Wallys//DR6018V4&DR6018-S V02&DR6018(CP01)/Qualcomm-Atheros IPQ6010 QCN9074 WIFI6E Card
DR6018 V4
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Ratin
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter
CPU Qualcomm-Atheros IPQ6010
CPU Frequency
SD Card Slot
1x SD Card Slot
USB /header
1x USB 2.0 Port
DC Jack 24V power supply
LED header FFC/FPC Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
4 x MMCX Connectors
Bluetooth CSR8811 BLE 4.2
Nor Flash 32MB
Nand Flash 256MB
DDR 256MB~512MB
Dimension 185mm x 116mm
Radio TX Specifications(5180MHz-5825MHz)
DR6018-S V01
8MB NOR Flash, 256MB NAND Flash
Absolute Maximum Rating
Paramete Rating Unit
Supply Voltage 24V~48V(DC Jack) V
Symbol Parameter
CPU Frequency Quad-core ARM 64 bit A53 @1.8 GHz processor
Ethernet Port 1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
NGFF Slot M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
SD Card Slot 1x SD Card Slot(Option)
USB /header 1x USB 3.0 Port(Option)
DC Jack 24V~48V power supply
LED header 2.0 pitch pin header
Wireless
4 x MMCX Connectors
Nor Flash 8MB
Nand Flash 256MB
DDR 256MB~512MB
Dimension
125mm x 105mm x 20mmOperating Humidity Range 5 to +95 (non-condensing) %
DR6018(CP01)
Operating Humidity Range 5 to +95 (non-condensing %
Symbol Parameter
CPU Qualcomm-Atheros IPQ6018
CPU Frequency
Ethernet Port 5x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
USB /header 1x USB 2.0 Port, 1x USB 3.0 Type-C Port
DC Jack 12V power supply
Serial Port 1x Serial Port 12 Pin Connector
Wireless
4x U.FL Connectors
Nor Flash 32MB
Nand Flash 256MB
DDR 256MB~512MB
Dimension (W x H x D) 219mm x 150mm x 16.5mm (Without Heatsink)
Our company:
Wallys Communications (SuZhou) Co.,Ltd was established in 2010. The company is a techno-innovation enterprise specializing in the independent R&D, production and sales of wireless network products and offering wireless solutions.
More detail and opportunities attach Emile & Face book :sales4@wallystech.com. This is Jane for you
