这同步更新都成功了,但是执行./build.sh进行编译的时候报错
SDK包名称:rv1126_rv1109_linux_release_20211022.tgz
SDK修改内容:未修改
Log日志:log.zip
processing option: allff
TARGET_ARCH=
TARGET_PLATFORM=
TARGET_UBOOT_CONFIG=
TARGET_SPL_CONFIG=
TARGET_KERNEL_CONFIG=
TARGET_KERNEL_DTS=
TARGET_TOOLCHAIN_CONFIG=
TARGET_BUILDROOT_CONFIG=
TARGET_RECOVERY_CONFIG=
TARGET_PCBA_CONFIG=
TARGET_RAMBOOT_CONFIG=
Skipping build_uboot for missing configs: RK_UBOOT_DEFCONFIG.
Skipping build_loader for missing configs: RK_LOADER_BUILD_TARGET.
Skipping build_kernel for missing configs: RK_KERNEL_DTS RK_KERNEL_DEFCONFIG.
Skipping build_toolchain for missing configs: RK_CFG_TOOLCHAIN.
Skipping build_rootfs for missing configs: RK_ROOTFS_IMG.
==========Start building recovery==========
config is
/home/wangbo/rv1126_rv1109_linux_release_20211022/device/rockchip/common/mk-ramdisk.sh: line 18: /home/wangbo/rv1126_rv1109_linux_release_20211022/device/rockchip/.BoardConfig.mk: No such file or directory
config for building recovery.img doesn’t exist, skip!
you take 0:00.00 to build recovery
====Build recovery ok!====
Running build_recovery succeeded.
Skipping build_ramboot for missing configs: RK_CFG_RAMBOOT.
Running build_all succeeded.
./mkfirmware.sh: line 18: /home/wangbo/rv1126_rv1109_linux_release_20211022/device/rockchip/.BoardConfig.mk: No such file or directory
ERROR: Running build_firmware failed!
ERROR: exit code 1 from line 1033:
./mkfirmware.sh $BOARD_CONFIG
这同步更新都成功了,但是执行./build.sh的时候报错,请问是什么原因?
log.zip (679 Bytes)
额,已解决。查看文档,执行:./build.sh lunch后可以编译了
