最新sdk, 最新hdmiin源码与我的编辑器版本存在差异,我ad编辑器不升级(有其他项目调试) ,所以麻烦你们给一个编译好的公版的hdmi-in的apk
我把你们源码放入,packages/apps中,HdmiInDemo工程编译失败。
直接编译失败:
device/rockchip/rk356x/device.mk was modified, regenerating…
[100% 730/730] initializing build system …
device/rockchip/common/prebuild.mk:2: warning: Generating manifest snapshot at out/commit_id.xml…
device/rockchip/common/prebuild.mk:3: warning: You can disable this by removing this and setting BOARD_RECORD_COMMIT_ID := false in BoardConfig.mk
[ 72% 732/1016] including RKDocs/common/hdmi-in/apk/HdmiInDemo/Android.mk …
FAILED:
RKDocs/common/hdmi-in/apk/HdmiInDemo/Android.mk: error: droidipcam: Must specify LOCAL_SDK_VERSION or LOCAL_PRIVATE_PLATFORM_APIS,
In file included from out/soong/Android-rk3566_firefly_aiojd4.mk:786341:
In file included from RKDocs/common/hdmi-in/apk/HdmiInDemo/Android.mk:21:
In file included from build/make/core/package.mk:58:
In file included from build/make/core/package_internal.mk:370:
In file included from build/make/core/java.mk:173:
build/make/core/sdk_check.mk:21: error: done.
10:50:40 ckati failed with: exit status 1
单独编译 rkCamera2 也报错,你们连个文档都没有,真Low。
will have user root-level access to files
[W][2022-12-16T11:07:11+0800][26886] void cmdline::logParams(nsjconf_t *)():260 Process will be GID/EGID=0 in the global user namespace, and will have group root-level access to files
[100% 15/15] initializing build system …
[ 5% 17/302] including RKDocs/common/hdmi-in/apk/HdmiInDemo/Android.mk …
FAILED:
11:07:30 ckati failed with: exit status 1
ls RKDocs/common/hdmi-in/
apk Rockchip_Developer_Guide_HDMI_IN_Based_On_CameraHal1_CN.pdf Rockchip_Developer_Guide_HDMI_IN_Based_On_CameraHal3_CN.pdf
我没有问rk628d的问题了,我已搞定了 ,包括yuv看到画面了。 我现在要hdminin的apk。你能好好沟通吗
rk628d的问题,我在企业微信里问过了,你们费用太高,而且要二周,我自己用了三四天就调试通过了。rk628d的问题翻篇了。 拜托。
经过这次摩擦后,我也了解你们技术支持的实力杠杠的吓人,我也不在问过深的问题了。我只问片面的问题,知道就麻烦回复。不知道也麻烦回复不清楚。我也适当刹车。
