SDK包名称:rk3399pro_linux_release_v2.5.1_20210304
SDK修改内容:未修改
Log日志:log.zip
/home/zhang/linux/01_rk3399pro/rk3399pro_linux_release_v2.5.1_20210304
CC scripts/mod/empty.o
CC scripts/mod/devicetable-offsets.s
aarch64-buildroot-linux-gnu-gcc:No such file or directory
Is your PATH set correctly?
scripts/Makefile.build:277: recipe for target ‘scripts/mod/empty.o’ failed
make[2]: *** [scripts/mod/empty.o] Error 2
make[2]: *** Waiting for unfinished jobs…
scripts/Makefile.build:153: recipe for target ‘scripts/mod/devicetable-offsets.s’ failed
make[2]: *** [scripts/mod/devicetable-offsets.s] Error 2
scripts/Makefile.build:484: recipe for target ‘scripts/mod’ failed
make[1]: *** [scripts/mod] Error 2
Makefile:579: recipe for target ‘scripts’ failed
make: *** [scripts] Error 2
ERROR: Running build_kernel failed!
ERROR: exit code 2 from line 598:
make ARCH=$RK_ARCH $RK_KERNEL_DTS.img -j$RK_JOBS
log.zip (634 Bytes)
你是不是没有使用脚本编译,而是自己用make去编译了。
请在sdk目录下,使用./build.sh kernel 命令去编译
请在sdk目录下,使用./build.sh kernel 命令去编 …
2022-10-10T21:36:01 >>> host-qemu 4.2.0 Downloading
2022-10-10T21:36:01 --2022-10-10 21:36:01-- http://download.qemu.org/qemu-4.2.0.tar.xz
2022-10-10T21:36:01 Connecting to 127.0.0.1:12333… connected.
2022-10-10T21:36:01 Proxy request sent, awaiting response… 307 Temporary Redirect
2022-10-10T21:36:01 Location: https://download.qemu.org:80/qemu-4.2.0.tar.xz [following]
2022-10-10T21:36:01 --2022-10-10 21:36:01-- https://download.qemu.org:80/qemu-4.2.0.tar.xz
2022-10-10T21:36:01 Resolving download.qemu.org (download.qemu.org)… 13.107.213.49, 13.107.246.49, 2620:1ec:bdf::49, …
2022-10-10T21:36:01 Connecting to download.qemu.org (download.qemu.org)|13.107.213.49|:80… connected.
2022-10-10T21:36:01 OpenSSL: error:1408F10B:SSL routines:ssl3_get_record:wrong version number
2022-10-10T21:36:01 Unable to establish SSL connection.
2022-10-10T21:36:01 --2022-10-10 21:36:01-- http://sources.buildroot.net/qemu-4.2.0.tar.xz
2022-10-10T21:36:02 Proxy request sent, awaiting response… 404 Not Found
2022-10-10T21:36:02 2022-10-10 21:36:02 ERROR 404: Not Found.
2022-10-10T21:36:02
2022-10-10T21:36:02 package/pkg-generic.mk:166: recipe for target ‘/home/zhang/linux/01_rk3399pro/rk3399pro_linux_release_v2.5.1_20210304/buildroot/output/rockchip_rk3399pro_combine/build/host-qemu-4.2.0/.stamp_downloaded’ failed
2022-10-10T21:36:02 make[1]: *** [/home/zhang/linux/01_rk3399pro/rk3399pro_linux_release_v2.5.1_20210304/buildroot/output/rockchip_rk3399pro_combine/build/host-qemu-4.2.0/.stamp_downloaded] Error 1
2022-10-10T21:36:02 /home/zhang/linux/01_rk3399pro/rk3399pro_linux_release_v2.5.1_20210304/buildroot/output/rockchip_rk3399pro_combine/Makefile:16: recipe for target ‘_all’ failed
2022-10-10T21:36:02 make: *** [_all] Error 2
you take 0:07.15 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 726:
/usr/bin/time -f “you take %E to build builroot” $COMMON_DIR/mk-buildroot.sh $BOARD_CONFIG
