tftpbootm - tftpbootm aosp/uImage/FIT imagevia network using TFTP protocol
Usage:
tftpbootm [loadAddress][[hostIPaddr:]bootfilename]
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at0027f800 …
Using ‘conf’ configuration
optee api revision: 2.0
TEEC: Waring: Could not find securitypartition
## Verified-boot: 0
Trying ‘kernel’ kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0x002a8400
Data Size: 27421184 Bytes =26.2 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00400000
Entry Point: 0x00400000
Hash algo: sha256
Hash value: e6606121429504e501c6b1fd0c4759340dfb7c35bfb01c1d78535b821db963c8
Verifying Hash Integrity … sha256+ OK
## Flattened Device Tree blob at 0x08300000
Booting using the fdt blob at 0x08300000
“Synchronous Abort” handler, esr0x96000010
Reason: Exception from a Data abort, fromcurrent exception level
PC = 00000000002b3e9c
LR = 0000000000218b78
SP = 00000000eb9fa480
ESR_EL2 = 0000000096000010
Reloc Off = 00000000edb4f000
x0 : 0000000000000000 x1 : 00000000ede40243
x2 : 00000000ffffffee x3 : 0000000000000000
x4 : 0000000000000000 x5 : 0000000000000064
x6 : 000000000000037c x7 : 0000000000000001
x8 : 000000000000036c x9 : 0000000000000008
x10: 00000000eb9fa4ec x11: 000000000027f800
x12: 0000000000000314 x13: 00000000eb9fa54c
x14: 000000000027f800 x15: 0000000000000020
x16: 00000000edd8aec8 x17: 000000000a128404
x18: 00000000eb9ffcf0 x19: 00000000ede77ae8
x20: 000000000027f800 x21: 000000000000071f
x22: 000000000027f800 x23: 0000000000000003
x24: 00000000ebdf8f28 x25: 00000000ede5a480
x26: 0000000000000000 x27: 0000000000000000
x28: 00000000ede77ae8 x29: 00000000eb9fa660
Call trace:
PC: [< 002b3e9c >]
LR: [< 00218b78 >]
Stack:
[< 002b3e9c >]
[< 0021929c >]
[< 0022dfc8 >]
[< 00217504 >]
[< 002176b8 >]
[< 00216dcc >]
[< 0022d590 >]
[< 0022dfc8 >]
[< 00217504 >]
[< 002176b8 >]
[< 00217bec >]
[< 0022d68c >]
[< 00215be4 >]
[< 002183f8 >]
[< 0029b4b0 >]
[< 00218780 >]
[< 00201e18 >]
Copy info from “Call trace…” toa file(eg. dump.txt), and run
command in your U-Boot project:./scripts/stacktrace.sh dump.txt
Resetting CPU …
