ifconfig -a 可以识别到 wlan0,但是无法启动
sudo ifconfig wlan0 up 失败,已经使用 sudo 了,还是显示权限不足 SIOCSIFFLAGS: Operation not permitted
$ sudo ifconfig wlan0 up
[ 830.644250] dhdsdio_download_code_file: Open firmware file failed /vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 830.644259] _dhdsdio_download_firmware: dongle image file download failed
[ 830.644313] dhd_bus_devreset Failed to download binary to the dongle
[ 830.644337] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 830.644360] dhd_dbg_detach_pkt_monitor, 2100
[ 830.644374] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 830.644446] wifi_platform_set_power = 0, delay: 0 msec
[ 830.644462] ======== PULL WL_REG_ON(-1) LOW! ========
[ 830.644472] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 830.644503] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 830.644510] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 830.644516] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 830.644523] [dhd-wlan0] wl_android_wifi_on : Failed
[ 830.644549] dhd_open : wl_android_wifi_on failed (-35)
[ 830.644563] dhd_stop: Enter wlan0
[ 830.644579] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 830.644698] dhd_dbg_detach_pkt_monitor, 2100
[ 830.644714] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 830.644830] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 830.644843] wifi_platform_set_power = 0, delay: 0 msec
[ 830.644869] ======== PULL WL_REG_ON(-1) LOW! ========
[ 830.644875] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 830.644891] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 830.644898] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 830.644904] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 830.644910] [dhd-wlan0] wl_android_wifi_off : out
[ 830.658544] dhd_stop: Exit wlan0
[ 830.658558] dhd_open : the lock is released.
[ 830.658565] dhd_open: Exit wlan0 ret=-1
[ 830.658574] Failed to open primary dev ret -1
提供一下完整的dmesg
$ dmesg
[ 0.000000] Linux version 4.19.232 (thingswise@a337f25b747c) (firefly: 330e82b263990b1218820d784f5a01e9c471f037) (sdk version: rk356x_linux_release_20220726_v1.3.0a.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #3 SMP Mon Sep 26 06:28:53 UTC 2022
[ 0.000000] Machine model: AIO-3568J HDMI (Linux)
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '')
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB
[ 0.000000] cma: Reserved 16 MiB at 0x00000000ef000000
[ 0.000000] On node 0 totalpages: 1043968
[ 0.000000] DMA32 zone: 15288 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 978432 pages, LIFO batch:63
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 65536 pages, LIFO batch:15
[ 0.000000] percpu: Embedded 24 pages/cpu s60136 r8192 d29976 u98304
[ 0.000000] pcpu-alloc: s60136 r8192 d29976 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1027656
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal storagenode=/sdhci@fe310000 androidboot.verifiedbootstate=orange ro rootwait earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] software IO TLB: mapped [mem 0xe9f00000-0xedf00000] (64MB)
[ 0.000000] Memory: 3968936K/4175872K available (15166K kernel code, 1956K rwdata, 5324K rodata, 1600K init, 598K bss, 190552K reserved, 16384K cma-reserved)
[ 0.000000] ftrace: allocating 54438 entries in 213 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @ee810000 (indirect, esz 8, psz 64K, shr 0)
[ 0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @ee820000 (flat, esz 2, psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x00000000ee830000
[ 0.000000] CPU0: using LPI pending table @0x00000000ee840000
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x514 with crng_init=0
[ 0.002296] Console: colour dummy device 80x25
[ 0.002757] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003713] pid_max: default: 32768 minimum: 301
[ 0.004280] Security Framework initialized
[ 0.004675] AppArmor: AppArmor disabled by boot time parameter
[ 0.005280] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.005955] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.008561] ASID allocator initialised with 32768 entries
[ 0.009238] rcu: Hierarchical SRCU implementation.
[ 0.012667] Platform MSI: interrupt-controller@fd440000 domain created
[ 0.013883] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[ 0.015520] smp: Bringing up secondary CPUs ...
[ 0.017528] Detected VIPT I-cache on CPU1
[ 0.017568] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 0.017624] CPU1: using LPI pending table @0x00000000ee850000
[ 0.017683] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.019300] Detected VIPT I-cache on CPU2
[ 0.019337] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 0.019391] CPU2: using LPI pending table @0x00000000ee860000
[ 0.019439] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 0.021098] Detected VIPT I-cache on CPU3
[ 0.021133] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 0.021187] CPU3: using LPI pending table @0x00000000ee870000
[ 0.021235] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 0.021377] smp: Brought up 1 node, 4 CPUs
[ 0.028276] SMP: Total of 4 processors activated.
[ 0.028714] CPU features: detected: GIC system register CPU interface
[ 0.029309] CPU features: detected: Privileged Access Never
[ 0.029824] CPU features: detected: LSE atomic instructions
[ 0.030340] CPU features: detected: User Access Override
[ 0.030854] CPU features: detected: 32-bit EL0 Support
[ 0.031331] CPU features: detected: RAS Extension Support
[ 0.032022] CPU: All CPU(s) started at EL2
[ 0.032435] alternatives: patching kernel code
[ 0.039944] devtmpfs: initialized
[ 0.072355] Registered cp15_barrier emulation handler
[ 0.072889] Registered setend emulation handler
[ 0.073682] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.074601] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.076058] pinctrl core: initialized pinctrl subsystem
[ 0.076923] regulator-dummy: no parameters
[ 0.077734] NET: Registered protocol family 16
[ 0.079335] audit: initializing netlink subsys (disabled)
[ 0.080112] audit: type=2000 audit(0.073:1): state=initialized audit_enabled=0 res=1
[ 0.084166] cpuidle: using governor menu
[ 0.084558] Registered FIQ tty driver
[ 0.085872] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.088046] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.092928] console [pstore-1] enabled
[ 0.093282] pstore: Registered ramoops as persistent store backend
[ 0.093860] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.137432] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio)
[ 0.138750] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[ 0.140088] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[ 0.141392] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio)
[ 0.142692] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[ 0.143432] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.161977] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.162878] cryptd: max_cpu_qlen set to 1000
[ 0.165292] console [ttyFIQ0] enabled
[ 0.166006] bootconsole [uart8250] disabled
[ 0.166680] Registered fiq debugger ttyFIQ0
[ 0.167344] dc_12v: 12000 mV
[ 0.167628] reg-fixed-voltage dc-12v: dc_12v supplying 12000000uV
[ 0.167784] reg-fixed-voltage vcc3v3-sys: Looking up vin-supply from device tree
[ 0.167799] vcc3v3_sys: supplied by dc_12v
[ 0.167878] vcc3v3_sys: 3300 mV
[ 0.168154] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[ 0.168298] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree
[ 0.168312] vcc5v0_sys: supplied by dc_12v
[ 0.168391] vcc5v0_sys: 5000 mV
[ 0.168660] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[ 0.168928] vcc5v0_host: no parameters
[ 0.169173] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[ 0.169446] vcc5v0_otg: no parameters
[ 0.169696] reg-fixed-voltage vcc5v0-otg-regulator: vcc5v0_otg supplying 0uV
[ 0.169838] vcc3v3_lcd0_n: no parameters
[ 0.170067] reg-fixed-voltage vcc3v3-lcd0-n: vcc3v3_lcd0_n supplying 0uV
[ 0.170208] vcc3v3_lcd1_n: no parameters
[ 0.170462] reg-fixed-voltage vcc3v3-lcd1-n: vcc3v3_lcd1_n supplying 0uV
[ 0.170610] reg-fixed-voltage vcc2v5-ddr: Looking up vin-supply from device tree
[ 0.170625] vcc2v5-sys: supplied by vcc3v3_sys
[ 0.170705] vcc2v5-sys: 2500 mV
[ 0.170981] reg-fixed-voltage vcc2v5-ddr: vcc2v5-sys supplying 2500000uV
[ 0.171147] reg-fixed-voltage vcc3v3-vga: Looking up vin-supply from device tree
[ 0.171160] vcc3v3_vga: supplied by vcc3v3_sys
[ 0.171245] vcc3v3_vga: at 3300 mV
[ 0.171489] reg-fixed-voltage vcc3v3-vga: vcc3v3_vga supplying 0uV
[ 0.171626] reg-fixed-voltage pcie30-avdd0v9: Looking up vin-supply from device tree
[ 0.171639] pcie30_avdd0v9: supplied by vcc3v3_sys
[ 0.171746] pcie30_avdd0v9: 900 mV
[ 0.171991] reg-fixed-voltage pcie30-avdd0v9: pcie30_avdd0v9 supplying 900000uV
[ 0.172137] reg-fixed-voltage pcie30-avdd1v8: Looking up vin-supply from device tree
[ 0.172151] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.172235] pcie30_avdd1v8: 1800 mV
[ 0.172507] reg-fixed-voltage pcie30-avdd1v8: pcie30_avdd1v8 supplying 1800000uV
[ 0.172649] reg-fixed-voltage vcc3v3-bu: Looking up vin-supply from device tree
[ 0.172664] vcc3v3_bu: supplied by vcc5v0_sys
[ 0.172785] vcc3v3_bu: 3300 mV
[ 0.173055] reg-fixed-voltage vcc3v3-bu: vcc3v3_bu supplying 3300000uV
[ 0.173338] vcc_hub_power_en: no parameters
[ 0.173583] reg-fixed-voltage vcc-hub-power-regulator: vcc_hub_power_en supplying 0uV
[ 0.173844] vcc_hub_reset_en: no parameters
[ 0.174106] reg-fixed-voltage vcc-hub-reset-regulator: vcc_hub_reset_en supplying 0uV
[ 0.174370] pcie_pi6c_oe_en: no parameters
[ 0.174628] reg-fixed-voltage pcie-pi6c-oe-regulator: pcie_pi6c_oe_en supplying 0uV
[ 0.174852] vcc_4g_power_en: no parameters
[ 0.175125] reg-fixed-voltage vcc-4g-power-regulator: vcc_4g_power_en supplying 0uV
[ 0.175782] pcie30_3v3: 100 <--> 3300 mV at 3300 mV
[ 0.176753] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_npu-supply from device tree
[ 0.176778] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_npu-supply property in node /power-management@fdd90000/power-controller failed
[ 0.176840] rk_iommu fde4b000.iommu: version = 2
[ 0.177641] rk_iommu fdea0800.iommu: version = 2
[ 0.177963] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vpu-supply from device tree
[ 0.177988] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vpu-supply property in node /power-management@fdd90000/power-controller failed
[ 0.178183] rk_iommu fded0480.iommu: version = 2
[ 0.178593] rk_iommu fdee0800.iommu: version = 2
[ 0.178970] rk_iommu fdef0800.iommu: version = 2
[ 0.179342] rk_iommu fdf40f00.iommu: version = 2
[ 0.179837] rk_iommu fdf80800.iommu: version = 2
[ 0.180224] rk_iommu fdff1a00.iommu: version = 2
[ 0.180577] rk_iommu fe043e00.iommu: version = 2
[ 0.181713] SCSI subsystem initialized
[ 0.181801] libata version 3.00 loaded.
[ 0.182079] usbcore: registered new interface driver usbfs
[ 0.182177] usbcore: registered new interface driver hub
[ 0.182252] usbcore: registered new device driver usb
[ 0.182389] media: Linux media interface: v0.10
[ 0.182459] videodev: Linux video capture interface: v2.00
[ 0.182590] pps_core: LinuxPPS API ver. 1 registered
[ 0.182618] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.182667] PTP clock support registered
[ 0.183128] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[ 0.183906] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rga-supply from device tree
[ 0.183933] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rga-supply property in node /power-management@fdd90000/power-controller failed
[ 0.184032] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvenc-supply from device tree
[ 0.184054] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvenc-supply property in node /power-management@fdd90000/power-controller failed
[ 0.184117] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvdec-supply from device tree
[ 0.184139] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvdec-supply property in node /power-management@fdd90000/power-controller failed
[ 0.184187] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vi-supply from device tree
[ 0.184208] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vi-supply property in node /power-management@fdd90000/power-controller failed
[ 0.186380] Advanced Linux Sound Architecture Driver Initialized.
[ 0.187147] Bluetooth: Core ver 2.22
[ 0.187223] NET: Registered protocol family 31
[ 0.187248] Bluetooth: HCI device and connection manager initialized
[ 0.187277] Bluetooth: HCI socket layer initialized
[ 0.187310] Bluetooth: L2CAP socket layer initialized
[ 0.187389] Bluetooth: SCO socket layer initialized
[ 0.190046] rockchip-cpuinfo cpuinfo: SoC : 35682000
[ 0.190087] rockchip-cpuinfo cpuinfo: Serial : 8d70475e4d97facb
[ 0.191743] clocksource: Switched to clocksource arch_sys_counter
[ 0.293775] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.294212] NET: Registered protocol family 2
[ 0.294584] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.297168] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes)
[ 0.297301] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.297627] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.298738] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.298990] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.299230] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.299674] NET: Registered protocol family 1
[ 0.300627] PCI: CLS 0 bytes, default 64
[ 0.301797] Trying to unpack rootfs image as initramfs...
[ 0.785352] Freeing initrd memory: 9020K
[ 0.787176] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.788078] kvm [1]: 16-bit VMID
[ 0.788118] kvm [1]: GICv3: no GICV resource entry
[ 0.788133] kvm [1]: disabling GICv2 emulation
[ 0.788146] kvm [1]: GIC system register CPU interface enabled
[ 0.788319] kvm [1]: vgic interrupt IRQ1
[ 0.788590] kvm [1]: VHE mode initialized successfully
[ 0.791112] Initialise system trusted keyrings
[ 0.791380] workingset: timestamp_bits=45 max_order=20 bucket_order=0
[ 0.801900] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.802335] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.802659] fuse init (API version 7.27)
[ 0.803291] SGI XFS with security attributes, no debug enabled
[ 0.807249] NET: Registered protocol family 38
[ 0.807307] Key type asymmetric registered
[ 0.807322] Asymmetric key parser 'x509' registered
[ 0.807380] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.807578] io scheduler noop registered
[ 0.807596] io scheduler deadline registered
[ 0.807802] io scheduler cfq registered (default)
[ 0.807819] io scheduler mq-deadline registered
[ 0.807832] io scheduler kyber registered
[ 0.809279] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.809501] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 0.812583] phy phy-fe8a0000.usb2-phy.0: Looking up phy-supply from device tree
[ 0.812664] phy phy-fe8a0000.usb2-phy.0: Linked as a consumer to regulator.4
[ 0.812830] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply from device tree
[ 0.812844] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply property in node /usb2-phy@fe8a0000/otg-port failed
[ 0.812982] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply from device tree
[ 0.813063] phy phy-fe8a0000.usb2-phy.1: Linked as a consumer to regulator.5
[ 0.814766] extcon extcon1: failed to create extcon usb2-phy link
[ 0.814862] phy phy-fe8b0000.usb2-phy.2: Looking up phy-supply from device tree
[ 0.814937] phy phy-fe8b0000.usb2-phy.2: Linked as a consumer to regulator.4
[ 0.815189] phy phy-fe8b0000.usb2-phy.3: Looking up phy-supply from device tree
[ 0.815258] phy phy-fe8b0000.usb2-phy.3: Linked as a consumer to regulator.4
[ 0.815404] phy phy-fe8b0000.usb2-phy.3: Looking up vbus-supply from device tree
[ 0.815417] phy phy-fe8b0000.usb2-phy.3: Looking up vbus-supply property in node /usb2-phy@fe8b0000/otg-port failed
[ 0.815446] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port
[ 0.819783] phy phy-fe820000.phy.4: Looking up phy-supply from device tree
[ 0.819800] phy phy-fe820000.phy.4: Looking up phy-supply property in node /phy@fe820000 failed
[ 0.820404] phy phy-fe830000.phy.5: Looking up phy-supply from device tree
[ 0.820418] phy phy-fe830000.phy.5: Looking up phy-supply property in node /phy@fe830000 failed
[ 0.820985] phy phy-fe840000.phy.6: Looking up phy-supply from device tree
[ 0.820998] phy phy-fe840000.phy.6: Looking up phy-supply property in node /phy@fe840000 failed
[ 0.822609] phy phy-fe8c0000.phy.7: Looking up phy-supply from device tree
[ 0.822625] phy phy-fe8c0000.phy.7: Looking up phy-supply property in node /phy@fe8c0000 failed
[ 0.827508] rk-pcie 3c0800000.pcie: Looking up vpcie3v3-supply from device tree
[ 0.827655] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.17
[ 0.828314] mpp_service mpp-srv: 17e24d4a84af author: Ding Wei 2022-05-05 video: rockchip: mpp: rkvdec2: task->irq_status set for link mode
[ 0.828349] mpp_service mpp-srv: probe start
[ 0.829676] iommu: Adding device fdf40000.rkvenc to group 5
[ 0.829736] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu
[ 0.830021] mpp_rkvenc fdf40000.rkvenc: probing start
[ 0.830661] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[ 0.830689] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry
[ 0.830720] rkvenc_init:1199: failed to add venc devfreq
[ 0.831166] mpp_rkvenc fdf40000.rkvenc: probing finish
[ 0.832796] iommu: Adding device fdea0400.vdpu to group 1
[ 0.832854] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu
[ 0.833093] mpp_vdpu2 fdea0400.vdpu: probe device
[ 0.833916] mpp_vdpu2 fdea0400.vdpu: probing finish
[ 0.834705] iommu: Adding device fdee0000.vepu to group 3
[ 0.834761] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu
[ 0.835024] mpp_vepu2 fdee0000.vepu: probe device
[ 0.835859] mpp_vepu2 fdee0000.vepu: probing finish
[ 0.836637] iommu: Adding device fdef0000.iep to group 4
[ 0.836694] mpp-iep2 fdef0000.iep: Linked as a consumer to fdef0800.iommu
[ 0.836903] mpp-iep2 fdef0000.iep: probe device
[ 0.837040] snps pcie3phy FW update! size 8192
[ 0.837555] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[ 0.837781] mpp-iep2 fdef0000.iep: probing finish
[ 0.838572] iommu: Adding device fded0000.jpegd to group 2
[ 0.838627] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu
[ 0.838885] mpp_jpgdec fded0000.jpegd: probe device
[ 0.839680] mpp_jpgdec fded0000.jpegd: probing finish
[ 0.840469] iommu: Adding device fdf80200.rkvdec to group 6
[ 0.840524] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu
[ 0.840831] mpp_rkvdec2 fdf80200.rkvdec: probing start
[ 0.841060] mpp_rkvdec2 fdf80200.rkvdec: 16 task capacity link mode detected
[ 0.841541] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[ 0.841571] rkvdec2_init:661: No niu aclk reset resource define
[ 0.841598] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[ 0.841620] rkvdec2_init:664: No niu hclk reset resource define
[ 0.841922] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[ 0.841952] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[ 0.841977] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[ 0.841999] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[ 0.842018] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[ 0.842094] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[ 0.842203] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[ 0.842694] mpp_service mpp-srv: probe success
[ 0.851232] rk-pcie 3c0800000.pcie: missing legacy IRQ resource
[ 0.851276] rk-pcie 3c0800000.pcie: Missing *config* reg space
[ 0.851300] rk-pcie 3c0800000.pcie: host bridge /pcie@fe280000 ranges:
[ 0.851335] rk-pcie 3c0800000.pcie: err 0xf0000000..0xf00fffff -> 0xf0000000
[ 0.851384] rk-pcie 3c0800000.pcie: IO 0xf0100000..0xf01fffff -> 0xf0100000
[ 0.851430] rk-pcie 3c0800000.pcie: MEM 0xf0200000..0xf1ffffff -> 0xf0200000
[ 0.851463] rk-pcie 3c0800000.pcie: MEM 0x380000000..0x3bfffffff -> 0x380000000
[ 0.854554] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.854582] dma-pl330 fe530000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.858048] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.858091] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.859999] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.861450] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.862685] fe670000.serial: ttyS3 at MMIO 0xfe670000 (irq = 68, base_baud = 1500000) is a 16550A
[ 0.863591] fe680000.serial: ttyS4 at MMIO 0xfe680000 (irq = 69, base_baud = 1500000) is a 16550A
[ 0.864477] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 70, base_baud = 1500000) is a 16550A
[ 0.868312] random: fast init done
[ 0.868663] random: crng init done
[ 0.869178] iommu: Adding device fe040000.vop to group 8
[ 0.869238] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu
[ 0.876058] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop
[ 0.877882] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi
[ 0.880849] rockchip-drm display-subsystem: defer getting devfreq
[ 0.881218] vp0: rgb_pixelclk: 0
[ 0.881265] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x3f, primary plane phy id: 4
[ 0.881293] vp1: rgb_pixelclk: 0
[ 0.881321] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x0, primary plane phy id: -1
[ 0.881346] vp2: rgb_pixelclk: 0
[ 0.881374] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1
[ 0.881658] [drm] unsupported AFBC format[3432564e]
[ 0.881776] [drm] failed to init overlay plane Cluster0-win1
[ 0.881876] [drm] failed to init overlay plane Cluster1-win1
[ 0.882034] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8009032338)
[ 0.882306] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.883105] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.884009] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8009035e50)
[ 0.884046] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.884067] [drm] No driver support for vblank timestamp query.
[ 1.133010] fbcon: Deferring console take-over
[ 1.133063] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.134235] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 1.142060] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_gpu-supply from device tree
[ 1.142101] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_gpu-supply property in node /power-management@fdd90000/power-controller failed
[ 1.142173] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 1.142303] mali fde60000.gpu: Looking up mali-supply from device tree
[ 1.142337] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.142349] mali fde60000.gpu: Device initialization Deferred
[ 1.143421] brd: module loaded
[ 1.153705] loop: module loaded
[ 1.154406] zram: Added device: zram0
[ 1.154598] lkdtm: No crash points registered, enable through debugfs
[ 1.156347] ahci fc800000.sata: Looking up target-supply from device tree
[ 1.156366] ahci fc800000.sata: Looking up target-supply property in node /sata@fc800000 failed
[ 1.156500] ahci fc800000.sata: forcing port_map 0x0 -> 0x1
[ 1.156582] ahci fc800000.sata: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 1.156616] ahci fc800000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst
[ 1.156652] ahci fc800000.sata: port 0 is not capable of FBS
[ 1.158008] scsi host0: ahci
[ 1.158596] ata1: SATA max UDMA/133 mmio [mem 0xfc800000-0xfc800fff] port 0x100 irq 11
[ 1.162269] register firefly_spi_init spi return v = :0
[ 1.162685] CAN device driver interface
[ 1.167396] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[ 1.167422] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply property in node /ethernet@fe010000 failed
[ 1.167456] rk_gmac-dwmac fe010000.ethernet: no regulator found
[ 1.167498] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[ 1.167518] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f).
[ 1.167535] rk_gmac-dwmac fe010000.ethernet: RX delay(0x26).
[ 1.167556] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[ 1.167638] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[ 1.172676] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[ 1.173018] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 1.173051] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5
[ 1.173078] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[ 1.173101] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[ 1.173121] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[ 1.173142] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[ 1.173201] rk_gmac-dwmac fe010000.ethernet: TSO supported
[ 1.173217] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.173234] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[ 1.312756] rk_gmac-dwmac fe2a0000.ethernet: Looking up phy-supply from device tree
[ 1.312783] rk_gmac-dwmac fe2a0000.ethernet: Looking up phy-supply property in node /ethernet@fe2a0000 failed
[ 1.312817] rk_gmac-dwmac fe2a0000.ethernet: no regulator found
[ 1.312864] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (input).
[ 1.312883] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x3c).
[ 1.312899] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x2f).
[ 1.312919] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[ 1.313005] rk_gmac-dwmac fe2a0000.ethernet: clock input from PHY
[ 1.318043] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[ 1.318432] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 1.318465] rk_gmac-dwmac fe2a0000.ethernet: DWMAC4/5
[ 1.318492] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[ 1.318514] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[ 1.318534] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[ 1.318554] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[ 1.318615] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[ 1.318631] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.318660] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[ 1.458939] usbcore: registered new interface driver rndis_wlan
[ 1.459044] usbcore: registered new interface driver rtl8150
[ 1.459126] usbcore: registered new interface driver r8152
[ 1.459209] usbcore: registered new interface driver asix
[ 1.459300] usbcore: registered new interface driver ax88179_178a
[ 1.459381] usbcore: registered new interface driver cdc_ether
[ 1.459459] usbcore: registered new interface driver rndis_host
[ 1.459553] usbcore: registered new interface driver cdc_ncm
[ 1.459646] usbcore: registered new interface driver qmi_wwan_q
[ 1.459726] usbcore: registered new interface driver qmi_wwan
[ 1.459792] usbcore: registered new interface driver cdc_mbim
[ 1.461452] dwc3 fcc00000.dwc3: Failed to get clk 'ref': -2
[ 1.468633] dwc3 fd000000.dwc3: Failed to get clk 'ref': -2
[ 1.475667] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.475717] ehci-pci: EHCI PCI platform driver
[ 1.475822] ehci-platform: EHCI generic platform driver
[ 1.478199] ehci-platform fd800000.usb: EHCI Host Controller
[ 1.478505] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1
[ 1.479039] ehci-platform fd800000.usb: irq 12, io mem 0xfd800000
[ 1.491794] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[ 1.492135] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.492168] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.492192] usb usb1: Product: EHCI Host Controller
[ 1.492217] usb usb1: Manufacturer: Linux 4.19.232 ehci_hcd
[ 1.492239] usb usb1: SerialNumber: fd800000.usb
[ 1.492978] hub 1-0:1.0: USB hub found
[ 1.493056] hub 1-0:1.0: 1 port detected
[ 1.495906] ehci-platform fd880000.usb: EHCI Host Controller
[ 1.496191] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2
[ 1.496720] ehci-platform fd880000.usb: irq 14, io mem 0xfd880000
[ 1.508461] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[ 1.508809] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.508841] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.508865] usb usb2: Product: EHCI Host Controller
[ 1.508887] usb usb2: Manufacturer: Linux 4.19.232 ehci_hcd
[ 1.508908] usb usb2: SerialNumber: fd880000.usb
[ 1.509595] hub 2-0:1.0: USB hub found
[ 1.509670] hub 2-0:1.0: 1 port detected
[ 1.510828] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.510876] ohci-platform: OHCI generic platform driver
[ 1.511209] ohci-platform fd840000.usb: Generic Platform OHCI controller
[ 1.511481] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[ 1.511871] ohci-platform fd840000.usb: irq 13, io mem 0xfd840000
[ 1.572721] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.572754] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.572771] usb usb3: Product: Generic Platform OHCI controller
[ 1.572785] usb usb3: Manufacturer: Linux 4.19.232 ohci_hcd
[ 1.572799] usb usb3: SerialNumber: fd840000.usb
[ 1.573478] hub 3-0:1.0: USB hub found
[ 1.573553] hub 3-0:1.0: 1 port detected
[ 1.574326] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[ 1.574600] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4
[ 1.574932] ohci-platform fd8c0000.usb: irq 15, io mem 0xfd8c0000
[ 1.632705] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.632739] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.632755] usb usb4: Product: Generic Platform OHCI controller
[ 1.632768] usb usb4: Manufacturer: Linux 4.19.232 ohci_hcd
[ 1.632783] usb usb4: SerialNumber: fd8c0000.usb
[ 1.633483] hub 4-0:1.0: USB hub found
[ 1.633560] hub 4-0:1.0: 1 port detected
[ 1.636003] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 1.636310] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 5
[ 1.637252] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010
[ 1.637348] xhci-hcd xhci-hcd.4.auto: irq 86, io mem 0xfd000000
[ 1.637849] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.637870] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.637886] usb usb5: Product: xHCI Host Controller
[ 1.637913] usb usb5: Manufacturer: Linux 4.19.232 xhci-hcd
[ 1.637936] usb usb5: SerialNumber: xhci-hcd.4.auto
[ 1.638655] hub 5-0:1.0: USB hub found
[ 1.638723] hub 5-0:1.0: 1 port detected
[ 1.639285] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 1.639542] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 6
[ 1.639587] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[ 1.639720] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.639944] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 1.639965] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.639995] usb usb6: Product: xHCI Host Controller
[ 1.640020] usb usb6: Manufacturer: Linux 4.19.232 xhci-hcd
[ 1.640041] usb usb6: SerialNumber: xhci-hcd.4.auto
[ 1.640712] hub 6-0:1.0: USB hub found
[ 1.640781] hub 6-0:1.0: 1 port detected
[ 1.641523] usbcore: registered new interface driver cdc_acm
[ 1.641551] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.641656] usbcore: registered new interface driver cdc_wdm
[ 1.642048] usbcore: registered new interface driver uas
[ 1.642272] usbcore: registered new interface driver usb-storage
[ 1.642421] usbcore: registered new interface driver usbserial_generic
[ 1.642483] usbserial: USB Serial support registered for generic
[ 1.642574] usbcore: registered new interface driver cp210x
[ 1.642629] usbserial: USB Serial support registered for cp210x
[ 1.642776] usbcore: registered new interface driver ftdi_sio
[ 1.642823] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.643171] usbcore: registered new interface driver keyspan
[ 1.643231] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.643285] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.643334] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.643390] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.643494] usbcore: registered new interface driver option
[ 1.643549] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.644043] usbcore: registered new interface driver oti6858
[ 1.644088] usbserial: USB Serial support registered for oti6858
[ 1.644180] usbcore: registered new interface driver pl2303
[ 1.644236] usbserial: USB Serial support registered for pl2303
[ 1.644354] usbcore: registered new interface driver qcserial
[ 1.644411] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.644554] usbcore: registered new interface driver sierra
[ 1.644601] usbserial: USB Serial support registered for Sierra USB modem
[ 1.646495] usbcore: registered new interface driver usbtouchscreen
[ 1.646570] ============ himax_hx83102_init 1742 jjlook ==========
[ 1.646594] ============ himax_hx83102_probe 1725 jjlook ==========
[ 1.646696] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[ 1.646725] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[ 1.647182] .. rk pwm remotectl v2.0 init
[ 1.647587] input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input0
[ 1.648120] remotectl-pwm fe6e0030.pwm: pwm version is 0x2130000
[ 1.648163] remotectl-pwm fe6e0030.pwm: cannot find PWR IRQ
[ 1.648180] remotectl-pwm fe6e0030.pwm: pwm sip wakeup config error!!
[ 1.648205] remotectl-pwm fe6e0030.pwm: Donot support ATF Wakeup
[ 1.649222] i2c /dev entries driver
[ 1.651710] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[ 1.652277] vdd_cpu: override max_uV, 1390000 -> 1387500
[ 1.653597] fan53555-regulator 0-001c: Looking up vin-supply from device tree
[ 1.653616] vdd_cpu: supplied by vcc5v0_sys
[ 1.656105] vdd_cpu: 712 <--> 1387 mV at 1025 mV
[ 1.658928] rk808 0-0020: chip id: 0x8090
[ 1.659011] rk808 0-0020: No cache defaults, reading back from HW
[ 1.682855] rk808 0-0020: source: on=0x40, off=0x00
[ 1.682894] rk808 0-0020: support dcdc3 fb mode:-22, 63
[ 1.682913] rk808 0-0020: support pmic reset mode:0,0
[ 1.688607] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.688679] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.688793] rk808 0-0020: Looking up vcc1-supply from device tree
[ 1.688812] vdd_logic: supplied by vcc3v3_sys
[ 1.688930] vdd_logic: 500 <--> 1350 mV at 900 mV
[ 1.689372] rk808 0-0020: Looking up vcc2-supply from device tree
[ 1.689387] vdd_gpu: supplied by vcc3v3_sys
[ 1.689482] vdd_gpu: 500 <--> 1350 mV at 900 mV
[ 1.689894] rk808 0-0020: Looking up vcc3-supply from device tree
[ 1.689909] vcc_ddr: supplied by vcc3v3_sys
[ 1.689993] vcc_ddr: at 500 mV
[ 1.690400] rk808 0-0020: Looking up vcc4-supply from device tree
[ 1.690415] vdd_npu: supplied by vcc3v3_sys
[ 1.690514] vdd_npu: 500 <--> 1350 mV at 900 mV
[ 1.690917] rk808 0-0020: Looking up vcc9-supply from device tree
[ 1.690933] vcc_1v8: supplied by vcc3v3_sys
[ 1.691021] vcc_1v8: 1800 mV
[ 1.691397] rk808 0-0020: Looking up vcc5-supply from device tree
[ 1.691412] vdda0v9_image: supplied by vcc3v3_sys
[ 1.691501] vdda0v9_image: 900 mV
[ 1.691922] rk808 0-0020: Looking up vcc5-supply from device tree
[ 1.691937] vdda_0v9: supplied by vcc3v3_sys
[ 1.692027] vdda_0v9: 900 mV
[ 1.692422] rk808 0-0020: Looking up vcc5-supply from device tree
[ 1.692437] vdda0v9_pmu: supplied by vcc3v3_sys
[ 1.692527] vdda0v9_pmu: 900 mV
[ 1.692910] rk808 0-0020: Looking up vcc6-supply from device tree
[ 1.692926] vccio_acodec: supplied by vcc3v3_sys
[ 1.693014] vccio_acodec: 3300 mV
[ 1.693394] rk808 0-0020: Looking up vcc6-supply from device tree
[ 1.693409] vccio_sd: supplied by vcc3v3_sys
[ 1.693502] vccio_sd: 1800 <--> 3300 mV at 3300 mV
[ 1.693890] rk808 0-0020: Looking up vcc6-supply from device tree
[ 1.693905] vcc3v3_pmu: supplied by vcc3v3_sys
[ 1.693994] vcc3v3_pmu: 3300 mV
[ 1.694377] rk808 0-0020: Looking up vcc7-supply from device tree
[ 1.694391] vcca_1v8: supplied by vcc3v3_sys
[ 1.694500] vcca_1v8: 1800 mV
[ 1.694880] rk808 0-0020: Looking up vcc7-supply from device tree
[ 1.694895] vcca1v8_pmu: supplied by vcc3v3_sys
[ 1.695006] vcca1v8_pmu: 1800 mV
[ 1.695425] rk808 0-0020: Looking up vcc7-supply from device tree
[ 1.695440] vcca1v8_image: supplied by vcc3v3_sys
[ 1.695546] vcca1v8_image: 1800 mV
[ 1.695912] rk808 0-0020: Looking up vcc9-supply from device tree
[ 1.695927] vcc_3v3: supplied by vcc3v3_sys
[ 1.696011] vcc_3v3: at 3300 mV
[ 1.696366] rk808 0-0020: Looking up vcc8-supply from device tree
[ 1.696381] vcc3v3_sd: supplied by vcc3v3_sys
[ 1.696466] vcc3v3_sd: at 3300 mV
[ 1.697039] rk817-battery rk817-battery: Failed to find matching dt id
[ 1.697379] rk817-charger rk817-charger: Failed to find matching dt id
[ 1.700872] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[ 1.701539] rk808-rtc rk808-rtc: device is disabled
[ 1.701584] rk808-rtc: probe of rk808-rtc failed with error -22
[ 1.703778] pca953x 1-0021: Looking up vcc-supply from device tree
[ 1.703792] pca953x 1-0021: Looking up vcc-supply property in node /i2c@fe5a0000/gpio@21 failed
[ 1.703843] pca953x 1-0021: 1-0021 supply vcc not found, using dummy regulator
[ 1.703962] pca953x 1-0021: Linked as a consumer to regulator.0
[ 1.710062] rtc-hym8563 5-0051: rtc information is valid
[ 1.715700] rtc-hym8563 5-0051: rtc core: registered hym8563 as rtc0
[ 1.716781] rtc-hym8563 5-0051: setting system clock to 2022-04-15 14:11:52 UTC (1650031912)
[ 1.718501] gsensor_mc3230 5-004c: sensor_register_device: gs_mc3230, id = 27
[ 1.718540] i2c i2c-5: sensor_probe: gs_mc3230,00000000d0e335e1
[ 1.718606] gsensor_mc3230 5-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0x000000004fd1b67d
[ 1.758614] [Gsensor] init_3230_ctl_data 457 : error: -6
[ 1.758647] gsensor_mc3230 5-004c: sensor_initial:fail to init sensor
[ 1.758664] gsensor_mc3230 5-004c: sensor_chip_init:fail to init sensor
[ 1.758678] i2c i2c-5: sensor_probe failed -2
[ 1.762711] iommu: Adding device fdff0000.rkisp to group 7
[ 1.762776] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iommu
[ 1.763038] rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[ 1.763059] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[ 1.763110] rkisp_hw fdff0000.rkisp: can't request region for resource [mem 0xfdff0000-0xfdffffff]
[ 1.764379] rkisp rkisp-vir0: rkisp driver version: v01.08.00
[ 1.764786] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 1.764818] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[ 1.767885] usbcore: registered new interface driver uvcvideo
[ 1.767922] USB Video Class driver (1.1.1)
[ 1.768216] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply from device tree
[ 1.768331] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.29
[ 1.768445] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[ 1.768509] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio2-supply from device tree
[ 1.768626] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[ 1.768679] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio1-supply from device tree
[ 1.768776] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.27
[ 1.768839] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[ 1.768889] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply from device tree
[ 1.768906] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply property in node /syscon@fdc20000/io-domains failed
[ 1.768952] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio3-supply from device tree
[ 1.769058] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.28
[ 1.769121] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[ 1.769171] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio4-supply from device tree
[ 1.769266] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.23
[ 1.769326] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[ 1.769387] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio5-supply from device tree
[ 1.769480] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.33
[ 1.769532] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[ 1.769583] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio6-supply from device tree
[ 1.769710] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[ 1.769764] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio7-supply from device tree
[ 1.769888] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[ 1.774464] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[ 1.776246] Bluetooth: HCI UART driver ver 2.3
[ 1.776281] Bluetooth: HCI UART protocol H4 registered
[ 1.776303] Bluetooth: HCI UART protocol ATH3K registered
[ 1.776613] Bluetooth: HCI UART protocol Broadcom registered
[ 1.776738] usbcore: registered new interface driver bfusb
[ 1.776852] usbcore: registered new interface driver btusb
[ 1.777254] cpu cpu0: leakage=29
[ 1.777334] cpu cpu0: pvtm = 85930, from nvmem
[ 1.777374] cpu cpu0: pvtm-volt-sel=1
[ 1.777751] cpu cpu0: Looking up cpu-supply from device tree
[ 1.778357] cpu cpu0: Linked as a consumer to regulator.18
[ 1.778493] cpu cpu0: Dropping the link to regulator.18
[ 1.778675] cpu cpu0: Looking up cpu-supply from device tree
[ 1.779260] cpu cpu0: Linked as a consumer to regulator.18
[ 1.780460] cpu cpu0: avs=0
[ 1.780562] energy_model: pd0: hertz/watts ratio non-monotonically decreasing: em_cap_state 2 >= em_cap_state1
[ 1.780878] energy_model: Created perf domain 0-3
[ 1.780930] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.784656] cpu cpu0: failed to find power_model node
[ 1.786595] sdhci: Secure Digital Host Controller Interface driver
[ 1.786623] sdhci: Copyright(c) Pierre Ossman
[ 1.786633] Synopsys Designware Multimedia Card Interface Driver
[ 1.787772] dwmmc_rockchip fe000000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.788035] dwmmc_rockchip fe000000.dwmmc: Using internal DMA controller.
[ 1.788064] dwmmc_rockchip fe000000.dwmmc: Version ID is 270a
[ 1.788131] dwmmc_rockchip fe000000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo
[ 1.788178] dwmmc_rockchip fe000000.dwmmc: Looking up vmmc-supply from device tree
[ 1.788191] dwmmc_rockchip fe000000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe000000 failed
[ 1.788233] dwmmc_rockchip fe000000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.788242] dwmmc_rockchip fe000000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe000000 failed
[ 1.788322] dwmmc_rockchip fe000000.dwmmc: allocated mmc-pwrseq
[ 1.788347] mmc_host mmc3: card is non-removable.
[ 1.871999] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 1.888456] usb 5-1: new high-speed USB device number 2 using xhci-hcd
[ 1.905420] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.918678] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.918794] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[ 1.918811] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[ 1.918861] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 51,32 bit host data width,256 deep fifo
[ 1.918889] dwmmc_rockchip fe2b0000.dwmmc: Looking up vmmc-supply from device tree
[ 1.918966] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.34
[ 1.918981] dwmmc_rockchip fe2b0000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.919034] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.28
[ 1.932023] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.945343] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.946800] sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply from device tree
[ 1.946813] sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply property in node /sdhci@fe310000 failed
[ 1.946879] sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply from device tree
[ 1.946888] sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe310000 failed
[ 1.946917] mmc0: Unknown controller version (5). You may experience problems.
[ 1.954360] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.956343] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.958092] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.961178] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.977694] mmc0: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[ 1.978463] usb 3-1: new low-speed USB device number 2 using ohci-platform
[ 1.982684] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.983150] usbcore: registered new interface driver usbhid
[ 1.983171] usbhid: USB HID core driver
[ 1.983673] rockchip,bus bus-npu: Looking up bus-supply from device tree
[ 1.983769] rockchip,bus bus-npu: Linked as a consumer to regulator.19
[ 1.983799] rockchip,bus bus-npu: Failed to get leakage
[ 1.983861] rockchip,bus bus-npu: pvtm = 85930, from nvmem
[ 1.983883] rockchip,bus bus-npu: pvtm-volt-sel=1
[ 1.984161] rockchip,bus bus-npu: avs=0
[ 1.987885] rockchip-saradc fe720000.saradc: Looking up vref-supply from device tree
[ 1.987971] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.30
[ 1.988765] rksfc_base v1.1 2016-01-08
[ 1.989482] rksfc fe300000.sfc: rksfc_probe clk rate = 50000000
[ 1.989551] rkflash_dev_init enter
[ 1.989575] sfc nor id: ef 60 19
[ 1.989600] rkflash[1] init success
[ 1.990772] sfc_nor_mtd_init register mtd succuss
[ 1.990793] rkflash_dev_init device register as mtd dev, ret= 0
[ 1.991577] usbcore: registered new interface driver snd-usb-audio
[ 1.993836] rk817-codec rk817-codec: DMA mask not set
[ 1.994523] rk817_codec_parse_dt_property: rk809 hp adc effective value of detection 0~600
[ 1.994552] invalid rk817->hp_det_gpio: -2
[ 1.994566] invalid gpio: -2
[ 2.000530] NET: Registered protocol family 10
[ 2.001462] Segment Routing with IPv6
[ 2.001528] NET: Registered protocol family 17
[ 2.001554] can: controller area network core (rev 20170425 abi 9)
[ 2.001689] NET: Registered protocol family 29
[ 2.001752] can: raw protocol (rev 20170425)
[ 2.001774] can: broadcast manager protocol (rev 20170425 t)
[ 2.001796] can: netlink gateway (rev 20170425) max_hops=1
[ 2.002088] Bluetooth: RFCOMM socket layer initialized
[ 2.002132] Bluetooth: RFCOMM ver 1.11
[ 2.002149] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.002169] Bluetooth: HIDP socket layer initialized
[ 2.002183] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.002195] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.002777] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.002831] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275s
[ 2.002847] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.002859] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.002902] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 124, flags = 0.
[ 2.002923] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 2.002937] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.002950] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 2.002962] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.003565] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 73.
[ 2.003603] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 96.
[ 2.003627] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 109.
[ 2.003650] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 95.
[ 2.003725] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.003823] [BT_RFKILL]: ** disable irq
[ 2.003953] [BT_RFKILL]: bt_default device registered.
[ 2.004098] Key type dns_resolver registered
[ 2.004397] flash vendor_init_thread!
[ 2.004417] flash vendor storage:20170308 ret = -1
[ 2.006493] Loading compiled-in X.509 certificates
[ 2.007121] pstore: Using compression: deflate
[ 2.008089] rga2: Driver loaded successfully ver:3.2.63318
[ 2.008647] mmc0: new HS200 MMC card at address 0001
[ 2.008673] rga2: Module initialized.
[ 2.009449] mmcblk0: mmc0:0001 Y2P032 29.1 GiB
[ 2.010067] mmcblk0boot0: mmc0:0001 Y2P032 partition 1 4.00 MiB
[ 2.010699] mmcblk0boot1: mmc0:0001 Y2P032 partition 2 4.00 MiB
[ 2.010959] mmcblk0rpmb: mmc0:0001 Y2P032 partition 3 16.0 MiB, chardev (239:0)
[ 2.013511] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 2.031311] usb 5-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.91
[ 2.031342] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.031351] usb 5-1: Product: USB2.1 Hub
[ 2.031358] usb 5-1: Manufacturer: GenesysLogic
[ 2.035719] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 2.035801] input: adc-keys as /devices/platform/adc-keys/input/input2
[ 2.035840] mali fde60000.gpu: Looking up mali-supply from device tree
[ 2.035925] mali fde60000.gpu: Linked as a consumer to regulator.20
[ 2.035944] mali fde60000.gpu: Looking up shadercores-supply from device tree
[ 2.035955] mali fde60000.gpu: Looking up shadercores-supply property in node /gpu@fde60000 failed
[ 2.036026] mali fde60000.gpu: Looking up mali-supply from device tree
[ 2.036055] vdd_gpu: could not add device link fde60000.gpu err -17
[ 2.036062] vdd_gpu: Failed to create debugfs directory
[ 2.036071] mali fde60000.gpu: Looking up shadercores-supply from device tree
[ 2.036084] mali fde60000.gpu: Looking up shadercores-supply property in node /gpu@fde60000 failed
[ 2.036106] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19
[ 2.036215] mali fde60000.gpu: leakage=7
[ 2.036262] mali fde60000.gpu: pvtm = 85930, from nvmem
[ 2.036281] mali fde60000.gpu: pvtm-volt-sel=1
[ 2.036382] rockchip-dmc dmc: Looking up center-supply from device tree
[ 2.036438] rockchip-dmc dmc: Linked as a consumer to regulator.19
[ 2.036518] rockchip-dmc dmc: leakage=47
[ 2.036537] rockchip-dmc dmc: leakage-volt-sel=0
[ 2.036573] rockchip-dmc dmc: pvtm = 85930, from nvmem
[ 2.036591] rockchip-dmc dmc: pvtm-volt-sel=1
[ 2.036730] mali fde60000.gpu: avs=0
[ 2.036751] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 2.036753] rockchip-dmc dmc: avs=0
[ 2.036766] rockchip-dmc dmc: current ATF version 0x102
[ 2.037052] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[ 2.037131] mali fde60000.gpu: No priority control manager is configured
[ 2.037147] mali fde60000.gpu: No memory group manager is configured
[ 2.037331] rockchip-dmc dmc: normal_rate = 780000000
[ 2.037353] rockchip-dmc dmc: reboot_rate = 1560000000
[ 2.037366] rockchip-dmc dmc: suspend_rate = 324000000
[ 2.037378] rockchip-dmc dmc: video_4k_rate = 780000000
[ 2.037389] rockchip-dmc dmc: video_4k_10b_rate = 780000000
[ 2.037401] rockchip-dmc dmc: boost_rate = 1560000000
[ 2.037414] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1560000000
[ 2.037426] rockchip-dmc dmc: performance_rate = 1560000000
[ 2.037468] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 2.037653] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 2.037731] rockchip-dmc dmc: could not find power_model node
[ 2.037739] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 2.038477] mali fde60000.gpu: Probed as mali0
[ 2.046047] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 2.051289] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 266
[ 2.052950] mmc3: new ultra high speed SDR104 SDIO card at address 0001
[ 2.056130] asoc-simple-card hdmi-sound: i2s-hifi <-> fe400000.i2s mapping ok
[ 2.058579] rk817-codec rk817-codec: rk817_probe: chip_name:0x80, chip_ver:0x94
[ 2.063679] asoc-simple-card rk809-sound: rk817-hifi <-> fe410000.i2s mapping ok
[ 2.063724] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 2.063735] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 -> direct -> Mic Jack
[ 2.063743] asoc-simple-card rk809-sound: ASoC: no source widget found for Mic Jack
[ 2.063751] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack -> direct -> IN1P
[ 2.063760] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 2.063767] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL -> direct -> Headphone Jack
[ 2.063774] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 2.063781] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR -> direct -> Headphone Jack
[ 2.067056] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 2.088134] hub 5-1:1.0: USB hub found
[ 2.088445] hub 5-1:1.0: 4 ports detected
[ 2.125650] vendor storage:20190527 ret = 0
[ 2.149715] devfreq fde60000.gpu: Couldn't update frequency transition information.
[ 2.152091] usb 6-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 2.171698] usb 6-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.91
[ 2.171746] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.171756] usb 6-1: Product: USB3.2 Hub
[ 2.171764] usb 6-1: Manufacturer: GenesysLogic
[ 2.200195] hub 6-1:1.0: USB hub found
[ 2.200568] hub 6-1:1.0: 4 ports detected
[ 2.210885] usb 3-1: New USB device found, idVendor=413c, idProduct=2113, bcdDevice= 1.08
[ 2.210919] usb 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.210927] usb 3-1: Product: Dell KB216 Wired Keyboard
[ 2.220483] input: Dell KB216 Wired Keyboard as /devices/platform/fd840000.usb/usb3/3-1/3-1:1.0/0003:413C:2113.0001/input/input3
[ 2.241197] wk2xxx_serial_init()
[ 2.241238] wk2xxx_request_port
[ 2.241250] ttysWK0 at I/O 0x1 (irq = 114, base_baud = 460800) is a wk2xxx
[ 2.241554] uart_add_one_port success for line i:= 0 with right 0
[ 2.241570] wk2xxx_request_port
[ 2.241581] ttysWK1 at I/O 0x2 (irq = 114, base_baud = 460800) is a wk2xxx
[ 2.241714] uart_add_one_port success for line i:= 1 with right 0
[ 2.241743] wk2xxx_request_port
[ 2.241756] ttysWK2 at I/O 0x3 (irq = 114, base_baud = 460800) is a wk2xxx
[ 2.241995] uart_add_one_port success for line i:= 2 with right 0
[ 2.242006] wk2xxx_request_port
[ 2.242014] ttysWK3 at I/O 0x4 (irq = 114, base_baud = 460800) is a wk2xxx
[ 2.242238] uart_add_one_port success for line i:= 3 with right 0
[ 2.242246] uart_add_one_port = 0x0
[ 2.243617] register spi return v = :0
[ 2.243647] dhd_module_init: in Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 2.243658] ======== dhd_wlan_init_plat_data ========
[ 2.243670] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.243759] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=115, oob_irq_flags=0x414
[ 2.243770] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 2.243780] dhd_wifi_platform_load: Enter
[ 2.243792] Power-up adapter 'DHD generic adapter'
[ 2.245660] wifi_platform_set_power = 1, delay: 200 msec
[ 2.245693] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 2.245705] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.245717] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 2.245728] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 2.279367] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-fd840000.usb-1/input0
[ 2.287135] input: Dell KB216 Wired Keyboard System Control as /devices/platform/fd840000.usb/usb3/3-1/3-1:1.1/0003:413C:2113.0002/input/input4
[ 2.342281] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/fd840000.usb/usb3/3-1/3-1:1.1/0003:413C:2113.0002/input/input5
[ 2.342711] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-fd840000.usb-1/input1
[ 2.479331] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.479423] ata1: ready = 1 sstatus = 0
[ 2.551996] wifi_platform_bus_enumerate device present 1
[ 2.552072] ======== Card detection to detect SDIO card! ========
[ 2.552099] mmc3:mmc host rescan start!
[ 2.568313] bcmsdh_register: register client driver
[ 2.568803] bcmsdh_sdmmc_probe: Enter num=1
[ 2.569728] bcmsdh_sdmmc_probe: Enter num=2
[ 2.569752] bus num (host idx)=3, slot num (rca)=1
[ 2.569763] found adapter info 'DHD generic adapter'
[ 2.569879] sdioh_attach: set sd_f2_blocksize 256
[ 2.569938] sdioh_attach: sd clock rate = 0
[ 2.570240] dhdsdio_probe : no mutex held. set lock
[ 2.570412] F1 signature read @0x18000000=0x1042aae8
[ 2.574123] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 2.574797] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 2.574900] [dhd] dhd_conf_set_chiprev : chip=0xaae8, chiprev=2
[ 2.576223] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.576254] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.576263] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.576272] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.576280] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.577050] dhd_log_dump_init: kernel log buf size = 256KB; logdump_prsrv_tailsize = 80KB; limit prsrv tail size to = 38KB
[ 2.580551] dhd_attach(): thread:dhd_watchdog_thread:6d started
[ 2.581004] dhd_attach(): thread:dhd_dpc:6e started
[ 2.581349] dhd_attach(): thread:dhd_rxf:6f started
[ 2.581418] dhd_deferred_work_init: work queue initialized
[ 2.581513] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 2
[ 2.581878] get_mem_val_from_file: File [/data/misc/wifi/.memdump.info] doesn't exist
[ 2.581967] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[ 2.582059] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 2.589132] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 2.589280] Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 2.590231] Register interface [wlan0] MAC: 10:2c:6b:7f:b8:f8
[ 2.590415] dhd_dbg_detach_pkt_monitor, 2100
[ 2.590431] dhd_bus_devreset: == Power OFF ==
[ 2.590653] dhd_bus_stop: making DHD_BUS_DOWN
[ 2.590694] bcmsdh_oob_intr_unregister: Enter
[ 2.590710] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.590734] dhd_bus_devreset: making dhdpub up FALSE
[ 2.590751] dhd_txglom_enable: enable 0
[ 2.590765] dhd_bus_devreset: making DHD_BUS_DOWN
[ 2.590779] dhd_bus_devreset: WLAN OFF DONE
[ 2.590823] wifi_platform_set_power = 0, delay: 0 msec
[ 2.590843] ======== PULL WL_REG_ON(-1) LOW! ========
[ 2.590858] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.590892] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 2.590902] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 2.590909] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 2.590923] dhdsdio_probe : the lock is released.
[ 2.592657] dhd_module_init: Exit err=0
[ 2.593573] ==gsl_ts_init==
[ 2.593715] ret=0
[ 2.596096] iommu: Adding device fde40000.npu to group 0
[ 2.596170] RKNPU fde40000.npu: Linked as a consumer to fde4b000.iommu
[ 2.597278] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 2.597381] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[ 2.597557] RKNPU fde40000.npu: Linked as a consumer to regulator.22
[ 2.597587] RKNPU fde40000.npu: Looking up mem-supply from device tree
[ 2.597601] RKNPU fde40000.npu: Looking up mem-supply property in node /npu@fde40000 failed
[ 2.597686] RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff]
[ 2.598838] [drm] Initialized rknpu 0.7.2 20220428 for fde40000.npu on minor 1
[ 2.599013] RKNPU fde40000.npu: leakage=3
[ 2.599071] RKNPU fde40000.npu: pvtm = 85930, from nvmem
[ 2.599090] RKNPU fde40000.npu: pvtm-volt-sel=1
[ 2.599877] RKNPU fde40000.npu: avs=0
[ 2.600693] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 2.600764] RKNPU fde40000.npu: failed to find power_model node
[ 2.600779] RKNPU fde40000.npu: RKNPU: failed to initialize power model
[ 2.600794] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient
[ 2.604067] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.613872] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.614104] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.614129] cfg80211: failed to load regulatory.db
[ 2.616799] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 2.619541] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '05:56:57', on 'Sep 22 2022'.
[ 2.620410] Mali:
[ 2.620414] Mali device driver loaded
[ 2.620966] xc7160 4-001b: T-chip firefly camera driver version: 00.01.02
[ 2.621662] xc7160 4-001b: Failed to get power-gpios, maybe no use
[ 2.624179] xc7160 4-001b: Looking up avdd-supply from device tree
[ 2.624197] xc7160 4-001b: Looking up avdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.624268] xc7160 4-001b: 4-001b supply avdd not found, using dummy regulator
[ 2.624410] xc7160 4-001b: Linked as a consumer to regulator.0
[ 2.624430] xc7160 4-001b: Looking up dovdd-supply from device tree
[ 2.624440] xc7160 4-001b: Looking up dovdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.624479] xc7160 4-001b: 4-001b supply dovdd not found, using dummy regulator
[ 2.624573] xc7160 4-001b: Looking up dvdd-supply from device tree
[ 2.624583] xc7160 4-001b: Looking up dvdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.624612] xc7160 4-001b: 4-001b supply dvdd not found, using dummy regulator
[ 2.624717] xc7160 4-001b: could not get default pinstate
[ 2.624736] xc7160 4-001b: could not get sleep pinstate
[ 2.624769] xc7160 4-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 2.624785] xc7160 4-001b: xc7160 num data lanes is 4
[ 2.641916] xc7160 4-001b: write XC7160_REG_HIGH_SELECT failed
[ 2.643115] xc7160: probe of 4-001b failed with error -5
[ 2.643257] rkisp rkisp-vir0: clear unready subdev num: 4
[ 2.643283] rockchip-csi2-dphy0: No link between dphy and sensor
[ 2.643952] rockchip-csi2-dphy0: No link between dphy and sensor
[ 2.643969] rkisp-vir0: update sensor failed
[ 2.652673] ret 1024 0
[ 2.653936] ALSA device list:
[ 2.653999] #0: rockchip,hdmi
[ 2.654024] #1: rockchip,rk809-codec
[ 2.661520] Freeing unused kernel memory: 1600K
[ 2.671908] Run /init as init process
[ 2.720864] phy phy-fe8a0000.usb2-phy.1: charger = USB_SDP_CHARGER
[ 2.885252] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 3.811578] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 3.901799] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 4.079466] EXT4-fs (mmcblk0p7): recovery complete
[ 4.080215] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 4.202048] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 4.409684] systemd[1]: System time before build time, advancing clock.
[ 4.437807] systemd[1]: Failed to find module 'autofs4'
[ 4.479358] systemd[1]: systemd 245.4-4ubuntu3.18 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 4.481211] systemd[1]: Detected architecture arm64.
[ 4.494328] systemd[1]: Set hostname to <ThingsWise-iEOS>.
[ 4.496472] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 4.497041] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 4.820564] systemd[1]: Configuration file /etc/systemd/system/usbdevice.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.820646] systemd[1]: Configuration file /etc/systemd/system/usbdevice.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 4.821465] systemd[1]: /etc/systemd/system/usbdevice.service:3: Failed to add dependency on dnsmasq, ignoring: Invalid argument
[ 4.898836] systemd[1]: Created slice system-getty.slice.
[ 4.902000] systemd[1]: Created slice system-modprobe.slice.
[ 4.904832] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 4.907934] systemd[1]: Created slice User and Session Slice.
[ 4.909202] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.910358] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.911169] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[ 4.911306] systemd[1]: Reached target Local Encrypted Volumes.
[ 4.911648] systemd[1]: Reached target Paths.
[ 4.911852] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 4.912042] systemd[1]: Reached target Remote File Systems.
[ 4.912547] systemd[1]: Reached target Slices.
[ 4.912958] systemd[1]: Reached target Swap.
[ 4.913847] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.915940] systemd[1]: Listening on Journal Audit Socket.
[ 4.917280] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.918631] systemd[1]: Listening on Journal Socket.
[ 4.920085] systemd[1]: Listening on udev Control Socket.
[ 4.921191] systemd[1]: Listening on udev Kernel Socket.
[ 4.927958] systemd[1]: Mounting Huge Pages File System...
[ 4.935938] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.945505] systemd[1]: Mounting Kernel Debug File System...
[ 4.955175] systemd[1]: Mounting Kernel Trace File System...
[ 4.966796] systemd[1]: Starting Journal Service...
[ 4.978737] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 4.988017] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 4.989766] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 4.998361] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 5.009282] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 5.019217] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 5.020882] systemd[1]: Condition check resulted in Load Kernel Module ramoops being skipped.
[ 5.024801] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 5.037281] systemd[1]: Starting Load Kernel Modules...
[ 5.047205] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.056683] systemd[1]: Starting udev Coldplug all Devices...
[ 5.065047] systemd[1]: Mounted Huge Pages File System.
[ 5.066805] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.068662] systemd[1]: Mounted Kernel Debug File System.
[ 5.070368] systemd[1]: Mounted Kernel Trace File System.
[ 5.075743] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 5.078609] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[ 5.080345] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[ 5.082635] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[ 5.084394] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 5.086535] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[ 5.088360] systemd[1]: Finished Load Kernel Module pstore_blk.
[ 5.090506] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[ 5.093171] systemd[1]: Finished Load Kernel Module pstore_zone.
[ 5.097317] systemd[1]: Finished Load Kernel Modules.
[ 5.101296] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 5.108040] systemd[1]: Mounting FUSE Control File System...
[ 5.113829] systemd[1]: Mounting Kernel Configuration File System...
[ 5.116211] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 5.122979] systemd[1]: Starting Platform Persistent Storage Archival...
[ 5.128780] systemd[1]: Starting Load/Save Random Seed...
[ 5.134250] systemd[1]: Starting Apply Kernel Variables...
[ 5.141015] systemd[1]: Starting Create System Users...
[ 5.146894] systemd[1]: Mounted FUSE Control File System.
[ 5.148374] systemd[1]: Mounted Kernel Configuration File System.
[ 5.179237] systemd[1]: Finished Platform Persistent Storage Archival.
[ 5.186905] systemd[1]: Finished Load/Save Random Seed.
[ 5.202619] systemd[1]: Finished Apply Kernel Variables.
[ 5.206712] systemd[1]: Finished Create System Users.
[ 5.212067] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 5.251471] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 5.252710] systemd[1]: Reached target Local File Systems (Pre).
[ 5.253106] systemd[1]: Reached target Local File Systems.
[ 5.253646] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 5.253779] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 5.258346] systemd[1]: Starting udev Kernel Device Manager...
[ 5.385942] systemd[1]: Started udev Kernel Device Manager.
[ 5.509321] systemd[1]: Started Journal Service.
[ 5.541675] systemd-journald[372]: Received client request to flush runtime journal.
[ 5.546969] systemd-journald[372]: File /var/log/journal/37d3d677b87042e4ade1206eb07af6d2/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.925224] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 6.189296] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.189720] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.190343] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.190537] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.812355] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.812915] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.813654] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.813898] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.938644] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x1
[ 6.952982] using random self ethernet address
[ 6.952992] using random host ethernet address
[ 7.336871] [BT_RFKILL]: bt shut off power
[ 7.626136] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.626331] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.626378] Generic PHY stmmac-1:00: [phy_probe-1992] led_status_value = 0x6940
[ 7.627644] Generic PHY stmmac-1:00: phy_rtl8211f_led_fixup
[ 7.657223] Generic PHY stmmac-1:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-1:00, irq=POLL)
[ 7.658622] dwmac4: Master AXI performs any burst length
[ 7.658651] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[ 7.658679] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 7.658965] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[ 7.659470] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.659481] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.659788] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.687708] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 7.687877] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.687921] Generic PHY stmmac-0:00: [phy_probe-1992] led_status_value = 0x6940
[ 7.689220] Generic PHY stmmac-0:00: phy_rtl8211f_led_fixup
[ 7.710072] Generic PHY stmmac-0:00: phy_rtl8211f_led_fixup
[ 7.731290] Generic PHY stmmac-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 7.742611] dwmac4: Master AXI performs any burst length
[ 7.742635] rk_gmac-dwmac fe2a0000.ethernet eth1: No Safety Features support found
[ 7.742657] rk_gmac-dwmac fe2a0000.ethernet eth1: IEEE 1588-2008 Advanced Timestamp supported
[ 7.742940] rk_gmac-dwmac fe2a0000.ethernet eth1: registered PTP clock
[ 7.743561] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 7.743575] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.759198] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.759353] dhd_open: Enter wlan0
[ 7.759355] dhd_open : no mutex held. set lock
[ 7.759362]
[ 7.759376] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 7.759408] wifi_platform_set_power = 1, delay: 200 msec
[ 7.759413] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 7.759416] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 7.759420] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 7.759423] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 7.952103] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 8.065189] sdio_reset_comm():
[ 8.185593] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 8.202792] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 8.236654] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 8.239287] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 8.241899] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 8.246649] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 8.347554] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 8.359748] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 266
[ 8.359890] sdioh_start: set sd_f2_blocksize 256
[ 8.360486]
dhd_bus_devreset: == Power ON ==
[ 8.360693] F1 signature read @0x18000000=0x1042aae8
[ 8.369010] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 8.370447] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 8.370597] dhd_bus_devreset: making DHD_BUS_DOWN
[ 8.370694] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 8.371300] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 8.371428] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 8.371456] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 8.371479] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 8.371500] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 8.372374] dhdsdio_download_code_file: Open firmware file failed /vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 8.372379] _dhdsdio_download_firmware: dongle image file download failed
[ 8.372419] dhd_bus_devreset Failed to download binary to the dongle
[ 8.372439] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 8.372456] dhd_dbg_detach_pkt_monitor, 2100
[ 8.372468] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 8.372514] wifi_platform_set_power = 0, delay: 0 msec
[ 8.372524] ======== PULL WL_REG_ON(-1) LOW! ========
[ 8.372530] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 8.372558] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 8.372562] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 8.372566] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 8.372571] [dhd-wlan0] wl_android_wifi_on : Failed
[ 8.372591] dhd_open : wl_android_wifi_on failed (-35)
[ 8.372601] dhd_stop: Enter wlan0
[ 8.372612] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 8.372636] dhd_dbg_detach_pkt_monitor, 2100
[ 8.372645] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 8.372673] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 8.372681] wifi_platform_set_power = 0, delay: 0 msec
[ 8.372688] ======== PULL WL_REG_ON(-1) LOW! ========
[ 8.372692] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 8.372699] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 8.372703] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 8.372705] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 8.372708] [dhd-wlan0] wl_android_wifi_off : out
[ 8.398602] dhd_stop: Exit wlan0
[ 8.398615] dhd_open : the lock is released.
[ 8.398619] dhd_open: Exit wlan0 ret=-1
[ 8.398624] Failed to open primary dev ret -1
[ 8.398867] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.399793] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.399903] usb0: HOST MAC 3a:62:b4:fc:b8:17
[ 8.399907] usb0: MAC 8a:ac:1c:b0:f8:c6
[ 8.461660] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 8.463523] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.464271] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.470315] IPv6: ADDRCONF(NETDEV_UP): lan: link is not ready
[ 8.470554] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.471023] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.540112] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.554157] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.554589] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.554955] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.555298] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.555522] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.555766] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.555990] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.556199] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.556353] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.556483] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.557162] dhd_open: Enter wlan0
[ 8.557167] dhd_open : no mutex held. set lock
[ 8.557177]
[ 8.557191] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 8.557230] wifi_platform_set_power = 1, delay: 200 msec
[ 8.557236] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 8.557240] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 8.557243] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 8.557246] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 8.652142] dwc3 fcc00000.dwc3: device reset
[ 8.673012] rk_gmac-dwmac fe010000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 8.782992] dwc3 fcc00000.dwc3: device reset
[ 8.783118] android_work: did not send uevent (0 0 (null))
[ 8.862301] sdio_reset_comm():
[ 8.928916] android_work: sent uevent USB_STATE=CONNECTED
[ 8.931557] configfs-gadget gadget: high-speed config #1: b
[ 8.932291] android_work: sent uevent USB_STATE=CONFIGURED
[ 8.968546] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 8.981995] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 8.999329] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 9.029374] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 9.031432] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 9.033621] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 9.037351] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 9.153989] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 9.181447] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 267
[ 9.181674] sdioh_start: set sd_f2_blocksize 256
[ 9.183341]
[ 9.183945] F1 signature read @0x18000000=0x1042aae8
[ 9.200482] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 9.203497] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 9.203733] dhd_bus_devreset: making DHD_BUS_DOWN
[ 9.203914] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 9.204622] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 9.204746] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 9.204776] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 9.204801] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 9.204824] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 9.206874] dhdsdio_download_code_file: Open firmware file failed /vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 9.206889] _dhdsdio_download_firmware: dongle image file download failed
[ 9.207022] dhd_bus_devreset Failed to download binary to the dongle
[ 9.207061] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 9.207093] dhd_dbg_detach_pkt_monitor, 2100
[ 9.207114] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 9.207317] wifi_platform_set_power = 0, delay: 0 msec
[ 9.207341] ======== PULL WL_REG_ON(-1) LOW! ========
[ 9.207352] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 9.207400] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 9.207411] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 9.207421] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 9.207431] [dhd-wlan0] wl_android_wifi_on : Failed
[ 9.207503] dhd_open : wl_android_wifi_on failed (-35)
[ 9.207524] dhd_stop: Enter wlan0
[ 9.207547] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 9.207594] dhd_dbg_detach_pkt_monitor, 2100
[ 9.207614] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 9.207731] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 9.207749] wifi_platform_set_power = 0, delay: 0 msec
[ 9.207768] ======== PULL WL_REG_ON(-1) LOW! ========
[ 9.207777] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 9.207796] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 9.207804] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 9.207813] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 9.207821] [dhd-wlan0] wl_android_wifi_off : out
[ 9.208339] dhd_stop: Exit wlan0
[ 9.208353] dhd_open : the lock is released.
[ 9.208362] dhd_open: Exit wlan0 ret=-1
[ 9.208373] Failed to open primary dev ret -1
[ 9.209990] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 9.210592] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 9.210810] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.211323] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 9.216274] dhd_open: Enter wlan0
[ 9.216288] dhd_open : no mutex held. set lock
[ 9.216308]
[ 9.216333] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 9.216429] wifi_platform_set_power = 1, delay: 200 msec
[ 9.216438] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 9.216442] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 9.216448] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 9.216452] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 9.522036] sdio_reset_comm():
[ 9.642233] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 9.659416] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 9.691823] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 9.693965] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 9.817594] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 9.823577] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 266
[ 9.823654] sdioh_start: set sd_f2_blocksize 256
[ 9.823965]
[ 9.824128] F1 signature read @0x18000000=0x1042aae8
[ 9.828529] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 9.829321] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 9.829392] dhd_bus_devreset: making DHD_BUS_DOWN
[ 9.829442] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 9.829677] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 9.829747] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 9.829756] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 9.829764] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 9.829771] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 9.830215] dhdsdio_download_code_file: Open firmware file failed /vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 9.830219] _dhdsdio_download_firmware: dongle image file download failed
[ 9.830255] dhd_bus_devreset Failed to download binary to the dongle
[ 9.830271] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 9.830286] dhd_dbg_detach_pkt_monitor, 2100
[ 9.830294] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 9.830354] wifi_platform_set_power = 0, delay: 0 msec
[ 9.830361] ======== PULL WL_REG_ON(-1) LOW! ========
[ 9.830366] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 9.830393] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 9.830397] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 9.830399] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 9.830407] [dhd-wlan0] wl_android_wifi_on : Failed
[ 9.830427] dhd_open : wl_android_wifi_on failed (-35)
[ 9.830433] dhd_stop: Enter wlan0
[ 9.830444] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 9.830458] dhd_dbg_detach_pkt_monitor, 2100
[ 9.830463] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 9.830495] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 9.830499] wifi_platform_set_power = 0, delay: 0 msec
[ 9.830507] ======== PULL WL_REG_ON(-1) LOW! ========
[ 9.830509] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 9.830515] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 9.830517] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 9.830519] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 9.830521] [dhd-wlan0] wl_android_wifi_off : out
[ 9.872166] dhd_stop: Exit wlan0
[ 9.872190] dhd_open : the lock is released.
[ 9.872203] dhd_open: Exit wlan0 ret=-1
[ 9.872214] Failed to open primary dev ret -1
[ 9.880174] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 9.908642] usb 5-1.3: new high-speed USB device number 3 using xhci-hcd
[ 9.915255] lan: port 1(eth0) entered blocking state
[ 9.915270] lan: port 1(eth0) entered disabled state
[ 9.915468] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 9.915762] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 9.916175] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 9.916210] device eth0 entered promiscuous mode
[ 9.916547] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 9.916684] lan: port 1(eth0) entered blocking state
[ 9.916692] lan: port 1(eth0) entered listening state
[ 9.916975] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 9.918786] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 9.919269] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 9.978537] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 10.031879] usb 5-1.3: New USB device found, idVendor=2c7c, idProduct=0125, bcdDevice= 3.18
[ 10.031888] usb 5-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.031891] usb 5-1.3: Product: Android
[ 10.031895] usb 5-1.3: Manufacturer: Android
[ 10.188236] option 5-1.3:1.0: GSM modem (1-port) converter detected
[ 10.188999] usb 5-1.3: GSM modem (1-port) converter now attached to ttyUSB0
[ 10.190738] option 5-1.3:1.1: GSM modem (1-port) converter detected
[ 10.194137] usb 5-1.3: GSM modem (1-port) converter now attached to ttyUSB1
[ 10.196006] option 5-1.3:1.2: GSM modem (1-port) converter detected
[ 10.199093] usb 5-1.3: GSM modem (1-port) converter now attached to ttyUSB2
[ 10.200820] option 5-1.3:1.3: GSM modem (1-port) converter detected
[ 10.204017] usb 5-1.3: GSM modem (1-port) converter now attached to ttyUSB3
[ 10.252184] qmi_wwan_q 5-1.3:1.4: cdc-wdm0: USB WDM device
[ 10.252197] qmi_wwan_q 5-1.3:1.4: Quectel EC25&EC21&EG91&EG95&EG06&EP06&EM06&EG12&EP12&EM12&EG16&EG18&BG96&AG35 work on RawIP mode
[ 10.252388] qmi_wwan_q 5-1.3:1.4: rx_urb_size = 1520
[ 10.252462] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.253171] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.253347] qmi_wwan_q 5-1.3:1.4 wwan0: register 'qmi_wwan_q' at usb-xhci-hcd.4.auto-1.3, WWAN/QMI device, 02:ad:fa:67:b9:8b
[ 10.292596] qmi_wwan_q 5-1.3:1.4 wwx02adfa67b98b: renamed from wwan0
[ 10.316731] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.991985] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 11.212871] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2
[ 11.235263] fbcon: Taking over console
[ 11.236093] Console: switching to colour frame buffer device 240x67
[ 11.238586] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.239075] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.239515] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.254783] Freeing drm_logo memory: 812K
[ 11.425234] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.425793] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.537172] lan: port 2(usb0) entered blocking state
[ 11.537185] lan: port 2(usb0) entered disabled state
[ 11.537249] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.537452] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.537956] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.537995] device usb0 entered promiscuous mode
[ 11.538329] lan: port 2(usb0) entered blocking state
[ 11.538336] lan: port 2(usb0) entered listening state
[ 11.538820] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.540120] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.540819] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 12.005123] rk-pcie 3c0800000.pcie: PCIe Link Fail
[ 12.005173] rk-pcie 3c0800000.pcie: failed to initialize host
[ 14.578299] Bridge firewalling registered
[ 14.821947] Initializing XFRM netlink socket
[ 14.848372] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 14.849119] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 14.992961] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 14.993267] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 14.993274] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 20.029273] dhd_open: Enter wlan0
[ 20.029288] dhd_open : no mutex held. set lock
[ 20.029309]
[ 20.029349] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 20.029435] wifi_platform_set_power = 1, delay: 200 msec
[ 20.029453] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 20.029460] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 20.029468] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 20.029476] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 20.335415] sdio_reset_comm():
[ 20.455578] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 20.472823] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 20.502495] sdio_read_cis: 2 callbacks suppressed
[ 20.502506] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 20.504486] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 20.506628] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 20.510207] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 20.618782] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 20.630876] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 268
[ 20.631009] sdioh_start: set sd_f2_blocksize 256
[ 20.631600]
[ 20.632104] F1 signature read @0x18000000=0x1042aae8
[ 20.640074] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 20.641497] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 20.641647] dhd_bus_devreset: making DHD_BUS_DOWN
[ 20.641909] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 20.642222] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 20.642293] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 20.642304] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 20.642314] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 20.642322] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 20.642682] dhdsdio_download_code_file: Open firmware file failed /vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 20.642687] _dhdsdio_download_firmware: dongle image file download failed
[ 20.642725] dhd_bus_devreset Failed to download binary to the dongle
[ 20.642742] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 20.642758] dhd_dbg_detach_pkt_monitor, 2100
[ 20.642769] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 20.642810] wifi_platform_set_power = 0, delay: 0 msec
[ 20.642820] ======== PULL WL_REG_ON(-1) LOW! ========
[ 20.642826] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 20.642854] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 20.642858] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 20.642861] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 20.642866] [dhd-wlan0] wl_android_wifi_on : Failed
[ 20.642881] dhd_open : wl_android_wifi_on failed (-35)
[ 20.642889] dhd_stop: Enter wlan0
[ 20.642898] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 20.642922] dhd_dbg_detach_pkt_monitor, 2100
[ 20.642931] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 20.642958] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 20.642966] wifi_platform_set_power = 0, delay: 0 msec
[ 20.642973] ======== PULL WL_REG_ON(-1) LOW! ========
[ 20.642977] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 20.642986] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 20.642990] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 20.642994] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 20.642997] [dhd-wlan0] wl_android_wifi_off : out
[ 20.668671] dhd_stop: Exit wlan0
[ 20.668682] dhd_open : the lock is released.
[ 20.668686] dhd_open: Exit wlan0 ret=-1
[ 20.668690] Failed to open primary dev ret -1
[ 20.670619] dhd_open: Enter wlan0
[ 20.670628] dhd_open : no mutex held. set lock
[ 20.670645]
[ 20.670669] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 20.670728] wifi_platform_set_power = 1, delay: 200 msec
[ 20.670738] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 20.670742] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 20.670748] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 20.670755] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 20.975421] sdio_reset_comm():
[ 21.095478] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 21.112504] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 21.138218] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 21.140284] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 21.142186] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 21.145301] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 21.245362] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 21.255114] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 267
[ 21.255217] sdioh_start: set sd_f2_blocksize 256
[ 21.255672]
[ 21.255928] F1 signature read @0x18000000=0x1042aae8
[ 21.262390] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 21.263651] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 21.263752] dhd_bus_devreset: making DHD_BUS_DOWN
[ 21.263822] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 21.264136] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 21.264209] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 21.264220] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 21.264230] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 21.264241] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 21.264898] dhdsdio_download_code_file: Open firmware file failed /vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 21.264904] _dhdsdio_download_firmware: dongle image file download failed
[ 21.265000] dhd_bus_devreset Failed to download binary to the dongle
[ 21.265016] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 21.265029] dhd_dbg_detach_pkt_monitor, 2100
[ 21.265038] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 21.265211] wifi_platform_set_power = 0, delay: 0 msec
[ 21.265223] ======== PULL WL_REG_ON(-1) LOW! ========
[ 21.265230] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 21.265256] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 21.265260] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 21.265264] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 21.265269] [dhd-wlan0] wl_android_wifi_on : Failed
[ 21.265297] dhd_open : wl_android_wifi_on failed (-35)
[ 21.265314] dhd_stop: Enter wlan0
[ 21.265324] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 21.265343] dhd_dbg_detach_pkt_monitor, 2100
[ 21.265353] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 21.265399] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 21.265407] wifi_platform_set_power = 0, delay: 0 msec
[ 21.265414] ======== PULL WL_REG_ON(-1) LOW! ========
[ 21.265417] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 21.265426] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 21.265429] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 21.265432] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 21.265436] [dhd-wlan0] wl_android_wifi_off : out
[ 21.292106] dhd_stop: Exit wlan0
[ 21.292122] dhd_open : the lock is released.
[ 21.292131] dhd_open: Exit wlan0 ret=-1
[ 21.292137] Failed to open primary dev ret -1
[ 25.231891] lan: port 1(eth0) entered learning state
[ 26.938551] lan: port 2(usb0) entered learning state
[ 32.037108] dhd_open: Enter wlan0
[ 32.037126] dhd_open : no mutex held. set lock
[ 32.037155]
[ 32.037207] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 32.037308] wifi_platform_set_power = 1, delay: 200 msec
[ 32.037329] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 32.037340] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 32.037351] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 32.037363] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 32.342018] sdio_reset_comm():
[ 32.462176] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 32.479408] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 32.508658] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 32.510625] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 32.512600] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 32.515895] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 32.633437] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 32.661485] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 266
[ 32.661704] sdioh_start: set sd_f2_blocksize 256
[ 32.663335]
[ 32.663942] F1 signature read @0x18000000=0x1042aae8
[ 32.675223] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 32.676371] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 32.676466] dhd_bus_devreset: making DHD_BUS_DOWN
[ 32.676535] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 32.676829] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 32.676889] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 32.676900] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 32.676910] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 32.676919] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 32.677526] dhdsdio_download_code_file: Open firmware file failed /vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 32.677530] _dhdsdio_download_firmware: dongle image file download failed
[ 32.677577] dhd_bus_devreset Failed to download binary to the dongle
[ 32.677591] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 32.677605] dhd_dbg_detach_pkt_monitor, 2100
[ 32.677615] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 32.677689] wifi_platform_set_power = 0, delay: 0 msec
[ 32.677698] ======== PULL WL_REG_ON(-1) LOW! ========
[ 32.677703] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 32.677727] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 32.677732] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 32.677735] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 32.677740] [dhd-wlan0] wl_android_wifi_on : Failed
[ 32.677764] dhd_open : wl_android_wifi_on failed (-35)
[ 32.677774] dhd_stop: Enter wlan0
[ 32.677784] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 32.677802] dhd_dbg_detach_pkt_monitor, 2100
[ 32.677809] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 32.677850] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 32.677858] wifi_platform_set_power = 0, delay: 0 msec
[ 32.677866] ======== PULL WL_REG_ON(-1) LOW! ========
[ 32.677869] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 32.677876] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 32.677879] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 32.677882] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 32.677885] [dhd-wlan0] wl_android_wifi_off : out
[ 32.718554] dhd_stop: Exit wlan0
[ 32.718566] dhd_open : the lock is released.
[ 32.718570] dhd_open: Exit wlan0 ret=-1
[ 32.718575] Failed to open primary dev ret -1
[ 32.720437] dhd_open: Enter wlan0
[ 32.720448] dhd_open : no mutex held. set lock
[ 32.720464]
[ 32.720485] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 32.720550] wifi_platform_set_power = 1, delay: 200 msec
[ 32.720560] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 32.720565] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 32.720571] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 32.720576] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 33.025367] sdio_reset_comm():
[ 33.145530] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 33.162735] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 33.192284] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 33.194392] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 33.196472] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 33.199843] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 33.314598] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 33.338793] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 267
[ 33.339006] sdioh_start: set sd_f2_blocksize 256
[ 33.340165]
[ 33.340746] F1 signature read @0x18000000=0x1042aae8
[ 33.357007] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 33.360079] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 33.360322] dhd_bus_devreset: making DHD_BUS_DOWN
[ 33.360507] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 33.361194] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 33.361309] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 33.361338] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 33.361364] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 33.361387] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 33.363223] dhdsdio_download_code_file: Open firmware file failed /vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 33.363236] _dhdsdio_download_firmware: dongle image file download failed
[ 33.363372] dhd_bus_devreset Failed to download binary to the dongle
[ 33.363405] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 33.363435] dhd_dbg_detach_pkt_monitor, 2100
[ 33.363455] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 33.363670] wifi_platform_set_power = 0, delay: 0 msec
[ 33.363693] ======== PULL WL_REG_ON(-1) LOW! ========
[ 33.363704] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 33.363748] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 33.363758] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 33.363767] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 33.363777] [dhd-wlan0] wl_android_wifi_on : Failed
[ 33.363839] dhd_open : wl_android_wifi_on failed (-35)
[ 33.363872] dhd_stop: Enter wlan0
[ 33.363894] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 33.363942] dhd_dbg_detach_pkt_monitor, 2100
[ 33.363962] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 33.364082] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 33.364102] wifi_platform_set_power = 0, delay: 0 msec
[ 33.364122] ======== PULL WL_REG_ON(-1) LOW! ========
[ 33.364131] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 33.364151] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 33.364160] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 33.364168] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 33.364175] [dhd-wlan0] wl_android_wifi_off : out
[ 33.364676] dhd_stop: Exit wlan0
[ 33.364688] dhd_open : the lock is released.
[ 33.364698] dhd_open: Exit wlan0 ret=-1
[ 33.364707] Failed to open primary dev ret -1
[ 33.765393] vcc5v0_otg: disabling
[ 33.765416] vcc3v3_lcd0_n: disabling
[ 33.765429] vcc3v3_lcd1_n: disabling
[ 33.765455] pcie30_3v3: disabling
[ 37.541899] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 37.542301] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 37.542619] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 40.592000] lan: port 1(eth0) entered forwarding state
[ 40.592067] lan: topology change detected, propagating
[ 40.592541] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 40.596924] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 40.642790] dwc3 fcc00000.dwc3: device disconnect
[ 40.643450] android_work: sent uevent USB_STATE=DISCONNECTED
[ 41.232931] android_work: did not send uevent (0 0 (null))
[ 41.605696] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 41.605752] lan: port 2(usb0) entered disabled state
[ 42.891371] phy phy-fe8a0000.usb2-phy.1: charger = USB_SDP_CHARGER
[ 43.147249] dwc3 fcc00000.dwc3: device reset
[ 43.277994] dwc3 fcc00000.dwc3: device reset
[ 43.278111] android_work: did not send uevent (0 0 (null))
[ 43.424227] android_work: sent uevent USB_STATE=CONNECTED
[ 43.426109] configfs-gadget gadget: high-speed config #1: b
[ 43.426673] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 43.426706] lan: port 2(usb0) entered blocking state
[ 43.426716] lan: port 2(usb0) entered listening state
[ 43.427360] android_work: sent uevent USB_STATE=CONFIGURED
[ 44.032068] dhd_open: Enter wlan0
[ 44.032089] dhd_open : no mutex held. set lock
[ 44.032117]
[ 44.032167] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 44.032259] wifi_platform_set_power = 1, delay: 200 msec
[ 44.032282] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 44.032293] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 44.032304] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 44.032314] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 44.338680] sdio_reset_comm():
[ 44.460298] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 44.476528] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 44.508304] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 44.510839] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 44.512751] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 44.516473] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 44.631473] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 44.642474] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 267
[ 44.642605] sdioh_start: set sd_f2_blocksize 256
[ 44.643197]
[ 44.643495] F1 signature read @0x18000000=0x1042aae8
[ 44.651633] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 44.653216] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 44.653369] dhd_bus_devreset: making DHD_BUS_DOWN
[ 44.653468] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 44.653870] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 44.653991] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 44.654022] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 44.654045] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 44.654067] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 44.654882] dhdsdio_download_code_file: Open firmware file failed /vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 44.654894] _dhdsdio_download_firmware: dongle image file download failed
[ 44.654974] dhd_bus_devreset Failed to download binary to the dongle
[ 44.655006] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 44.655036] dhd_dbg_detach_pkt_monitor, 2100
[ 44.655242] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 44.655359] wifi_platform_set_power = 0, delay: 0 msec
[ 44.655382] ======== PULL WL_REG_ON(-1) LOW! ========
[ 44.655395] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 44.655448] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 44.655457] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 44.655467] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 44.655477] [dhd-wlan0] wl_android_wifi_on : Failed
[ 44.655517] dhd_open : wl_android_wifi_on failed (-35)
[ 44.655525] dhd_stop: Enter wlan0
[ 44.655535] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 44.655556] dhd_dbg_detach_pkt_monitor, 2100
[ 44.655571] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 44.655599] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 44.655606] wifi_platform_set_power = 0, delay: 0 msec
[ 44.655613] ======== PULL WL_REG_ON(-1) LOW! ========
[ 44.655616] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 44.655625] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 44.655628] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 44.655631] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 44.655634] [dhd-wlan0] wl_android_wifi_off : out
[ 44.695220] dhd_stop: Exit wlan0
[ 44.695233] dhd_open : the lock is released.
[ 44.695236] dhd_open: Exit wlan0 ret=-1
[ 44.695243] Failed to open primary dev ret -1
[ 44.697242] dhd_open: Enter wlan0
[ 44.697251] dhd_open : no mutex held. set lock
[ 44.697267]
[ 44.697289] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 44.697354] wifi_platform_set_power = 1, delay: 200 msec
[ 44.697363] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 44.697367] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 44.697375] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 44.697380] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 45.002123] sdio_reset_comm():
[ 45.122245] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 45.139556] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 45.170650] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 45.172822] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 45.174703] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 45.178545] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 45.282385] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 45.335033] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 266
[ 45.335463] sdioh_start: set sd_f2_blocksize 256
[ 45.337468]
[ 45.338763] F1 signature read @0x18000000=0x1042aae8
[ 45.367434] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 45.369171] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 45.369326] dhd_bus_devreset: making DHD_BUS_DOWN
[ 45.369426] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 45.369840] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 45.369979] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 45.370010] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 45.370034] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 45.370054] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 45.370891] dhdsdio_download_code_file: Open firmware file failed /vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 45.370903] _dhdsdio_download_firmware: dongle image file download failed
[ 45.370986] dhd_bus_devreset Failed to download binary to the dongle
[ 45.371029] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 45.371059] dhd_dbg_detach_pkt_monitor, 2100
[ 45.371078] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 45.371179] wifi_platform_set_power = 0, delay: 0 msec
[ 45.371202] ======== PULL WL_REG_ON(-1) LOW! ========
[ 45.371212] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 45.371252] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 45.371261] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 45.371271] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 45.371281] [dhd-wlan0] wl_android_wifi_on : Failed
[ 45.371347] dhd_open : wl_android_wifi_on failed (-35)
[ 45.371367] dhd_stop: Enter wlan0
[ 45.371388] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 45.371434] dhd_dbg_detach_pkt_monitor, 2100
[ 45.371455] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 45.371527] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 45.371546] wifi_platform_set_power = 0, delay: 0 msec
[ 45.371565] ======== PULL WL_REG_ON(-1) LOW! ========
[ 45.371574] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 45.371591] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 45.371600] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 45.371608] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 45.371616] [dhd-wlan0] wl_android_wifi_off : out
[ 45.372318] dhd_stop: Exit wlan0
[ 45.372332] dhd_open : the lock is released.
[ 45.372342] dhd_open: Exit wlan0 ret=-1
[ 45.372351] Failed to open primary dev ret -1
[ 56.032654] dhd_open: Enter wlan0
[ 56.032673] dhd_open : no mutex held. set lock
[ 56.032701]
[ 56.032753] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 56.032850] wifi_platform_set_power = 1, delay: 200 msec
[ 56.032873] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 56.032883] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 56.032894] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 56.032905] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 56.338785] sdio_reset_comm():
[ 56.458906] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 56.476029] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 56.505496] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 56.507536] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 56.509587] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 56.513454] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 56.617341] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 56.662430] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 268
[ 56.662647] sdioh_start: set sd_f2_blocksize 256
[ 56.663818]
[ 56.664405] F1 signature read @0x18000000=0x1042aae8
[ 56.680237] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 56.683253] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 56.683490] dhd_bus_devreset: making DHD_BUS_DOWN
[ 56.683666] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 56.684369] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 56.684481] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 56.684512] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 56.684534] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 56.684556] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 56.685821] dhdsdio_download_code_file: Open firmware file failed /vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 56.685827] _dhdsdio_download_firmware: dongle image file download failed
[ 56.685879] dhd_bus_devreset Failed to download binary to the dongle
[ 56.685897] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 56.685912] dhd_dbg_detach_pkt_monitor, 2100
[ 56.685920] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 56.686003] wifi_platform_set_power = 0, delay: 0 msec
[ 56.686014] ======== PULL WL_REG_ON(-1) LOW! ========
[ 56.686019] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 56.686044] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 56.686049] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 56.686052] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 56.686058] [dhd-wlan0] wl_android_wifi_on : Failed
[ 56.686087] dhd_open : wl_android_wifi_on failed (-35)
[ 56.686095] dhd_stop: Enter wlan0
[ 56.686109] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 56.686125] dhd_dbg_detach_pkt_monitor, 2100
[ 56.686132] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 56.686177] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 56.686184] wifi_platform_set_power = 0, delay: 0 msec
[ 56.686191] ======== PULL WL_REG_ON(-1) LOW! ========
[ 56.686194] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 56.686201] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 56.686205] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 56.686208] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 56.686211] [dhd-wlan0] wl_android_wifi_off : out
[ 56.725206] dhd_stop: Exit wlan0
[ 56.725216] dhd_open : the lock is released.
[ 56.725219] dhd_open: Exit wlan0 ret=-1
[ 56.725224] Failed to open primary dev ret -1
[ 56.729016] dhd_open: Enter wlan0
[ 56.729035] dhd_open : no mutex held. set lock
[ 56.729062]
Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 56.729106] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 56.729194] wifi_platform_set_power = 1, delay: 200 msec
[ 56.729216] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 56.729227] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 56.729238] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 56.729248] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 57.035338] sdio_reset_comm():
[ 57.155421] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 57.172821] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 57.203397] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 57.205339] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 57.207299] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 57.211349] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 57.326404] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 57.350406] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 266
[ 57.350615] sdioh_start: set sd_f2_blocksize 256
[ 57.351879]
[ 57.352507] F1 signature read @0x18000000=0x1042aae8
[ 57.367750] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 57.370757] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 57.370988] dhd_bus_devreset: making DHD_BUS_DOWN
[ 57.371168] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 57.371910] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 57.372031] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 57.372067] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 57.372114] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 57.372162] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 57.373832] dhdsdio_download_code_file: Open firmware file failed /vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 57.373846] _dhdsdio_download_firmware: dongle image file download failed
[ 57.374002] dhd_bus_devreset Failed to download binary to the dongle
[ 57.374037] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 57.374068] dhd_dbg_detach_pkt_monitor, 2100
[ 57.374088] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 57.374280] wifi_platform_set_power = 0, delay: 0 msec
[ 57.374304] ======== PULL WL_REG_ON(-1) LOW! ========
[ 57.374315] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 57.374360] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 57.374371] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 57.374380] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 57.374390] [dhd-wlan0] wl_android_wifi_on : Failed
[ 57.374448] dhd_open : wl_android_wifi_on failed (-35)
[ 57.374469] dhd_stop: Enter wlan0
[ 57.374490] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 57.374546] dhd_dbg_detach_pkt_monitor, 2100
[ 57.374566] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 57.374690] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 57.374709] wifi_platform_set_power = 0, delay: 0 msec
[ 57.374728] ======== PULL WL_REG_ON(-1) LOW! ========
[ 57.374737] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 57.374755] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 57.374764] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 57.374772] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 57.374782] [dhd-wlan0] wl_android_wifi_off : out
[ 57.375517] dhd_stop: Exit wlan0
[ 57.375531] dhd_open : the lock is released.
[ 57.375540] dhd_open: Exit wlan0 ret=-1
[ 57.375549] Failed to open primary dev ret -1
[ 59.365108] lan: port 2(usb0) entered learning state
[ 62.100541] systemd-journald[372]: File /var/log/journal/37d3d677b87042e4ade1206eb07af6d2/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 68.030103] dhd_open: Enter wlan0
[ 68.030116] dhd_open : no mutex held. set lock
[ 68.030135]
[ 68.030166] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 68.030234] wifi_platform_set_power = 1, delay: 200 msec
[ 68.030245] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 68.030251] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 68.030258] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 68.030265] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 68.335478] sdio_reset_comm():
[ 68.455520] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 68.472725] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 68.502820] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 68.504693] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 68.507108] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 68.511194] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 68.637394] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 68.663449] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 268
[ 68.663670] sdioh_start: set sd_f2_blocksize 256
[ 68.664820]
[ 68.665541] F1 signature read @0x18000000=0x1042aae8
[ 68.680829] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 68.683785] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 68.684012] dhd_bus_devreset: making DHD_BUS_DOWN
[ 68.684189] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 68.684865] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 68.684981] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 68.685009] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 68.685032] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 68.685206] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 68.686783] dhdsdio_download_code_file: Open firmware file failed /vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 68.686795] _dhdsdio_download_firmware: dongle image file download failed
[ 68.686924] dhd_bus_devreset Failed to download binary to the dongle
[ 68.686961] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 68.686990] dhd_dbg_detach_pkt_monitor, 2100
[ 68.687011] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 68.687199] wifi_platform_set_power = 0, delay: 0 msec
[ 68.687222] ======== PULL WL_REG_ON(-1) LOW! ========
[ 68.687233] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 68.687288] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 68.687298] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 68.687307] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 68.687318] [dhd-wlan0] wl_android_wifi_on : Failed
[ 68.687378] dhd_open : wl_android_wifi_on failed (-35)
[ 68.687399] dhd_stop: Enter wlan0
[ 68.687421] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 68.687451] dhd_dbg_detach_pkt_monitor, 2100
[ 68.687470] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 68.687579] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 68.687599] wifi_platform_set_power = 0, delay: 0 msec
[ 68.687632] ======== PULL WL_REG_ON(-1) LOW! ========
[ 68.687641] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 68.687658] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 68.687666] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 68.687674] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 68.687682] [dhd-wlan0] wl_android_wifi_off : out
[ 68.688174] dhd_stop: Exit wlan0
[ 68.688188] dhd_open : the lock is released.
[ 68.688197] dhd_open: Exit wlan0 ret=-1
[ 68.688207] Failed to open primary dev ret -1
[ 68.692464] dhd_open: Enter wlan0
[ 68.692493] dhd_open : no mutex held. set lock
[ 68.692523]
[ 68.692566] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 68.692656] wifi_platform_set_power = 1, delay: 200 msec
[ 68.692677] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 68.692687] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 68.692699] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 68.692710] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 68.998667] sdio_reset_comm():
[ 69.118611] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 69.135990] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 69.167175] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 69.169288] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 69.171173] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 69.174756] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 69.296253] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 69.326786] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 266
[ 69.327004] sdioh_start: set sd_f2_blocksize 256
[ 69.328168]
[ 69.328866] F1 signature read @0x18000000=0x1042aae8
[ 69.342967] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 69.343918] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 69.343998] dhd_bus_devreset: making DHD_BUS_DOWN
[ 69.344056] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 69.344305] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 69.344361] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 69.344371] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 69.344379] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 69.344386] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 69.344886] dhdsdio_download_code_file: Open firmware file failed /vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 69.344890] _dhdsdio_download_firmware: dongle image file download failed
[ 69.344927] dhd_bus_devreset Failed to download binary to the dongle
[ 69.344940] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 69.344953] dhd_dbg_detach_pkt_monitor, 2100
[ 69.344962] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 69.345021] wifi_platform_set_power = 0, delay: 0 msec
[ 69.345029] ======== PULL WL_REG_ON(-1) LOW! ========
[ 69.345035] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 69.345097] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 69.345101] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 69.345105] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 69.345111] [dhd-wlan0] wl_android_wifi_on : Failed
[ 69.345130] dhd_open : wl_android_wifi_on failed (-35)
[ 69.345139] dhd_stop: Enter wlan0
[ 69.345148] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 69.345159] dhd_dbg_detach_pkt_monitor, 2100
[ 69.345165] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 69.345204] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 69.345210] wifi_platform_set_power = 0, delay: 0 msec
[ 69.345217] ======== PULL WL_REG_ON(-1) LOW! ========
[ 69.345219] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 69.345229] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 69.345232] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 69.345234] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 69.345237] [dhd-wlan0] wl_android_wifi_off : out
[ 69.385184] dhd_stop: Exit wlan0
[ 69.385194] dhd_open : the lock is released.
[ 69.385197] dhd_open: Exit wlan0 ret=-1
[ 69.385201] Failed to open primary dev ret -1
原因是你的文件系统里没有wifi芯片需要的驱动
请用官方提供的文件系统,自己弄很麻烦的
了解,感谢
请用官方提供的文件系统,自己弄很麻烦的
你好,我们换上官方提供的驱动后,显示这个错误:
Operation not possible due to RF-kill"?
$ sudo ifconfig wlan0 up
[sudo] password for thingswise:
SIOCSIFFLAGS: Operation not possible due to RF-kill
以下是 dmesg
$ dmesg
[ 0.000000] Linux version 4.19.232 (thingswise@4e53d0e19fd6) (firefly: 330e82b263990b1218820d784f5a01e9c471f037) (sdk version: rk356x_linux_release_20220726_v1.3.0a.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #1 SMP Sun Oct 9 02:24:23 UTC 2022
[ 0.000000] Machine model: AIO-3568J HDMI (Linux)
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '')
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB
[ 0.000000] cma: Reserved 16 MiB at 0x00000000ef000000
[ 0.000000] On node 0 totalpages: 1043968
[ 0.000000] DMA32 zone: 15288 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 978432 pages, LIFO batch:63
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 65536 pages, LIFO batch:15
[ 0.000000] percpu: Embedded 24 pages/cpu s60136 r8192 d29976 u98304
[ 0.000000] pcpu-alloc: s60136 r8192 d29976 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1027656
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal storagenode=/sdhci@fe310000 androidboot.verifiedbootstate=orange ro rootwait earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] software IO TLB: mapped [mem 0xe9f00000-0xedf00000] (64MB)
[ 0.000000] Memory: 3968936K/4175872K available (15166K kernel code, 1956K rwdata, 5324K rodata, 1600K init, 598K bss, 190552K reserved, 16384K cma-reserved)
[ 0.000000] ftrace: allocating 54438 entries in 213 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @ee810000 (indirect, esz 8, psz 64K, shr 0)
[ 0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @ee820000 (flat, esz 2, psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x00000000ee830000
[ 0.000000] CPU0: using LPI pending table @0x00000000ee840000
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x514 with crng_init=0
[ 0.002278] Console: colour dummy device 80x25
[ 0.002742] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003693] pid_max: default: 32768 minimum: 301
[ 0.004260] Security Framework initialized
[ 0.004655] AppArmor: AppArmor disabled by boot time parameter
[ 0.005261] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.005938] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.008550] ASID allocator initialised with 32768 entries
[ 0.009228] rcu: Hierarchical SRCU implementation.
[ 0.012622] Platform MSI: interrupt-controller@fd440000 domain created
[ 0.013843] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[ 0.015502] smp: Bringing up secondary CPUs ...
[ 0.017511] Detected VIPT I-cache on CPU1
[ 0.017552] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 0.017606] CPU1: using LPI pending table @0x00000000ee850000
[ 0.017665] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.019280] Detected VIPT I-cache on CPU2
[ 0.019317] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 0.019367] CPU2: using LPI pending table @0x00000000ee860000
[ 0.019417] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 0.021085] Detected VIPT I-cache on CPU3
[ 0.021120] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 0.021174] CPU3: using LPI pending table @0x00000000ee870000
[ 0.021223] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 0.021366] smp: Brought up 1 node, 4 CPUs
[ 0.028300] SMP: Total of 4 processors activated.
[ 0.028737] CPU features: detected: GIC system register CPU interface
[ 0.029330] CPU features: detected: Privileged Access Never
[ 0.029846] CPU features: detected: LSE atomic instructions
[ 0.030360] CPU features: detected: User Access Override
[ 0.030872] CPU features: detected: 32-bit EL0 Support
[ 0.031349] CPU features: detected: RAS Extension Support
[ 0.032038] CPU: All CPU(s) started at EL2
[ 0.032447] alternatives: patching kernel code
[ 0.039959] devtmpfs: initialized
[ 0.072508] Registered cp15_barrier emulation handler
[ 0.073002] Registered setend emulation handler
[ 0.073798] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.074719] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.076212] pinctrl core: initialized pinctrl subsystem
[ 0.077053] regulator-dummy: no parameters
[ 0.077865] NET: Registered protocol family 16
[ 0.079517] audit: initializing netlink subsys (disabled)
[ 0.080289] audit: type=2000 audit(0.073:1): state=initialized audit_enabled=0 res=1
[ 0.084333] cpuidle: using governor menu
[ 0.084736] Registered FIQ tty driver
[ 0.086054] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.088239] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.092882] console [pstore-1] enabled
[ 0.093238] pstore: Registered ramoops as persistent store backend
[ 0.093809] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.137312] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio)
[ 0.138647] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[ 0.139983] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[ 0.141285] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio)
[ 0.142589] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[ 0.143325] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.161904] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.162808] cryptd: max_cpu_qlen set to 1000
[ 0.165246] console [ttyFIQ0] enabled
[ 0.165957] bootconsole [uart8250] disabled
[ 0.166634] Registered fiq debugger ttyFIQ0
[ 0.167294] dc_12v: 12000 mV
[ 0.167578] reg-fixed-voltage dc-12v: dc_12v supplying 12000000uV
[ 0.167732] reg-fixed-voltage vcc3v3-sys: Looking up vin-supply from device tree
[ 0.167747] vcc3v3_sys: supplied by dc_12v
[ 0.167828] vcc3v3_sys: 3300 mV
[ 0.168102] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[ 0.168250] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree
[ 0.168265] vcc5v0_sys: supplied by dc_12v
[ 0.168342] vcc5v0_sys: 5000 mV
[ 0.168610] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[ 0.168882] vcc5v0_host: no parameters
[ 0.169129] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[ 0.169390] vcc5v0_otg: no parameters
[ 0.169641] reg-fixed-voltage vcc5v0-otg-regulator: vcc5v0_otg supplying 0uV
[ 0.169784] vcc3v3_lcd0_n: no parameters
[ 0.170015] reg-fixed-voltage vcc3v3-lcd0-n: vcc3v3_lcd0_n supplying 0uV
[ 0.170157] vcc3v3_lcd1_n: no parameters
[ 0.170410] reg-fixed-voltage vcc3v3-lcd1-n: vcc3v3_lcd1_n supplying 0uV
[ 0.170561] reg-fixed-voltage vcc2v5-ddr: Looking up vin-supply from device tree
[ 0.170576] vcc2v5-sys: supplied by vcc3v3_sys
[ 0.170657] vcc2v5-sys: 2500 mV
[ 0.170932] reg-fixed-voltage vcc2v5-ddr: vcc2v5-sys supplying 2500000uV
[ 0.171102] reg-fixed-voltage vcc3v3-vga: Looking up vin-supply from device tree
[ 0.171115] vcc3v3_vga: supplied by vcc3v3_sys
[ 0.171199] vcc3v3_vga: at 3300 mV
[ 0.171443] reg-fixed-voltage vcc3v3-vga: vcc3v3_vga supplying 0uV
[ 0.171582] reg-fixed-voltage pcie30-avdd0v9: Looking up vin-supply from device tree
[ 0.171595] pcie30_avdd0v9: supplied by vcc3v3_sys
[ 0.171699] pcie30_avdd0v9: 900 mV
[ 0.171949] reg-fixed-voltage pcie30-avdd0v9: pcie30_avdd0v9 supplying 900000uV
[ 0.172097] reg-fixed-voltage pcie30-avdd1v8: Looking up vin-supply from device tree
[ 0.172110] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.172195] pcie30_avdd1v8: 1800 mV
[ 0.172466] reg-fixed-voltage pcie30-avdd1v8: pcie30_avdd1v8 supplying 1800000uV
[ 0.172608] reg-fixed-voltage vcc3v3-bu: Looking up vin-supply from device tree
[ 0.172622] vcc3v3_bu: supplied by vcc5v0_sys
[ 0.172729] vcc3v3_bu: 3300 mV
[ 0.172999] reg-fixed-voltage vcc3v3-bu: vcc3v3_bu supplying 3300000uV
[ 0.173284] vcc_hub_power_en: no parameters
[ 0.173530] reg-fixed-voltage vcc-hub-power-regulator: vcc_hub_power_en supplying 0uV
[ 0.173796] vcc_hub_reset_en: no parameters
[ 0.174060] reg-fixed-voltage vcc-hub-reset-regulator: vcc_hub_reset_en supplying 0uV
[ 0.174325] pcie_pi6c_oe_en: no parameters
[ 0.174577] reg-fixed-voltage pcie-pi6c-oe-regulator: pcie_pi6c_oe_en supplying 0uV
[ 0.174801] vcc_4g_power_en: no parameters
[ 0.175068] reg-fixed-voltage vcc-4g-power-regulator: vcc_4g_power_en supplying 0uV
[ 0.175722] pcie30_3v3: 100 <--> 3300 mV at 3300 mV
[ 0.176694] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_npu-supply from device tree
[ 0.176719] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_npu-supply property in node /power-management@fdd90000/power-controller failed
[ 0.176782] rk_iommu fde4b000.iommu: version = 2
[ 0.177585] rk_iommu fdea0800.iommu: version = 2
[ 0.177912] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vpu-supply from device tree
[ 0.177937] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vpu-supply property in node /power-management@fdd90000/power-controller failed
[ 0.178130] rk_iommu fded0480.iommu: version = 2
[ 0.178543] rk_iommu fdee0800.iommu: version = 2
[ 0.178919] rk_iommu fdef0800.iommu: version = 2
[ 0.179288] rk_iommu fdf40f00.iommu: version = 2
[ 0.179781] rk_iommu fdf80800.iommu: version = 2
[ 0.180169] rk_iommu fdff1a00.iommu: version = 2
[ 0.180524] rk_iommu fe043e00.iommu: version = 2
[ 0.181659] SCSI subsystem initialized
[ 0.181750] libata version 3.00 loaded.
[ 0.182029] usbcore: registered new interface driver usbfs
[ 0.182121] usbcore: registered new interface driver hub
[ 0.182202] usbcore: registered new device driver usb
[ 0.182341] media: Linux media interface: v0.10
[ 0.182410] videodev: Linux video capture interface: v2.00
[ 0.182540] pps_core: LinuxPPS API ver. 1 registered
[ 0.182567] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.182616] PTP clock support registered
[ 0.183080] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[ 0.183856] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rga-supply from device tree
[ 0.183883] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rga-supply property in node /power-management@fdd90000/power-controller failed
[ 0.183980] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvenc-supply from device tree
[ 0.184003] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvenc-supply property in node /power-management@fdd90000/power-controller failed
[ 0.184065] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvdec-supply from device tree
[ 0.184087] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvdec-supply property in node /power-management@fdd90000/power-controller failed
[ 0.184136] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vi-supply from device tree
[ 0.184156] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vi-supply property in node /power-management@fdd90000/power-controller failed
[ 0.186365] Advanced Linux Sound Architecture Driver Initialized.
[ 0.187128] Bluetooth: Core ver 2.22
[ 0.187205] NET: Registered protocol family 31
[ 0.187230] Bluetooth: HCI device and connection manager initialized
[ 0.187260] Bluetooth: HCI socket layer initialized
[ 0.187287] Bluetooth: L2CAP socket layer initialized
[ 0.187355] Bluetooth: SCO socket layer initialized
[ 0.189909] rockchip-cpuinfo cpuinfo: SoC : 35682000
[ 0.189951] rockchip-cpuinfo cpuinfo: Serial : 8d70475e4d97facb
[ 0.191634] clocksource: Switched to clocksource arch_sys_counter
[ 0.293707] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.294132] NET: Registered protocol family 2
[ 0.294535] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.297008] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes)
[ 0.297136] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.297462] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.298573] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.298828] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.299062] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[ 0.299485] NET: Registered protocol family 1
[ 0.300446] PCI: CLS 0 bytes, default 64
[ 0.301437] Trying to unpack rootfs image as initramfs...
[ 0.784892] Freeing initrd memory: 9020K
[ 0.786765] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.787665] kvm [1]: 16-bit VMID
[ 0.787707] kvm [1]: GICv3: no GICV resource entry
[ 0.787722] kvm [1]: disabling GICv2 emulation
[ 0.787734] kvm [1]: GIC system register CPU interface enabled
[ 0.787912] kvm [1]: vgic interrupt IRQ1
[ 0.788125] kvm [1]: VHE mode initialized successfully
[ 0.790721] Initialise system trusted keyrings
[ 0.790994] workingset: timestamp_bits=45 max_order=20 bucket_order=0
[ 0.801375] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.801870] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.802199] fuse init (API version 7.27)
[ 0.802825] SGI XFS with security attributes, no debug enabled
[ 0.806828] NET: Registered protocol family 38
[ 0.806886] Key type asymmetric registered
[ 0.806901] Asymmetric key parser 'x509' registered
[ 0.806966] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.807185] io scheduler noop registered
[ 0.807211] io scheduler deadline registered
[ 0.807412] io scheduler cfq registered (default)
[ 0.807430] io scheduler mq-deadline registered
[ 0.807454] io scheduler kyber registered
[ 0.808957] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.809179] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 0.812256] phy phy-fe8a0000.usb2-phy.0: Looking up phy-supply from device tree
[ 0.812335] phy phy-fe8a0000.usb2-phy.0: Linked as a consumer to regulator.4
[ 0.812503] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply from device tree
[ 0.812517] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply property in node /usb2-phy@fe8a0000/otg-port failed
[ 0.812657] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply from device tree
[ 0.812735] phy phy-fe8a0000.usb2-phy.1: Linked as a consumer to regulator.5
[ 0.814408] extcon extcon1: failed to create extcon usb2-phy link
[ 0.814503] phy phy-fe8b0000.usb2-phy.2: Looking up phy-supply from device tree
[ 0.814591] phy phy-fe8b0000.usb2-phy.2: Linked as a consumer to regulator.4
[ 0.814769] phy phy-fe8b0000.usb2-phy.3: Looking up phy-supply from device tree
[ 0.814854] phy phy-fe8b0000.usb2-phy.3: Linked as a consumer to regulator.4
[ 0.815055] phy phy-fe8b0000.usb2-phy.3: Looking up vbus-supply from device tree
[ 0.815068] phy phy-fe8b0000.usb2-phy.3: Looking up vbus-supply property in node /usb2-phy@fe8b0000/otg-port failed
[ 0.815099] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port
[ 0.819430] phy phy-fe820000.phy.4: Looking up phy-supply from device tree
[ 0.819447] phy phy-fe820000.phy.4: Looking up phy-supply property in node /phy@fe820000 failed
[ 0.820033] phy phy-fe830000.phy.5: Looking up phy-supply from device tree
[ 0.820047] phy phy-fe830000.phy.5: Looking up phy-supply property in node /phy@fe830000 failed
[ 0.820633] phy phy-fe840000.phy.6: Looking up phy-supply from device tree
[ 0.820647] phy phy-fe840000.phy.6: Looking up phy-supply property in node /phy@fe840000 failed
[ 0.822269] phy phy-fe8c0000.phy.7: Looking up phy-supply from device tree
[ 0.822283] phy phy-fe8c0000.phy.7: Looking up phy-supply property in node /phy@fe8c0000 failed
[ 0.827324] rk-pcie 3c0800000.pcie: Looking up vpcie3v3-supply from device tree
[ 0.827451] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.17
[ 0.828130] mpp_service mpp-srv: 17e24d4a84af author: Ding Wei 2022-05-05 video: rockchip: mpp: rkvdec2: task->irq_status set for link mode
[ 0.828164] mpp_service mpp-srv: probe start
[ 0.829478] iommu: Adding device fdf40000.rkvenc to group 5
[ 0.829536] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu
[ 0.829815] mpp_rkvenc fdf40000.rkvenc: probing start
[ 0.830419] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[ 0.830447] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry
[ 0.830478] rkvenc_init:1199: failed to add venc devfreq
[ 0.830972] mpp_rkvenc fdf40000.rkvenc: probing finish
[ 0.832615] iommu: Adding device fdea0400.vdpu to group 1
[ 0.832656] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu
[ 0.832904] mpp_vdpu2 fdea0400.vdpu: probe device
[ 0.833692] mpp_vdpu2 fdea0400.vdpu: probing finish
[ 0.834456] iommu: Adding device fdee0000.vepu to group 3
[ 0.834511] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu
[ 0.834779] mpp_vepu2 fdee0000.vepu: probe device
[ 0.835632] mpp_vepu2 fdee0000.vepu: probing finish
[ 0.836385] iommu: Adding device fdef0000.iep to group 4
[ 0.836440] mpp-iep2 fdef0000.iep: Linked as a consumer to fdef0800.iommu
[ 0.836637] mpp-iep2 fdef0000.iep: probe device
[ 0.836824] snps pcie3phy FW update! size 8192
[ 0.837301] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[ 0.837532] mpp-iep2 fdef0000.iep: probing finish
[ 0.838240] iommu: Adding device fded0000.jpegd to group 2
[ 0.838331] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu
[ 0.838584] mpp_jpgdec fded0000.jpegd: probe device
[ 0.839381] mpp_jpgdec fded0000.jpegd: probing finish
[ 0.840143] iommu: Adding device fdf80200.rkvdec to group 6
[ 0.840198] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu
[ 0.840504] mpp_rkvdec2 fdf80200.rkvdec: probing start
[ 0.840720] mpp_rkvdec2 fdf80200.rkvdec: 16 task capacity link mode detected
[ 0.841178] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[ 0.841209] rkvdec2_init:661: No niu aclk reset resource define
[ 0.841236] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[ 0.841259] rkvdec2_init:664: No niu hclk reset resource define
[ 0.841517] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[ 0.841548] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[ 0.841571] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[ 0.841593] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[ 0.841652] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[ 0.841751] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[ 0.841857] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[ 0.842327] mpp_service mpp-srv: probe success
[ 0.851016] rk-pcie 3c0800000.pcie: missing legacy IRQ resource
[ 0.851059] rk-pcie 3c0800000.pcie: Missing *config* reg space
[ 0.851083] rk-pcie 3c0800000.pcie: host bridge /pcie@fe280000 ranges:
[ 0.851119] rk-pcie 3c0800000.pcie: err 0xf0000000..0xf00fffff -> 0xf0000000
[ 0.851157] rk-pcie 3c0800000.pcie: IO 0xf0100000..0xf01fffff -> 0xf0100000
[ 0.851194] rk-pcie 3c0800000.pcie: MEM 0xf0200000..0xf1ffffff -> 0xf0200000
[ 0.851227] rk-pcie 3c0800000.pcie: MEM 0x380000000..0x3bfffffff -> 0x380000000
[ 0.854396] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.854434] dma-pl330 fe530000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.857911] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.857950] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.859878] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.861503] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.862777] fe670000.serial: ttyS3 at MMIO 0xfe670000 (irq = 68, base_baud = 1500000) is a 16550A
[ 0.863690] fe680000.serial: ttyS4 at MMIO 0xfe680000 (irq = 69, base_baud = 1500000) is a 16550A
[ 0.864591] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 70, base_baud = 1500000) is a 16550A
[ 0.868367] random: fast init done
[ 0.868714] random: crng init done
[ 0.869266] iommu: Adding device fe040000.vop to group 8
[ 0.869326] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu
[ 0.876349] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop
[ 0.878248] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi
[ 0.881223] rockchip-drm display-subsystem: defer getting devfreq
[ 0.881670] vp0: rgb_pixelclk: 0
[ 0.881718] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x3f, primary plane phy id: 4
[ 0.881746] vp1: rgb_pixelclk: 0
[ 0.881775] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x0, primary plane phy id: -1
[ 0.881801] vp2: rgb_pixelclk: 0
[ 0.881828] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1
[ 0.882103] [drm] unsupported AFBC format[3432564e]
[ 0.882195] [drm] failed to init overlay plane Cluster0-win1
[ 0.882292] [drm] failed to init overlay plane Cluster1-win1
[ 0.882440] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8009032338)
[ 0.882741] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.883523] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.884375] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8009035e50)
[ 0.884412] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.884433] [drm] No driver support for vblank timestamp query.
[ 1.133164] fbcon: Deferring console take-over
[ 1.133215] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.134398] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 1.142228] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_gpu-supply from device tree
[ 1.142268] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_gpu-supply property in node /power-management@fdd90000/power-controller failed
[ 1.142345] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 1.142487] mali fde60000.gpu: Looking up mali-supply from device tree
[ 1.142496] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.142537] mali fde60000.gpu: Device initialization Deferred
[ 1.143574] brd: module loaded
[ 1.153772] loop: module loaded
[ 1.154455] zram: Added device: zram0
[ 1.154663] lkdtm: No crash points registered, enable through debugfs
[ 1.156467] ahci fc800000.sata: Looking up target-supply from device tree
[ 1.156485] ahci fc800000.sata: Looking up target-supply property in node /sata@fc800000 failed
[ 1.156620] ahci fc800000.sata: forcing port_map 0x0 -> 0x1
[ 1.156705] ahci fc800000.sata: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 1.156737] ahci fc800000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst
[ 1.156775] ahci fc800000.sata: port 0 is not capable of FBS
[ 1.158119] scsi host0: ahci
[ 1.158712] ata1: SATA max UDMA/133 mmio [mem 0xfc800000-0xfc800fff] port 0x100 irq 11
[ 1.162419] register firefly_spi_init spi return v = :0
[ 1.162832] CAN device driver interface
[ 1.167541] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[ 1.167567] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply property in node /ethernet@fe010000 failed
[ 1.167599] rk_gmac-dwmac fe010000.ethernet: no regulator found
[ 1.167642] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[ 1.167662] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f).
[ 1.167679] rk_gmac-dwmac fe010000.ethernet: RX delay(0x26).
[ 1.167700] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[ 1.167789] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[ 1.172829] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[ 1.173162] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 1.173194] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5
[ 1.173220] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[ 1.173244] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[ 1.173264] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[ 1.173286] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[ 1.173345] rk_gmac-dwmac fe010000.ethernet: TSO supported
[ 1.173364] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.173379] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[ 1.312686] rk_gmac-dwmac fe2a0000.ethernet: Looking up phy-supply from device tree
[ 1.312712] rk_gmac-dwmac fe2a0000.ethernet: Looking up phy-supply property in node /ethernet@fe2a0000 failed
[ 1.312746] rk_gmac-dwmac fe2a0000.ethernet: no regulator found
[ 1.312791] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (input).
[ 1.312811] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x3c).
[ 1.312828] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x2f).
[ 1.312849] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[ 1.312932] rk_gmac-dwmac fe2a0000.ethernet: clock input from PHY
[ 1.317972] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[ 1.318347] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 1.318379] rk_gmac-dwmac fe2a0000.ethernet: DWMAC4/5
[ 1.318405] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[ 1.318428] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[ 1.318449] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[ 1.318471] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[ 1.318531] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[ 1.318547] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.318562] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[ 1.458814] usbcore: registered new interface driver rndis_wlan
[ 1.458919] usbcore: registered new interface driver rtl8150
[ 1.459008] usbcore: registered new interface driver r8152
[ 1.459095] usbcore: registered new interface driver asix
[ 1.459175] usbcore: registered new interface driver ax88179_178a
[ 1.459252] usbcore: registered new interface driver cdc_ether
[ 1.459330] usbcore: registered new interface driver rndis_host
[ 1.459432] usbcore: registered new interface driver cdc_ncm
[ 1.459516] usbcore: registered new interface driver qmi_wwan_q
[ 1.459595] usbcore: registered new interface driver qmi_wwan
[ 1.459661] usbcore: registered new interface driver cdc_mbim
[ 1.461323] dwc3 fcc00000.dwc3: Failed to get clk 'ref': -2
[ 1.468484] dwc3 fd000000.dwc3: Failed to get clk 'ref': -2
[ 1.475362] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.475414] ehci-pci: EHCI PCI platform driver
[ 1.475521] ehci-platform: EHCI generic platform driver
[ 1.477896] ehci-platform fd800000.usb: EHCI Host Controller
[ 1.478174] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1
[ 1.478750] ehci-platform fd800000.usb: irq 12, io mem 0xfd800000
[ 1.491684] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[ 1.492030] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.492061] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.492086] usb usb1: Product: EHCI Host Controller
[ 1.492109] usb usb1: Manufacturer: Linux 4.19.232 ehci_hcd
[ 1.492131] usb usb1: SerialNumber: fd800000.usb
[ 1.492815] hub 1-0:1.0: USB hub found
[ 1.492889] hub 1-0:1.0: 1 port detected
[ 1.495744] ehci-platform fd880000.usb: EHCI Host Controller
[ 1.496040] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2
[ 1.496575] ehci-platform fd880000.usb: irq 14, io mem 0xfd880000
[ 1.508352] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[ 1.508698] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.508730] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.508755] usb usb2: Product: EHCI Host Controller
[ 1.508777] usb usb2: Manufacturer: Linux 4.19.232 ehci_hcd
[ 1.508798] usb usb2: SerialNumber: fd880000.usb
[ 1.509463] hub 2-0:1.0: USB hub found
[ 1.509536] hub 2-0:1.0: 1 port detected
[ 1.510687] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.510724] ohci-platform: OHCI generic platform driver
[ 1.511083] ohci-platform fd840000.usb: Generic Platform OHCI controller
[ 1.511377] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[ 1.511756] ohci-platform fd840000.usb: irq 13, io mem 0xfd840000
[ 1.572597] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.572631] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.572646] usb usb3: Product: Generic Platform OHCI controller
[ 1.572661] usb usb3: Manufacturer: Linux 4.19.232 ohci_hcd
[ 1.572675] usb usb3: SerialNumber: fd840000.usb
[ 1.573393] hub 3-0:1.0: USB hub found
[ 1.573467] hub 3-0:1.0: 1 port detected
[ 1.574221] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[ 1.574504] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4
[ 1.574825] ohci-platform fd8c0000.usb: irq 15, io mem 0xfd8c0000
[ 1.632594] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.632627] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.632644] usb usb4: Product: Generic Platform OHCI controller
[ 1.632659] usb usb4: Manufacturer: Linux 4.19.232 ohci_hcd
[ 1.632672] usb usb4: SerialNumber: fd8c0000.usb
[ 1.633366] hub 4-0:1.0: USB hub found
[ 1.633448] hub 4-0:1.0: 1 port detected
[ 1.635888] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 1.636186] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 5
[ 1.637117] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010
[ 1.637221] xhci-hcd xhci-hcd.4.auto: irq 86, io mem 0xfd000000
[ 1.637696] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.637728] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.637745] usb usb5: Product: xHCI Host Controller
[ 1.637760] usb usb5: Manufacturer: Linux 4.19.232 xhci-hcd
[ 1.637782] usb usb5: SerialNumber: xhci-hcd.4.auto
[ 1.638501] hub 5-0:1.0: USB hub found
[ 1.638569] hub 5-0:1.0: 1 port detected
[ 1.639107] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 1.639381] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 6
[ 1.639425] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[ 1.639553] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.639764] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 1.639787] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.639814] usb usb6: Product: xHCI Host Controller
[ 1.639837] usb usb6: Manufacturer: Linux 4.19.232 xhci-hcd
[ 1.639858] usb usb6: SerialNumber: xhci-hcd.4.auto
[ 1.640512] hub 6-0:1.0: USB hub found
[ 1.640583] hub 6-0:1.0: 1 port detected
[ 1.641336] usbcore: registered new interface driver cdc_acm
[ 1.641364] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.641465] usbcore: registered new interface driver cdc_wdm
[ 1.641909] usbcore: registered new interface driver uas
[ 1.642137] usbcore: registered new interface driver usb-storage
[ 1.642295] usbcore: registered new interface driver usbserial_generic
[ 1.642350] usbserial: USB Serial support registered for generic
[ 1.642446] usbcore: registered new interface driver cp210x
[ 1.642501] usbserial: USB Serial support registered for cp210x
[ 1.642649] usbcore: registered new interface driver ftdi_sio
[ 1.642704] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.643062] usbcore: registered new interface driver keyspan
[ 1.643110] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.643166] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.643218] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.643277] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.643381] usbcore: registered new interface driver option
[ 1.643436] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.643926] usbcore: registered new interface driver oti6858
[ 1.643982] usbserial: USB Serial support registered for oti6858
[ 1.644073] usbcore: registered new interface driver pl2303
[ 1.644127] usbserial: USB Serial support registered for pl2303
[ 1.644239] usbcore: registered new interface driver qcserial
[ 1.644308] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.644430] usbcore: registered new interface driver sierra
[ 1.644489] usbserial: USB Serial support registered for Sierra USB modem
[ 1.646540] usbcore: registered new interface driver usbtouchscreen
[ 1.646596] ============ himax_hx83102_init 1742 jjlook ==========
[ 1.646624] ============ himax_hx83102_probe 1725 jjlook ==========
[ 1.646719] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[ 1.646745] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[ 1.647277] .. rk pwm remotectl v2.0 init
[ 1.647669] input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input0
[ 1.648210] remotectl-pwm fe6e0030.pwm: pwm version is 0x2130000
[ 1.648255] remotectl-pwm fe6e0030.pwm: cannot find PWR IRQ
[ 1.648316] remotectl-pwm fe6e0030.pwm: pwm sip wakeup config error!!
[ 1.648332] remotectl-pwm fe6e0030.pwm: Donot support ATF Wakeup
[ 1.649335] i2c /dev entries driver
[ 1.651832] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[ 1.652367] vdd_cpu: override max_uV, 1390000 -> 1387500
[ 1.653691] fan53555-regulator 0-001c: Looking up vin-supply from device tree
[ 1.653711] vdd_cpu: supplied by vcc5v0_sys
[ 1.656203] vdd_cpu: 712 <--> 1387 mV at 1025 mV
[ 1.659063] rk808 0-0020: chip id: 0x8090
[ 1.659141] rk808 0-0020: No cache defaults, reading back from HW
[ 1.682958] rk808 0-0020: source: on=0x40, off=0x00
[ 1.682998] rk808 0-0020: support dcdc3 fb mode:-22, 63
[ 1.683017] rk808 0-0020: support pmic reset mode:0,0
[ 1.689033] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.689099] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.689194] rk808 0-0020: Looking up vcc1-supply from device tree
[ 1.689213] vdd_logic: supplied by vcc3v3_sys
[ 1.689323] vdd_logic: 500 <--> 1350 mV at 900 mV
[ 1.689774] rk808 0-0020: Looking up vcc2-supply from device tree
[ 1.689790] vdd_gpu: supplied by vcc3v3_sys
[ 1.689885] vdd_gpu: 500 <--> 1350 mV at 900 mV
[ 1.690282] rk808 0-0020: Looking up vcc3-supply from device tree
[ 1.690297] vcc_ddr: supplied by vcc3v3_sys
[ 1.690392] vcc_ddr: at 500 mV
[ 1.690810] rk808 0-0020: Looking up vcc4-supply from device tree
[ 1.690825] vdd_npu: supplied by vcc3v3_sys
[ 1.690924] vdd_npu: 500 <--> 1350 mV at 900 mV
[ 1.691342] rk808 0-0020: Looking up vcc9-supply from device tree
[ 1.691357] vcc_1v8: supplied by vcc3v3_sys
[ 1.691442] vcc_1v8: 1800 mV
[ 1.691865] rk808 0-0020: Looking up vcc5-supply from device tree
[ 1.691880] vdda0v9_image: supplied by vcc3v3_sys
[ 1.691956] vdda0v9_image: 900 mV
[ 1.692348] rk808 0-0020: Looking up vcc5-supply from device tree
[ 1.692363] vdda_0v9: supplied by vcc3v3_sys
[ 1.692439] vdda_0v9: 900 mV
[ 1.692826] rk808 0-0020: Looking up vcc5-supply from device tree
[ 1.692842] vdda0v9_pmu: supplied by vcc3v3_sys
[ 1.692932] vdda0v9_pmu: 900 mV
[ 1.693327] rk808 0-0020: Looking up vcc6-supply from device tree
[ 1.693342] vccio_acodec: supplied by vcc3v3_sys
[ 1.693419] vccio_acodec: 3300 mV
[ 1.693781] rk808 0-0020: Looking up vcc6-supply from device tree
[ 1.693795] vccio_sd: supplied by vcc3v3_sys
[ 1.693906] vccio_sd: 1800 <--> 3300 mV at 3300 mV
[ 1.694289] rk808 0-0020: Looking up vcc6-supply from device tree
[ 1.694305] vcc3v3_pmu: supplied by vcc3v3_sys
[ 1.694418] vcc3v3_pmu: 3300 mV
[ 1.694789] rk808 0-0020: Looking up vcc7-supply from device tree
[ 1.694804] vcca_1v8: supplied by vcc3v3_sys
[ 1.694898] vcca_1v8: 1800 mV
[ 1.695331] rk808 0-0020: Looking up vcc7-supply from device tree
[ 1.695346] vcca1v8_pmu: supplied by vcc3v3_sys
[ 1.695436] vcca1v8_pmu: 1800 mV
[ 1.695833] rk808 0-0020: Looking up vcc7-supply from device tree
[ 1.695848] vcca1v8_image: supplied by vcc3v3_sys
[ 1.695941] vcca1v8_image: 1800 mV
[ 1.696325] rk808 0-0020: Looking up vcc9-supply from device tree
[ 1.696339] vcc_3v3: supplied by vcc3v3_sys
[ 1.696428] vcc_3v3: at 3300 mV
[ 1.696792] rk808 0-0020: Looking up vcc8-supply from device tree
[ 1.696807] vcc3v3_sd: supplied by vcc3v3_sys
[ 1.696883] vcc3v3_sd: at 3300 mV
[ 1.697450] rk817-battery rk817-battery: Failed to find matching dt id
[ 1.697807] rk817-charger rk817-charger: Failed to find matching dt id
[ 1.701314] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[ 1.702087] rk808-rtc rk808-rtc: device is disabled
[ 1.702133] rk808-rtc: probe of rk808-rtc failed with error -22
[ 1.704278] pca953x 1-0021: Looking up vcc-supply from device tree
[ 1.704291] pca953x 1-0021: Looking up vcc-supply property in node /i2c@fe5a0000/gpio@21 failed
[ 1.704338] pca953x 1-0021: 1-0021 supply vcc not found, using dummy regulator
[ 1.704458] pca953x 1-0021: Linked as a consumer to regulator.0
[ 1.710706] rtc-hym8563 5-0051: rtc information is valid
[ 1.716347] rtc-hym8563 5-0051: rtc core: registered hym8563 as rtc0
[ 1.717427] rtc-hym8563 5-0051: setting system clock to 2022-04-15 18:31:19 UTC (1650047479)
[ 1.719131] gsensor_mc3230 5-004c: sensor_register_device: gs_mc3230, id = 27
[ 1.719168] i2c i2c-5: sensor_probe: gs_mc3230,0000000048faeb39
[ 1.719231] gsensor_mc3230 5-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0x0000000024745b47
[ 1.758508] [Gsensor] init_3230_ctl_data 457 : error: -6
[ 1.758541] gsensor_mc3230 5-004c: sensor_initial:fail to init sensor
[ 1.758558] gsensor_mc3230 5-004c: sensor_chip_init:fail to init sensor
[ 1.758572] i2c i2c-5: sensor_probe failed -2
[ 1.762971] iommu: Adding device fdff0000.rkisp to group 7
[ 1.763033] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iommu
[ 1.763299] rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[ 1.763320] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[ 1.763370] rkisp_hw fdff0000.rkisp: can't request region for resource [mem 0xfdff0000-0xfdffffff]
[ 1.764629] rkisp rkisp-vir0: rkisp driver version: v01.08.00
[ 1.765064] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 1.765096] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[ 1.767836] usbcore: registered new interface driver uvcvideo
[ 1.767866] USB Video Class driver (1.1.1)
[ 1.768135] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply from device tree
[ 1.768254] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.29
[ 1.768386] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[ 1.768440] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio2-supply from device tree
[ 1.768589] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[ 1.768736] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio1-supply from device tree
[ 1.768855] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.27
[ 1.768920] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[ 1.768966] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply from device tree
[ 1.768983] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply property in node /syscon@fdc20000/io-domains failed
[ 1.769032] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio3-supply from device tree
[ 1.769128] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.28
[ 1.769190] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[ 1.769231] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio4-supply from device tree
[ 1.769340] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.23
[ 1.769402] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[ 1.769453] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio5-supply from device tree
[ 1.769545] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.33
[ 1.769609] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[ 1.769656] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio6-supply from device tree
[ 1.769762] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[ 1.769821] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio7-supply from device tree
[ 1.769956] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[ 1.774870] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[ 1.776616] Bluetooth: HCI UART driver ver 2.3
[ 1.776648] Bluetooth: HCI UART protocol H4 registered
[ 1.776670] Bluetooth: HCI UART protocol ATH3K registered
[ 1.776982] Bluetooth: HCI UART protocol Broadcom registered
[ 1.777106] usbcore: registered new interface driver bfusb
[ 1.777208] usbcore: registered new interface driver btusb
[ 1.777634] cpu cpu0: leakage=29
[ 1.777715] cpu cpu0: pvtm = 85930, from nvmem
[ 1.777752] cpu cpu0: pvtm-volt-sel=1
[ 1.778137] cpu cpu0: Looking up cpu-supply from device tree
[ 1.778745] cpu cpu0: Linked as a consumer to regulator.18
[ 1.778841] cpu cpu0: Dropping the link to regulator.18
[ 1.779014] cpu cpu0: Looking up cpu-supply from device tree
[ 1.779584] cpu cpu0: Linked as a consumer to regulator.18
[ 1.780813] cpu cpu0: avs=0
[ 1.780913] energy_model: pd0: hertz/watts ratio non-monotonically decreasing: em_cap_state 2 >= em_cap_state1
[ 1.781211] energy_model: Created perf domain 0-3
[ 1.781265] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.785141] cpu cpu0: failed to find power_model node
[ 1.786914] sdhci: Secure Digital Host Controller Interface driver
[ 1.786936] sdhci: Copyright(c) Pierre Ossman
[ 1.786946] Synopsys Designware Multimedia Card Interface Driver
[ 1.788324] dwmmc_rockchip fe000000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.788515] dwmmc_rockchip fe000000.dwmmc: Using internal DMA controller.
[ 1.788535] dwmmc_rockchip fe000000.dwmmc: Version ID is 270a
[ 1.788610] dwmmc_rockchip fe000000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo
[ 1.788651] dwmmc_rockchip fe000000.dwmmc: Looking up vmmc-supply from device tree
[ 1.788664] dwmmc_rockchip fe000000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe000000 failed
[ 1.788706] dwmmc_rockchip fe000000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.788714] dwmmc_rockchip fe000000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe000000 failed
[ 1.788848] dwmmc_rockchip fe000000.dwmmc: allocated mmc-pwrseq
[ 1.788875] mmc_host mmc3: card is non-removable.
[ 1.871717] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 1.891674] usb 5-1: new high-speed USB device number 2 using xhci-hcd
[ 1.909102] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.922580] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.922770] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[ 1.922798] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[ 1.922866] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 51,32 bit host data width,256 deep fifo
[ 1.922940] dwmmc_rockchip fe2b0000.dwmmc: Looking up vmmc-supply from device tree
[ 1.923054] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.34
[ 1.923079] dwmmc_rockchip fe2b0000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.923152] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.28
[ 1.935410] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.948653] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.950291] sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply from device tree
[ 1.950304] sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply property in node /sdhci@fe310000 failed
[ 1.950347] sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply from device tree
[ 1.950354] sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe310000 failed
[ 1.950383] mmc0: Unknown controller version (5). You may experience problems.
[ 1.957960] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.959763] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.961541] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.964735] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.978329] usb 3-1: new low-speed USB device number 2 using ohci-platform
[ 1.981692] mmc0: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[ 1.986615] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.987114] usbcore: registered new interface driver usbhid
[ 1.987135] usbhid: USB HID core driver
[ 1.987627] rockchip,bus bus-npu: Looking up bus-supply from device tree
[ 1.987720] rockchip,bus bus-npu: Linked as a consumer to regulator.19
[ 1.987742] rockchip,bus bus-npu: Failed to get leakage
[ 1.987806] rockchip,bus bus-npu: pvtm = 85930, from nvmem
[ 1.987827] rockchip,bus bus-npu: pvtm-volt-sel=1
[ 1.988127] rockchip,bus bus-npu: avs=0
[ 1.992219] rockchip-saradc fe720000.saradc: Looking up vref-supply from device tree
[ 1.992326] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.30
[ 1.993060] rksfc_base v1.1 2016-01-08
[ 1.993831] rksfc fe300000.sfc: rksfc_probe clk rate = 50000000
[ 1.993899] rkflash_dev_init enter
[ 1.993924] sfc nor id: ef 60 19
[ 1.993949] rkflash[1] init success
[ 1.995115] sfc_nor_mtd_init register mtd succuss
[ 1.995139] rkflash_dev_init device register as mtd dev, ret= 0
[ 1.996012] usbcore: registered new interface driver snd-usb-audio
[ 1.998808] rk817-codec rk817-codec: DMA mask not set
[ 1.999678] rk817_codec_parse_dt_property: rk809 hp adc effective value of detection 0~600
[ 1.999711] invalid rk817->hp_det_gpio: -2
[ 1.999724] invalid gpio: -2
[ 2.005998] NET: Registered protocol family 10
[ 2.006981] Segment Routing with IPv6
[ 2.007056] NET: Registered protocol family 17
[ 2.007079] can: controller area network core (rev 20170425 abi 9)
[ 2.007241] NET: Registered protocol family 29
[ 2.007269] can: raw protocol (rev 20170425)
[ 2.007287] can: broadcast manager protocol (rev 20170425 t)
[ 2.007308] can: netlink gateway (rev 20170425) max_hops=1
[ 2.007584] Bluetooth: RFCOMM socket layer initialized
[ 2.007629] Bluetooth: RFCOMM ver 1.11
[ 2.007651] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.007670] Bluetooth: HIDP socket layer initialized
[ 2.007684] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.007694] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.008310] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.008364] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275s
[ 2.008379] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.008391] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.008456] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 124, flags = 0.
[ 2.008477] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 2.008485] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.008494] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 2.008502] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.009189] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 73.
[ 2.009231] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 96.
[ 2.009255] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 109.
[ 2.009277] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 95.
[ 2.009369] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.009470] [BT_RFKILL]: ** disable irq
[ 2.009593] [BT_RFKILL]: bt_default device registered.
[ 2.009759] Key type dns_resolver registered
[ 2.010076] flash vendor_init_thread!
[ 2.010096] flash vendor storage:20170308 ret = -1
[ 2.012243] Loading compiled-in X.509 certificates
[ 2.012786] pstore: Using compression: deflate
[ 2.013842] rga2: Driver loaded successfully ver:3.2.63318
[ 2.014218] rga2: Module initialized.
[ 2.014383] mmc0: new HS200 MMC card at address 0001
[ 2.015362] mmcblk0: mmc0:0001 Y2P032 29.1 GiB
[ 2.015991] mmcblk0boot0: mmc0:0001 Y2P032 partition 1 4.00 MiB
[ 2.016659] mmcblk0boot1: mmc0:0001 Y2P032 partition 2 4.00 MiB
[ 2.016948] mmcblk0rpmb: mmc0:0001 Y2P032 partition 3 16.0 MiB, chardev (239:0)
[ 2.020001] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 2.034626] usb 5-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.91
[ 2.034660] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.034669] usb 5-1: Product: USB2.1 Hub
[ 2.034675] usb 5-1: Manufacturer: GenesysLogic
[ 2.041735] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 2.041801] input: adc-keys as /devices/platform/adc-keys/input/input2
[ 2.041847] mali fde60000.gpu: Looking up mali-supply from device tree
[ 2.041928] mali fde60000.gpu: Linked as a consumer to regulator.20
[ 2.041943] mali fde60000.gpu: Looking up shadercores-supply from device tree
[ 2.041953] mali fde60000.gpu: Looking up shadercores-supply property in node /gpu@fde60000 failed
[ 2.042010] mali fde60000.gpu: Looking up mali-supply from device tree
[ 2.042030] vdd_gpu: could not add device link fde60000.gpu err -17
[ 2.042037] vdd_gpu: Failed to create debugfs directory
[ 2.042043] mali fde60000.gpu: Looking up shadercores-supply from device tree
[ 2.042055] mali fde60000.gpu: Looking up shadercores-supply property in node /gpu@fde60000 failed
[ 2.042071] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19
[ 2.042183] mali fde60000.gpu: leakage=7
[ 2.042229] mali fde60000.gpu: pvtm = 85930, from nvmem
[ 2.042249] mali fde60000.gpu: pvtm-volt-sel=1
[ 2.042316] rockchip-dmc dmc: Looking up center-supply from device tree
[ 2.042363] rockchip-dmc dmc: Linked as a consumer to regulator.19
[ 2.042434] rockchip-dmc dmc: leakage=47
[ 2.042453] rockchip-dmc dmc: leakage-volt-sel=0
[ 2.042490] rockchip-dmc dmc: pvtm = 85930, from nvmem
[ 2.042502] rockchip-dmc dmc: pvtm-volt-sel=1
[ 2.042644] rockchip-dmc dmc: avs=0
[ 2.042666] rockchip-dmc dmc: current ATF version 0x102
[ 2.042693] mali fde60000.gpu: avs=0
[ 2.042719] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 2.043190] rockchip-dmc dmc: normal_rate = 780000000
[ 2.043201] rockchip-dmc dmc: reboot_rate = 1560000000
[ 2.043209] rockchip-dmc dmc: suspend_rate = 324000000
[ 2.043217] rockchip-dmc dmc: video_4k_rate = 780000000
[ 2.043231] rockchip-dmc dmc: video_4k_10b_rate = 780000000
[ 2.043243] rockchip-dmc dmc: boost_rate = 1560000000
[ 2.043255] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1560000000
[ 2.043266] rockchip-dmc dmc: performance_rate = 1560000000
[ 2.043292] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 2.043451] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 2.043495] rockchip-dmc dmc: could not find power_model node
[ 2.043991] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[ 2.044074] mali fde60000.gpu: No priority control manager is configured
[ 2.044090] mali fde60000.gpu: No memory group manager is configured
[ 2.044688] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 2.045290] mali fde60000.gpu: Probed as mali0
[ 2.050134] mmc_host mmc3: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[ 2.055960] dwmmc_rockchip fe000000.dwmmc: Successfully tuned phase to 268
[ 2.057362] asoc-simple-card hdmi-sound: i2s-hifi <-> fe400000.i2s mapping ok
[ 2.057827] mmc3: new ultra high speed SDR104 SDIO card at address 0001
[ 2.060302] rk817-codec rk817-codec: rk817_probe: chip_name:0x80, chip_ver:0x94
[ 2.065296] asoc-simple-card rk809-sound: rk817-hifi <-> fe410000.i2s mapping ok
[ 2.065348] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 2.065358] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 -> direct -> Mic Jack
[ 2.065368] asoc-simple-card rk809-sound: ASoC: no source widget found for Mic Jack
[ 2.065375] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack -> direct -> IN1P
[ 2.065383] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 2.065391] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL -> direct -> Headphone Jack
[ 2.065399] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 2.065406] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR -> direct -> Headphone Jack
[ 2.069549] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 2.088430] hub 5-1:1.0: USB hub found
[ 2.088861] hub 5-1:1.0: 4 ports detected
[ 2.134174] vendor storage:20190527 ret = 0
[ 2.146188] devfreq fde60000.gpu: Couldn't update frequency transition information.
[ 2.155208] usb 6-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 2.174706] usb 6-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.91
[ 2.174730] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.174740] usb 6-1: Product: USB3.2 Hub
[ 2.174748] usb 6-1: Manufacturer: GenesysLogic
[ 2.200011] hub 6-1:1.0: USB hub found
[ 2.200334] hub 6-1:1.0: 4 ports detected
[ 2.207796] usb 3-1: New USB device found, idVendor=413c, idProduct=2113, bcdDevice= 1.08
[ 2.207847] usb 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.207856] usb 3-1: Product: Dell KB216 Wired Keyboard
[ 2.217403] input: Dell KB216 Wired Keyboard as /devices/platform/fd840000.usb/usb3/3-1/3-1:1.0/0003:413C:2113.0001/input/input3
[ 2.243733] wk2xxx_serial_init()
[ 2.243768] wk2xxx_request_port
[ 2.243780] ttysWK0 at I/O 0x1 (irq = 114, base_baud = 460800) is a wk2xxx
[ 2.244128] uart_add_one_port success for line i:= 0 with right 0
[ 2.244148] wk2xxx_request_port
[ 2.244159] ttysWK1 at I/O 0x2 (irq = 114, base_baud = 460800) is a wk2xxx
[ 2.244288] uart_add_one_port success for line i:= 1 with right 0
[ 2.244298] wk2xxx_request_port
[ 2.244305] ttysWK2 at I/O 0x3 (irq = 114, base_baud = 460800) is a wk2xxx
[ 2.244429] uart_add_one_port success for line i:= 2 with right 0
[ 2.244444] wk2xxx_request_port
[ 2.244455] ttysWK3 at I/O 0x4 (irq = 114, base_baud = 460800) is a wk2xxx
[ 2.244586] uart_add_one_port success for line i:= 3 with right 0
[ 2.244598] uart_add_one_port = 0x0
[ 2.246012] register spi return v = :0
[ 2.246043] dhd_module_init: in Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 2.246058] ======== dhd_wlan_init_plat_data ========
[ 2.246069] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.246160] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=115, oob_irq_flags=0x414
[ 2.246171] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 2.246182] dhd_wifi_platform_load: Enter
[ 2.246192] Power-up adapter 'DHD generic adapter'
[ 2.247991] wifi_platform_set_power = 1, delay: 200 msec
[ 2.248026] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 2.248038] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.248050] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 2.248061] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 2.272586] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-fd840000.usb-1/input0
[ 2.280205] input: Dell KB216 Wired Keyboard System Control as /devices/platform/fd840000.usb/usb3/3-1/3-1:1.1/0003:413C:2113.0002/input/input4
[ 2.335580] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/fd840000.usb/usb3/3-1/3-1:1.1/0003:413C:2113.0002/input/input5
[ 2.336054] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-fd840000.usb-1/input1
[ 2.479374] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.479421] ata1: ready = 1 sstatus = 0
[ 2.551791] wifi_platform_bus_enumerate device present 1
[ 2.551838] ======== Card detection to detect SDIO card! ========
[ 2.551854] mmc3:mmc host rescan start!
[ 2.568064] bcmsdh_register: register client driver
[ 2.568558] bcmsdh_sdmmc_probe: Enter num=1
[ 2.570065] bcmsdh_sdmmc_probe: Enter num=2
[ 2.570085] bus num (host idx)=3, slot num (rca)=1
[ 2.570095] found adapter info 'DHD generic adapter'
[ 2.570325] sdioh_attach: set sd_f2_blocksize 256
[ 2.570413] sdioh_attach: sd clock rate = 0
[ 2.570923] dhdsdio_probe : no mutex held. set lock
[ 2.571157] F1 signature read @0x18000000=0x1042aae8
[ 2.581780] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 2.583697] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 2.583866] [dhd] dhd_conf_set_chiprev : chip=0xaae8, chiprev=2
[ 2.585207] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.585237] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.585246] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.585254] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.585262] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 2.585630] dhd_log_dump_init: kernel log buf size = 256KB; logdump_prsrv_tailsize = 80KB; limit prsrv tail size to = 38KB
[ 2.587739] dhd_attach(): thread:dhd_watchdog_thread:6f started
[ 2.587825] dhd_attach(): thread:dhd_dpc:70 started
[ 2.588037] dhd_attach(): thread:dhd_rxf:71 started
[ 2.588061] dhd_deferred_work_init: work queue initialized
[ 2.588078] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 2
[ 2.588219] get_mem_val_from_file: File [/data/misc/wifi/.memdump.info] doesn't exist
[ 2.588234] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[ 2.588256] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 2.596778] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 2.596955] Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 2.597785] Register interface [wlan0] MAC: 10:2c:6b:7f:b8:f8
[ 2.597951] dhd_dbg_detach_pkt_monitor, 2100
[ 2.597969] dhd_bus_devreset: == Power OFF ==
[ 2.598217] dhd_bus_stop: making DHD_BUS_DOWN
[ 2.598262] bcmsdh_oob_intr_unregister: Enter
[ 2.598275] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.598308] dhd_bus_devreset: making dhdpub up FALSE
[ 2.598324] dhd_txglom_enable: enable 0
[ 2.598336] dhd_bus_devreset: making DHD_BUS_DOWN
[ 2.598347] dhd_bus_devreset: WLAN OFF DONE
[ 2.598400] wifi_platform_set_power = 0, delay: 0 msec
[ 2.598416] ======== PULL WL_REG_ON(-1) LOW! ========
[ 2.598429] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.598462] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 2.598473] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 2.598480] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 2.598493] dhdsdio_probe : the lock is released.
[ 2.599904] dhd_module_init: Exit err=0
[ 2.600736] ==gsl_ts_init==
[ 2.600848] ret=0
[ 2.602900] iommu: Adding device fde40000.npu to group 0
[ 2.602969] RKNPU fde40000.npu: Linked as a consumer to fde4b000.iommu
[ 2.603904] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 2.603983] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[ 2.604158] RKNPU fde40000.npu: Linked as a consumer to regulator.22
[ 2.604175] RKNPU fde40000.npu: Looking up mem-supply from device tree
[ 2.604188] RKNPU fde40000.npu: Looking up mem-supply property in node /npu@fde40000 failed
[ 2.604264] RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff]
[ 2.605269] [drm] Initialized rknpu 0.7.2 20220428 for fde40000.npu on minor 1
[ 2.605430] RKNPU fde40000.npu: leakage=3
[ 2.605479] RKNPU fde40000.npu: pvtm = 85930, from nvmem
[ 2.605498] RKNPU fde40000.npu: pvtm-volt-sel=1
[ 2.606124] RKNPU fde40000.npu: avs=0
[ 2.606874] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 2.606931] RKNPU fde40000.npu: failed to find power_model node
[ 2.606945] RKNPU fde40000.npu: RKNPU: failed to initialize power model
[ 2.606956] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient
[ 2.609779] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.617833] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.619153] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.619184] cfg80211: failed to load regulatory.db
[ 2.620363] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 2.621459] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '02:25:01', on 'Oct 9 2022'.
[ 2.622357] Mali:
[ 2.622361] Mali device driver loaded
[ 2.622898] xc7160 4-001b: T-chip firefly camera driver version: 00.01.02
[ 2.623482] xc7160 4-001b: Failed to get power-gpios, maybe no use
[ 2.626067] xc7160 4-001b: Looking up avdd-supply from device tree
[ 2.626082] xc7160 4-001b: Looking up avdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.626147] xc7160 4-001b: 4-001b supply avdd not found, using dummy regulator
[ 2.626304] xc7160 4-001b: Linked as a consumer to regulator.0
[ 2.626320] xc7160 4-001b: Looking up dovdd-supply from device tree
[ 2.626327] xc7160 4-001b: Looking up dovdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.626353] xc7160 4-001b: 4-001b supply dovdd not found, using dummy regulator
[ 2.626409] xc7160 4-001b: Looking up dvdd-supply from device tree
[ 2.626416] xc7160 4-001b: Looking up dvdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 2.626429] xc7160 4-001b: 4-001b supply dvdd not found, using dummy regulator
[ 2.626483] xc7160 4-001b: could not get default pinstate
[ 2.626497] xc7160 4-001b: could not get sleep pinstate
[ 2.626524] xc7160 4-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 2.626536] xc7160 4-001b: xc7160 num data lanes is 4
[ 2.641774] xc7160 4-001b: write XC7160_REG_HIGH_SELECT failed
[ 2.642935] xc7160: probe of 4-001b failed with error -5
[ 2.643063] rkisp rkisp-vir0: clear unready subdev num: 4
[ 2.643083] rockchip-csi2-dphy0: No link between dphy and sensor
[ 2.643627] rockchip-csi2-dphy0: No link between dphy and sensor
[ 2.643640] rkisp-vir0: update sensor failed
[ 2.651319] ret 1024 0
[ 2.652119] ALSA device list:
[ 2.652146] #0: rockchip,hdmi
[ 2.652154] #1: rockchip,rk809-codec
[ 2.655279] Freeing unused kernel memory: 1600K
[ 2.668442] Run /init as init process
[ 2.724242] phy phy-fe8a0000.usb2-phy.1: charger = USB_SDP_CHARGER
[ 2.885244] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 3.790797] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 3.898441] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 4.006055] EXT4-fs (mmcblk0p7): recovery complete
[ 4.006799] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 4.160836] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 4.392745] systemd[1]: System time before build time, advancing clock.
[ 4.414616] systemd[1]: Failed to find module 'autofs4'
[ 4.457589] systemd[1]: systemd 245.4-4ubuntu3.18 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 4.459753] systemd[1]: Detected architecture arm64.
[ 4.472195] systemd[1]: Set hostname to <ThingsWise-iEOS>.
[ 4.473852] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 4.474292] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 4.776348] systemd[1]: Configuration file /etc/systemd/system/usbdevice.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 4.854040] systemd[1]: Created slice system-getty.slice.
[ 4.857283] systemd[1]: Created slice system-modprobe.slice.
[ 4.860314] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 4.863576] systemd[1]: Created slice User and Session Slice.
[ 4.864849] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.866043] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.866834] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[ 4.866996] systemd[1]: Reached target Local Encrypted Volumes.
[ 4.867325] systemd[1]: Reached target Paths.
[ 4.867681] systemd[1]: Reached target Remote File Systems.
[ 4.868182] systemd[1]: Reached target Slices.
[ 4.868655] systemd[1]: Reached target Swap.
[ 4.869491] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.870974] systemd[1]: Listening on Journal Audit Socket.
[ 4.872632] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.873845] systemd[1]: Listening on Journal Socket.
[ 4.875434] systemd[1]: Listening on udev Control Socket.
[ 4.876596] systemd[1]: Listening on udev Kernel Socket.
[ 4.883416] systemd[1]: Mounting Huge Pages File System...
[ 4.891322] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.900670] systemd[1]: Mounting Kernel Debug File System...
[ 4.910495] systemd[1]: Mounting Kernel Trace File System...
[ 4.911888] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 4.922836] systemd[1]: Starting Journal Service...
[ 4.934343] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 4.943850] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 4.945510] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 4.953830] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 4.963927] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 4.974068] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 4.975532] systemd[1]: Condition check resulted in Load Kernel Module ramoops being skipped.
[ 4.979236] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 4.990675] systemd[1]: Starting Load Kernel Modules...
[ 4.996498] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.003113] systemd[1]: Starting udev Coldplug all Devices...
[ 5.011310] systemd[1]: Mounted Huge Pages File System.
[ 5.013292] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.015186] systemd[1]: Mounted Kernel Debug File System.
[ 5.017168] systemd[1]: Mounted Kernel Trace File System.
[ 5.022420] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 5.025368] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[ 5.027166] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[ 5.029687] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[ 5.031376] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 5.033441] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[ 5.035109] systemd[1]: Finished Load Kernel Module pstore_blk.
[ 5.037167] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[ 5.038921] systemd[1]: Finished Load Kernel Module pstore_zone.
[ 5.043915] systemd[1]: Finished Load Kernel Modules.
[ 5.047877] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 5.055179] systemd[1]: Mounting FUSE Control File System...
[ 5.060636] systemd[1]: Mounting Kernel Configuration File System...
[ 5.063049] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 5.068176] systemd[1]: Starting Platform Persistent Storage Archival...
[ 5.074149] systemd[1]: Starting Load/Save Random Seed...
[ 5.082211] systemd[1]: Starting Apply Kernel Variables...
[ 5.087706] systemd[1]: Starting Create System Users...
[ 5.093933] systemd[1]: Mounted FUSE Control File System.
[ 5.095546] systemd[1]: Mounted Kernel Configuration File System.
[ 5.129875] systemd[1]: Finished Platform Persistent Storage Archival.
[ 5.145825] systemd[1]: Finished Load/Save Random Seed.
[ 5.150632] systemd[1]: Finished Create System Users.
[ 5.157031] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 5.166676] systemd[1]: Finished Apply Kernel Variables.
[ 5.200020] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 5.201014] systemd[1]: Reached target Local File Systems (Pre).
[ 5.201394] systemd[1]: Reached target Local File Systems.
[ 5.201983] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 5.202129] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 5.207720] systemd[1]: Starting udev Kernel Device Manager...
[ 5.332679] systemd[1]: Started udev Kernel Device Manager.
[ 5.449279] systemd[1]: Finished udev Coldplug all Devices.
[ 5.473327] systemd[1]: Started Journal Service.
[ 5.511612] systemd-journald[375]: Received client request to flush runtime journal.
[ 5.516402] systemd-journald[375]: File /var/log/journal/37d3d677b87042e4ade1206eb07af6d2/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.925062] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 6.126463] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.126908] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.127597] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.127804] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.824102] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.824575] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.829151] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.829729] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 6.925224] using random self ethernet address
[ 6.925232] using random host ethernet address
[ 6.938430] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x1
[ 7.200330] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host high!
[ 7.251947] [BT_RFKILL]: ENABLE UART_RTS
[ 7.358405] [BT_RFKILL]: DISABLE UART_RTS
[ 7.358451] [BT_RFKILL]: bt turn on power
[ 7.358479] [BT_RFKILL]: Request irq for bt wakeup host
[ 7.358515] [BT_RFKILL]: ** disable irq
[ 7.519172] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.519346] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.519387] Generic PHY stmmac-1:00: [phy_probe-1992] led_status_value = 0x6940
[ 7.522169] Generic PHY stmmac-1:00: phy_rtl8211f_led_fixup
[ 7.544526] Generic PHY stmmac-1:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-1:00, irq=POLL)
[ 7.546284] dwmac4: Master AXI performs any burst length
[ 7.546311] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[ 7.546337] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 7.547202] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[ 7.547775] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.547790] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.548357] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.573291] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 7.573437] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.573476] Generic PHY stmmac-0:00: [phy_probe-1992] led_status_value = 0x6940
[ 7.576032] Generic PHY stmmac-0:00: phy_rtl8211f_led_fixup
[ 7.596841] Generic PHY stmmac-0:00: phy_rtl8211f_led_fixup
[ 7.618020] Generic PHY stmmac-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 7.629521] dwmac4: Master AXI performs any burst length
[ 7.629544] rk_gmac-dwmac fe2a0000.ethernet eth1: No Safety Features support found
[ 7.629567] rk_gmac-dwmac fe2a0000.ethernet eth1: IEEE 1588-2008 Advanced Timestamp supported
[ 7.629868] rk_gmac-dwmac fe2a0000.ethernet eth1: registered PTP clock
[ 7.630375] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 7.630386] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.644353] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.672421] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 7.673445] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.673912] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.678064] IPv6: ADDRCONF(NETDEV_UP): lan: link is not ready
[ 7.678249] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.678513] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.723575] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.735064] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.735445] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.735630] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.735759] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.735881] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.736067] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.736208] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.736335] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.736447] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.736571] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.951802] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 7.954778] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.956074] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 7.956270] usb0: HOST MAC 9a:0b:f2:7e:1d:7b
[ 7.956275] usb0: MAC e6:5e:33:f0:3e:f2
[ 8.209576] dwc3 fcc00000.dwc3: device reset
[ 8.340484] dwc3 fcc00000.dwc3: device reset
[ 8.340615] android_work: did not send uevent (0 0 (null))
[ 8.485501] android_work: sent uevent USB_STATE=CONNECTED
[ 8.488153] configfs-gadget gadget: high-speed config #1: b
[ 8.489183] android_work: sent uevent USB_STATE=CONFIGURED
[ 8.565393] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.565948] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.566169] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.566584] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.568124] rk_gmac-dwmac fe010000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 8.575361] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.603387] lan: port 1(eth0) entered blocking state
[ 8.603406] lan: port 1(eth0) entered disabled state
[ 8.603495] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.603853] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.604019] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.604052] device eth0 entered promiscuous mode
[ 8.604265] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.604414] lan: port 1(eth0) entered blocking state
[ 8.604422] lan: port 1(eth0) entered listening state
[ 8.604553] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.606622] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.606932] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 8.965205] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 9.845237] usb 5-1.3: new high-speed USB device number 3 using xhci-hcd
[ 9.968789] usb 5-1.3: New USB device found, idVendor=2c7c, idProduct=0125, bcdDevice= 3.18
[ 9.968814] usb 5-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.968830] usb 5-1.3: Product: Android
[ 9.968844] usb 5-1.3: Manufacturer: Android
[ 9.982018] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x1
[ 10.157968] option 5-1.3:1.0: GSM modem (1-port) converter detected
[ 10.159765] usb 5-1.3: GSM modem (1-port) converter now attached to ttyUSB0
[ 10.161508] option 5-1.3:1.1: GSM modem (1-port) converter detected
[ 10.165713] usb 5-1.3: GSM modem (1-port) converter now attached to ttyUSB1
[ 10.167664] option 5-1.3:1.2: GSM modem (1-port) converter detected
[ 10.171578] usb 5-1.3: GSM modem (1-port) converter now attached to ttyUSB2
[ 10.173687] option 5-1.3:1.3: GSM modem (1-port) converter detected
[ 10.177661] usb 5-1.3: GSM modem (1-port) converter now attached to ttyUSB3
[ 10.220966] qmi_wwan_q 5-1.3:1.4: cdc-wdm0: USB WDM device
[ 10.220990] qmi_wwan_q 5-1.3:1.4: Quectel EC25&EC21&EG91&EG95&EG06&EP06&EM06&EG12&EP12&EM12&EG16&EG18&BG96&AG35 work on RawIP mode
[ 10.226356] qmi_wwan_q 5-1.3:1.4: rx_urb_size = 1520
[ 10.226492] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.227939] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.228248] qmi_wwan_q 5-1.3:1.4 wwan0: register 'qmi_wwan_q' at usb-xhci-hcd.4.auto-1.3, WWAN/QMI device, ca:c9:51:1b:f7:c9
[ 10.980371] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.981030] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.991805] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 11.114278] lan: port 2(usb0) entered blocking state
[ 11.114295] lan: port 2(usb0) entered disabled state
[ 11.114387] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.114624] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.114784] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.114815] device usb0 entered promiscuous mode
[ 11.115064] lan: port 2(usb0) entered blocking state
[ 11.115075] lan: port 2(usb0) entered listening state
[ 11.116826] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.117301] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.149716] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2
[ 11.185290] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.185861] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.186847] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.195406] fbcon: Taking over console
[ 11.196213] Console: switching to colour frame buffer device 240x67
[ 11.222000] Freeing drm_logo memory: 812K
[ 12.005032] rk-pcie 3c0800000.pcie: PCIe Link Fail
[ 12.005074] rk-pcie 3c0800000.pcie: failed to initialize host
[ 14.377115] Bridge firewalling registered
[ 14.551287] Initializing XFRM netlink socket
[ 14.575146] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 14.575648] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 14.688394] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 14.688630] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 14.688636] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 18.268267] systemd-journald[375]: File /var/log/journal/37d3d677b87042e4ade1206eb07af6d2/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 25.231682] lan: port 1(eth0) entered learning state
[ 26.938342] lan: port 2(usb0) entered learning state
[ 33.765278] vcc5v0_otg: disabling
[ 33.765299] vcc3v3_lcd0_n: disabling
[ 33.765313] vcc3v3_lcd1_n: disabling
[ 33.765338] pcie30_3v3: disabling
[ 37.421770] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 37.422133] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 37.422619] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 40.591774] lan: port 1(eth0) entered forwarding state
[ 40.591850] lan: topology change detected, propagating
[ 40.592256] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 40.596160] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 42.298453] lan: port 2(usb0) entered forwarding state
[ 42.298528] lan: topology change detected, propagating
“换上官方提供的驱动” ?你是怎么操作的?
