zhangzhenzhao 发表于 2023-3-7 11:23
可以复现情况的时候抓log看看,内核和上层都抓~
# dmesg -C
# logcat -c
# logcat |grep wpa&
[1] 1428 1429
# wpa_cli
wpa_cli v2.8-devel-10
Copyright (c) 2004-2019, Jouni Malinen <j@w1.fi> and contributors
This software may be distributed under the terms of the BSD license.
See README for more details.
Using interface ‘wlan0’
Interactive mode
add_net
0
set_network 0 ssid “Xiaomi_68A5”
OK
set_network 0 key_mgmt WPA-PSK
OK
set_network 0 psk “12345678”
OK
enable_network 0
OK
<3>CTRL-EVENT-STATE-CHANGE id=-1 state=3 BSSID=00:00:00:00:00:00 SSID=
<3>CTRL-EVENT-SCAN-STARTED
<3>CTRL-EVENT-SCAN-RESULTS
<3>WPS-AP-AVAILABLE
<3>Trying to associate with ec:41:18:e7:68:a6 (SSID=‘Xiaomi_68A5’ freq=2417 MHz)
12-28 10:19:51.621 751 751 I wpa_supplicant: wlan0: Trying to associate with ec:41:18:e7:68:a6 (SSID=‘Xiaomi_68A5’ freq=2417 MHz)
<3>CTRL-EVENT-STATE-CHANGE id=-1 state=5 BSSID=00:00:00:00:00:00 SSID=
<3>CTRL-EVENT-STATE-CHANGE id=0 state=6 BSSID=00:00:00:00:00:00 SSID=Xiaomi_68A5
<3>Associated with ec:41:18:e7:68:a6
12-28 10:19:51.705 751 751 I wpa_supplicant: wlan0: Associated with ec:41:18:e7:68:a6
<3>CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
12-28 10:19:51.706 751 751 I wpa_supplicant: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
<3>CTRL-EVENT-STATE-CHANGE id=0 state=7 BSSID=ec:41:18:e7:68:a6 SSID=Xiaomi_68A5
<3>WPA: RX message 1 of 4-Way Handshake from ec:41:18:e7:68:a6 (ver=2)
<3>WPA: Sending EAPOL-Key 2/4
12-28 10:19:51.808 751 751 I wpa_supplicant: wlan0: WPA: RX message 1 of 4-Way Handshake from ec:41:18:e7:68:a6 (ver=2)
12-28 10:19:51.808 751 751 I wpa_supplicant: wlan0: WPA: Sending EAPOL-Key 2/4
<3>WPA: RX message 3 of 4-Way Handshake from ec:41:18:e7:68:a6 (ver=2)
<3>WPA: Sending EAPOL-Key 4/4
12-28 10:19:51.834 751 751 I wpa_supplicant: wlan0: WPA: RX message 3 of 4-Way Handshake from ec:41:18:e7:68:a6 (ver=2)
12-28 10:19:51.834 751 751 I wpa_supplicant: wlan0: WPA: Sending EAPOL-Key 4/4
<3>CTRL-EVENT-STATE-CHANGE id=0 state=8 BSSID=ec:41:18:e7:68:a6 SSID=Xiaomi_68A5
<3>WPA: Key negotiation completed with ec:41:18:e7:68:a6 [PTK=CCMP GTK=TKIP]
<3>CTRL-EVENT-CONNECTED - Connection to ec:41:18:e7:68:a6 completed [id=0 id_str=]
12-28 10:19:51.838 751 751 I wpa_supplicant: wlan0: WPA: Key negotiation completed with ec:41:18:e7:68:a6 [PTK=CCMP GTK=TKIP]
<3>setprop vendor.wifi.state connected
<3>CTRL-EVENT-STATE-CHANGE id=0 state=9 BSSID=ec:41:18:e7:68:a6 SSID=Xiaomi_68A5
12-28 10:19:51.839 751 751 I wpa_supplicant: wlan0: CTRL-EVENT-CONNECTED - Connection to ec:41:18:e7:68:a6 completed [id=0 id_str=]
12-28 10:19:51.840 751 751 I wpa_supplicant: wlan0: setprop vendor.wifi.state connected
<3>CTRL-EVENT-DISCONNECTED bssid=ec:41:18:e7:68:a6 reason=3 locally_generated=1
<3>setprop vendor.wifi.state disconnected
12-28 10:19:51.856 751 751 I wpa_supplicant: wlan0: CTRL-EVENT-DISCONNECTED bssid=ec:41:18:e7:68:a6 reason=3 locally_generated=1
12-28 10:19:51.856 751 751 I wpa_supplicant: wlan0: setprop vendor.wifi.state disconnected
<3>CTRL-EVENT-STATE-CHANGE id=0 state=0 BSSID=ec:41:18:e7:68:a6 SSID=Xiaomi_68A5
status
wpa_state=DISCONNECTED
p2p_device_address=24:b7:2a:df:3c:0f
address=24:b7:2a:df:3c:0e
uuid=2e365ec6-567b-5baa-9410-92697f52f34a
<3>CTRL-EVENT-STATE-CHANGE id=-1 state=0 BSSID=00:00:00:00:00:00 SSID=
status
q
# dmesg
[ 172.228997] logd: logdr: UID=0 GID=0 PID=1428 b tail=0 logMask=19 pid=0 start=0ns timeout=0ns
[ 185.898589] healthd: battery none chg=a
[ 217.824427] >>> rwnx_cfg80211_scan()
[ 217.824462] >>> rwnx_send_scanu_req()
[ 217.824488] rwnx_send_msg (4104)SCANU_VENDOR_IE_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0\x0d
[ 217.825245] rwnx_send_msg (4105)SCANU_START_CFM_ADDTIONAL reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0\x0d
[ 219.108919] >>> rwnx_rx_scanu_start_cfm()
[ 219.124450] >>> rwnx_cfg80211_connect()
[ 219.124485] >>> rwnx_send_sm_connect_req()
[ 219.124511] rwnx_send_msg (6145)SM_CONNECT_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0\x0d
[ 219.199195] >>> rwnx_rx_sm_connect_ind()
[ 219.305845] need cfm ethertype: 8e88,user_idx=1, skb=00000000738b0c47
[ 219.308595] sdio_host_tx_cfm_handler:used_idx=0, 0x00000000b2223747, status=9\x0d
[ 219.331095] need cfm ethertype: 8e88,user_idx=2, skb=00000000b5281073
[ 219.331808] >>> rwnx_cfg80211_add_key()
[ 219.331843] >>> rwnx_send_key_add()
[ 219.331865] rwnx_send_key_add: sta_idx:0 key_idx:0 inst_nbr:0 cipher:2 key_len:16
[ 219.331889] key: 00000000: 82 a3 d9 cb 1c 0f 53 26 03 07 6b d3 cb c1 f7 58 …S&..k…X
[ 219.331901] rwnx_send_msg (37)MM_KEY_ADD_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0\x0d
[ 219.332803] >>> rwnx_cfg80211_set_default_key()
[ 219.334242] >>> rwnx_cfg80211_add_key()
[ 219.334276] >>> rwnx_send_key_add()
[ 219.334298] rwnx_send_key_add: sta_idx:255 key_idx:1 inst_nbr:0 cipher:1 key_len:32
[ 219.334321] key: 00000000: b8 11 89 ee 88 be 7a a5 83 f2 90 99 48 f2 13 79 …z…H..y
[ 219.334331] key: 00000010: 57 c4 bb 9d 0f 21 f2 c9 8b 3c 55 3b a7 e8 22 5d W…!..<U;.."]
[ 219.334343] rwnx_send_msg (37)MM_KEY_ADD_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0\x0d
[ 219.335406] sdio_host_tx_cfm_handler:used_idx=1, 0x00000000b2223747, status=9\x0d
[ 219.338728] selinux: avc: denied { set } for property=vendor.wifi.state pid=751 uid=1010 gid=1010 scontext=u:r:hal_wifi_supplicant_default:s0 tcontext=u:object_r:vendor_hal_wifi_prop:s0 tclass=property_service permissive=1\x0a
[ 219.340458] >>> rwnx_send_me_set_control_port_req()
[ 219.340498] rwnx_send_msg (5125)ME_SET_CONTROL_PORT_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0\x0d
[ 219.347272] >>> rwnx_cfg80211_disconnect()
[ 219.347306] >>> rwnx_send_sm_disconnect_req()
[ 219.347330] rwnx_send_msg (6148)SM_DISCONNECT_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0\x0d
[ 219.352479] >>> rwnx_rx_sm_disconnect_ind()
[ 219.352590] deinit:macaddr:24,b7,2a,df,3c,e\x0d
[ 219.352656] >>> rwnx_cfg80211_del_key()
[ 219.352680] >>> rwnx_send_key_del()
[ 219.352704] rwnx_send_msg (39)MM_KEY_DEL_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0\x0d
[ 219.355242] >>> rwnx_cfg80211_del_key()
[ 219.355273] >>> rwnx_send_key_del()
[ 219.355296] rwnx_send_msg (39)MM_KEY_DEL_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0\x0d
[ 219.356421] >>> rwnx_cfg80211_del_key()
[ 219.356453] >>> rwnx_send_key_del()
[ 219.356477] rwnx_send_msg (39)MM_KEY_DEL_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0\x0d
[ 219.357048] >>> rwnx_cfg80211_del_key()
[ 219.357073] >>> rwnx_send_key_del()
[ 219.357170] rwnx_send_msg (39)MM_KEY_DEL_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0\x0d
[ 219.357568] >>> rwnx_cfg80211_del_key()
[ 219.357585] >>> rwnx_send_key_del()
[ 219.357605] rwnx_send_msg (39)MM_KEY_DEL_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0\x0d
[ 219.357935] >>> rwnx_cfg80211_del_key()
[ 219.357951] >>> rwnx_send_key_del()
[ 219.357971] rwnx_send_msg (39)MM_KEY_DEL_CFM reqcfm:1 in_irq:0 in_softirq:0 in_atomic:0\x0d
# logcat
--------- beginning of system
12-28 10:19:00.001 393 474 V AlarmManager: setImplLocked type=3 ,when=227494
--------- beginning of main
12-28 10:19:00.006 542 542 D KeyguardClockSwitch: Updating clock: 10:19 AM
12-28 10:19:51.612 307 307 I wificond: Received external scan result notification from kernel.
12-28 10:19:51.613 393 667 D WificondControl: Scan result ready event
12-28 10:19:51.846 393 487 W WifiClientModeImpl: Connected to unknown networkId -1, disconnecting…
12-28 10:19:51.851 393 412 I EthernetTracker: interfaceLinkStateChanged, iface: wlan0, up: true
12-28 10:19:51.864 393 412 I EthernetTracker: interfaceLinkStateChanged, iface: wlan0, up: false
12-28 10:19:51.872 213 575 I netd : interfaceGetCfg(“wlan0”) <0.66ms>
12-28 10:19:51.875 213 575 I netd : interfaceGetCfg(“wlan0”) <0.60ms>
12-28 10:20:00.001 393 474 V AlarmManager: setImplLocked type=3 ,when=287494
12-28 10:20:00.007 542 542 D KeyguardClockSwitch: Updating clock: 10:20 AM
^C
130|
130|
130|
