固件文件名称:ROC-RK3568-PC-BUILDROOT-GPT-20220222-1538.img
Log日志:log.rar
usb2.0口插入usb网卡(rtl8152),重启设备时启动异常缓慢,同时有异常log,而拔掉usb则启动正常,插入usb网卡启动时,部分log如下:
[ 2.878462] r8152 1-1:1.0 rename4: renamed from eth2
[ 2.906456] ssdbg >>> usb phy bus num = [2 | 3 | 1]
[ 2.906481] ssdbg kl_get_mac=ca:a0:67:aa:bb:cc, name=eth3
[ 2.907092] r8152 2-1.1:1.0: skip request firmware
[ 2.912298] r8152 2-1.1:1.0 eth3: v1.11.11
[ 3.043612] r8152 2-1.1:1.0 rename5: renamed from eth3
[ 3.148120] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 3.330161] phy phy-fe8a0000.usb2-phy.6: charger = USB_SDP_CHARGER
[ 4.161809] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 4.888225] fusb302 0-0022: PD disabled
[ 5.175200] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 6.188366] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 7.201691] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 8.215019] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 9.228343] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 10.241661] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 11.255002] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 12.268345] rk-pcie 3c0000000.pcie: PCIe Link Fail
[ 12.268422] rk-pcie 3c0000000.pcie: failed to initialize host
[ 32.241720] vcc3v3_lcd0_n: disabling
[ 32.241799] vcc3v3_lcd1_n: disabling
[ 32.241837] pcie30_3v3: disabling
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Running /scripts/local-premount … done.
Warning: fsck not present, so skipping root file system
[ 95.175069] EXT4-fs (mmcblk0p7): mounted filesystem with ordered dadone.
ta mode. Opts: (null)
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … Warning: overlayroot: configuring overlayroot with driver=overlay mode=device opts=‘dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ per kernel cmdline
[ 95.411579] EXT4-fs (mmcblk0p8): recovery complete
[ 95.412612] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
Success: overlayroot: configured root with ‘device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ using overlay per kernel cmdline
Warning: Something odd, no /lib/modules/4.19.193 in initramfs.
log.rar (1.22 KB)
