Wallys// DR6018 Support: QUECTEL RM500Q-GL
Wallys// DR6018 Support: QUECTEL RM500Q-GL&Support:
QCN9074 WiFi 6E Card,Open WRT, IPQ6010,802.1lax,
2x2 2.4G&5G,2.5Gbps Ethernet Port Support,Open WRT
Link Here Get More Information :[u]PRODUCTS_Wallys Communications (Suzhou ) Co., LTD (wallystech.com)[/u]
Feature:
Qualcomm-Atheros IPQ6010
1GB DDRL3L System Memory
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specification
Symbol Parameter
CPU :Qualcomm-Atheros IPQ6010
CPU Frequency: Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory: 1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port: 1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
NGFF Slot: M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot: 1x SD Card Slot
USB /header: 1x USB 2.0 Port
POE: 24V~48V passive POE/Active POE(Suport 802.3bt)
DC :Jack 24V power supply
LED header: FFC/FPC Connector
Serial Port: 1x Serial Port 4 Pin Connector
Wireless: On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain 4 x MMCX Connectors
Bluetooth: optional
Nor Flash :8-32MB(normally is 8MB)
Nand Flash: 256MB
DDR: 1GB
Dimension: 185mm x 116m
OUR CONPANY:
Wallys Communications (Suzhou ) Co., LTD Link :https://link.segmentfault.com
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective routerboards and wireless network cards.
In the complex market, Wallys products stand out and are affirmed by partners. From 802.11 a – ax, Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win-win cooperation.
More detail and opportunities attach: sales4@wallystech.com. This is Jane for you .
