现在看到了你们H.264硬编码&硬解码 http://www.t-firefly.com/zh/firenow/firefly_rk3288/case/2015/0529/3.html 的实现过程,本人也很想学习硬解码这方面,请问各位有没有谁有 编码: Camcodec.apk 解码: RTPclinet.apk 的源码?如果没有的话,有没有相关可以实现的帖子,本人正在学习在3288上构建硬解码这一块!
可以直接找Android的mediacodec的资料
好的!![]()
private final String TAG = “MediaCodeSample”;
/** 用来解码 /
private MediaCodec mMediaCodec;
/* 用来读取音频文件 */
private MediaExtractor extractor;
private MediaFormat format;
private String mime = null;
private int sampleRate = 0, channels = 0, bitrate = 0;
private long presentationTimeUs = 0, duration = 0;
public void decode(String url)
extractor = new MediaExtractor();
// 根据路径获取源文件
try
extractor.setDataSource(url);
} catch (Exception e)
Log.e(TAG, " 设置文件路径错误" + e.getMessage());
try
// 音频文件信息
format = extractor.getTrackFormat(0);
mime = format.getString(MediaFormat.KEY_MIME);
sampleRate = format.getInteger(MediaFormat.KEY_SAMPLE_RATE);
// 声道个数:单声道或双声道
channels = format.getInteger(MediaFormat.KEY_CHANNEL_COUNT);
// if duration is 0, we are probably playing a live stream
duration = format.getLong(MediaFormat.KEY_DURATION);
// System.out.println("歌曲总时间秒:"+duration/1000000);
bitrate = format.getInteger(MediaFormat.KEY_BIT_RATE);
Log.e(TAG, "音频文件信息读取出错:" + e.getMessage());
// 不要退出,下面进行判断
Log.d(TAG, "Track info: mime:" + mime + " 采样率sampleRate:" + sampleRate + " channels:" + channels + " bitrate:"
+ bitrate + " duration:" + duration);
// 检查是否为音频文件
if (format == null || !mime.startsWith("audio/"))
Log.e(TAG, "不是音频文件 end !");
return;
// 实例化一个指定类型的解码器,提供数据输出
// Instantiate an encoder supporting output data of the given mime type
mMediaCodec = MediaCodec.createDecoderByType(mime);
if (mMediaCodec == null)
Log.e(TAG, "创建解码器失败!");
return;
mMediaCodec.configure(format, null, null, 0);
mMediaCodec.start();
// 用来存放目标文件的数据
ByteBuffer[] inputBuffers = mMediaCodec.getInputBuffers();
// 解码后的数据
ByteBuffer[] outputBuffers = mMediaCodec.getOutputBuffers();
// 设置声道类型:AudioFormat.CHANNEL_OUT_MONO单声道,AudioFormat.CHANNEL_OUT_STEREO双声道
int channelConfiguration = channels == 1 ? AudioFormat.CHANNEL_OUT_MONO : AudioFormat.CHANNEL_OUT_STEREO;
Log.i(TAG, "channelConfiguration=" + channelConfiguration);
extractor.selectTrack(0);
// ==========开始解码=============
boolean sawInputEOS = false;
boolean sawOutputEOS = false;
final long kTimeOutUs = 10;
MediaCodec.BufferInfo info = new MediaCodec.BufferInfo();
while (!sawOutputEOS)
try
if (!sawInputEOS)
int inputBufIndex = mMediaCodec.dequeueInputBuffer(kTimeOutUs);
if (inputBufIndex >= 0)
ByteBuffer dstBuf = inputBuffers[inputBufIndex];
int sampleSize = extractor.readSampleData(dstBuf, 0);
if (sampleSize < 0)
Log.d(TAG, "saw input EOS. Stopping playback");
sawInputEOS = true;
sampleSize = 0;
} else
presentationTimeUs = extractor.getSampleTime();
mMediaCodec.queueInputBuffer(inputBufIndex, 0, sampleSize, presentationTimeUs,
sawInputEOS ? MediaCodec.BUFFER_FLAG_END_OF_STREAM : 0);
if (!sawInputEOS)
extractor.advance();
} else
Log.e(TAG, "inputBufIndex " + inputBufIndex);
} // !sawInputEOS
// decode to PCM and push it to the AudioTrack player
int res = mMediaCodec.dequeueOutputBuffer(info, kTimeOutUs);
if (res >= 0)
int outputBufIndex = res;
ByteBuffer buf = outputBuffers[outputBufIndex];
final byte[] chunk = new byte[info.size];
buf.get(chunk);
buf.clear();
if (chunk.length > 0)
// chunk解码后的音频流
// TODO:处理...
mMediaCodec.releaseOutputBuffer(outputBufIndex, false);
if ((info.flags & MediaCodec.BUFFER_FLAG_END_OF_STREAM) != 0)
Log.d(TAG, "saw output EOS.");
sawOutputEOS = true;
} else if (res == MediaCodec.INFO_OUTPUT_BUFFERS_CHANGED)
Log.w(TAG, "[AudioDecoder]output buffers have changed.");
} else if (res == MediaCodec.INFO_OUTPUT_FORMAT_CHANGED)
MediaFormat oformat = mMediaCodec.getOutputFormat();
Log.w(TAG, "[AudioDecoder]output format has changed to " + oformat);
} else
Log.w(TAG, "[AudioDecoder] dequeueOutputBuffer returned " + res);
} catch (RuntimeException e)
Log.e(TAG, "[decodeMP3] error:" + e.getMessage());
if (mMediaCodec != null)
mMediaCodec.stop();
mMediaCodec.release();
mMediaCodec = null;
if (extractor != null)
extractor.release();
extractor = null;
// clear source and the other globals
duration = 0;
mime = null;
sampleRate = 0;
channels = 0;
bitrate = 0;
presentationTimeUs = 0;
duration = 0;
你们官方是基于mediacodec做的么? 为何你们那个实时性那么好,一点都没有卡顿! 网上的硬解码代码在3288上跑很卡!
我也有点糊涂,放一下代码出来看看?
我现在也在做视频解码,多多交流啊
MeidaCodec的编码能正常跑,但是解码,从来没有跑成功过
