固件文件名称:AIO-3588SJD4_Ubuntu20.04-Gnome-r2204_v1.0.4b_22112
固件下载地址:百度网盘
Log日志:pci_log.tar
我们想扩展3588S的USB3.0接口的数量,以3588SJD4的开发板为例,如果插上一个mini PCIe转USB3.0的转接卡,是否可以支持呢?
我这边手上有一个 https://item.taobao.com/item.htm?id=41485814386 这样的转接卡,插上去后看起来没有反应,我这边已经使用大4PIN转小4PIN的电源线给转接卡供电了,但是lspci并没有任何反应,而且插上U盘也一样没有任何反应,请问下是否需要修改设备树重新编译固件才可以?谢谢。
$ lspci -vv
0004:40:00.0 PCI bridge: Fuzhou Rockchip Electronics Co., Ltd Device 3588 (rev 01) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR+ <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 129
Bus: primary=00, secondary=00, subordinate=00, sec-latency=0
I/O behind bridge: 00000000-00000fff
Memory behind bridge: 00000000-000fffff
Prefetchable memory behind bridge: 0000000000000000-00000000000fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
Expansion ROM at f4800000 [virtual] [disabled]
BridgeCtl: Parity- SERR- NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities:
Kernel driver in use: pcieport
lspci: Unable to load libkmod resources: error -12
0004:41:00.0 Network controller: Broadcom Inc. and subsidiaries Device 449d (rev 02)
Subsystem: Broadcom Inc. and subsidiaries Device aae8
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 128
Region 0: Memory at f4200000 (64-bit, non-prefetchable)
Region 2: Memory at f4400000 (64-bit, non-prefetchable)
Capabilities:
Kernel driver in use: pcieh
pci_log.tar (2.94 KB)
