abcxyztt 发表于 2022-10-26 14:59
应该是dts配置不对
dts文件如下所示,可以帮忙看看哪里有问题吗?目前是板子上看DSI的接口有出来,背光也可以开关,就是没信号。
- Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License as
published by the Free Software Foundation; either version 2 of the
License, or (at your option) any later version.
This file is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
- Or, alternatively,
restriction, including without limitation the rights to use,
copy, modify, merge, publish, distribute, sublicense, and/or
sell copies of the Software, and to permit persons to whom the
Software is furnished to do so, subject to the following
conditions:
The above copyright notice and this permission notice shall be
included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
OTHER DEALINGS IN THE SOFTWARE.
/dts-v1/;
#include “rk3399-firefly-port.dtsi”
#include <dt-bindings/sensor-dev.h>
#include <dt-bindings/display/media-bus-format.h>
model = “AIO-3399J Board LVDS HSX101H40C (Linux Opensource)”;
compatible = “rockchip,rk3399-firefly”, “rockchip,rk3399”;
test-power {
status = "okay";
/delete-node/ vcc-sd;
sdmmc_pwrseq: sdmmc-pwrseq {
compatible = "mmc-pwrseq-simple";
clocks = <&rk808 1>;
clock-names = "ext_clock";
pinctrl-names = "default";
pinctrl-0 = <&sdcard_enable_h>;
* On the module itself this is one of these (depending
* on the actual card populated):
* - SDIO_RESET_L_WL_REG_ON
* - PDN (power down when low)
reset-gpios = <&gpio1 20 GPIO_ACTIVE_LOW>; /* GPIO1_C4 */
lcd_en:lcd-en-regulator {
compatible = "regulator-fixed";
enable-active-high;
gpio = <&gpio1 4 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&lcd_panel_lcd_en>;
regulator-name = "lcd_en";
regulator-always-on;
leds {
compatible = "gpio-leds";
work {
gpios = <&gpio2 7 GPIO_ACTIVE_HIGH>;
default-state = "on";
user {
gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>;
default-state = "off";
&backlight {
status = “okay”;
pwms = <&pwm0 0 25000 1>;
enable-gpios = <&gpio1 1 GPIO_ACTIVE_HIGH>;
brightness-levels = </*
0 1 2 3 4 5 6 7
8 9 10 11 12 13 14 15
16 17 18 19 20 21 22 23
24 25 26 27 28 29 30 31
32 33 34 35*/36 37 38 39
40 41 42 43 44 45 46 47
48 49 50 51 52 53 54 55
56 57 58 59 60 61 62 63
64 65 66 67 68 69 70 71
72 73 74 75 76 77 78 79
80 81 82 83 84 85 86 87
88 89 90 91 92 93 94 95
96 97 98 99 100 101 102 103
104 105 106 107 108 109 110 111
112 113 114 115 116 117 118 119
120 121 122 123 124 125 126 127
128 129 130 131 132 133 134 135
136 137 138 139 140 141 142 143
144 145 146 147 148 149 150 151
152 153 154 155 156 157 158 159
160 161 162 163 164 165 166 167
168 169 170 171 172 173 174 175
176 177 178 179 180 181 182 183
184 185 186 187 188 189 190 191
192 193 194 195 196 197 198 199
200 201 202 203 204 205 206 207
208 209 210 211 212 213 214 215
216 217 218 219 220 221 222 223
224 225 226 227 228 229 230 231
232 233 234 235 236 237 238 239
240 241 242 243 244 245 246 247
248 249 250 251 252 253 254 255>;
default-brightness-level = <200>;
&dsi {
status = “okay”;
rockchip,lane-rate = <1000>; //lvds_clock62
dsi_panel: panel {
compatible =“simple-panel-dsi”;
reg = <0>;
backlight = <&backlight>;
enable-gpios = <&gpio3 16 GPIO_ACTIVE_HIGH>;
reset-gpios = <&gpio2 27 GPIO_ACTIVE_LOW>;
//bus-format = <MEDIA_BUS_FMT_RGB666_1X18>;
dsi,lanes = <4>;
dsi,channel = <0>;
enable-delay-ms = <35>;
prepare-delay-ms = <6>;
unprepare-delay-ms = <0>;
disable-delay-ms = <20>;
size,width = <120>;
size,height = <170>;
power-supply = <&lcd_en>;
status = “okay”;
panel-init-sequence = [
29 02 06 3C 01 09 00 07 00
29 02 06 14 01 06 00 00 00
29 02 06 64 01 0C 00 00 00
29 02 06 68 01 0C 00 00 00
29 02 06 6C 01 0C 00 00 00
29 02 06 70 01 0C 00 00 00
29 02 06 34 01 1F 00 00 00
29 02 06 10 02 1F 00 00 00
29 02 06 04 01 01 00 00 00
29 02 06 04 02 01 00 00 00
29 02 06 50 04 20 01 F0 03
29 02 06 54 04 20 00 50 00
29 02 06 58 04 00 05 30 00
29 02 06 5C 04 05 00 0D 00
29 02 06 60 04 D0 02 03 00
29 02 06 64 04 01 00 00 00
29 02 06 A0 04 06 80 44 00
29 02 06 A0 04 06 80 04 00
29 02 06 04 05 04 00 00 00
29 02 06 80 04 00 01 02 03
29 02 06 84 04 04 07 05 08
29 02 06 88 04 09 0A 0E 0F
29 02 06 8C 04 0B 0C 0D 10
29 02 06 90 04 16 17 11 12
29 02 06 94 04 13 14 15 1B
29 02 06 98 04 18 19 1A 06
29 02 06 9C 04 61 02 00 00
panel-exit-sequence = [
05 05 01 28
05 78 01 10
/*power_ctr: power_ctr {
rockchip,debug = <0>;
bl_en: bl_en {
gpios = <&gpio1 1 GPIO_ACTIVE_HIGH>; //GPIO1_A1
pinctrl-0 = <&lcd_panel_bl_en>;
rockchip,delay = <0>;
lcd_en: lcd_en {
gpios = <&gpio1 4 GPIO_ACTIVE_HIGH>; //GPIO1_A4
rockchip,delay = <10>;
lcd_pwr_en: lcd-pwr-en {
gpios = <&gpio3 16 GPIO_ACTIVE_HIGH>; //GPIO3_C0
pinctrl-0 = <&lcd_panel_pwr_en>;
lcd_rst: lcd-rst {
gpios = <&gpio2 27 GPIO_ACTIVE_LOW>; //GPIO2_D3
pinctrl-0 = <&lcd_panel_reset>;
rockchip,delay = <6>;
native-mode = <&timing0>;
timing0: timing0 {
clock-frequency = <64000000>; //@60
hactive = <1280>;
vactive = <720>;
hsync-len = <32>;
hback-porch = <80>;
hfront-porch = <48>;
vsync-len = <5>;
vback-porch = <13>;
vfront-porch = <3>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <0>;
pixelclk-active = <0>;
&route_dsi {
status = “okay”;
logo,mode = “center”;
&pwm0 {
status = “okay”;
&dsi_in_vopl {
status = “okay”;
&dsi_in_vopb {
status = “disabled”;
&cdn_dp {
&hdmi_dp_sound {
status = “okay”;
&i2c4 {
status = “okay”;
gsl3680: gsl3680@41 {
compatible = "gslX680";
reg = <0x41>;
screen_max_x = <1280>;
screen_max_y = <720>;
touch-gpio = <&gpio2 2 IRQ_TYPE_LEVEL_LOW>;
reset-gpio = <&gpio1 23 GPIO_ACTIVE_HIGH>;
gsl,fw = <1>;
flip-x = <1>;
flip-y = <0>;
swap-xy = <0>;
sensor@4c {
status = "disabled";
compatible = "gs_mc3230";
reg = <0x4c>;
type = <SENSOR_TYPE_ACCEL>;
irq_enable = <0>;
poll_delay_ms = <30>;
layout = <1>;
&rt5640 {
aux-det-adc-value = <1000>;
io-channels = <&saradc 4>, <&saradc 2>;
io-channel-names = “hp-det”, “aux-det”;
&sdmmc {
/delete-property/ vmmc-supply;
mmc-pwrseq = <&sdmmc_pwrseq>;
&spi1 {
status = “okay”;
&spi_wk2xxx {
status = “okay”;
&fusb0 {
&tcphy0 {
status = “okay”;
/delete-property/ extcon;
&u2phy0 {
status = “okay”;
u2phy0_otg: otg-port {
rockchip,vbus-always-on;
vbus-5v-gpios = <&gpio1 3 GPIO_ACTIVE_HIGH>;
status = "okay";
&usbdrd3_0 {
status = “okay”;
&usbdrd_dwc3_0 {
status = “okay”;
dr_mode = “host”;
&vcc3v3_pcie {
gpio = <&gpio0 13 GPIO_ACTIVE_HIGH>;
&pcie0 {
ep-gpios = <&gpio4 25 GPIO_ACTIVE_HIGH>;
&vcc3v3_3g {
gpio = <&gpio2 6 GPIO_ACTIVE_HIGH>;
&uart4 {
&dp_in_vopb {
&hdmi_in_vopb {
status = “okay”;
&hdmi_in_vopl {
&wdt {
&pinctrl {
leds {
led_power: led-power {
rockchip,pins =
<2 7 RK_FUNC_GPIO &pcfg_pull_none>;
led_user: led-user {
rockchip,pins =
<2 2 RK_FUNC_GPIO &pcfg_pull_none>;
pcie {
pcie_drv: pcie-drv {
rockchip,pins =
<0 13 RK_FUNC_GPIO &pcfg_pull_none>;
pcie_3g_drv: pcie-3g-drv {
rockchip,pins =
<2 6 RK_FUNC_GPIO &pcfg_pull_up>;
sdmmc-pwrseq {
sdcard_enable_h: sdcard-enable-h {
rockchip,pins =
<1 20 RK_FUNC_GPIO &pcfg_pull_none>;
lcd-panel {
/*lcd_panel_reset: lcd_panel_reset {
rockchip,pins = <2 27 RK_FUNC_GPIO &pcfg_pull_down>;
lcd_panel_pwr_en: lcd_panel_pwr_en {
rockchip,pins = <3 16 RK_FUNC_GPIO &pcfg_pull_down>;
lcd_panel_lcd_en: lcd-panel-lcd-en {
rockchip,pins = <1 4 RK_FUNC_GPIO &pcfg_pull_down>;
/*lcd_panel_bl_en: lcd_panel_bl_en {
rockchip,pins = <1 1 RK_FUNC_GPIO &pcfg_pull_down>;
