AIO-3568J 修改波特率115200后,Uboot乱码,Kernel打印正常
Ubuntu18.04系统
修改Uboot:
~\u-boot\configs\firefly-rk3568_defconfig
-CONFIG_BAUDRATE=1500000
+CONFIG_BAUDRATE=115200
保存修改后,重新编译
./build.sh uboot
修改Kernel:
~\kernel\arch\arm64\boot\dts\rockchip\rk3568_linux.dtsi
fiq-debugger {
compatible = “rockchip,fiq-debugger”;
rockchip,serial-id = <2>;
rockchip,wake-irq = <0>;
/* If enable uart uses irq instead of fiq /
rockchip,irq-mode-enable = <1>;
rockchip,baudrate = <115200>;//<1500000>; /
Only 115200 and 1500000 */
interrupts = <GIC_SPI 252 IRQ_TYPE_LEVEL_LOW>;
pinctrl-names = “default”;
pinctrl-0 = <&uart2m0_xfer>;
status = “okay”;
修改完成后,重新编译
sudo ./build.sh extboot
更新链接
sudo ./mkfirmware.sh
打包固件
sudo ./build.sh updateimg
重新烧录后,SecureCRT调试软件中,波特率按照115200打开串口: Uboot显示乱码,Kernel打印正常
鼢哌鼢鼢鼢骺鼢鼢圻亏鼢鼢鼢鼢鼢亏鼢鼢鼢哌哌哌哌哌哌哌圻哌哌骺鼢鼢鼢鼢哌哌哌哌亏哌哌鼢鬟哌鼢亏哌哌骺鼢哌哌鼢骰鼢鼢骺鼢鼢圻鼢鼢哌哌哌哌鼢鼢圻哌哌哌哌哌哌哌哌圻鼢鼢鼢镞鼢哌哌哌哌哌哌鼢鼢圻哌哌鼢鼢圻哌哌哌哌哌鼢鼢鼢哌鼢鼢哌鼢鼢哌亏鼢哌哌鼢哌哌鼢哌哌鼢鼢亏鼢鼢>唼e缁珑飛~燐铫餆|骺|oo~黯堰縸飛伉繑C肯q黠_窟傹z谗消锎坑挚亲浻:瑶訚帄抻瑶跟淄肟鼢繌钧鲲键珩脔鼢棘蛲萧顼偤鳜~x莛唿帢笨瘙橚荥婵巷_掶?征飚楒縒快_?屈佧/茳髑牺傀泅嗃z洒忐齸唪~矜_蕊轫鼽峻桷忂o呖棹析啉~[[ 0.165301] console [ttyFIQ0] enabled
[ 0.173011] bootconsole [uart8250] disabled
[ 0.177898] Registered fiq debugger ttyFIQ0
[ 0.179013] vcc3v3_sys: supplied by dc_12v
[ 0.179526] vcc5v0_sys: supplied by dc_12v
因为uboot没有修改成功,还需要去rkbin仓库修改
查看rkbin/tools/ddrbin_tool_user_guide.txt中的功能1,学习使用工具修改ddrbin中的波特率参数
查看rkbin/RKBOOT/RK3568MINIALL.ini看看当前rk3568使用的是哪个ddrbin,这个跟你的sdk版本有关,假设是rk3568_ddr_1560MHz_v1.13.bin
在你填写好ddrbin_param.txt后执行
./ddrbin_tool ddrbin_param.txt rk3568_ddr_1560MHz_v1.13.bin
然后把修改后的ddrbin放回原位,重新编译uboot,烧录uboot和loader
查看rkbin/tools/ddrbin_tool_user_guide.txt中的功能1, …
你好,修改uboot过程如下,同时有两个疑惑
1、rkbin/tools/ddrbin_tool_user_guide.txt
function 1: modify ddr.bin file from ddrbin_param.txt.
1) modify ‘ddrbin_param.txt’, set ddr frequency, uart info etc what you want.
If want to keep items default, please keep these items blank.
2) run ‘ddrbin_tool’ with argument 1: ddrbin_param.txt, argument 2: ddr bin file.
like: ./ddrbin_tool ddrbin_param.txt px30_ddr_333MHz_v1.13.bin
2、rkbin/tools/ddrbin_param.txt
修改如下参数
uart baudrate=115200
3、rkbin/RKROOT/RK3568MINIALL.ini
[CHIP_NAME]
NAME=RK3568
[VERSION]
MAJOR=1
MINOR=1
[CODE471_OPTION]
NUM=1
Path1=bin/rk35/rk3568_ddr_1560MHz_v1.13.bin
Sleep=1
[CODE472_OPTION]
NUM=1
Path1=bin/rk35/rk356x_usbplug_v1.14.bin
[LOADER_OPTION]
NUM=2
LOADER1=FlashData
LOADER2=FlashBoot
FlashData=bin/rk35/rk3568_ddr_1560MHz_v1.13.bin
FlashBoot=bin/rk35/rk356x_spl_v1.12.bin
[OUTPUT]
PATH=rk356x_spl_loader_v1.13.112.bin
[SYSTEM]
NEWIDB=true
[FLAG]
471_RC4_OFF=true
RC4_OFF=true
ini文件中: FlashData: bin/rk35/rk3568_ddr_1560MHz_v1.13.bin
rk35目录下还有一个:rk3568_ddr_1560MHz_v1.05-firefly.bin
4、OUTPUT文件为:rk356x_spl_loader_v1.13.112.bin
在目录 u-boot 下
更新各部分镜像链接到 rockdev/ 目录 : ./mkfirmware.sh
有打印:
Linking uboot.img from /home/think/proj/rk356x_linux_release_20211019/u-boot/uboot.img…
Done linking uboot.img
Linking MiniLoaderAll.bin from /home/think/proj/rk356x_linux_release_20211019/u-boot/rk356x_spl_loader_v1.13.112.bin…
Done linking MiniLoaderAll.bin
5、./ddrbin_tool ddrbin_param.txt rk3568_ddr_1560MHz_v1.13.bin
所以现有疑惑:
1)此命令中第二个参数: rk3568_ddr_1560MHz_v1.13.bin
还是选rk3568_ddr_1560MHz_v1.05-firefly.bin
2)此命令更新的文件是rk356x_spl_loader_v1.13.112.bin 还是命令中的第二参数文件?
执行此命令之前,需要备份哪个文件
6、执行过上述命令后,执行: ./build.sh uboot
重新编译uboot
可以同时更新uboot和loader?
是哪个bin文件以ini文件为准
更新的文件是命令中第二参数的bin文件
用不着备份,用git管理就行,能还原回来
编译uboot之后,uboot.img和新生成的spl_loader都会在u-boot文件夹下
在loader模式下先执行
upgrade_tool di -u uboot.img
再执行
upgrade_tool ul rk356x_spl_loader_vxxxx.bin
如果是windows就先单独勾选uboot,下载完成后再单独勾选loader
