Camera sensor 抓图出现 mipi报错 sensor(imx415),rv1126
SDK包名称:sdk2.2.5
SDK修改内容:no
Log日志:dmesg.rar
[ 2.077224] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:1
[ 2.077301] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:2
[ 2.077321] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:3
[ 2.077334] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:4
dmesg.rar (14.7 KB)
DDR4, 328MHz
BW=32 Col=10 Bk=4 BG=2 CS0 Row=15 CS=1 Die BW=16 Size=1024MB
change to: 328MHz
change to: 528MHz
change to: 784MHz
change to: 924MHz(final freq)
out
U-Boot SPL board init
U-Boot SPL 2017.09-gaaca6ffec1-211203 #zzz (Dec 03 2021 - 18:59:23)
unknown raw ID phN
Trying to boot from MMC2
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
No misc partition
spl: partition error
Trying fit image at 0x4000 sector
Not fit magic
Trying fit image at 0x5000 sector
Not fit magic
Trying to boot from MMC1
## Verified-boot: 0
## Checking optee 0x08400000 (gzip @0x08600000) ... sha256(ebd51cbfad...) + sha256(bae962097a...) + OK
## Checking uboot 0x00600000 (gzip @0x00800000) ... sha256(90cbb059ad...) + sha256(c04af33a15...) + OK
## Checking fdt 0x006b85d8 ... sha256(a362d022de...) + OK
Jumping to U-Boot(0x00600000) via OP-TEE(0x08400000)
Total: 212.469 ms
I/TC:
I/TC: cpu feature:0x0
I/TC: RV1126 SoC
I/TC: cpu_st=0xe0
I/TC: Next entry point address: 0x00600000
I/TC: OP-TEE version: 3.13.0-515-g7b4275734 #zhangzj (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 Wed Aug  4 03:30:34 UTC 2021 arm
U-Boot 2017.09-gd403b1ca8a-210914-dirty #root (Dec 20 2022 - 23:22:24 -0800)
Model: Rockchip RV1126 Evaluation Board
PreSerial: 2, raw, 0xff570000
DRAM:  1021.7 MiB
Sysmem: init
Relocation Offset: 00000000
Relocation fdt: 3bbf93b0 - 3bbfedd8
CR: M/C/I
dwmmc@ffc50000: 0, dwmmc@ffc60000: 1
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: None
DTB: rk-kernel.dtb
HASH(c): OK
io-domain: OK
Can't get crtc id, default set to id = 0
Model: Rockchip RV1126 EVB DDR3 V13 Board
Using display timing dts
dsi@ffb30000:  detailed mode clock 65000 kHz, flags[a]
    H: 0720 0768 0776 0828
    V: 1280 1296 1302 1317
bus_format: 100e
final DSI-Link bandwidth: 480 Mbps x 4
  apll 816000 KHz
  dpll 462000 KHz
  gpll 1188000 KHz
  cpll 500000 KHz
  hpll 1400000 KHz
  aclk_pdbus 500000 KHz
  hclk_pdbus 198000 KHz
  pclk_pdbus 99000 KHz
  aclk_pdphp 297000 KHz
  hclk_pdphp 198000 KHz
  hclk_pdaudio 148500 KHz
  hclk_pdcore 198000 KHz
  pclk_pdpmu 99000 KHz
Net:   eth0: ethernet@ffc40000
Hit key to stop autoboot('CTRL+C'):  0
## Booting FIT Image at 0x3b419580 with size 0x005dce00
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at 3b419580 ...
   Using 'conf' configuration
optee api revision: 2.0
## Verified-boot: 0
   Trying 'kernel' kernel subimage
     Description:  unavailable
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x3b430980
     Data Size:    6052032 Bytes = 5.8 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x02008000
     Entry Point:  0x02008000
     Hash algo:    sha256
     Hash value:   d286d605bd15a98c1e072ea542d81b3ff43177c227b67e0caf841b2c11468297
   Verifying Hash Integrity ... sha256+ OK
## Loading fdt from FIT Image at 3b419580 ...
   Trying 'fdt' fdt subimage
     Type:         Flat Device Tree
     Data Start:   0x3b419d80
     Data Size:    93065 Bytes = 90.9 KiB
     Architecture: ARM
     Load Address: 0x08300000
     Hash algo:    sha256
     Hash value:   64b2d32b8db298e90516c790322067db1428872afcd57dc0f839086db703dbb7
   Loading fdt from 0x08300000 to 0x08300000
   Booting using the fdt blob at 0x08300000
   Loading Kernel Image from 0x3b430980 to 0x02008000 ... OK
  'reserved-memory' ramoops@8000000: addr=8000000 size=100000
   Using Device Tree in place at 08300000, end 08319b88
failed to reserve drm-cubic-lut memory
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x08648000 - 0x40000000 (size: 0x379b8000)
Total: 387.288 ms
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Linux version 4.19.111 (root@wallace) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 SMP PREEMPT Wed Dec 21 17:32:22 PST 2022
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Rockchip RV1126 EVB DDR3 V13 Board
[    0.000000] earlycon: uart8250 at MMIO32 0xff570000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x3f800000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x1dc00000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node isp, compatible id shared-dma-pool
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 15 pages/cpu s32140 r8192 d21108 u61440
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 259512
[    0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal  rootwait earlycon=uart8250,mmio32,0xff570000 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 snd_aloop.index=7
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 488524K/1046240K available (8192K kernel code, 332K rwdata, 1892K rodata, 1024K init, 270K bss, 25236K reserved, 532480K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xb0000000 - 0xf0000000   (1024 MB)
[    0.000000]     pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
[    0.000000]     modules : 0xaf000000 - 0xafe00000   (  14 MB)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
[    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 333 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 271 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: random: get_random_bytes called from start_kernel+0x324/0x4a4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000758] Switching to timer-based delay loop, resolution 41ns
[    0.002532] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.003496] pid_max: default: 4096 minimum: 301
[    0.004104] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.004733] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.006053] CPU: Testing write buffer coherency: ok
[    0.006865] /cpus/cpu@f00 missing clock-frequency property
[    0.007393] /cpus/cpu@f01 missing clock-frequency property
[    0.007917] /cpus/cpu@f02 missing clock-frequency property
[    0.008440] /cpus/cpu@f03 missing clock-frequency property
[    0.008959] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.010228] Setting up static identity map for 0x100000 - 0x100060
[    0.010971] rcu: Hierarchical SRCU implementation.
[    0.012063] smp: Bringing up secondary CPUs ...
[    0.014070] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.015737] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.017417] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.017554] smp: Brought up 1 node, 4 CPUs
[    0.019533] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.020144] CPU: All CPU(s) started in SVC mode.
[    0.021376] devtmpfs: initialized
[    0.047477] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.048815] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.049731] futex hash table entries: 16 (order: -2, 1024 bytes)
[    0.050498] pinctrl core: initialized pinctrl subsystem
[    0.052134] NET: Registered protocol family 16
[    0.053125] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.055759] cpuidle: using governor menu
[    0.056161] Registered FIQ tty driver
[    0.057041] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.057809] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.060522] console [pstore-1] enabled
[    0.061124] pstore: Registered ramoops as persistent store backend
[    0.061754] ramoops: attached 0x100000@0x8000000, ecc: 0/0
[    0.107581] cryptd: max_cpu_qlen set to 1000
[    0.108832] fiq debugger fiq mode enabled
[[    0.109617] console [ttyFIQ0] enabled
[    0.110300] bootconsole [uart8250] disabled
[    0.110957] Registered fiq debugger ttyFIQ0
[    0.111582] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    0.116138] vcc_sd: supplied by vcc3v3_sys
[    0.117992] rk_iommu ffb00f00.iommu: version = 1
[    0.118588] rk_iommu ffb20800.iommu: version = 1
[    0.119075] rk_iommu ffb51a00.iommu: version = 1
[    0.119631] rk_iommu ffb60e00.iommu: version = 1
[    0.120251] rk_iommu ffb80480.iommu: version = 1
[    0.120810] rk_iommu ffb90800.iommu: version = 1
[    0.121262] rk_iommu ffbb0f00.iommu: version = 1
[    0.122356] SCSI subsystem initialized
[    0.122678] usbcore: registered new interface driver usbfs
[    0.122773] usbcore: registered new interface driver hub
[    0.122951] usbcore: registered new device driver usb
[    0.123060] media: Linux media interface: v0.10
[    0.123130] videodev: Linux video capture interface: v2.00
[    0.123199] pps_core: LinuxPPS API ver. 1 registered
[    0.123222] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.123264] PTP clock support registered
[    0.124630] Advanced Linux Sound Architecture Driver Initialized.
[    0.125306] Bluetooth: Core ver 2.22
[    0.125390] NET: Registered protocol family 31
[    0.125415] Bluetooth: HCI device and connection manager initialized
[    0.125494] Bluetooth: HCI socket layer initialized
[    0.125526] Bluetooth: L2CAP socket layer initialized
[    0.125586] Bluetooth: SCO socket layer initialized
[    0.126051] rockchip-cpuinfo cpuinfo: SoC            : 11260000
[    0.126087] rockchip-cpuinfo cpuinfo: Serial         : f662c2ca9d016108
[    0.126988] clocksource: Switched to clocksource arch_sys_counter
[    0.129561] NET: Registered protocol family 2
[    0.130541] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.130602] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.130760] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.130963] TCP: Hash tables configured (established 8192 bind 8192)
[    0.131110] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.131185] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.131435] NET: Registered protocol family 1
[    0.133194] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.135798] Initialise system trusted keyrings
[    0.136039] workingset: timestamp_bits=29 max_order=17 bucket_order=0
[    0.143285] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.146084] Key type asymmetric registered
[    0.146118] Asymmetric key parser 'x509' registered
[    0.146185] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.146213] io scheduler noop registered
[    0.146235] io scheduler deadline registered
[    0.146407] io scheduler cfq registered (default)
[    0.146436] io scheduler mq-deadline registered
[    0.146458] io scheduler kyber registered
[    0.146607] io scheduler bfq registered
[    0.150643] phy phy-ff4c0000.usb2-phy.1: Failed to get VBUS supply regulator
[    0.152541] phy phy-ff4c8000.usb2-phy.2: Linked as a consumer to regulator.7
[    0.155756] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.155875] pwm-backlight backlight: Linked as a consumer to regulator.0
[    0.156265] mpp_service mpp-srv: 92c80ddf68f6 author: Yandong Lin 2021-08-10 video: rockchip: mpp: workaround patch for rv1126 iommu issue
[    0.156298] mpp_service mpp-srv: probe start
[    0.157277] iommu: Adding device ffb80000.rkvdec to group 4
[    0.157323] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
[    0.157527] mpp_rkvdec ffb80000.rkvdec: probing start
[    0.158127] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
[    0.158160] rkvdec_init:1190: No niu aclk reset resource define
[    0.158189] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
[    0.158210] rkvdec_init:1193: No niu hclk reset resource define
[    0.158524] mpp_rkvdec ffb80000.rkvdec: probing finish
[    0.159318] iommu: Adding device ffbb0000.rkvenc to group 6
[    0.159373] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
[    0.159675] mpp_rkvenc ffbb0000.rkvenc: probing start
[    0.160434] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to regulator.10
[    0.160510] mpp_rkvenc ffbb0000.rkvenc: bin=0
[    0.160564] mpp_rkvenc ffbb0000.rkvenc: leakage=2.0
[    0.160652] mpp_rkvenc ffbb0000.rkvenc: Failed to get pvtm
[    0.160703] mpp_rkvenc ffbb0000.rkvenc: bin-scale=37
[    0.161261] mpp_rkvenc ffbb0000.rkvenc: avs=0
[    0.161734] mpp_rkvenc ffbb0000.rkvenc: failed to find power_model node
[    0.161769] mpp_rkvenc ffbb0000.rkvenc: failed to initialize power model
[    0.162391] mpp_rkvenc ffbb0000.rkvenc: probing finish
[    0.163115] iommu: Adding device ffb90400.vdpu to group 5
[    0.163174] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommu
[    0.163279] mpp_vdpu2 ffb90400.vdpu: probe device
[    0.163899] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[    0.163949] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[    0.164195] mpp_vdpu2 ffb90400.vdpu: probing finish
[    0.164818] iommu: Adding device ffb90000.vepu to group 5
[    0.164874] mpp_vepu2 ffb90000.vepu: Linked as a consumer to ffb90800.iommu
[    0.165004] mpp_vepu2 ffb90000.vepu: probe device
[    0.165494] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[    0.165532] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[    0.165808] mpp_vepu2 ffb90000.vepu: probing finish
[    0.166334] iommu: Adding device ffb20000.iep to group 1
[    0.166388] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb20800.iommu
[    0.166506] mpp-iep2 ffb20000.iep: probe device
[    0.167188] mpp-iep2 ffb20000.iep: allocate roi buffer failed
[    0.167401] mpp-iep2 ffb20000.iep: probing finish
[    0.167668] mpp_service mpp-srv: probe success
[    0.172756] dma-pl330 ff4e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.172798] dma-pl330 ff4e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.174841] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    0.175713] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    0.176596] ff560000.serial: ttyS0 at MMIO 0xff560000 (irq = 32, base_baud = 1500000) is a 16550A
[    0.178752] random: fast init done
[    0.179145] random: crng init done
[    0.179521] iommu: Adding device ffb00000.vop to group 0
[    0.179576] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
[    0.183635] rockchip-drm display-subsystem: Linked as a consumer to ffb00000.vop
[    0.184766] rockchip-drm display-subsystem: Linked as a consumer to ffb30000.dsi
[    0.186091] rockchip-drm display-subsystem: devfreq is not set
[    0.186559] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093bf40)
[    0.186631] dw-mipi-dsi ffb30000.dsi: [drm:dw_mipi_dsi_bind] *ERROR* Failed to find panel or bridge: -517
[    0.186666] rockchip-drm display-subsystem: failed to bind ffb30000.dsi (ops 0xb094266c): -517
[    0.186928] rockchip-drm display-subsystem: master bind failed: -517
[    0.192086] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.1
[    0.192151] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsp not found, using dummy regulator
[    0.192244] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.0
[    0.192292] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsn not found, using dummy regulator
[    0.193525] zram: Added device: zram0
[    0.195592] libphy: Fixed MDIO Bus: probed
[    0.197620] rk_gmac-dwmac ffc40000.ethernet: no regulator found
[    0.197663] rk_gmac-dwmac ffc40000.ethernet: clock input or output? (input).
[    0.197685] rk_gmac-dwmac ffc40000.ethernet: TX delay(0x40).
[    0.197716] rk_gmac-dwmac ffc40000.ethernet: RX delay(0x2c).
[    0.197745] rk_gmac-dwmac ffc40000.ethernet: integrated PHY? (no).
[    0.197830] rk_gmac-dwmac ffc40000.ethernet: clock input from PHY
[    0.202877] rk_gmac-dwmac ffc40000.ethernet: init for RGMII
[    0.203146] rk_gmac-dwmac ffc40000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    0.203172] rk_gmac-dwmac ffc40000.ethernet:         DWMAC4/5
[    0.203198] rk_gmac-dwmac ffc40000.ethernet: DMA HW capability register supported
[    0.203223] rk_gmac-dwmac ffc40000.ethernet: RX Checksum Offload Engine supported
[    0.203246] rk_gmac-dwmac ffc40000.ethernet: TX Checksum insertion supported
[    0.203268] rk_gmac-dwmac ffc40000.ethernet: Wake-Up On Lan supported
[    0.203333] rk_gmac-dwmac ffc40000.ethernet: TSO supported
[    0.203359] rk_gmac-dwmac ffc40000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    0.203384] rk_gmac-dwmac ffc40000.ethernet: TSO feature enabled
[    0.337038] libphy: stmmac: probed
[    0.340599] dwc3 ffd00000.dwc3: Failed to get clk 'ref': -2
[    0.345957] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.345996] ehci-platform: EHCI generic platform driver
[    0.349574] ehci-platform ffe00000.usb: EHCI Host Controller
[    0.349647] ehci-platform ffe00000.usb: new USB bus registered, assigned bus number 1
[    0.349827] ehci-platform ffe00000.usb: irq 68, io mem 0xffe00000
[    0.360341] ehci-platform ffe00000.usb: USB 2.0 started, EHCI 1.00
[    0.360641] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.360677] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.360702] usb usb1: Product: EHCI Host Controller
[    0.360726] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[    0.360749] usb usb1: SerialNumber: ffe00000.usb
[    0.361492] hub 1-0:1.0: USB hub found
[    0.361564] hub 1-0:1.0: 1 port detected
[    0.362327] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.362369] ohci-platform: OHCI generic platform driver
[    0.362905] ohci-platform ffe10000.usb: Generic Platform OHCI controller
[    0.362965] ohci-platform ffe10000.usb: new USB bus registered, assigned bus number 2
[    0.363127] ohci-platform ffe10000.usb: irq 69, io mem 0xffe10000
[    0.421289] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[    0.421322] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.421342] usb usb2: Product: Generic Platform OHCI controller
[    0.421362] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[    0.421399] usb usb2: SerialNumber: ffe10000.usb
[    0.422111] hub 2-0:1.0: USB hub found
[    0.422200] hub 2-0:1.0: 1 port detected
[    0.423908] usbcore: registered new interface driver usb-storage
[    0.424702] i2c /dev entries driver
[    0.427942] <<GTP-INF>>[gt1x_ts_probe:537] GTP Driver Version: V1.4<2015/07/10>
[    0.427979] <<GTP-INF>>[gt1x_ts_probe:538] GTP I2C Address: 0x14
[    0.428123] <<GTP-ERR>>[gt1x_parse_dt:334] vdd_ana not specified, fallback to power-supply
[    0.428249] Goodix-TS-GT1X 5-0014: Linked as a consumer to regulator.1
[    0.428300] <<GTP-ERR>>[gt1x_request_io_port:407] Failed to request GPIO:74, ERRNO:-16
[    0.428324] <<GTP-ERR>>[gt1x_ts_probe:558] GTP request IO port failed.
[    0.428418] Goodix-TS-GT1X 5-0014: Dropping the link to regulator.1
[    0.428481] Goodix-TS-GT1X: probe of 5-0014 failed with error -16
[    0.428660] ircut cam_ircut: driver version: 00.01.00
[    0.428909] ircut cam_ircut: failed get pulse-width,use dafult value 100
[    0.429215] ircut cam_ircut: probe successful!
[    0.430105] rockchip-mipi-csi2: probe success, v4l2_dev:(null)!
[    0.431464] rkcifhw ffae0000.rkcif: no iommu attached, using non-iommu buffers
[    0.431519] rkcifhw ffae0000.rkcif: assigned reserved memory node isp
[    0.431656] rkcif rkcif_dvp: rkcif driver version: v00.01.0a
[    0.431745] rkcif rkcif_dvp: attach to cif hw node
[    0.431774] rkcif rkcif_dvp: rkcif wait line 0
[    0.432819] rkcif_dvp: cif_subdev_notifier: no subdev be found!
[    0.432848] rkcif_dvp: Failed to register subdev notifier(-19)
[    0.433845] rkcif rkcif_dvp: detach to cif hw node
[    0.433962] rkcif rkcif_mipi_lvds: rkcif driver version: v00.01.0a
[    0.434062] rkcif rkcif_mipi_lvds: attach to cif hw node
[    0.434090] rkcif rkcif_mipi_lvds: rkcif wait line 0
[    0.435087] rkcif rkcif_mipi_lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[    0.435119] rockchip-mipi-csi2: Async registered subdev
[    0.437274] iommu: Adding device ffb50000.rkisp to group 2
[    0.437333] rkisp_hw ffb50000.rkisp: Linked as a consumer to ffb51a00.iommu
[    0.437583] rkisp_hw ffb50000.rkisp: is_thunderboot: 0
[    0.437607] rkisp_hw ffb50000.rkisp: Missing rockchip,grf property
[    0.437652] rkisp_hw ffb50000.rkisp: can't request region for resource [mem 0xffb50000-0xffb5ffff]
[    0.437973] rkisp_hw ffb50000.rkisp: assigned reserved memory node isp
[    0.438298] rkisp rkisp-vir0: rkisp driver version: v01.06.02
[    0.438534] rkisp rkisp-vir0: No memory-region-thunderboot specified
[    0.438776] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[    0.438820] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[    0.438850] rkisp rkisp-vir0: Entity type for entity rkisp-bridge-ispp was not initialized!
[    0.442453] iommu: Adding device ffb60000.rkispp to group 3
[    0.442515] rkispp_hw ffb60000.rkispp: Linked as a consumer to ffb60e00.iommu
[    0.442926] rkispp_hw ffb60000.rkispp: max input:0x0@0fps
[    0.442974] rkispp_hw ffb60000.rkispp: can't request region for resource [mem 0xffb60000-0xffb7ffff]
[    0.443213] rkispp_hw ffb60000.rkispp: failed to get cru reset
[    0.443482] rkispp rkispp-vir0: rkispp driver version: v01.06.02
[    0.446561] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.8
[    0.446623] rockchip-iodomain fe020000.syscon:io-domains: vccio2(3300000 uV) supplied by vcc_sd
[    0.446741] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.4
[    0.446787] rockchip-iodomain fe020000.syscon:io-domains: vccio3(1800000 uV) supplied by vcc_1v8
[    0.446909] rockchip-iodomain fe020000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    0.447089] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.6
[    0.447135] rockchip-iodomain fe020000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc3v3_sys
[    0.447263] rockchip-iodomain fe020000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    0.447390] rockchip-iodomain fe020000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc3v3_sys
[    0.447539] rockchip-iodomain fe020000.syscon:io-domains: pmuio0(3300000 uV) supplied by vcc3v3_sys
[    0.447665] rockchip-iodomain fe020000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_sys
[    0.450263] rockchip-thermal ff5f0000.tsadc: tsadc trimmed value = -4
[    0.450660] rockchip-thermal ff5f0000.tsadc: tsadc is probed successfully!
[    0.451112] rockchip-thermal ff5f8000.tsadc: tsadc trimmed value = -3
[    0.451363] rockchip-thermal ff5f8000.tsadc: tsadc is probed successfully!
[    0.452269] Bluetooth: HCI UART driver ver 2.3
[    0.452300] Bluetooth: HCI UART protocol H4 registered
[    0.452627] cpu cpu0: bin=0
[    0.452668] cpu cpu0: leakage=2.375
[    0.452800] cpu cpu0: Linked as a consumer to regulator.3
[    0.452931] cpu cpu0: Failed to set pvtm_volt
[    0.453009] cpu cpu0: Failed to get pvtm
[    0.453101] cpu cpu0: Dropping the link to regulator.3
[    0.453161] cpu cpu0: bin-scale=5
[    0.453520] cpu cpu0: Linked as a consumer to regulator.3
[    0.453604] cpu cpu0: Dropping the link to regulator.3
[    0.453879] cpu cpu0: Linked as a consumer to regulator.3
[    0.454774] core: _opp_supported_by_regulators: OPP minuV: 925000 maxuV: 1000000, not supported by regulator
[    0.454809] cpu cpu0: _opp_add: OPP not supported by regulators (1416000000)
[    0.454951] core: _opp_supported_by_regulators: OPP minuV: 975000 maxuV: 1000000, not supported by regulator
[    0.454980] cpu cpu0: _opp_add: OPP not supported by regulators (1512000000)
[    0.455102] cpu cpu0: avs=0
[    0.455454] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    0.455502] cpu cpu0: failed to read out thermal zone (-22)
[    0.456205] cpu cpu0: failed to find power_model node
[    0.456327] cpuidle: enable-method property 'psci' found operations
[    0.456507] cpuidle: enable-method property 'psci' found operations
[    0.456621] cpuidle: enable-method property 'psci' found operations
[    0.456697] cpuidle: enable-method property 'psci' found operations
[    0.457595] Synopsys Designware Multimedia Card Interface Driver
[    0.458102] dwmmc_rockchip ffc50000.dwmmc: IDMAC supports 32-bit address mode.
[    0.458133] dwmmc_rockchip ffc50000.dwmmc: Using internal DMA controller.
[    0.458151] dwmmc_rockchip ffc50000.dwmmc: Version ID is 270a
[    0.458208] dwmmc_rockchip ffc50000.dwmmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[    0.458321] mmc_host mmc0: card is non-removable.
[    0.470631] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.484413] dwmmc_rockchip ffc60000.dwmmc: IDMAC supports 32-bit address mode.
[    0.484511] dwmmc_rockchip ffc60000.dwmmc: Using internal DMA controller.
[    0.484541] dwmmc_rockchip ffc60000.dwmmc: Version ID is 270a
[    0.484656] dwmmc_rockchip ffc60000.dwmmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[    0.484941] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.8
[    0.525214] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[    0.525313] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[    0.530259] mmc0: new HS200 MMC card at address 0001
[    0.533463] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[    0.534953] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[    0.536225] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[    0.537092] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (242:0)
[    0.551775]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[    0.603993] rockchip-iodomain fe020000.syscon:io-domains: Voltage invalid: -293069456
[    0.604080] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.618035] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[    0.618177] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[    0.618228] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[    0.618380] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 65,32 bit host data width,256 deep fifo
[    0.618732] dwmmc_rockchip ffc70000.dwmmc: allocated mmc-pwrseq
[    0.618807] mmc_host mmc1: card is non-removable.
[    0.632267] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.646259] usbcore: registered new interface driver usbhid
[    0.646334] usbhid: USB HID core driver
[    0.650753] rockchip-saradc ff5e0000.saradc: Linked as a consumer to regulator.4
[    0.652582] rksfc_base v1.1 2016-01-08
[    0.653128] rksfc ffc90000.sfc: rksfc_probe clk rate = 79200000
[    0.653197] rkflash_dev_init enter
[    0.653219] sfc nor id: 0 0 0
[    0.653232] rkflash[1] is invalid
[    0.653235] rkflash_dev_init enter
[    0.653260] sfc_nand id: 0 0 0
[    0.653271] rkflash[2] is invalid
[    0.660901] NET: Registered protocol family 17
[    0.661040] NET: Registered protocol family 15
[    0.661808] Bluetooth: RFCOMM TTY layer initialized
[    0.661874] Bluetooth: RFCOMM socket layer initialized
[    0.661916] Bluetooth: RFCOMM ver 1.11
[    0.661981] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    0.662011] Bluetooth: HIDP socket layer initialized
[    0.662034] [BT_RFKILL]: Enter rfkill_rk_init
[    0.662043] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    0.662465] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    0.662527] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6255
[    0.662542] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    0.662553] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    0.662631] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 8, flags = 0.
[    0.662649] ERROR: could not get clock /wireless-wlan:clk_wifi(0)
[    0.662661] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    0.662672] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    0.662682] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    0.662966] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 48.
[    0.662995] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 7.
[    0.663042] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 5.
[    0.663056] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[    0.663112] [BT_RFKILL]: Request irq for bt wakeup host
[    0.663216] [BT_RFKILL]: ** disable irq
[    0.663351] [BT_RFKILL]: bt_default device registered.
[    0.663562] flash vendor_init_thread!
[    0.663584] flash vendor storage:20170308 ret = -1
[    0.664262] imx415 1-001a: driver version: 00.01.06
[    0.664343] imx415 1-001a:  Get hdr mode failed! no hdr default
[    0.664532] imx415 1-001a: Failed to get power-gpios
[    0.664667] imx415 1-001a: could not get sleep pinstate
[    0.664817] imx415 1-001a: Linked as a consumer to regulator.5
[    0.664934] imx415 1-001a: Linked as a consumer to regulator.4
[    0.665057] imx415 1-001a: Linked as a consumer to regulator.6
[    0.673814] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    0.690401] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    0.696246] vendor storage:20190527 ret = 0
[    0.714565] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[    0.735810] imx415 1-001a: Detected imx415 id 0000e0
[    0.735961] rockchip-mipi-dphy-rx ff4b0000.csi-dphy: match m01_f_imx415 1-001a:bus type 4
[    0.742490] rkcif_mipi_lvds: Async subdev notifier completed
[    0.743425] Registering SWP/SWPB emulation handler
[    0.746517] Loading compiled-in X.509 certificates
[    0.748950] rga2: Driver loaded successfully ver:3.2.56726
[    0.749322] rga2: Module initialized.
[    0.760539] mmc_host mmc1: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[    0.770486] rockchip-iodomain fe020000.syscon:io-domains: Voltage invalid: -301425168
[    0.775743] rockchip-drm display-subsystem: devfreq is not set
[    0.776065] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093bf40)
[    0.776119] rockchip-drm display-subsystem: bound ffb30000.dsi (ops 0xb094266c)
[    0.776137] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.776147] [drm] No driver support for vblank timestamp query.
[    0.794083] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[    0.795211] input: adc-keys as /devices/platform/adc-keys/input/input0
[    0.798801] rkcif rkcif_mipi_lvds: clear unready subdev num: 0
[    0.799452] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    0.802718] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    0.802917] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    0.802940] cfg80211: failed to load regulatory.db
[    0.803450] rkisp rkisp-vir0: clear unready subdev num: 1
[    0.805794] rkisp0: Async subdev notifier completed
[    0.842821] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.38
[    0.842905] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    0.842933] usb 1-1: Product: USB2.0 Hub
[    0.846868] hub 1-1:1.0: USB hub found
[    0.849120] hub 1-1:1.0: 4 ports detected
[    0.855306] ALSA device list:
[    0.855357]   #7: Loopback 1
[    0.857447] EXT4-fs (mmcblk0p6): INFO: recovery required on readonly filesystem
[    0.857503] EXT4-fs (mmcblk0p6): write access will be enabled during recovery
[    0.931647] EXT4-fs (mmcblk0p6): recovery complete
[    0.933952] rockchip-iodomain fe020000.syscon:io-domains: Voltage invalid: -301425040
[    0.934590] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[    0.934712] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[    0.936148] devtmpfs: mounted
[    0.938277] Freeing unused kernel memory: 1024K
[    0.938765] Run /sbin/init as init process
[    0.981187] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    0.982122] mmc2: new high speed SDHC card at address 1234
[    0.984046] mmcblk2: mmc2:1234 SA16G 14.5 GiB
[    0.985834]  mmcblk2: p1
[    0.995772] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
NAME=Buildroot
VERSION=2018.02-rc3-00411-ga439fb32a0-dirty
ID=buildroot
VERSION_ID=2018.02-rc3
PRETTY_NAME="Buildroot 2018.02-rc3"
Starting logging: OK
startup_app_ipc start
/usr/bin/modetest
media get entity by name: stream_cif_dvp_id0 is null
media get entity by name: stream_cif_dvp_id1 is null
media get entity by name: stream_cif_dvp_id2 is null
media get entity by name: stream_cif_dvp_id3 is null
media get entity by name: rkcif-lvds-subdev is null
Populating /dev using udev: media get entity by name: stream_cif_dvp_id3 is null
media get entity by name: rkcif-lite-lvds-subdev is null
media get entity by name: stream_cif is null
media get entity by name: rkcif-dvp-sof is null
media get entity by name: rkisp-mpfbc-subdev is null
media get entity by name: rkisp_dmapath is null
media get entity by name: rockchip-mipi-dphy-rx is null
media get entity by name: rkcif_dvp is null
media get entity by name: rkcif_lite_mipi_lvds is null
[08:00:01.155743][CAMHW]:XCAM ERROR CamHwIsp20.cpp:1022: No free isp&ispp needed by fake camera!
[08:00:01.156618][CAMHW]:XCAM ERROR CamHwIsp20.cpp:1022: No free isp&ispp needed by fake camera!
ispserver[109]: ispserver version 1.0.0
ispserver[109]: [ispserver][rkaiq_get_media_info]:get sensor name m01_f_imx415 1-001a
register factory : filter
ispserver[109]: [ispserver][rkaiq_get_media_info]:get cam_num 1
register factory : source_stream
ispserver[109]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media0
register factory : output_stream
register factory : file_write_st[ ream
media get entity by name: rkisp-isp-subdev is null
register factory : file_read_stream
media get entity by nam : rkisp-input-params is null
register factory : v4l2_cap  ture_stream
media get entity by name: rkisp-statistics is null
register factory : v4l12_output_stream
media get entity by name: rkispp_input_pa.rams is null
register factory : 1drm_output_stream
0spserver[109]: [ispser6ver][rkaiq_get_media_info]:me4dia get sys_path: /dev/media1
 rga_api version 1.3.0_[11] (69RGA is compiling with meson base: $PRODUCT_BASE)
register] factory : rkrga
ispserver[1 09]: [ispserver][rkaiq_get_duevname]:get rkisp-isp-subdevd devname: /dev/v4l-subdev5
eegister factory : through_guard
 ispserver[109]: [ispserver][vrkaiq_get_devname]:get rkisp-input-params devname: /dev/viddeo15
ispserver[109]: [ispser[ver][rkaiq_get_devname]:get rkisp-statistics devname: /dev/video14
media get entity by name: rkispp_input_params is null
125]: stispserver[109]: [ispserver][rkaiqa_get_media_info]:media get sys_rpath: /dev/media2
ting version 3.2.7
n    1.168843] udevd[125]: specified group 'kvm' unknoispserver[109]: [ispserver][rkaiqw_get_devname]:get rkispp_input_params devname: /dev/video23
 #video_node: rkispp_scale2
ispserver[109]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media3
#CameraIdx: 0
o]:media get sys_path: /dev/rkaiq_get_media_inf
                            media4
#video_width: 960
ispserver[109]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media5
#video_height: 540
ispserver[109]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media6
#disp_width: 720
ispserver[109]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media7
#disp_height: 1280
ispserver[109]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media8
##RKMEDIA Log level: 2
ispserver[109]: [ispserver][rkaiq_get_media_info]:media get sys_path: /dev/media9
[RKMEDIA][SYS][Info]:text is all=2
ispserver[109]: [ispserver][rkaiq_get_media_info]:cam id 0 find_sensor 1 find_isp 1 find_ispp 1
[RKMEDIA][SYS][Info]:module is all, log_level is 2
ispserver[109]: [ispserver][rkaiq_get_media_info]:cam id 1 find_sensor 0 find_isp 0 find_ispp 0
[RKMEDIA][SYS][Info]:RK_MPI_VI_EnableChn: Enable VI[0:0]:rkispp_scale2, 960x540 Start...
DBus::Error - Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
ispserver[109]: [ispserver][main]:enter wait thread for cam index 0
[RKMEDIA][SYS][Info]:RKAIQ: parsing /dev/media0
ispserver[109]: [ispserver][thread_func]:thread_func cam_id 0...
ispserver[109]: [ispserver][database_hash_init]:database_hash_init init complete
ispserver[109]: [ispserver][subscrible_stream_event]:subscribe events from /dev/video15 success !
[RKMEDIA][SYS][Info]:RKAIQ: parsing /dev/media1
[RKMEDIA][SYS][Info]:RKAIQ: model(rkisp0): isp_info(0): isp-subdev entity name: /dev/v4l-subdev5
[RKMEDIA][SYS][Info]:RKAIQ: parsing /dev/media2
[RKMEDIA][SYS][Info]:RKAIQ: model(rkispp0): ispp_info(0): ispp-subdev entity name: /dev/v4l-subdev0
[RKMEDIA][SYS][Info]:#V4l2Stream: camraID:0, Device:rkispp_scale2
[RKMEDIA][SYS][Warn]:camera_id: 0, chn: rkispp_scale2
[RKMEDIA][SYS][Warn]:camera_id: 0, chn: rk[ispp_scale2, idx: 0
 RKMEDIA][ YS][Info]:#V4l2Stream: camera  id:0, VideoNode:/dev/video21
  1.191681] udevd[129]: starting eudev-3.2.7
[    1.194810] rkispp0: scale2:0x0 out of range:
[    1.194810]  [width max:1280 ratio max:8 min:2]Using mplane plugin for capture
[    1.194915] rkispp0: scale2:0x0 out of range:
[    1.194915]  [width max:1280 ratio max:8 min:2]
[    1.194954] rkispp0: scale2:0x0 out of range:
[    1.194954]  [width max:1280 ratio max:8 min:2]
[    1.194986] rkispp0: scale2:0x0 out of range:
[    1.194986]  [width max:1280 ratio max:8 [RKMEDIA][SYS][Info]:#V4L2Ctx: open /dev/video21, fd 7
2]n[RKMEDIA][SYS][Info]:Opened DRM device /dev/dri/card0: dri:ver rockchip version 2.0.0.
[    1.195018] rkispp0: scale2:0x0 out of range:
[    1.195018]  [width max:1280 ratio max:8 min:2]
[RKMEDIA][SYS][Info]:RK_MPI_VI_EnableChn: Enable VI[0:0]:rkispp_scale2, 960x540 End...
[RKMEDIA][SYS][Info]:RK_MPI_RGA_CreateChn: Enable RGA[0], Rect<0,0,960,540> Start...
[RKMEDIA][SYS][Info]:FilterFlow:rkrga: Enable BufferPool! memtype:hw_mem, memcnt:2
Had init the rga dev ctx = 0x2c168
rga_api version 1.3.0_[11] (RGA is compiling with meson base: $PRODUCT_BASE)
[RKMEDIA][SYS][Info]:RK_MPI_RGA_CreateChn: Enable RGA[0], Rect<0,0,960,540> End...
[RKMEDIA][SYS][Info]:RK_MPI_VO_CreateChn: Enable VO[0] Start...
[RKMEDIA][SYS][Info]:conn id : 56, enc id: 55, crtc id: 53, plane id: 54, w/h: 720,1280, fps: 60
[RKMEDIA][SYS][Info]:RK_MPI_VO_CreateChn: Enable VO[0] End!
#Bind VI[0] to RGA[0]....
[RKMEDIA][SYS][Info]:RK_MPI_SYS_Bind: Bind Mode[VI]:Chn[0] to Mode[RGA]:Chn[0]...
#Bind VI[0] to VO[0]....
[RKMEDIA][SYS][Info]:RK_MPI_SYS_Bind: Bind Mode[RGA]:Chn[0] to Mode[VO]:Chn[0]...
display_stream_on initial finish
[ispserver_register] attemp dbus of ispserver start
[08:00:01.377255][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:6920: calib_check_getID_by_name(6920): subtag: focusInfPosition from parent tag: zoomfocus_tbl is unknown, assert!!!
[08:00:01.378190][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:6998: calib_check_tag_attrs(6998): parent_tag_id:439 tag_id:1201 --- tag id is is wrong: min:0 max:1201
[08:00:01.379385][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:7044: calib_check_tag_attrs(7044): parent_tag_id:439 parent_tag_name:zoomfocus_tbl  tag_id:1201 tag_name:unknown --- ASSERT!!!
[08:00:01.380769][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:7188: calib_check_tag_mark(7188): parent_tag_id:439 tag_id:1201 --- tag_id is wrong:  min:0 max:1201
[08:00:01.381970][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:6920: calib_check_getID_by_name(6920): subtag: focusMacroPosition from parent tag: zoomfocus_tbl is unknown, assert!!!
[08:00:01.383298][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:6998: calib_check_tag_attrs(6998): parent_tag_id:439 tag_id:1201 --- tag id is is wrong: min:0 max:1201
[08:00:01.384929][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:7044: calib_check_tag_attrs(7044): parent_tag_id:439 parent_tag_name:zoomfocus_tbl  tag_id:1201 tag_name:unknown --- ASSERT!!!
[08:00:01.386308][XCORE]:XCAM ERROR RkAiqCalibTag.cpp:7188: calib_check_tag_mark(7188): parent_tag_id:439 tag_id:1201 --- tag_id is wrong:  min:0 max:1201
[    1.527070] FAT-fs (mmcblk2p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    1.683800] phy phy-ff4c0000.usb2-phy.1: charger = USB_CDP_CHARGER
[08:00:01.787537][XCORE]:XCAM ERROR v4l2_device.cpp:196: open device() failed
[08:00:01.861907][CAMHW]:XCAM ERROR LensHw.cpp:199: get vcm cfg failed
[08:00:01.895843][XCORE]:XCAM ERROR CamHwIsp20.cpp:3751: |||set DC-Iris PwmDuty: 100
[08:00:01.896112][CAMHW]:XCAM ERROR LensHw.cpp:411: iris is not supported
[08:00:01.954328][CAMHW]:XCAM ERROR LensHw.cpp:296: focus is not supported
ispserver[109]: [ispserver][thread_func]:wait stream start event...
ispserver[109]: [ispserver][thread_func]:wait stream start event success ...
ispserver[109]: [ispserver][thread_func]:state=0
ispserver[109]: [ispserver][thread_func]:start engine...
[    1.987544] rkcif_mipi_lvds: stream[0] start streaming
[    1.991741] rkcif_mipi_lvds: Allocate dummy buffer, size: 0x00a05000
[    1.991851] rkcif_mipi_lvds: stream[1] start streaming
[    1.991895] rockchip-mipi-csi2 ffb10000.mipi-csi2: stream on, src_sd: e0561a20, sd_name:rockchip-mipi-dphy-rx
[    1.991910] rockchip-mipi-csi2 ffb10000.mipi-csi2: stream ON
[    1.991937] rockchip-mipi-dphy-rx ff4b0000.csi-dphy: stream on:1
[    1.991953] rockchip-mipi-dphy-rx: data_rate_mbps 1486
[    1.993053] rockchip-mipi-dphy-rx ff4b0000.csi-dphy: stream on:1
[RKMEDIA][SYS][Info]:Camera 0 stream 7 is started
done
ispserver[109]: [ispserver][start_engine]:rkisp_init engine succeed
ispserver[109]: [ispserver][thread_func]:wait stream stop event...
Initializing random number generator... done.
[    2.077347] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:5
[    2.077359] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:6
[    2.077376] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:7
[    2.077393] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:8
[    2.077405] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:9
[    2.077418] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:10
[    2.077430] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:11
[    2.077443] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:12
[    2.077459] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:13
[    2.077478] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:14
[    2.077492] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:15
[    2.077509] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:16
[    2.077522] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:17
[    2.077534] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:18
[    2.077548] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:19
[    2.077565] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:20
[    2.077579] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:21
[    2.077592] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:22
[    2.077605] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:23
[    2.077616] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:24
[    2.077680] rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000, cnt:25
。。。。后面移植打印rockchip-mipi-csi2: ERR1: crc errors, reg: 0x10000000,。。。。。
你好,问下,这个MIPI CRC数据校验错误解决了吗,怎么解决的呢?
我也是你解决了吗,?是不是硬件问题
