镜像读取烧写
rk3588j在一个正常的板上apt-get install在线安装的包是否是在rootfs分区,用dd命令导出来的dd if=/dev/mmcblkp3 of=rootfs.img ,导出来的镜像再用工具烧到另一个3588板上,查看并没有在线安装的包,如何做到其他的板能够复制另一个板已经装好的软件包
https://wiki.t-firefly.com/zh_CN/Firefly-Linux-Guide/manual_ubuntu.html#dao-chu-she-bei-xi-tong
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … Warning: overlayroot: configuring overlayroot with driver=overlay mode=device opts=‘dev=PARTLABEL=userdata,fstype=ext4,mkfs=1’ per kernel cmdline
[ 11.614753] EXT4-fs (mmcblk0p8): warning: mounting unchecked fs, running e2fsck is recommended
[ 11.629155] EXT4-fs (mmcblk0p8): mounted filesystem without journal. Opts: (null)
mount: mounting /root on /root-ro failed: Invalid argument
Failure: overlayroot: failed to move root away from /root to /root-ro
mount: mounting /dev on /root/dev failed: No such file or directory
Warning: Something odd, no /lib/modules/5.10.66 in initramfs.
done.
按文档1.6步骤出现这样的报错
导出来的时候有报错 文件属性感觉也不对
东海龙王 发表于 2023-1-5 15:33
导出来的时候有报错 文件属性感觉也不对
你这导出失败了,你的u盘格式化成ext4格式试一试
或者如果你的板子容量足够,不接u盘直接导出到/userdata/
