SDK包名称:MX6012-IS
SDK修改内容:IPQ6010 intrinsically Safety WiFi Motherboard dual-band 802.11ax Wireless Embedded board MX6012-IS - Nanjing Maxon O.E. Tech. Co., Ltd
Log日志:Maxon_MX-A6032-MEIS_Safe_dual-band_Wifi6_industrial-grade_wireless_AP_20221027.rar
KEYWORDS: AP, Wireless Access Point Board, 802.11ax wifi6, Intrinsic Safety, 2×2 MIMO, 2.4GHz 5.8GHz Dual-Band, IPQ6010, QCA8075, QCN5052, QCN5022
Originally Posted By me on www.mxcomm.cn
FEATURES:
- Chipset: IPQ6010+QCA8075+QCN5052+QCN5022
- 2.4GHz rate 573.5Mbps, 5.8GHz rate 1200Mbps
- Support access point, client, WDS access point, WDS client mode
- Support 2×2MIMO, dual-band combined MMCX connector
- Support extended Uart/RS-485/5G cellular module
- Includ 3* 1Gbps ethernet RJ45 Port and 2* 1Gbps SFP
- Professional intrinsic safety power supply design, with under-voltage protection, output short-circuit, over-current, over-voltage protection, input anti-reverse connection function
- WIFI stand-alone power consumption ≤ 15W, extended 5G network power consumption ≤ 18W;
- DC or 2-PIN 5.08mm pitch terminals for power supply, wide voltage range as 9~36V
- Meet the intrinsic safety requirement
- Support AC management
DESCRIPTIONS:
MX6012-IS WiFi6 intrinsic safety Dual-Band Wireless Access Point Board supports the IEEE 802.11a/b/g/n/ac/ax protocol with a maximum rate of 1773.5Mbps.
It has an M-Pcie (USB3.0) interface and easy access to 5G/4G cellular modules.
Support multiple working modes of AP/Client/Mesh to meet different application requirements.
It is flexibly suitable for different network access schemes, supports wireless positioning function, supports KVR seamless roaming technology, automatically detects and seamlessly switches, and users can roam without perception within the coverage of network signals.
MX6012-IS provides 3* 1Gbps ethernet RJ45 Port and 2* 1Gbps SFP 2.4G/5.8G dual-band combined antenna ports, which support access to various types of antennas. The protection design of the power supply and interface allows the MX6012-IS to provide a stable and reliable wireless network in harsh environments.
SPECIFICATIONS:
External FEM: QPF4588A+QPF4288A
Memory: 1GB DDR3+ 16MB Nor Flash+ 128MB Nand Flash
Frequency Range: 2.4G: 2412MHz~2472MHz;
5.8G: 5180MHz~5320MHz, 5745MHz~5825MHz
Wireless Rate: 1773.5Mbps
Data Modulation Method: 11n: 64-QAM MCS7
11ac: 256-QAM MCS9
11ax: 1024-QAM MCS11
Transmit Power: 2.4G (11ax): HT40: 24dBm@MCS0
5.8G (11ax): HT80: 24dBm@MCS0
Receive Sensitivity: 11ax:
HE20 MCS0 <-95dBm / MCS11 <-62dBm
HE40 MCS0 <-89dBm / MCS11 <-60dBm
HE80 MCS0 <-86dBm / MCS11 <-56dBm
Network Port: 3x1Gbps RJ45+2x1Gbps SFP
Supply Voltage: 9V~36V
Machine Power Consumption: WiFi power consumption≤15W,
Extended 5G Internet power consumption≤18W
Antenna Interface: 2xMMCX, dual frequency combined
UART: Uart interface, 3Pin
RS-485: RS-485 3Pin
LTE Interface: 4G/5G LTE Slot Mini-PCIe (USB3.0 bus)
SIM Card Slot: Micro SIM
Indicator Light: Status indicator, bicolor
Button: Reset
Size (mm): 160 x 136 x 21.5
Color: Matte black
Operating Temperature: -20℃ to +70℃
Storage Temperature: -40℃ to +90℃
Operating Humidity (non-condensing): 10% to 95%
Storage Humidity (non-condensing): 5% to 90%
Certification Standards: RoHS/REACH
Maxon_MX-A6032-MEIS_Safe_dual-band_Wifi6_industrial-grade_wireless_AP_20221027.rar (934 KB)
