rv1126 使用rkmedia 工具 如何去更改rtsp 推流出来的分辨率
SDK包名称:官网sdk2.2.5
SDK修改内容:使用sensor: imx415
Log日志:dmesg.rar
rv1126 使用rkmedia 工具 如何去更改rtsp 推流出来的分辨率:
现在板子能出来的主码流分辨率是:3840*2160 25fpos (vlc rtsp://168.168.101.208:554/live/main_strea)
请问大佬们我如何去更改推流出来的分辨率
当前修改:
1、修改过 ipc.conf 但是没有效果,不知是没有没有改对地方还是
dmesg.rar (14.7 KB)
    "Pipe_0": {
        "Flow_0": {
            "flow_index": {
                "flow_index_name": "source_0",
                "flow_type": "source",
                "stream_id": "0",
                "stream_type": "camera",
                "upflow_index_name": "none"
            "flow_name": "source_stream",
            "flow_param": {
                "name": "v4l2_capture_stream"
            "stream_param": {
                "device": "rkispp_m_bypass",
                "frame_num": "6",
                "height": "1520",
                "output_data_type": "image:nv12",
                "use_libv4l2": "1",
                "v4l2_capture_type": "VIDEO_CAPTURE",
                "v4l2_mem_type": "MEMORY_DMABUF",
                "virtual_height": "1520",
                "virtual_width": "2688",
                "width": "2688"
        "Flow_1": {
            "flow_index": {
                "flow_index_name": "nn_result_input_0",
                "flow_type": "io",
                "in_slot_index_of_down": "0",
                "out_slot_index": "0",
                "stream_type": "filter",
                "upflow_index_name": "source_0"
            "flow_name": "filter",
            "flow_param": {
                "input_data_type": "image:nv12",
                "name": "nn_result_input",
            "stream_param": {
                "enable": "1",
                "frame_caches": "1",
                "frame_rate": "30"
        "Flow_2": {
            "flow_index": {
                "flow_index_name": "face_capture_0",
                "flow_type": "io",
                "upflow_index_name": "nn_result_input_0"
            "flow_param": {
                "name": "face_capture",
            "stream_param": {
                "enable": "1",
                "path": "/userdata/snapshot",
                "file_prefix": "face",
                "file_suffix": ".jpeg",
        "Flow_3": {
            "flow_index": {
                "flow_index_name": "draw_filter_0",
                "flow_type": "io",
                "upflow_index_name": "face_capture_0"
            "flow_param": {
                "name": "draw_filter",
            "stream_param": {
                "enable": "1",
                "draw_rect_thick": "2",
                "need_hw_draw": "0",
                "offset_x": "16.0",
                "offset_y": "0.0",
                "min_rect": "2000",
        "Flow_4": {
            "flow_index": {
                "flow_index_name": "video_enc_0",
                "flow_type": "io",
                "stream_type": "video_enc",
                "upflow_index_name": "draw_filter_0"
            "flow_name": "video_enc",
            "flow_param": {
                "name": "rkmpp",
                "need_extra_merge": "1",
                "output_data_type": "video:h265"
            "stream_param": {
                "bitrate_max": "8000000",
                "bitrate": "6000000",
                "bitrate_min": "4000000",
                "codec_type": "7",
                "framerate": "25/1",
                "framerate_in": "25/1",
                "full_range": "1",
                "gop": "30",
                "h264_trans_8x8": "1",
                "height": "1520",
                "level": "52",
                "output_data_type": "video:h265",
                "profile": "100",
                "rc_mode": "cbr",
                "rc_quality": "highest",
                "width": "2688",
                "roi_regions": "",
                "smart": "close"
        "Flow_5": {
            "flow_index": {
                "flow_index_name": "muxer_0",
                "flow_type": "sink",
                "stream_type": "muxer",
                "upflow_index_name": "video_enc_0"
            "flow_name": "muxer_flow",
            "flow_param": {
                "name": "muxer_flow",
                "path": "rtmp://127.0.0.1:1935/live/mainstream",
                "output_data_type": "flv"
            "stream_param": {}
        "Flow_6": {
            "flow_index": {
                "flow_index_name": "muxer_1",
            "flow_param": {
                "muxer_rkaudio_avdictionary": "movflags-frag_keyframe",
                "file_duration": "60",
                "file_index": "1",
                "file_time": "1",
                "path": "/userdata/video0",
                "file_prefix": "main",
                "enable_streaming": "false"
            "stream_param": {}
        "Flow_7": {
            "flow_index": {
                "flow_index_name": "rtsp_0",
                "stream_type": "rtsp",
            "flow_name": "live555_rtsp_server",
            "flow_param": {
                "input_data_type": "video:h265",
                "channel_name": "live/mainstream",
                "portnum": "554",
                "sample_rate": "8000",
                "channel_num": "1",
                "profile": "1",
                "sample_format": "16"
            "stream_param": {}
        "Flow_8": {
            "flow_index": {
                "flow_index_name": "through_guard_0",
                "flow_type": "io",
                "stream_type": "jpeg_through_guard",
            "flow_param": {
                "name": "through_guard",
            "stream_param": {
                "allow_through_count": "0"
        "Flow_9": {
            "flow_index": {
                "flow_index_name": "video_enc_1",
                "flow_type": "io",
                "stream_type": "jpeg_enc",
                "upflow_index_name": "through_guard_0"
            "flow_param": {
                "name": "rkmpp",
                "output_data_type": "image:jpeg"
            "stream_param": {
                "codec_type": "8",
                "output_data_type": "image:jpeg",
                "height": "1520",
                "width": "2688",
                "jpeg_qfactor": "99"
        "Flow_10": {
            "flow_index": {
                "flow_index_name": "sink_0",
                "stream_type": "file",
                "upflow_index_name": "video_enc_1"
            "flow_name": "file_write_flow",
            "flow_param": {
                "mode": "w+",
                "path": "/userdata/photo0",
                "save_mode": "single_frame"
            "stream_param": {}
    "Pipe_1": {
        "Flow_0": {
            "flow_index": {
                "stream_id": "1",
            "flow_param": {
            "stream_param": {
                "device": "rkispp_scale1",
                "frame_num": "6",
                "height": "480",
                "use_libv4l2": "1",
                "virtual_height": "480",
                "virtual_width": "640",
                "width": "640"
        "Flow_1": {
            "flow_index": {
                "flow_index_name": "move_detec_test",
                "stream_id": "1",
                "flow_type": "io",
                "stream_type": "move_detec",
            "flow_name": "move_detec",
            "flow_param": {
                "name": "move_detec",
                "input_data_type": "nv12",
                "output_data_type": "NULL"
            "stream_param": {
                "md_single_ref": "1",
                "md_orignal_width": "640",
                "md_orignal_height": "480",
                "md_down_scale_width": "640",
                "md_down_scale_height": "480",
                "md_roi_cnt": "0",
                "md_roi_rect": ""
        "Flow_2": {
            "flow_index": {
                "flow_index_name": "rockface_0",
                "flow_type": "io",
            "flow_param": {
                "thread_model": "asynccommon",
                "input_model": "dropfront",
                "name": "rockface_detect"
            "stream_param": {
                "enable": "1",
                "detect_track": "1",
                "track_frame": "2",
                "detect_align": "0",
                "detect_landmark": "0"
        "Flow_3": {
            "flow_index": {
                "flow_type": "io",
            "flow_param": {
                "name": "rkmpp",
                "output_data_type": "video:h264"
            "stream_param": {
                "bitrate_max": "800000",
                "bitrate": "400000",
                "bitrate_min": "200000",
                "codec_type": "6",
                "full_range": "1",
                "gop": "30",
                "height": "480",
                "level": "52",
                "output_data_type": "video:h264",
                "profile": "100",
                "rc_mode": "cbr",
                "width": "640",
                "roi_regions": ""
        "Flow_4": {
            "flow_index": {
            "flow_param": {
                "path": "rtmp://127.0.0.1:1935/live/substream",
            "stream_param": {}
        "Flow_5": {
            "flow_index": {
            "flow_param": {
                "input_data_type": "video:h264",
                "channel_name": "live/substream",
                "portnum": "554",
                "channel_num": "1",
                "profile": "1",
            "stream_param": {}
        "Flow_6": {
            "flow_index": {
                "flow_index_name": "bodydetect_0",
                "flow_type": "io",
            "flow_param": {
                "name": "rockface_bodydetect"
            "stream_param": {
                "rect": "(0,0,640,480)",
                "detect_rect": "(0,0,640,480)",
                "frame_interval": "5",
                "percentage": "80",
                "duration": "2",
                "enable": "1"
        "Flow_7": {
            "flow_index": {
                "flow_index_name": "face_recognize_0",
                "flow_type": "io",
                "upflow_index_name": "rockface_0"
            "flow_param": {
                "name": "rockface_recognize"
            "stream_param": {
                "enable": "1",
                "enable_face_reg": "1",
                "enable_face_detect": "1",
                "db_path": "/data/face.db"
    "Pipe_2": {
        "Flow_0": {
            "flow_index": {
                "stream_id": "2",
            "flow_param": {
            "stream_param": {
                "device": "rkispp_scale0",
                "frame_num": "4",
                "height": "1080",
                "use_libv4l2": "1",
                "virtual_height": "1080",
                "virtual_width": "1920",
                "width": "1920"
        "Flow_1": {
            "flow_index": {
                "flow_type": "io",
            "flow_param": {
                "name": "rkmpp",
            "stream_param": {
                "bitrate_max": "3000000",
                "bitrate": "2000000",
                "bitrate_min": "1000000",
                "codec_type": "7",
                "full_range": "1",
                "gop": "30",
                "height": "1080",
                "level": "52",
                "profile": "100",
                "rc_mode": "cbr",
                "width": "1920",
                "roi_regions": ""
        "Flow_2": {
            "flow_index": {
            "flow_param": {
                "path": "rtmp://127.0.0.1:1935/live/thirdstream",
            "stream_param": {}
        "Flow_3": {
            "flow_index": {
            "flow_param": {
                "channel_name": "live/thirdstream",
                "portnum": "554",
                "channel_num": "1",
                "profile": "1",
            "stream_param": {}
