rk3566jd4,最新sdk,android11,请问如何设置i2s2的M1能正常使能。请大佬指点下
我当前的默认dts i2s2的一些引脚情况如下
pin 133 (gpio4-5): vcc5v0-usb30-regulator gpio4:133 function usb group vcc5v0-usb30-drv
pin 138 (gpio4-10): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 145 (gpio4-17): (MUX UNCLAIMED) (GPIO UNCLAIMED)
pin 82 (gpio2-18): fe420000.i2s (GPIO UNCLAIMED) function i2s2 group i2s2m0-sclktx
pin 83 (gpio2-19): fe420000.i2s gpio2:83 function i2s2 group i2s2m0-lrcktx
pin 84 (gpio2-20): fe420000.i2s (GPIO UNCLAIMED) function i2s2 group i2s2m0-sdo
pin 85 (gpio2-21): fe420000.i2s (GPIO UNCLAIMED) function i2s2 group i2s2m0-sdi
我的需求是音频输入到i2s2中, 我用示波器已测量I2S2_SCLK_RX_M1,I2S2_LRCK_RX_M1,I2S2_SDI_M1(前二个脚有信号时钟,当有声音输入第三个脚测量是信号时钟)。 说明我的i2s2的输入都正常设置号了。
现在要解决的问题是dts 如何配置相关i2s2的输入的脚。
我尝试过把上面i2s2m0-sclktx,i2s2m0-lrcktx,i2s2m0-sdo,i2s2m0-sdi在dts中关闭换成如下dts,结果也是不行。
i2s2_2ch: i2s@fe420000 {
    compatible = "rockchip,rk3568-i2s-tdm";
    reg = <0x0 0xfe420000 0x0 0x1000>;
    interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&cru MCLK_I2S2_2CH>, <&cru MCLK_I2S2_2CH>, <&cru HCLK_I2S2_2CH>;
    clock-names = "mclk_tx", "mclk_rx", "hclk";
    dmas = <&dmac1 4>, <&dmac1 5>;
    dma-names = "tx", "rx";
    rockchip,cru = <&cru>;
    rockchip,grf = <&grf>;
    rockchip,clk-trcm = <1>;
    #sound-dai-cells = <0>;
    pinctrl-names = "default";
    // pinctrl-0 = <&i2s2m0_sclktx
    //       &i2s2m0_lrcktx
    //       &i2s2m0_sdi
    //       &i2s2m0_sdo>;
    pinctrl-0 = <&i2s2m1_sclkrx
        &i2s2m1_lrckrx
        &i2s2m1_sdi
        &i2s2m1_sdo>;
    status = "disabled";
cat /proc/asound/cards <
0 [rockchiphdmi ]: rockchip_hdmi - rockchip,hdmi
rockchip,hdmi
1 [rockchiprk809co]: rockchip_rk809- - rockchip,rk809-codec
rk3566_firefly_aiojd4:/data/mig $ ls /dev/snd/
controlC0 controlC1 pcmC0D0p pcmC1D0c pcmC1D0p timer
rk3566_firefly_aiojd4:/data/mig $ cat /pro
proc/ product/
cat /proc/asound/devices <
2: [ 0- 0]: digital audio playback
3: [ 0] : control
4: [ 1- 0]: digital audio playback
5: [ 1- 0]: digital audio capture
6: [ 1] : control
33: : timer
  1. 根据硬件原理图,dts里检查 I2S2_M1 所用到的pin脚有没有被复用成其他功能,如果被复用成其他功能,就disabled掉。
  2. pinctrl如何使用,参考SDK内 RKDocs/common/PIN-Ctrl/Rockchip-Developer-Guide-Linux-Pin-Ctrl-CN.pdf
firefly_zhongw 发表于 2023-1-11 10:03
  1. 根据硬件原理图,dts里检查 I2S2_M1 所用到的pin脚有没有被复用成其他功能,如果被复用成其他功能,就di …
i2s2的M1脚当前还没复用也还没使用,关键是,你们天启设置i2s2的dts 具体是那个dts文件,请告知。
我就是看到没设置所以才发帖找你们,了解具体的dts在哪里,参考那个i2s的dts配置。
我发帖第一行就写出了 M1脚的情况 ,
我发帖是想咨询天启的rk3566的 i2s2接收输入音频,参考的,具体dts是那文件,请回答。其他回答都是无效回答。
现在是rk3566 I2S2_M1都找不到是哪个dts文件里设置,你说I2S2_M1的复用脚需要禁用。 你说的有什么意义。
现在就是一个问题,请指点rk3566 I2S2_M1 在哪dts文件设置的。 我只有看到设置了,再找复用脚去设置或者禁止。
  1. 公版硬件没有用到 I2S2_M1,公版dts也不会去配置
  2. 公版dts用的是哪个,麻烦看维基教程kernel编译章节
  3. 要想基于公版dts去使用I2S2_M1,那就根据公版硬件去找I2S2_M1引脚用在了哪个硬件模块上,然后在dts里去disabled掉
  4. 硬件资料找商务要
你好,你问题解决了吗
