SDK包名称:AIO-3588Q_Debian11_v1.0.2a_230129.img
SDK修改内容:无修改
Log日志:relogin.txt
按照官网提供的步骤:编译 Debian 固件 — Firefly Wiki
编译出来的debian系统img整刷进去,开机在登录界面一直要循环登录,无法进入系统,username和password输入正确,界面黑一下又回到登录界面。
./build.sh aio-3588mq-debian.mk
mkdir -p ubuntu_rootfs
sudo ./build.sh debian
./build.sh
打包日志:
Images in /mnt/data1/jayson/RK3588/rk3588_repo_sdk_v1.0.2a/rockdev are ready! Make image ok!File name is AIO-3588Q_Debian11_v1.0.2a_230129.imgRename the file? [N|y]Make update.imgstart to make update.img…Android Firmware Package Tool v2.0------ PACKAGE ------Add file: ./package-filepackage-file,Add file: ./package-file done,offset=0x800,size=0xf4,userspace=0x1Add file: ./Image/MiniLoaderAll.binbootloader,Add file: ./Image/MiniLoaderAll.bin done,offset=0x1000,size=0x6f1c0,userspace=0xdfAdd file: ./Image/parameter.txtparameter,Add file: ./Image/parameter.txt done,offset=0x70800,size=0x1e2,userspace=0x1Add file: ./Image/uboot.imguboot,Add file: ./Image/uboot.img done,offset=0x71000,size=0x800000,userspace=0x1000Add file: ./Image/misc.imgmisc,Add file: ./Image/misc.img done,offset=0x871000,size=0xc000,userspace=0x18Add file: ./Image/boot.imgboot,Add file: ./Image/boot.img done,offset=0x87d000,size=0x10000000,userspace=0x20000Add file: ./Image/recovery.imgrecovery,Add file: ./Image/recovery.img done,offset=0x1087d000,size=0x4bd7400,userspace=0x97afAdd file: ./Image/rootfs.imgrootfs,Add file: ./Image/rootfs.img done,offset=0x15454800,size=0xed600000,userspace=0x1dac00Add CRC…Make firmware OK!------ OK ------rkImageMaker ver 2.0Generating new image, please wait…Writing head info…Writing boot file…Writing firmware…Generating MD5 data…MD5 data generated successfully!New image generated successfully!Making ./Image/update.img OK.Make update image ok! /mnt/data1/jayson/RK3588/rk3588_repo_sdk_v1.0.2a/rockdev/pack/AIO-3588Q_Debian11_v1.0.2a_230129.img Running build_updateimg succeeded.
relogin.txt (153 KB)
