编译失败
固件文件名称:rk3568 同样SDK
固件下载地址:官网下载地址
Log日志:build_error.txt
rk3568源码编译,大家有遇到过这个问题吗,怎么解决呢
Environment variable DIST was set, regenerating…
[ 7% 9/123] XYConnector dexpreopt
FAILED: out/target/product/rk3568_r/obj/APPS/XYConnector_intermediates/dexpreopt.zip
/bin/bash -c “bash out/target/product/rk3568_r/obj/APPS/XYConnector_intermediates/dexpreopt.sh vendor/nemo/systemosdependencies/NE98/sysa pp/XYConnector/XYConnector.apk out/target/product/rk3568_r/obj/APPS/XYConnector_intermediates/dexpreopt.zip”
dex2oatd64 E 02-13 02:22:09 248 248 oat_writer.cc:575] Expected valid zip or dex file: ‘/system/app/XYConnector/XYConnector.apk’
error: out/target/product/rk3568_r/obj/APPS/XYConnector_intermediates/dexpreopt.sh:23 exited with status 1
error in command:
ANDROID_LOG_TAGS=“:e" out/soong/host/linux-x86/bin/dex2oatd64 --avoid-storing-invocation --write-invocation-to=out/target/product/rk3568 r/obj/APPS/XYConnector_intermediates/oat/arm/package.invocation --runtime-arg -Xms64m --runtime-arg -Xmx512m --runtime-arg -Xbootclasspa th:out/soong/rk3568_r/dex_artjars_input/core-oj.jar:out/soong/rk3568_r/dex_artjars_input/core-libart.jar:out/soong/rk3568_r/dex_artjars_i nput/core-icu4j.jar:out/soong/rk3568_r/dex_artjars_input/okhttp.jar:out/soong/rk3568_r/dex_artjars_input/bouncycastle.jar:out/soong/rk356 8_r/dex_artjars_input/apache-xml.jar:out/soong/rk3568_r/dex_bootjars_input/framework.jar:out/soong/rk3568_r/dex_bootjars_input/ext.jar:ou t/soong/rk3568_r/dex_bootjars_input/telephony-common.jar:out/soong/rk3568_r/dex_bootjars_input/voip-common.jar:out/soong/rk3568_r/dex_boo tjars_input/ims-common.jar:out/soong/rk3568_r/dex_bootjars_input/framework-atb-backward-compatibility.jar --runtime-arg -Xbootclasspath-l ocations:/apex/com.android.art/javalib/core-oj.jar:/apex/com.android.art/javalib/core-libart.jar:/apex/com.android.art/javalib/core-icu4j .jar:/apex/com.android.art/javalib/okhttp.jar:/apex/com.android.art/javalib/bouncycastle.jar:/apex/com.android.art/javalib/apache-xml.jar :/system/framework/framework.jar:/system/framework/ext.jar:/system/framework/telephony-common.jar:/system/framework/voip-common.jar:/syst em/framework/ims-common.jar:/system/framework/framework-atb-backward-compatibility.jar ${class_loader_context_arg} ${stored_class_loader context_arg} --boot-image=out/soong/rk3568_r/dex_artjars/apex/com.android.art/javalib/boot.art:out/soong/rk3568_r/dex_bootjars/system/fra mework/boot-framework.art --dex-file=$1 --dex-location=/system/app/XYConnector/XYConnector.apk --oat-file=out/target/product/rk3568_r/obj /APPS/XYConnector_intermediates/oat/arm/package.odex --android-root=out/empty --instruction-set=arm --instruction-set-variant=cortex-a55 --instruction-set-features=default --no-generate-debug-info --generate-build-id --abort-on-hard-verifier-error --force-determinism --no-i nline-from=core-oj.jar --copy-dex-files=false --compiler-filter=quicken --generate-mini-debug-info --compilation-reason=prebuilt
[ 8% 10/123] XYLauncher dexpreopt
FAILED: out/target/product/rk3568_r/obj/APPS/XYLauncher_intermediates/dexpreopt.zip
/bin/bash -c “bash out/target/product/rk3568_r/obj/APPS/XYLauncher_intermediates/dexpreopt.sh vendor/nemo/systemosdependencies/NE98/sysap p/XYLauncher/XYLauncher.apk out/target/product/rk3568_r/obj/APPS/XYLauncher_intermediates/dexpreopt.zip”
dex2oatd64 E 02-13 02:22:09 260 260 oat_writer.cc:575] Expected valid zip or dex file: ‘/system/app/XYLauncher/XYLauncher.apk’
error: out/target/product/rk3568_r/obj/APPS/XYLauncher_intermediates/dexpreopt.sh:23 exited with status 1
error in command:
ANDROID_LOG_TAGS="
:e” out/soong/host/linux-x86/bin/dex2oatd64 --avoid-storing-invocation --write-invocation-to=out/target/product/rk3568 _r/obj/APPS/XYLauncher_intermediates/oat/arm/package.invocation --runtime-arg -Xms64m --runtime-arg -Xmx512m --runtime-arg -Xbootclasspat h:out/soong/rk3568_r/dex_artjars_input/core-oj.jar:out/soong/rk3568_r/dex_artjars_input/core-libart.jar:out/soong/rk3568_r/dex_artjars_in put/core-icu4j.jar:out/soong/rk3568_r/dex_artjars_input/okhttp.jar:out/soong/rk3568_r/dex_artjars_input/bouncycastle.jar:out/soong/rk3568 _r/dex_artjars_input/apache-xml.jar:out/soong/rk3568_r/dex_bootjars_input/framework.jar:out/soong/rk3568_r/dex_bootjars_input/ext.jar:out /soong/rk3568_r/dex_bootjars_input/telephony-common.jar:out/soong/rk3568_r/dex_bootjars_input/voip-common.jar:out/soong/rk3568_r/dex_boot jars_input/ims-common.jar:out/soong/rk3568_r/dex_bootjars_input/framework-atb-backward-compatibility.jar --runtime-arg -Xbootclasspath-lo cations:/apex/com.android.art/javalib/core-oj.jar:/apex/com.android.art/javalib/core-libart.jar:/apex/com.android.art/javalib/core-icu4j. jar:/apex/com.android.art/javalib/okhttp.jar:/apex/com.android.art/javalib/bouncycastle.jar:/apex/com.android.art/javalib/apache-xml.jar: /system/framework/framework.jar:/system/framework/ext.jar:/system/framework/telephony-common.jar:/system/framework/voip-common.jar:/syste m/framework/ims-common.jar:/system/framework/framework-atb-backward-compatibility.jar ${class_loader_context_arg} ${stored_class_loader_c ontext_arg} --boot-image=out/soong/rk3568_r/dex_artjars/apex/com.android.art/javalib/boot.art:out/soong/rk3568_r/dex_bootjars/system/fram ework/boot-framework.art --dex-file=$1 --dex-location=/system/app/XYLauncher/XYLauncher.apk --oat-file=out/target/product/rk3568_r/obj/AP PS/XYLauncher_intermediates/oat/arm/package.odex --android-root=out/empty --instruction-set=arm --instruction-set-variant=cortex-a55 --in struction-set-features=default --no-generate-debug-info --generate-build-id --abort-on-hard-verifier-error --force-determinism --no-inlin e-from=core-oj.jar --copy-dex-files=false --compiler-filter=quicken --generate-mini-debug-info --compilation-reason=prebuilt
[ 8% 11/123] XYNetwork dexpreopt
FAILED: out/target/product/rk3568_r/obj/APPS/XYNetwork_intermediates/dexpreopt.zip
/bin/bash -c “bash out/target/product/rk3568_r/obj/APPS/XYNetwork_intermediates/dexpreopt.sh vendor/nemo/systemosdependencies/NE98/sysapp /XYNetwork/XYNetwork.apk out/target/product/rk3568_r/obj/APPS/XYNetwork_intermediates/dexpreopt.zip”
dex2oatd64 E 02-13 02:22:09 239 239 oat_writer.cc:575] Expected valid zip or dex file: ‘/system/app/XYNetwork/XYNetwork.apk’
error: out/target/product/rk3568_r/obj/APPS/XYNetwork_intermediates/dexpreopt.sh:23 exited with status 1
error in command:
ANDROID_LOG_TAGS=“:e" out/soong/host/linux-x86/bin/dex2oatd64 --avoid-storing-invocation --write-invocation-to=out/target/product/rk3568 r/obj/APPS/XYNetwork_intermediates/oat/arm/package.invocation --runtime-arg -Xms64m --runtime-arg -Xmx512m --runtime-arg -Xbootclasspath :out/soong/rk3568_r/dex_artjars_input/core-oj.jar:out/soong/rk3568_r/dex_artjars_input/core-libart.jar:out/soong/rk3568_r/dex_artjars_inp ut/core-icu4j.jar:out/soong/rk3568_r/dex_artjars_input/okhttp.jar:out/soong/rk3568_r/dex_artjars_input/bouncycastle.jar:out/soong/rk3568 r/dex_artjars_input/apache-xml.jar:out/soong/rk3568_r/dex_bootjars_input/framework.jar:out/soong/rk3568_r/dex_bootjars_input/ext.jar:out/ soong/rk3568_r/dex_bootjars_input/telephony-common.jar:out/soong/rk3568_r/dex_bootjars_input/voip-common.jar:out/soong/rk3568_r/dex_bootj ars_input/ims-common.jar:out/soong/rk3568_r/dex_bootjars_input/framework-atb-backward-compatibility.jar --runtime-arg -Xbootclasspath-loc ations:/apex/com.android.art/javalib/core-oj.jar:/apex/com.android.art/javalib/core-libart.jar:/apex/com.android.art/javalib/core-icu4j.j ar:/apex/com.android.art/javalib/okhttp.jar:/apex/com.android.art/javalib/bouncycastle.jar:/apex/com.android.art/javalib/apache-xml.jar:/ system/framework/framework.jar:/system/framework/ext.jar:/system/framework/telephony-common.jar:/system/framework/voip-common.jar:/system /framework/ims-common.jar:/system/framework/framework-atb-backward-compatibility.jar ${class_loader_context_arg} ${stored_class_loader_co ntext_arg} --boot-image=out/soong/rk3568_r/dex_artjars/apex/com.android.art/javalib/boot.art:out/soong/rk3568_r/dex_bootjars/system/frame work/boot-framework.art --dex-file=$1 --dex-location=/system/app/XYNetwork/XYNetwork.apk --oat-file=out/target/product/rk3568_r/obj/APPS/ XYNetwork_intermediates/oat/arm/package.odex --android-root=out/empty --instruction-set=arm --instruction-set-variant=cortex-a55 --instru ction-set-features=default --no-generate-debug-info --generate-build-id --abort-on-hard-verifier-error --force-determinism --no-inline-fr om=core-oj.jar --copy-dex-files=false --compiler-filter=quicken --generate-mini-debug-info --compilation-reason=prebuilt
[ 9% 12/123] XYPinyinIME dexpreopt
FAILED: out/target/product/rk3568_r/obj/APPS/XYPinyinIME_intermediates/dexpreopt.zip
/bin/bash -c “bash out/target/product/rk3568_r/obj/APPS/XYPinyinIME_intermediates/dexpreopt.sh vendor/nemo/systemosdependencies/NE98/sysa pp/XYPinyinIME/XYPinyinIME.apk out/target/product/rk3568_r/obj/APPS/XYPinyinIME_intermediates/dexpreopt.zip”
dex2oatd64 E 02-13 02:22:09 231 231 oat_writer.cc:575] Expected valid zip or dex file: ‘/system/app/XYPinyinIME/XYPinyinIME.apk’
error: out/target/product/rk3568_r/obj/APPS/XYPinyinIME_intermediates/dexpreopt.sh:23 exited with status 1
error in command:
ANDROID_LOG_TAGS="
:e” out/soong/host/linux-x86/bin/dex2oatd64 --avoid-storing-invocation --write-invocation-to=out/target/product/rk3568 r/obj/APPS/XYPinyinIME_intermediates/oat/arm/package.invocation --runtime-arg -Xms64m --runtime-arg -Xmx512m --runtime-arg -Xbootclasspa th:out/soong/rk3568_r/dex_artjars_input/core-oj.jar:out/soong/rk3568_r/dex_artjars_input/core-libart.jar:out/soong/rk3568_r/dex_artjars_i nput/core-icu4j.jar:out/soong/rk3568_r/dex_artjars_input/okhttp.jar:out/soong/rk3568_r/dex_artjars_input/bouncycastle.jar:out/soong/rk356 8_r/dex_artjars_input/apache-xml.jar:out/soong/rk3568_r/dex_bootjars_input/framework.jar:out/soong/rk3568_r/dex_bootjars_input/ext.jar:ou t/soong/rk3568_r/dex_bootjars_input/telephony-common.jar:out/soong/rk3568_r/dex_bootjars_input/voip-common.jar:out/soong/rk3568_r/dex_boo tjars_input/ims-common.jar:out/soong/rk3568_r/dex_bootjars_input/framework-atb-backward-compatibility.jar --runtime-arg -Xbootclasspath-l ocations:/apex/com.android.art/javalib/core-oj.jar:/apex/com.android.art/javalib/core-libart.jar:/apex/com.android.art/javalib/core-icu4j .jar:/apex/com.android.art/javalib/okhttp.jar:/apex/com.android.art/javalib/bouncycastle.jar:/apex/com.android.art/javalib/apache-xml.jar :/system/framework/framework.jar:/system/framework/ext.jar:/system/framework/telephony-common.jar:/system/framework/voip-common.jar:/syst em/framework/ims-common.jar:/system/framework/framework-atb-backward-compatibility.jar ${class_loader_context_arg} ${stored_class_loader context_arg} --boot-image=out/soong/rk3568_r/dex_artjars/apex/com.android.art/javalib/boot.art:out/soong/rk3568_r/dex_bootjars/system/fra mework/boot-framework.art --dex-file=$1 --dex-location=/system/app/XYPinyinIME/XYPinyinIME.apk --oat-file=out/target/product/rk3568_r/obj /APPS/XYPinyinIME_intermediates/oat/arm/package.odex --android-root=out/empty --instruction-set=arm --instruction-set-variant=cortex-a55 --instruction-set-features=default --no-generate-debug-info --generate-build-id --abort-on-hard-verifier-error --force-determinism --no-i nline-from=core-oj.jar --copy-dex-files=false --compiler-filter=quicken --generate-mini-debug-info --compilation-reason=prebuilt
[ 10% 13/123] XYSysService dexpreopt
build_error.txt (11.9 KB)
