固件文件名称:AIO-3588SJD4-BE45-A1_Buildroot_v1.0.4b_221125.img
固件下载地址:百度网盘
Log日志:01_WIFIBT日志打印.zip
buildroot版本有关WIFI&BT调不通的测试,统计了以下信息:
一、ifconfig -a 找不到wlan0
二、使用/rockchip-test脚本测试,打印信息如下
root@RK3588:/rockchip-test# ./rockchip_test.sh
*** * ROCKCHIPS TEST TOOLS * ***
*** * V1.1 updated on 20220808 * ***
cpu test: 1 (cpufreq stresstest)
ddr test: 2 (memtester & stressapptest)
gpu test: 3 (use glmark2)
npu test: 4 (npu2:rk3588)
auto reboot test: 5 (reboot tests)
suspend_resume test: 6 (suspend & resume)
nand power lost test: 7 (S5 stress tests)
flash stress test: 8 (flash tests)
audio test: 9 (audio tests)
recovery test: 10 (default wipe all)
bluetooth test: 11 (bluetooth on&off test)
wifi test: 12 (wifi on&off test)
ethernet test: 13 (ethernet tests)
camera test: 14 (use rkaiq_demo)
video test: 15 (use gstreamer-wayland and app_demo)
chromium test: 16 (chromium with video hardware acceleration)
please input your test moudle:
11
root@RK3588:/rockchip-test# killall: brcm_patchram_plus1: no process killed
[ 105.472622] [BT_RFKILL]: bt shut off power
[ 105.496625] [BT_RFKILL]: bt shut off power
[ 106.528174] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host high!
[ 106.556369] [BT_RFKILL]: ENABLE UART_RTS
[ 106.662984] [BT_RFKILL]: DISABLE UART_RTS
[ 106.663102] [BT_RFKILL]: bt turn on power
[ 106.663162] [BT_RFKILL]: Request irq for bt wakeup host
[ 106.663246] [BT_RFKILL]: ** disable irq
[ 106.663741] [BT_RFKILL]: proc_rk_set_power: set bt wake_host high!
[ 106.689892] [BT_RFKILL]: ENABLE UART_RTS
[ 106.796561] [BT_RFKILL]: DISABLE UART_RTS
[ 106.796683] [BT_RFKILL]: bt turn on power
[ 106.796814] [BT_RFKILL]: Request irq for bt wakeup host
[ 106.796881] [BT_RFKILL]: ** disable irq
###AMPAK FW Auto detection patch version = [v1.1 20161117]###
FW folder path = /system/etc/firmware
port --no2bytes could not be opened, error 2
Can’t get device info: No such device
The bt test fail !!!
12
ifconfig: SIOCGIFFLAGS: No such device
The wifi test fail !!!
三、使用SDK中的/external/rkwifibt-app中的例程rkwifibt_test,报错信息如下
尝试使用SDK中的librkwifibt.so替换开发板/usr/bin目录下的该动态库,现象一致
# rkwifibt_test bluetooth
Please input number or help to run: 01
bt_test_bluetooth_init: bt_test_bluetooth_init_thread: BT BLUETOOTH INIT
ble_name_len: ROCKCHIP_AUDIO_BLE(18)
Please input number or help to run: ++++++++++ RK_BT_STATE_TURNING_ON ++++++++++
[ 195.683860] [BT_RFKILL]: bt shut off power
[ 195.727481] [BT_RFKILL]: proc_rk_set_power: set bt wake_host high!
[ 195.753055] [BT_RFKILL]: ENABLE UART_RTS
[ 195.859741] [BT_RFKILL]: DISABLE UART_RTS
[ 195.859792] [BT_RFKILL]: bt turn on power
[ 195.859814] [BT_RFKILL]: Request irq for bt wakeup host
[ 195.859843] [BT_RFKILL]: ** disable irq
cat: ‘/sys/bus/sdio/devices/*/uevent’: No such file or directory
四、可否提供进一步的测试步骤?
第三项中有报错“cat: ‘/sys/bus/sdio/devices/*/uevent’: No such file or directory”
AP6275P是pcie接口的,应该是哪里没配置对,怀疑是哪里的配置开关没打开,一直没找到,
可否给指导一下?附件日志中详细的信息
01_WIFIBT日志打印.zip (86.3 KB)
