使用3588J核心板,自制的底板,启动ubuntu 内核报错,麻烦看下什么问题
[ 5.513776] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish
[ 5.513848] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12
[ 5.713701] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.739255] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.765920] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.792587] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.819253] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.845920] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.872587] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.899253] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.925920] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.952587] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 8.379252] rk-pcie fe170000.pcie: PCIe Link Fail
[ 8.379258] rk-pcie fe170000.pcie: failed to initialize host
[ 95.089233] rcu: INFO: rcu_sched detected stalls on CPUs/tasks:
[ 95.089257] rcu: 4-…!: (1 GPs behind) idle=c32/1/0x4000000000000000 softirq=131/134 fqs=103
[ 95.089269] rcu: 5-…!: (1 GPs behind) idle=aca/1/0x4000000000000000 softirq=28/29 fqs=103
[ 95.089281] (detected by 1, t=26871 jiffies, g=-1091, q=24)
[ 95.089289] Task dump for CPU 4:
[ 95.089297] task:swapper/0 state:R running task stack: 0 pid: 1 ppid: 0 flags:0x00000008
[ 95.089314] Call trace:
[ 95.089329] __switch_to+0x130/0x1a0
[ 95.089339] 0xffffffc0115b22e0
[ 95.089346] Task dump for CPU 5:
[ 95.089354] task:rk-pcie state:R running task stack: 0 pid: 143 ppid: 2 flags:0x00000008
[ 95.089370] Call trace:
[ 95.089380] __switch_to+0x130/0x1a0
[ 95.089392] of_find_node_by_phandle+0xa0/0xd4
[ 95.089404] rcu: rcu_sched kthread starved for 26012 jiffies! g-1091 f0x0 RCU_GP_WAIT_FQS(5) ->state=0x402 ->cpu=1
[ 95.089413] rcu: Unless rcu_sched kthread gets sufficient CPU time, OOM is now expected behavior.
[ 95.089420] rcu: RCU grace-period kthread stack dump:
[ 95.089428] task:rcu_sched state:I stack: 0 pid: 11 ppid: 2 flags:0x00000008
[ 95.089440] Call trace:
[ 95.089449] __switch_to+0x130/0x1a0
[ 95.089460] __schedule+0x3e8/0x5bc
[ 95.089470] schedule+0x80/0xc8
[ 95.089479] schedule_timeout+0xcc/0xf0
[ 95.089491] rcu_gp_kthread+0x2ac/0x840
[ 95.089501] kthread+0xf8/0x108
[ 95.089511] ret_from_fork+0x10/0x30
log.txt (33.8 KB)
自制底板需要自己调通 kernel 才行,没有用到的功能得关闭,例如 pcie
多半是你开了pcie,没给pcie对应controler的clk
你把PCIE相关的设备树全部关了试一下
