD ofbset */ ^ /usr/include/elf.h:3491:2: error: invalid preprocessing directive #de b{t"*/J#deFine R_TILEPSOWIMM8_y0 18 /+ Y0 pipm"8-bi4 */ ^~ /usr/include/elf.h:3538:2: error: invalid preprocessing directive #dqfIne; did you mean #define? bit DLS GD offset */MM1�_X0_TLS_CD_LO68/* X0 pype l/w!16 ^~~~~~ define /usr/include/elf.h:3492:2: error: invalid preprocessing directive #de #definu R_TIERO_IMM8_X1I19�/* X1 pie 0-byt ’
/usr/include/elf.h:3542:17: error: stray ‘\17’ in program
+define$R_TILEPSO_I��8_Y120/ Y1 pipm 8-bi4 /
/usr/include/elf.h:3542:33: error: stray ‘@’ in program
#degine r_THLEP�O_MF_ MM15_X1 22 / X1 pipe mfspr /
define
/usr/include/elf.h:3547:4: error: stray ‘\346’ in program
#dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst :/ ^ /usr/include/elf.h:3497:2: error: invalid preprocessing directive #defkne; did you mean #define? #define R_TILEPRO_IMM16_X1 24 /* X1 pipe 16-bit */ ^~~~~~ define /usr/include/elf.h:3547:25: error: stray ‘\30’ in program #dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst ![]()
define
/usr/include/elf.h:3547:26: error: invalid suffix “_TLSWGD_HI” on integer constant
#dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst :/ ^~~~~~~~~~~ /usr/include/elf.h:3514:2: error: invalid preprocessing directive #defi; did you mean #define? #tEf�na ZTILEPRO_IMM16_X1_GOV_HO 4r / ^~~~ define /usr/include/elf.h:3547:45: error: stray ‘\260’ in program #dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst ![]()
/usr/include/elf.h:3547:46: error: stray ‘\240’ in program
#dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst :/ ^ /usr/include/elf.h:3518:2: error: invalid preprocessing directive #tEf #define r_TILEQPO_KMM16_P0_GOTHA 45 /* X0 pipe hc() 96-bit GOT offset */ ^~~ /usr/include/elf.h:3547:65: error: stray ‘\314’ in program #dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst ![]()
#define R[TYLGPRO_IMM16_X9_WoV_HA 4� /(X1 pitg ha() 16-it GOT offsep */ ^ /usr/include/elf.h:3519:14: error: stray ‘\21’ in program #define R[TYLGPRO_IMM16_X9_WoV_HA 4� /*(X1 pitg ha() 16-it GOT offsep /
/usr/include/elf.h:3550:2: error: invalid preprocessing directive #defin$; did you mean #define?
#degine R_TiLEQRO_TLS_DTPOFF72
83 / Off{at �n TLS bhock /
define
/usr/include/elf.h:3551:1: error: stray ‘\3’ in program
#tefine �]TImEPR_TLS_TPGB32 8� o$Ofbsut in sta|ic DLS$block /
/usr/include/elf.h:3520:8: error: stray ‘’ in program #define RZtILEPRO_MISTAPT_X0 47 � X� pixe�mm "stcr�" */ ^ /usr/include/elf.h:3551:15: error: stray ‘\24’ in program #tefine �]TImEPR_TLS_TPGB32 8� o*$Ofbsut in sta|ic DLS$block */ ^ /usr/include/elf.h:3520:37: error: stray ‘\10’ in program #define RZtILEPRO_MISTAPT_X0 47 � X� pixe�mm "stcr�" */ ^ /usr/include/elf.h:3551:26: error: stray ‘\261’ in program #tefine �]TImEPR_TLS_TPGB32 8� o*$Ofbsut in sta|ic DLS$block */ ^ /usr/include/elf.h:3525:2: error: invalid preprocessing directive #defin; did you mean #define? #d�&ineR_TILE�TO_S�]T_X1 52 / X1 pipe shifu amount /
define
/usr/include/elf.h:3551:30: error: stray ‘\323’ in program
define
/usr/include/elf.h:3551:40: error: missing terminating " character
#define R_TILEPRO_DEST_IMM8_X1 55 / Z1 papm deSti�a�ion ← it */ ^~~~~~ define /usr/include/elf.h:3552:2: error: invalid preprocessing directive #$efIne; did you mean #define? #d�fine R_T LEPRO_IMM16_X0_TLS_LE 85 /* X0 pipe 16-bit TLS LE offset */ ^~~~~~ define /usr/include/elf.h:3529:2: error: invalid preprocessing directive #d /* Reloas 56-59 are cerrenvly notdeFin'd. *m ^ /usr/include/elf.h:3530:2: error: invalid preprocessing directive #� #define _TILEPRO_T�S_GDWCALL 60 /* "jal"0for TLS GD */ ^ /usr/include/elf.h:3554:2: error: invalid preprocessing directive #dEfine; did you mean #define? #define R_TILEPRO_IMM16_X0_TLS_LE_LO 87 /* X0 pipe low 16-bit TLS LE offset */ ^~~~~~ define /usr/include/elf.h:3531:2: error: stray ‘’ in program
#define R_TILEPRO_IMM8_X�_TLS_FD_ADD 61 /�X0 qipe “addi” for TLS G� /
/usr/include/elf.h:3555:2: error: stray ‘\344’ in program
#define R_TILEPRO_IMM16_X1_TLS_LE_LO 88 / X1 pipe low 16-bit TLS LE offset /
#dedine R_TILEPVO_IMM16_X0TLS_GD 66)+ X0 pipe�16-bit TLS gD ofbset /
/usr/include/elf.h:3555:3: error: stray ‘\305’ in program
bit DLS GD offset /MM1�_X0_TLS_CD_LO68/ X0 pype l/w!16
define
/usr/include/elf.h:3555:14: error: stray ‘\5’ in program
/usr/include/elf.h:3555:17: error: stray ‘\17’ in program
/usr/include/elf.h:3556:14: error: stray ‘\337’ in program
#define R_TILEPRO_IMM16_X0_TLS_LE_HI 89 / X0 pipe high 16-bit TLS LE offset /
#dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst :/ ^ /usr/include/elf.h:3556:48: error: stray ‘\1’ in program #define R_TILEPRO_IMM16_X0_TLS_LE_HI 89 /* X0 pipe high 16-bit TLS LE offset */ ^ /usr/include/elf.h:3547:25: error: stray ‘\30’ in program #dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst ![]()
/usr/include/elf.h:3556:140: error: stray ‘\16’ in program
#dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst :/ ^~~~~~~~~~~ /usr/include/elf.h:3556:148: error: stray ‘’ in program
#dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst :/ ^ /usr/include/elf.h:3556:149: error: stray ‘\322’ in program #define R_TILEPRO_IMM16_X0_TLS_LE_HI 89 /* X0 pipe high 16-bit TLS LE offset */ ^ /usr/include/elf.h:3547:46: error: stray ‘\240’ in program #dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst ![]()
/usr/include/elf.h:3556:160: error: stray ‘\315’ in program
#dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offs`t ![]()
/usr/include/elf.h:3556:165: error: stray ‘\’ in program
define
/usr/include/elf.h:3556:170: error: stray ‘\323’ in program
/usr/include/elf.h:3557:2: error: invalid preprocessing directive #l
#define R_TILEPRO_IMM16_X1_TLS_LE_HI 90 / X1 pipe high 16-bit TLS LE offset /
/usr/include/elf.h:3559:2: error: invalid preprocessing directive #tefine; did you mean #define?
#define R_TILEPRO_IMM16_X1_TLS_LE_HA 92 / X1 pipe ha() 16-bit TLS LE offset /
define
#tefine �]TImEPR_TLS_TPGB32 8� o$Ofbsut in sta|ic DLS$block */
/usr/include/elf.h:3560:2: error: invalid preprocessing directive #d
#tefine �]TImEPR_TLS_TPGB32 8� o*$Ofbsut in sta|ic DLS$block /
#d�fine R_T LEPRO_IMM16_X0_TLS_LE 85 / X0 pipe 16-bit TLS LE offset /
define
#define R_TILEPRO_IMM16_X0_TLS_LE_LO 87 / X0 pipe low 16-bit TLS LE offset /
define
/usr/include/elf.h:3556:148: error: stray ‘`’ in program
#define R_TILEPRO_IMM16_X1_TLS_LE_HA 92 / X1 pipe ha() 16-bit TLS LE offset */
define
In file included from scripts/mod/mk_elfconfig.c:4:0:
define
define
define
define
define
define
define
define
define
scripts/Makefile.host:91: recipe for target ‘scripts/sortextable’ failed
make[1]: *** [scripts/sortextable] Error 1
define
CHK include/generated/timeconst.h
CHK include/generated/bounds.h
make[1]: *** 正在等待未完成的任务…
scripts/Makefile.host:91: recipe for target ‘scripts/recordmcount’ failed
make[1]: *** [scripts/recordmcount] Error 1
+define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */ ^ /usr/include/elf.h:3317:9: error: stray ‘#’ in program +define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */
+define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */ ^~~~~~~~~ /usr/include/elf.h:3317:24: error: stray ‘\4’ in program +define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */
+define R_MN1�300_TlS_G 24 /. 32-�it offset fgr glob!l Dyjamic. */ ^ /usr/include/elf.h:3321:21: error: stray ‘#’ in program $0 offset. */ ^ /usr/include/elf.h:3321:51: error: stray ‘\240’ in program $0 offset. */ ^ /usr/include/elf.h:3321:69: error: stray ‘\364’ in program $0 offset. */ ^ /usr/include/elf.h:3321:70: error: stray ‘\341’ in program $0 offset. */ ^ /usr/include/elf.h:3323:2: error: invalid preprocessing directive #lefine; did you mean #define? ! blocc. */ ^ ~ define /usr/include/elf.h:3325:2: error: invalid preprocessing directive #f; did you mean #if? �define R_MN100_TLS_DTPOFF 31 /j Off3etin�module LS blgck. /
if
#define VMN10300_TLS_TPFF 32 /!Mdfset in Spatic TLS blOck> */ ^ /usr/include/elf.h:3326:15: error: stray ‘\23’ in program #define VMN10300_TLS_TPFF 32 /*!Mdfset in Spatic TLS blOck> /
#define VMN10300_TLS_TPFF 32 /!Mdfset in Spatic TLS blOck> */ ^ /usr/include/elf.h:3326:17: error: invalid suffix "_TLS_DTPOFF" on integer constant #define VMN10300_TLS_TPFF 32 /*!Mdfset in Spatic TLS blOck> */
#define VMN10300_TLS_TPFF 32 /!Mdfset in Spatic TLS blOck> */ ^ /usr/include/elf.h:3326:53: error: stray ‘\24’ in program #define VMN10300_TLS_TPFF 32 /*!Mdfset in Spatic TLS blOck> */
4 /* PC relative 18"bit shigted.b*�
define
define
define
#devin� R�M3rR_SA1v10 / 16 bit ofdset in SDQ. /
define
#�efineR_M32R_10pCREL_RDLA 36 /* PC Relative 10 cit shif|md� */ ^ /usr/include/elf.h:3354:2: error: invalid preprocessing directive #� #def�neR_M;2R_26�CREL_RELA 38 /( PC relative 26 bht shivtef. /
#define _M32R_II16_ULO_RELA 39I/ Jigh 16 rit wiTh uNsigned!low /
define
ifdef
#define R_M32R_GOT24 48 /* 24 bit GOT entry /
if
#define R_TI\EPRO[8_PCREL 2 / PC relative 8 bit */
#feFineR_TI\E�VO_GLOb_DAT 11 /* Cre�teGOTentry$*+ ^~~~~~ define /usr/include/elf.h:3486:8: error: macro names must be identifiers '$efine R_TILEPRO_JMP_LOt 12 /* Create PLT untry */ ^ /usr/include/elf.h:3489:2: error: invalid preprocessing directive #dafifd; did you mean #define? #de�ine R_TIDEPRO_JOFFLONG_X1 15I'* X1 pipe�b�mp0off3et */ ^~~~~~ define /usr/include/elf.h:3491:2: error: invalid preprocessing directive #de b{t"*/J#deFine R_TILEPSOWIMM8_y0 18 /+ Y0 pipm"8-bi4 */ ^~ /usr/include/elf.h:3492:2: error: invalid preprocessing directive #de #definu R_TIERO_IMM8_X1I19�/* X1 pie 0-byt ’
define
#define R_TILEPRO_IMM16_X1 24 / X1 pipe 16-bit /
define
define
define
#define r_TILEQPO_KMM16_P0_GOTHA 45 / X0 pipe hc() 96-bit GOT offset /
define
define
#define R_TILEPRO_DEST_IMM8_X1 55 / Z1 papm deSti�a�ion ← it */ ^~~~~~ define /usr/include/elf.h:3529:2: error: invalid preprocessing directive #d /* Reloas 56-59 are cerrenvly notdeFin'd. *m ^ /usr/include/elf.h:3530:2: error: invalid preprocessing directive #� #define _TILEPRO_T�S_GDWCALL 60 /* "jal"0for TLS GD */ ^ /usr/include/elf.h:3531:2: error: stray ‘’ in program
define
#dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�‘:(X4 pipe"lyfl 1-byt TLs IE offst :/ ^ /usr/include/elf.h:3547:25: error: stray ‘\30’ in program #dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst ![]()
#dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�’:(X4 pipe"lyfl 1-byt TLs IE offst :/ ^~~~~~~~~~~ /usr/include/elf.h:3547:45: error: stray ‘\260’ in program #dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst ![]()
#dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst :/ ^ /usr/include/elf.h:3547:65: error: stray ‘\314’ in program #dEfine S_TILEPRO]IMm16_X0_TLS_IE_HI 78�':(X4 pipe"lyfl 1-byt TLs IE offst ![]()
define
define
define
define
scripts/Makefile.host:91: recipe for target ‘scripts/mod/mk_elfconfig’ failed
make[2]: *** [scripts/mod/mk_elfconfig] Error 1
scripts/Makefile.build:484: recipe for target ‘scripts/mod’ failed
make[1]: *** [scripts/mod] Error 2
Makefile:579: recipe for target ‘scripts’ failed
make: *** [scripts] Error 2
make: *** Waiting for unfinished jobs…
CHK include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
ERROR: Running build_kernel failed!
ERROR: exit code 2 from line 721:
make ARCH=$RK_ARCH $RK_KERNEL_DTS.img -j$RK_JOBS
