rk3308 ubuntu固件声卡问题
固件文件名称:教程生成固件
固件下载地址:无
Log日志:新建文本文档.zip
--------------------------------------- device #0
Name = rockchip,rk3308b-acodec: - (hw:0,0)
Host API = ALSA
Max inputs = 1, Max outputs = 1
Default low input latency = 0.0020
Default low output latency = 0.0020
Default high input latency = 0.0080
Default high output latency = 0.0080
Default sample rate = 192000.00
Supported standard sample rates
for half-duplex 16 bit 1 channel input =
None
for half-duplex 16 bit 1 channel output =
None
for full-duplex 16 bit 1 channel input, 1 channel output =
None
--------------------------------------- device #1
Name = Loopback: PCM (hw:7,0)
Host API = ALSA
None
None
None
--------------------------------------- device #2
Name = Loopback: PCM (hw:7,1)
这个是我按照教程做出的ubuntu系统Minimal固件 portaudio的读取上来的声卡信息,看着就有问题,全是1通道192k的。arecord可以录音但是alsa和portaudio打不开声卡设备
下面是声卡信息
Host API = ALSA
None
None
None
--------------------------------------- device #3
Name = sysdefault
Host API
新建文本文档.zip (462 Bytes)
