rv1126 进入uboot之后发现没有i2c工具,需要怎么移植进去
SDK包名称:sdk
SDK修改内容:无,log再下面,文件为空
Log日志:log.rar
Net:   eth0: ethernet@ffc40000
Hit key to stop autoboot('CTRL+C'):  0
=> i2c
Unknown command 'i2c' - try 'help'
=> help
?       - alias for 'help'
android_print_hdr- print android image header
atags   - Dump all atags
base    - print or set address offset
bdinfo  - print Board Info structure
bidram_dump- Dump bidram layout
boot    - boot default, i.e., run 'bootcmd'
boot_android- Execute the Android Bootloader flow.
boot_fit- Boot FIT Image from memory or boot/recovery partition
bootavb - Execute the Android avb a/b boot flow.
bootd   - boot default, i.e., run 'bootcmd'
bootm   - boot application image from memory
bootp   - boot image via network using BOOTP/TFTP protocol
bootrkp - Boot Linux Image from rockchip image type
bootz   - boot Linux zImage image from memory
cmp     - memory compare
coninfo - print console devices and information
cp      - memory copy
crc32   - checksum calculation
crypto_sum- crypto checksum engine
dhcp    - boot image via network using DHCP/TFTP protocol
dm      - Driver model low level access
download- enter rockusb/bootrom download mode
dump_irqs- Dump IRQs
dump_resource- dump resource list
echo    - echo args to console
editenv - edit environment variable
env     - environment handling commands
exit    - exit script
ext2load- load binary file from a Ext2 filesystem
ext2ls  - list files in a directory (default /)
ext4load- load binary file from a Ext4 filesystem
ext4ls  - list files in a directory (default /)
ext4size- determine a file's size
false   - do nothing, unsuccessfully
fastboot- use USB or UDP Fastboot protocol
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls   - list files in a directory (default /)
fatsize - determine a file's size
fatwrite- write file into a dos filesystem
fdt     - flattened device tree utility commands
fstype  - Look up a filesystem type
go      - start application at address 'addr'
gpt     - GUID Partition Table
help    - print command description/usage
iomem   - Show iomem data by device compatible(high priority) or node name
lcdputs - print string on video framebuffer
load    - load binary file from a filesystem
loop    - infinite loop on address range
md      - memory display
mdio    - MDIO utility commands
mii     - MII utility commands
mm      - memory modify (auto-incrementing address)
mmc     - MMC sub system
mmcinfo - display MMC info
mtd     - MTD utils
mtd_blk - MTD Block device sub-system
mw      - memory write (fill)
nand    - NAND sub-system
nboot   - boot from NAND device
nm      - memory modify (constant address)
part    - disk partition related commands
ping    - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
pxe     - commands to get and boot from pxe files
rbrom   - Perform RESET of the CPU
reboot  - Perform RESET of the CPU, alias of 'reset'
reset   - Perform RESET of the CPU
rkimgtest- Test if storage media have rockchip image
rockchip_show_bmp- load and display bmp from resource partition
rockchip_show_logo- load and display log from resource partition
rockusb - Use the rockusb Protocol
run     - run commands in an environment variable
save    - save file to a filesystem
setcurs - set cursor position within screen
setenv  - set environment variables
sf      - SPI flash sub-system
showvar - print local hushshell variables
source  - run script from memory
sspi    - SPI utility command
sysboot - command to get and boot from syslinux files
sysmem_dump- Dump sysmem layout
sysmem_search- Search a available sysmem region
test    - minimal test like /bin/sh
tftp    - download image via network using TFTP protocol
tftpbootm- tftpbootm aosp/uImage/FIT image via network using TFTP protocol
tftpflash- flash image via network using TFTP protocol
tftpput - TFTP put command, for uploading files to a server
true    - do nothing, successfully
ums     - Use the UMS [USB Mass Storage]
usb     - USB sub-system
usbboot - boot from USB device
version - print monitor, compiler and linker version
log.rar (74 Bytes)
uboot 里面打开 i2c 就可以了。进入到 uboot 目录执行: make ARCH=arm menuconfig。找到 i2c 配置,将其打开。编译烧录就能在uboot看到i2c工具了。
799959745 发表于 2022-11-26 17:59
uboot 里面打开 i2c 就可以了。进入到 uboot 目录执行: make ARCH=arm menuconfig。找到 i2c 配置,将其打 …
可以了,谢谢大佬的回复
